DRA746: PVR Monitor, PVRScope support in 6AO.1.1 and 6AM.1.3 ?
Part Number: DRA746
HW: Jacinto 6 EVM
SW: Android 6AM.1.3 and 6AO.1.1
Issue category: GPU, PowerVR
We would like to get Jacinto 6 GPU benchmark data by using PVR monitor.
The PVR monitor apk can run but some of functions can't work properly.
The logs are like below:
04-11 06:14:17.370  1628  1628 E PVRScopeHUD: Error: failed to initialise services connection.
04-11 06:14:17.370  1628  1628 E PVRScopeHUD: Error: cannot connect to PVRScope.
It looks libPVRScopeServices.so doesn't support PVRScope.
Could you tell us how to make PVR Monitor and PVRScope work?
  • Hi James,
    are there any messages in 'dmesg' indicating that PVR kernel module has crashed when this happens? If so, can you try the last patch in this table:
    Also acn you check if you apply those patches there is an improvement:
    Yordan
  • Hi Yordan,
    I base on 6AO1.1 BSP and tried to follow your suggestion to apply those patches but it shows PVR error logs like below and can't work well. Any idea?
    [ 364.593343] PVR_K:(Error): NewAllocPagesLinuxMemArea: failed
    [ 364.599305] PVR_K:(Error): BM_ImportMemory: OSAllocPages(0xc8a000) failed
    [ 364.607143] PVR_K:(Error): AllocMemory: RA_Alloc(0xc8a000) FAILED
    [ 364.613288] PVR_K:(Error): BM_Alloc: AllocMemory FAILED
    [ 364.623487] PVR_K:(Error): AllocDeviceMem: BM_Alloc Failed
    [ 364.629252] PVR_K:(Error): PVRSRVAllocDeviceMemBW: PVRSRVAllocDeviceMemKM failed with eError = 1
    [ 366.265774] init: Untracked pid 7739 exited with status 0
    [ 366.398191] binder: undelivered transaction 469675
    [ 366.417043] binder: 231:906 transaction failed 29189/-22, size 60-0 line 2930
    [ 366.592872] binder: 303:303 transaction failed 29189/-22, size 84-0 line 2930
    [ 367.208812] binder: 226:270 transaction failed 29189/-22, size 100-0 line 2930
    [ 367.504076] binder: 303:3339 transaction failed 29189/-22, size 0-0 line 2930
    Herman
  • Hi Yordan,
    If I just apply http://review.omapzoom.org/#/c/39004/ patch, PVR can work. But PVRMonitor application still can't work. There is nothing shows error when I run that application in kernel dmesg command but it shows below messages. We would like to know does 6AM1.1 BSP support PVR scope initialize? We have tried this application in previous OMAP4 platform and it can work.
    09-26 19:23:54.238 1150 1150 D PVRLinker: dlopen failed for libPVRScopeServices.so
    09-26 19:23:54.238 1150 1150 D PVRLinker: Failed to get sphal namespace
    09-26 19:23:54.241 1150 1150 D PVRLinker: pvrdlopen succeeded for libPVRScopeServices.so
    09-26 19:23:54.242 1150 1150 E PVRScopeHUD: Error: failed to initialise services connection.
    09-26 19:23:54.242 1150 1150 E PVRScopeHUD: Error: cannot connect to PVRScope.
    09-26 19:23:53.325   306   318 I ActivityManager: START u0 {flg=0x10000000 cmp=com.powervr.PVRMonitor/.PVRMonitor} from uid 2000
    09-26 19:23:53.339   306   321 I ActivityManager: Waited long enough for: ServiceRecord{c6efc48 u0 com.android.calendar/.alerts.InitAlarmsService}
    09-26 19:23:53.353   306   814 I ActivityManager: Start proc 1150:com.powervr.PVRMonitor/u0a66 for activity com.powervr.PVRMonitor/.PVRMonitor
    --------- beginning of main
    09-26 19:23:53.358  1150  1150 I zygote  : Late-enabling -Xcheck:jni
    09-26 19:23:53.386   204   235 D PermissionCache: checking android.permission.READ_FRAME_BUFFER for uid=1000 => granted (597 us)
    09-26 19:23:53.469   306   321 I ActivityManager: Waited long enough for: ServiceRecord{c58f41d u0 com.android.car.messenger/.MessengerService}
    09-26 19:23:53.584   306   321 I ActivityManager: Waited long enough for: ServiceRecord{a6ebeaf u0 com.android.car.radio/.RadioService}
    09-26 19:23:53.675  1150  1150 I zygote  : Rejecting re-init on previously-failed class java.lang.Class<android.support.v4.view.ViewCompat$OnUnhandledKeyEventListenerWrapper>: java.lang.NoClassDefFoundError: Failed resolution of: Landroid/view/View$OnUnhandledKeyEventListener;
    09-26 19:23:53.675  1150  1150 I zygote  :   at void android.support.v4.view.ViewCompat.setBackground(android.view.View, android.graphics.drawable.Drawable) (ViewCompat.java:2341)
    09-26 19:23:53.675  1150  1150 I zygote  :   at void android.support.v7.widget.ActionBarContainer.<init>(android.content.Context, android.util.AttributeSet) (ActionBarContainer.java:62)
    09-26 19:23:53.675  1150  1150 I zygote  :   at java.lang.Object java.lang.reflect.Constructor.newInstance0(java.lang.Object[]) (Constructor.java:-2)
    09-26 19:23:53.675  1150  1150 I zygote  :   at java.lang.Object java.lang.reflect.Constructor.newInstance(java.lang.Object[]) (Constructor.java:334)
    09-26 19:23:53.675  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.createView(java.lang.String, java.lang.String, android.util.AttributeSet) (LayoutInflater.java:647)
    09-26 19:23:53.675  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.createViewFromTag(android.view.View, java.lang.String, android.content.Context, android.util.AttributeSet, boolean) (LayoutInflater.java:790)
    09-26 19:23:53.675  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.createViewFromTag(android.view.View, java.lang.String, android.content.Context, android.util.AttributeSet) (LayoutInflater.java:730)
    09-26 19:23:53.675  1150  1150 I zygote  :   at void android.view.LayoutInflater.rInflate(org.xmlpull.v1.XmlPullParser, android.view.View, android.content.Context, android.util.AttributeSet, boolean) (LayoutInflater.java:863)
    09-26 19:23:53.675  1150  1150 I zygote  :   at void android.view.LayoutInflater.rInflateChildren(org.xmlpull.v1.XmlPullParser, android.view.View, android.util.AttributeSet, boolean) (LayoutInflater.java:824)
    09-26 19:23:53.675  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.inflate(org.xmlpull.v1.XmlPullParser, android.view.ViewGroup, boolean) (LayoutInflater.java:515)
    09-26 19:23:53.675  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.inflate(int, android.view.ViewGroup, boolean) (LayoutInflater.java:423)
    09-26 19:23:53.675  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.inflate(int, android.view.ViewGroup) (LayoutInflater.java:374)
    09-26 19:23:53.675  1150  1150 I zygote  :   at android.view.ViewGroup android.support.v7.app.AppCompatDelegateImpl.createSubDecor() (AppCompatDelegateImpl.java:607)
    09-26 19:23:53.675  1150  1150 I zygote  :   at void android.support.v7.app.AppCompatDelegateImpl.ensureSubDecor() (AppCompatDelegateImpl.java:518)
