I recently upgraded my tool from CCSv4.1.1 to 4.2.0, also upgraded the c6000 tools from 6.1.12 to 6.1.18. Now I am receiving the following warnings while compiling my RTSC configuration project. Could you please help me to resolve them.
C:\Program Files\Texas Instruments\ccsv4\utils\gmake\gmake -k all
'Building target: configPkg/linker.cmd'
'Invoking: XDCtools'
"C:/Program Files/Texas Instruments/xdctools_3_16_02_32/xs"
--xdcpath="C:/Program Files/Texas
Instruments/bios_6_21_00_13/packages;C:/Program Files/Texas
Instruments/xdais_6_25_01_08/packages;C:/Program Files/Texas
Instruments/xdais_6_25_01_08/examples;" xdc.tools.configuro -o configPkg
-t ti.targets.C64P -p ti.platforms.evm6424 -r whole_program_debug -c
"C:/Program Files/Texas Instruments/ccsv4/tools/compiler/C6000 Code
Generation Tools 6.1.18" "../McBSPConfig.cfg"
making package.mak (because of package.bld) ...
generating interfaces for package configPkg (because
package/package.xdc.inc is older than package.xdc) ...
configuring McBSPConfig.p64P from package/cfg/McBSPConfig_p64P.cfg ...
cl64P package/cfg/McBSPConfig_p64P.c ...
lnk64P McBSPConfig.p64P ...
"/db/rtree/install/trees/products/xdcprod-l18/product/Linux/xdctools_3_1
6_00_18/packages/xdc/runtime/System.c", line 443: warning:
relocation from function "xdc_runtime_System_doPrint__I" to symbol
"__remu"
overflowed; the 26-bit relocated address 0xecde638 is too large to
encode in
the 21-bit signed PC-Relative field (type = 'R_C60PCR21' (82), file =
"C:\TEMP\011122.obj", offset = 0x000006d0, section =
"[33].text:_xdc_runtime_System_doPrint__I")
6_00_18/packages/xdc/runtime/System.c", line 444: warning:
"__divu"
overflowed; the 26-bit relocated address 0xecde630 is too large to
encode in
"C:\TEMP\011122.obj", offset = 0x000006f4, section =
"__remu"
overflowed; the 26-bit relocated address 0xecde628 is too large to
encode in
"C:\TEMP\011122.obj", offset = 0x00000708, section =
"__remu"
overflowed; the 26-bit relocated address 0xecde600 is too large to
encode in
"C:\TEMP\011122.obj", offset = 0x000007a8, section =
6_00_18/packages/xdc/runtime/System.c", line 446: warning:
"__divu"
overflowed; the 26-bit relocated address 0xecde5f0 is too large to
encode in
"C:\TEMP\011122.obj", offset = 0x000007e0, section =
"__remu"
encode in
"C:\TEMP\011122.obj", offset = 0x000007f0, section =
"package/cfg/McBSPConfig_p64P.c", line 2333: warning: relocation from
function
"xdc_runtime_SysMin_output__I" to symbol "_HOSTwrite" overflowed; the
26-bit
relocated address 0xecdc1f8 is too large to encode in the 21-bit
signed
offset = 0x0000001c, section =
"[0].text:_xdc_runtime_SysMin_output__I")
function
26-bit
relocated address 0xecdc1e8 is too large to encode in the 21-bit
signed
offset = 0x00000058, section =
function
"xdc_runtime_SysMin_flush__F" to symbol "_HOSTwrite" overflowed; the
26-bit
relocated address 0xecdcfb0 is too large to encode in the 21-bit
signed
offset = 0x0000005c, section =
"[29].text:_xdc_runtime_SysMin_flush__F")
function
26-bit
relocated address 0xecdcfa0 is too large to encode in the 21-bit
signed
offset = 0x00000098, section =
function
26-bit
relocated address 0xecdcf90 is too large to encode in the 21-bit
signed
offset = 0x000000c0, section =
function
26-bit
relocated address 0xecdcf88 is too large to encode in the 21-bit
signed
offset = 0x000000fc, section =
6_00_18/packages/xdc/runtime/Error.c", line 32: warning:
relocation from function "xdc_runtime_Error_init__F" to symbol
"_memset"
overflowed; the 26-bit relocated address 0xecdba50 is too large to
encode in
"C:\TEMP\011122.obj", offset = 0x00000010, section =
