TDA2EVM5777: Software self shutdown
Part Number: TDA2EVM5777
Using non-linux software, either PDK or starterware, we want to have the TDA self shutdown under certain scenarios. This would be similar to a thermal shutdown but would be for non-thermal reasons. The TRM lists power-down or clockstop methods for individual cores or domains but is there a way to perform this self shutdown across the entire TDA at once? Is there a recommended method for shutting down through software on command?
Thank you!
    You could initiate a software cold reset from the software to reset the whole device at once. It would be interesting to see under what circumstance you would like to wakeup from this state.
    The cold reset would again start rebooting the device after the reset is done from software.
    Thanks and Regards
    Piyali