    09-26 19:23:53.675  1150  1150 I zygote  :   at void android.support.v7.app.AppCompatDelegateImpl.setContentView(int) (AppCompatDelegateImpl.java:466)
    09-26 19:23:53.675  1150  1150 I zygote  :   at void android.support.v7.app.AppCompatActivity.setContentView(int) (AppCompatActivity.java:140)
    09-26 19:23:53.675  1150  1150 I zygote  :   at void com.powervr.PVRMonitor.PVRMonitor.onCreate(android.os.Bundle) (PVRMonitor.java:577)
    09-26 19:23:53.675  1150  1150 I zygote  :   at void android.app.Activity.performCreate(android.os.Bundle, android.os.PersistableBundle) (Activity.java:6999)
    09-26 19:23:53.675  1150  1150 I zygote  :   at void android.app.Activity.performCreate(android.os.Bundle) (Activity.java:6990)
    09-26 19:23:53.675  1150  1150 I zygote  :   at void android.app.Instrumentation.callActivityOnCreate(android.app.Activity, android.os.Bundle) (Instrumentation.java:1214)
    09-26 19:23:53.675  1150  1150 I zygote  :   at android.app.Activity android.app.ActivityThread.performLaunchActivity(android.app.ActivityThread$ActivityClientRecord, android.content.Intent) (ActivityThread.java:2731)
    09-26 19:23:53.675  1150  1150 I zygote  :   at void android.app.ActivityThread.handleLaunchActivity(android.app.ActivityThread$ActivityClientRecord, android.content.Intent, java.lang.String) (ActivityThread.java:2856)
    09-26 19:23:53.675  1150  1150 I zygote  :   at void android.app.ActivityThread.-wrap11(android.app.ActivityThread, android.app.ActivityThread$ActivityClientRecord, android.content.Intent, java.lang.String) (ActivityThread.java:-1)
    09-26 19:23:53.675  1150  1150 I zygote  :   at void android.app.ActivityThread$H.handleMessage(android.os.Message) (ActivityThread.java:1589)
    09-26 19:23:53.675  1150  1150 I zygote  :   at void android.os.Handler.dispatchMessage(android.os.Message) (Handler.java:106)
    09-26 19:23:53.675  1150  1150 I zygote  :   at void android.os.Looper.loop() (Looper.java:164)
    09-26 19:23:53.675  1150  1150 I zygote  :   at void android.app.ActivityThread.main(java.lang.String[]) (ActivityThread.java:6494)
    09-26 19:23:53.675  1150  1150 I zygote  :   at java.lang.Object java.lang.reflect.Method.invoke(java.lang.Object, java.lang.Object[]) (Method.java:-2)
    09-26 19:23:53.675  1150  1150 I zygote  :   at void com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run() (RuntimeInit.java:438)
    09-26 19:23:53.675  1150  1150 I zygote  :   at void com.android.internal.os.ZygoteInit.main(java.lang.String[]) (ZygoteInit.java:807)
    09-26 19:23:53.675  1150  1150 I zygote  : Caused by: java.lang.ClassNotFoundException: Didn't find class "android.view.View$OnUnhandledKeyEventListener" on path: DexPathList[[zip file "/data/app/com.powervr.PVRMonitor-YvW-fB1aVhYlYw7lTZYHcQ==/base.apk"],nativeLibraryDirectories=[/data/app/com.powervr.PVRMonitor-YvW-fB1aVhYlYw7lTZYHcQ==/lib/arm, /data/app/com.powervr.PVRMonitor-YvW-fB1aVhYlYw7lTZYHcQ==/base.apk!/lib/armeabi-v7a, /system/lib, /vendor/lib]]
    09-26 19:23:53.675  1150  1150 I zygote  :   at java.lang.Class dalvik.system.BaseDexClassLoader.findClass(java.lang.String) (BaseDexClassLoader.java:125)
    09-26 19:23:53.675  1150  1150 I zygote  :   at java.lang.Class java.lang.ClassLoader.loadClass(java.lang.String, boolean) (ClassLoader.java:379)
    09-26 19:23:53.675  1150  1150 I zygote  :   at java.lang.Class java.lang.ClassLoader.loadClass(java.lang.String) (ClassLoader.java:312)
    09-26 19:23:53.676  1150  1150 I zygote  :   at void android.os.Handler.dispatchMessage(android.os.Message) (Handler.java:106)
    09-26 19:23:53.676  1150  1150 I zygote  :   at void android.os.Looper.loop() (Looper.java:164)
    09-26 19:23:53.676  1150  1150 I zygote  :   at void android.app.ActivityThread.main(java.lang.String[]) (ActivityThread.java:6494)
    09-26 19:23:53.676  1150  1150 I zygote  :   at java.lang.Object java.lang.reflect.Method.invoke(java.lang.Object, java.lang.Object[]) (Method.java:-2)
    09-26 19:23:53.676  1150  1150 I zygote  :   at void com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run() (RuntimeInit.java:438)
    09-26 19:23:53.676  1150  1150 I zygote  :   at void com.android.internal.os.ZygoteInit.main(java.lang.String[]) (ZygoteInit.java:807)
    09-26 19:23:53.678  1150  1150 I zygote  : Rejecting re-init on previously-failed class java.lang.Class<android.support.v4.view.ViewCompat$OnUnhandledKeyEventListenerWrapper>: java.lang.NoClassDefFoundError: Failed resolution of: Landroid/view/View$OnUnhandledKeyEventListener;
    09-26 19:23:53.678  1150  1150 I zygote  :   at void android.support.v4.view.ViewCompat.setBackground(android.view.View, android.graphics.drawable.Drawable) (ViewCompat.java:2341)
    09-26 19:23:53.678  1150  1150 I zygote  :   at void android.support.v7.widget.ActionBarContainer.<init>(android.content.Context, android.util.AttributeSet) (ActionBarContainer.java:62)
    09-26 19:23:53.678  1150  1150 I zygote  :   at java.lang.Object java.lang.reflect.Constructor.newInstance0(java.lang.Object[]) (Constructor.java:-2)
    09-26 19:23:53.678  1150  1150 I zygote  :   at java.lang.Object java.lang.reflect.Constructor.newInstance(java.lang.Object[]) (Constructor.java:334)
    09-26 19:23:53.678  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.createView(java.lang.String, java.lang.String, android.util.AttributeSet) (LayoutInflater.java:647)
    09-26 19:23:53.678  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.createViewFromTag(android.view.View, java.lang.String, android.content.Context, android.util.AttributeSet, boolean) (LayoutInflater.java:790)
    09-26 19:23:53.678  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.createViewFromTag(android.view.View, java.lang.String, android.content.Context, android.util.AttributeSet) (LayoutInflater.java:730)
    09-26 19:23:53.678  1150  1150 I zygote  :   at void android.view.LayoutInflater.rInflate(org.xmlpull.v1.XmlPullParser, android.view.View, android.content.Context, android.util.AttributeSet, boolean) (LayoutInflater.java:863)
    09-26 19:23:53.678  1150  1150 I zygote  :   at void android.view.LayoutInflater.rInflateChildren(org.xmlpull.v1.XmlPullParser, android.view.View, android.util.AttributeSet, boolean) (LayoutInflater.java:824)
    09-26 19:23:53.678  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.inflate(org.xmlpull.v1.XmlPullParser, android.view.ViewGroup, boolean) (LayoutInflater.java:515)
    09-26 19:23:53.678  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.inflate(int, android.view.ViewGroup, boolean) (LayoutInflater.java:423)
