my question:
I work on DM6467 with dvsdk_1_40_00_31.
I call engine_open() but failed. The error code is 5.
Sometimes I can open the codec engine , but sometimes failed.
I use CE_DEBUG=3 to run the app,the error info is :
CE - rserverOpen('decodeCombo.x64P'):
OC - Comm_locate> Error: could not locate DSP server's MSGQ 'rmsq' in 20 retries.
When I changed the value RMAN.tableSize from 10 to 1000 in the config file in servers,the codec engine can be open again.
But with RMAN.tableSize = 1000 ,after we changed the codec , sometimes the x64P can not open again.
my environment:
dvsdk_1_40_00_31
bios_5_32_01
codec_engine_2_10_01
dsplink-davinci-v1.50-prebuilt
cg6x_6_0_16
cmem_2_10
dm6467_dvsdk_combos_1_15
xdc_3_00_06
framework_components_2_10_01
dmai_1_10_00_06
ceutils_1_04
biosutils_1_01_00
xdais_6_10_01
edma3_lld_1_04_00
PSP_01_30_00_082
linux-2.6.10_mvl401_LSP_01_30_00_082
I Enabled SET_FAILURE_REASON prints, After running ,I get failed info and successful info :
engine_open failed info:
root@(none):~/ep_slave# CE_DEBUG=3 ./ep2010.sh
Good-bye, SPI module was removed!
SPI initialized
SPI initialized
Good-bye, DMA module was removed!
DMA initialized
insmod: cannot insert `cmemk.ko': File exists (-1): File exists
dsplinkk: no version for "struct_module" found: kernel tainted.
dsplinkk: module license 'DSP/BIOS(TM) LINK' taints kernel.
DSPLINK Module (1.50) created on Date: Dec 18 2010 Time: 10:36:07
mv: unable to rename `jpeg_slaver2': No such file or directory
mv: unable to rename `decodeCombo2.x64P': No such file or directory
Decode demo started. v0.230 -upgrade
@0,584,431us: [+4 T:0x00004000 S:0xbefffbd4] OG - Global_init> This program was
built with the following packages:
@0,584,819us: [+4 T:0x00004000 S:0xbefffbd4] OG - package gnu.targets.rts470
MV (/root/dvsdk_1_40_00_31/xdc_3_00_06/packages/gnu/targets/rts470MV/) [1,0,0,0,
1203621000516]
@0,585,132us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.codecs.jpeg
dec (/root/dvsdk_1_40_00_31/dm6467_dvsdk_combos_1_15/packages/ti/sdo/codecs/jpeg
dec/) [1,0,0,1270199533000]
@0,585,352us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.codecs.jpeg
enc (/root/dvsdk_1_40_00_31/dm6467_dvsdk_combos_1_15/packages/ti/sdo/codecs/jpeg
enc/) [1,0,0,1270199534000]
@0,585,562us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.codecs.mpeg
2dec (/root/dvsdk_1_40_00_31/dm6467_dvsdk_combos_1_15/packages/ti/sdo/codecs/mpe
g2dec/) [1,0,0,1270199535000]
@0,585,767us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.xdais.dm (/root
/dvsdk_1_40_00_31/xdais_6_10_01/packages/ti/xdais/dm/) [1,0,4,1210262746529]
@0,585,951us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.xdais (/root/dv
sdk_1_40_00_31/xdais_6_10_01/packages/ti/xdais/) [1,2,1,1210262742149]
@0,586,133us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.utils.trace
(/root/dvsdk_1_40_00_31/framework_components_2_10_01/packages/ti/sdo/utils/trac
e/) [1,0,0,1210822330791]
@0,586,333us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.utils.xd
m (/root/dvsdk_1_40_00_31/codec_engine_2_10_01/packages/ti/sdo/ce/utils/xdm/) [1
,0,1,1210912978675]
@0,586,528us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.fc.dman3 (/
root/dvsdk_1_40_00_31/framework_components_2_10_01/packages/ti/sdo/fc/dman3/) [1
,0,3,1210822157942]
@0,586,725us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.fc.acpy3 (/
root/dvsdk_1_40_00_31/framework_components_2_10_01/packages/ti/sdo/fc/acpy3/) [1
,0,2,1210822135592]
@0,586,921us: [+4 T:0x00004000 S:0xbefffbd4] OG - package dsplink.gpp (/root
/dvsdk_1_40_00_31/dsplink-davinci-v1.50-prebuilt/packages/dsplink/gpp/) [3,0,0]
@0,587,105us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.linuxutils.
cmem (/root/dvsdk_1_40_00_31/cmem_2_10/packages/ti/sdo/linuxutils/cmem/) [2,0,1,
1204929560755]
@0,587,296us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.catalog.c470 (/
root/dvsdk_1_40_00_31/xdc_3_00_06/packages/ti/catalog/c470/) [1,0,1,0,1203561761
475]
@0,587,482us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.catalog.c6000 (
/root/dvsdk_1_40_00_31/xdc_3_00_06/packages/ti/catalog/c6000/) [1,0,0,0,12035617
81695]
@0,587,671us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.platforms.evmDM
6467 (/root/dvsdk_1_40_00_31/bios_5_32_01/packages/ti/platforms/evmDM6467/) [1,0
,0,0,1192229633217]
@0,587,888us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.osal (/r
oot/dvsdk_1_40_00_31/codec_engine_2_10_01/packages/ti/sdo/ce/osal/) [2,0,2,12109
12758604]
@0,588,084us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.ipc (/ro
ot/dvsdk_1_40_00_31/codec_engine_2_10_01/packages/ti/sdo/ce/ipc/) [2,0,1,1210912
707081]
@0,588,280us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.osal.lin
ux (/root/dvsdk_1_40_00_31/codec_engine_2_10_01/packages/ti/sdo/ce/osal/linux/)
[2,0,1,1210912772730]
@0,588,482us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.ipc.dspl
ink (/root/dvsdk_1_40_00_31/codec_engine_2_10_01/packages/ti/sdo/ce/ipc/dsplink/
) [2,0,1,1210912721394]
@0,588,680us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.alg (/ro
ot/dvsdk_1_40_00_31/codec_engine_2_10_01/packages/ti/sdo/ce/alg/) [1,0,1,1210912
389491]
@0,588,871us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce (/root/d
vsdk_1_40_00_31/codec_engine_2_10_01/packages/ti/sdo/ce/) [1,0,6,1210912375058]
@0,589,057us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.image1 (
/root/dvsdk_1_40_00_31/codec_engine_2_10_01/packages/ti/sdo/ce/image1/) [1,0,1,1
210912701200]
@0,589,251us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.codecs.jpeg
dec.ce (/root/dvsdk_1_40_00_31/dm6467_dvsdk_combos_1_15/packages/ti/sdo/codecs/j
pegdec/ce/) [1,0,0,1270199534000]
@0,589,456us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.codecs.jpeg
enc.ce (/root/dvsdk_1_40_00_31/dm6467_dvsdk_combos_1_15/packages/ti/sdo/codecs/j
pegenc/ce/) [1,0,0,1270199534000]
@0,923,486us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.video2 (
/root/dvsdk_1_40_00_31/codec_engine_2_10_01/packages/ti/sdo/ce/video2/) [1,0,2,1
210913003946]
@0,923,703us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.codecs.mpeg
2dec.ce (/root/dvsdk_1_40_00_31/dm6467_dvsdk_combos_1_15/packages/ti/sdo/codecs/
mpeg2dec/ce/) [1,0,0,1270199535000]
@0,923,918us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.speech (
/root/dvsdk_1_40_00_31/codec_engine_2_10_01/packages/ti/sdo/ce/speech/) [1,0,2,1
210912797352]
@0,924,113us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.speech1
(/root/dvsdk_1_40_00_31/codec_engine_2_10_01/packages/ti/sdo/ce/speech1/) [1,0,1
,1210912803800]
@0,924,311us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.audio (/
root/dvsdk_1_40_00_31/codec_engine_2_10_01/packages/ti/sdo/ce/audio/) [1,0,2,121
0912396869]
@0,924,501us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.video (/
root/dvsdk_1_40_00_31/codec_engine_2_10_01/packages/ti/sdo/ce/video/) [1,0,3,121
0912990552]
@0,924,694us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.video1 (
/root/dvsdk_1_40_00_31/codec_engine_2_10_01/packages/ti/sdo/ce/video1/) [1,0,2,1
210912997315]
@0,924,887us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.dmai (/root
/dvsdk_1_40_00_31/dmai_1_10_00_06/packages/ti/sdo/dmai/) [1,0,0,1218218639000]
@0,925,071us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.simplewidge
t (/root/dvsdk_1_40_00_31/dvsdk_demos_1_40_00_18/packages/ti/sdo/simplewidget/)
@0,925,259us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.bioslog
(/root/dvsdk_1_40_00_31/codec_engine_2_10_01/packages/ti/sdo/ce/bioslog/) [1,0,1
,1210912409169]
@0,925,453us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.utils.tr
ace (/root/dvsdk_1_40_00_31/codec_engine_2_10_01/packages/ti/sdo/ce/utils/trace/
) [1,0,1,1210912971800]
@0,925,651us: [+4 T:0x00004000 S:0xbefffbd4] OG - package jpeg_slaver_config
(/root/dm6467/ep_codec/300-dy-2/jpeg_slaver/jpeg_slaver_config/) []
@0,925,889us: [+0 T:0x00004000 S:0xbefffbdc] OG - Global_atexit> enter (fxn=0x34
418)
@0,926,075us: [+0 T:0x00004000 S:0xbefffbdc] OG - Global_atexit> enter (fxn=0x33
8b0)
@0,926,348us: [+0 T:0x00004000 S:0xbefffbac] OM - Memory_alloc> Enter(0x18)
@0,926,522us: [+0 T:0x00004000 S:0xbefffbac] OM - Memory_alloc> return (0x495138
@0,926,897us: [+0 T:0x00004000 S:0xbefffbcc] OG - Global_atexit> enter (fxn=0x32
198)
@0,927,112us: [+0 T:0x00004000 S:0xbefffbac] OM - Memory_alloc> Enter(0x18)
@0,927,283us: [+0 T:0x00004000 S:0xbefffbac] OM - Memory_alloc> return (0x495188
@0,927,437us: [+0 T:0x00004000 S:0xbefffbcc] OG - Global_atexit> enter (fxn=0x2f
ed0)
@0,927,647us: [+0 T:0x00004000 S:0xbefffbd4] OG - Global_atexit> enter (fxn=0x32
f34)
@0,927,875us: [+0 T:0x00004000 S:0xbefffbbc] ti.sdo.ce.osal.Sem - Sem_create> co
unt: 0
@0,928,043us: [+0 T:0x00004000 S:0xbefffba4] OM - Memory_alloc> Enter(0x14)
@0,928,201us: [+0 T:0x00004000 S:0xbefffba4] OM - Memory_alloc> return (0x495208
@0,928,373us: [+0 T:0x00004000 S:0xbefffbbc] ti.sdo.ce.osal.Sem - Leaving Sem_cr
eate> sem[0x495208]
@0,928,539us: [+0 T:0x00004000 S:0xbefffbbc] ti.sdo.ce.osal.Sem - Sem_create> co
unt: 0
@0,928,688us: [+0 T:0x00004000 S:0xbefffba4] OM - Memory_alloc> Enter(0x14)
@0,928,836us: [+0 T:0x00004000 S:0xbefffba4] OM - Memory_alloc> return (0x495220
@0,929,010us: [+0 T:0x00004000 S:0xbefffbbc] ti.sdo.ce.osal.Sem - Leaving Sem_cr
eate> sem[0x495220]
@0,929,174us: [+0 T:0x00004000 S:0xbefffba4] OM - Memory_alloc> Enter(0x18)
@0,929,327us: [+0 T:0x00004000 S:0xbefffba4] OM - Memory_alloc> return (0x495238
@0,929,477us: [+0 T:0x00004000 S:0xbefffba4] OT - Thread_create> Enter (fxn=0x2f
010, attrs=0x0)
@1,264,503us: [+0 T:0x00004000 S:0xbefffb8c] OM - Memory_alloc> Enter(0x64)
@1,264,678us: [+0 T:0x00004000 S:0xbefffb8c] OM - Memory_alloc> return (0x495258
@1,266,018us: [+1 T:0x00004002 S:0xbe7ffa74] OP - daemon> thread created.
