I am trying to get our kernel to boot on our custom hardware. I had built this kernel for BBB with different hardware and it worked. Im not sure what it is either looking for and not finding or where to start looking.
Any help would be appreciated!
I have attached the terminal print out. We have 128MiB ram, no RTC
U-Boot SPL 2018.01 (Aug 16 2019 - 09:45:08)
Trying to boot from MMC2
** Bad device mmc 0 **
Using default environment
Does this get printed?5
U-Boot 2018.01 (Aug 16 2019 - 09:45:08 -0700)
CPU : AM335X-GP rev 2.1
Model: TI AM335x EVM
DRAM: 128 MiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0
** No partition table - mmc 0 **
<ethaddr> not set. Validating first E-fuse MAC
Net: Does this get printed?
usb_ether
Hit any key to stop autoboot: 0
=> setenv fdtaddr 0x84000000; setenv fdt_addr_r 0x84000000; setenv loadaddr 0x80008000
=> usb start; setenv bootm_size 0x8000000; setenv bootfile zImage-initramfs
starting USB...
USB0: scanning bus 0 for devices... 1 USB Device(s) found
scanning usb for storage devices... 0 Storage Device(s) found
scanning usb for ethernet devices... 1 Ethernet Device(s) found
=> setenv bootargs console=${console} ${optargs} root=${ramroot} rootfstype=${ramrootfstype} earlyprintk
=> run findfdt; run netloadfdt; run netloadimage; bootz ${loadaddr} - ${fdtaddr}
using musb-hdrc, OUT ep1out IN ep1in STATUS ep2in
MAC 04:79:b7:02:9c:c4
HOST MAC de:ad:be:ef:00:00
RNDIS ready
Waiting for Ethernet connection... done.
Using sms0 device
TFTP from server 192.168.7.100; our IP address is 192.168.7.200
Filename 'am335x-evm.dtb'.
Load address: 0x84000000
Loading: ###
5.9 KiB/s
done
Bytes transferred = 32844 (804c hex)
Using sms0 device
Filename 'zImage-initramfs'.
Load address: 0x80008000
Loading: #################################################################
1.1 MiB/s
done
Bytes transferred = 10781184 (a48200 hex)
## Flattened Device Tree blob at 84000000
Booting using the fdt blob at 0x84000000
Loading Device Tree to 85f04000, end 85f0f04b ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.67-gd315a9bb00 (ebem@debian-64) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #2 PREEMPT Thu Aug 15 16:26:38 PDT 2019
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: TI AM335x EVM
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 48 MiB at 0x82800000
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (neon)
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32480
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/ram0 rw rootfstype=ext2 earlyprintk
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 61324K/131072K available (8192K kernel code, 316K rwdata, 2456K rodata, 7168K init, 275K bss, 20596K reserved, 49152K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xc8800000 - 0xff800000 ( 880 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc8000000 ( 128 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0900000 (9184 kB)
[ 0.000000] .init : 0xc0c00000 - 0xc1300000 (7168 kB)
[ 0.000000] .data : 0xc1300000 - 0xc134f388 ( 317 kB)
[ 0.000000] .bss : 0xc134f388 - 0xc139410c ( 276 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] OMAP clockevent source: timer2 at 25000000 Hz
[ 0.000020] sched_clock: 32 bits at 25MHz, resolution 40ns, wraps every 85899345900ns
[ 0.008169] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417870 ns
[ 0.017732] OMAP clocksource: timer1 at 25000000 Hz
[ 0.022990] timer_probe: no matching timers found
[ 0.028294] Console: colour dummy device 80x30
[ 0.032971] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.039782] This ensures that you still see kernel messages. Please
[ 0.046315] update your kernel commandline.
[ 0.050730] Calibrating delay loop... 795.44 BogoMIPS (lpj=3977216)
[ 0.089950] pid_max: default: 32768 minimum: 301
[ 0.095005] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.101898] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.110275] CPU: Testing write buffer coherency: ok
[ 0.116490] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.123538] Hierarchical SRCU implementation.
[ 0.128524] EFI services will not be available.
