AM5728: PCIe link status
Part Number: AM5728
Customer trying to verifying status of PCIe link-up between AM57x EVM and PCIe NIC Card
Could you verify which message should they use check to see the PCIe Gen 2 link status ?
    1. Just running “lspci” command, can they verify the PCIe Gen 2 link-up status ?
    1. Using lspci -vvv do they verify check “LinkCap” or “LinkCtl2” status as way to confirm link status?
  • Hi Lawrence,
    LinkCap and LinkCtl2 do not reflect the link status. If lspci command lists the NIC card entry, it means the link is up. If lspci only lists one entry which is the PCI bridge, it means the link is down.
  • Bin,
    Here is what my customer is seeing.  Can you confirm if the AM57x  automatically reduces PCIe speed to 2.5GT when the GEN 2 link-up fail ?
    Test #1: Pcie link-up with NIC at 5GT.
    root@am57xx-evm:~# lspci
    00:00.0 PCI bridge: Texas Instruments Multicore DSP+ARM KeyStone II SOC (rev 01)
    01:00.0 Ethernet controller: Toshiba America Info Systems Device 021a
    AM57x:
    LnkCap: Port #0, Speed 5GT/s, Width x2, ASPM L0s L1, Exit Latency L0s <512ns, L1 <64us
    LnkSta: Speed 5GT/s (ok), Width x1 (downgraded)
    LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis
    Neutrino:
    LnkCap: Port #0, Speed 5GT/s, Width x1, ASPM L0s L1, Exit Latency L0s <512ns, L1 <32us
    LnkSta: Speed 5GT/s (ok), Width x1 (ok)
    LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
    Test #2: Pcie Fails to link-up with NIC due to no power is presented to NIC.
    AM572x:
    LnkSta: Speed 2.5GT/s (downgraded), Width x1 (downgraded)
    Lawrence
  • Hi Lawrence,
    Yes, the PCI link negotiation starts from the lowest speed - 2.5GT, and sets to the highest successfully negotiated speed.
    In the test #2 you mentioned above, lspci command doesn't list the PCIe device, but you mentioned the NIC doesn't have power, so it is expected, isn't it?
