Other Parts Discussed in Thread: DRA829
Customer is using Beta EVM (J721EXSOMG01EVM) and the u-boot is hanging after printing "vdd_mmc1: disabling". They are using the prebuilt binaries. Have tried 6_00_00_00 and 06_00_01_00.
U-Boot SPL 2019.01-ga280dd38e1 (Sep 12 2019 - 09:20:44 +0000) SYSFW ABI: 2.6 (firmware rev 0x0013 '19.7.0-v2019.07 (Terrific Llama') Trying to boot from MMC2 Loading Environment from MMC... *** Warning - No MMC card found, using default environment Remoteproc 2 started successfully ** File not found /lib/firmware/j7-mcu-r5f0_0-fw ** Starting ATF on ARM64 core... NOTICE: BL31: v2.1(release):ti2019.03 NOTICE: BL31: Built : 09:18:16, Sep 12 2019 I/TC: I/TC: OP-TEE version: ti2019.03-dev (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #1 Thu Sep 12 09:18:54 UTC 2019 aarch64 I/TC: Initialized U-Boot SPL 2019.01-ga280dd38e1 (Sep 12 2019 - 09:19:45 +0000) detected J7X-BASE-CPB detected J7X-VSC8514-ETH Trying to boot from MMC2 ti_sci_power_domain_on: get_device(91) failed (-19) U-Boot 2019.01-ga280dd38e1 (Sep 12 2019 - 09:19:45 +0000) Model: Texas Instruments K3 J721E SoC DRAM: 4 GiB Flash: 0 Bytes MMC: ti_sci_power_domain_on: get_device(91) failed (-19) sdhci@4f80000: 0, sdhci@4fb0000: 1 Loading Environment from MMC... *** Warning - bad CRC, using default environment In: serial@2800000 Out: serial@2800000 Err: serial@2800000 detected J7X-BASE-CPB detected J7X-VSC8514-ETH Net: Warning: ethernet@046000000 using MAC address from ROM eth0: ethernet@046000000 Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 ** Unable to read file boot.scr ** 15 bytes read in 1 ms (14.6 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... 13203464 bytes read in 557 ms (22.6 MiB/s) 87265 bytes read in 5 ms (16.6 MiB/s) ## Flattened Device Tree blob at 82000000 Booting using the fdt blob at 0x82000000 Loading Device Tree to 00000000fddc0000, end 00000000fded8fff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x411fd080] [ 0.000000] Linux version 4.19.59-g50ceb3c6e7 (oe-user@oe-host) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #1 SMP PREEMPT Thu Sep 12 09:13:59 UTC 2019 [ 0.000000] Machine model: Texas Instruments K3 J721E SoC [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] bootconsole [ns16550a0] enabled [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a2000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a2100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a2100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a3000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a3100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a3100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a4000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a4100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a4100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a5000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a5100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a5100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a6000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a6100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c66-memory@a6100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c66-dma-memory@a7000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a7100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c66-memory@a7100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node c71-dma-memory@a8000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a8100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node c71-memory@a8100000, compatible id shared-dma-pool [ 0.000000] cma: Reserved 512 MiB at 0x00000000c0000000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.1 [ 0.000000] random: get_random_bytes called from start_kernel+0x94/0x3e4 with crng_init=0 [ 0.000000] percpu: Embedded 2 pages/cpu s52632 r8192 d70248 u131072 [ 0.000000] Detected PIPT I-cache on CPU0 [ 0.000000] CPU features: enabling workaround for EL2 vector hardening [ 0.000000] Speculative Store Bypass Disable mitigation not required [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 62339 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ot [ 0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes) [ 0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes) [ 0.000000] software IO TLB: mapped [mem 0xf9dc0000-0xfddc0000] (64MB) [ 0.000000] Memory: 3377856K/3993600K available (8382K kernel code, 798K rwdata, 3072K rodata, 576K init, 646K bss, 91456K reserved, 524288K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=2. [ 0.000000] Tasks RCU enabled. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: no VLPI support, no direct LPI support [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GIC: using LPI property table @0x00000008c00a0000 [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001900000 [ 0.000000] CPU0: using LPI pending table @0x00000008c00b0000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000001] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008354] Console: colour dummy device 80x25 [ 0.012909] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023577] pid_max: default: 32768 minimum: 301 [ 0.028317] Security Framework initialized [ 0.032520] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes) [ 0.039375] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes) [ 0.070708] ASID allocator initialised with 32768 entries [ 0.084236] rcu: Hierarchical SRCU implementation. [ 0.097179] Platform MSI: gic-its@1820000 domain created [ 0.102702] PCI/MSI: /interconnect@100000/interrupt-controller@1800000/gic-its@1820000 domain created [ 0.120137] smp: Bringing up secondary CPUs ... [ 0.170926] Detected PIPT I-cache on CPU1 [ 0.170943] GICv3: CPU1: found redistributor 1 region 0:0x0000000001920000 [ 0.170970] CPU1: using LPI pending table @0x00000008c0310000 [ 0.170992] CPU1: Booted secondary processor 0x0000000001 [0x411fd080] [ 0.171036] smp: Brought up 1 node, 2 CPUs [ 0.198872] SMP: Total of 2 processors activated. [ 0.203681] CPU features: detected: GIC system register CPU interface [ 0.210263] CPU features: detected: 32-bit EL0 Support [ 0.215743] CPU: All CPU(s) started at EL2 [ 0.219930] alternatives: patching kernel code [ 0.224895] devtmpfs: initialized [ 0.232078] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.242042] futex hash table entries: 512 (order: -1, 32768 bytes) [ 0.248710] pinctrl core: initialized pinctrl subsystem [ 0.254362] NET: Registered protocol family 16 [ 0.259231] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____)) [ 0.266792] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.275933] DMA: preallocated 256 KiB pool for atomic allocations [ 0.288918] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.295769] HugeTLB registered 512 MiB page size, pre-allocated 0 pages [ 0.303132] cryptd: max_cpu_qlen set to 1000 [ 0.311916] vsys_3v3: supplied by evm_12v0 [ 0.316178] vsys_5v0: supplied by evm_12v0 [ 0.320693] SCSI subsystem initialized [ 0.324768] media: Linux media interface: v0.10 [ 0.329412] videodev: Linux video capture interface: v2.00 [ 0.335027] pps_core: LinuxPPS API ver. 1 registered [ 0.340100] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.349439] PTP clock support registered [ 0.353452] EDAC MC: Ver: 3.0.0 [ 0.357230] Advanced Linux Sound Architecture Driver Initialized. [ 0.363770] clocksource: Switched to clocksource arch_sys_counter [ 0.370056] VFS: Disk quotas dquot_6.6.0 [ 0.374102] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes) [ 0.383449] NET: Registered protocol family 2 [ 0.388145] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes) [ 