I am trying to connect to the codec engine to compress the images that I am grabbing, but I am running into some issues. I havent added any compression code, all I did was create a header file and I placed the following 3 header files as said to do in SPRUE67.
#include <xdc/std.h>
#include <ti/sdo/ce/Engine.h>
#include <ti/sdo/ce/CERuntime.h>
Then I added the location of them in the make file
DVSDKDIR = /localhome/administrator/dvsdk_1_30_00_40
INCLUDES = -I/opt/mv_pro_4.0.1/montavista/pro/devkit/lsp/ti-davinci/include/ \
-I${DVSDKDIR}/codec_engine_2_00_01/packages/ \
-I${DVSDKDIR}/xdc_3_00_02/packages/
but I am running into the following errors: What am I not doing, to cause these?
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:101: error: parse error before "IArg"
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:101: warning: type defaults to `int' in declaration of `IArg'
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:101: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:102: error: parse error before "UArg"
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:102: warning: type defaults to `int' in declaration of `UArg'
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:102: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:104: error: parse error before "Int8"
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:104: warning: type defaults to `int' in declaration of `Int8'
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:104: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:105: error: parse error before "Int16"
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:105: warning: type defaults to `int' in declaration of `Int16'
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:105: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:106: error: parse error before "Int32"
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:106: warning: type defaults to `int' in declaration of `Int32'
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:106: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:111: error: parse error before "UInt8"
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:111: warning: type defaults to `int' in declaration of `UInt8'
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:111: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:112: error: parse error before "UInt16"
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:112: warning: type defaults to `int' in declaration of `UInt16'
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:112: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:113: error: parse error before "UInt32"
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:113: warning: type defaults to `int' in declaration of `UInt32'
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:113: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:126: error: parse error before "Uint8"
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:126: warning: type defaults to `int' in declaration of `Uint8'
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:126: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:127: error: parse error before "Uint16"
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:127: warning: type defaults to `int' in declaration of `Uint16'
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:127: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:128: error: parse error before "Uint32"
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:128: warning: type defaults to `int' in declaration of `Uint32'
/localhome/administrator/dvsdk_1_30_00_40/xdc_3_00_02/packages/xdc/std.h:128: warning: data definition has no type or storage class
In file included from /localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:34,
from src/../include/compression.h:5,
from src/txCap.c:8:
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Server.h:81: error: parse error before "Uint32"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Server.h:81: warning: no semicolon at end of struct or union
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Server.h:82: warning: type defaults to `int' in declaration of `size'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Server.h:82: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Server.h:83: error: parse error before "used"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Server.h:83: warning: type defaults to `int' in declaration of `used'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Server.h:83: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Server.h:84: error: parse error before "maxBlockLen"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Server.h:84: warning: type defaults to `int' in declaration of `maxBlockLen'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Server.h:84: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Server.h:85: warning: type defaults to `int' in declaration of `Server_MemStat'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Server.h:85: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Server.h:213: error: parse error before "Server_MemStat"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Server.h:293: error: parse error before "Uint32"
In file included from /localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:35,
from src/txCap.c:8:
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:27: error: parse error before "Comm_MSGSIZE"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:27: warning: type defaults to `int' in declaration of `Comm_MSGSIZE'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:27: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:32: error: parse error before "Comm_Queue"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:32: warning: type defaults to `int' in declaration of `Comm_Queue'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:32: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:70: error: parse error before "UInt32"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:70: warning: no semicolon at end of struct or union
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:71: warning: type defaults to `int' in declaration of `reserved1'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:71: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:72: error: parse error before "reserved2"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:72: warning: type defaults to `int' in declaration of `reserved2'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:72: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:73: error: parse error before "size"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:73: warning: type defaults to `int' in declaration of `size'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:73: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:74: error: parse error before "reserved3"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:74: warning: type defaults to `int' in declaration of `reserved3'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:74: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:75: error: parse error before "reserved4"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:75: warning: type defaults to `int' in declaration of `reserved4'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:75: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:76: error: parse error before "msgId"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:76: warning: type defaults to `int' in declaration of `msgId'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:76: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:77: warning: type defaults to `int' in declaration of `Comm_MsgHeader'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:77: warning: type defaults to `int' in declaration of `Comm_Msg'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:77: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:100: error: parse error before "Comm_Queue"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:106: error: parse error before "poolId"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:112: error: parse error before "msg"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:118: error: parse error before "queue"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:124: error: parse error before "queue"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:130: error: parse error before "msg"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:136: error: parse error before "msg"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:142: error: parse error before "msg"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:148: error: parse error before "Comm_Queue"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/osal/Comm.h:170: error: parse error before "queue"