    09-26 19:23:53.678  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.inflate(int, android.view.ViewGroup) (LayoutInflater.java:374)
    09-26 19:23:53.678  1150  1150 I zygote  :   at android.view.ViewGroup android.support.v7.app.AppCompatDelegateImpl.createSubDecor() (AppCompatDelegateImpl.java:607)
    09-26 19:23:53.678  1150  1150 I zygote  :   at void android.support.v7.app.AppCompatDelegateImpl.ensureSubDecor() (AppCompatDelegateImpl.java:518)
    09-26 19:23:53.678  1150  1150 I zygote  :   at void android.support.v7.app.AppCompatDelegateImpl.setContentView(int) (AppCompatDelegateImpl.java:466)
    09-26 19:23:53.678  1150  1150 I zygote  :   at void android.support.v7.app.AppCompatActivity.setContentView(int) (AppCompatActivity.java:140)
    09-26 19:23:53.678  1150  1150 I zygote  :   at void com.powervr.PVRMonitor.PVRMonitor.onCreate(android.os.Bundle) (PVRMonitor.java:577)
    09-26 19:23:53.678  1150  1150 I zygote  :   at void android.app.Activity.performCreate(android.os.Bundle, android.os.PersistableBundle) (Activity.java:6999)
    09-26 19:23:53.678  1150  1150 I zygote  :   at void android.app.Activity.performCreate(android.os.Bundle) (Activity.java:6990)
    09-26 19:23:53.678  1150  1150 I zygote  :   at void android.app.Instrumentation.callActivityOnCreate(android.app.Activity, android.os.Bundle) (Instrumentation.java:1214)
    09-26 19:23:53.678  1150  1150 I zygote  :   at android.app.Activity android.app.ActivityThread.performLaunchActivity(android.app.ActivityThread$ActivityClientRecord, android.content.Intent) (ActivityThread.java:2731)
    09-26 19:23:53.678  1150  1150 I zygote  :   at void android.app.ActivityThread.handleLaunchActivity(android.app.ActivityThread$ActivityClientRecord, android.content.Intent, java.lang.String) (ActivityThread.java:2856)
    09-26 19:23:53.678  1150  1150 I zygote  :   at void android.app.ActivityThread.-wrap11(android.app.ActivityThread, android.app.ActivityThread$ActivityClientRecord, android.content.Intent, java.lang.String) (ActivityThread.java:-1)
    09-26 19:23:53.678  1150  1150 I zygote  :   at void android.app.ActivityThread$H.handleMessage(android.os.Message) (ActivityThread.java:1589)
    09-26 19:23:53.678  1150  1150 I zygote  :   at void android.os.Handler.dispatchMessage(android.os.Message) (Handler.java:106)
    09-26 19:23:53.679  1150  1150 I zygote  :   at void android.os.Looper.loop() (Looper.java:164)
    09-26 19:23:53.679  1150  1150 I zygote  :   at void android.app.ActivityThread.main(java.lang.String[]) (ActivityThread.java:6494)
    09-26 19:23:53.679  1150  1150 I zygote  :   at java.lang.Object java.lang.reflect.Method.invoke(java.lang.Object, java.lang.Object[]) (Method.java:-2)
    09-26 19:23:53.679  1150  1150 I zygote  :   at void com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run() (RuntimeInit.java:438)
    09-26 19:23:53.679  1150  1150 I zygote  :   at void com.android.internal.os.ZygoteInit.main(java.lang.String[]) (ZygoteInit.java:807)
    09-26 19:23:53.679  1150  1150 I zygote  : Caused by: java.lang.ClassNotFoundException: Didn't find class "android.view.View$OnUnhandledKeyEventListener" on path: DexPathList[[zip file "/data/app/com.powervr.PVRMonitor-YvW-fB1aVhYlYw7lTZYHcQ==/base.apk"],nativeLibraryDirectories=[/data/app/com.powervr.PVRMonitor-YvW-fB1aVhYlYw7lTZYHcQ==/lib/arm, /data/app/com.powervr.PVRMonitor-YvW-fB1aVhYlYw7lTZYHcQ==/base.apk!/lib/armeabi-v7a, /system/lib, /vendor/lib]]
    09-26 19:23:53.679  1150  1150 I zygote  :   at java.lang.Class dalvik.system.BaseDexClassLoader.findClass(java.lang.String) (BaseDexClassLoader.java:125)
    09-26 19:23:53.679  1150  1150 I zygote  :   at java.lang.Class java.lang.ClassLoader.loadClass(java.lang.String, boolean) (ClassLoader.java:379)
    09-26 19:23:53.679  1150  1150 I zygote  :   at java.lang.Class java.lang.ClassLoader.loadClass(java.lang.String) (ClassLoader.java:312)
    09-26 19:23:53.679  1150  1150 I zygote  :   at void android.support.v4.view.ViewCompat.setBackground(android.view.View, android.graphics.drawable.Drawable) (ViewCompat.java:2341)
    09-26 19:23:53.679  1150  1150 I zygote  :   at void android.support.v7.widget.ActionBarContainer.<init>(android.content.Context, android.util.AttributeSet) (ActionBarContainer.java:62)
    09-26 19:23:53.679  1150  1150 I zygote  :   at java.lang.Object java.lang.reflect.Constructor.newInstance0(java.lang.Object[]) (Constructor.java:-2)
    09-26 19:23:53.679  1150  1150 I zygote  :   at java.lang.Object java.lang.reflect.Constructor.newInstance(java.lang.Object[]) (Constructor.java:334)
    09-26 19:23:53.679  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.createView(java.lang.String, java.lang.String, android.util.AttributeSet) (LayoutInflater.java:647)
    09-26 19:23:53.679  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.createViewFromTag(android.view.View, java.lang.String, android.content.Context, android.util.AttributeSet, boolean) (LayoutInflater.java:790)
    09-26 19:23:53.679  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.createViewFromTag(android.view.View, java.lang.String, android.content.Context, android.util.AttributeSet) (LayoutInflater.java:730)
    09-26 19:23:53.679  1150  1150 I zygote  :   at void android.view.LayoutInflater.rInflate(org.xmlpull.v1.XmlPullParser, android.view.View, android.content.Context, android.util.AttributeSet, boolean) (LayoutInflater.java:863)
    09-26 19:23:53.679  1150  1150 I zygote  :   at void android.view.LayoutInflater.rInflateChildren(org.xmlpull.v1.XmlPullParser, android.view.View, android.util.AttributeSet, boolean) (LayoutInflater.java:824)
    09-26 19:23:53.679  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.inflate(org.xmlpull.v1.XmlPullParser, android.view.ViewGroup, boolean) (LayoutInflater.java:515)
    09-26 19:23:53.679  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.inflate(int, android.view.ViewGroup, boolean) (LayoutInflater.java:423)
    09-26 19:23:53.679  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.inflate(int, android.view.ViewGroup) (LayoutInflater.java:374)
    09-26 19:23:53.679  1150  1150 I zygote  :   at android.view.ViewGroup android.support.v7.app.AppCompatDelegateImpl.createSubDecor() (AppCompatDelegateImpl.java:607)
    09-26 19:23:53.679  1150  1150 I zygote  :   at void android.support.v7.app.AppCompatDelegateImpl.ensureSubDecor() (AppCompatDelegateImpl.java:518)
    09-26 19:23:53.679  1150  1150 I zygote  :   at void android.support.v7.app.AppCompatDelegateImpl.setContentView(int) (AppCompatDelegateImpl.java:466)
