TDA4M: PSDKLA Linux v1.0 Problems With First Time Builds...
TWIMC,
There are errors in my first time rootfs builds for the v1.0 PSDKLA per below how can I solve these build issues?
ERROR: Task (/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/sources/meta-qt5/recipes-qt/qt5/qtbase_git.bb:do_compile) failed with exit code '1'
A more complete error only log...
tshelbur @ ubun18win10-2 : 192.168.0.146 : /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build:TOOLCHAIN_BASE=$HOME MACHINE=j7-evm bitbake -k tisdk-rootfs-image > ./errors.txt
ERROR: qtbase-5.11.3+gitAUTOINC+08de243eaa-r0.arago16 do_compile: oe_runmake failed
ERROR: qtbase-5.11.3+gitAUTOINC+08de243eaa-r0.arago16 do_compile: Function failed: do_compile (log file is located at /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/temp/log.do_compile.6504)
ERROR: Logfile of failure stored in: /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/temp/log.do_compile.6504
    can you check your configuration if you are working behind a proxy:
    there was a similar thread and the issue was found to be that the user was needed VPN to access qtbase:
    Yordan
  • I am not running behind a proxy, I am using a dedicated Ubuntu 18.04 LTS laptop on my home internet connection with no proxy. All other build steps have built properly but there are two errors out of 7k-8k build steps that remain.
    This looks like a failure in the open source component qtbase
    Please share the logfile mentioned in the above path.
    We can get details of the failure using that.
    Nikhil D
  • Tom
    Have you been able to verify with component level re-build (For kernel, uboot,..) and the pre-built filesystem.
    Unless there is clear cut need for modifying the root filesystem, would suggest a workflow, where you can modify and rebuild kernel, bootloader but use the pre-built filesystem as is.
    To enable this,we added shallow copy of the source code for kernel, bootloader in the release package and also Makefile based component level builds(you can refer the Userguide  "1.1.5. Top-Level Makefile")
    If you have a clear cut need to rebuild the Filesystem, can we check if the failure is transient due to failed repo fetch - have you tried rerunning the build
  • Please provide instructions for the component level build...
    Attached is the log file associated with the error you requested. Of course he E2E system throws errors and won't let me attach the log file so I will include the text below:
    DEBUG: Executing shell function do_compile
    NOTE: make -j 3 MAKEFLAGS=-j 3 OE_QMAKE_COMPILER=aarch64-linux-gnu-gcc --sysroot=/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot OE_QMAKE_CC=aarch64-linux-gnu-gcc --sysroot=/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot OE_QMAKE_CXX=aarch64-linux-gnu-g++ --sysroot=/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot OE_QMAKE_CFLAGS= -isystem/home/tshelbur/gcc-arm-8.3-2019.03-x86_64-aarch64-linux-gnu/aarch64-linux-gnu/include -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16=/usr/src/debug/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16 -fdebug-prefix-map=/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot= -fdebug-prefix-map=/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native= OE_QMAKE_CXXFLAGS= -isystem/home/tshelbur/gcc-arm-8.3-2019.03-x86_64-aarch64-linux-gnu/aarch64-linux-gnu/include -O2 -pipe -g -feliminate-unused-debug-types -fdebug-prefix-map=/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16=/usr/src/debug/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16 -fdebug-prefix-map=/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot= -fdebug-prefix-map=/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native= OE_QMAKE_LINK=aarch64-linux-gnu-g++ --sysroot=/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot OE_QMAKE_LDFLAGS= -L/home/tshelbur/gcc-arm-8.3-2019.03-x86_64-aarch64-linux-gnu/aarch64-linux-gnu/lib -Wl,-rpath-link,/home/tshelbur/gcc-arm-8.3-2019.03-x86_64-aarch64-linux-gnu/aarch64-linux-gnu/lib -Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed OE_QMAKE_AR=aarch64-linux-gnu-ar OE_QMAKE_STRIP=echo OE_QMAKE_INCDIR_QT=/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot//usr/include
    cd src/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/src.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qmake/ && ( test -e Makefile.qmake-aux || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile.qmake-aux /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/qmake/qmake-aux.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile.qmake-aux
    cd doc/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/doc/doc.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[1]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/doc'
    make[1]: Nothing to be done for 'first'.
    make[1]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/doc'
    make[1]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/qmake'
    make binary
    make[1]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src'
    cd corelib/ && ( test -e Makefile.qtzlib || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile.qtzlib /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/corelib/qtzlib.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile.qtzlib
    cd 3rdparty/pcre2/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/3rdparty/pcre2/pcre2.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/qmake'
    cd tools/bootstrap/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/tools/bootstrap/bootstrap.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[2]: Nothing to be done for 'binary'.