@1,266,247us: [+0 T:0x00004002 S:0xbe7ffa74] OP - getCmd_d> Enter (proc=0xbe7ffa
ec)
@1,266,419us: [+0 T:0x00004002 S:0xbe7ffa54] ti.sdo.ce.osal.Sem - Entered Sem_pe
nd> sem[0x495208] timeout[0xffffffff]
@1,266,679us: [+0 T:0x00004000 S:0xbefffba4] OT - Thread_create> Exit (task=0x49
5258)
@1,266,862us: [+0 T:0x00004000 S:0xbefffbdc] OG - Global_atexit> enter (fxn=0x2e
bd0)
@1,267,046us: [+0 T:0x00004000 S:0xbefffbdc] OG - Global_atexit> enter (fxn=0x30
cc4)
@1,267,314us: [+0 T:0x00004000 S:0xbefffbc4] ti.sdo.ce.alg - ALG_init> Enter
@1,267,478us: [+0 T:0x00004000 S:0xbefffbb4] OG - Global_atexit> enter (fxn=0x2e
118)
@1,267,644us: [+0 T:0x00004000 S:0xbefffbe4] ti.sdo.ce.alg - ALG_init> Exit
@1,267,790us: [+0 T:0x00004000 S:0xbefffbdc] OG - Global_atexit> enter (fxn=0x2d
bb8)
@1,268,004us: [+0 T:0x00004000 S:0xbefffbb4] OM - Memory_alloc> Enter(0x18)
@1,268,180us: [+0 T:0x00004000 S:0xbefffbb4] OM - Memory_alloc> return (0x497418
@1,268,342us: [+0 T:0x00004000 S:0xbefffbdc] OG - Global_atexit> enter (fxn=0x33
098)
@1,268,578us: [+6 T:0x00004000 S:0xbefffbdc] CE - Engine_init> CE debugging on (
CE_DEBUG=3; allowed CE_DEBUG levels: 1=min, 2=good, 3=max)
@1,268,782us: [+0 T:0x00004000 S:0xbefffbcc] OG - Global_atexit> enter (fxn=0x2a
f3c)
@1,268,945us: [+0 T:0x00004000 S:0xbefffbac] OM - Memory_alloc> Enter(0x18)
@1,269,109us: [+0 T:0x00004000 S:0xbefffbac] OM - Memory_alloc> return (0x497458
@1,269,265us: [+0 T:0x00004000 S:0xbefffbac] OM - Memory_alloc> Enter(0x18)
@1,269,423us: [+0 T:0x00004000 S:0xbefffbac] OM - Memory_alloc> return (0x497478
@1,269,576us: [+0 T:0x00004000 S:0xbefffbac] OM - Memory_alloc> Enter(0x18)
@1,269,734us: [+0 T:0x00004000 S:0xbefffbac] OM - Memory_alloc> return (0x497498
@1,269,967us: [+0 T:0x00004000 S:0xbefffbdc] CS - Server_init()
@1,270,204us: [+0 T:0x00004000 S:0xbefffbdc] CS - Server_init> Global_useLinkArb
iter = 0
@1,270,365us: [+0 T:0x00004000 S:0xbefffbdc] OG - Global_atexit> enter (fxn=0x29
a8c)
@1,270,635us: [+0 T:0x00004000 S:0xbefffbec] OG - Global_atexit> enter (fxn=0x1a
f18)
sssssssssssss
@1,271,192us: [+0 T:0x00004000 S:0xbefffb6c] CE - Engine_open> Enter('decode', 0
xbefffc10, 0xbefffc14)
@1,271,390us: [+0 T:0x00004000 S:0xbefffb54] OM - Memory_alloc> Enter(0x2c)
@1,271,555us: [+0 T:0x00004000 S:0xbefffb54] OM - Memory_alloc> return (0x497578
@1,271,716us: [+0 T:0x00004000 S:0xbefffb6c] CE - rserverOpen('decodeCombo.x64P'
), count = 0
@1,271,875us: [+0 T:0x00004000 S:0xbefffb34] OP - Processor_create> Enter(imageN
ame='decodeCombo.x64P', linkCfg='(null)', attrs=0xbefffbb8)
@1,272,135us: [+0 T:0x00004000 S:0xbefffb1c] OM - Memory_alloc> Enter(0x24)
@1,272,318us: [+0 T:0x00004000 S:0xbefffb1c] OM - Memory_alloc> return (0x4975a8
@1,272,479us: [+0 T:0x00004000 S:0xbefffb14] OP - doCmd> Enter (cmdId=1, proc=0x
4975a8)
@1,272,632us: [+0 T:0x00004000 S:0xbefffb04] ti.sdo.ce.osal.Sem - Entered Sem_po
st> sem[0x495208]
@1,272,864us: [+0 T:0x00004000 S:0xbefffb14] ti.sdo.ce.osal.Sem - Leaving Sem_po
st> sem[0x495208]
@1,273,046us: [+0 T:0x00004000 S:0xbefffaf4] ti.sdo.ce.osal.Sem - Entered Sem_pe
nd> sem[0x495220] timeout[0xffffffff]
@1,273,284us: [+0 T:0x00004002 S:0xbe7ffa54] ti.sdo.ce.osal.Sem - Leaving Sem_pe
nd> sem[0x495208] status[0]
@1,273,479us: [+0 T:0x00004002 S:0xbe7ffa74] OP - getCmd_d> Exit (result=1)
@1,273,641us: [+0 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Enter(proc
=0x4975a8)
@1,273,806us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Initializi
ng DSP PROC...
@1,273,975us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Using DspL
ink config data for entry #0 [server 'decodeCombo.x64P']
@1,608,376us: [+0 T:0x00004002 S:0xbe7ffa5c] OM - Memory_alloc> Enter(0xe0)
@1,608,566us: [+0 T:0x00004002 S:0xbe7ffa5c] OM - Memory_alloc> return (0x4975d0
@1,608,736us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Adding DSP
segment #0 to Link configuration: name='DDR2', startAddress=0x8ea00000, sizeInB
ytes=0x1400000, shared=1
@1,608,970us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Adding DSP
segment #1 to Link configuration: name='DSPLINKMEM', startAddress=0x8fe00000, s
izeInBytes=0x100000, shared=1
@1,609,202us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Adding DSP
segment #2 to Link configuration: name='RESET_VECTOR', startAddress=0x8ff00000,
sizeInBytes=0x80, shared=0
@1,609,431us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Adding DSP
segment #3 to Link configuration: name='DDRALGHEAP', startAddress=0x8ba00000, s
izeInBytes=0x3000000, shared=0
@1,609,661us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> DOPOWERCON
TROL was=0; now=0
Entered PROC_setup ()
linkCfg [0x5f154]
Entered DRV_Initialize ()
drvObj [0x5f92c]
arg [0x0]
Leaving DRV_Initialize () status [0x8000]
Entered DRV_ProtectInit ()
drvObj [0x4976b8]
Leaving DRV_ProtectInit () status [0x8000]
Entered DRV_ProtectEnter ()
drvObj [0x4976b8]
Leaving DRV_ProtectEnter () status [0x8000]
Entered DRV_Invoke ()
drvObj [0x4976b8]
cmdId [0x6c01]
arg1 [0xbe7ffa60]
arg2 [0x0]
Entered DRV_installCleanupRoutines ()
linkCfgPtr [0x5f154]
Leaving DRV_installCleanupRoutines ()
osStatus: 0
Entered _POOL_init ()
Leaving _POOL_init ()
Status: 8000
Leaving DRV_Invoke () status [0x8000]
Entered _MEM_USR_init ()
Leaving _MEM_USR_init () status [0x8000]
Entered _IDM_USR_init ()
drvObj [0x4976b8]
cmdId [0x7351]
arg1 [0xbe7ffa30]
arg2 [0x0]
Status: 8000
Leaving _IDM_USR_init () status [0x8000]
Entered _SYNC_USR_init ()
Entered _IDM_USR_create ()
key [0x10080]
attrs [0xbe7ffa38]
drvObj [0x4976b8]
cmdId [0x7353]
arg1 [0xbe7ff9f8]
arg2 [0x0]
Status: 8000
Leaving _IDM_USR_create () status [0x8000]
Leaving _SYNC_USR_init () status [0x8000]
Entered _SYNC_USR_createCS ()
idKey [0x54c88]
csObj [0x5f934]
Entered _IDM_USR_acquireId ()
key [0x10080]
idKey [0x54c88]
id [0xbe7ffa30]
drvObj [0x4976b8]
cmdId [0x7355]
arg1 [0xbe7ff9f8]
arg2 [0x0]
Status: 8000
Leaving _IDM_USR_acquireId () status [0x8000]
Leaving _SYNC_USR_createCS () status [0x8000]
Entered DRV_ProtectLeave ()
drvObj [0x4976b8]
Leaving DRV_ProtectLeave () status [0x8000]
Entered PROC_resetCurStatus ()
Leaving PROC_resetCurStatus ()
Leaving PROC_setup () status [0x8000]
@1,616,071us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Attaching
to DSP PROC...
Entered PROC_attach ()
procId [0x0]
attr [0x0]
Entered _SYNC_USR_enterCS ()
csObj [0x4976d0]
Leaving _SYNC_USR_enterCS () status [0x8000]
drvObj [0x4976b8]
cmdId [0x6c08]
arg1 [0xbe7ffa58]
arg2 [0x0]
Status: 8000
Entered _NOTIFY_init ()
dspId [0x0]
drvObj [0x4976b8]
cmdId [0x7301]
arg1 [0xbe7ffa28]
arg2 [0x0]
Status: 8000
Leaving _NOTIFY_init () status [0x8000]
Entered _MPCS_init ()
procId [0x0]
drvObj [0x4976b8]
cmdId [0x7201]
arg1 [0xbe7ffa28]
arg2 [0x0]
Status: 8000
Entered _MPCS_open ()
procId [0x0]
name [0x534f0]
mpcsHandle [0x5f91c]
mpcsShObj [0x40304680]
Entered _MPCS_OS_open ()
procId [0x0]
name [0x534f0]
Entered _MEM_USR_calloc ()
ptr [0x5f91c]
bytes [0xc]
_MEM_USR_calloc *ptr [0x4976e0]
Leaving _MEM_USR_calloc () status [0x8000]
idKey [0x534f0]
csObj [0x4976e4]
key [0x10080]
idKey [0x534f0]
id [0xbe7ff988]
drvObj [0x4976b8]
cmdId [0x7355]
arg1 [0xbe7ff950]
arg2 [0x0]
Status: 8000
Leaving _MPCS_OS_open () status [0x8000]
Leaving MPCS_open () status [0x8000]
Leaving _MPCS_init () status [0x8000]
Entered _MPLIST_moduleInit ()
procId [0x0]
drvObj [0x4976b8]
cmdId [0x7321]
arg1 [0xbe7ffa20]
arg2 [0x0]
Status: 8000
Entered MPCS_create ()
procId [0x0]
name [0x53a18]
mpcsShObj [0x4001a880]
attrs [0xbe7ffa1e]
Entered MPCS_enter ()
mpcsHandle [0x4976e0]
csObj [0x4976f0]
Leaving MPCS_enter () status [0x8000]
Entered MPCS_leave ()
Entered _SYNC_USR_leaveCS ()
csObj [0x4976f0]
Leaving _SYNC_USR_leaveCS () status [0x8000]
Leaving MPCS_leave () status [0x8000]
Leaving MPCS_create () status [0x8000]
drvObj [0x4976b8]
cmdId [0x7322]
arg1 [0xbe7ffa20]
arg2 [0x0]
Status: 8000
Leaving _MPLIST_moduleInit () status [0x8000]
Entered _MPLIST_init ()
procId [0x0]
drvObj [0x4976b8]
cmdId [0x7321]
arg1 [0xbe7ffa28]
arg2 [0x0]
Status: 8000
procId [0x0]
name [0x53a18]
mpcsHandle [0x5f928]
procId [0x0]
name [0x53a18]
ptr [0x5f928]
bytes [0xc]
_MEM_USR_calloc *ptr [0x497700]
idKey [0x53a18]
csObj [0x497704]
key [0x10080]
idKey [0x53a18]
id [0xbe7ff988]
drvObj [0x4976b8]
cmdId [0x7355]
arg1 [0xbe7ff950]
arg2 [0x0]
Status: 8000
Leaving _MPLIST_init () status [0x8000]
csObj [0x4976d0]
Leaving PROC_attach () status [0x8000]
@1,964,298us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Opening MS
GQ pool...
Entered POOL_open ()
poolId [0x0]
params [0x5ed20]
csObj [0x4976d0]
drvObj [0x4976b8]
cmdId [0x7101]
arg1 [0xbe7ffa58]
arg2 [0x0]
Status: 8000
csObj [0x4976d0]
Leaving POOL_open () status [0x8000]
@1,965,645us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Loading de
codeCombo.x64P on DSP (1 args)...
Entered PROC_load ()
procId [0x0]
imagePath [0x49534]
argc [0x1]
argv [0xbefffbc8]
csObj [0x4976d0]
drvObj [0x4976b8]
cmdId [0x6c05]
arg1 [0xbe7ffa50]
arg2 [0x0]
Status: 8000
csObj [0x4976d0]
Leaving PROC_load () status [0x8000]
@3,186,171us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Starting D
SP PROC...
Entered PROC_start ()
procId [0x0]
csObj [0x4976d0]
drvObj [0x4976b8]
cmdId [0x6c03]
arg1 [0xbe7ffa60]
arg2 [0x0]
Status: 8000
csObj [0x4976d0Failure [0x80008054] in [0x71a] at line 1305
Leaving _SYNC_USR_leaveCS () Failure [0x80008054] in [0x71a] at line 862
status [0x8000]
Leaving PROC_sFailure [0x80008054] in [0x703] at line 706
tart () status [0x8000]
@3,258Failure [0x80008054] in [0x302] at line 487
,191us: [+2 T:0x00004002 S:0xbe7Failure [0x80008054] in [0x71a] at line 1305
ffa74] OP - Processor_create_d> Failure [0x80008054] in [0x71a] at line 862
Opening remote transport...
