hi
usb driver use DMA channel on the davinci dm355 .
capture.c have included memory mapping,why not to use memory mapping in the usb driver in order to usb speed ?
I do not know how to modify to improve usb speed?
please give me some advice!!!
/* Map the allocated buffers to user space */
for (numCapBufs = 0; numCapBufs < req.count; numCapBufs++) {
CLEAR(buf);
buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
buf.memory = V4L2_MEMORY_MMAP;
buf.index = numCapBufs;
if (ioctl(fd, VIDIOC_QUERYBUF, &buf) == -1) {
ERR("Failed VIDIOC_QUERYBUF on %s (%s)\n", V4L2_DEVICE,
strerror(errno));
return FAILURE;
the following source files from the davinci dm355 demo
capture.c
* Copyright (c) Texas Instruments Inc 2007
* Use of this software is controlled by the terms and conditions found in the
* license agreement under which this software has been supplied or provided.
/* Standard Linux headers */
#include <stdio.h>
#include <fcntl.h>
#include <errno.h>
#include <stdlib.h>
#include <string.h>
#include <unistd.h>
#include <sys/mman.h>
#include <sys/ioctl.h>
#include <asm/types.h>
#include <linux/videodev2.h>
/* Davinci specific kernel headers */
#include <media/davinci/davinci_vpfe.h>
#include <media/davinci/tvp5146.h>
/* Demo headers */
#include <rendezvous.h>
#include <fifoutil.h>
#include <rszcopy.h>
#include <smooth.h>
#include <pause.h>
#include "encode.h"
#include "capture.h"
#include "video.h"
#include "display.h"
/* Number of retries finding a video source before failing */
#define NUM_IOCTL_RETRIES 100
/* Triple buffering for the capture driver */
#define NUM_CAPTURE_BUFS 3
/* The smooth module needs extra input rows for proper processing */
#define EXTRA_TOP_ROWS 2
#define EXTRA_BOTTOM_ROWS 4
#define EXTRA_ROWS EXTRA_TOP_ROWS + EXTRA_BOTTOM_ROWS
/* Describes a capture frame buffer */
typedef struct CaptureBuffer {
void *start;
unsigned long offset;
size_t length;
} CaptureBuffer;
/* Local function prototypes */
static int initCaptureDevice(CaptureBuffer **capBufsPtr, int *numCapBufsPtr,
int svideoInput, int captureWidth,
int captureHeight, int topOffset);
static void cleanupCaptureDevice(int fd, CaptureBuffer *capBufs,
int numCapBufs, int topOffset);
* initCaptureDevice
int failCount = 0;
struct v4l2_requestbuffers req;
struct v4l2_capability cap;
struct v4l2_cropcap cropCap;
struct v4l2_crop crop;
struct v4l2_format fmt;
struct v4l2_buffer buf;
enum v4l2_buf_type type;
v4l2_std_id std;
int input;
int fd;
CaptureBuffer *capBufs;
int numCapBufs;
int ret;
DBG("captureWidth = %d, captureHeight = %d\n", captureWidth, captureHeight);
/* Open video capture device */
fd = open(V4L2_DEVICE, O_RDWR | O_NONBLOCK, 0);
if (fd == -1) {
ERR("Cannot open %s (%s)\n", V4L2_DEVICE, strerror(errno));
return FAILURE;
/* Select the video input */
if (svideoInput == TRUE) {
input = TVP5146_AMUX_SVIDEO;
else {
input = TVP5146_AMUX_COMPOSITE;