    09-26 19:23:53.679  1150  1150 I zygote  :   at void android.support.v7.app.AppCompatActivity.setContentView(int) (AppCompatActivity.java:140)
    09-26 19:23:53.679  1150  1150 I zygote  :   at void com.powervr.PVRMonitor.PVRMonitor.onCreate(android.os.Bundle) (PVRMonitor.java:577)
    09-26 19:23:53.679  1150  1150 I zygote  :   at void android.app.Activity.performCreate(android.os.Bundle, android.os.PersistableBundle) (Activity.java:6999)
    09-26 19:23:53.679  1150  1150 I zygote  :   at void android.app.Activity.performCreate(android.os.Bundle) (Activity.java:6990)
    09-26 19:23:53.679  1150  1150 I zygote  :   at void android.app.Instrumentation.callActivityOnCreate(android.app.Activity, android.os.Bundle) (Instrumentation.java:1214)
    09-26 19:23:53.679  1150  1150 I zygote  :   at android.app.Activity android.app.ActivityThread.performLaunchActivity(android.app.ActivityThread$ActivityClientRecord, android.content.Intent) (ActivityThread.java:2731)
    09-26 19:23:53.679  1150  1150 I zygote  :   at void android.app.ActivityThread.handleLaunchActivity(android.app.ActivityThread$ActivityClientRecord, android.content.Intent, java.lang.String) (ActivityThread.java:2856)
    09-26 19:23:53.679  1150  1150 I zygote  :   at void android.app.ActivityThread.-wrap11(android.app.ActivityThread, android.app.ActivityThread$ActivityClientRecord, android.content.Intent, java.lang.String) (ActivityThread.java:-1)
    09-26 19:23:53.679  1150  1150 I zygote  :   at void android.app.ActivityThread$H.handleMessage(android.os.Message) (ActivityThread.java:1589)
    09-26 19:23:53.679  1150  1150 I zygote  :   at void android.os.Handler.dispatchMessage(android.os.Message) (Handler.java:106)
    09-26 19:23:53.680  1150  1150 I zygote  : Rejecting re-init on previously-failed class java.lang.Class<android.support.v4.view.ViewCompat$OnUnhandledKeyEventListenerWrapper>: java.lang.NoClassDefFoundError: Failed resolution of: Landroid/view/View$OnUnhandledKeyEventListener;
    09-26 19:23:53.680  1150  1150 I zygote  :   at void android.support.v4.view.ViewCompat.setBackground(android.view.View, android.graphics.drawable.Drawable) (ViewCompat.java:2341)
    09-26 19:23:53.680  1150  1150 I zygote  :   at void android.support.v7.widget.ActionBarContainer.<init>(android.content.Context, android.util.AttributeSet) (ActionBarContainer.java:62)
    09-26 19:23:53.680  1150  1150 I zygote  :   at java.lang.Object java.lang.reflect.Constructor.newInstance0(java.lang.Object[]) (Constructor.java:-2)
    09-26 19:23:53.680  1150  1150 I zygote  :   at java.lang.Object java.lang.reflect.Constructor.newInstance(java.lang.Object[]) (Constructor.java:334)
    09-26 19:23:53.680  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.createView(java.lang.String, java.lang.String, android.util.AttributeSet) (LayoutInflater.java:647)
    09-26 19:23:53.680  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.createViewFromTag(android.view.View, java.lang.String, android.content.Context, android.util.AttributeSet, boolean) (LayoutInflater.java:790)
    09-26 19:23:53.680  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.createViewFromTag(android.view.View, java.lang.String, android.content.Context, android.util.AttributeSet) (LayoutInflater.java:730)
    09-26 19:23:53.680  1150  1150 I zygote  :   at void android.view.LayoutInflater.rInflate(org.xmlpull.v1.XmlPullParser, android.view.View, android.content.Context, android.util.AttributeSet, boolean) (LayoutInflater.java:863)
    09-26 19:23:53.680  1150  1150 I zygote  :   at void android.view.LayoutInflater.rInflateChildren(org.xmlpull.v1.XmlPullParser, android.view.View, android.util.AttributeSet, boolean) (LayoutInflater.java:824)
    09-26 19:23:53.680  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.inflate(org.xmlpull.v1.XmlPullParser, android.view.ViewGroup, boolean) (LayoutInflater.java:515)
    09-26 19:23:53.680  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.inflate(int, android.view.ViewGroup, boolean) (LayoutInflater.java:423)
    09-26 19:23:53.680  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.inflate(int, android.view.ViewGroup) (LayoutInflater.java:374)
    09-26 19:23:53.680  1150  1150 I zygote  :   at android.view.ViewGroup android.support.v7.app.AppCompatDelegateImpl.createSubDecor() (AppCompatDelegateImpl.java:607)
    09-26 19:23:53.680  1150  1150 I zygote  :   at void android.support.v7.app.AppCompatDelegateImpl.ensureSubDecor() (AppCompatDelegateImpl.java:518)
    09-26 19:23:53.680  1150  1150 I zygote  :   at void android.support.v7.app.AppCompatDelegateImpl.setContentView(int) (AppCompatDelegateImpl.java:466)
    09-26 19:23:53.680  1150  1150 I zygote  :   at void android.support.v7.app.AppCompatActivity.setContentView(int) (AppCompatActivity.java:140)
    09-26 19:23:53.680  1150  1150 I zygote  :   at void com.powervr.PVRMonitor.PVRMonitor.onCreate(android.os.Bundle) (PVRMonitor.java:577)
    09-26 19:23:53.680  1150  1150 I zygote  :   at void android.app.Activity.performCreate(android.os.Bundle, android.os.PersistableBundle) (Activity.java:6999)
    09-26 19:23:53.680  1150  1150 I zygote  :   at void android.app.Activity.performCreate(android.os.Bundle) (Activity.java:6990)
    09-26 19:23:53.680  1150  1150 I zygote  :   at void android.app.Instrumentation.callActivityOnCreate(android.app.Activity, android.os.Bundle) (Instrumentation.java:1214)
    09-26 19:23:53.680  1150  1150 I zygote  :   at android.app.Activity android.app.ActivityThread.performLaunchActivity(android.app.ActivityThread$ActivityClientRecord, android.content.Intent) (ActivityThread.java:2731)
    09-26 19:23:53.680  1150  1150 I zygote  :   at void android.app.ActivityThread.handleLaunchActivity(android.app.ActivityThread$ActivityClientRecord, android.content.Intent, java.lang.String) (ActivityThread.java:2856)
    09-26 19:23:53.680  1150  1150 I zygote  :   at void android.app.ActivityThread.-wrap11(android.app.ActivityThread, android.app.ActivityThread$ActivityClientRecord, android.content.Intent, java.lang.String) (ActivityThread.java:-1)
    09-26 19:23:53.680  1150  1150 I zygote  :   at void android.app.ActivityThread$H.handleMessage(android.os.Message) (ActivityThread.java:1589)
    09-26 19:23:53.680  1150  1150 I zygote  :   at void android.os.Handler.dispatchMessage(android.os.Message) (Handler.java:106)
    09-26 19:23:53.680  1150  1150 I zygote  :   at void android.os.Looper.loop() (Looper.java:164)
    09-26 19:23:53.680  1150  1150 I zygote  :   at void android.app.ActivityThread.main(java.lang.String[]) (ActivityThread.java:6494)