[ 0.134846] devtmpfs: initialized
[ 0.146333] random: get_random_u32 called from bucket_table_alloc+0x8c/0x1ac with crng_init=0
[ 0.155902] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.164338] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.174583] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.185847] pinctrl core: initialized pinctrl subsystem
[ 0.192296] DMI not present or invalid.
[ 0.196993] NET: Registered protocol family 16
[ 0.204667] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.226151] omap_hwmod: debugss: _wait_target_disable failed
[ 0.232323] Unhandled fault: external abort on non-linefetch (0x1028) at 0xf9e3e078
[ 0.240278] pgd = c0004000
[ 0.243143] [f9e3e078] *pgd=44e11452(bad)
[ 0.247366] Internal error: : 1028 [#1] PREEMPT ARM
[ 0.252462] Modules linked in:
[ 0.255697] CPU: 0 PID: 1 Comm: swapper Not tainted 4.14.67-gd315a9bb00 #2
[ 0.262849] Hardware name: Generic AM33XX (Flattened Device Tree)
[ 0.269192] task: c7038000 task.stack: c703c000
[ 0.273949] PC is at _update_sysc_cache+0x38/0x90
[ 0.278870] LR is at _enable+0x1ac/0x284
[ 0.282981] pc : [<c011ae6c>] lr : [<c011b5e0>] psr: 40000013
[ 0.289504] sp : c703de60 ip : 00000000 fp : c703de6c
[ 0.294958] r10: c134f3c0 r9 : 000000d0 r8 : c0c3b820
[ 0.300410] r7 : c130b3d4 r6 : c134f8f4 r5 : 00000000 r4 : c130ae80
[ 0.307202] r3 : c130ae80 r2 : f9e3e078 r1 : c130b95c r0 : 00000078
[ 0.313996] Flags: nZcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
[ 0.321409] Control: 10c5387d Table: 80004019 DAC: 00000051
[ 0.327398] Process swapper (pid: 1, stack limit = 0xc703c208)
[ 0.333477] Stack: (0xc703de60 to 0xc703e000)
[ 0.338047] de60: c703de94 c703de70 c011b5e0 c011ae40 c130ae80 c1309b84 c130ae80 c130aeb0
[ 0.346542] de80: c130aec4 c134f3c0 c703dec4 c703de98 c0c0b044 c011b440 c703dec4 c703dea8
[ 0.355039] dea0: c011a114 c0830bc0 c1307ec8 c130ae80 c1307f20 c0c0b460 c703dedc c703dec8
[ 0.363533] dec0: c0c0b554 c0c0af80 ffffe000 00000000 c703df4c c703dee0 c0101a18 c0c0b46c
[ 0.372025] dee0: c703df4c c703def0 c0145600 c0c00624 c0a9b864 c0a9b844 c0a9b890 c0aa59d8
[ 0.380521] df00: 00000000 c0a9b81c 00000002 00000002 c0a92d2c c0b64504 c7fffc79 00000000
[ 0.389014] df20: 00000000 c0b64504 00000003 c0b64504 c0c4c360 00000003 c134f3c0 c0c3b820
[ 0.397505] df40: c703df94 c703df50 c0c00eb4 c01019d8 00000002 00000002 00000000 c0c00618
[ 0.405995] df60: 00000000 c0c00618 00000000 00000000 c0835f38 00000000 00000000 00000000
[ 0.414489] df80: 00000000 00000000 c703dfac c703df98 c0835f48 c0c00d78 00000000 c0835f38
[ 0.422981] dfa0: 00000000 c703dfb0 c0107ea8 c0835f44 00000000 00000000 00000000 00000000
[ 0.431474] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.439971] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[ 0.448456] Backtrace:
[ 0.451063] [<c011ae34>] (_update_sysc_cache) from [<c011b5e0>] (_enable+0x1ac/0x284)
