CCS/TMS320C5535: TIesr_C55_demo
Part Number: TMS320C5535
Build the demo once, a difficult task, but was successful. The demo ran well. Closed CCS(version 6). After a few hours, reopened CCS, tried to rebuild the project(s). Turns out to be impossible. Either STACK is undefined, or a system AIC function says variables are not correct, or something else. TIesr_C55_demo is missing a reference project csVL5505 that doesn't exist anymore. Regularly a project says as a warning that a project path is undefined, even though the project is there and compiles to a LIB. I also load an existing executable(.out) and start it, no complaints from CCS, and it's as nothing was done, the EZDSP5535 continues to show the "Play Audio From Your PC" rolling message. How can I introduce others to this process, using the same boards and tools, when I can't seem to have a repeatable solid TIesr build procedure myself. I would appreciate very much any help for a successful and repeatable building instructions. Currently I follow the ones from the documentation PDF, and it worked once.
Vladimir
  • everything is set by the book, and now I get these for codec_aic3254.c
            status = I2C_read(readBuff,
                            1,
                            I2C_CODEC_ADDR,
                            TRUE,
                            startStop,
                            CSL_I2C_MAX_TIMEOUT,
                            FALSE);
    too few arguments in a function call
    and
    argument of type "Bool" is incompatible with int16
    Help is appreciated.
    Vladimir
    P.S. The available pre-build executable started working.
    I'd like to point that C5535 devices are NRND, and you should consider transitioning to the recommended DPS C5517, which is supported currently.
    Check the following FAQ:
    Yordan
    My only goal at the moment, is to be able to build TIesr on the EZDSP5535 reliably. It worked once, it should work more than once. It was advertised for the 5535 and so it does work on it somewhere.  I need help in building the TIesr system on that particular platform,  EZDSP5535.
    Vladimir
  • Hello Vladimir,
    The expectation is you should be able to follow user guide to get it to work as is without modifications.
    If it is the same saved CCS project, without any changes in source code, CCS version and project setting, you should still be able to build it as is after you close CCS and open it again.
    What is the C5000 CSL version you are using? This is the latest version.
    software-dl.ti.com/.../index_FDS.html
    best regards,
    David Zhou
  • Hello Vladimir,
    I noticed you are using CCS v6. As per C5000 latest CSL's release notes which I copied/pasted below, it has dependency on CCS 7.3 or later version. So I would recommend you upgrade your CCS and use the latest CSL and then try esr demo again.
    Release 3.08.00 Dependencies
    DSP/BIOS 5.42.00.07 and DSP/BIOS 5.42.02.10
    CCS 7.3 or later
    best regards,
    David Zhou
  • Hi Vladimir,
    Before you build the CSL library, you may need to modify the c55_csl\c55xx_csl\inc\csl_general.h. By default it is configured for C5517. For C5535, you will need to comment out the following lines:
    #define CHIP_C5517 and
    #define CHIP_C5505_C5515
    Ming
    Here's what I have. It was exactly the same thing I had two days ago, when it compiled and ran fine. Not anymore. I followed all suggestions, and te documentation as well. What you see here is one of the reasons it doesn't build. The other was __STACK_ undefined, but it was at link time. Now I can't even get to link. Again, all the projects, setting, and tools were exactly the same as they used to be two days ago, when the thing worked.
    Vladimir
  • Bizzare, I can't see the screenshot myself, even though it was well visible on the reply box.
  • Did you install anything in the c:\ti folder in past two days?