In file included from src/../include/compression.h:5,
from src/txCap.c:8:
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:36:27: ti/xdais/ialg.h: No such file or directory
In file included from /localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:37,
from src/txCap.c:8:
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/node/node.h:55: error: parse error before "Arg"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/node/node.h:55: warning: no semicolon at end of struct or union
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/node/node.h:56: warning: type defaults to `int' in declaration of `arg2'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/node/node.h:56: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/node/node.h:57: warning: type defaults to `int' in declaration of `NODE_Cmd'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/node/node.h:57: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/node/node.h:66: error: parse error before "Comm_MsgHeader"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/node/node.h:66: warning: no semicolon at end of struct or union
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/node/node.h:67: warning: type defaults to `int' in declaration of `cmd'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/node/node.h:67: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/node/node.h:68: warning: type defaults to `int' in declaration of `NODE_MsgHeader'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/node/node.h:68: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/node/node.h:88: error: parse error before "UInt32"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/node/node.h:88: warning: no semicolon at end of struct or union
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/node/node.h:89: warning: type defaults to `int' in declaration of `NODE_Uuid'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/node/node.h:89: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/node/node.h:163: error: parse error before '*' token
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/node/node.h: In function `NODE_uuidMatch':
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/node/node.h:165: error: `uuid1' undeclared (first use in this function)
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/node/node.h:165: error: (Each undeclared identifier is reported only once
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/node/node.h:165: error: for each function it appears in.)
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/node/node.h:165: error: `uuid2' undeclared (first use in this function)
from src/txCap.c:8:
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h: At top level:
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:135: error: parse error before "NODE_Uuid"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:135: warning: no semicolon at end of struct or union
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:136: warning: type defaults to `int' in declaration of `fxns'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:136: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:144: error: parse error before '}' token
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:144: warning: type defaults to `int' in declaration of `Engine_AlgDesc'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:144: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:164: error: parse error before "Engine_AlgDesc"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:164: warning: no semicolon at end of struct or union
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:169: error: parse error before '}' token
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:169: warning: type defaults to `int' in declaration of `Engine_Desc'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:169: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:175: error: parse error before "Engine_Desc"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:175: warning: no semicolon at end of struct or union
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:177: error: parse error before '}' token
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:177: warning: type defaults to `int' in declaration of `Engine_Config'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:177: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:185: error: parse error before "Uint32"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:185: warning: no semicolon at end of struct or union
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:186: warning: type defaults to `int' in declaration of `size'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:186: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:187: error: parse error before "used"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:187: warning: type defaults to `int' in declaration of `used'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:187: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:188: error: parse error before "maxBlockLen"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:188: warning: type defaults to `int' in declaration of `maxBlockLen'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:188: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:189: warning: type defaults to `int' in declaration of `Engine_MemStat'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:189: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:197: error: parse error before "Engine_config"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:197: warning: type defaults to `int' in declaration of `Engine_config'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:197: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:202: error: parse error before "Comm_Msg"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:207: error: parse error before "Comm_Msg"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:250: error: parse error before "IALG_Params"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:282: error: parse error before "IALG_Params"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:301: error: parse error before '*' token
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:302: warning: type defaults to `int' in declaration of `Engine_getFxns'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:302: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:323: error: parse error before "Engine_MemStat"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:343: error: parse error before "Engine_getRemoteVisa"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:343: warning: type defaults to `int' in declaration of `Engine_getRemoteVisa'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:343: warning: data definition has no type or storage class
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:354: error: parse error before "Comm_Queue"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:360: error: parse error before "Uint32"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:611: error: parse error before "Engine_getUsedMem"
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:611: warning: type defaults to `int' in declaration of `Engine_getUsedMem'
/localhome/administrator/dvsdk_1_30_00_40/codec_engine_2_00_01/packages/ti/sdo/ce/Engine.h:611: warning: data definition has no type or storage class
make: *** [txCap.o] Error 1
