When using the default PSP image from the DVSDK 4.0, my omap3530 (gumstix overo) boots into Matrix-GUI, and I can use the mouse and select a couple of the applications. I took the matrix-gui out of the rc5 so that I could get to the command prompt, but instead it just seems to hang after loading the modules for gstreamer. Any ideas what could be happening?
Thanks!
Here is my boot log:
@ @�C�C��exas Instruments X-Loader 1.4.4ss (Nov 12 2010 - 10:22:09)
OMAP3530-GP ES3.1
Board revision: 0
Reading boot sector
Loading u-boot.bin from mmc
U-Boot 2010.09 (Nov 13 2010 - 20:30:07)
OMAP3530-GP ES3.1, CPU-OPP2, L3-165MHz, Max CPU Clock 720 mHz
Gumstix Overo board + LPDDR/NAND
I2C: ready
DRAM: 256 MiB
NAND: 256 MiB
In: serial
Out: serial
Err: serial
Board revision: 0
Tranceiver detected on mmc2
No EEPROM on expansion board
Die ID #1e4e00040000000004037f680d016010
Net: smc911x-0
Hit any key to stop autoboot: 0
mmc1 is available
reading boot.scr
** Unable to read "boot.scr" from mmc 0:1 **
reading uImage
2978832 bytes read
Booting from mmc ...
## Booting kernel from Legacy Image at 82000000 ...
Image Name: Linux-2.6.32
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2978768 Bytes = 2.8 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux...................................................................................................
........................................................................................... done, booting the kernel.
Linux version 2.6.32 (tcalef@tcalef-desktop) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-203) ) #1 Tue Dec 14 08:32:5
2 EST 2010
CPU: ARMv7 Processor [411fc083] revision 3 (ARMv7), cr=10c53c7f
CPU: VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
Machine: Gumstix Overo
Memory policy: ECC disabled, Data cache writeback
OMAP3430/3530 ES3.1 (l2cache iva sgx neon isp 720m )
SRAM: Mapped pa 0x40200000 to va 0xfe400000 size: 0x100000
Reserving 12582912 bytes SDRAM for VRAM
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
Kernel command line: console=ttyS2,115200n8 mpurate=500 vram=12M omapfb.mode=dvi:1024x768MR-16@60 omapfb.debug=y omapd
ss.def_disp=dvi root=/dev/mmcblk0p2 rw rootfstype=ext3 rootwait
PID hash table entries: 1024 (order: 0, 4096 bytes)
Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
Memory: 128MB 128MB = 256MB total
Memory: 241024KB available (5396K code, 619K data, 164K init, 0K highmem)
Hierarchical RCU implementation.
NR_IRQS:402
Clocking rate (Crystal/Core/MPU): 26.0/224/500 MHz
Reprogramming SDRC clock to 224791666 Hz
dpll3_m2_clk rate change failed: -22
GPMC revision 5.0
IRQ: Found an INTC at 0xfa200000 (revision 4.0) with 96 interrupts
Total of 96 interrupts on 1 active controller
OMAP GPIO hardware version 2.5
OMAP clockevent source: GPTIMER1 at 32768 Hz
Console: colour dummy device 80x30
Calibrating delay loop... 499.92 BogoMIPS (lpj=1949696)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
tmpfs: No value for mount option 'mode'
devtmpfs: initialized
regulator: core version 0.5
NET: Registered protocol family 16
Found NAND on CS0
Registering NAND on CS0
Target VDD1 OPP = 3, VDD2 OPP = 3
OMAP DMA hardware revision 4.0
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
i2c_omap i2c_omap.1: bus 1 rev3.12 at 2600 kHz
twl4030: PIH (irq 7) chaining IRQs 368..375
twl4030: power (irq 373) chaining IRQs 376..383
twl4030: gpio (irq 368) chaining IRQs 384..401
regulator: VUSB1V5: 1500 mV normal standby
regulator: VUSB1V8: 1800 mV normal standby
regulator: VUSB3V1: 3100 mV normal standby
twl4030_usb twl4030_usb: Initialized TWL4030 USB module
regulator: VMMC1: 1850 <--> 3150 mV normal standby
regulator: VDAC: 1800 mV normal standby
regulator: VPLL2: 1800 mV normal standby
i2c_omap i2c_omap.3: bus 3 rev3.12 at 400 kHz
Bluetooth: Core ver 2.15
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
cfg80211: Using static regulatory domain info