  • This may be boring, but that's all I have as info. Here are all the build logs:
    **** Build of configuration Debug for project atafs_bios_drv_lib ****
    "C:\\ti\\ccsv6\\utils\\bin\\gmake" -k all
    'Building target: C:/c55xx_csl_3.00/c55_csl_3.08/ccs_v6.x_examples/drv/atafs/atafs_bios_drv_lib/../../../../ccs_v6.x_examples/drv/atafs/atafs_bios_drv_lib/Debug/atafs_bios_drv_lib.lib'
    'Invoking: C5500 Archiver'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/ar55" r "C:/c55xx_csl_3.00/c55_csl_3.08/ccs_v6.x_examples/drv/atafs/atafs_bios_drv_lib/../../../../ccs_v6.x_examples/drv/atafs/atafs_bios_drv_lib/Debug/atafs_bios_drv_lib.lib" "./Atadisk.obj" "./Atadiskfree.obj" "./ata.obj" "./ata_.obj" "./ata_bytes.obj" "./ata_bytes_seek.obj" "./ata_bytes_write.obj" "./ata_chdir.obj" "./ata_fileinit.obj" "./ata_flush.obj" "./ata_labels.obj" "./ata_labels_label.obj" "./ata_labels_vol.obj" "./ata_names.obj" "./ata_readword.obj" "./ata_sector.obj" "./ata_timeout.obj" "./ata_usb.obj" "./atacreate.obj" "./atacreate_findcluster.obj" "./atacreatedir.obj" "./atadir.obj" "./atadir_.obj" "./atadir__getdir.obj" "./atadirentry.obj" "./ataformat.obj" "./atalong.obj" "./atalong_create.obj" "./atalong_create_rename.obj" "./atalong_createentry.obj" "./atalong_setname.obj" "./ataread.obj" "./ataread_.obj" "./ataread__nextbroken.obj" "./ataread_calc.obj" "./ataread_fat.obj" "./ataread_fatphy.obj" "./ataseek.obj" "./ataseek_relative.obj" "./atatell.obj" "./atawrite.obj" "./atawrite_close.obj" "./atawrite_fat.obj" "./atawrite_fatphy.obj" "./atawrite_write.obj" "./version.obj"
      ==>  new archive 'C:/c55xx_csl_3.00/c55_csl_3.08/ccs_v6.x_examples/drv/atafs/atafs_bios_drv_lib/../../../../ccs_v6.x_examples/drv/atafs/atafs_bios_drv_lib/Debug/atafs_bios_drv_lib.lib'
      ==>  building archive 'C:/c55xx_csl_3.00/c55_csl_3.08/ccs_v6.x_examples/drv/atafs/atafs_bios_drv_lib/../../../../ccs_v6.x_examples/drv/atafs/atafs_bios_drv_lib/Debug/atafs_bios_drv_lib.lib'
    'Finished building target: C:/c55xx_csl_3.00/c55_csl_3.08/ccs_v6.x_examples/drv/atafs/atafs_bios_drv_lib/../../../../ccs_v6.x_examples/drv/atafs/atafs_bios_drv_lib/Debug/atafs_bios_drv_lib.lib'
    **** Build Finished ****
    **** Build of configuration Debug for project C55XXCSL_LP ****
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_audioClass.c'
    'Invoking: C5500 Compiler'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_audioClass.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_audioClass.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_audioClass.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_cdc.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_cdc.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_cdc.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_cdc.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_dat.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_dat.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_dat.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_dat.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_dma.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_dma.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_dma.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_dma.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_emif.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_emif.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_emif.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_emif.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_gpio.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_gpio.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_gpio.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_gpio.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_gpt.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_gpt.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_gpt.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_gpt.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_hid.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_hid.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_hid.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_hid.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_i2c.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_i2c.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_i2c.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_i2c.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_i2s.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_i2s.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_i2s.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_i2s.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_intc.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_intc.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_intc.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_intc.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_irqplug.asm'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_irqplug.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_irqplug.asm"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_irqplug.asm'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_lcdc.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_lcdc.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_lcdc.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_lcdc.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_mcbsp.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_mcbsp.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_mcbsp.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_mcbsp.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_mcspi.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_mcspi.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_mcspi.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_mcspi.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_mem.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_mem.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_mem.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_mem.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_mmcsd.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_mmcsd.