[DM365] Problems with run system_server
Hello!
I have downloaded source from Appro server and successfully build it and now I try run it on my board with DM365 and MT9P031. I try run system from NFS and flash.
When I run system from NFS I get this:
# ./system_server
queue id:0
FileMngThread created
Creat queue id:32769
queue id:32769
AlramThread created
Share memory init success
IPNC_DM365_2.0.0-gb36a56e4-dirty (kirill@kirill) (gcc version 4
queue id:65538
Creat queue id:65538
queue id:65538
queue id:32769
CPU is DM365
DEMOCFG Value   : 0
Videocodecmode  : 0
Videocodecres   : 0
./av_server.out FD OSD DM365 AEWB TI2A AUDIO 8000 720P H264 4000000 VBR AUTO MENUOFF &
Check_device_version : DEVICE VER = 1 !!
ApproDrvInit: 7
Creat queue id:98307
queue id:98307
AVSERVER UI: Initializing.
DRV_SyncRst: module = 47, domain = 0, state = 0
DRV_SyncRst: module = 47, domain = 0, state = 3
 CLK Hz,
 ARM   Hz =  297000000
DDR   Hz =  243000000
 VPSS  Hz =  243000000
 IMCOP Hz =  243000000
 [OSA_FILE ] Reading file [/mnt/nand/IMG_Paramset.bin] ... ERROR
IMAGE TUNE: Paramset File is not available..... Setting DEFAULT parameter
CONFIGURING AVSERVER FOR DM365 .....
SENSOR FPS VALUE = 30
I2C-address 0x90
DavinciDisplay DavinciDisplay.1: Before finishing with S_FMT:
layer.pix_fmt.bytesperline = 640,
 layer.pix_fmt.width = 640,
 layer.pix_fmt.height = 480,
 layer.pix_fmt.sizeimage =460800
queue id:98307
DavinciDisplay DavinciDisplay.1: pixfmt->width = 640,
 layer->layer_info.config.line_length= 640
 FR : 0 users registered from exsiting face album
IPNC AUTO_IRIS = 1 #####################
GBCE in EVAL MODE
queue id:65538
TI 2A TRIAL VERSION!!!
TI 2A Expiration date: 2010, Dec 31
Simple mixer control 'PGA',0
  Capabilities: cvolume
  Capture channels: Mono
  Limits: Capture 0 - 3
  Mono: Capture 2 [67%]
Simple mixer control 'Mono DAC',0
  Capabilities: pvolume pvolume-joined
  Playback channels: Mono
  Limits: Playback 0 - 63
  Mono: Playback 47 [75%]
killall: wis-streamer: no process killed
SystemInit success
Schedule manager init success
umount: /mnt/mmc: not mounted
mount: special device /dev/mmcblk0 does not exist
mount: special device /dev/mmcblk0p1 does not exist
net_config.c: start net_get_hwaddr
system_control.c: start SetDhcpEnable, val 0
nenfs: RPC call returned error 101
killall: dhcpcd: no process killed
rm: cannot remove `/var/run/dhcpcd-eth0.pid': No such file or directory
    net_config.c: startnfs: RPC call returned error 101
 net_set_ifaddr
file_msg_drv.c: start fSetDhcpEnable, val 0
net_config.c: start net_set_ifaddr
net_config.c: start net_set_netmask
net_config.c: start net_set_gateway
net_config.c: start net_search_gateway
net_search_gateway:eth0, 1A8C0, 0, 1
net_config.c: start net_add_gateway
net_config.c: start net_set_dns
nfs: server 192.168.10.3 not responding, still trying
Link on network card is active.