EntFailure [0x80008054] in [0x703] at line 706
ered MSGQ_transportOpen ()
proFailure [0x80008054] in [0x302] at line 487
cId [0x0]
attrs [0xbe7ffae8]
cFailure [0x80008054] in [0x71a] at line 862
sObj [0x4976d0]
Leaving _SYNC_UFailure [0x80008054] in [0x703] at line 706
drvObj [0x4976b8]
cmdId [0x6f01]
arg1 [0xbe7ffa58]
arg2 [0x0]
Status: 8000
csObj [0x4976d0]
Leaving MSGQ_transportOpen () status [0x8000]
@3,259,556us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> return (1)
@3,259,729us: [+0 T:0x00004002 S:0xbe7ffa64] ti.sdo.ce.osal.Sem - Entered Sem_po
st> sem[0x495220]
@3,259,926us: [+0 T:0x00004002 S:0xbe7ffa74] ti.sdo.ce.osal.Sem - Leaving Sem_po
st> sem[0x495220]
@3,260,156us: [+0 T:0x00004002 S:0xbe7ffa74] OP - getCmd_d> Enter (proc=0xbe7ffa
ec)
@3,260,325us: [+0 T:0x00004002 S:0xbe7ffa54] ti.sdo.ce.osal.Sem - Entered Sem_pe
@3,260,564us: [+0 T:0x00004000 S:0xbefffaf4] ti.sdo.ce.osal.Sem - Leaving Sem_pe
nd> sem[0x495220] status[0]
@3,260,753us: [+0 T:0x00004000 S:0xbefffb14] OP - doCmd> Exit (result=1)
@3,260,899us: [+0 T:0x00004000 S:0xbefffb34] OP - Processor_create> return (0x49
75a8)
@3,261,082us: [+0 T:0x00004000 S:0xbefffb6c] CE - rserverOpen('decodeCombo.x64P'
): 0x5f7a0 done.
@3,261,250us: [+0 T:0x00004000 S:0xbefffb54] OM - Memory_alloc> Enter(0x1a)
@3,261,410us: [+0 T:0x00004000 S:0xbefffb54] OM - Memory_alloc> return (0x497720
@3,261,620us: [+0 T:0x00004000 S:0xbefffb44] OC - Comm_create> Enter(queueName='
decode_0', queue=0x497588, attrs=0x0)
@3,261,809us: [+0 T:0x00004000 S:0xbefffb2c] OM - Memory_alloc> Enter(0x4)
@3,261,969us: [+0 T:0x00004000 S:0xbefffb2c] OM - Memory_alloc> return (0x497740
Entered MSGQ_open ()
queueName [0x497720]
msgqQueue [0x497588]
attrs [0x0]
drvObj [0x4976b8]
cmdId [0x6f03]
arg1 [0xbefffb38]
arg2 [0x0]
Status: 8000
Leaving MSGQ_open () status [0x8000]
@3,263,055us: [+0 T:0x00004000 S:0xbefffb44] OC - Comm_create> return (0x497740)
@3,263,218us: [+0 T:0x00004000 S:0xbefffb44] OM - Memory_free> Enter(0x497720, 0
x1a)
@3,263,416us: [+0 T:0x00004000 S:0xbefffb44] OM - Memory_free> return (0x1)
@3,263,581us: [+0 T:0x00004000 S:0xbefffb4c] OC - Comm_alloc> Enter(poolId=0x0,
msg=0x497594, size=576)
Entered MSGQ_alloc ()
poolId [0x0]
size [0x1000]
msg [0x497594]
drvObj [0x4976b8]
cmdId [0x6f08]
arg1 [0xbefffb40]
arg2 [0x0]
Entered _POOL_xltBuf ()
poolId [0x0]
bufPtr [0xbefffb4c]
xltFlag [0x2]
Leaving _POOL_xltBuf ()
Status: 8000
Leaving MSGQ_alloc () status [0x8000]
@3,264,473us: [+0 T:0x00004000 S:0xbefffb4c] OC - Comm_alloc> msg=0x4030e880, re
turning (0)
@3,264,637us: [+0 T:0x00004000 S:0xbefffb2c] OC - Comm_locate> Enter(queueName='
rmsq', queue=0x497584)
Entered MSGQ_locate ()
queueName [0x4eac4]
msgqQueue [0x497584]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 80008054
Leaving DRV_Invoke () status [0x80008054]
Leaving MSGQ_locate () status [0x80008054]
@3,291,725us: [+6 T:0x00004000 S:0xbefffb2c] OC - Comm_locate> Attempt 1 of 20 t
o locate DSP's MSGQ 'rmsq' failed. Retrying...
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 80008054
@3,319,434us: [+6 T:0x00004000 S:0xbefffb2c] OC - Comm_locate> Attempt 2 of 20 t
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 80008054
Leaving MSGQ_locate () status [0xFailure [0x80008054] in [0x71a] at line 1305
80008054]
@3,347,124us: [+6 T:0Failure [0x80008054] in [0x71a] at line 862
x00004000 S:0xbefffb2c] OC - ComFailure [0x80008054] in [0x703] at line 706
m_locate> Attempt 3 of 20 to locFailure [0x80008054] in [0x302] at line 487
ate DSP's MSGQ 'rmsq' failed. ReFailure [0x80008054] in [0x71a] at line 1305
trying...
Entered MSGQ_locate (Failure [0x80008054] in [0x71a] at line 862
queueName [0x4eac4]
msgqQuFailure [0x80008054] in [0x703] at line 706
eue [0x497584]
attrs [0xbefffbFailure [0x80008054] in [0x302] at line 487
6c]
drvFailure [0x80008054] in [0x71a] at line 1305
Obj [0x4976b8]
arg1 [0xbefffb20]
arg2 [0x0]Failure [0x80008054] in [0x703] at line 706
Status: 80008054
Leaving DRV_Failure [0x80008054] in [0x302] at line 487
Leaving MSGQ_locate () status [Failure [0x80008054] in [0x71a] at line 862
0x80008054]
@3,710,365us: [+6 TFailure [0x80008054] in [0x703] at line 706
:0x00004000 S:0xbefffb2c] OC - CFailure [0x80008054] in [0x302] at line 487
omm_locate> Attempt 4 of 20 to lFailure [0x80008054] in [0x71a] at line 1305
ocate DSP's MSGQ 'rmsq' failed. Failure [0x80008054] in [0x71a] at line 862
Retrying...
Entered MSGQ_locateFailure [0x80008054] in [0x703] at line 706
queueName [0x4eac4]
msgqFailure [0x80008054] in [0x302] at line 487
Queue [0x497584]
attrs [0xbeffFailure [0x80008054] in [0x71a] at line 1305
fb6c]
dFailure [0x80008054] in [0x71a] at line 862
rvObj [0x4976b8]
cmdId [0x6f05Failure [0x80008054] in [0x703] at line 706
arg1 [0xbefffb20]
arg2 [0xFailure [0x80008054] in [0x302] at line 487
0]
Status: 80008054
Leaving DRFailure [0x80008054] in [0x71a] at line 1305
V_Invoke () status [0x80008054]Failure [0x80008054] in [0x71a] at line 862
Leaving MSGQ_locate () statusFailure [0x80008054] in [0x703] at line 706
[0x80008054]
@3,738,067us: [+6Failure [0x80008054] in [0x302] at line 487
T:0x00004000 S:0xbefffb2c] OC -Failure [0x80008054] in [0x71a] at line 1305
Comm_locate> Attempt 5 of 20 toFailure [0x80008054] in [0x71a] at line 862
locate DSP's MSGQ 'rmsq' failedFailure [0x80008054] in [0x703] at line 706
. Retrying...
Entered MSGQ_locaFailure [0x80008054] in [0x302] at line 487
te ()
queueName [0x4eac4]
msFailure [0x80008054] in [0x71a] at line 1305
gqQueue [0x497584]
attrs [0xbeFailure [0x80008054] in [0x71a] at line 862
fffb6c]
drvObj [0x4976b8]
cmdId [0x6fFailure [0x80008054] in [0x302] at line 487
05]
arg1 [0xbefffb20]
arg2 [Failure [0x80008054] in [0x71a] at line 1305
0x0]
Status: 80008054
Leaving Failure [0x80008054] in [0x71a] at line 862
DRV_Invoke () status [0x8000805Failure [0x80008054] in [0x703] at line 706
4]
Leaving MSGQ_locate () statFailure [0x80008054] in [0x302] at line 487
us [0x80008054]
@3,765,810us: [Failure [0x80008054] in [0x71a] at line 1305
+6 T:0x00004000 S:0xbefffb2c] OCFailure [0x80008054] in [0x71a] at line 862
- Comm_locate> Attempt 6 of 20 Failure [0x80008054] in [0x703] at line 706
to locate DSP's MSGQ 'rmsq' failFailure [0x80008054] in [0x302] at line 487
ed. Retrying...
Entered MSGQ_loFailure [0x80008054] in [0x71a] at line 1305
cate ()
queueName [0x4eac4]
attrs [0xFailure [0x80008054] in [0x703] at line 706
befffb6c]
Entered DRV_Invoke ()Failure [0x80008054] in [0x302] at line 487
drvObj [0x4976b8]
cmdId [0xFailure [0x80008054] in [0x71a] at line 1305
6f05]
arg1 [0xbefffb20]
arg2Failure [0x80008054] in [0x71a] at line 862
[0x0]
Status: 80008054
LeavinFailure [0x80008054] in [0x703] at line 706
g DRV_Invoke () status [0x80008Failure [0x80008054] in [0x302] at line 4
87
054]
@3,793,552us: [+6 T:0x00004000 S:0xbefffb2c] OC - Comm_locate> Attempt 7 of 20 t
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 80008054
@3,821,276us: [+6 T:0x00004000 S:0xbefffb2c] OC - Comm_locate> Attempt 8 of 20 t
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 80008054
@3,848,990us: [+6 T:0x00004000 S:0xbefffb2c] OC - Comm_locate> Attempt 9 of 20 t
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 80008054
@3,876,742us: [+6 T:0x00004000 S:0xbefffb2c] OC - Comm_locate> Attempt 10 of 20
to locate DSP's MSGQ 'rmsq' failed. Retrying...
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 80008054
@3,904,466us: [+6 T:0x00004000 S:0xbefffb2c] OC - Comm_locate> Attempt 11 of 20
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 80008054
@3,932,202us: [+6 T:0x00004000 S:0xbefffb2c] OC - Comm_locate> Attempt 12 of 20
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 80008054
@3,959,905us: [+6 T:0x00004000 S:0xbefffb2c] OC - Comm_locate> Attempt 13 of 20
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 80008054
@3,987,619us: [+6 T:0x00004000 S:0xbefffb2c] OC - Comm_locate> Attempt 14 of 20
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 80008054
@4,015,384us: [+6 T:0x00004000 S:0xbefffb2c] OC - Comm_locate> Attempt 15 of 20
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 80008054
@4,043,105us: [+6 T:0x00004000 S:0xbefffb2c] OC - ComFailure [0x80008054] in [0x
71a] at line 1305
m_locate> Attempt 16 of 20 to loFailure [0x80008054] in [0x71a] at line 862
cate DSP's MSGQ 'rmsq' failed. RFailure [0x80008054] in [0x703] at line 706
etrying...
Entered MSGQ_locate Failure [0x80008054] in [0x302] at line 487
queueName [0x4eac4]
msgqQFailure [0x80008054] in [0x71a] at line 1305
ueue [0x497584]
attrs [0xbefffFailure [0x80008054] in [0x71a] at line 862
b6c]
drFailure [0x80008054] in [0x703] at line 706
vObj [0x4976b8]
cmdId [0x6f05]Failure [0x80008054] in [0x302] at line 487
arg1 [0xbefffb20]
arg2 [0x0Failure [0x80008054] in [0x71a] at line 1305
Status: 80008054
Leaving DRVFailure [0x80008054] in [0x71a] at line 862
Leaving MSGQ_locate () status Failure [0x80008054] in [0x302] at line 487
[0x80008054]
@4,406,339us: [+6 Failure [0x80008054] in [0x71a] at line 1305
T:0x00004000 S:0xbefffb2c] OC - Failure [0x80008054] in [0x71a] at line 862
Comm_locate> Attempt 17 of 20 toFailure [0x80008054] in [0x703] at line 706
locate DSP's MSGQ 'rmsq' failedFailure [0x80008054] in [0x302] at line 487
. Retrying...
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 80008054
@4,434,046us: [+6 T:0x00004000 S:0xbefffb2c] OC - Comm_locate> Attempt 18 of 20
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 80008054
@4,461,784us: [+6 T:0x00004000 S:0xbefffb2c] OC - Comm_locate> Attempt 19 of 20
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 80008054
@4,489,490us: [+6 T:0x00004000 S:0xbefffb2c] OC - Comm_locate> Attempt 20 of 20
@4,489,687us: [+7 T:0x00004000 S:0xbefffb2c] OC - Comm_locate> Error: could not
locate DSP server's MSGQ 'rmsq' in 20 retries. Check if you have the correct DSP
image, or increase the number of retries (see ti.sdo.ce.osal.Global's commLocat
eRetries config param.