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_mmcsd.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_mmcsd.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_mmcsd_ataIf.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_mmcsd_ataIf.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_mmcsd_ataIf.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_mmcsd_ataIf.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_msc.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_msc.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_msc.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_msc.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_pll.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_pll.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_pll.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_pll.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_rtc.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_rtc.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_rtc.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_rtc.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_sar.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_sar.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_sar.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_sar.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_sdio.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_sdio.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_sdio.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_sdio.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_spi.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_spi.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_spi.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_spi.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_sysctrl.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_sysctrl.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_sysctrl.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_sysctrl.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_uart.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_uart.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_uart.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_uart.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_uhpi.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_uhpi.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_uhpi.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_uhpi.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_usb.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_usb.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_usb.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_usb.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_wdt.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="csl_wdt.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_wdt.c"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/csl_wdt.c'
    'Building file: C:/c55xx_csl_3.00/c55_csl_3.08/src/vectors.asm'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/src" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tws3/C55XXCSL_LP/Debug" --define="_DEBUG" --define=c5535 --diag_warning=225 --ptrdiff_size=32 --algebraic --asm_source=algebraic --preproc_with_compile --preproc_dependency="vectors.pp"  "C:/c55xx_csl_3.00/c55_csl_3.08/src/vectors.asm"
    'Finished building: C:/c55xx_csl_3.00/c55_csl_3.08/src/vectors.asm'
    'Building target: C55XXCSL_LP.lib'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/ar55" r "C55XXCSL_LP.lib" "./csl_audioClass.obj" "./csl_cdc.obj" "./csl_dat.obj" "./csl_dma.obj" "./csl_emif.obj" "./csl_gpio.obj" "./csl_gpt.obj" "./csl_hid.obj" "./csl_i2c.obj" "./csl_i2s.obj" "./csl_intc.obj" "./csl_irqplug.obj" "./csl_lcdc.obj" "./csl_mcbsp.obj" "./csl_mcspi.obj" "./csl_mem.obj" "./csl_mmcsd.obj" "./csl_mmcsd_ataIf.obj" "./csl_msc.obj" "./csl_pll.obj" "./csl_rtc.obj" "./csl_sar.obj" "./csl_sdio.obj" "./csl_spi.obj" "./csl_sysctrl.obj" "./csl_uart.obj" "./csl_uhpi.obj" "./csl_usb.obj" "./csl_wdt.obj" "./vectors.obj"
      ==>  new archive 'C55XXCSL_LP.lib'
      ==>  building archive 'C55XXCSL_LP.lib'
    'Finished building target: C55XXCSL_LP.lib'
    **** Build of configuration Debug for project TIesrEngineC55 ****
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/dist.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=C55x --define=NO_FILE_IO --define=C55x_8KHZ --define=OWN_LOAD_FUNCTIONS --define=DSPBIOS_BUILD --define=c5535 --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --asm_listing --preproc_with_compile --preproc_dependency="dist.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/dist.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/dist.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/engine_sireco_init.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=C55x --define=NO_FILE_IO --define=C55x_8KHZ --define=OWN_LOAD_FUNCTIONS --define=DSPBIOS_BUILD --define=c5535 --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --asm_listing --preproc_with_compile --preproc_dependency="engine_sireco_init.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/engine_sireco_init.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/engine_sireco_init.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/gmhmm_type_common.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=C55x --define=NO_FILE_IO --define=C55x_8KHZ --define=OWN_LOAD_FUNCTIONS --define=DSPBIOS_BUILD --define=c5535 --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --asm_listing --preproc_with_compile --preproc_dependency="gmhmm_type_common.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/gmhmm_type_common.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/gmhmm_type_common.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/jac-estm.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=C55x --define=NO_FILE_IO --define=C55x_8KHZ --define=OWN_LOAD_FUNCTIONS --define=DSPBIOS_BUILD --define=c5535 --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --asm_listing --preproc_with_compile --preproc_dependency="jac-estm.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/jac-estm.c"