    09-26 19:23:53.680  1150  1150 I zygote  :   at java.lang.Object java.lang.reflect.Method.invoke(java.lang.Object, java.lang.Object[]) (Method.java:-2)
    09-26 19:23:53.680  1150  1150 I zygote  :   at void com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run() (RuntimeInit.java:438)
    09-26 19:23:53.680  1150  1150 I zygote  :   at void com.android.internal.os.ZygoteInit.main(java.lang.String[]) (ZygoteInit.java:807)
    09-26 19:23:53.680  1150  1150 I zygote  : Caused by: java.lang.ClassNotFoundException: Didn't find class "android.view.View$OnUnhandledKeyEventListener" on path: DexPathList[[zip file "/data/app/com.powervr.PVRMonitor-YvW-fB1aVhYlYw7lTZYHcQ==/base.apk"],nativeLibraryDirectories=[/data/app/com.powervr.PVRMonitor-YvW-fB1aVhYlYw7lTZYHcQ==/lib/arm, /data/app/com.powervr.PVRMonitor-YvW-fB1aVhYlYw7lTZYHcQ==/base.apk!/lib/armeabi-v7a, /system/lib, /vendor/lib]]
    09-26 19:23:53.680  1150  1150 I zygote  :   at java.lang.Class dalvik.system.BaseDexClassLoader.findClass(java.lang.String) (BaseDexClassLoader.java:125)
    09-26 19:23:53.680  1150  1150 I zygote  :   at java.lang.Class java.lang.ClassLoader.loadClass(java.lang.String, boolean) (ClassLoader.java:379)
    09-26 19:23:53.680  1150  1150 I zygote  :   at java.lang.Class java.lang.ClassLoader.loadClass(java.lang.String) (ClassLoader.java:312)
    09-26 19:23:53.682  1150  1150 I zygote  : Rejecting re-init on previously-failed class java.lang.Class<android.support.v4.view.ViewCompat$OnUnhandledKeyEventListenerWrapper>: java.lang.NoClassDefFoundError: Failed resolution of: Landroid/view/View$OnUnhandledKeyEventListener;
    09-26 19:23:53.682  1150  1150 I zygote  :   at void android.support.v4.view.ViewCompat.setBackground(android.view.View, android.graphics.drawable.Drawable) (ViewCompat.java:2341)
    09-26 19:23:53.682  1150  1150 I zygote  :   at void android.support.v7.widget.ActionBarContainer.<init>(android.content.Context, android.util.AttributeSet) (ActionBarContainer.java:62)
    09-26 19:23:53.682  1150  1150 I zygote  :   at java.lang.Object java.lang.reflect.Constructor.newInstance0(java.lang.Object[]) (Constructor.java:-2)
    09-26 19:23:53.682  1150  1150 I zygote  :   at java.lang.Object java.lang.reflect.Constructor.newInstance(java.lang.Object[]) (Constructor.java:334)
    09-26 19:23:53.682  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.createView(java.lang.String, java.lang.String, android.util.AttributeSet) (LayoutInflater.java:647)
    09-26 19:23:53.682  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.createViewFromTag(android.view.View, java.lang.String, android.content.Context, android.util.AttributeSet, boolean) (LayoutInflater.java:790)
    09-26 19:23:53.682  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.createViewFromTag(android.view.View, java.lang.String, android.content.Context, android.util.AttributeSet) (LayoutInflater.java:730)
    09-26 19:23:53.682  1150  1150 I zygote  :   at void android.view.LayoutInflater.rInflate(org.xmlpull.v1.XmlPullParser, android.view.View, android.content.Context, android.util.AttributeSet, boolean) (LayoutInflater.java:863)
    09-26 19:23:53.682  1150  1150 I zygote  :   at void android.view.LayoutInflater.rInflateChildren(org.xmlpull.v1.XmlPullParser, android.view.View, android.util.AttributeSet, boolean) (LayoutInflater.java:824)
    09-26 19:23:53.682  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.inflate(org.xmlpull.v1.XmlPullParser, android.view.ViewGroup, boolean) (LayoutInflater.java:515)
    09-26 19:23:53.682  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.inflate(int, android.view.ViewGroup, boolean) (LayoutInflater.java:423)
    09-26 19:23:53.682  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.inflate(int, android.view.ViewGroup) (LayoutInflater.java:374)
    09-26 19:23:53.682  1150  1150 I zygote  :   at android.view.ViewGroup android.support.v7.app.AppCompatDelegateImpl.createSubDecor() (AppCompatDelegateImpl.java:607)
    09-26 19:23:53.682  1150  1150 I zygote  :   at void android.support.v7.app.AppCompatDelegateImpl.ensureSubDecor() (AppCompatDelegateImpl.java:518)
    09-26 19:23:53.682  1150  1150 I zygote  :   at void android.support.v7.app.AppCompatDelegateImpl.setContentView(int) (AppCompatDelegateImpl.java:466)
    09-26 19:23:53.682  1150  1150 I zygote  :   at void android.support.v7.app.AppCompatActivity.setContentView(int) (AppCompatActivity.java:140)
    09-26 19:23:53.682  1150  1150 I zygote  :   at void com.powervr.PVRMonitor.PVRMonitor.onCreate(android.os.Bundle) (PVRMonitor.java:577)
    09-26 19:23:53.682  1150  1150 I zygote  :   at void android.app.Activity.performCreate(android.os.Bundle, android.os.PersistableBundle) (Activity.java:6999)
    09-26 19:23:53.683  1150  1150 I zygote  :   at void android.app.Activity.performCreate(android.os.Bundle) (Activity.java:6990)
    09-26 19:23:53.683  1150  1150 I zygote  :   at void android.app.Instrumentation.callActivityOnCreate(android.app.Activity, android.os.Bundle) (Instrumentation.java:1214)
    09-26 19:23:53.683  1150  1150 I zygote  :   at android.app.Activity android.app.ActivityThread.performLaunchActivity(android.app.ActivityThread$ActivityClientRecord, android.content.Intent) (ActivityThread.java:2731)
    09-26 19:23:53.683  1150  1150 I zygote  :   at void android.app.ActivityThread.handleLaunchActivity(android.app.ActivityThread$ActivityClientRecord, android.content.Intent, java.lang.String) (ActivityThread.java:2856)
    09-26 19:23:53.683  1150  1150 I zygote  :   at void android.app.ActivityThread.-wrap11(android.app.ActivityThread, android.app.ActivityThread$ActivityClientRecord, android.content.Intent, java.lang.String) (ActivityThread.java:-1)
    09-26 19:23:53.683  1150  1150 I zygote  :   at void android.app.ActivityThread$H.handleMessage(android.os.Message) (ActivityThread.java:1589)
    09-26 19:23:53.683  1150  1150 I zygote  :   at void android.os.Handler.dispatchMessage(android.os.Message) (Handler.java:106)
    09-26 19:23:53.683  1150  1150 I zygote  :   at void android.os.Looper.loop() (Looper.java:164)
    09-26 19:23:53.683  1150  1150 I zygote  :   at void android.app.ActivityThread.main(java.lang.String[]) (ActivityThread.java:6494)
    09-26 19:23:53.683  1150  1150 I zygote  :   at java.lang.Object java.lang.reflect.Method.invoke(java.lang.Object, java.lang.Object[]) (Method.java:-2)
    09-26 19:23:53.683  1150  1150 I zygote  :   at void com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run() (RuntimeInit.java:438)
