TDA2EG-17: IPU hung when VpsHal vpdmaLoadFirmware
    After doing all this change are you doing a clean build for VSDK and linux.
    And are you using the correct dtb file name in uenv.txt file.
    Your patch seems proper.
    There could be issue with something else.
    Anuj
  • Hi Anuj:
    I surely do a clean and rebuild VSDK. and The dtb file I used is dra71-evm-infoadas.dtb according to file vision_sdk/apps/configs/tda2ex_17x17_evm_linux_all/cfg.mk  line 105.
    I boot system from SD, and at the uboot stage, the boot cmd is:
    setenv bootargs 'console=ttyS0,115200n8 root=/dev/mmcblk0p2 rootwait mem=512M'
    fatload mmc 0:1 0x88000000 /dra71-evm-infoadas.dtb;fatload mmc 0:1 0x82000000 /zImage;bootz 0x82000000 - 0x88000000
    Attached file is system booting log.
    U-Boot SPL 2016.05-g17b372f-dirty (Sep 17 2019 - 13:44:30)
    DRA722-GP ES2.1
    no pinctrl for hs200_1_8v
    no pinctrl for ddr_1_8v
    ** First descriptor is NOT a primary desc on 1:1 **
    Trying to boot from MMC1
    reading u-boot.img
    reading u-boot.img
    reading u-boot.img
    reading u-boot.img
    U-Boot 2016.05-g17b372f-dirty (Sep 17 2019 - 13:44:30 +0800)
    CPU  : DRA722-GP ES2.1
    Model: TI DRA722
    Board: DRA72x EVM REV
    DRAM:  1 GiB
    MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
    Warning: fastboot.board_rev: unknown board revision
    GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
    part_get_info_efi: *** ERROR: Invalid GPT ***
    part_get_info_efi: *** ERROR: Invalid Backup GPT ***
    ERROR: cannot find partition: 'userdata'
    at arch/arm/cpu/armv7/omap-common/utils.c:199/mmc_get_part_size()
    Warning: fastboot.userdata_size: unable to calc
    SCSI:  SATA link 0 timeout.
    AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
    flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
    scanning bus for devices...
    Found 0 device(s).
    Net:   Could not get PHY for cpsw: addr 2
    cpsw
    Hit any key to stop autoboot:  0
    i2c_write: error waiting for data ACK (status=0x116)
    tps65903x: could not set LDO1 voltage.
    ** Bad device mmc 0 **
    reading /zImage
    3458808 bytes read in 149 ms (22.1 MiB/s)
    Kernel image @ 0x82000000 [ 0x000000 - 0x34c6f8 ]
    ERROR: Did not find a cmdline Flattened Device Tree
    Could not find a valid device tree
    => run bootcmd
    reading /dra71-evm-infoadas.dtb
    101229 bytes read in 9 ms (10.7 MiB/s)
    reading /zImage
       Loading Device Tree to 8ffe4000, end 8ffffb6c ... OK
    Starting kernel ...