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/jac-estm.c", line 99: warning: variable "pnoisymu" was set but never used
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/jac-estm.c", line 104: warning: variable "long_diff" was declared but never referenced
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/jac-estm.c", line 104: warning: variable "longtemp" was declared but never referenced
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/jac-estm.c", line 105: warning: variable "diff_s" was declared but never referenced
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/jac-estm.c", line 105: warning: variable "weight" was declared but never referenced
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/jac-estm.c", line 106: warning: variable "invvar" was declared but never referenced
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/jac-estm.c", line 106: warning: variable "p_invvar" was declared but never referenced
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/jac-estm.c", line 680: warning: variable "d" was declared but never referenced
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/jac-estm.c", line 681: warning: variable "numFilters" was declared but never referenced
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/jac-estm.c", line 682: warning: variable "featDim" was declared but never referenced
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/jac-estm.c", line 683: warning: variable "numRead" was declared but never referenced
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/jac-estm.c", line 889: warning: variable "p_sym0" was set but never used
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/jac-estm.c", line 1036: warning: variable "last_lhd" was set but never used
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/jac-estm.c", line 1037: warning: variable "coeff_1" was set but never used
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/jac-estm.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/jac_one.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=C55x --define=NO_FILE_IO --define=C55x_8KHZ --define=OWN_LOAD_FUNCTIONS --define=DSPBIOS_BUILD --define=c5535 --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --asm_listing --preproc_with_compile --preproc_dependency="jac_one.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/jac_one.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/jac_one.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/liveproc.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=C55x --define=NO_FILE_IO --define=C55x_8KHZ --define=OWN_LOAD_FUNCTIONS --define=DSPBIOS_BUILD --define=c5535 --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --asm_listing --preproc_with_compile --preproc_dependency="liveproc.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/liveproc.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/liveproc.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/load.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=C55x --define=NO_FILE_IO --define=C55x_8KHZ --define=OWN_LOAD_FUNCTIONS --define=DSPBIOS_BUILD --define=c5535 --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --asm_listing --preproc_with_compile --preproc_dependency="load.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/load.c"
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/load.c", line 302: warning: variable "fp" was declared but never referenced
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/load.c", line 305: warning: variable "nread" was declared but never referenced
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/load.c", line 520: warning: variable "fp" was declared but never referenced
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/load.c", line 522: warning: variable "nread" was declared but never referenced
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/load.c", line 1130: warning: variable "fname" was declared but never referenced
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/load.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/mfcc_f.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=C55x --define=NO_FILE_IO --define=C55x_8KHZ --define=OWN_LOAD_FUNCTIONS --define=DSPBIOS_BUILD --define=c5535 --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --asm_listing --preproc_with_compile --preproc_dependency="mfcc_f.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/mfcc_f.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/mfcc_f.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/my_fileio.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=C55x --define=NO_FILE_IO --define=C55x_8KHZ --define=OWN_LOAD_FUNCTIONS --define=DSPBIOS_BUILD --define=c5535 --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --asm_listing --preproc_with_compile --preproc_dependency="my_fileio.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/my_fileio.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/my_fileio.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/noise_sub.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=C55x --define=NO_FILE_IO --define=C55x_8KHZ --define=OWN_LOAD_FUNCTIONS --define=DSPBIOS_BUILD --define=c5535 --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --asm_listing --preproc_with_compile --preproc_dependency="noise_sub.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/noise_sub.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/noise_sub.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/obsprob.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=C55x --define=NO_FILE_IO --define=C55x_8KHZ --define=OWN_LOAD_FUNCTIONS --define=DSPBIOS_BUILD --define=c5535 --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --asm_listing --preproc_with_compile --preproc_dependency="obsprob.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/obsprob.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/obsprob.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/pack.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=C55x --define=NO_FILE_IO --define=C55x_8KHZ --define=OWN_LOAD_FUNCTIONS --define=DSPBIOS_BUILD --define=c5535 --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --asm_listing --preproc_with_compile --preproc_dependency="pack.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/pack.c"