cfg80211: Regulatory domain: 00
(start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
(2402000 KHz - 2472000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
(2457000 KHz - 2482000 KHz @ 20000 KHz), (600 mBi, 2000 mBm)
(2474000 KHz - 2494000 KHz @ 20000 KHz), (600 mBi, 2000 mBm)
(5170000 KHz - 5250000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
(5735000 KHz - 5835000 KHz @ 40000 KHz), (600 mBi, 2000 mBm)
cfg80211: Calling CRDA to update world regulatory domain
Switching to clocksource 32k_counter
musb_hdrc: version 6.0, musb-dma, host, debug=0
musb_hdrc: USB Host mode controller at fa0ab000 using DMA, IRQ 92
musb_hdrc musb_hdrc: MUSB HDRC host driver
musb_hdrc musb_hdrc: new USB bus registered, assigned bus number 1
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: MUSB HDRC host driver
usb usb1: Manufacturer: Linux 2.6.32 musb-hcd
usb usb1: SerialNumber: musb_hdrc
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
NET: Registered protocol family 2
IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
TCP established hash table entries: 8192 (order: 4, 65536 bytes)
TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
omap-iommu omap-iommu.0: isp registered
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
JFFS2 version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red Hat, Inc.
msgmni has been set to 471
alg: No test for stdrng (krng)
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
OMAP DSS rev 2.0
OMAP DISPC rev 3.0
OMAP VENC rev 2
Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
serial8250.0: ttyS0 at MMIO 0x4806a000 (irq = 72) is a ST16654
serial8250.1: ttyS1 at MMIO 0x4806c000 (irq = 73) is a ST16654
serial8250.2: ttyS2 at MMIO 0x49020000 (irq = 74) is a ST16654
console [ttyS2] enabled
usb 1-1: new high speed USB device using musb_hdrc and address 2
brd: module loaded
loop: module loaded
omap2-nand driver initializing
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xba (Micron NAND 256MiB 1,8V 16-bit)
cmdlinepart partition parsing not available
Creating 5 MTD partitions on "omap2-nand":
0x000000000000-0x000000080000 : "xloader"
0x000000080000-0x000000240000 : "uboot"
0x000000240000-0x000000280000 : "uboot environment"
0x000000280000-0x000000680000 : "linux"
0x000000680000-0x000010000000 : "rootfs"
smsc911x: Driver version 2008-10-21.
smsc911x-mdio: probed
eth0: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:01, irq=-1)
net eth0: MAC Address: 00:15:c9:28:d6:4e
usbcore: registered new interface driver asix
usbcore: registered new interface driver cdc_ether
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
ehci-omap ehci-omap.0: OMAP-EHCI Host Controller
ehci-omap ehci-omap.0: new USB bus registered, assigned bus number 2
ehci-omap ehci-omap.0: irq 77, io mem 0x48064800
ehci-omap ehci-omap.0: USB 2.0 started, EHCI 1.00
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: OMAP-EHCI Host Controller
usb usb2: Manufacturer: Linux 2.6.32 ehci_hcd
usb usb2: SerialNumber: ehci-omap.0
usb 1-1: New USB device found, idVendor=050d, idProduct=0017
usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
usb 1-1: Product: USB 2.0 Hub [MTT]
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 3 ports detected
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 7 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
udc: OMAP UDC driver, version: 4 October 2004 (iso) (dma)
mice: PS/2 mouse device common for all mice
twl_rtc twl_rtc: rtc core: registered twl_rtc as rtc0
i2c /dev entries driver
Linux video capture interface: v2.00
omap-iommu omap-iommu.0: isp: version 1.1
OMAP Watchdog Timer Rev 0x31: initial timeout 60 sec
Bluetooth: HCI UART driver ver 2.2
Bluetooth: HCI H4 protocol initialized
Bluetooth: HCI BCSP protocol initialized
Bluetooth: HCILL protocol initialized
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
Advanced Linux Sound Architecture Driver Version 1.0.21.