@4,489,948us: [+0 T:0x00004000 S:0xbefffb2c] OC - Comm_locate> return (1)
@4,490,148us: [+0 T:0x00004000 S:0xbefffb4c] CE - Engine_close(0x497578)
@4,490,325us: [+0 T:0x00004000 S:0xbefffaac] OC - Comm_put> Enter(queue=0xffff,
msg=0x4030e880)
Entered MSGQ_put ()
msgqQueue [0xffff]
msg [0x4030e880]
Leaving MSGQ_put () status [0x8000800b]
@4,490,664us: [+0 T:0x00004000 S:0xbefffaac] OC - Comm_put> return (1)
@4,490,813us: [+0 T:0x00004000 S:0xbefffb34] OC - Comm_free> Enter (msg=0x4030e8
80)
Entered MSGQ_free ()
msg [0x4030e880]
drvObj [0x4976b8]
cmdId [0x6f09]
arg1 [0xbefffb30]
arg2 [0x0]
poolId [0x0]
bufPtr [0xbefffb34]
xltFlag [0x200]
Status: 8000
Leaving MSGQ_free () status [0x8000]
@4,491,591us: [+0 T:0x00004000 S:0xbefffb34] OC - Comm_free> return (0)
@4,491,740us: [+0 T:0x00004000 S:0xbefffb3c] OC - Comm_delete> Enter (comm=0x497
740)
Entered MSGQ_close ()
msgqQueue [0x10000]
drvObj [0x4976b8]
cmdId [0x6f04]
arg1 [0xbefffb38]
arg2 [0x0]
Status: 8000
Leaving MSGQ_close () status [0x8000]
@4,492,626us: [+0 T:0x00004000 S:0xbefffb14] OM - Memory_free> Enter(0x497740, 0
x4)
@4,492,799us: [+0 T:0x00004000 S:0xbefffb14] OM - Memory_free> return (0x1)
@4,492,950us: [+0 T:0x00004000 S:0xbefffb4c] OC - Comm_delete> return
@4,493,088us: [+0 T:0x00004000 S:0xbefffb4c] CE - rserverClose(0x5f7a0), count =
1
@4,493,241us: [+0 T:0x00004000 S:0xbefffb3c] OP - Processor_delete> Enter(proc=0
x4975a8)
@4,493,397us: [+0 T:0x00004000 S:0xbefffb1c] OP - doCmd> Enter (cmdId=2, proc=0x
4975a8)
@4,493,549us: [+0 T:0x00004000 S:0xbefffb0c] ti.sdo.ce.osal.Sem - Entered Sem_po
st> sem[0x495208]
@4,493,736us: [+0 T:0x00004000 S:0xbefffb1c] ti.sdo.ce.osal.Sem - Leaving Sem_po
st> sem[0x495208]
@4,493,904us: [+0 T:0x00004000 S:0xbefffafc] ti.sdo.ce.osal.Sem - Entered Sem_pe
@4,494,135us: [+0 T:0x00004002 S:0xbe7ffa54] ti.sdo.ce.osal.Sem - Leaving Sem_pe
@4,494,332us: [+0 T:0x00004002 S:0xbe7ffa74] OP - getCmd_d> Exit (result=2)
@4,494,494us: [+0 T:0x00004002 S:0xbe7ffa54] OP - Processor_delete_d> Enter (pro
c=0x4975a8)
@4,494,658us: [+2 T:0x00004002 S:0xbe7ffa54] OP - Processor_delete_d> Closing re
mote transport...
Entered MSGQ_transportClose ()
procId [0x0]
csObj [0x4976d0]
drvObj [0x4976b8]
cmdId [0x6f02]
arg1 [0xbe7ffa40]
arg2 [0x0]
Status: 800d
Leaving DRV_Invoke () status [0x800d]
csObj [0x4976d0]
Leaving MSGQ_transportClose () status [0x800d]
@4,831,046us: [+2 T:0x00004002 S:0xbe7ffa54] OP - Processor_delete_d> Stopping D
SP...
Entered PROC_stop ()
procId [0x0]
csObj [0x4976d0]
drvObj [0x4976b8]
cmdId [0x6c04]
arg1 [0xbe7ffa40]
arg2 [0x0]
Status: 800c
Leaving DRV_Invoke () status [0x800c]
csObj [0x4976d0]
Leaving PROC_stop () status [0x800c]
@4,832,156us: [+2 T:0x00004002 S:0xbe7ffa54] OP - Processor_delete_d> Closing po
ol...
Entered POOL_close ()
poolId [0x0]
csObj [0x4976d0]
drvObj [0x4976b8]
cmdId [0x7102]
arg1 [0xbe7ffa40]
arg2 [0x0]
Status: 800d
csObj [0x4976d0]
Leaving POOL_close () status [0x800d]
@4,833,457us: [+2 T:0x00004002 S:0xbe7ffa54] OP - Processor_delete_d> Detaching
from DSP...
Entered PROC_detach ()
procId [0x0]
csObj [0x4976d0]
drvObj [0x4976b8]
cmdId [0x6c0f]
arg1 [0xbe7ffa40]
arg2 [0x0]
Status: 8000
Entered _MPLIST_exit ()
procId [0x0]
Entered MPCS_close ()
procId [0x0]
mpcsHandle [0x497700]
csObj [0x4976f0]
Entered _MPCS_OS_close ()
procId [0x0]
Entered _SYNC_USR_deleteCS ()
csObj [0x497704]
Entered _IDM_USR_releaseId ()
key [0x10080]
id [0x2]
drvObj [0x4976b8]
cmdId [0x7356]
arg1 [0xbe7ff968]
arg2 [0x0]
Status: 8006
Leaving DRV_Invoke () status [0x8006]
Leaving _IDM_USR_releaseId () status [0x8006]
Leaving _SYNC_USR_deleteCS () status [0x8006]
Entered _MEM_USR_free ()
ptr [0xbe7ff9c8]
Leaving _MEM_USR_free () status [0x8000]
Leaving _MPCS_OS_close () status [0x8006]
csObj [0x4976f0]
Leaving MPCS_close () status [0x8006]
drvObj [0x4976b8]
cmdId [0x7322]
arg1 [0xbe7ffa08]
arg2 [0x0]
Status: 8000
Leaving _MPLIST_exit () status [0x8006]
Entered _MPLIST_moduleExit ()
procId [0x0]
drvObj [0x4976b8]
cmdId [0x7321]
arg1 [0xbe7ffa00]
arg2 [0x0]
Status: 8000
Entered MPCS_delete ()
procId [0x0]
name [0x53a18]
Leaving MPCS_delete () status [0x8000]
drvObj [0x4976b8]
cmdId [0x7322]
arg1 [0xbe7ffa00]
arg2 [0x0]
Status: 8000
Leaving _MPLIST_moduleExit () status [0x8000]
Entered _MPCS_exit ()
procId [0x0]
procId [0x0]
procId [0x0]
csObj [0x4976e4]
key [0x10080]
id [0x1]
drvObj [0x4976b8]
cmdId [0x7356]
arg1 [0xbe7ff968]
arg2 [0x0]
Status: 8006
ptr [0xbe7ff9c8]
drvObj [0x4976b8]
cmdId [0x7202]
arg1 [0xbe7ffa08]
arg2 [0x0]
Status: 8000
Leaving _MPCS_exit () status [0x8006]
Entered _NOTIFY_exit ()
dspId [0x0]
drvObj [0x4976b8]
cmdId [0x7302]
arg1 [0xbe7ffa10]
arg2 [0x0]
Status: 8000
Leaving _NOTIFY_exit () status [0x8000]
drvObj [0x4976b8]
cmdId [0x6c07]
arg1 [0xbe7ffa40]
arg2 [0x0]
Status: 8009
Leaving DRV_Invoke () status [0x8009]
Entered DRV_Finalize ()
drvObj [0x4976b8]
arg [0x0]
Leaving DRV_Finalize () status [0x8003]
csObj [0x4976d0]
Leaving PROC_detach () status [0x8009]
@5,186,223us: [+2 T:0x00004002 S:0xbe7ffa54] OP - Processor_delete_d> Destroying
DSP... (object, that is)
Entered PROC_destroy ()
drvObj [0x5f92c]
arg [0x0]
drvObj [0x4976b8]
drvObj [0x4976b8]
cmdId [0x6c0e]
arg1 [0xbe7ffa40]
arg2 [0x0]
Status: 8000
csObj [0x5f934]
key [0x10080]
id [0x0]
drvObj [0x4976b8]
cmdId [0x7356]
arg1 [0xbe7ff9f0]
arg2 [0x0]
Status: 8006
Entered _SYNC_USR_exit ()
Entered _IDM_USR_delete ()
key [0x10080]
drvObj [0x4976b8]
cmdId [0x7354]
arg1 [0xbe7ff9f0]
arg2 [0x0]
Status: 8000
Leaving _IDM_USR_delete () status [0x8000]
Leaving _SYNC_USR_exit () status [0x8000]
Entered _IDM_USR_exit ()
drvObj [0x4976b8]
cmdId [0x7352]
arg1 [0xbe7ffa10]
arg2 [0x0]
Status: 8000
Leaving _IDM_USR_exit () status [0x8000]
Entered _MEM_USR_exit ()
Leaving _MEM_USR_exit () status [0x8000]
drvObj [0x4976b8]
cmdId [0x6c02]
arg1 [0xbe7ffa40]
arg2 [0x0]
Entered _POOL_exit ()
Leaving _POOL_exit ()
Status: 8008
Leaving DRV_Invoke () status [0x8008]
drvObj [0x4976b8]
Entered DRV_ProtectExit ()
drvObj [0x4976b8]
Leaving DRV_ProtectExit () status [0x8000]
drvObj [0x4976b8]
arg [0x0]
Leaving PROC_destroy () status [0x8008]
@5,190,608us: [+0 T:0x00004002 S:0xbe7ffa2c] OM - Memory_free> Enter(0x4975d0, 0
x0)
@5,190,790us: [+0 T:0x00004002 S:0xbe7ffa2c] OM - Memory_free> return (0x1)
@5,190,946us: [+0 T:0x00004002 S:0xbe7ffa74] OP - Processor_delete_d> return
@5,191,126us: [+0 T:0x00004002 S:0xbe7ffa64] ti.sdo.ce.osal.Sem - Entered Sem_po
st> sem[0x495220]
@5,191,325us: [+0 T:0x00004002 S:0xbe7ffa74] ti.sdo.ce.osal.Sem - Leaving Sem_po
st> sem[0x495220]
@5,191,504us: [+0 T:0x00004002 S:0xbe7ffa74] OP - getCmd_d> Enter (proc=0xbe7ffa
ec)
@5,191,665us: [+0 T:0x00004002 S:0xbe7ffa54] ti.sdo.ce.osal.Sem - Entered Sem_pe
@5,191,900us: [+0 T:0x00004000 S:0xbefffafc] ti.sdo.ce.osal.Sem - Leaving Sem_pe
@5,192,088us: [+0 T:0x00004000 S:0xbefffb1c] OP - doCmd> Exit (result=1)
@5,192,235us: [+1 T:0x00004000 S:0xbefffb3c] OP - Processor_delete(0x4975a8) fre
eing object ...
@5,192,394us: [+0 T:0x00004000 S:0xbefffb14] OM - Memory_free> Enter(0x4975a8, 0
x24)
@5,192,553us: [+0 T:0x00004000 S:0xbefffb14] OM - Memory_free> return (0x1)
@5,192,700us: [+0 T:0x00004000 S:0xbefffb4c] OP - Processor_delete> return.
@5,192,844us: [+0 T:0x00004000 S:0xbefffb4c] CE - rserverClose(0x5f7a0) done.
@5,526,587us: [+0 T:0x00004000 S:0xbefffb44] OM - Memory_free> Enter(0x497578, 0
x2c)
@5,526,772us: [+0 T:0x00004000 S:0xbefffb44] OM - Memory_free> return (0x1)
@5,526,925us: [+0 T:0x00004000 S:0xbefffb6c] CE - Engine_open> return(0)
Error: Failed to open codec engine decode, err code is 5
the flag_engine_ok is 0
engine_open succefful info:
SPI initialized
SPI initialized
DMA initialized
insmod: cannot insert `dsplinkk.ko': File exists (-1): File exists
@0,756,121us: [+4 T:0x00004000 S:0xbefffbd4] OG - Global_init> This program was
@0,756,503us: [+4 T:0x00004000 S:0xbefffbd4] OG - package gnu.targets.rts470
1203621000516]
@0,756,817us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.codecs.jpeg
@0,757,037us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.codecs.jpeg
@0,757,244us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.codecs.mpeg
@0,757,449us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.xdais.dm (/root
@0,757,634us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.xdais (/root/dv
@0,757,815us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.utils.trace
@0,758,017us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.utils.xd
,0,1,1210912978675]
@0,758,216us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.fc.dman3 (/
,0,3,1210822157942]
@0,758,412us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.fc.acpy3 (/
,0,2,1210822135592]
@0,758,608us: [+4 T:0x00004000 S:0xbefffbd4] OG - package dsplink.gpp (/root
@0,758,794us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.linuxutils.