if (ioctl(fd, VIDIOC_S_INPUT, &input) == -1) {
ERR("Failed to set video input to %d\n", input);
return FAILURE;
DBG("Set the capture input to id %d\n", input);
/* Query for capture device capabilities */
if (ioctl(fd, VIDIOC_QUERYCAP, &cap) == -1) {
if (errno == EINVAL) {
ERR("%s is no V4L2 device\n", V4L2_DEVICE);
return FAILURE;
ERR("Failed VIDIOC_QUERYCAP on %s (%s)\n", V4L2_DEVICE,
strerror(errno));
return FAILURE;
if (!(cap.capabilities & V4L2_CAP_VIDEO_CAPTURE)) {
ERR("%s is no video capture device\n", V4L2_DEVICE);
return FAILURE;
if (!(cap.capabilities & V4L2_CAP_STREAMING)) {
ERR("%s does not support streaming i/o\n", V4L2_DEVICE);
return FAILURE;
cropCap.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
if (ioctl(fd, VIDIOC_CROPCAP, &cropCap) == -1) {
ERR("VIDIOC_CROPCAP failed %d, %s\n", errno, strerror(errno));
return FAILURE;
/* Auto detect PAL or NTSC using the capture driver as sanity check */
std = VPFE_STD_AUTO;
if(ioctl(fd, VIDIOC_S_STD, &std) == -1) {
ERR("VIDIOC_S_STD (auto) failed on %s (%s)\n", V4L2_DEVICE,
strerror(errno));
return FAILURE;
DBG("Checking video standard\n");
/* It might take a few tries to detect the signal */
do {
ret = ioctl(fd, VIDIOC_QUERYSTD, &std);
if (ret == -1 && errno == EAGAIN) {
usleep(1);
failCount++;
} while (ret == -1 && errno == EAGAIN && failCount < NUM_IOCTL_RETRIES);
if (ret == -1) {
printf("VIDIOC_QUERYSTD failed on %s. Video input connected?\n",
V4L2_DEVICE);
return FAILURE;
switch (std) {
case V4L2_STD_NTSC:
DBG("NTSC camera detected\n");
if (gblGetYFactor() == PALSTD) {
ERR("NTSC camera connected but PAL selected.\n");
return FAILURE;
break;
case V4L2_STD_PAL:
DBG("PAL camera detected\n");
if (gblGetYFactor() == NTSCSTD) {
ERR("PAL camera connected but NTSC selected.\n");
return FAILURE;
break;
default:
ERR("Camera (%s) using unsupported video standard\n", V4L2_DEVICE);
return FAILURE;
/* Use either NTSC or PAL depending on display kernel parameter */
std = gblGetYFactor() == NTSCSTD ? V4L2_STD_NTSC : V4L2_STD_PAL;
ERR("VIDIOC_S_STD failed on %s (%s)\n", V4L2_DEVICE,
strerror(errno));
return FAILURE;
/* Set the video capture image format */
CLEAR(fmt);
fmt.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
fmt.fmt.pix.width = D1_WIDTH;
fmt.fmt.pix.height = D1_HEIGHT;
fmt.fmt.pix.pixelformat = V4L2_PIX_FMT_UYVY;
fmt.fmt.pix.field = V4L2_FIELD_INTERLACED;
/* Set the video capture format */
if (ioctl(fd, VIDIOC_S_FMT, &fmt) == -1) {
ERR("VIDIOC_S_FMT failed on %s (%s)\n", V4L2_DEVICE,
strerror(errno));
return FAILURE;
crop.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
crop.c.left = D1_WIDTH / 2 - captureWidth / 2;
crop.c.top = D1_HEIGHT / 2 - captureHeight / 2;
crop.c.width = captureWidth;
* Note that we are optionally capturing 2 extra rows at the top and 4 at
* the bottom to have more valid image data to work with while removing
* interlacing artifacts.