"[38].text:_xdc_runtime_Error_init__F")
6_00_18/packages/xdc/runtime/System.c", line 54: warning:
relocation from function "xdc_runtime_System_abort__F" to symbol
"_abort"
overflowed; the 26-bit relocated address 0xecdc408 is too large to
encode in
"C:\TEMP\011122.obj", offset = 0x00000084, section =
"[33].text:_xdc_runtime_System_abort__F")
6_00_18/packages/xdc/runtime/Error.c", line 116: warning:
relocation from function "xdc_runtime_Error_raiseX__F" to symbol
"_memset"
overflowed; the 26-bit relocated address 0xecdd700 is too large to
encode in
"C:\TEMP\011122.obj", offset = 0x00000068, section =
"[38].text:_xdc_runtime_Error_raiseX__F")
6_00_18/packages/xdc/runtime/System.c", line 84: warning:
relocation from function "xdc_runtime_System_exit__F" to symbol
"_exit"
overflowed; the 26-bit relocated address 0xecdb4f0 is too large to
encode in
"C:\TEMP\011122.obj", offset = 0x0000000c, section =
"[33].text:_xdc_runtime_System_exit__F")
6_00_18/packages/xdc/runtime/Core_params.c", line 42: warning:
relocation from function "xdc_runtime_Core_assignParams__I" to symbol
"_memcpy" overflowed; the 26-bit relocated address 0xecdc468 is too
large to
encode in the 21-bit signed PC-Relative field (type = 'R_C60PCR21'
(82),
file = "C:\TEMP\011122.obj", offset = 0x00000044, section =
"[40].text:_xdc_runtime_Core_assignParams__I")
6_00_18/packages/xdc/runtime/Core_params.c", line 48: warning:
"_memcpy" overflowed; the 26-bit relocated address 0xecdc460 is too
large to
(82),
file = "C:\TEMP\011122.obj", offset = 0x00000064, section =
relocation from function "ti_sysbios_knl_Clock_Params__init__S" to
symbol
"_memcpy" overflowed; the 26-bit relocated address 0xecdc720 is too
large to
(82),
file = "C:\TEMP\011122.obj", offset = 0x0000005c, section =
"[0].text:_ti_sysbios_knl_Clock_Params__init__S")
6_00_18/packages/xdc/runtime/Core_params.c", line 45: warning:
symbol
"_memcpy" overflowed; the 26-bit relocated address 0xecdc718 is too
large to
(82),
file = "C:\TEMP\011122.obj", offset = 0x00000078, section =
"package/cfg/McBSPConfig_p64P.c", line 2597: warning: relocation from
function
"ti_sysbios_BIOS_exitFunc__I" to symbol "__register_lock" overflowed;
the
26-bit relocated address 0xecdc3c8 is too large to encode in the
21-bit
"C:\TEMP\011122.obj", offset = 0x00000040, section =
"[0].text:_ti_sysbios_BIOS_exitFunc__I")
function
"ti_sysbios_BIOS_exitFunc__I" to symbol "__register_unlock"
overflowed; the
21-bit
"C:\TEMP\011122.obj", offset = 0x00000058, section =
"Timer.c", line 510: warning: relocation from function
"ti_sysbios_timers_timer64_Timer_setPeriodMicroSecs__F" to symbol
"__divu"
overflowed; the 26-bit relocated address 0xecdd628 is too large to
encode in
"C:\TEMP\011122.obj", offset = 0x0000003c, section =
"[1].text:_ti_sysbios_timers_timer64_Timer_setPeriodMicroSecs__F")
"Timer.c", line 94: warning: relocation from function
"__divu"
overflowed; the 26-bit relocated address 0xecdd618 is too large to
encode in
"Timer.c", line 643: warning: relocation from function
"__divlli"
encode in
"C:\TEMP\011122.obj", offset = 0x0000007c, section =
"__divu"
overflowed; the 26-bit relocated address 0xecdd610 is too large to
encode in
"C:\TEMP\011122.obj", offset = 0x00000098, section =
"__divlli"
overflowed; the 26-bit relocated address 0xecdd600 is too large to
encode in
"C:\TEMP\011122.obj", offset = 0x000000c4, section =
"package/cfg/McBSPConfig_p64P.c", line 13525: warning: relocation from
function
"xdc_runtime_SysMin_Module_startup__E" to symbol "_memset"
overflowed; the
26-bit relocated address 0xecdba20 is too large to encode in the