1204929560755]
@0,758,985us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.catalog.c470 (/
475]
@0,759,174us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.catalog.c6000 (
81695]
@0,759,364us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.platforms.evmDM
,0,0,1192229633217]
@0,759,583us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.osal (/r
12758604]
@0,759,776us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.ipc (/ro
707081]
@0,759,967us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.osal.lin
@0,760,220us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.ipc.dspl
@0,760,428us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.alg (/ro
389491]
@0,760,621us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce (/root/d
@0,760,806us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.image1 (
210912701200]
@0,760,998us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.codecs.jpeg
@0,761,205us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.codecs.jpeg
@1,095,215us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.video2 (
210913003946]
@1,095,446us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.codecs.mpeg
@1,095,667us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.speech (
210912797352]
@1,095,863us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.speech1
,1210912803800]
@1,096,058us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.audio (/
0912396869]
@1,096,253us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.video (/
0912990552]
@1,096,448us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.video1 (
210912997315]
@1,096,642us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.dmai (/root
@1,096,827us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.simplewidge
@1,097,016us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.bioslog
,1210912409169]
@1,097,215us: [+4 T:0x00004000 S:0xbefffbd4] OG - package ti.sdo.ce.utils.tr
@1,097,417us: [+4 T:0x00004000 S:0xbefffbd4] OG - package jpeg_slaver_config
@1,097,659us: [+0 T:0x00004000 S:0xbefffbdc] OG - Global_atexit> enter (fxn=0x34
418)
@1,097,865us: [+0 T:0x00004000 S:0xbefffbdc] OG - Global_atexit> enter (fxn=0x33
8b0)
@1,098,114us: [+0 T:0x00004000 S:0xbefffbac] OM - Memory_alloc> Enter(0x18)
@1,098,291us: [+0 T:0x00004000 S:0xbefffbac] OM - Memory_alloc> return (0x495138
@1,098,666us: [+0 T:0x00004000 S:0xbefffbcc] OG - Global_atexit> enter (fxn=0x32
198)
@1,098,880us: [+0 T:0x00004000 S:0xbefffbac] OM - Memory_alloc> Enter(0x18)
@1,099,051us: [+0 T:0x00004000 S:0xbefffbac] OM - Memory_alloc> return (0x495188
@1,099,211us: [+0 T:0x00004000 S:0xbefffbcc] OG - Global_atexit> enter (fxn=0x2f
ed0)
@1,099,422us: [+0 T:0x00004000 S:0xbefffbd4] OG - Global_atexit> enter (fxn=0x32
f34)
@1,099,651us: [+0 T:0x00004000 S:0xbefffbbc] ti.sdo.ce.osal.Sem - Sem_create> co
unt: 0
@1,099,817us: [+0 T:0x00004000 S:0xbefffba4] OM - Memory_alloc> Enter(0x14)
@1,099,976us: [+0 T:0x00004000 S:0xbefffba4] OM - Memory_alloc> return (0x495208
@1,100,218us: [+0 T:0x00004000 S:0xbefffbbc] ti.sdo.ce.osal.Sem - Leaving Sem_cr
eate> sem[0x495208]
@1,100,388us: [+0 T:0x00004000 S:0xbefffbbc] ti.sdo.ce.osal.Sem - Sem_create> co
unt: 0
@1,100,535us: [+0 T:0x00004000 S:0xbefffba4] OM - Memory_alloc> Enter(0x14)
@1,100,714us: [+0 T:0x00004000 S:0xbefffba4] OM - Memory_alloc> return (0x495220
@1,100,870us: [+0 T:0x00004000 S:0xbefffbbc] ti.sdo.ce.osal.Sem - Leaving Sem_cr
eate> sem[0x495220]
@1,101,025us: [+0 T:0x00004000 S:0xbefffba4] OM - Memory_alloc> Enter(0x18)
@1,101,176us: [+0 T:0x00004000 S:0xbefffba4] OM - Memory_alloc> return (0x495238
@1,101,327us: [+0 T:0x00004000 S:0xbefffba4] OT - Thread_create> Enter (fxn=0x2f
010, attrs=0x0)
@1,436,230us: [+0 T:0x00004000 S:0xbefffb8c] OM - Memory_alloc> Enter(0x64)
@1,436,412us: [+0 T:0x00004000 S:0xbefffb8c] OM - Memory_alloc> return (0x495258
@1,437,742us: [+1 T:0x00004002 S:0xbe7ffa74] OP - daemon> thread created.
@1,437,976us: [+0 T:0x00004002 S:0xbe7ffa74] OP - getCmd_d> Enter (proc=0xbe7ffa
ec)
@1,438,148us: [+0 T:0x00004002 S:0xbe7ffa54] ti.sdo.ce.osal.Sem - Entered Sem_pe
@1,438,407us: [+0 T:0x00004000 S:0xbefffba4] OT - Thread_create> Exit (task=0x49
5258)
@1,438,586us: [+0 T:0x00004000 S:0xbefffbdc] OG - Global_atexit> enter (fxn=0x2e
bd0)
@1,438,774us: [+0 T:0x00004000 S:0xbefffbdc] OG - Global_atexit> enter (fxn=0x30
cc4)
@1,439,039us: [+0 T:0x00004000 S:0xbefffbc4] ti.sdo.ce.alg - ALG_init> Enter
@1,439,207us: [+0 T:0x00004000 S:0xbefffbb4] OG - Global_atexit> enter (fxn=0x2e
118)
@1,439,371us: [+0 T:0x00004000 S:0xbefffbe4] ti.sdo.ce.alg - ALG_init> Exit
@1,439,515us: [+0 T:0x00004000 S:0xbefffbdc] OG - Global_atexit> enter (fxn=0x2d
bb8)
@1,439,730us: [+0 T:0x00004000 S:0xbefffbb4] OM - Memory_alloc> Enter(0x18)
@1,439,904us: [+0 T:0x00004000 S:0xbefffbb4] OM - Memory_alloc> return (0x497418
@1,440,120us: [+0 T:0x00004000 S:0xbefffbdc] OG - Global_atexit> enter (fxn=0x33
098)
@1,440,371us: [+6 T:0x00004000 S:0xbefffbdc] CE - Engine_init> CE debugging on (
@1,440,576us: [+0 T:0x00004000 S:0xbefffbcc] OG - Global_atexit> enter (fxn=0x2a
f3c)
@1,440,741us: [+0 T:0x00004000 S:0xbefffbac] OM - Memory_alloc> Enter(0x18)
@1,440,905us: [+0 T:0x00004000 S:0xbefffbac] OM - Memory_alloc> return (0x497458
@1,441,061us: [+0 T:0x00004000 S:0xbefffbac] OM - Memory_alloc> Enter(0x18)
@1,441,217us: [+0 T:0x00004000 S:0xbefffbac] OM - Memory_alloc> return (0x497478
@1,441,371us: [+0 T:0x00004000 S:0xbefffbac] OM - Memory_alloc> Enter(0x18)
@1,441,525us: [+0 T:0x00004000 S:0xbefffbac] OM - Memory_alloc> return (0x497498
@1,441,781us: [+0 T:0x00004000 S:0xbefffbdc] CS - Server_init()
@1,441,938us: [+0 T:0x00004000 S:0xbefffbdc] CS - Server_init> Global_useLinkArb
iter = 0
@1,442,100us: [+0 T:0x00004000 S:0xbefffbdc] OG - Global_atexit> enter (fxn=0x29
a8c)
@1,442,367us: [+0 T:0x00004000 S:0xbefffbec] OG - Global_atexit> enter (fxn=0x1a
f18)
sssssssssssss
@1,442,920us: [+0 T:0x00004000 S:0xbefffb6c] CE - Engine_open> Enter('decode', 0
@1,443,118us: [+0 T:0x00004000 S:0xbefffb54] OM - Memory_alloc> Enter(0x2c)
@1,443,283us: [+0 T:0x00004000 S:0xbefffb54] OM - Memory_alloc> return (0x497578
@1,443,443us: [+0 T:0x00004000 S:0xbefffb6c] CE - rserverOpen('decodeCombo.x64P'
), count = 0
@1,443,603us: [+0 T:0x00004000 S:0xbefffb34] OP - Processor_create> Enter(imageN
@1,443,865us: [+0 T:0x00004000 S:0xbefffb1c] OM - Memory_alloc> Enter(0x24)
@1,444,048us: [+0 T:0x00004000 S:0xbefffb1c] OM - Memory_alloc> return (0x4975a8
@1,444,211us: [+0 T:0x00004000 S:0xbefffb14] OP - doCmd> Enter (cmdId=1, proc=0x
4975a8)
@1,444,368us: [+0 T:0x00004000 S:0xbefffb04] ti.sdo.ce.osal.Sem - Entered Sem_po
st> sem[0x495208]
@1,444,602us: [+0 T:0x00004000 S:0xbefffb14] ti.sdo.ce.osal.Sem - Leaving Sem_po
st> sem[0x495208]
@1,444,784us: [+0 T:0x00004000 S:0xbefffaf4] ti.sdo.ce.osal.Sem - Entered Sem_pe
@1,445,020us: [+0 T:0x00004002 S:0xbe7ffa54] ti.sdo.ce.osal.Sem - Leaving Sem_pe
@1,445,217us: [+0 T:0x00004002 S:0xbe7ffa74] OP - getCmd_d> Exit (result=1)
@1,445,375us: [+0 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Enter(proc
=0x4975a8)
@1,445,538us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Initializi
ng DSP PROC...
@1,445,708us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Using DspL
@1,780,098us: [+0 T:0x00004002 S:0xbe7ffa5c] OM - Memory_alloc> Enter(0xe0)
@1,780,289us: [+0 T:0x00004002 S:0xbe7ffa5c] OM - Memory_alloc> return (0x4975d0
@1,780,458us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Adding DSP
@1,780,690us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Adding DSP
@1,780,921us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Adding DSP
@1,781,152us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Adding DSP
@1,781,382us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> DOPOWERCON
TROL was=0; now=0
linkCfg [0x5f154]
drvObj [0x5f92c]
arg [0x0]
drvObj [0x4976b8]
drvObj [0x4976b8]
drvObj [0x4976b8]
cmdId [0x6c01]
arg1 [0xbe7ffa60]
arg2 [0x0]
osStatus: 0
Status: 8000
drvObj [0x4976b8]
cmdId [0x7351]
arg1 [0xbe7ffa30]
arg2 [0x0]
Status: 8000
key [0x10080]
attrs [0xbe7ffa38]
drvObj [0x4976b8]
cmdId [0x7353]
arg1 [0xbe7ff9f8]
arg2 [0x0]
Status: 8000
idKey [0x54c88]
csObj [0x5f934]
key [0x10080]
idKey [0x54c88]
id [0xbe7ffa30]
drvObj [0x4976b8]
cmdId [0x7355]
arg1 [0xbe7ff9f8]
arg2 [0x0]
Status: 8000
drvObj [0x4976b8]
@1,787,682us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Attaching
to DSP PROC...
procId [0x0]
attr [0x0]
csObj [0x4976d0]
drvObj [0x4976b8]
cmdId [0x6c08]
arg1 [0xbe7ffa58]
arg2 [0x0]
Status: 8000
dspId [0x0]
drvObj [0x4976b8]
cmdId [0x7301]
arg1 [0xbe7ffa28]
arg2 [0x0]
Status: 8000
procId [0x0]
drvObj [0x4976b8]
cmdId [0x7201]
arg1 [0xbe7ffa28]
arg2 [0x0]
Status: 8000
procId [0x0]
name [0x534f0]
procId [0x0]
name [0x534f0]
ptr [0x5f91c]
bytes [0xc]
idKey [0x534f0]
csObj [0x4976e4]
key [0x10080]
idKey [0x534f0]
id [0xbe7ff988]
drvObj [0x4976b8]
cmdId [0x7355]
arg1 [0xbe7ff950]
arg2 [0x0]
Status: 8000
procId [0x0]
drvObj [0x4976b8]
cmdId [0x7321]
arg1 [0xbe7ffa20]
arg2 [0x0]
Status: 8000
procId [0x0]
name [0x53a18]
attrs [0xbe7ffa1e]
csObj [0x4976f0]
csObj [0x4976f0]
drvObj [0x4976b8]
cmdId [0x7322]
arg1 [0xbe7ffa20]
arg2 [0x0]
Status: 8000
procId [0x0]
drvObj [0x4976b8]
cmdId [0x7321]
arg1 [0xbe7ffa28]
arg2 [0x0]
Status: 8000
procId [0x0]
name [0x53a18]
procId [0x0]
name [0x53a18]
ptr [0x5f928]
bytes [0xc]
idKey [0x53a18]
csObj [0x497704]
key [0x10080]
idKey [0x53a18]
id [0xbe7ff988]
drvObj [0x4976b8]
cmdId [0x7355]
arg1 [0xbe7ff950]
arg2 [0x0]
Status: 8000
csObj [0x4976d0]
@2,135,949us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Opening MS
GQ pool...
poolId [0x0]
params [0x5ed20]
csObj [0x4976d0]
drvObj [0x4976b8]
cmdId [0x7101]
arg1 [0xbe7ffa58]
arg2 [0x0]
Status: 8000
csObj [0x4976d0]
@2,137,268us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Loading de
procId [0x0]
imagePath [0x49534]
argc [0x1]
argv [0xbefffbc8]
csObj [0x4976d0]
drvObj [0x4976b8]
cmdId [0x6c05]
arg1 [0xbe7ffa50]
arg2 [0x0]
Status: 8000
csObj [0x4976d0]
@3,357,500us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Starting D
SP PROC...
procId [0x0]
csObj [0x4976d0]
drvObj [0x4976b8]
cmdId [0x6c03]
arg1 [0xbe7ffa60]
arg2 [0x0]
Status: 8000
csObj [0x4976d0]
Leaving PROC_start () status [0x8000]
@3,429,527us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> Opening re
mote transport...