But when I run system from flash I get this:
     # ./system_server
queue id:0
queue id:65538
AlramThread created
queue id:98307
queue id:65538
CPU is DM365
DEMOCFG Value   : 0
Videocodecmode  : 0
Videocodecres   : 0
queue id:98307
CPU CurrentStatus is = 0
 CLK Hz,
 ARM   Hz =  297000000
 DDR   Hz =  243000000
 VPSS  Hz =  243000000
ApproDrvInit: 7
queue id:32769
I2C-address 0x90
queue id:32769
GBCE in EVAL MODE
queue id:98307
SystemInit success
1:01 not found
rm: cannot remov1:02 not found
net_config.c:net_search_gateway:eth0, 1A8C0, 0, 1
dns=192.168.1.1
net_config.c:net_search_gateway:eth0, 0, FE01A8C0, 3
dns=192.168.1.1
ERROR: Module g_file_storage does not exist in /proc/modules
g_file_storage gadget: File-backed Storage Gadget, version: 28 November 2005
g_file_storage gadget: Number of LUNs=1
g_file_storage gadget-lun0: ro=0, file: /dev/sbulla
Unable to handle kernel NULL pointer dereference at virtual address 00000004
pgd = c09f4000
[00000004] *pgd=811d9031, *pte=00000000, *ppte=00000000
Internal error: Oops: 17 [#1]
Modules linked in: g_file_storage sbull iscsi_tcp libiscsi scsi_transport_iscsi usbmon musb_hdrc usbcore davinci_mmc mmc_block mmc_core ppp_deflate ppp_async ppp_synctty ppp_generic netconsole slhc tun loop nfsdl
CPU: 0
PC is at phy_read+0x1c/0x60
LR is at emac_control+0x118/0x4d4
pc : [<c0201010>]    lr : [<c020321c>]    Not tainted
sp : c0c3dcc8  ip : c0c3dce8  fp : c0c3dce4
r10: c0c3deb0  r9 : c0c3c000  r8 : 00000000
r7 : 00000001  r6 : c0c3ddac  r5 : 00000000  r4 : c0c3c000
r3 : c12b7284  r2 : c0c3ddac  r1 : 00000001  r0 : 00000000
Flags: Nzcv  IRQs off  FIQs on  Mode SVC_32  Segment user
Control: 5317F
Table: 809F4000  DAC: 00000015
Process system_server (pid: 729, stack limit = 0xc0c3c258)
Stack: (0xc0c3dcc8 to 0xc0c3e000)
dcc0:                   c12b7280 c12b7280 c0c3ddac c0c3ddac c0c3dda4 c0c3dce8
dce0: c020321c c0201004 c0c3dd14 c0c3dcf8 c0c3dd14 c0c3dd00 c00b0750 c00b06bc
dd00: ffffffea ffffffea c0c3dd3c c0c3dd18 c00d22e4 c00b06f8 00000000 c05cda58
dd20: 00000000 c197abb8 c197ac2c c0c3df08 c0c3dd74 c0c3dd40 c00a62f8 c00a61f4
dd40: c0c3dd74 c0c3dd50 c00b13fc c01d134c c197aa80 c0c3df08 c197abb8 c0c3c000
dd60: 00000000 00000003 c0c3ddc4 c0c3dd78 c00a8ad4 c00b13d4 00000101 c02e7ef8
dd80: 60000013 c12b7280 c0c3ddac c0c3c000 00000000 c0c3deb0 c0c3de6c c0c3dda8
dda0: c0207574 c0203114 c0c3df08 00000001 00000001 00000001 c0c3de3c c0c3ddc8
ddc0: c00a8d8c c00b63dc c2c03b18 c04602a0 c0460220 c05cdc58 c0c3df4c 00000000
dde0: 00000020 00000000 c02f30f8 00000000 c0c3de14 c030de00 c0053b68 c01bf918
de00: c009410c 00000204 00000000 00000000 c0053ba8 00000000 00000020 00000000
de20: c02f30f8 00000000 c0078c5c 32398320 00003135 c0c3df08 00000001 00000000
de40: c0c3de6c c0c3de50 00000016 42223dd4 c197abb8 000089f0 c12b7000 c0c3deb0
de60: c0c3de8c c0c3de70 c0270c44 c0207444 c0c3de8c c0c3deb0 000089f0 42223db4
de80: c0c3df04 c0c3de90 c02720c0 c02708b4 c0c3deec c0c3dea0 c01d5d24 c01d4fcc
dea0: 0000000a ffffffff ffffffff 00000000 30687465 00000000 00000000 00000000
dec0: 42223de0 00000000 00000000 00000000 00000119 c0c3df3c c05cda34 c060f9a0
dee0: 000089f0 42223db4 c060f9a0 00000004 c0c3c000 00000000 c0c3df24 c0c3df08
df00: c0264228 c0271b80 c0c3df64 c060f9a0 42223db4 000089f0 c0c3df44 c0c3df28
df20: c00ab770 c0264040 00000002 c060f9a0 00000004 42223db4 c0c3df74 c0c3df48
df40: c00aba94 c00ab748 c0d8b4a0 00000004 0003a5c8 00000000 42223db4 000089f0
