PROCESSOR-SDK-AM65X: RTOS examples
Guru 10255 points
Part Number: PROCESSOR-SDK-AM65X
Hi Sitara support Team,
I have tested sample programs in PROCESSOR-SDK-RTOS-AM65X 05_03_00_07.
Some programs are working without probles, but "udma_baremetal_dru_testapp"
and "udma_baremetal_dru_direct_tr_testapp" are working with the following error,
[Version Info.]
-CCS 8.3.0
-SDK AM65x 5.03.00.07
-PDK AM65x 1.0.4
-Run on Cortex-A53
UDMA DRU application started...
[Error] RM PSIL read failed!!!
[Error] PSI UTC destination thread enable failed!!!
[Error] TR Response not completed!!
[Error] UDMA App memcpy test failed!!
[Error] RM PSIL write failed!!!
[Error] PSIL write teardown failed!!
[Error] UDMA UTC disable failed!!
[Error] UDMA channel disable failed!!
[Error] UDMA event unregister failed!!
[Error] PSI UTC destination thread RT disable failed!!!
[Error] PSI UTC destination thread disable failed!!!
[Error] UDMA channel unparing failed!!
[Error] Free resource failed!!!
[Error] UDMA channel close failed!!
[Error] UDMA App delete failed!!
[Error] UDMA App deinit failed!!
UDMA DRU memcpy using TR15 block copy Failed!!
Some tests have failed!!
UDMA DRU Direct TR application started...
UDMA DRU memcpy using Direct TR15 block copy Failed!!
The following program is no problem.
"udma_memcpy_testapp"
UDMA memcpy application started...
UDMA memcpy using TR15 block copy Passed!!
All tests have passed!!
[Question]
Is there solution to this error?
Please share your environment when you test these programs.
Kanae