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/qmake'
    make[1]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/qmake'
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/corelib'
    make[2]: Nothing to be done for 'first'.
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/corelib'
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/3rdparty/pcre2'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/3rdparty/pcre2'
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/tools/bootstrap'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/tools/bootstrap'
    cd tools/moc/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/tools/moc/moc.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd tools/qfloat16-tables/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/tools/qfloat16-tables/qfloat16-tables.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd tools/rcc/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/tools/rcc/rcc.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/tools/qfloat16-tables'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/tools/qfloat16-tables'
    cd tools/qlalr/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/tools/qlalr/qlalr.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/tools/rcc'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/tools/rcc'
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/tools/moc'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/tools/moc'
    cd tools/uic/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/tools/uic/uic.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd tools/qvkgen/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/tools/qvkgen/qvkgen.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/tools/qvkgen'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/tools/qvkgen'
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/tools/qlalr'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/tools/qlalr'
    cd tools/bootstrap-dbus/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/tools/bootstrap-dbus/bootstrap-dbus.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd corelib/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/corelib/corelib.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/tools/uic'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/tools/uic'
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/tools/bootstrap-dbus'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/tools/bootstrap-dbus'
    cd tools/qdbusxml2cpp/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/tools/qdbusxml2cpp/qdbusxml2cpp.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd tools/qdbuscpp2xml/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/tools/qdbuscpp2xml/qdbuscpp2xml.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/tools/qdbusxml2cpp'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/tools/qdbusxml2cpp'
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/tools/qdbuscpp2xml'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/tools/qdbuscpp2xml'
    cd network/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/network/network.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd xml/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/xml/xml.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd sql/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/sql/sql.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/xml'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/xml'
    cd 3rdparty/harfbuzz-ng/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/3rdparty/harfbuzz-ng/harfbuzz-ng.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/sql'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/sql'
    cd dbus/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/dbus/dbus.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/3rdparty/harfbuzz-ng'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/3rdparty/harfbuzz-ng'
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/dbus'
    cd concurrent/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/concurrent/concurrent.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/dbus'
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/network'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/network'
    cd gui/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/gui/gui.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/concurrent'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/concurrent'
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/gui'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/gui'
    cd platformheaders/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/platformheaders/platformheaders.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd openglextensions/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/openglextensions/openglextensions.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformheaders'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformheaders'
    cd widgets/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/widgets/widgets.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd platformsupport/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/platformsupport/platformsupport.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/openglextensions'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/openglextensions'
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformsupport'
    cd edid/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/platformsupport/edid/edid.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd eventdispatchers/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/platformsupport/eventdispatchers/eventdispatchers.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformsupport/edid'
    make[3]: Nothing to be done for 'first'.
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformsupport/edid'
    cd devicediscovery/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/platformsupport/devicediscovery/devicediscovery.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformsupport/eventdispatchers'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformsupport/eventdispatchers'
    cd fbconvenience/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/platformsupport/fbconvenience/fbconvenience.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformsupport/devicediscovery'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformsupport/devicediscovery'
    cd themes/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/platformsupport/themes/themes.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformsupport/fbconvenience'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformsupport/fbconvenience'
    cd fontdatabases/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/platformsupport/fontdatabases/fontdatabases.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformsupport/fontdatabases'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformsupport/fontdatabases'
    cd input/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/platformsupport/input/input.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformsupport/themes'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformsupport/themes'
    cd services/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/platformsupport/services/services.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformsupport/services'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformsupport/services'
    cd platformcompositor/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/platformsupport/platformcompositor/platformcompositor.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformsupport/input'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformsupport/input'
    cd eglconvenience/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/platformsupport/eglconvenience/eglconvenience.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformsupport/platformcompositor'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformsupport/platformcompositor'
    cd kmsconvenience/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/platformsupport/kmsconvenience/kmsconvenience.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformsupport/eglconvenience'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformsupport/eglconvenience'
    cd accessibility/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/platformsupport/accessibility/accessibility.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformsupport/kmsconvenience'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformsupport/kmsconvenience'
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformsupport/accessibility'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformsupport/accessibility'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/platformsupport'
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/widgets'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/widgets'
    cd testlib/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/testlib/testlib.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd opengl/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/opengl/opengl.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd printsupport/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/printsupport/printsupport.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/testlib'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/testlib'
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/opengl'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/opengl'
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/printsupport'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/printsupport'
    cd plugins/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/plugins.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins'
    cd sqldrivers/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/sqldrivers/sqldrivers.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd platforms/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/platforms/platforms.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd bearer/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/bearer/bearer.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/bearer'
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforms'
    cd generic/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/bearer/generic/generic.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd minimal/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/platforms/minimal/minimal.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/sqldrivers'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/sqldrivers'
    cd offscreen/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/platforms/offscreen/offscreen.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/bearer/generic'
    make[4]: Nothing to be done for 'first'.