usbcore: registered new interface driver snd-usb-audio
No device for DAI omap-mcbsp-dai-0
No device for DAI omap-mcbsp-dai-1
No device for DAI omap-mcbsp-dai-2
No device for DAI omap-mcbsp-dai-3
No device for DAI omap-mcbsp-dai-4
overo SoC init
asoc: twl4030 <-> omap-mcbsp-dai-0 mapping ok
ALSA device list:
#0: overo (twl4030)
usb 1-1.2: new high speed USB device using musb_hdrc and address 3
oprofile: using arm/armv7
TCP cubic registered
NET: Registered protocol family 17
NET: Registered protocol family 15
Bluetooth: L2CAP ver 2.14
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO (Voice Link) ver 0.6
Bluetooth: SCO socket layer initialized
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
ThumbEE CPU extension supported.
Power Management for TI OMAP3.
Unable to set L3 frequency (332000000)
Switched to new clocking rate (Crystal/Core/MPU): 26.0/224/500 MHz
IVA2 clocking rate: 360 MHz
SmartReflex driver initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 1
fbcvt: 1024x768@60: CVT Name - .786M3-R
Console: switching to colour frame buffer device 128x48
usb 1-1.2: New USB device found, idVendor=045e, idProduct=076e
usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 1-1.2: Product: Microsoft�® LifeCam HD-5001
usb 1-1.2: Manufacturer: Microsoft
regulator_init_complete: incomplete constraints, leaving VDVI on
regulator_init_complete: incomplete constraints, leaving VDAC on
twl_rtc twl_rtc: setting system clock to 2010-10-15 18:30:55 UTC (1287167455)
omap_vout omap_vout: probed for an unknown device
mmc0: host does not support reading read-only switch. assuming write-enable.
mmc0: new high speed SDHC card at address e624
mmcblk0: mmc0:e624 SU08G 7.40 GiB
mmcblk0: p1 p2
mmc1: new SDIO card at address 0001
ALSA sound/usb/usbaudio.c:1297: 3:3:1: cannot get freq at ep 0x82
kjournald starting. Commit interval 5 seconds
EXT3-fs (mmcblk0p2): warning: maximal mount count reached, running e2fsck is recommended
EXT3-fs (mmcblk0p2): using internal journal
EXT3-fs (mmcblk0p2): recovery complete
EXT3-fs (mmcblk0p2): mounted filesystem with writeback data mode
VFS: Mounted root (ext3 filesystem) on device 179:2.
usb 1-1.5: new low speed USB device using musb_hdrc and address 4
devtmpfs: mounted
Freeing init memory: 164K
usb 1-1.5: New USB device found, idVendor=0461, idProduct=4e04
usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 1-1.5: Product: USB NETVISTA FULL WIDTH KEYBOARD
usb 1-1.5: Manufacturer: NOVATEK
input: NOVATEK USB NETVISTA FULL WIDTH KEYBOARD as /devices/platform/musb_hdrc/usb1/1-1/1-1.5/1-1.5:1.0/input/input0
generic-usb 0003:0461:4E04.0001: input: USB HID v1.10 Keyboard [NOVATEK USB NETVISTA FULL WIDTH KEYBOARD] on usb-musb_
hdrc-1.5/input0
input: NOVATEK USB NETVISTA FULL WIDTH KEYBOARD as /devices/platform/musb_hdrc/usb1/1-1/1-1.5/1-1.5:1.1/input/input1
generic-usb 0003:0461:4E04.0002: input: USB HID v1.10 Device [NOVATEK USB NETVISTA FULL WIDTH KEYBOARD] on usb-musb_hd
rc-1.5/input1
usb 1-1.7: new low speed USB device using musb_hdrc and address 5
INIT: version 2.86 bootingusb 1-1.7: New USB device found, idVendor=04b3, idProduct=310c
usb 1-1.7: New USB device strings: Mfr=0, Product=2, SerialNumber=0
usb 1-1.7: Product: USB Optical Mouse
input: USB Optical Mouse as /devices/platform/musb_hdrc/usb1/1-1/1-1.7/1-1.7:1.0/input/input2
generic-usb 0003:04B3:310C.0003: input: USB HID v1.11 Mouse [USB Optical Mouse] on usb-musb_hdrc-1.7/input0
Please wait: booting...