    09-26 19:23:53.683  1150  1150 I zygote  :   at void com.android.internal.os.ZygoteInit.main(java.lang.String[]) (ZygoteInit.java:807)
    09-26 19:23:53.683  1150  1150 I zygote  : Caused by: java.lang.ClassNotFoundException: Didn't find class "android.view.View$OnUnhandledKeyEventListener" on path: DexPathList[[zip file "/data/app/com.powervr.PVRMonitor-YvW-fB1aVhYlYw7lTZYHcQ==/base.apk"],nativeLibraryDirectories=[/data/app/com.powervr.PVRMonitor-YvW-fB1aVhYlYw7lTZYHcQ==/lib/arm, /data/app/com.powervr.PVRMonitor-YvW-fB1aVhYlYw7lTZYHcQ==/base.apk!/lib/armeabi-v7a, /system/lib, /vendor/lib]]
    09-26 19:23:53.683  1150  1150 I zygote  :   at java.lang.Class dalvik.system.BaseDexClassLoader.findClass(java.lang.String) (BaseDexClassLoader.java:125)
    09-26 19:23:53.683  1150  1150 I zygote  :   at java.lang.Class java.lang.ClassLoader.loadClass(java.lang.String, boolean) (ClassLoader.java:379)
    09-26 19:23:53.683  1150  1150 I zygote  :   at java.lang.Class java.lang.ClassLoader.loadClass(java.lang.String) (ClassLoader.java:312)
    09-26 19:23:53.683  1150  1150 I zygote  :   at void android.support.v4.view.ViewCompat.setBackground(android.view.View, android.graphics.drawable.Drawable) (ViewCompat.java:2341)
    09-26 19:23:53.683  1150  1150 I zygote  :   at void android.support.v7.widget.ActionBarContainer.<init>(android.content.Context, android.util.AttributeSet) (ActionBarContainer.java:62)
    09-26 19:23:53.683  1150  1150 I zygote  :   at java.lang.Object java.lang.reflect.Constructor.newInstance0(java.lang.Object[]) (Constructor.java:-2)
    09-26 19:23:53.683  1150  1150 I zygote  :   at java.lang.Object java.lang.reflect.Constructor.newInstance(java.lang.Object[]) (Constructor.java:334)
    09-26 19:23:53.683  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.createView(java.lang.String, java.lang.String, android.util.AttributeSet) (LayoutInflater.java:647)
    09-26 19:23:53.683  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.createViewFromTag(android.view.View, java.lang.String, android.content.Context, android.util.AttributeSet, boolean) (LayoutInflater.java:790)
    09-26 19:23:53.683  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.createViewFromTag(android.view.View, java.lang.String, android.content.Context, android.util.AttributeSet) (LayoutInflater.java:730)
    09-26 19:23:53.683  1150  1150 I zygote  :   at void android.view.LayoutInflater.rInflate(org.xmlpull.v1.XmlPullParser, android.view.View, android.content.Context, android.util.AttributeSet, boolean) (LayoutInflater.java:863)
    09-26 19:23:53.683  1150  1150 I zygote  :   at void android.view.LayoutInflater.rInflateChildren(org.xmlpull.v1.XmlPullParser, android.view.View, android.util.AttributeSet, boolean) (LayoutInflater.java:824)
    09-26 19:23:53.683  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.inflate(org.xmlpull.v1.XmlPullParser, android.view.ViewGroup, boolean) (LayoutInflater.java:515)
    09-26 19:23:53.683  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.inflate(int, android.view.ViewGroup, boolean) (LayoutInflater.java:423)
    09-26 19:23:53.683  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.inflate(int, android.view.ViewGroup) (LayoutInflater.java:374)
    09-26 19:23:53.683  1150  1150 I zygote  :   at android.view.ViewGroup android.support.v7.app.AppCompatDelegateImpl.createSubDecor() (AppCompatDelegateImpl.java:607)
    09-26 19:23:53.683  1150  1150 I zygote  :   at void android.support.v7.app.AppCompatDelegateImpl.ensureSubDecor() (AppCompatDelegateImpl.java:518)
    09-26 19:23:53.683  1150  1150 I zygote  :   at void android.support.v7.app.AppCompatDelegateImpl.setContentView(int) (AppCompatDelegateImpl.java:466)
    09-26 19:23:53.683  1150  1150 I zygote  :   at void android.support.v7.app.AppCompatActivity.setContentView(int) (AppCompatActivity.java:140)
    09-26 19:23:53.683  1150  1150 I zygote  :   at void com.powervr.PVRMonitor.PVRMonitor.onCreate(android.os.Bundle) (PVRMonitor.java:577)
    09-26 19:23:53.683  1150  1150 I zygote  :   at void android.app.Activity.performCreate(android.os.Bundle, android.os.PersistableBundle) (Activity.java:6999)
    09-26 19:23:53.684  1150  1150 I zygote  : Rejecting re-init on previously-failed class java.lang.Class<android.support.v4.view.ViewCompat$OnUnhandledKeyEventListenerWrapper>: java.lang.NoClassDefFoundError: Failed resolution of: Landroid/view/View$OnUnhandledKeyEventListener;
    09-26 19:23:53.684  1150  1150 I zygote  :   at void android.support.v4.view.ViewCompat.setBackground(android.view.View, android.graphics.drawable.Drawable) (ViewCompat.java:2341)
    09-26 19:23:53.684  1150  1150 I zygote  :   at void android.support.v7.widget.ActionBarContainer.<init>(android.content.Context, android.util.AttributeSet) (ActionBarContainer.java:62)
    09-26 19:23:53.684  1150  1150 I zygote  :   at java.lang.Object java.lang.reflect.Constructor.newInstance0(java.lang.Object[]) (Constructor.java:-2)
    09-26 19:23:53.684  1150  1150 I zygote  :   at java.lang.Object java.lang.reflect.Constructor.newInstance(java.lang.Object[]) (Constructor.java:334)
    09-26 19:23:53.684  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.createView(java.lang.String, java.lang.String, android.util.AttributeSet) (LayoutInflater.java:647)
    09-26 19:23:53.684  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.createViewFromTag(android.view.View, java.lang.String, android.content.Context, android.util.AttributeSet, boolean) (LayoutInflater.java:790)
    09-26 19:23:53.684  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.createViewFromTag(android.view.View, java.lang.String, android.content.Context, android.util.AttributeSet) (LayoutInflater.java:730)
    09-26 19:23:53.684  1150  1150 I zygote  :   at void android.view.LayoutInflater.rInflate(org.xmlpull.v1.XmlPullParser, android.view.View, android.content.Context, android.util.AttributeSet, boolean) (LayoutInflater.java:863)
    09-26 19:23:53.684  1150  1150 I zygote  :   at void android.view.LayoutInflater.rInflateChildren(org.xmlpull.v1.XmlPullParser, android.view.View, android.util.AttributeSet, boolean) (LayoutInflater.java:824)
    09-26 19:23:53.684  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.inflate(org.xmlpull.v1.XmlPullParser, android.view.ViewGroup, boolean) (LayoutInflater.java:515)
    09-26 19:23:53.684  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.inflate(int, android.view.ViewGroup, boolean) (LayoutInflater.java:423)
    09-26 19:23:53.684  1150  1150 I zygote  :   at android.view.View android.view.LayoutInflater.inflate(int, android.view.ViewGroup) (LayoutInflater.java:374)
