TDA2PXEVM: Apply earlyboot-kernel-patches failed
Part Number: TDA2PXEVM
Hi all,
I'm tring to build Linux Vision SDK for fast boot  which refer in the VisionSDK_Linux_UserGuide.pdf
But I stuck on apply the earlyboot-kernel-patches for kernel.
My SDK version is Vsion SDK 03_07_00_00, below is my log and error.
ac@ub:~/TDAx/PROCESSOR_SDK_VISION_03_07_00_00/ti_components/os_tools/linux/kernel/omap$ git checkout -b fast-boot tags/REL_VISION_SDK_03_07_00_00
Switched to a new branch 'fast-boot'
ac@ub:~/TDAx/PROCESSOR_SDK_VISION_03_07_00_00/ti_components/os_tools/linux/kernel/omap$ git status
On branch fast-boot
Untracked files:
(use "git add <file>..." to include in what will be committed)
arch/arm/configs/ti_sdk_dra7x_release_defconfig
ac@ub:~/TDAx/PROCESSOR_SDK_VISION_03_07_00_00/ti_components/os_tools/linux/kernel/omap$ git apply ../linux-kernel-addon/earlyboot-kernel-patches/0001-dra7xx-Kernel-Optimizations-for-early-use-case-enabl.patch
error: patch failed: ti_config_fragments/auto.cfg:50
error: ti_config_fragments/auto.cfg: patch does not apply
On branch fast-boot
Untracked files:
nothing added to commit but untracked files present (use "git add" to track)
How to apply apply the patches?
AC
    You have to use git am commonad to apply patches.
    Anuj
  • Hi Anuj,
    Thanks for reply. I still got error...
    ac@ub:~/TDAx/PROCESSOR_SDK_VISION_03_07_00_00/ti_components/os_tools/linux/kernel/omap$ git am ../linux-kernel-addon/earlyboot-kernel-patches/0001-dra7xx-Kernel-Optimizations-for-early-use-case-enabl.patch
    Applying: dra7xx: Kernel Optimizations for early-use-case enablement
    Patch failed at 0001 dra7xx: Kernel Optimizations for early-use-case enablement
    The copy of the patch that failed is found in: .git/rebase-apply/patch
    When you have resolved this problem, run "git am --continue".
    If you prefer to skip this patch, run "git am --skip" instead.
    To restore the original branch and stop patching, run "git am --abort".
    On branch fast-boot
    You are in the middle of an am session.
    (fix conflicts and then run "git am --continue")
    (use "git am --skip" to skip this patch)
    (use "git am --abort" to restore the original branch)
    Untracked files:
    Please update the below patch like shown below
    Replace below lines
    @@ -50,3 +50,8 @@ CONFIG_ICS932S401=n
    CONFIG_VMEM_EXP_DMABUF=y
    CONFIG_DEBUG_INFO=y
    CONFIG_ARM_LPAE=y
    +#CONFIG_DEBUG_INFO=y
    +# Boot time options
    +# Change kernel compression to LZO which has faster decompression
    +# times compared to gzip.
    +CONFIG_RD_LZO=y
    With
    @@ -51,3 +51,8 @@ CONFIG_VMEM_EXP_DMABUF=y
    CONFIG_DEBUG_INFO=y
    CONFIG_ARM_LPAE=y
    CONFIG_BLK_DEV_NVME=y
    +CONFIG_RD_LZO=y
    And then apply the patch.
    Anuj