0.396195] TCP established hash table entries: 32768 (order: 2, 262144 bytes) [ 0.403679] TCP bind hash table entries: 32768 (order: 3, 524288 bytes) [ 0.410653] TCP: Hash tables configured (established 32768 bind 32768) [ 0.417377] UDP hash table entries: 2048 (order: 0, 65536 bytes) [ 0.423557] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes) [ 0.430226] NET: Registered protocol family 1 [ 0.434881] RPC: Registered named UNIX socket transport module. [ 0.440934] RPC: Registered udp transport module. [ 0.445738] RPC: Registered tcp transport module. [ 0.450540] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.457360] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 0.466895] Initialise system trusted keyrings [ 0.471499] workingset: timestamp_bits=46 max_order=16 bucket_order=0 [ 0.479501] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.485669] NFS: Registering the id_resolver key type [ 0.490837] Key type id_resolver registered [ 0.495110] Key type id_legacy registered [ 0.499206] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.506105] 9p: Installing v9fs 9p2000 file system support [ 0.513139] Key type asymmetric registered [ 0.517327] Asymmetric key parser 'x509' registered [ 0.522327] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 0.529887] io scheduler noop registered [ 0.533893] io scheduler deadline registered [ 0.538292] io scheduler cfq registered (default) [ 0.543099] io scheduler mq-deadline registered [ 0.547725] io scheduler kyber registered [ 0.552568] pinctrl-single 4301c000.pinmux: 94 pins, size 376 [ 0.558626] pinctrl-single 11c000.pinmux: 173 pins, size 692 [ 0.564740] pinctrl-single a40000.timesync_router: 512 pins, size 2048 [ 0.574624] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.582348] arm-smmu-v3 36600000.smmu: ias 48-bit, oas 48-bit (features 0x00001faf) [ 0.591164] arm-smmu-v3 36600000.smmu: msi_domain absent - falling back to wired irqs [ 0.602694] brd: module loaded [ 0.608251] loop: module loaded [ 0.612462] libphy: Fixed MDIO Bus: probed [ 0.616797] tun: Universal TUN/TAP device driver, 1.6 [ 0.622168] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k [ 0.630174] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.636236] sky2: driver version 1.30 [ 0.640490] VFIO - User Level meta-driver version: 0.3 [ 0.646033] i2c /dev entries driver [ 0.650002] sdhci: Secure Digital Host Controller Interface driver [ 0.656317] sdhci: Copyright(c) Pierre Ossman [ 0.660939] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.667131] ledtrig-cpu: registered to indicate activity on CPUs [ 0.673896] optee: probing for conduit method from DT. [ 0.679157] optee: revision 3.6 (e5a8779a) [ 0.679251] optee: initialized driver [ 0.687847] NET: Registered protocol family 17 [ 0.692442] 9pnet: Installing 9P2000 support [ 0.696821] Key type dns_resolver registered [ 0.701378] registered taskstats version 1 [ 0.705564] Loading compiled-in X.509 certificates [ 0.717797] ti-sci 44083000.dmsc: ABI: 2.6 (firmware rev 0x0013 '19.7.0-v2019.07 (Terrific Llama') [ 1.613096] random: fast init done [ 3.114603] omap_i2c 40b00000.i2c: bus 0 rev0.12 at 100 kHz [ 3.127209] omap_i2c 40b10000.i2c: bus 1 rev0.12 at 100 kHz [ 3.142282] palmas 2-0058: IRQ missing: skipping irq request [ 3.171906] palmas: probe of 2-0058 failed with error -121 [ 3.177547] omap_i2c 42120000.i2c: bus 2 rev0.12 at 400 kHz [ 3.191593] pca953x 3-0020: 3-0020 supply vcc not found, using dummy regulator [ 3.198995] pca953x 3-0020: Linked as a consumer to regulator.0 [ 3.228301] pca953x 3-0022: 3-0022 supply vcc not found, using dummy regulator [ 3.235698] pca953x 3-0022: Linked as a consumer to regulator.0 [ 3.242568] GPIO line 481 (MCASP/TRACE_MUX_S0) hogged as output/low [ 3.249291] GPIO line 482 (MCASP/TRACE_MUX_S1) hogged