[ 0.459211] [<c011b434>] (_enable) from [<c0c0b044>] (_setup.part.12+0xd0/0x404)
[ 0.466899] r7:c134f3c0 r6:c130aec4 r5:c130aeb0 r4:c130ae80
[ 0.472803] [<c0c0af74>] (_setup.part.12) from [<c0c0b554>] (__omap_hwmod_setup_all+0xf4/0x108)
[ 0.481827] r6:c0c0b460 r5:c1307f20 r4:c130ae80
[ 0.486666] [<c0c0b460>] (__omap_hwmod_setup_all) from [<c0101a18>] (do_one_initcall+0x4c/0x170)
[ 0.495774] r5:00000000 r4:ffffe000
[ 0.499544] [<c01019cc>] (do_one_initcall) from [<c0c00eb4>] (kernel_init_freeable+0x148/0x1e4)
[ 0.508573] r8:c0c3b820 r7:c134f3c0 r6:00000003 r5:c0c4c360 r4:c0b64504
[ 0.515559] [<c0c00d6c>] (kernel_init_freeable) from [<c0835f48>] (kernel_init+0x10/0x114)
[ 0.524141] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0835f38
[ 0.532270] r4:00000000
[ 0.534968] [<c0835f38>] (kernel_init) from [<c0107ea8>] (ret_from_fork+0x14/0x2c)
[ 0.542825] r5:c0835f38 r4:00000000
[ 0.546590] Code: e5932054 e31c0c01 e0822000 1a000009 (e5922000)
[ 0.552967] ---[ end trace ad0498c0a2262fd0 ]---
[ 0.557890] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 0.557890]
[ 0.567464] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 0.567464]
[ 2.903403] random: fast init done
[ 134.103463] random: crng init done
DRAM: 128 MiB
NAND: 0 MiB
MMC: OMAP SD/MMC: 0
usb_ether
starting USB...
RNDIS ready
Using sms0 device
Loading: ###
5.9 KiB/s
done
Bytes transferred = 32848 (8050 hex)
Using sms0 device
1.1 MiB/s
done
Loading Device Tree to 85f04000, end 85f0f04f ... OK
Starting kernel ...
[ 0.000019] sched_clock: 32 bits at 25MHz, resolution 40ns, wraps every 85899345900ns
[ 0.008165] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 76450417870 ns
[ 0.022993] timer_probe: no matching timers found
[ 0.028289] Console: colour dummy device 80x30
[ 0.032967] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[ 0.039784] This ensures that you still see kernel messages. Please
[ 0.046319] update your kernel commandline.
[ 0.050736] Calibrating delay loop... 795.44 BogoMIPS (lpj=3977216)
[ 0.089946] pid_max: default: 32768 minimum: 301
[ 0.095000] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.101889] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.110262] CPU: Testing write buffer coherency: ok
[ 0.116469] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.123519] Hierarchical SRCU implementation.
[ 0.128507] EFI services will not be available.
[ 0.134824] devtmpfs: initialized
[ 0.146316] random: get_random_u32 called from bucket_table_alloc+0x8c/0x1ac with crng_init=0
[ 0.155874] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.164325] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.174564] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.185790] pinctrl core: initialized pinctrl subsystem
[ 0.192234] DMI not present or invalid.