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] Initializing cgroup subsys cpuset
    [    0.000000] Initializing cgroup subsys cpuacct
    [    0.000000] Linux version 4.4.84-00034-gaa42c96-dirty (tujian@tujian) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #2 SMP PREEMPT Tue Sep 17 10:14:13 CST 2019
    [    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [    0.000000] Machine model: TI DRA718 EVM
    [    0.000000] Reserved memory: created DMA memory pool at 0x0000000040300000, size 3 MiB
    [    0.000000] Reserved memory: initialized node cmem@40300000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: regions without no-map are not yet supported
    [    0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 32 MiB
    [    0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: created CMA memory pool at 0x000000009b000000, size 16 MiB
    [    0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
    [    0.000000] Reserved memory: incorrect alignment of CMA region
    [    0.000000] Reserved memory: created DMA memory pool at 0x000000009d200000, size 32 MiB
    [    0.000000] Reserved memory: initialized node cmem@9D200000, compatible id shared-dma-pool
    [    0.000000] cma: Reserved 24 MiB at 0x0000000097800000
    [    0.000000] Forcing write-allocate cache policy for SMP
    [    0.000000] Memory policy: Data cache writealloc
    [    0.000000] OMAP4: Map 0x000000009fd00000 to fe600000 for dram barrier
    [    0.000000] DRA722 ES2.1
    [    0.000000] PERCPU: Embedded 11 pages/cpu @df5e2000 s14912 r8192 d21952 u45056
    [    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 120960
    [    0.000000] Kernel command line: console=ttyS0,115200n8 root=/dev/mmcblk0p2 rootwait mem=512M
    [    0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
    [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
    [    0.000000] Memory: 183592K/488448K available (6443K kernel code, 307K rwdata, 2292K rodata, 336K init, 288K bss, 231128K reserved, 73728K cma-reserved, 0K highmem)
    [    0.000000] Virtual kernel memory layout:
    [    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    [    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    [    0.000000]     vmalloc : 0xe0800000 - 0xff800000   ( 496 MB)
    [    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
    [    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
    [    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
    [    0.000000]       .text : 0xc0008000 - 0xc088fffc   (8736 kB)
    [    0.000000]       .init : 0xc0890000 - 0xc08e4000   ( 336 kB)
    [    0.000000]       .data : 0xc08e4000 - 0xc0930fa0   ( 308 kB)
    [    0.000000]        .bss : 0xc0932000 - 0xc097a000   ( 288 kB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
    [    0.000000] Preemptible hierarchical RCU implementation.
    [    0.000000]  Build-time adjustment of leaf fanout to 32.
    [    0.000000]  RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
    [    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=1
    [    0.000000] NR_IRQS:16 nr_irqs:16 16
    [    0.000000] ti_dt_clocks_register: failed to lookup clock node gmac_gmii_ref_clk_div
    [    0.000000] OMAP clockevent source: timer1 at 31475 Hz
    [    0.000000] Architected cp15 timer(s) running at 5.90MHz (phys).
    [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x15c70fb29, max_idle_ns: 440795202138 ns
    [    0.000005] sched_clock: 56 bits at 5MHz, resolution 169ns, wraps every 4398046511093ns
    [    0.000016] Switching to timer-based delay loop, resolution 169ns
    [    0.000331] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
    [    0.000339] OMAP clocksource: 32k_counter at 32768 Hz
    [    0.000764] Console: colour dummy device 80x30
    [    0.000783] Calibrating delay loop (skipped), value calculated using timer frequency.. 11.80 BogoMIPS (lpj=59016)
    [    0.000796] pid_max: default: 32768 minimum: 301
    [    0.000893] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
    [    0.000903] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
    [    0.001421] Initializing cgroup subsys io
    [    0.001438] Initializing cgroup subsys memory
    [    0.001462] Initializing cgroup subsys devices
    [    0.001473] Initializing cgroup subsys freezer
    [    0.001484] Initializing cgroup subsys perf_event
    [    0.001496] Initializing cgroup subsys pids
    [    0.001523] CPU: Testing write buffer coherency: ok
    [    0.001727] /cpus/cpu@0 missing clock-frequency property
    [    0.001739] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [    0.001771] Setting up static identity map for 0x80008380 - 0x800083e0
    [    0.050030] Brought up 1 CPUs
    [    0.050041] SMP: Total of 1 processors activated (11.80 BogoMIPS).
    [    0.050048] CPU: All CPU(s) started in HYP mode.
    [    0.050054] CPU: Virtualization extensions available.