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/bearer/generic'
    cd connman/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/bearer/connman/connman.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforms/minimal'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforms/minimal'
    cd networkmanager/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/bearer/networkmanager/networkmanager.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforms/offscreen'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforms/offscreen'
    cd eglfs/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/platforms/eglfs/eglfs.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/bearer/connman'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/bearer/connman'
    cd minimalegl/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/platforms/minimalegl/minimalegl.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/bearer/networkmanager'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/bearer/networkmanager'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforms/eglfs'
    ( test -e Makefile.eglfsdeviceintegration || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile.eglfsdeviceintegration /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/platforms/eglfs/eglfsdeviceintegration.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile.eglfsdeviceintegration
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/bearer'
    cd linuxfb/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/platforms/linuxfb/linuxfb.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforms/minimalegl'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforms/minimalegl'
    cd vnc/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/platforms/vnc/vnc.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforms/linuxfb'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforms/linuxfb'
    cd platforminputcontexts/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/platforminputcontexts/platforminputcontexts.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforms/eglfs'
    make[5]: Nothing to be done for 'first'.
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforms/eglfs'
    ( test -e Makefile.eglfs-plugin || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile.eglfs-plugin /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/platforms/eglfs/eglfs-plugin.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile.eglfs-plugin
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforminputcontexts'
    cd ibus/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/platforminputcontexts/ibus/ibus.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd deviceintegration/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/platforms/eglfs/deviceintegration/deviceintegration.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforms/vnc'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforms/vnc'
    cd platformthemes/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/platformthemes/platformthemes.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforms/eglfs/deviceintegration'
    cd eglfs_kms_support/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/platforms/eglfs/deviceintegration/eglfs_kms_support/eglfs_kms_support.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platformthemes'
    cd flatpak/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/platformthemes/flatpak/flatpak.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforminputcontexts/ibus'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforminputcontexts/ibus'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforminputcontexts'
    cd imageformats/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/imageformats/imageformats.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/imageformats'
    cd jpeg/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/imageformats/jpeg/jpeg.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforms/eglfs/deviceintegration/eglfs_kms_support'
    make[6]: Nothing to be done for 'first'.
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforms/eglfs/deviceintegration/eglfs_kms_support'
    cd eglfs_emu/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/platforms/eglfs/deviceintegration/eglfs_emu/eglfs_emu.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platformthemes/flatpak'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platformthemes/flatpak'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platformthemes'
    cd generic/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/generic/generic.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/imageformats/jpeg'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/imageformats/jpeg'
    cd gif/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/imageformats/gif/gif.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/generic'
    cd evdevmouse/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/generic/evdevmouse/evdevmouse.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforms/eglfs/deviceintegration/eglfs_emu'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforms/eglfs/deviceintegration/eglfs_emu'
    cd eglfs_kms/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/platforms/eglfs/deviceintegration/eglfs_kms/eglfs_kms.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/imageformats/gif'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/imageformats/gif'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/imageformats'
    cd styles/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/styles/styles.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/generic/evdevmouse'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/generic/evdevmouse'
    cd evdevtouch/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/generic/evdevtouch/evdevtouch.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/styles'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/styles'
    cd printsupport/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/printsupport/printsupport.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforms/eglfs/deviceintegration/eglfs_kms'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforms/eglfs/deviceintegration/eglfs_kms'
    cd eglfs_kms_egldevice/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/platforms/eglfs/deviceintegration/eglfs_kms_egldevice/eglfs_kms_egldevice.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/generic/evdevtouch'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/generic/evdevtouch'
    cd evdevkeyboard/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/generic/evdevkeyboard/evdevkeyboard.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/printsupport'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/printsupport'
    cd evdevtablet/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/generic/evdevtablet/evdevtablet.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/generic/evdevkeyboard'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/generic/evdevkeyboard'
    cd tuiotouch/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/generic/tuiotouch/tuiotouch.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforms/eglfs/deviceintegration/eglfs_kms_egldevice'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforms/eglfs/deviceintegration/eglfs_kms_egldevice'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforms/eglfs/deviceintegration'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforms/eglfs'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/platforms'
    cd libinput/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/src/plugins/generic/libinput/libinput.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/generic/evdevtablet'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/generic/evdevtablet'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/generic/libinput'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/generic/libinput'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/generic/tuiotouch'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/generic/tuiotouch'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins/generic'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src/plugins'
    make[1]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/src'
    cd examples/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/examples.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd tests/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/tests.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[1]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests'
    make[1]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples'
    cd benchmarks/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/benchmarks.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd auto/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/auto.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qpa/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/qpa/qpa.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd embedded/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/embedded/embedded.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd corelib/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/corelib/corelib.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks'
    cd corelib/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/corelib.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib'
    cd sql/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/sql/sql.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd ipc/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/corelib/ipc/ipc.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto'
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/embedded'
    Some of the required modules (if(embedded|x11):qtHaveModule(gui)) are not available.