Entered MSGQ_transportOpen ()
procId [0x0]
attrs [0xbe7ffae8]
csObj [0x4976d0]
drvObj [0x4976b8]
cmdId [0x6f01]
arg1 [0xbe7ffa58]
arg2 [0x0]
Status: 8000
csObj [0x4976d0]
@3,430,961us: [+2 T:0x00004002 S:0xbe7ffa74] OP - Processor_create_d> return (1)
@3,431,134us: [+0 T:0x00004002 S:0xbe7ffa64] ti.sdo.ce.osal.Sem - Entered Sem_po
st> sem[0x495220]
@3,431,333us: [+0 T:0x00004002 S:0xbe7ffa74] ti.sdo.ce.osal.Sem - Leaving Sem_po
st> sem[0x495220]
@3,431,513us: [+0 T:0x00004002 S:0xbe7ffa74] OP - getCmd_d> Enter (proc=0xbe7ffa
ec)
@3,431,673us: [+0 T:0x00004002 S:0xbe7ffa54] ti.sdo.ce.osal.Sem - Entered Sem_pe
@3,431,909us: [+0 T:0x00004000 S:0xbefffaf4] ti.sdo.ce.osal.Sem - Leaving Sem_pe
@3,432,099us: [+0 T:0x00004000 S:0xbefffb14] OP - doCmd> Exit (result=1)
@3,432,249us: [+0 T:0x00004000 S:0xbefffb34] OP - Processor_create> return (0x49
75a8)
@3,432,434us: [+0 T:0x00004000 S:0xbefffb6c] CE - rserverOpen('decodeCombo.x64P'
): 0x5f7a0 done.
@3,432,601us: [+0 T:0x00004000 S:0xbefffb54] OM - Memory_alloc> Enter(0x1a)
@3,432,761us: [+0 T:0x00004000 S:0xbefffb54] OM - Memory_alloc> return (0x497720
@3,432,973us: [+0 T:0x00004000 S:0xbefffb44] OC - Comm_create> Enter(queueName='
@3,433,161us: [+0 T:0x00004000 S:0xbefffb2c] OM - Memory_alloc> Enter(0x4)
@3,433,317us: [+0 T:0x00004000 S:0xbefffb2c] OM - Memory_alloc> return (0x497740
attrs [0x0]
drvObj [0x4976b8]
cmdId [0x6f03]
arg1 [0xbefffb38]
arg2 [0x0]
Status: 8000
@3,434,401us: [+0 T:0x00004000 S:0xbefffb44] OC - Comm_create> return (0x497740)
@3,434,565us: [+0 T:0x00004000 S:0xbefffb44] OM - Memory_free> Enter(0x497720, 0
x1a)
@3,434,764us: [+0 T:0x00004000 S:0xbefffb44] OM - Memory_free> return (0x1)
@3,434,928us: [+0 T:0x00004000 S:0xbefffb4c] OC - Comm_alloc> Enter(poolId=0x0,
poolId [0x0]
size [0x1000]
msg [0x497594]
drvObj [0x4976b8]
cmdId [0x6f08]
arg1 [0xbefffb40]
arg2 [0x0]
poolId [0x0]
bufPtr [0xbefffb4c]
xltFlag [0x2]
Status: 8000
@3,435,811us: [+0 T:0x00004000 S:0xbefffb4c] OC - Comm_alloc> msg=0x4030e880, re
turning (0)
@3,435,975us: [+0 T:0x00004000 S:0xbefffb2c] OC - Comm_locate> Enter(queueName='
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 8000
Leaving MSGQ_locate () status [0x8000]
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 8000
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 8000
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 8000
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 8000
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 8000
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 8000
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 8000
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 8000
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 8000
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 8000
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 8000
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 8000
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 8000
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 8000
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 8000
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 8000
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 8000
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 8000
queueName [0x4eac4]
attrs [0xbefffb6c]
drvObj [0x4976b8]
cmdId [0x6f05]
arg1 [0xbefffb20]
arg2 [0x0]
Status: 8000
@4,121,853us: [+0 T:0x00004000 S:0xbefffb2c] OC - Comm_locate> return (0)
@4,122,011us: [+0 T:0x00004000 S:0xbefffb6c] CE - checkServer(0x497578)
@4,122,176us: [+0 T:0x00004000 S:0xbefffb3c] OC - Comm_put> Enter(queue=0x0, msg
=0x4030e880)
Entered MSGQ_put ()
msgqQueue [0x0]
msg [0x4030e880]
drvObj [0x4976b8]
cmdId [0x6f0a]
arg1 [0xbefffb30]
arg2 [0x0]
poolId [0x0]
bufPtr [0xbefffb38]
xltFlag [0x200]
Status: 8000
Leaving MSGQ_put () status [0x8000]
@4,123,127us: [+0 T:0x00004000 S:0xbefffb3c] OC - Comm_put> return (0)
@4,123,283us: [+0 T:0x00004000 S:0xbefffb34] OC - Comm_get> Enter(queue=0x10000,
msg=0xbefffbb0, timeout=-1)
Entered MSGQ_get ()
msgqQueue [0x10000]
timeout [0xffffffff]
msg [0xbefffbb0]
drvObj [0x4976b8]
cmdId [0x6f0b]
arg1 [0xbefffb28]
arg2 [0x0]
poolId [0x0]
bufPtr [0xbefffb38]
xltFlag [0x2]
Status: 8000
Leaving MSGQ_get () status [0x8000]
@4,124,107us: [+0 T:0x00004000 S:0xbefffb34] OC - Comm_get> MSGQ_Get() status=0x
8000, return (0)
@4,124,280us: [+0 T:0x00004000 S:0xbefffb6c] CE - rmsInit> RMS initialized(0x497
578); CE_DEBUG on, setting DSP trace mask to *+01234567,GT_prefix=12345,GT_time=
3
@4,124,488us: [+0 T:0x00004000 S:0xbefffb3c] CE - Engine_setTrace> Enter(engine=
0x497578, mask='*+01234567,GT_prefix=12345,GT_time=3')
@4,124,689us: [+1 T:0x00004000 S:0xbefffb3c] CE - Engine_setTrace> Requesting DS
P set trace ...
@4,124,843us: [+0 T:0x00004000 S:0xbefffb0c] OC - Comm_put> Enter(queue=0x0, msg
=0x4030e880)
Entered MSGQ_put ()
msgqQueue [0x0]
msg [0x4030e880]
drvObj [0x4976b8]
cmdId [0x6f0a]
arg1 [0xbefffb00]
arg2 [0x0]
poolId [0x0]
bufPtr [0xbefffb08]
xltFlag [0x200]
Status: 8000
@4,125,691us: [+0 T:0x00004000 S:0xbefffb0c] OC - Comm_put> return (0)
@4,125,845us: [+0 T:0x00004000 S:0xbefffb04] OC - Comm_get> Enter(queue=0x10000,
msg=0xbefffb74, timeout=-1)
Entered MSGQ_get ()
msgqQueue [0x10000]
msg [0xbefffb74]
drvObj [0x4976b8]
cmdId [0x6f0b]
arg1 [0xbefffaf8]
arg2 [0x0]
poolId [0x0]
bufPtr [0xbefffb08]
xltFlag [0x2]
Status: 8000
@4,127,320us: [+0 T:0x00004000 S:0xbefffb04] OC - Comm_get> MSGQ_Get() status=0x
8000, return (0)
@4,127,494us: [+0 T:0x00004000 S:0xbefffb3c] CE - Engine_setTrace> return(0)
@4,127,666us: [+0 T:0x00004000 S:0xbefffacc] OC - Comm_put> Enter(queue=0x0, msg
=0x4030e880)
Entered MSGQ_put ()
msgqQueue [0x0]
msg [0x4030e880]
drvObj [0x4976b8]
cmdId [0x6f0a]
arg1 [0xbefffac0]
arg2 [0x0]
poolId [0x0]
bufPtr [0xbefffac8]
xltFlag [0x200]
Status: 8000
@4,128,634us: [+0 T:0x00004000 S:0xbefffacc] OC - Comm_put> return (0)
@4,128,790us: [+0 T:0x00004000 S:0xbefffac4] OC - Comm_get> Enter(queue=0x10000,
msg=0xbefffb58, timeout=-1)
Entered MSGQ_get ()
msgqQueue [0x10000]
msg [0xbefffb58]
drvObj [0x4976b8]
cmdId [0x6f0b]
arg1 [0xbefffab8]
arg2 [0x0]
poolId [0x0]
bufPtr [0xbefffac8]
xltFlag [0x2]
Status: 8000
@4,464,714us: [+0 T:0x00004000 S:0xbefffac4] OC - Comm_get> MSGQ_Get() status=0x
8000, return (0)
[DSP] @0x0000046e:[T:0x00000000] encode_server - main> Welcome to DSP server's m
ain().