21-bit
"[0].text:_xdc_runtime_SysMin_Module_startup__E")
6_00_18/packages/xdc/runtime/System.c", line 41: warning:
relocation from function "xdc_runtime_System_Module_startup__E" to
symbol
"_atexit" overflowed; the 26-bit relocated address 0xecdb508 is too
large to
(82),
file = "C:\TEMP\011122.obj", offset = 0x00000008, section =
"[0].text:_xdc_runtime_System_Module_startup__E")
"BIOS.c", line 67: warning: relocation from function
"ti_sysbios_BIOS_registerRTSLock__E" to symbol "__register_lock"
overflowed;
the 26-bit relocated address 0xecdc100 is too large to encode in the
21-bit
"C:\TEMP\011122.obj", offset = 0x00000024, section =
"[0].text:_ti_sysbios_BIOS_registerRTSLock__E")
"BIOS.c", line 68: warning: relocation from function
"ti_sysbios_BIOS_registerRTSLock__E" to symbol "__register_unlock"
overflowed; the 26-bit relocated address 0xecdc100 is too large to
encode in
"C:\TEMP\011122.obj", offset = 0x00000034, section =
"ti_sysbios_BIOS_startFunc__I" to symbol "__register_lock"
overflowed; the
26-bit relocated address 0xecdd470 is too large to encode in the
21-bit
"[0].text:_ti_sysbios_BIOS_startFunc__I")
"ti_sysbios_BIOS_startFunc__I" to symbol "__register_unlock"
overflowed; the
26-bit relocated address 0xecdd468 is too large to encode in the
21-bit
6_00_18/packages/xdc/runtime/Memory.c", line 119: warning:
relocation from function "xdc_runtime_Memory_calloc__E" to symbol
"_memset"
overflowed; the 26-bit relocated address 0xecdbe90 is too large to
encode in
"C:\TEMP\011122.obj", offset = 0x00000020, section =
"[0].text:_xdc_runtime_Memory_calloc__E")
6_00_18/packages/xdc/runtime/Core_mem.c", line 34: warning:
relocation from function "xdc_runtime_Core_createObject__I" to symbol
"_memcpy" overflowed; the 26-bit relocated address 0xecddc78 is too
large to
(82),
file = "C:\TEMP\011122.obj", offset = 0x00000028, section =
"[43].text:_xdc_runtime_Core_createObject__I")
"_memcpy" overflowed; the 26-bit relocated address 0xecddc58 is too
large to
(82),
file = "C:\TEMP\011122.obj", offset = 0x000000bc, section =
6_00_18/packages/xdc/runtime/Core_params.c", line 44: warning:
"_memcpy" overflowed; the 26-bit relocated address 0xecddc48 is too
large to
(82),
file = "C:\TEMP\011122.obj", offset = 0x000000ec, section =
"_memset" overflowed; the 26-bit relocated address 0xecddc30 is too
large to
(82),
file = "C:\TEMP\011122.obj", offset = 0x00000144, section =
6_00_18/packages/xdc/runtime/Core_mem.c", line 85: warning:
"_memset" overflowed; the 26-bit relocated address 0xecddc08 is too
large to
(82),
file = "C:\TEMP\011122.obj", offset = 0x000001f4, section =
"_memset" overflowed; the 26-bit relocated address 0xecddc00 is too
large to
(82),
file = "C:\TEMP\011122.obj", offset = 0x00000208, section =
relocation from function "ti_sysbios_ipc_Semaphore_pend__F" to symbol
"_memcpy" overflowed; the 26-bit relocated address 0xecddf68 is too
large to
(82),
file = "C:\TEMP\011122.obj", offset = 0x00000060, section =
"[4].text:_ti_sysbios_ipc_Semaphore_pend__F")
"_memcpy" overflowed; the 26-bit relocated address 0xecddf60 is too
large to
(82),
file = "C:\TEMP\011122.obj", offset = 0x00000094, section =
relocation from function "xdc_runtime_Memory_valloc__E" to symbol
"_memset"
overflowed; the 26-bit relocated address 0xecdbe60 is too large to
encode in
"[0].text:_xdc_runtime_Memory_valloc__E")
relocation from function "ti_sysbios_knl_Task_sleep__F" to symbol
"_memcpy"
overflowed; the 26-bit relocated address 0xecdda90 is too large to
encode in
"C:\TEMP\011122.obj", offset = 0x0000008c, section =
"[21].text:_ti_sysbios_knl_Task_sleep__F")
