Linux/BEAGLEBK: 1-wire implementation
Part Number: BEAGLEBK
Tool/software: Linux
i supposed to implement one wire communication between beaglebone(as master) and controller(as slave)
after adding dtb file from command line can i check slave device is connected or not if it is DS series it will show but am using other controller as slave so how can i check
any suggession
  • Hello and thanks for your post. One wire is a community provided driver and TI does not modify it. Therefore, the kernel documentation and other online resources apply and should be helpful to help you get this up and running.
    Thank you.