    [    0.050363] devtmpfs: initialized
    [    0.080031] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
    [    0.081012] omap_hwmod: l3_main_2 using broken dt data from ocp
    [    0.252034] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.252058] futex hash table entries: 256 (order: 2, 16384 bytes)
    [    0.261708] pinctrl core: initialized pinctrl subsystem
    [    0.262569] NET: Registered protocol family 16
    [    0.263498] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.290178] cpuidle: using governor ladder
    [    0.320200] cpuidle: using governor menu
    [    0.328924] OMAP GPIO hardware version 0.1
    [    0.335456] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
    [    0.356499] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [    0.356511] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [    0.356919] omap4_sram_init:Unable to allocate sram needed to handle errata I688
    [    0.356929] omap4_sram_init:Unable to get sram pool needed to handle errata I688
    [    0.357531] OMAP DMA hardware revision 0.0
    [    0.441071] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
    [    0.442215] edma 43300000.edma: memcpy is disabled
    [    0.446957] edma 43300000.edma: TI EDMA DMA engine driver
    [    0.451738] omap-iommu 40d01000.mmu: 40d01000.mmu registered
    [    0.451924] omap-iommu 40d02000.mmu: 40d02000.mmu registered
    [    0.452086] omap-iommu 58882000.mmu: 58882000.mmu registered
    [    0.452250] omap-iommu 55082000.mmu: 55082000.mmu registered
    [    0.471050] pcf857x: probe of 0-0020 failed with error -121
    [    0.471357] pcf857x: probe of 0-0021 failed with error -121
    [    0.471734] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
    [    0.472198] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
    [    0.472360] media: Linux media interface: v0.10
    [    0.472413] Linux video capture interface: v2.00
    [    0.472454] pps_core: LinuxPPS API ver. 1 registered
    [    0.472462] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.472486] PTP clock support registered
    [    0.472534] EDAC MC: Ver: 3.0.0
    [    0.481502] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
    [    0.481699] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
    [    0.482791] clocksource: Switched to clocksource arch_sys_counter
    [    0.492902] NET: Registered protocol family 2
    [    0.493393] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
    [    0.493432] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
    [    0.493499] TCP: Hash tables configured (established 4096 bind 4096)
    [    0.493537] UDP hash table entries: 256 (order: 1, 8192 bytes)
    [    0.493558] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
    [    0.493754] NET: Registered protocol family 1
    [    0.504040] RPC: Registered named UNIX socket transport module.
    [    0.504050] RPC: Registered udp transport module.
    [    0.504057] RPC: Registered tcp transport module.
    [    0.504063] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.505004] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
    [    0.525041] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.535723] NFS: Registering the id_resolver key type
    [    0.535759] Key type id_resolver registered
    [    0.535767] Key type id_legacy registered
    [    0.535824] ntfs: driver 2.1.32 [Flags: R/O].
    [    0.537460] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
    [    0.537477] io scheduler noop registered
    [    0.537490] io scheduler deadline registered
    [    0.537523] io scheduler cfq registered (default)
    [    0.541613] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
    [    0.541742] pinctrl-single 4a002e8c.pinmux: 1 pins at pa fc002e8c size 4
    [    0.544860] PCI host bridge /ocp/axi@0/pcie_rc@51000000 ranges:
    [    0.544873]   No bus range found for /ocp/axi@0/pcie_rc@51000000, using [bus 00-ff]
    [    0.544907]    IO 0x20003000..0x20012fff -> 0x00000000
    [    0.544928]   MEM 0x20013000..0x2fffffff -> 0x20013000
    [    0.574456] dra7-pcie 51000000.pcie_rc: link is not up
    [    0.574622] dra7-pcie 51000000.pcie_rc: PCI host bridge to bus 0000:00
    [    0.574636] pci_bus 0000:00: root bus resource [bus 00-ff]
    [    0.574646] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
    [    0.574655] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
    [    0.575052] PCI: bus0: Fast back to back transfers disabled
    [    0.575171] PCI: bus1: Fast back to back transfers enabled
    [    0.575260] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
    [    0.575274] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
    [    0.575287] pci 0000:00:00.0: PCI bridge to [bus 01]
    [    0.575513] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
    [    0.631410] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
    [    0.634786] console [ttyS0] disabled
    [    0.634840] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 301, base_baud = 3000000) is a 8250
    [    1.562452] console [ttyS0] enabled
    [    1.566876] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 302, base_baud = 3000000) is a 8250
    [    1.576877] [drm] Initialized drm 1.1.0 20060810
    [    1.582393] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [    1.589088] [drm] No driver support for vblank timestamp query.