df60: 00000004 c0c3c000 c0c3dfa4 c0c3df78 c00abb70 c00ab7e0 c0c3dfa4 00000001
df80: c0265364 00000000 00000001 42223db4 00000036 c0034f88 00000000 c0c3dfa8
dfa0: c0034f58 c00abacc 00000000 00000001 00000004 000089f0 42223db4 42223de0
dfc0: 00000000 00000001 42223db4 00000036 00000000 00000000 00000000 ffffffff
dfe0: 00000004 42223db0 0001a30c 4016b27c 60000010 00000004 72c57de5 cbb7c2b3
Backtrace:
[<c0200ff4>] (phy_read+0x0/0x60) from [<c020321c>] (emac_control+0x118/0x4d4)
 r7 = C0C3DDAC  r6 = C0C3DDAC  r5 = C12B7280  r4 = C12B7280
[<c0203104>] (emac_control+0x0/0x4d4) from [<c0207574>] (emac_ioctl+0x140/0x4a0)
[<c0207434>] (emac_ioctl+0x0/0x4a0) from [<c0270c44>] (dev_ifsioc+0x3a0/0x3e8)
 r6 = C0C3DEB0  r5 = C12B7000  r4 = 000089F0
[<c02708a4>] (dev_ifsioc+0x0/0x3e8) from [<c02720c0>] (dev_ioctl+0x550/0x5ec)
 r6 = 42223DB4  r5 = 000089F0  r4 = C0C3DEB0
[<c0271b70>] (dev_ioctl+0x0/0x5ec) from [<c0264228>] (sock_ioctl+0x1f8/0x230)
[<c0264030>] (sock_ioctl+0x0/0x230) from [<c00ab770>] (do_ioctl+0x38/0x98)
 r6 = 000089F0  r5 = 42223DB4  r4 = C060F9A0
[<c00ab738>] (do_ioctl+0x0/0x98) from [<c00aba94>] (vfs_ioctl+0x2c4/0x2ec)
 r6 = 42223DB4  r5 = 00000004  r4 = C060F9A0
[<c00ab7d0>] (vfs_ioctl+0x0/0x2ec) from [<c00abb70>] (sys_ioctl+0xb4/0xe8)
 r9 = C0C3C000  r8 = 00000004  r6 = 000089F0  r5 = 42223DB4
 r4 = 00000000
[<c00ababc>] (sys_ioctl+0x0/0xe8) from [<c0034f58>] (__sys_trace_return+0x0/0x28)
 r8 = C0034F88  r7 = 00000036  r6 = 42223DB4  r5 = 00000001
 r4 = 00000000
Code: e3cd4d7f e3c4403f e1a05000 e1a07001 (e5906004)
How can I solve this problem?
Thank you and excuse me for my bad english.
  • I have inserted printk() in drivers/net/davinci_emac.c and found what problem in emac_ioctl function.
    I get this output:
    Debug SYS_MSG_DO_BOOT_PROC
    BootProc2
    [01/Jan/2000:00:00:33 +0000] boa: server version Boa/0.94.13
    [01/Jan/2000:00:00:33 +0000] boa: server built Dec 17 2010 at 09:44:42.
    [01/Jan/2000:00:00:33 +0000] boa: starting server pid=736, port 80
    queue id:0
    UDPString=uuid:Upnp-TVEmulator-1_0-00_0075546551</UDN>
    emac_ioctl: cmd SIOCDEVPRIVATE, ioctl 22
    Upnp port is 0
    UPnP Initialized OK ip=192.168.10.254, port=49152
    desc_doc_url
    start ioctl EMAC_PRIV_MII_READ
    = http://192.168copy_from_user OK
    .10.254/tvdevicelocal_irq_save OK
    pgd = c27d4000
    [00000004] *pgd=82065031, *pte=00000000, *ppte=00000000
    Function emac_control() in ioctl EMAC_PRIV_MII_READ is a root this problem, but why?
  • Hmm, this is a very strage, but I have problem in function phy_read, file drivers/net/phy/phy.c
    I have inserted in it debug output and get this:
    Normal output when board loaded:
    Starting phy_read, reg 0x1
    phy_read: reg 0x1, val 0x786d
    Starting phy_read, reg 0x5
    phy_read: reg 0x5, val 0x45e1
    Starting phy_read, reg 0x4
    phy_read: reg 0x4, val 0x1e1
    And another output:
     start ioctl EMAlocal_irq_save OK
    link_speed 100000000, link_mode 3
    emac_control EMAC_IOCTL_READ_PHY_REG, reg 0x1
    I have Realtek RTL8201BL phy-chip on my board.
    Thanks.
  • OK, I solve this problem.
  • Could you please state clear how you solved the problem? This might help others.
    Thanks.
  • Hi Kirill,
    I think it's time this post was made, but we have the same problem with the RTL8201 and appro dm368 IPNC. Is this HW or SW problem?
    Can you tell us the solution that you found?
    Thanks you in advance.
    Sakho