crop.c.height = topOffset ? captureHeight + EXTRA_ROWS : captureHeight;
DBG("Setting capture cropping (%dx%d)\n", crop.c.width, crop.c.height);
/* Crop the image depending on requested image size */
if (ioctl(fd, VIDIOC_S_CROP, &crop) == -1) {
ERR("VIDIOC_S_CROP failed %d, %s\n", errno, strerror(errno));
return FAILURE;
printf("Capturing %dx%d video (cropped to %dx%d)\n",
fmt.fmt.pix.width, fmt.fmt.pix.height, crop.c.width, crop.c.height);
CLEAR(req);
req.count = NUM_CAPTURE_BUFS;
req.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
req.memory = V4L2_MEMORY_MMAP;
/* Allocate buffers in the capture device driver */
if (ioctl(fd, VIDIOC_REQBUFS, &req) == -1) {
ERR("VIDIOC_REQBUFS failed on %s (%s)\n", V4L2_DEVICE,
strerror(errno));
return FAILURE;
DBG("%d capture buffers were successfully allocated.\n", req.count);
if (req.count < NUM_CAPTURE_BUFS) {
ERR("Insufficient buffer memory on %s\n", V4L2_DEVICE);
return FAILURE;
capBufs = calloc(req.count, sizeof(*capBufs));
if (!capBufs) {
ERR("Failed to allocate memory for capture buffer structs.\n");
return FAILURE;
CLEAR(buf);
strerror(errno));
return FAILURE;
capBufs[numCapBufs].length = buf.length;
capBufs[numCapBufs].offset = buf.m.offset + topOffset;
capBufs[numCapBufs].start = mmap(NULL,
buf.length,
PROT_READ | PROT_WRITE,
MAP_SHARED,
fd, buf.m.offset) + topOffset;
if (capBufs[numCapBufs].start == MAP_FAILED) {
ERR("Failed to mmap buffer on %s (%s)\n", V4L2_DEVICE,
strerror(errno));
return FAILURE;
DBG("Capture driver buffer %d at physical address %lu mapped to "
"virtual address %#lx\n", numCapBufs, (unsigned long)
capBufs[numCapBufs].start, capBufs[numCapBufs].offset);
if (ioctl(fd, VIDIOC_QBUF, &buf) == -1) {
ERR("VIODIOC_QBUF failed on %s (%s)\n", V4L2_DEVICE,
strerror(errno));
return FAILURE;
/* Start the video streaming */
if (ioctl(fd, VIDIOC_STREAMON, &type) == -1) {
ERR("VIDIOC_STREAMON failed on %s (%s)\n", V4L2_DEVICE,
strerror(errno));
return FAILURE;
*capBufsPtr = capBufs;
*numCapBufsPtr = numCapBufs;
return fd;
* cleanupCaptureDevice
unsigned int i;
/* Shut off the video capture */
if (ioctl(fd, VIDIOC_STREAMOFF, &type) == -1) {
ERR("VIDIOC_STREAMOFF failed (%s)\n", strerror(errno));
if (close(fd) == -1) {
ERR("Failed to close capture device (%s)\n", strerror(errno));
for (i = 0; i < numCapBufs; i++) {
if (munmap(capBufs[i].start - topOffset, capBufs[i].length) == -1) {
ERR("Failed to unmap capture buffer %d\n", i);
free(capBufs);
* captureThrFxn
void *captureThrFxn(void *arg)
CaptureBufferElement cFlush = { CAPTURE_FLUSH };
DisplayBufferElement dFlush = { DISPLAY_FLUSH };
CaptureEnv *envp = (CaptureEnv *) arg;
Rszcopy_Handle hRszcopy = RSZCOPY_FAILURE;
Smooth_Handle hSmooth = SMOOTH_FAILURE;
void *status = THREAD_SUCCESS;
int captureFd = FAILURE;
int topOffset = 0;
struct v4l2_buffer v4l2buf;
unsigned int numCapBufs;
DisplayBufferElement de;
CaptureBufferElement ce;
/* Include more rows than necessary for the smoother if applicable */
if (envp->captureOp == CAPOP_SMOOTH &&
envp->imageHeight + EXTRA_ROWS <= D1_HEIGHT) {
topOffset = envp->imageWidth * EXTRA_TOP_ROWS * SCREEN_BPP / 8;
/* Initialize the video capture device */
captureFd = initCaptureDevice(&capBufs, &numCapBufs, envp->svideoInput,
envp->imageWidth, envp->imageHeight,
topOffset);
if (captureFd == FAILURE) {
cleanup(THREAD_FAILURE);
DBG("Video capture initialized and started\n");