    [    1.595253] [drm] Initialized vdrm 1.0.0 20110917 on minor 0
    [    1.688071] loop: module loaded
    [    1.691626] lp873x 0-0060: Failed to read OTP ID
    [    1.696353] lp873x: probe of 0-0060 failed with error -121
    [    1.702038] lp873x 0-0061: Failed to read OTP ID
    [    1.706770] lp873x: probe of 0-0061 failed with error -121
    [    1.712455] vmemexp device MAJOR num = 245
    [    1.716626] vmemexp class registered
    [    1.720330] /dev/vmemexp device registered
    [    1.724488] ioctl DBUFIOC_EXPORT_VIRTMEM = -1072899120
    [    1.732071] m25p80 spi32766.0: unrecognized JEDEC id bytes: 00,  0,  0
    [    1.739673] libphy: Fixed MDIO Bus: probed
    [    1.745417] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    1.752563] mousedev: PS/2 mouse device common for all mice
    [    1.768864] i2c /dev entries driver
    [    1.777368] omap_hsmmc 4809c000.mmc: Got CD GPIO
    [    1.782212] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode
    [    1.788708] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode
    [    1.795104] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode
    [    1.801485] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode
    [    1.807877] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode
    [    1.814510] vsys_3v3: supplied by evm_12v0
    [    1.818665] evm_3v3: supplied by vsys_3v3
    [    1.822723] evm_3v3_sd: supplied by evm_3v3
    [    1.873271] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
    [    1.879657] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
    [    1.933174] omap_hsmmc 480d1000.mmc: no pinctrl state for sdr25 mode
    [    1.939558] omap_hsmmc 480d1000.mmc: no pinctrl state for sdr12 mode
    [    1.962796] omap_hsmmc 480d1000.mmc: no pinctrl state for hs mode
    [    2.003502] ledtrig-cpu: registered to indicate activity on CPUs
    [    2.011206] NET: Registered protocol family 10
    [    2.043480] sit: IPv6 over IPv4 tunneling driver
    [    2.048674] NET: Registered protocol family 17
    [    2.063021] Key type dns_resolver registered
    [    2.067394] omap_voltage_late_init: Voltage driver support not added
    [    2.083352] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    2.089560] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    2.112812] cpu0 supply vdd not found, using dummy regulator
    [    2.118745] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
    [    2.132816] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
    [    2.139035] cpu0 supply vdd not found, using dummy regulator
    [    2.163657] Power Management for TI OMAP4+ devices.
    [    2.168769] Registering SWP/SWPB emulation handler
    [    2.184158] dmm 4e000000.dmm: workaround for errata i878 in use
    [    2.202836] dmm 4e000000.dmm: initialized all PAT entries
    [    2.209276] [drm] Initialized omapdrm 1.0.0 20110917 on minor 1
    [    2.239550] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    2.246277] hctosys: unable to open rtc device (rtc0)
    [    2.259733] mmc0: host does not support reading read-only switch, assuming write-enable
    [    2.271896] aic_dvdd: disabling
    [    2.277193] Waiting for root device /dev/mmcblk0p2...