[DSP] @1,983,331tk: [+0 T:0x8ba0006c S:0x8ba03fdc] OG - Global_setSpecialTrace>
enter(mask='*+01234567,GT_prefix=12345,GT_time=3')
[DSP] @1,983,431tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - Global_setSpecialTrace>
This program was built with the following packages:
[DSP] @1,983,507tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.targets.r
ts6000 (/root/dvsdk_1_40_00_31/xdc_3_00_06/packages/ti/targets/rts6000/) [1,0,0,
0,1203621186754]
[DSP] @1,983,606tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.sdo.codec
s.mpeg2dec (/root/dvsdk_1_40_00_31/dm6467_dvsdk_combos_1_15/packages/ti/sdo/code
cs/mpeg2dec/) [1,0,0,1270199535000]
[DSP] @1,983,713tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.sdo.fc.ir
es.hdvicp (/root/dvsdk_1_40_00_31/framework_components_2_10_01/packages/ti/sdo/f
c/ires/hdvicp/) [1,0,0,1210822244196]
[DSP] @1,983,821tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.sdo.fc.hd
intc (/root/dvsdk_1_40_00_31/framework_components_2_10_01/packages/ti/sdo/fc/hdi
ntc/) [1,0,3,1210822202314]
[DSP] @1,983,925tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.sdo.utils
.trace (/root/dvsdk_1_40_00_31/framework_components_2_10_01/packages/ti/sdo/util
s/trace/) [1,0,0,1210822330791]
[DSP] @1,984,030tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.sdo.edma3
.rm (/root/dvsdk_1_40_00_31/framework_components_2_10_01/fctools/packages/ti/sdo
/edma3/rm/) [1,3,2,1201524583021]
[DSP] @1,984,137tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.sdo.fc.ir
es.nullresource (/root/dvsdk_1_40_00_31/framework_components_2_10_01/packages/ti
/sdo/fc/ires/nullresource/) [1,0,0,1210822250871]
[DSP] @1,984,251tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.rtdx (/ro
ot/dvsdk_1_40_00_31/bios_5_32_01/packages/ti/rtdx/) [2,0,0,1,1194024051755]
[DSP] @1,984,339tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.psl (/roo
t/dvsdk_1_40_00_31/bios_5_32_01/packages/ti/psl/) [5,0,0,0,0]
[DSP] @1,984,421tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.bios (/ro
ot/dvsdk_1_40_00_31/bios_5_32_01/packages/ti/bios/) [5,2,4,9,1193960176642]
[DSP] @1,984,509tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.sdo.fc.ds
kt2 (/root/dvsdk_1_40_00_31/framework_components_2_10_01/packages/ti/sdo/fc/dskt
2/) [1,0,4,1210822181113]
[DSP] @1,984,612tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.sdo.fc.rm
an (/root/dvsdk_1_40_00_31/framework_components_2_10_01/packages/ti/sdo/fc/rman/
) [2,0,0,1210822263849]
[DSP] @1,984,714tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.sdo.fc.ed
ma3 (/root/dvsdk_1_40_00_31/framework_components_2_10_01/packages/ti/sdo/fc/edma
3/) [2,0,0,1210822195275]
[DSP] @1,984,817tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.sdo.fc.ir
es.edma3chan (/root/dvsdk_1_40_00_31/framework_components_2_10_01/packages/ti/sd
o/fc/ires/edma3chan/) [1,0,0,1210822218054]
[DSP] @1,984,928tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.xdais.dm
(/root/dvsdk_1_40_00_31/xdais_6_10_01/packages/ti/xdais/dm/) [1,0,4,121026274652
9]
[DSP] @1,985,019tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.xdais (/r
oot/dvsdk_1_40_00_31/xdais_6_10_01/packages/ti/xdais/) [1,2,1,1210262742149]
[DSP] @1,985,108tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.sdo.ce.no
de (/root/dvsdk_1_40_00_31/codec_engine_2_10_01/packages/ti/sdo/ce/node/) [1,0,0
,1210912751782]
[DSP] @1,985,215tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.sdo.ce.ip
c.dsplink.dsp (/root/dvsdk_1_40_00_31/codec_engine_2_10_01/packages/ti/sdo/ce/ip
c/dsplink/dsp/) [2,0,1,1210912728971]
[DSP] @1,985,324tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.sdo.ce.ut
ils.xdm (/root/dvsdk_1_40_00_31/codec_engine_2_10_01/packages/ti/sdo/ce/utils/xd
m/) [1,0,1,1210912978675]
[DSP] @1,985,426tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.sdo.fc.dm
an3 (/root/dvsdk_1_40_00_31/framework_components_2_10_01/packages/ti/sdo/fc/dman
3/) [1,0,3,1210822157942]
[DSP] @1,985,529tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.sdo.fc.ac
py3 (/root/dvsdk_1_40_00_31/framework_components_2_10_01/packages/ti/sdo/fc/acpy
3/) [1,0,2,1210822135592]
[DSP] @1,98@4,815,728us: [+0 T:0x00004000 S:0xbefffacc] OC - Comm_put> Enter(que
ue=0x0, msg=0x4030e880)
Entered MSGQ_put ()
msgqQueue [0x0]
msg [0x4030e880]
drvObj [0x4976b8]
cmdId [0x6f0a]
arg1 [0xbefffac0]
arg2 [0x0]
poolId [0x0]
bufPtr [0xbefffac8]
xltFlag [0x200]
Status: 8000
@4,816,732us: [+0 T:0x00004000 S:0xbefffacc] OC - Comm_put> return (0)
@4,816,886us: [+0 T:0x00004000 S:0xbefffac4] OC - Comm_get> Enter(queue=0x10000,
Entered MSGQ_get ()
msgqQueue [0x10000]
msg [0xbefffb58]
drvObj [0x4976b8]
cmdId [0x6f0b]
arg1 [0xbefffab8]
arg2 [0x0]
poolId [0x0]
bufPtr [0xbefffac8]
xltFlag [0x2]
Status: 8000
@4,817,720us: [+0 T:0x00004000 S:0xbefffac4] OC - Comm_get> MSGQ_Get() status=0x
8000, return (0)
5,632tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package dsplink.dsp (/root/dvsd
k_1_40_00_31/dsplink-davinci-v1.50-prebuilt/packages/dsplink/dsp/) [1,3,0]
[DSP] @1,985,725tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.bios.util
s (/root/dvsdk_1_40_00_31/biosutils_1_01_00/packages/ti/bios/utils/) [2,0,1,0,11
91891830609]
[DSP] @1,985,821tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.catalog.c
6000 (/root/dvsdk_1_40_00_31/xdc_3_00_06/packages/ti/catalog/c6000/) [1,0,0,0,12
03561781695]
[DSP] @1,985,917tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.platforms
.evmDM6467 (/root/dvsdk_1_40_00_31/bios_5_32_01/packages/ti/platforms/evmDM6467/
) [1,0,0,0,1192229633217]
[DSP] @1,986,020tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.sdo.ce.os
al (/root/dvsdk_1_40_00_31/codec_engine_2_10_01/packages/ti/sdo/ce/osal/) [2,0,2
,1210912758604]
[DSP] @1,986,117tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.sdo.ce.ip
c (/root/dvsdk_1_40_00_31/codec_engine_2_10_01/packages/ti/sdo/ce/ipc/) [2,0,1,1
210912707081]
[DSP] @1,986,214tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.sdo.ce.al
g (/root/dvsdk_1_40_00_31/codec_engine_2_10_01/packages/ti/sdo/ce/alg/) [1,0,1,1
210912389491]
[DSP] @1,986,311tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.sdo.ce.os
al.bios (/root/dvsdk_1_40_00_31/codec_engine_2_10_01/packages/ti/sdo/ce/osal/bio
s/) [2,0,1,1210912764880]
[DSP] @1,986,414tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.sdo.ce.ip
c.bios (/root/dvsdk_1_40_00_31/codec_engine_2_10_01/packages/ti/sdo/ce/ipc/bios/
) [2,0,1,1210912714040]
[DSP] @1,986,515tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.sdo.ce (/
root/dvsdk_1_40_00_31/codec_engine_2_10_01/packages/ti/sdo/ce/) [1,0,6,121091237
5058]
[DSP] @1,986,608tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.sdo.ce.bi
oslog (/root/dvsdk_1_40_00_31/codec_engine_2_10_01/packages/ti/sdo/ce/bioslog/)
[1,0,1,1210912409169]
[DSP] @1,986,709tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.sdo.ce.vi
deo2 (/root/dvsdk_1_40_00_31/codec_engine_2_10_01/packages/ti/sdo/ce/video2/) [1
,0,2,1210913003946]
[DSP] @1,986,809tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.sdo.codec
s.mpeg2dec.ce (/root/dvsdk_1_40_00_31/dm6467_dvsdk_combos_1_15/packages/ti/sdo/c
odecs/mpeg2dec/ce/) [1,0,0,1270199535000]
[DSP] @1,986,919tk: [+4 T:0x8ba0006c S:0x8ba03fdc] OG - package ti.sdo.serve
rs.decode (/root/dvsdk_1_40_00_31/dm6467_dvsdk_combos_1_15/packages/ti/sdo/serve
rs/decode/) []
[DSP] @1,987,016tk: [+0 T:0x8ba0006c S:0x8ba03fdc] OG - Global_setSpecialTrace>
return
[DSP] @1,991,385tk: [+0 T:0x8ba0006c S:0x8ba04024] CR - processRmsCmd(0x8fe038a8
, 4056): cmd = 5
[DSP] @1,991,455tk: [+0 T:0x8ba0006c S:0x8ba04024] CR - remote time = 0x0, trace
buffer size = 4032
[DSP] @3,950,891tk: [+0 T:0x8ba0006c S:0x8ba04024] CR - processRmsCmd(0x8fe038a8
, 4056): cmd = 5
[DSP] @3,950,964tk: [+0 T:0x8ba0006c S:0x8ba04024] CR - remote time = 0x0, trace
buffer size = 4032
@5,162,741us: [+0 T:0x00004000 S:0xbefffafc] CE - Engine_fwriteTrace> returning
count [7149]
@5,162,942us: [+0 T:0x00004000 S:0xbefffb6c] CE - Engine_open> return(4814200)
@5,163,165us: [+0 T:0x00004000 S:0xbefffbbc] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_
create> Enter (engine=0x497578, name='mpeg2dec', params=0x0)
@5,163,400us: [+0 T:0x00004000 S:0xbefffb8c] CV - VISA_create(0x497578, 'mpeg2de
c', 0x0, 0x2484, 'ti.sdo.ce.video2.IVIDDEC2')
@5,163,594us: [+0 T:0x00004000 S:0xbefffab4] CV - VISA_create2(0x497578, 'mpeg2d
ec', 0x0, 0x0, 0x2484, 'ti.sdo.ce.video2.IVIDDEC2')
@5,163,806us: [+0 T:0x00004000 S:0xbefffa9c] OM - Memory_alloc> Enter(0x30)
@5,163,970us: [+0 T:0x00004000 S:0xbefffa9c] OM - Memory_alloc> return (0x497780
@5,164,131us: [+0 T:0x00004000 S:0xbefffa44] CE - Engine_createNode(0x497578, 'm
peg2dec', 2484, 0x0, 0x0, 0xbefffbb8)
@5,164,310us: [+0 T:0x00004000 S:0xbefffa2c] OM - Memory_alloc> Enter(0x20)
@5,164,468us: [+0 T:0x00004000 S:0xbefffa2c] OM - Memory_alloc> return (0x4977b8
@5,164,638us: [+0 T:0x00004000 S:0xbefffa1c] OC - Comm_create> Enter(queueName='
gppfromnode_1', queue=0x4977c0, attrs=0x0)
@5,164,819us: [+0 T:0x00004000 S:0xbefffa04] OM - Memory_alloc> Enter(0x4)
@5,164,972us: [+0 T:0x00004000 S:0xbefffa04] OM - Memory_alloc> return (0x4977e0
queueName [0xbefffaa0]
msgqQueue [0x4977c0]
attrs [0x0]
drvObj [0x4976b8]
cmdId [0x6f03]
arg1 [0xbefffa10]
arg2 [0x0]
Status: 8000
@5,166,070us: [+0 T:0x00004000 S:0xbefffa1c] OC - Comm_create> return (0x4977e0)
@5,166,240us: [+0 T:0x00004000 S:0xbefffa24] OC - Comm_put> Enter(queue=0x0, msg
=0x4030e880)
Entered MSGQ_put ()
msgqQueue [0x0]
msg [0x4030e880]
drvObj [0x4976b8]
cmdId [0x6f0a]
arg1 [0xbefffa18]
arg2 [0x0]
poolId [0x0]
bufPtr [0xbefffa20]
xltFlag [0x200]
Status: 8000
@5,167,084us: [+0 T:0x00004000 S:0xbefffa24] OC - Comm_put> return (0)
@5,167,235us: [+0 T:0x00004000 S:0xbefffa1c] OC - Comm_get> Enter(queue=0x10000,
msg=0xbefffa9c, timeout=-1)
Entered MSGQ_get ()
msgqQueue [0x10000]
msg [0xbefffa9c]