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/pack.c", line 82: warning: variable "clipped" was set but never used
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/pack.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/pmc_f.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=C55x --define=NO_FILE_IO --define=C55x_8KHZ --define=OWN_LOAD_FUNCTIONS --define=DSPBIOS_BUILD --define=c5535 --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --asm_listing --preproc_with_compile --preproc_dependency="pmc_f.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/pmc_f.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/pmc_f.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/rapidsearch.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=C55x --define=NO_FILE_IO --define=C55x_8KHZ --define=OWN_LOAD_FUNCTIONS --define=DSPBIOS_BUILD --define=c5535 --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --asm_listing --preproc_with_compile --preproc_dependency="rapidsearch.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/rapidsearch.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/rapidsearch.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/sbc.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=C55x --define=NO_FILE_IO --define=C55x_8KHZ --define=OWN_LOAD_FUNCTIONS --define=DSPBIOS_BUILD --define=c5535 --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --asm_listing --preproc_with_compile --preproc_dependency="sbc.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/sbc.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/sbc.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/search.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=C55x --define=NO_FILE_IO --define=C55x_8KHZ --define=OWN_LOAD_FUNCTIONS --define=DSPBIOS_BUILD --define=c5535 --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --asm_listing --preproc_with_compile --preproc_dependency="search.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/search.c"
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/search.c", line 376: warning: variable "depth" was set but never used
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/search.c", line 1517: warning: variable "bsymc" was set but never used
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/search.c", line 1678: warning: variable "bsymc" was set but never used
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/search.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/siinit.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=C55x --define=NO_FILE_IO --define=C55x_8KHZ --define=OWN_LOAD_FUNCTIONS --define=DSPBIOS_BUILD --define=c5535 --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --asm_listing --preproc_with_compile --preproc_dependency="siinit.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/siinit.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/siinit.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/siproc.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=C55x --define=NO_FILE_IO --define=C55x_8KHZ --define=OWN_LOAD_FUNCTIONS --define=DSPBIOS_BUILD --define=c5535 --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --asm_listing --preproc_with_compile --preproc_dependency="siproc.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/siproc.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/siproc.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/uttdet.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=C55x --define=NO_FILE_IO --define=C55x_8KHZ --define=OWN_LOAD_FUNCTIONS --define=DSPBIOS_BUILD --define=c5535 --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --asm_listing --preproc_with_compile --preproc_dependency="uttdet.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/uttdet.c"
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/uttdet.c", line 395: warning: variable "max_pow" was set but never used
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/uttdet.c", line 398: warning: variable "arg_max" was set but never used
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/uttdet.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/volume.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5505 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=C55x --define=NO_FILE_IO --define=C55x_8KHZ --define=OWN_LOAD_FUNCTIONS --define=DSPBIOS_BUILD --define=c5535 --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --asm_listing --preproc_with_compile --preproc_dependency="volume.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/volume.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src/volume.c'
    'Building target: TIesrEngineC55.lib'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/ar55" r "TIesrEngineC55.lib" "./dist.obj" "./engine_sireco_init.obj" "./gmhmm_type_common.obj" "./jac-estm.obj" "./jac_one.obj" "./liveproc.obj" "./load.obj" "./mfcc_f.obj" "./my_fileio.obj" "./noise_sub.obj" "./obsprob.obj" "./pack.obj" "./pmc_f.obj" "./rapidsearch.obj" "./sbc.obj" "./search.obj" "./siinit.obj" "./siproc.obj" "./uttdet.obj" "./volume.obj"
      ==>  new archive 'TIesrEngineC55.lib'
      ==>  building archive 'TIesrEngineC55.lib'
    'Finished building target: TIesrEngineC55.lib'
    The above three projects all build fine, the one below just refuses so:
    **** Build of configuration Debug for project TIesrDemoC55 ****
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/build/TIesrDemoC55.tcf'
    'Invoking: TConf'
    "C:/ti/bios_5_42_02_10/xdctools/tconf" -b -Dconfig.importPath="C:/ti/bios_5_42_02_10/packages;" "C:/tidcbz3/TIesr_src/TIesr_C55_demo/build/TIesrDemoC55.tcf"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/build/TIesrDemoC55.tcf'
    'Building file: TIesrDemoC55cfg.s??'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5515 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/tws3/TIesrDemoC55/Debug" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=c5515 --define=C55x --define=PF_C5535_EZDSP --undefine=PF_C5515_EVM --display_error_number --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --algebraic --preproc_with_compile --preproc_dependency="TIesrDemoC55cfg.pp"  "TIesrDemoC55cfg.s??"