    [    2.282380] mmc0: new high speed SDHC card at address 0007
    [    2.298428] mmcblk0: mmc0:0007 SD16G 14.4 GiB
    [    2.304235]  mmcblk0: p1 p2
    [    2.308654] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    2.356355] mmc1: MAN_BKOPS_EN bit is not set
    [    2.364845] mmc1: switch to bus width 2 failed
    [    2.401875] mmc1: new HS200 MMC card at address 0001
    [    2.406974] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
    [    2.417069] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
    [    2.425672] mmcblk1: mmc1:0001 IS004G 3.64 GiB
    [    2.433410] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
    [    2.440907] mmcblk1boot0: mmc1:0001 IS004G partition 1 2.00 MiB
    [    2.446993] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
    [    2.464702] mmcblk1boot1: mmc1:0001 IS004G partition 2 2.00 MiB
    [    2.473626] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    3.510495] EXT4-fs (mmcblk0p2): recovery complete
    [    3.537743] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    3.545924] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
    [    3.557632] devtmpfs: mounted
    [    3.560829] Freeing unused kernel memory: 336K
    [    3.565393] This architecture does not have kernel memory protection.
    [    3.783523] systemd[1]: System time before build time, advancing clock.
    [    3.821511] random: systemd: uninitialized urandom read (16 bytes read, 12 bits of entropy available)
    [    3.835490] random: systemd: uninitialized urandom read (16 bytes read, 12 bits of entropy available)
    [    3.847271] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
    [    3.865863] systemd[1]: Detected architecture arm.
    Welcome to Arago 2016.12!
    [    3.894189] systemd[1]: Set hostname to <dra7xx-evm>.
    [    3.934959] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 13 bits of entropy available)
    [    3.947172] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 13 bits of entropy available)
    [    3.972179] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 13 bits of entropy available)
    [    4.003335] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 14 bits of entropy available)
    [    4.021104] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 15 bits of entropy available)
    [    4.124826] random: systemd: uninitialized urandom read (16 bytes read, 17 bits of entropy available)
    [    4.134448] random: systemd: uninitialized urandom read (16 bytes read, 17 bits of entropy available)
    [    4.144547] random: systemd: uninitialized urandom read (16 bytes read, 17 bits of entropy available)
    [    4.322579] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
    [    4.330477] systemd[1]: sysinit.target: Found dependency on alignment.service/start
    [    4.338250] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
    [    4.345703] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
    [    4.355160] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
    [ SKIP ] Ordering cycle found, skipping alignment.service
    [    4.395413] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
    [  OK  ] Started Forward Password Requests to Wall Directory Watch.
    [    4.423204] systemd[1]: Listening on Journal Socket (/dev/log).
    [  OK  ] Listening on Journal Socket (/dev/log).
    [    4.453103] systemd[1]: Listening on Syslog Socket.
    [  OK  ] Listening on Syslog Socket.
    [    4.473122] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
    [  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
    [    4.503136] systemd[1]: Listening on udev Control Socket.
    [  OK  ] Listening on udev Control Socket.
    [    4.533080] systemd[1]: Listening on udev Kernel Socket.
    [  OK  ] Listening on udev Kernel Socket.
    [    4.563210] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
    [  OK  ] Started Dispatch Password Requests to Console Directory Watch.
    [    4.593015] systemd[1]: Reached target Swap.
    [  OK  ] Reached target Swap.
    [    4.614445] systemd[1]: Created slice User and Session Slice.
    [  OK  ] Created slice User and Session Slice.
    [    4.643051] systemd[1]: Reached target Remote File Systems.
    [  OK  ] Reached target Remote File Systems.
    [    4.673170] systemd[1]: Listening on Journal Socket.
    [  OK  ] Listening on Journal Socket.
    [    4.713744] systemd[1]: Reached target Paths.
    [  OK  ] Reached target Paths.
    [    4.733790] systemd[1]: Created slice System Slice.
    [  OK  ] Created slice System Slice.
    [    4.766272] systemd[1]: Mounting Temporary Directory...
    [    4.805534] systemd[1]: Mounting POSIX Message Queue File System...
    [    4.843083] systemd[1]: Reached target Slices.
    [  OK  ] Reached target Slices.