[ 0.196928] NET: Registered protocol family 16
[ 0.204601] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.226078] omap_hwmod: debugss: _wait_target_disable failed
[ 0.232277] Unhandled fault: external abort on non-linefetch (0x1028) at 0xf9e3e078
[ 0.240234] pgd = c0004000
[ 0.243102] [f9e3e078] *pgd=44e11452(bad)
[ 0.247325] Internal error: : 1028 [#1] PREEMPT ARM
[ 0.252422] Modules linked in:
[ 0.255657] CPU: 0 PID: 1 Comm: swapper Not tainted 4.14.67-gd315a9bb00 #2
[ 0.262807] Hardware name: Generic AM33XX (Flattened Device Tree)
[ 0.269152] task: c7038000 task.stack: c703c000
[ 0.273909] PC is at _update_sysc_cache+0x38/0x90
[ 0.278830] LR is at _enable+0x1ac/0x284
[ 0.282943] pc : [<c011ae6c>] lr : [<c011b5e0>] psr: 40000013
[ 0.289466] sp : c703de60 ip : 00000000 fp : c703de6c
[ 0.294919] r10: c134f3c0 r9 : 000000d0 r8 : c0c3b820
[ 0.300371] r7 : c130b3d4 r6 : c134f8f4 r5 : 00000000 r4 : c130ae80
[ 0.307165] r3 : c130ae80 r2 : f9e3e078 r1 : c130b95c r0 : 00000078
[ 0.313963] Flags: nZcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
[ 0.321383] Control: 10c5387d Table: 80004019 DAC: 00000051
[ 0.327367] Process swapper (pid: 1, stack limit = 0xc703c208)
[ 0.333445] Stack: (0xc703de60 to 0xc703e000)
[ 0.338013] de60: c703de94 c703de70 c011b5e0 c011ae40 c130ae80 c1309b84 c130ae80 c130aeb0
[ 0.346502] de80: c130aec4 c134f3c0 c703dec4 c703de98 c0c0b044 c011b440 c703dec4 c703dea8
[ 0.354996] dea0: c011a114 c0830bc0 c1307ec8 c130ae80 c1307f20 c0c0b460 c703dedc c703dec8
[ 0.363487] dec0: c0c0b554 c0c0af80 ffffe000 00000000 c703df4c c703dee0 c0101a18 c0c0b46c
[ 0.371984] dee0: c703df4c c703def0 c0145600 c0c00624 c0a9b864 c0a9b844 c0a9b890 c0aa59d8
[ 0.380479] df00: 00000000 c0a9b81c 00000002 00000002 c0a92d2c c0b64504 c7fffc79 00000000
[ 0.388977] df20: 00000000 c0b64504 00000003 c0b64504 c0c4c360 00000003 c134f3c0 c0c3b820
[ 0.397466] df40: c703df94 c703df50 c0c00eb4 c01019d8 00000002 00000002 00000000 c0c00618
[ 0.405960] df60: 00000000 c0c00618 00000000 00000000 c0835f38 00000000 00000000 00000000
[ 0.414454] df80: 00000000 00000000 c703dfac c703df98 c0835f48 c0c00d78 00000000 c0835f38
[ 0.422948] dfa0: 00000000 c703dfb0 c0107ea8 c0835f44 00000000 00000000 00000000 00000000
[ 0.431442] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.439936] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[ 0.448419] Backtrace:
[ 0.451029] [<c011ae34>] (_update_sysc_cache) from [<c011b5e0>] (_enable+0x1ac/0x284)
[ 0.459172] [<c011b434>] (_enable) from [<c0c0b044>] (_setup.part.12+0xd0/0x404)
[ 0.466860] r7:c134f3c0 r6:c130aec4 r5:c130aeb0 r4:c130ae80
[ 0.472764] [<c0c0af74>] (_setup.part.12) from [<c0c0b554>] (__omap_hwmod_setup_all+0xf4/0x108)
[ 0.481789] r6:c0c0b460 r5:c1307f20 r4:c130ae80
[ 0.486626] [<c0c0b460>] (__omap_hwmod_setup_all) from [<c0101a18>] (do_one_initcall+0x4c/0x170)
[ 0.495740] r5:00000000 r4:ffffe000
[ 0.499509] [<c01019cc>] (do_one_initcall) from [<c0c00eb4>] (kernel_init_freeable+0x148/0x1e4)
[ 0.508538] r8:c0c3b820 r7:c134f3c0 r6:00000003 r5:c0c4c360 r4:c0b64504
[ 0.515522] [<c0c00d6c>] (kernel_init_freeable) from [<c0835f48>] (kernel_init+0x10/0x114)
[ 0.524100] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0835f38
[ 0.532229] r4:00000000
[ 0.534930] [<c0835f38>] (kernel_init) from [<c0107ea8>] (ret_from_fork+0x14/0x2c)
[ 0.542795] r5:c0835f38 r4:00000000
[ 0.546560] Code: e5932054 e31c0c01 e0822000 1a000009 (e5922000)
[ 0.552939] ---[ end trace ad0498c0a2262fd0 ]---
[ 0.557866] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 0.557866]
[ 0.567438] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 0.567438]
[ 2.903393] random: fast init done
[ 134.103452] random: crng init done