"_memcpy"
overflowed; the 26-bit relocated address 0xecdda80 is too large to
encode in
relocation from function "ti_sysbios_knl_Task_Params__init__S" to
symbol
"_memcpy" overflowed; the 26-bit relocated address 0xecdc6f0 is too
large to
(82),
"[0].text:_ti_sysbios_knl_Task_Params__init__S")
symbol
"_memcpy" overflowed; the 26-bit relocated address 0xecdc6e8 is too
large to
(82),
6_00_18/packages/xdc/runtime/Memory.c", line 117: warning:
relocation from function "ti_sysbios_knl_Task_Instance_init__F" to
symbol
"_memset" overflowed; the 26-bit relocated address 0xecddca8 is too
large to
(82),
file = "C:\TEMP\011122.obj", offset = 0x00000220, section =
"[21].text:_ti_sysbios_knl_Task_Instance_init__F")
relocation from function "ti_sysbios_ipc_Semaphore_Params__init__S"
to
symbol "_memcpy" overflowed; the 26-bit relocated address 0xecdc750
is too
large to encode in the 21-bit signed PC-Relative field (type =
'R_C60PCR21'
(82), file = "C:\TEMP\011122.obj", offset = 0x0000005c, section =
"[0].text:_ti_sysbios_ipc_Semaphore_Params__init__S")
to
symbol "_memcpy" overflowed; the 26-bit relocated address 0xecdc748
is too
'R_C60PCR21'
(82), file = "C:\TEMP\011122.obj", offset = 0x00000078, section =
relocation from function "ti_sysbios_ipc_Event_pend__F" to symbol
"_memcpy"
overflowed; the 26-bit relocated address 0xecde250 is too large to
encode in
"C:\TEMP\011122.obj", offset = 0x000000f4, section =
"[5].text:_ti_sysbios_ipc_Event_pend__F")
"_memcpy"
overflowed; the 26-bit relocated address 0xecde240 is too large to
encode in
"C:\TEMP\011122.obj", offset = 0x00000128, section =
relocation from function "ti_sysbios_ipc_Event_Params__init__S" to
symbol
"_memcpy" overflowed; the 26-bit relocated address 0xecdc780 is too
large to
(82),
"[0].text:_ti_sysbios_ipc_Event_Params__init__S")
symbol
"_memcpy" overflowed; the 26-bit relocated address 0xecdc778 is too
large to
(82),
relocation from function "ti_sysbios_heaps_HeapMem_Params__init__S"
to
symbol "_memcpy" overflowed; the 26-bit relocated address 0xecdc7b0
is too
'R_C60PCR21'
"[0].text:_ti_sysbios_heaps_HeapMem_Params__init__S")
to
symbol "_memcpy" overflowed; the 26-bit relocated address 0xecdc7a8
is too
'R_C60PCR21'
relocation from function "ti_sysbios_heaps_HeapBuf_Params__init__S"
to
symbol "_memcpy" overflowed; the 26-bit relocated address 0xecdc810
is too
'R_C60PCR21'
"[0].text:_ti_sysbios_heaps_HeapBuf_Params__init__S")
to
symbol "_memcpy" overflowed; the 26-bit relocated address 0xecdc808
is too
'R_C60PCR21'
relocation from function "ti_sysbios_family_c64p_Hwi_Params__init__S"
to
symbol "_memcpy" overflowed; the 26-bit relocated address 0xecdc870
is too
'R_C60PCR21'
"[0].text:_ti_sysbios_family_c64p_Hwi_Params__init__S")
to
symbol "_memcpy" overflowed; the 26-bit relocated address 0xecdc868
is too
'R_C60PCR21'
"autoinit.c", line 63: warning: relocation from function "_auto_init" to
symbol
"_memcpy" overflowed; the 26-bit relocated address 0xecdd210 is too
large to
(82),
file = "C:\TEMP\011122.obj", offset = 0x00000050, section =
"[45].text:__auto_init")
symbol
"_memcpy" overflowed; the 26-bit relocated address 0xecdd200 is too
large to
(82),
file = "C:\TEMP\011122.obj", offset = 0x00000084, section =
"boot.c", line 137: warning: relocation from function "c_int00" to
symbol
"_exit" overflowed; the 26-bit relocated address 0xecdc128 is too
large to
(82),
file = "C:\TEMP\011122.obj", offset = 0x00000040, section =
"[44].text:_c_int00")
'Finished building target: configPkg/linker.cmd'
Build complete for project EncodeApplicationSource_configuration
Smitha Joseph