    [    4.865526] systemd[1]: Starting File System Check on Root Device...
    [    4.904023] systemd[1]: Created slice system-serial\x2dgetty.slice.
    [  OK  ] Created slice system-serial\x2dgetty.slice.[    4.915139] systemd[1]: Starting Journal Service...
             Starting Journal Service...[    4.929181] systemd[1]: Created slice system-getty.slice.
    [  OK  ] Created slice system-getty.slice.
    [    4.972903] systemd[1]: Starting Load Kernel Modules...
             Starting Load Kernel Modules...[    4.982316] systemd[1]: Listening on Network Service Netlink Socket.
    [  OK  ] Listening on Network Service Netlink Socket.[    4.999539] systemd[1]: Starting Setup Virtual Console...
    [    5.023571] systemd[1]: Starting Create list of required static device nodes for the current kernel...
             Starting Create list of required st... nodes for the current kernel...
    [    5.055509] systemd[1]: Mounting Debug File System...
    [    5.107948] systemd[1]: Mounted POSIX Message Queue File System.
    [  OK  ] Mounted POSIX Message Queue File System.
    [    5.163572] systemd[1]: Mounted Debug File System.
    [  OK  ] Mounted Debug File System.
    [    5.193106] systemd[1]: Mounted Temporary Directory.
    [  OK  ] Mounted Temporary Directory.
    [    5.223339] systemd[1]: Started Journal Service.
    [  OK  ] Started Journal Service.
    [  OK  ] Started File System Check on Root Device.
    [FAILED] Failed to start Load Kernel Modules.
    See 'systemctl status systemd-modules-load.service' for details.
    [  OK  ] Started Setup Virtual Console.
    [  OK  ] Started Create list of required sta...ce nodes for the current kernel.
             Starting Create Static Device Nodes in /dev...
             Starting Apply Kernel Variables...
             Starting Remount Root and Kernel File Systems...
    [    5.753911] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
    [  OK  ] Started Create Static Device Nodes in /dev.
    [  OK  ] Started Apply Kernel Variables.
    [  OK  ] Started Remount Root and Kernel File Systems.
             Starting udev Coldplug all Devices...
             Starting Flush Journal to Persistent Storage...
             Starting udev Kernel Device Manager...
    [  OK  ] Reached target Local File Systems (Pre).
             Mounting /media/ram...
             Mounting /var/volatile...
    [  OK  ] Mounted /media/ram.
    [  OK  ] Mounted /var/volatile.
    [  OK  ] Started udev Kernel Device Manager.
    [    6.499432] systemd-journald[107]: Received request to flush runtime journal from PID 1
    [  OK  ] Started Flush Journal to Persistent Storage.
             Starting Load/Save Random Seed...
    [  OK  ] Reached target Local File Systems.
             Starting Create Volatile Files and Directories...
    [  OK  ] Started Load/Save Random Seed.
    [  OK  ] Started Create Volatile Files and Directories.
             Starting Update UTMP about System Boot/Shutdown...
             Starting Network Time Synchronization...
    [    7.287817] omap-rproc 58820000.ipu: device does not have specific CMA pool
    [    7.353563]  remoteproc0: releasing 58820000.ipu
    [    7.358252] omap-rproc: probe of 58820000.ipu failed with error -22
    [  OK  ] Started Network Time Synchronization.
    [    7.493100] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
    [    7.500937]  remoteproc0: 55020000.ipu is available
    [    7.615596]  remoteproc0: Note: remoteproc is still under development and considered experimental.
    [    7.706168]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [  OK  ] Started udev Coldplug all Devices.
    [    7.785444] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    7.794299] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
    [    7.802130]  remoteproc1: 40800000.dsp is available
    [  OK  ] Started Update UTMP about System Boot/Shutdown.
    [    7.921845]  remoteproc1: Note: remoteproc is still under development and considered experimental.