    09-26 19:23:53.684  1150  1150 I zygote  :   at android.view.ViewGroup android.support.v7.app.AppCompatDelegateImpl.createSubDecor() (AppCompatDelegateImpl.java:607)
    09-26 19:23:53.684  1150  1150 I zygote  :   at void android.support.v7.app.AppCompatDelegateImpl.ensureSubDecor() (AppCompatDelegateImpl.java:518)
    09-26 19:23:53.684  1150  1150 I zygote  :   at void android.support.v7.app.AppCompatDelegateImpl.setContentView(int) (AppCompatDelegateImpl.java:466)
    09-26 19:23:53.684  1150  1150 I zygote  :   at void android.support.v7.app.AppCompatActivity.setContentView(int) (AppCompatActivity.java:140)
    09-26 19:23:53.684  1150  1150 I zygote  :   at void com.powervr.PVRMonitor.PVRMonitor.onCreate(android.os.Bundle) (PVRMonitor.java:577)
    09-26 19:23:53.684  1150  1150 I zygote  :   at void android.app.Activity.performCreate(android.os.Bundle, android.os.PersistableBundle) (Activity.java:6999)
    09-26 19:23:53.684  1150  1150 I zygote  :   at void android.app.Activity.performCreate(android.os.Bundle) (Activity.java:6990)
    09-26 19:23:53.684  1150  1150 I zygote  :   at void android.app.Instrumentation.callActivityOnCreate(android.app.Activity, android.os.Bundle) (Instrumentation.java:1214)
    09-26 19:23:53.684  1150  1150 I zygote  :   at android.app.Activity android.app.ActivityThread.performLaunchActivity(android.app.ActivityThread$ActivityClientRecord, android.content.Intent) (ActivityThread.java:2731)
    09-26 19:23:53.684  1150  1150 I zygote  :   at void android.app.ActivityThread.handleLaunchActivity(android.app.ActivityThread$ActivityClientRecord, android.content.Intent, java.lang.String) (ActivityThread.java:2856)
    09-26 19:23:53.684  1150  1150 I zygote  :   at void android.app.ActivityThread.-wrap11(android.app.ActivityThread, android.app.ActivityThread$ActivityClientRecord, android.content.Intent, java.lang.String) (ActivityThread.java:-1)
    09-26 19:23:53.684  1150  1150 I zygote  :   at void android.app.ActivityThread$H.handleMessage(android.os.Message) (ActivityThread.java:1589)
    09-26 19:23:53.684  1150  1150 I zygote  :   at void android.os.Handler.dispatchMessage(android.os.Message) (Handler.java:106)
    09-26 19:23:53.684  1150  1150 I zygote  :   at void android.os.Looper.loop() (Looper.java:164)
    09-26 19:23:53.684  1150  1150 I zygote  :   at void android.app.ActivityThread.main(java.lang.String[]) (ActivityThread.java:6494)
    09-26 19:23:53.684  1150  1150 I zygote  :   at java.lang.Object java.lang.reflect.Method.invoke(java.lang.Object, java.lang.Object[]) (Method.java:-2)
    09-26 19:23:53.684  1150  1150 I zygote  :   at void com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run() (RuntimeInit.java:438)
    09-26 19:23:53.684  1150  1150 I zygote  :   at void com.android.internal.os.ZygoteInit.main(java.lang.String[]) (ZygoteInit.java:807)
    09-26 19:23:53.684  1150  1150 I zygote  : Caused by: java.lang.ClassNotFoundException: Didn't find class "android.view.View$OnUnhandledKeyEventListener" on path: DexPathList[[zip file "/data/app/com.powervr.PVRMonitor-YvW-fB1aVhYlYw7lTZYHcQ==/base.apk"],nativeLibraryDirectories=[/data/app/com.powervr.PVRMonitor-YvW-fB1aVhYlYw7lTZYHcQ==/lib/arm, /data/app/com.powervr.PVRMonitor-YvW-fB1aVhYlYw7lTZYHcQ==/base.apk!/lib/armeabi-v7a, /system/lib, /vendor/lib]]
    09-26 19:23:53.684  1150  1150 I zygote  :   at java.lang.Class dalvik.system.BaseDexClassLoader.findClass(java.lang.String) (BaseDexClassLoader.java:125)
    09-26 19:23:53.684  1150  1150 I zygote  :   at java.lang.Class java.lang.ClassLoader.loadClass(java.lang.String, boolean) (ClassLoader.java:379)
    09-26 19:23:53.684  1150  1150 I zygote  :   at java.lang.Class java.lang.ClassLoader.loadClass(java.lang.String) (ClassLoader.java:312)
    09-26 19:23:54.003  1150  1155 I zygote  : Do partial code cache collection, code=31KB, data=26KB
    09-26 19:23:54.006  1150  1155 I zygote  : After code cache collection, code=31KB, data=26KB
    09-26 19:23:54.006  1150  1155 I zygote  : Increasing code cache capacity to 128KB
    09-26 19:23:54.118  1150  1155 I zygote  : Do partial code cache collection, code=37KB, data=53KB
    09-26 19:23:54.119  1150  1155 I zygote  : After code cache collection, code=37KB, data=53KB
    09-26 19:23:54.119  1150  1155 I zygote  : Increasing code cache capacity to 256KB
    09-26 19:23:54.120  1150  1155 I zygote  : Compiler allocated 4MB to compile void android.widget.TextView.<init>(android.content.Context, android.util.AttributeSet, int, int)
    09-26 19:23:54.205  1150  1167 D OpenGLRenderer: HWUI GL Pipeline
    09-26 19:23:54.306  1150  1155 I zygote  : Do full code cache collection, code=126KB, data=71KB
    09-26 19:23:54.307  1150  1155 I zygote  : After code cache collection, code=124KB, data=62KB
    09-26 19:23:54.329  1150  1150 I HUD     : type=1400 audit(0.0:19): avc: denied { read } for name="stat" dev="proc" ino=4026532102 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:proc_stat:s0 tclass=file permissive=1
    09-26 19:23:54.433  1150  1167 D vndksupport: Loading /vendor/lib/hw/gralloc.jacinto6.so from current namespace instead of sphal namespace.
    09-26 19:23:54.439  1150  1167 D vndksupport: Loading /vendor/lib/hw/gralloc.jacinto6.so from current namespace instead of sphal namespace.
    09-26 19:23:54.329  1150  1150 I HUD     : type=1400 audit(0.0:20): avc: denied { open } for path="/proc/stat" dev="proc" ino=4026532102 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:proc_stat:s0 tclass=file permissive=1
    09-26 19:23:54.443  1150  1167 I com.powervr.PVRMonitor: android::hardware::configstore::V1_0::ISurfaceFlingerConfigs::hasWideColorDisplay retrieved: 0
    09-26 19:23:54.443  1150  1167 I OpenGLRenderer: Initialized EGL, version 1.4
    09-26 19:23:54.443  1150  1167 D OpenGLRenderer: Swap behavior 1
    09-26 19:23:54.329  1150  1150 I HUD     : type=1400 audit(0.0:21): avc: denied { getattr } for path="/proc/stat" dev="proc" ino=4026532102 scontext=u:r:untrusted_app:s0:c512,c768 tcontext=u:object_r:proc_stat:s0 tclass=file permissive=1
    09-26 19:23:54.546  1150  1155 I zygote  : Do partial code cache collection, code=125KB, data=70KB
    09-26 19:23:54.548  1150  1155 I zygote  : After code cache collection, code=125KB, data=70KB
    09-26 19:23:54.548  1150  1155 I zygote  : Increasing code cache capacity to 512KB
    09-26 19:23:54.792  1150  1167 D vndksupport: Loading /vendor/lib/hw/android.hardware.graphics.mapper@2.0-impl.so from current namespace instead of sphal namespace.