    'Finished building: TIesrDemoC55cfg.s??'
    'Building file: TIesrDemoC55cfg_c.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5515 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/tws3/TIesrDemoC55/Debug" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=c5515 --define=C55x --define=PF_C5535_EZDSP --undefine=PF_C5515_EVM --display_error_number --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --algebraic --preproc_with_compile --preproc_dependency="TIesrDemoC55cfg_c.pp"  "TIesrDemoC55cfg_c.c"
    'Finished building: TIesrDemoC55cfg_c.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/audio_data_collection.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5515 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/tws3/TIesrDemoC55/Debug" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=c5515 --define=C55x --define=PF_C5535_EZDSP --undefine=PF_C5515_EVM --display_error_number --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --algebraic --preproc_with_compile --preproc_dependency="audio_data_collection.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/audio_data_collection.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/audio_data_collection.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/codec_aic3254.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5515 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/tws3/TIesrDemoC55/Debug" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=c5515 --define=C55x --define=PF_C5535_EZDSP --undefine=PF_C5515_EVM --display_error_number --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --algebraic --preproc_with_compile --preproc_dependency="codec_aic3254.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/codec_aic3254.c"
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/codec_aic3254.c", line 175: error #169: argument of type "Bool" is incompatible with parameter of type "Uint16 *"
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/codec_aic3254.c", line 178: error #167: too few arguments in function call
    >> Compilation failure
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/codec_aic3254.c", line 275: error #169: argument of type "Bool" is incompatible with parameter of type "Uint16 *"
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/codec_aic3254.c", line 278: error #167: too few arguments in function call
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/codec_aic3254.c", line 310: error #169: argument of type "Bool" is incompatible with parameter of type "Uint16 *"
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/codec_aic3254.c", line 313: error #167: too few arguments in function call
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/codec_aic3254.c", line 372: error #169: argument of type "Bool" is incompatible with parameter of type "Uint16 *"
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/codec_aic3254.c", line 375: error #167: too few arguments in function call
    8 errors detected in the compilation of "C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/codec_aic3254.c".