    [    7.979465]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [  OK  ] Found device /dev/ttyS0.
    [    8.084748]  remoteproc1: Direct firmware load for dra7-dsp1-fw.xe66 failed with error -2
    [    8.105740] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    8.112706] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
    [    8.147310]  remoteproc1: failed to load dra7-dsp1-fw.xe66
    [    8.154911] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
    [    8.164457] cpsw 48484000.ethernet: gpio request failed, ret -517
    [  OK  ] Reached target System Time Synchronized.
    [    8.265173]  remoteproc0: registered virtio0 (type 7)
             Starting Synchronize System and HW clocks...
    [FAILED] Failed to start Synchronize System and HW clocks.
    See 'systemctl status sync-clocks.service' for details.
    [  OK  ] Reached target System Initialization.
    [  OK  ] Listening on D-Bus System Message Bus Socket.
    [  OK  ] Listening on dropbear.socket.
    [  OK  ] Reached target Sockets.
    [  OK  ] Reached target Basic System.
             Starting Permit User Sessions...
    [  OK  ] Started Kernel Logging Service.[    8.921311] CAN device driver interface
    [    8.934421] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
    [  OK  ] Started D-Bus System Message Bus.
    [    9.111201] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    9.117557] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
    [    9.189339] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
    [    9.197054] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    9.217405] c_can_platform 4ae3c000.can: c_can_platform device registered (regs=fce3c000, irq=348)
    [    9.283912] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    9.352216] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    9.454755] [drm] Initialized pvr 1.14.3699939 20110701 on minor 2
    [    9.492169] cpsw 48484000.ethernet: gpio request failed, ret -517
    [    9.502350] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
             Starting Network Service...
    [  OK  ] Started Daily Cleanup of Temporary Directories.
    [  OK  ] Reached target Timers.
    [  OK  ] Started System Logging Service.
             Starting Login Service...
             Starting rc.pvr.service...
    [  OK  ] Started Network Service.
    [  OK  ] Started Permit User Sessions.
    [   10.047052] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
    [  OK  ] Started rc.pvr.service.
    [   11.505446]  remoteproc0: powering up 55020000.ipu
    [   11.530645]  remoteproc0: Booting fw image dra7-ipu2-fw.xem4, size 7893324
    [   11.553173] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
    [   11.622778]  remoteproc0: remote processor 55020000.ipu is now up
    [   11.640633] virtio_rpmsg_bus virtio0: rpmsg host is online
    [   11.665541] cpsw 48484000.ethernet: gpio request failed, ret -517
    [   11.671704] virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x50
    [   11.703218] NET: Registered protocol family 41
    [   11.711320] cpsw 48484000.ethernet: gpio request failed, ret -517
    [  OK  ] Started Login Service.
    [  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
             Starting weston.service...
    [  OK  ] Started Serial Getty on ttyS0.
    [  OK  ] Started Getty on tty1.
    [  OK  ] Reached target Network.
             Starting Network Name Resolution...
    [  OK  ] Started weston.service.
    [  OK  ] Started Network Name Resolution.
             Starting telnetd.service...
             Starting tiipclad-daemon.service...
    [  OK  ] Started telnetd.service.
    [  OK  ] Started tiipclad-daemon.service.
     _____                    _____           _         _
    |  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
    |     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
    |__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
                  |___|                    |___|
    Arago Project http://arago-project.org dra7xx-evm ttyS0
    Arago 2016.12 dra7xx-evm ttyS0
    dra7xx-evm login: root
    root@dra7xx-evm:~# ls
    decode_ipumm.sh  init-demo.sh
    root@dra7xx-evm:~#
    TuJian
    Is it an EVM or a custom board?
    Can you try to run only bios and check first.
    Just to avoid any issue with linux.
    Anuj
  • HI,
    Its been long since any update on this thread.
    I hope the issue is resolved.
    If not then please reply below or create a new thread for different query.
    Anuj