    09-26 19:23:54.793  1150  1167 D vndksupport: Loading /vendor/lib/hw/gralloc.jacinto6.so from current namespace instead of sphal namespace.
    09-26 19:23:54.825   306   330 I ActivityManager: Displayed com.powervr.PVRMonitor/.PVRMonitor: +1s483ms
    09-26 19:23:54.871   306   330 D OpenGLRenderer: HWUI GL Pipeline
    09-26 19:23:54.988   418   418 W StaticLayout: maxLineHeight should not be -1.  maxLines:1 lineCount:1
    09-26 19:23:58.191   306   306 W WindowManager: removeWindowToken: Attempted to remove non-existing token: android.os.Binder@9da326f
    09-26 19:24:00.987   306   329 I ActivityManager: Start proc 1175:android.ext.services/u0a29 for service android.ext.services/.storage.CacheQuotaServiceImpl
    09-26 19:24:01.027  1175  1175 I zygote  : The ClassLoaderContext is a special shared library.
    09-26 19:24:08.365   959   994 D InitAlarmsService: Clearing and rescheduling alarms.
    Herman
  • Hi Yordan,
    I tried this release patch for updating SGX DDK  http://review.omapzoom.org/#/c/39002/
    but got the below errors and fails to get screen display successfully.
    01-01 00:00:37.566   659   659 E IMGSRV  : :0: PVRSRVConnect: Unable to open connection.
    01-01 00:00:37.566   659   659 E IMGSRV  : :0: OpenPVRServices: Failed to open services connection
    01-01 00:00:37.566   659   659 E IMGSRV  : :0: hal_init: Failed to open services (err=-14)
    01-01 00:00:37.566   659   659 E IMGSRV  : :0: hal_open: Graphics HAL not initialized
    01-01 00:00:37.566   659   659 F Gralloc0Allocator: failed to open gralloc0 device: Not a typewriter
    01-01 00:00:37.567   659   659 F libc    : Fatal signal 6 (SIGABRT), code -6 in tid 659 (android.hardwar)
    01-01 00:00:37.596   750   750 I crash_dump32: obtaining output fd from tombstoned
    01-01 00:00:37.596   252   252 I /system/bin/tombstoned: received crash request for pid 659
    01-01 00:00:37.597   750   750 I crash_dump32: performing dump of process 659 (target tid = 659)
    01-01 00:00:37.598   750   750 F DEBUG   : *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
    01-01 00:00:37.598   750   750 F DEBUG   : Build fingerprint: 'TI/full_jacinto6evm/jacinto6evm:8.0.0/OPR6.170623.023/louis08261027:userdebug/test-keys'
    01-01 00:00:37.598   750   750 F DEBUG   : Revision: '0'
    01-01 00:00:37.598   750   750 F DEBUG   : ABI: 'arm'
    01-01 00:00:37.598   750   750 F DEBUG   : pid: 659, tid: 659, name: android.hardwar  >>> /vendor/bin/hw/android.hardware.graphics.allocator@2.0-service <<<
    01-01 00:00:37.598   750   750 F DEBUG   : signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
    01-01 00:00:37.602   750   750 F DEBUG   : Abort message: 'failed to open gralloc0 device: Not a typewriter'
    01-01 00:00:37.602   750   750 F DEBUG   :     r0 00000000  r1 00000293  r2 00000006  r3 00000008
    01-01 00:00:37.602   750   750 F DEBUG   :     r4 00000293  r5 00000293  r6 beefe390  r7 0000010c
    01-01 00:00:37.602   750   750 F DEBUG   :     r8 beefe9c8  r9 ae798840  sl 00000000  fp 403cff79
    01-01 00:00:37.602   750   750 F DEBUG   :     ip 00000000  sp beefe380  lr aea653c7  pc aea95a9c  cpsr 200f0010
    01-01 00:00:37.622   750   750 F DEBUG   :
    01-01 00:00:37.622   750   750 F DEBUG   : backtrace:
    01-01 00:00:37.623   750   750 F DEBUG   :     #00 pc 0004aa9c  /system/lib/libc.so (tgkill+12)
    01-01 00:00:37.623   750   750 F DEBUG   :     #01 pc 0001a3c3  /system/lib/libc.so (abort+54)
    01-01 00:00:37.623   750   750 F DEBUG   :     #02 pc 0000663f  /system/lib/liblog.so (__android_log_assert+154)
    01-01 00:00:37.623   750   750 F DEBUG   :     #03 pc 00004267  /vendor/lib/hw/android.hardware.graphics.allocator@2.0-impl.so (_ZN7android8hardware8graphics9allocator4V2_014implementation17Gralloc0AllocatorC1EPK11hw_module_t+70)
    01-01 00:00:37.623   750   750 F DEBUG   :     #04 pc 0000413d  /vendor/lib/hw/android.hardware.graphics.allocator@2.0-impl.so (HIDL_FETCH_IAllocator+100)
    01-01 00:00:37.623   750   750 F DEBUG   :     #05 pc 0001d4bd  /system/lib/libhidltransport.so (_ZN7android8hardware25PassthroughServiceManager3getERKNS0_11hidl_stringES4_+1372)
    01-01 00:00:37.623   750   750 F DEBUG   :     #06 pc 0000ea87  /system/lib/android.hardware.graphics.allocator@2.0.so (_ZN7android8hardware8graphics9allocator4V2_010IAllocator10getServiceERKNSt3__112basic_stringIcNS5_11char_traitsIcEENS5_9allocatorIcEEEEb+926)
    01-01 00:00:37.623   750   750 F DEBUG   :     #07 pc 00000cab  /vendor/bin/hw/android.hardware.graphics.allocator@2.0-service
    01-01 00:00:37.623   750   750 F DEBUG   :     #08 pc 00000c55  /vendor/bin/hw/android.hardware.graphics.allocator@2.0-service
    01-01 00:00:37.623   750   750 F DEBUG   :     #09 pc 00000bfb  /vendor/bin/hw/android.hardware.graphics.allocator@2.0-service
    01-01 00:00:37.623   750   750 F DEBUG   :     #10 pc 00017d45  /system/lib/libc.so (__libc_init+48)
    01-01 00:00:37.623   750   750 F DEBUG   :     #11 pc 00000ac0  /vendor/bin/hw/android.hardware.graphics.allocator@2.0-service (_start+100)
    Do you get idea on this?
    Louis
  • Hi Yordan,
    Do you have any further idea of this? Or does TI have any suggestion for problem of running PVRMonitor?
    Herman
  • Hi Herman,
    It appears that root permissions are needed for the PVRMonitor here. Can you share the which version and the source of the PVRMonitor you are using.
    Gowtham
  • Hi Gowtham,
    Basically, we don't need to test PVRMonitor now so you can ignore this issue, thanks.
    Herman