drvObj [0x4976b8]
cmdId [0x6f0b]
arg1 [0xbefffa10]
arg2 [0x0]
poolId [0x0]
bufPtr [0xbefffa20]
xltFlag [0x2]
Status: 8000
@5,168,801us: [+0 T:0x00004000 S:0xbefffa1c] OC - Comm_get> MSGQ_Get() status=0x
8000, return (0)
@5,168,975us: [+0 T:0x00004000 S:0xbefffa24] OC - Comm_put> Enter(queue=0x0, msg
=0x4030e880)
Entered MSGQ_put ()
msgqQueue [0x0]
msg [0x4030e880]
drvObj [0x4976b8]
cmdId [0x6f0a]
arg1 [0xbefffa18]
arg2 [0x0]
poolId [0x0]
bufPtr [0xbefffa20]
xltFlag [0x200]
Status: 8000
@5,504,378us: [+0 T:0x00004000 S:0xbefffa24] OC - Comm_put> return (0)
@5,504,532us: [+0 T:0x00004000 S:0xbefffa1c] OC - Comm_get> Enter(queue=0x10000,
Entered MSGQ_get ()
msgqQueue [0x10000]
msg [0xbefffa9c]
drvObj [0x4976b8]
cmdId [0x6f0b]
arg1 [0xbefffa10]
arg2 [0x0]
poolId [0x0]
bufPtr [0xbefffa20]
xltFlag [0x2]
Status: 8000
@5,505,364us: [+0 T:0x00004000 S:0xbefffa1c] OC - Comm_get> MSGQ_Get() status=0x
8000, return (0)
@5,505,535us: [+4 T:0x00004000 S:0xbefffa44] CE - Engine_createNode> created nod
e(stdIn=0x2, stdOut=0x10001, msgq=0x4977e0, algName='mpeg2dec', rmsNode=0x8ea004
38, algHandle=0x8ea00520)
@5,505,773us: [+0 T:0x00004000 S:0xbefff9a4] OC - Comm_put> Enter(queue=0x0, msg
=0x4030e880)
Entered MSGQ_put ()
msgqQueue [0x0]
msg [0x4030e880]
drvObj [0x4976b8]
cmdId [0x6f0a]
arg1 [0xbefff998]
arg2 [0x0]
poolId [0x0]
bufPtr [0xbefff9a0]
xltFlag [0x200]
Status: 8000
@5,506,709us: [+0 T:0x00004000 S:0xbefff9a4] OC - Comm_put> return (0)
@5,506,894us: [+0 T:0x00004000 S:0xbefff99c] OC - Comm_get> Enter(queue=0x10000,
msg=0xbefffa30, timeout=-1)
Entered MSGQ_get ()
msgqQueue [0x10000]
msg [0xbefffa30]
drvObj [0x4976b8]
cmdId [0x6f0b]
arg1 [0xbefff990]
arg2 [0x0]
poolId [0x0]
bufPtr [0xbefff9a0]
xltFlag [0x2]
Status: 8000
@5,507,724us: [+0 T:0x00004000 S:0xbefff99c] OC - Comm_get> MSGQ_Get() status=0x
8000, return (0)
[DSP] @4,948,878tk: [+0 T:0x8ba0006c S:0x8ba04024] CR - processRmsCmd(0x8fe038a8
, 4056): cmd = 0
[DSP] @4,948,952tk: [+0 T:0x8ba0006c S:0x8ba03f14] OM - Memory_alloc> Enter(size
=0x18)
[DSP] @4,949,013tk: [+0 T:0x8ba0006c S:0x8ba03f14] OM - Memory_alloc> return (0x
8ea00438)
[DSP] @4,949,075tk: [+0 T:0x8ba0006c S:0x8ba03f14] OM - Memory_alloc> Enter(size
=0xb)
[DSP] @4,949,130tk: [+0 T:0x8ba0006c S:0x8ba03f14] OM - Memory_alloc> return (0x
8ea00450)
[DSP] @4,949,195tk: [+0 T:0x8ba0006c S:0x8ba03edc] OM - Memory_alloc> Enter(size
=0x20)
[DSP] @4,949,252tk: [+0 T:0x8ba0006c S:0x8ba03edc] OM - Memory_alloc> return (0x
8ea00460)
[DSP] @4,949,312tk: [+0 T:0x8ba0006c S:0x8ba03eac] OM - Memory_alloc> Enter(size
=0x24)
[DSP] @4,949,369tk: [+0 T:0x8ba0006c S:0x8ba03eac] OM - Memory_alloc> return (0x
8ea00480)
[DSP] @4,949,456tk: [+0 T:0x8ba0006c S:0x8ba03ec4] ti.sdo.ce.video2.VIDDEC2 - VI
DDEC2_create> Enter (engine=0x0, name='mpeg2dec', params=0x0)
[DSP] @4,949,548tk: [+0 T:0x8ba0006c S:0x8ba03e8c] CV - VISA_create(0x0, 'mpeg2d
ec', 0x0, 0x2484, 'ti.sdo.ce.video2.IVIDDEC2')
[DSP] @4,949,632tk: [+0 T:0x8ba0006c S:0x8ba03d7c] CV - VISA_create2(0x0, 'mpeg2
dec', 0x0, 0x0, 0x2484, 'ti.sdo.ce.video2.IVIDDEC2')
[DSP] @4,949,724tk: [+0 T:0x8ba0006c S:0x8ba03d14] CE - Engine_open> Enter('loca
l', 0x8ba03d6c, 0x9b4)
[DSP] @4,949,793tk: [+0 T:0x8ba0006c S:0x8ba03cf4] OM - Memory_alloc> Enter(size
=0x2c)
[DSP] @4,949,850tk: [+0 T:0x8ba0006c S:0x8ba03cf4] OM - Memory_alloc> return (0x
8ea004f0)
[DSP] @4,949,916tk: [+0 T:0x8ba0006c S:0x8ba03d14] CE - Engine_open> return(-190
2115600)
[DSP] @4,949,986tk: [+0 T:0x8ba0006c S:0x8ba03d5c] OM - Memory_alloc> Enter(size
=0x30)
[DSP] @4,950,042tk: [+0 T:0x8ba0006c S:0x8ba03d5c] OM - Memory_alloc> return (0x
8ea00520)
[DSP] @4,950,105tk: [+0 T:0x8ba0006c S:0x8ba03d34] ti.sdo.ce.alg.Algorithm - Alg
orithm_create> Enter(fxns=0x8eba84a8, idma3Fxns=0x0, params=0x0, attrs=0x8ba03e8
0)
[DSP] @4,950,204tk: [+0 T:0x8ba0006c S:0x8ba03d14] OM - Memory_alloc> Enter(size
=0x10)
[DSP] @4,950,261tk: [+0 T:0x8ba0006c S:0x8ba03d14] OM - Memory_alloc> return (0x
8ea00550)
[DSP] @4,950,340tk: [+0 T:0x8ba0006c S:0x8ba03cf4] ti.sdo.fc.dskt2 - _DSKT2_init
> Enter
[DSP] @4,950,422tk: [+0 T:0x8ba0006c S:0x8ba03cf4] ti.sdo.fc.dskt2 - _DSKT2_init
> Exit
[DSP] @4,950,477tk: [+0 T:0x8ba0006c S:0x8ba03d04] ti.sdo.fc.dskt2 - DSKT2_creat
eAlg> Enter (scratchId=2, fxns=0x8eba84a8, parentAlg=0x0, params=0x0)
[DSP] @4,950,599tk: [+0 T:0x8ba0006c S:0x8ba03c8c] ti.sdo.fc.dskt2 - _DSKT2_init
> Enter
[DSP] @4,950,654tk: [+0 T:0x8ba0006c S:0x8ba03c8c] ti.sdo.fc.dskt2 - _DSKT2_init
> Exit
[DSP] @4,950,709tk: [+0 T:0x8ba0006c S:0x8ba03c9c] ti.sdo.fc.dskt2 - DSKT2_creat
eAlg3> Enter (scratchId=2, fxns=0x8eba84a8, parentAlg=0x0, params=0x0, extHeapId
=0, singleHeap=2)
[DSP] @4,950,815tk: [+2 T:0x8ba0006c S:0x8ba03c9c] ti.sdo.fc.dskt2 - DSKT2_creat
eAlg3> DSKT2_AlgAttrs extHeapId -1 and singleHeap 0
[DSP] @4,950,901tk: [+2 T:0x8ba0006c S:0x8ba03c9c] ti.sdo.fc.dskt2 - DSKT2_creat
eAlg3> AlgNumAlloc not implemented
[DSP] @4,950,973tk: [+2 T:0x8ba0006c S:0x8ba03c9c] ti.sdo.fc.dskt2 - DSKT2_creat
eAlg3> memTab allocated at 0x8ea008f0 size=0x50
[DSP] @4,951,053tk: [+2 T:0x8ba0006c S:0x8ba03c9c] ti.sdo.fc.dskt2 - DSKT2_creat
eAlg3> Num memory recs requested 1
[DSP] @4,951,126tk: [+4 T:0x8ba0006c S:0x8ba03c9c] ti.sdo.fc.dskt2 - DSKT2_creat
eAlg3> Requested memTab[0]: size=0x8, align=0x0, space=IALG_EXTERNAL, attrs=IALG
_PERSIST
[DSP] @4,951,227tk: [+0 T:0x8ba0006c S:0x8ba03c5c] ti.sdo.fc.dskt2 - _DSKT2_assi
gnInstanceMemory> Enter (scratchId=2, numRecs=1, extHeapId=0)
[DSP] @4,951,312tk: [+0 T:0x8ba0006c S:0x8ba03c3c] ti.sdo.fc.dskt2 - _DSKT2_uses
InternalScratch> Enter (numRecs=1)
[DSP] @4,951,382tk: [+0 T:0x8ba0006c S:0x8ba03c3c] ti.sdo.fc.dskt2 - _DSKT2_uses
InternalScratch> Exit (returnVal=0)
[DSP] @4,951,457tk: [+0 T:0x8ba0006c S:0x8ba03c1c] ti.sdo.fc.dskt2 - _DSKT2_allo
cateInDesignatedSpace> Enter (index=0, ialgSpace=IALG_EXTERNAL, extHeapId=0)
[DSP] @4,951,550tk: [+0 T:0x8ba0006c S:0x8ba03c1c] ti.sdo.fc.dskt2 - _DSKT2_allo
cateInDesignatedSpace> Exit (returnVal=1)
[DSP] @4,951,623tk: [+2 T:0x8ba0006c S:0x8ba03c5c] ti.sdo.fc.dskt2 - _DSKT2_assi
gnInstanceMemory> memTab[0] allocated in persistent memory in Memory space:IALG_
EXTERNAL. Addr=0x8b@5,859,569us: [+0 T:0x00004000 S:0xbefff9a4] OC - Comm_put> E
nter(queue=0x0, msg=0x4030e880)
Entered MSGQ_put ()
msgqQueue [0x0]
msg [0x4030e880]
drvObj [0x4976b8]
cmdId [0x6f0a]
arg1 [0xbefff998]
arg2 [0x0]
poolId [0x0]
bufPtr [0xbefff9a0]
xltFlag [0x200]
Status: 8000
@5,860,712us: [+0 T:0x00004000 S:0xbefff9a4] OC - Comm_put> return (0)
@5,860,866us: [+0 T:0x00004000 S:0xbefff99c] OC - Comm_get> Enter(queue=0x10000,
Entered MSGQ_get ()
msgqQueue [0x10000]
msg [0xbefffa30]
drvObj [0x4976b8]
cmdId [0x6f0b]
arg1 [0xbefff990]
arg2 [0x0]
poolId [0x0]
bufPtr [0xbefff9a0]
xltFlag [0x2]
Status: 8000
@5,861,699us: [+0 T:0x00004000 S:0xbefff99c] OC - Comm_get> MSGQ_Get() status=0x
8000, return (0)
a141e8
[DSP] @4,951,731tk: [+0 T:0x8ba0006c S:0x8ba03c3c] ti.sdo.fc.dskt2 - _DSKT2_uses
[DSP] @4,951,800tk: [+0 T:0x8ba0006c S:0x8ba03c3c] ti.sdo.fc.dskt2 - _DSKT2_uses
[DSP] @4,951,869tk: [+0 T:0x8ba0006c S:0x8ba03c5c] ti.sdo.fc.dskt2 - _DSKT2_assi
gnInstanceMemory> Exit (returnVal=1)
[DSP] @4,951,940tk: [+4 T:0x8ba0006c S:0x8ba03c9c] ti.sdo.fc.dskt2 - DSKT2_creat
eAlg3> Allocated memTab[0]: base=0x8ba141e8, size=0x8, align=0x0, space=IALG_EXT
ERNAL, attrs=IALG_PERSIST
[DSP] @4,952,052tk: [+0 T:0x8ba0006c S:0x8ba03c64] ti.sdo.fc.dskt2 - _DSKT2_enqu
eueMemTab> Enter (segId=1, memTabSize=80, numRecs=1, extHeapId=0)
[DSP] @4,952,144tk: [+0 T:0x8ba0006c S:0x8ba03c64] ti.sdo.fc.dskt2 - _DSKT2_enqu
eueMemTab> Exit (status=TRUE)
[DSP] @4,952,216tk: [+4 T:0x8ba0006c S:0x8ba03c9c] ti.sdo.fc.dskt2 - DSKT2_creat
eAlg3> Algorithm init successful.
[DSP] @4,952,284tk: [+0 T:0x8ba0006c S:0x8ba03c9c] ti.sdo.fc.dskt2 - DSKT2_creat
eAlg3> Exit (algHandle=0x8ba141e8)
[DSP] @4,952,355tk: [+0 T:0x8ba0006c S:0x8ba03d04] ti.sdo.fc.dskt2 - DSKT2_creat
eAlg> Exit (algHandle=0x8ba141e8)
[DSP] @4,952,429tk: [+0 T:0x8ba0006c S:0x8ba03d34] ti.sdo.ce.alg.Algorithm - Alg
orithm_create> return (0x8ea00550)
[DSP] @4,952,506tk: [+0 T:0x8ba0006c S:0x8ba03ec4] ti.sdo.ce.video2.VIDDEC2 - VI
DDEC2_create> return (0x8ea00520)
[DSP] @4,952,581tk: [+4 T:0x8ba0006c S:0x8ba03e84] OT - Thread_create > name: "m
peg2dec#0", pri: -1, stack size: 10240, stack seg: 0
[DSP] @5,909,043tk: [+0 T:0x8ba0006c S:0x8ba04024] CR - processRmsCmd(0x8fe038a8
, 4056): cmd = 1
[DSP] @5,915,710tk: [+0 T:0x8ba0006c S:0x8ba04024] CR - processRmsCmd(0x8fe038a8
, 4056): cmd = 5
[DSP] @5,915,779tk: [+0 T:0x8ba0006c S:0x8ba04024] CR - remote time = 0x0, trace
buffer size = 4032
[DSP] @6,923,782tk: [+0 T:0x8ba0006c S:0x8ba04024] CR - processRmsCmd(0x8fe038a8
, 4056): cmd = 5
[DSP] @6,923,851tk: [+0 T:0x8ba0006c S:0x8ba04024] CR - remote time = 0x0, trace
buffer size = 4032
@6,203,078us: [+0 T:0x00004000 S:0xbefff9d4] CE - Engine_fwriteTrace> returning
count [6255]
@6,203,262us: [+2 T:0x00004000 S:0xbefffa44] CE - Engine_createNode> Returning 0
x4977b8
@6,203,425us: [+0 T:0x00004000 S:0xbefffa9c] OM - Memory_alloc> Enter(0x4)
@6,203,583us: [+0 T:0x00004000 S:0xbefffa9c] OM - Memory_alloc> return (0x4977f0
@6,203,739us: [+0 T:0x00004000 S:0xbefffa94] OC - Comm_alloc> Enter(poolId=0x0,
msg=0x4977f0, size=2484)
poolId [0x0]
size [0x1000]
msg [0x4977f0]
drvObj [0x4976b8]
cmdId [0x6f08]
arg1 [0xbefffa88]
arg2 [0x0]
poolId [0x0]
bufPtr [0xbefffa94]
xltFlag [0x2]
Status: 8000
Leaving DRV_Invoke () status [0x8000]
@6,204,586us: [+0 T:0x00004000 S:0xbefffa94] OC - Comm_alloc> msg=0x4030f880, re
turning (0)
@6,204,767us: [+5 T:0x00004000 S:0xbefffab4] CV - VISA_create> remote codec crea
ted (name='mpeg2dec', localQueueID=0x10001, remoteQueueID=0x0002)
@6,204,969us: [+0 T:0x00004000 S:0xbefffbbc] ti.sdo.ce.video2.VIDDEC2 - VIDDEC2_
create> return (0x497780)
the flag_engine_ok is 1
how can I solve the problem? Is there anyone to help me ? Thanks a lots.