as output/high [ 3.255846] omap_i2c 2000000.i2c: bus 3 rev0.12 at 400 kHz [ 3.269822] omap_i2c 2010000.i2c: bus 4 rev0.12 at 400 kHz [ 3.283733] omap_i2c 2020000.i2c: bus 5 rev0.12 at 100 kHz [ 3.297679] pca953x 6-0020: 6-0020 supply vcc not found, using dummy regulator [ 3.305079] pca953x 6-0020: Linked as a consumer to regulator.0 [ 3.332433] GPIO line 464 (CODEC_RSTz) hogged as output/high [ 3.338320] omap_i2c 2030000.i2c: bus 6 rev0.12 at 400 kHz [ 3.352206] omap_i2c 2040000.i2c: bus 7 rev0.12 at 100 kHz [ 3.366091] omap_i2c 2050000.i2c: bus 8 rev0.12 at 100 kHz [ 3.380020] pca953x 9-0020: 9-0020 supply vcc not found, using dummy regulator [ 3.387419] pca953x 9-0020: Linked as a consumer to regulator.0 [ 3.416192] omap_i2c 2060000.i2c: bus 9 rev0.12 at 400 kHz [ 3.622932] wiz interconnect@100000:wiz@5030000: Failed to request typec-dir gpio: -517 [ 3.660064] cdns-dp-phy 5050000.serdes: 4 lanes, max bit rate 5.400 Gbps [ 3.674140] cdns-pcie-host d000000.pcie: missing "mem" [ 3.679730] cdns-pcie-host d000000.pcie: Linked as a consumer to phy-5000000.serdes.0 [ 4.689103] cdns-pcie-host d000000.pcie: Phy link never came up [ 4.695156] cdns-pcie-host d000000.pcie: host bridge /interconnect@100000/pcie@2900000/pcie@d000000 ranges: [ 4.705124] cdns-pcie-host d000000.pcie: IO 0x10001000..0x10010fff -> 0x10001000 [ 4.712956] cdns-pcie-host d000000.pcie: MEM 0x10011000..0x17ffffff -> 0x10011000 [ 4.720837] cdns-pcie-host d000000.pcie: PCI host bridge to bus 0000:00 [ 4.727598] pci_bus 0000:00: root bus resource [bus 00-0f] [ 4.733204] pci_bus 0000:00: root bus resource [io 0x0000-0xffff] (bus address [0x10001000-0x10010fff]) [ 4.742894] pci_bus 0000:00: root bus resource [mem 0x10011000-0x17ffffff] [ 4.749943] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits [ 4.759814] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x4 may corrupt adjacent RW1C bits [ 4.769705] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x92 may corrupt adjacent RW1C bits [ 4.779667] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0xb2 may corrupt adjacent RW1C bits [ 4.789653] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x84 may corrupt adjacent RW1C bits [ 4.801137] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 4.809321] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits [ 4.819281] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits [ 4.829242] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x3e may corrupt adjacent RW1C bits [ 4.839201] pci_bus 0000:00: 2-byte config write to 0000:00:00.0 offset 0x6 may corrupt adjacent RW1C bits [ 4.850466] pci_bus 0000:00: 1-byte config write to 0000:00:00.0 offset 0x1a may corrupt adjacent RW1C bits [ 4.860434] pci 0000:00:00.0: PCI bridge to [bus 01] [ 4.870018] cdns-pcie-host d800000.pcie: missing "mem" [ 4.875604] cdns-pcie-host d800000.pcie: Linked as a consumer to phy-5010000.serdes.1 [ 5.884982] cdns-pcie-host d800000.pcie: Phy link never came up [ 5.891038] cdns-pcie-host d800000.pcie: host bridge /interconnect@100000/pcie@2910000/pcie@d800000 ranges: [ 5.901007] cdns-pcie-host d800000.pcie: IO 0x18001000..0x18010fff -> 0x18001000 [ 5.908838] cdns-pcie-host d800000.pcie: MEM 0x18011000..0x1fffffff -> 0x18011000 [ 5.916736] cdns-pcie-host d800000.pcie: PCI host bridge to bus 0001:00 [ 5.923500] pci_bus 0001:00: root bus resource [bus 00-0f] [ 5.929105] pci_bus 0001:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x18001000-0x18010fff]) [ 5.938973] pci_bus 0001:00: root bus resource [mem 0x18011000-0x1fffffff] [ 5.947538] pci 0001:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 5.957137] pci 0001:00:00.0: PCI bridge to [bus 01] [ 5.966726] cdns-pcie-host e000000.pcie: missing "mem" [ 5.983370] cdns-pcie-host e000000.pcie: Linked as a consumer to phy-5020000.serdes.2 [ 6.992746] cdns-pcie-host e000000.pcie: Phy link never came up [ 6.998798] cdns-pcie-host e000000.pcie: host bridge /interconnect@100000/pcie@2920000/pcie@e000000 ranges: [ 7.008766] cdns-pcie-host e000000.pcie: IO 0x4400001000..0x4400010fff -> 0x00001000 [ 7.016951] cdns-pcie-host e000000.pcie: MEM 0x4400011000..0x4407ffffff -> 0x00011000 [ 7.025192] cdns-pcie-host e000000.pcie: PCI host bridge to bus 0002:00 [ 7.031953] pci_bus 0002:00: root bus resource [bus 00-0f] [ 7.037558] pci_bus 0002:00: root bus resource [io 0x20000-0x2ffff] (bus address [0x1000-0x10fff]) [ 7.046807] pci_bus 0002:00: root bus resource [mem 0x4400011000-0x4407ffffff] (bus address [0x00011000-0x07ffffff]) [ 7.059071] pci 0002:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring [ 7.068658] pci 0002:00:00.0: PCI bridge to [bus 01] [ 7.080249] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,20] sci-dev-id:235 [ 7.090128] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: disabled [ 7.096889] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 7.110685] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:1024, gp-rings[440,150] sci-dev-id:211 [ 7.120824] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: disabled [ 7.127585] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66346100, num_proxies:64 [ 7.139436] omap8250 40a00000.serial: PM domain pd:149 will not be powered off [ 7.146946] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 7, base_baud = 6000000) is a 8250 [ 7.160292] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 19, base_baud = 3000000) is a 8250 [ 7.169028] console [ttyS2] enabled [ 7.169028] console [ttyS2] enabled [ 7.176061] bootconsole [ns16550a0] disabled [ 7.176061] bootconsole [ns16550a0] disabled [ 7.193945] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 20, base_baud = 3000000) is a 8250 [ 7.211722] 2820000.serial: ttyS4 at MMIO 0x2820000 (irq = 21, base_baud = 3000000) is a 8250 [ 7.229496] 2840000.serial: ttyS6 at MMIO 0x2840000 (irq = 22, base_baud = 3000000) is a 8250 [ 7.289214] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled [ 7.299726] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vcc-supply regulator, assuming enabled [ 7.309883] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq-supply regulator, assuming enabled [ 7.320124] cdns-ufshcd 4e84000.ufs: ufshcd_populate_vreg: Unable to find vccq2-supply regulator, assuming enabled [ 7.356963] scsi host0: ufshcd [ 7.389425] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[1, 1], lane[1, 1], pwr[SLOWAUTO_MODE, SLOWAUTO_MODE], rate = 0 [ 7.422023] cdns-ufshcd 4e84000.ufs: ufshcd_print_pwr_info:[RX, TX]: gear=[3, 3], lane[2, 2], pwr[FAST MODE, FAST MODE], rate = 2 [ 7.433692] cdns-ufshcd 4e84000.ufs: ufshcd_find_max_sup_active_icc_level: Regulator capability was not set, actvIccLevel=0 [ 7.435392] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes) [ 7.444929] scsi 0:0:0:49488: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6 [ 7.450972] 7 cmdlinepart partitions found on MTD device 47040000.spi.0 [ 7.459704] scsi 0:0:0:49476: Well-known LUN TOSHIBA THGAF8G8T23BAILB 0300 PQ: 0 ANSI: 6 [ 7.465981] Creating 7 MTD partitions on "47040000.spi.0": [ 7.465984] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 7.466224] 0x000000080000-0x000000280000 : "ospi.tispl" [ 7.483884] cdns-ufshcd 4e84000.ufs: ufshcd_scsi_add_wlus: BOOT WLUN not found [ 7.485548] 0x000000280000-0x000000680000 : "ospi.u-boot" [ 7.503420] 0x000000680000-0x0000006a0000 : "ospi.env" [ 7.508750] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup" [ 7.514668] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw" [ 7.520148] 0x000000800000-0x000004000000 : "ospi.rootfs" [ 7.635852] cadence-qspi 47040000.spi: Cadence QSPI NOR probe failed -517 [ 