Part Number: PROCESSOR-SDK-AM335X
While, building the SDK6.0 filesystem with Yacto, using "snap shot of the source packages', we are getting below error. Please, let us know, how to overcome this issue:
WARNING: mariadb-native-5.5.64-r0 do_fetch: Failed to fetch URL https://downloads.mariadb.org/f/mariadb-5.5.64/source/mariadb-5.5.64.tar.gz, attempting MIRRORS if available
ERROR: mariadb-native-5.5.64-r0 do_fetch: Fetcher failure: Fetch command export PSEUDO_DISABLED=1; export DBUS_SESSION_BUS_ADDRESS="unix:abstract=/tmp/dbus-cPd9sjcp9N"; export SSH_AUTH_SOCK="/run/user/1000/keyring/ssh"; export PATH="/home/hari/tisdk6.0/tisdk/sources/oe-core/scripts/native-intercept:/home/hari/tisdk6.0/tisdk/sources/oe-core/scripts:/home/hari/tisdk6.0/tisdk/build/arago-tmp-external-arm-toolchain/work/x86_64-linux/mariadb-native/5.5.64-r0/recipe-sysroot-native/usr/bin/x86_64-linux:/home/hari/tisdk6.0/tisdk/build/arago-tmp-external-arm-toolchain/work/x86_64-linux/mariadb-native/5.5.64-r0/recipe-sysroot-native/usr/bin:/home/hari/tisdk6.0/tisdk/build/arago-tmp-external-arm-toolchain/work/x86_64-linux/mariadb-native/5.5.64-r0/recipe-sysroot-native/usr/sbin:/home/hari/tisdk6.0/tisdk/build/arago-tmp-external-arm-toolchain/work/x86_64-linux/mariadb-native/5.5.64-r0/recipe-sysroot-native/usr/bin:/home/hari/tisdk6.0/tisdk/build/arago-tmp-external-arm-toolchain/work/x86_64-linux/mariadb-native/5.5.64-r0/recipe-sysroot-native/sbin:/home/hari/tisdk6.0/tisdk/build/arago-tmp-external-arm-toolchain/work/x86_64-linux/mariadb-native/5.5.64-r0/recipe-sysroot-native/bin:${DEF_TOOLCHAIN_PATH}/bin:/home/hari/tisdk6.0/tisdk/sources/bitbake/bin:/home/hari/tisdk6.0/tisdk/build/arago-tmp-external-arm-toolchain/hosttools"; export HOME="/home/hari"; /usr/bin/env wget -t 2 -T 30 --passive-ftp --no-check-certificate -P /home/hari/tisdk6.0/tisdk/downloads 'https://downloads.mariadb.org/f/mariadb-5.5.64/source/mariadb-5.5.64.tar.gz' --progress=dot -v failed with exit code 8, output:
--2019-09-22 18:46:12-- https://downloads.mariadb.org/f/mariadb-5.5.64/source/mariadb-5.5.64.tar.gz
Resolving downloads.mariadb.org (downloads.mariadb.org)... 116.203.207.31, 2a01:4f8:c2c:b04e::1
Connecting to downloads.mariadb.org (downloads.mariadb.org)|116.203.207.31|:443... connected.
HTTP request sent, awaiting response... 302 FOUND
Location: http://ftp.cc.uoc.gr/mirrors/mariadb//mariadb-5.5.64/source/mariadb-5.5.64.tar.gz [following]
--2019-09-22 18:46:19-- http://ftp.cc.uoc.gr/mirrors/mariadb//mariadb-5.5.64/source/mariadb-5.5.64.tar.gz
Resolving ftp.cc.uoc.gr (ftp.cc.uoc.gr)... 147.52.159.12, 2001:648:2c00:6c05::2
Connecting to ftp.cc.uoc.gr (ftp.cc.uoc.gr)|147.52.159.12|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2019-09-22 18:46:25 ERROR 404: Not Found.
TI sdk mirrior (http://software-dl.ti.com/processor-sdk-mirror/sources/) for these packages show only the below versions:
44M |
44M |
44M |
44M |