    gmake: *** [codec_aic3254.obj] Error 1
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_config.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5515 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/tws3/TIesrDemoC55/Debug" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=c5515 --define=C55x --define=PF_C5535_EZDSP --undefine=PF_C5515_EVM --display_error_number --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --algebraic --preproc_with_compile --preproc_dependency="gd_config.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_config.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_config.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_dim.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5515 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/tws3/TIesrDemoC55/Debug" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=c5515 --define=C55x --define=PF_C5535_EZDSP --undefine=PF_C5515_EVM --display_error_number --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --algebraic --preproc_with_compile --preproc_dependency="gd_dim.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_dim.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_dim.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_gconst.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5515 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/tws3/TIesrDemoC55/Debug" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=c5515 --define=C55x --define=PF_C5535_EZDSP --undefine=PF_C5515_EVM --display_error_number --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --algebraic --preproc_with_compile --preproc_dependency="gd_gconst.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_gconst.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_gconst.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_hmm.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5515 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/tws3/TIesrDemoC55/Debug" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=c5515 --define=C55x --define=PF_C5535_EZDSP --undefine=PF_C5515_EVM --display_error_number --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --algebraic --preproc_with_compile --preproc_dependency="gd_hmm.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_hmm.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_hmm.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_mixture.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5515 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/tws3/TIesrDemoC55/Debug" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=c5515 --define=C55x --define=PF_C5535_EZDSP --undefine=PF_C5515_EVM --display_error_number --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --algebraic --preproc_with_compile --preproc_dependency="gd_mixture.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_mixture.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_mixture.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_mu.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5515 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/tws3/TIesrDemoC55/Debug" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=c5515 --define=C55x --define=PF_C5535_EZDSP --undefine=PF_C5515_EVM --display_error_number --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --algebraic --preproc_with_compile --preproc_dependency="gd_mu.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_mu.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_mu.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_net.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5515 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/tws3/TIesrDemoC55/Debug" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=c5515 --define=C55x --define=PF_C5535_EZDSP --undefine=PF_C5515_EVM --display_error_number --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --algebraic --preproc_with_compile --preproc_dependency="gd_net.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_net.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_net.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_pdf.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5515 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/tws3/TIesrDemoC55/Debug" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=c5515 --define=C55x --define=PF_C5535_EZDSP --undefine=PF_C5515_EVM --display_error_number --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --algebraic --preproc_with_compile --preproc_dependency="gd_pdf.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_pdf.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_pdf.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_tran.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5515 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/tws3/TIesrDemoC55/Debug" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=c5515 --define=C55x --define=PF_C5535_EZDSP --undefine=PF_C5515_EVM --display_error_number --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --algebraic --preproc_with_compile --preproc_dependency="gd_tran.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_tran.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_tran.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_var.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5515 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/tws3/TIesrDemoC55/Debug" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=c5515 --define=C55x --define=PF_C5535_EZDSP --undefine=PF_C5515_EVM --display_error_number --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --algebraic --preproc_with_compile --preproc_dependency="gd_var.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_var.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_var.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_word.c'
