Hello Support team.
I would like to know about Ethernet Switch feature of DAR829.
SO, I would like to know if this Ethernet Switch has TCAM(Ternary CAM) feature.
Br
KORO
Hello Support team.
Br
KORO
Hello Koro,
Can you please elaborate on the usage requirements for TCAM?
The DRA8x supports classifier/policer blocks which can classify/filter packets based on the L2/L3 header fields and also can take action like to drop, rate limit, filter packet.
Prasad
Hello Jondhale-san
Thanks a lot for your reply.
So, customer hopes to achieve more fast switching process by hardware table (TCAM) for security ACL, QoS ASL and searching at routing table.
Br
KORO
Hello Koro-san,
Thanks for the details use-case needs. Strictly speaking, our switch doesn't support the TCAM in it. Though all the above-mentioned requirements can be fulfilled by using other IP blocks of CPSW switch.
The classifier block can analyze packet contents like packet priority, OUI, src address, dest address, IP, etc. and take action like rate limit, filter it, etc. We also have hardware support for inter VLAN routing which can route packets among multiple VLANs.
So we should be able to meet customer requirements with these blocks. Hope this helps.
Prasad