Starting udev
udev: starting version 141
Remounting root file system...
Caching udev devnodes
Populating dev cacheuvcvideo: Found UVC 1.00 device Microsoft�® LifeCam HD-5001 (045e:076e)
ads7846 spi1.0: touchscreen, irq 274
input: Microsoft�® LifeCam HD-5001 as /devices/platform/musb_hdrc/usb1/1-1/1-1.2/1-1.2:1.0/input/input3
input: ADS7846 Touchscreen as /devices/platform/omap2_mcspi.1/spi1.0/input/input4
usbcore: registered new interface driver uvcvideo
USB Video Class driver (v0.1.0)
lib80211: common routines for IEEE802.11 drivers
libertas_sdio: Libertas SDIO driver
libertas_sdio: Copyright Pierre Ossman
libertas_sdio mmc1:0001:1: firmware: requesting sd8686_helper.bin
libertas: can't load helper firmware
libertas: failed to load helper firmware
libertas_sdio: probe of mmc1:0001:1 failed with error -2
ALSA: Restoring mixer settings...
Configuring network interfaces... net eth0: SMSC911x/921x identified at 0xd08c8000, IRQ: 336
Unknown hardware: "twl4030" "" "" "" ""
Hardware is initialized using a guess method
udhcpc (v1.13.2) started
/usr/share/alsa/init/default:53: control element not found
/usr/sbin/alsactl: set_control:1256: failed to obtain info for control #23 (No such file or directory)
/usr/sbin/alsactl: set_control:1256: failed to obtain info for control #24 (No such file or directory)
/usr/sbin/alsactl: set_control:1256: failed to obtain info for control #25 (No such file or directory)
/usr/sbin/alsactl: set_control:1256: failed to obtain info for control #26 (No such file or directory)
/usr/sbin/alsactl: set_control:1256: failed to obtain info for control #27 (No such file or directory)
/usr/sbin/alsactl: set_control:1256: failed to obtain info for control #28 (No such file or directory)
/usr/sbin/alsactl: set_control:1256: failed to obtain info for control #33 (No such file or directory)
/usr/sbin/alsactl: set_control:1256: failed to obtain info for control #35 (No such file or directory)
No state is present for card HD5001
Unknown hardware: "USB-Audio" "USB Mixer" "USB045e:076e" "" ""
Sending discover...
Sending select for 10.1.55.122...
Lease of 10.1.55.122 obtained, lease time 691200
adding dns 10.1.55.2
adding dns 209.213.64.2
done.
Setting up IP spoofing protection: rp_filter.
INIT: Entering runlevel: 5
Starting system message bus: dbus.
Starting telnet daemon.
Starting syslogd/klogd: done
Starting thttpdNET: Registered protocol family 10
ADDRCONF(NETDEV_UP): eth0: link is not ready
Starting PVR
ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
pvrsrvkm: disagrees about version of symbol module_layout
insmod: error inserting '/lib/modules/2.6.32/kernel/drivers/gpu/pvr/pvrsrvkm.ko': -1 Invalid module format
WARNING: Error inserting pvrsrvkm (/lib/modules/2.6.32/kernel/drivers/gpu/pvr/pvrsrvkm.ko): Invalid module format
omaplfb: disagrees about version of symbol module_layout
FATAL: Error inserting omaplfb (/lib/modules/2.6.32/kernel/drivers/gpu/pvr/omaplfb.ko): Invalid module format
bufferclass_ti: disagrees about version of symbol module_layout
FATAL: Error inserting bufferclass_ti (/lib/modules/2.6.32/kernel/drivers/gpu/pvr/bufferclass_ti.ko): Invalid module f
ormat
BusyBox v1.13.2 (2010-10-14 15:42:04 CDT) multi-call binary
Usage: mknod [OPTIONS] NAME TYPE MAJOR MINOR
Create a special file (block, character, or pipe)
Options:
-m Create the special file using the specified mode (default a=rw)
TYPEs include:
b: Make a block device
c or u: Make a character device
p: Make a named pipe (MAJOR and MINOR are ignored)
chmod: /dev/pvrsrvkm: No such file or directory
Loading kernel modules for gstreamer-ti... Running /usr/share/ti/gst/<platform>/loadmodule.sh done