7.675884] cadence-qspi 47050000.spi: n25q512a (65536 Kbytes) [ 7.699851] cadence-qspi 47050000.spi: Cadence QSPI NOR probe failed -517 [ 7.736600] am65-cpsw-nuss 46000000.ethernet: rx-flow-id-base is not set -22 [ 7.743650] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 [ 7.755065] UDMA has not been proped [ 7.758634] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517 [ 7.800381] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a010a, freq:200000000, add_val:4 pps:0 [ 7.814957] mmc0: Unknown controller version (4). You may experience problems. [ 7.822203] mmc0: CQHCI version 5.10 [ 7.856488] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit [ 7.899116] mmc0: Command Queue Engine enabled [ 7.903558] mmc0: new HS400 MMC card at address 0001 [ 7.908816] mmcblk0: mmc0:0001 S0J56X 14.8 GiB [ 7.913566] mmcblk0boot0: mmc0:0001 S0J56X partition 1 31.5 MiB [ 7.919700] mmcblk0boot1: mmc0:0001 S0J56X partition 2 31.5 MiB [ 7.925731] mmcblk0rpmb: mmc0:0001 S0J56X partition 3 4.00 MiB, chardev (242:0) [ 8.218781] vdd_mmc1: supplied by vsys_3v3 [ 8.231200] pca953x 4-0020: 4-0020 supply vcc not found, using dummy regulator [ 8.238427] pca953x 4-0020: Linked as a consumer to regulator.0 [ 8.268434] GPIO line 448 (DP0_PWR_SW_EN) hogged as output/high [ 8.289532] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100 [ 8.310949] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100 [ 8.332364] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100 [ 8.353776] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100 [ 8.375174] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100 [ 8.429849] ti-udma 285c0000.udmap: Channels: 24 (tchan: 48, echan: 0, rchan: 48, rflow: 96) [ 8.482899] ti-udma 31150000.udmap: Channels: 84 (tchan: 140, echan: 160, rchan: 140, rflow: 300) [ 8.533587] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes) [ 8.539761] 7 cmdlinepart partitions found on MTD device 47040000.spi.0 [ 8.546359] Creating 7 MTD partitions on "47040000.spi.0": [ 8.551831] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 8.557559] 0x000000080000-0x000000280000 : "ospi.tispl" [ 8.563048] 0x000000280000-0x000000680000 : "ospi.u-boot" [ 8.568637] 0x000000680000-0x0000006a0000 : "ospi.env" [ 8.573948] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup" [ 8.579869] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw" [ 8.585348] 0x000000800000-0x000004000000 : "ospi.rootfs" [ 8.791544] cadence-qspi 47050000.spi: n25q512a (65536 Kbytes) [ 8.988307] am65-cpsw-nuss 46000000.ethernet: rx-flow-id-base is not set -22 [ 8.995364] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA00101, cpsw version 0x6BA80100 Ports: 2 [ 10.039948] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [ 10.923549] pps pps0: new PPS source ptp1 [ 10.927636] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a010a, freq:500000000, add_val:1 pps:1 [ 10.936579] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 0.4 [ 10.943785] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 10.987778] am65-cpsw-nuss 46000000.ethernet: davinci mdio revision 9.7, bus freq 1000000 [ 10.995939] libphy: 46000000.ethernet: probed [ 11.011426] sdhci-am654 4fb0000.sdhci: Linked as a consumer to regulator.4 [ 11.031584] sdhci-am654 4fb0000.sdhci: Dropping the link to regulator.4 [ 11.847420] sdhci-am654 4fb0000.sdhci: Linked as a consumer to regulator.4 [ 11.864325] sdhci-am654 4fb0000.sdhci: Dropping the link to regulator.4 [ 11.887740] sdhci-am654 4fb0000.sdhci: Linked as a consumer to regulator.4 [ 11.904651] sdhci-am654 4fb0000.sdhci: Dropping the link to regulator.4 [ 11.911557] hctosys: unable to open rtc device (rtc0) [ 13.062414] vdd_mmc1: disabling [ 13.073771] ALSA device list: [ 13.076733] No soundcards found. [ 13.080331] Waiting for root device PARTUUID=5aeede62-02...