if (envp->captureOp == CAPOP_COPY) {
/* If no interlacing artifact removal, just copy the frame */
hRszcopy = Rszcopy_create(RSZCOPY_DEFAULTRSZRATE);
if (hRszcopy == RSZCOPY_FAILURE) {
ERR("Failed to create resize job\n");
if (Rszcopy_config(hRszcopy, envp->imageWidth, envp->imageHeight,
envp->imageWidth * SCREEN_BPP / 8,
envp->imageWidth * SCREEN_BPP / 8) == RSZCOPY_FAILURE) {
ERR("Failed to configure resize job\n");
else {
/* Use the Smooth module to remove interlacing artifacts */
hSmooth = Smooth_create(SMOOTH_DEFAULTRSZRATE);
if (hSmooth == SMOOTH_FAILURE) {
ERR("Failed to create smoother\n");
if (Smooth_config(hSmooth, envp->imageWidth,
envp->imageHeight) == SMOOTH_FAILURE) {
ERR("Failed to configure smooth job\n");
/* Signal that initialization is done and wait for other threads */
Rendezvous_meet(envp->hRendezvousInit);
DBG("Entering capture main loop.\n");
while (!gblGetQuit()) {
/* Pause processing? */
Pause_test(envp->hPause);
CLEAR(v4l2buf);
v4l2buf.type = V4L2_BUF_TYPE_VIDEO_CAPTURE;
v4l2buf.memory = V4L2_MEMORY_MMAP;
/* Get a frame buffer with captured data */
if (ioctl(captureFd, VIDIOC_DQBUF, &v4l2buf) == -1) {
if (errno == EAGAIN) {
continue;
ERR("VIDIOC_DQBUF failed (%s)\n", strerror(errno));
breakLoop(THREAD_FAILURE);
de.virtBuf = capBufs[v4l2buf.index].start;
de.physBuf = capBufs[v4l2buf.index].offset;
de.width = envp->imageWidth;
de.height = envp->imageHeight;
/* Display raw frame while encoding it */
if (FifoUtil_put(envp->hDisplayInFifo, &de) == FIFOUTIL_FAILURE) {
ERR("Failed to put buffer in output fifo\n");
/* Receive buffers to fill in from the video thread */
if (FifoUtil_get(&envp->inFifo, &ce) == FIFOUTIL_FAILURE) {
/* Is the video thread flushing the pipe? */
if (ce.id == CAPTURE_FLUSH) {
breakLoop(THREAD_SUCCESS);
/* Process input frame by copying or deinterlacing */
if (Rszcopy_execute(hRszcopy, capBufs[v4l2buf.index].offset,
ce.physBuf) == RSZCOPY_FAILURE) {
ERR("Failed to resize frame\n");
else {
if (Smooth_execute(hSmooth, capBufs[v4l2buf.index].offset,
ce.physBuf) == SMOOTH_FAILURE) {
ERR("Failed to smooth frame\n");
/* Send frames to video thread for encoding */
if (FifoUtil_put(&envp->outFifo, &ce) == FIFOUTIL_FAILURE) {
ERR("Failed to put buffer in input fifo\n");
/* Receive a buffer with a displayed frame from the display thread */
if (FifoUtil_get(envp->hDisplayOutFifo, &de) == FIFOUTIL_FAILURE) {
/* Is the display thread flushing the pipe? */
if (de.id == DISPLAY_FLUSH) {
/* Issue captured frame buffer back to device driver */
if (ioctl(captureFd, VIDIOC_QBUF, &v4l2buf) == -1) {
ERR("VIDIOC_QBUF failed (%s)\n", strerror(errno));
cleanup:
/* Make sure the other threads aren't waiting for init to complete */
Rendezvous_force(envp->hRendezvousInit);
/* Make sure the other threads aren't stuck pausing */
Pause_off(envp->hPause);
/* Make sure the video thread isn't stuck in FifoUtil_get() */
FifoUtil_put(&envp->outFifo, &cFlush);
/* Make sure the display thread isn't stuck in FifoUtil_get() */
FifoUtil_put(envp->hDisplayInFifo, &dFlush);
/* Meet up with other threads before cleaning up */
Rendezvous_meet(envp->hRendezvousCleanup);
/* Clean up the capture thread */
if (hRszcopy != RSZCOPY_FAILURE) {
Rszcopy_delete(hRszcopy);
if (hSmooth != SMOOTH_FAILURE) {
Smooth_delete(hSmooth);
if (captureFd != FAILURE) {
cleanupCaptureDevice(captureFd, capBufs, numCapBufs, topOffset);
return status;