    'Invoking: C5500 Compiler'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5515 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/tws3/TIesrDemoC55/Debug" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=c5515 --define=C55x --define=PF_C5535_EZDSP --undefine=PF_C5515_EVM --display_error_number --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --algebraic --preproc_with_compile --preproc_dependency="gd_word.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_word.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55xTIesrData/GramKWS/gd_word.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/gpio_control.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5515 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/tws3/TIesrDemoC55/Debug" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=c5515 --define=C55x --define=PF_C5535_EZDSP --undefine=PF_C5515_EVM --display_error_number --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --algebraic --preproc_with_compile --preproc_dependency="gpio_control.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/gpio_control.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/gpio_control.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/lcd_osd.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5515 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/tws3/TIesrDemoC55/Debug" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=c5515 --define=C55x --define=PF_C5535_EZDSP --undefine=PF_C5515_EVM --display_error_number --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --algebraic --preproc_with_compile --preproc_dependency="lcd_osd.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/lcd_osd.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/lcd_osd.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/pll_control.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5515 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/tws3/TIesrDemoC55/Debug" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=c5515 --define=C55x --define=PF_C5535_EZDSP --undefine=PF_C5515_EVM --display_error_number --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --algebraic --preproc_with_compile --preproc_dependency="pll_control.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/pll_control.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/pll_control.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/recognizer.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5515 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/tws3/TIesrDemoC55/Debug" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=c5515 --define=C55x --define=PF_C5535_EZDSP --undefine=PF_C5515_EVM --display_error_number --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --algebraic --preproc_with_compile --preproc_dependency="recognizer.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/recognizer.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/recognizer.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/sys_init.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5515 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/tws3/TIesrDemoC55/Debug" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=c5515 --define=C55x --define=PF_C5535_EZDSP --undefine=PF_C5515_EVM --display_error_number --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --algebraic --preproc_with_compile --preproc_dependency="sys_init.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/sys_init.c"
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/sys_init.c", line 227: warning #64-D: shift count is too large
    "C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/sys_init.c", line 251: warning #64-D: shift count is too large
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/sys_init.c'
    'Building file: C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/user_interface.c'
    "C:/ti/ccsv6/tools/compiler/c5500_4.4.1/bin/cl55" -v5515 --memory_model=huge -g --include_path="C:/ti/ccsv6/tools/compiler/c5500_4.4.1/include" --include_path="C:/tws3/TIesrDemoC55/Debug" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --include_path="C:/ti/bios_5_42_02_10/packages/ti/rtdx/include/c5500" --include_path="C:/c55xx_csl_3.00/c55_csl_3.08/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/inc" --include_path="C:/tidcbz3/TIesr_src/TIesr_C55_demo/C55/TIesrEngine/src" --include_path="C:/ti/bios_5_42_02_10/packages/ti/bios/include" --define=c5515 --define=C55x --define=PF_C5535_EZDSP --undefine=PF_C5515_EVM --display_error_number --diag_warning=225 --gen_func_subsections=on --ptrdiff_size=32 --algebraic --preproc_with_compile --preproc_dependency="user_interface.pp"  "C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/user_interface.c"
    'Finished building: C:/tidcbz3/TIesr_src/TIesr_C55_demo/src/user_interface.c'
    gmake: Target `all' not remade because of errors.
    **** Build Finished ****
  • I did not. Last thing installed is from a week ago.
  • Hi Vladimir,
    I downloaded and installed the following on my Win10 PC (c:\ti folder):
    1. C55xx CSL 3.08.00,
    2. CCS 7.4.0
    3. CGT for C5500 4.4.1
    4. XDCTools 3.24.05.48
    Imported the following projects:
    C:\ti\c55_lp\c55_csl_3.08\ccs_v6.x_examples\C55XXCSL_LP
    C:\ti\c55_lp\c55_csl_3.08\demos\TIesr\c5535\TIesr_C55_demo\TIesrEngineC55
    C:\ti\c55_lp\c55_csl_3.08\demos\TIesr\c5535\TIesr_C55_demo\build\TIesrDemoC55
    With the following changes:
    1. Add the "C:\ti\bios_5_42_01_09\xdctools\jre\bin" to my System PATH variable to resolve a JVM issue
    2. Comment out the following lines in C:\ti\c55_lp\c55_csl_3.08\inc\csl_general.h
    //#define CHIP_C5517
    //#define CHIP_C5505_C5515
    3. Change the memory model of C55XXCSL_LP from large to huge
    Properties -> Build -> C5500 Compiler -> Processor Options -> Specify memory model
    4. Change the --ptrdiff_size from 16 to 32
    Properties -> Build -> C5500 Compiler -> Advanced Options -> Runtime Model Options -> Specify the type size to hold the results of pointer math (--ptrdiff_size)
    After those changes, all three projects are built OK.
    There is a warning of "the project cslVC5505 does not exist in workspace". Please ignore it for now. It is for the Release profile. it should be C55XXCSL_LP. The one for Debug profile is correct and we are building the Debug profile now.
    Hope it helps
    Ming
  • Thank you! Can you please send me links for these downloads? I only found the CCS so far.
    Vladimir
  • Thank you very much! With the indicated downloads and installations, it started building and working exactly as you said. One last question, if I may. Is there an easy way to instruct the engine to use more than two phrases for recognition?
    Vladimir
  • Hi Vladimir,
    I am glad that it works for you.
    Yes, the TIser is a medium size recognizer. It can be configured to have a few hundred phrases. Unfortunately it needs to configure and re-build the TIser engine. The TIser building has to be done on Linux Box and it is not a trivial task.
    If you interested to configure and re-build TIser engine, please refer to the documents in c55_csl_3.08\demos\TIesr\c5545\TIesr_model_build\Documentation for details.
    Since you issue has been resolved, I will close this thread.
    Ming