    Skipped.
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/embedded'
    cd touch/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/touch/touch.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd corelib/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/corelib.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib'
    cd io/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/io/io.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qpa'
    cd windows/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/qpa/windows/windows.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/sql'
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib'
    cd kernel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/sql/kernel/kernel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/ipc'
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/touch'
    cd kernel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/kernel/kernel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd sharedmemory/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/corelib/ipc/sharedmemory/sharedmemory.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd pinchzoom/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/touch/pinchzoom/pinchzoom.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/io'
    cd qdir/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/io/qdir/qdir.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qpa/windows'
    make[3]: Nothing to be done for 'first'.
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qpa/windows'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/sql/kernel'
    cd qrasterwindow/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/qpa/qrasterwindow/qrasterwindow.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qsqlquery/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/sql/kernel/qsqlquery/qsqlquery.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/touch/pinchzoom'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/touch/pinchzoom'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel'
    cd fingerpaint/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/touch/fingerpaint/fingerpaint.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/ipc/sharedmemory'
    make[4]: Nothing to be done for 'first'.
    cd qcoreapplication/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/kernel/qcoreapplication/qcoreapplication.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/ipc/sharedmemory'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/io/qdir'
    cd localfortuneserver/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/corelib/ipc/localfortuneserver/localfortuneserver.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd 10000/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/io/qdir/10000/10000.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qpa/qrasterwindow'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/ipc/localfortuneserver'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/ipc/localfortuneserver'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qpa/qrasterwindow'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qpa'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qcoreapplication'
    Some of the required modules (qtConfig(private_tests)) are not available.
    cd dbus/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/dbus/dbus.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    Skipped.
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qcoreapplication'
    cd localfortuneclient/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/corelib/ipc/localfortuneclient/localfortuneclient.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qdeadlinetimer/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/kernel/qdeadlinetimer/qdeadlinetimer.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/touch/fingerpaint'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/touch/fingerpaint'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/sql/kernel/qsqlquery'
    make[5]: Nothing to be done for 'first'.
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/sql/kernel/qsqlquery'
    cd knobs/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/touch/knobs/knobs.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qsqlrecord/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/sql/kernel/qsqlrecord/qsqlrecord.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/io/qdir/10000'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/io/qdir/10000'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/io/qdir'
    cd qdiriterator/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/io/qdiriterator/qdiriterator.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/dbus'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/ipc/localfortuneclient'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/ipc/localfortuneclient'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/ipc'
    cd listnames/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/dbus/listnames/listnames.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd mimetypes/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/corelib/mimetypes/mimetypes.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/mimetypes'
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/touch/knobs'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/touch/knobs'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qdeadlinetimer'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qdeadlinetimer'
    cd mimetypebrowser/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/corelib/mimetypes/mimetypebrowser/mimetypebrowser.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd dials/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/touch/dials/dials.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qelapsedtimer/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/kernel/qelapsedtimer/qelapsedtimer.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/dbus/listnames'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/dbus/listnames'
    cd pingpong/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/dbus/pingpong/pingpong.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/sql/kernel/qsqlrecord'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/sql/kernel/qsqlrecord'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/sql/kernel'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/sql'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/io/qdiriterator'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/io/qdiriterator'
    cd qeventdispatcher/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/kernel/qeventdispatcher/qeventdispatcher.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qfile/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/io/qfile/qfile.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/touch/dials'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/touch/dials'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/touch'
    cd network/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/network/network.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/dbus/pingpong'
    ( test -e Makefile.ping || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile.ping /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/dbus/pingpong/ping.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile.ping
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qelapsedtimer'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qelapsedtimer'
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network'
    cd download/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/network/download/download.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qfileinfo/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/io/qfileinfo/qfileinfo.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/mimetypes/mimetypebrowser'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/mimetypes/mimetypebrowser'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/mimetypes'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/io/qfile'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/io/qfile'
    cd qiodevice/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/io/qiodevice/qiodevice.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd serialization/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/corelib/serialization/serialization.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qeventdispatcher'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qeventdispatcher'
    cd qeventloop/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/kernel/qeventloop/qeventloop.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/dbus/pingpong'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/dbus/pingpong'
    ( test -e Makefile.pong || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile.pong /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/dbus/pingpong/pong.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile.pong
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/download'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/download'
    cd downloadmanager/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/network/downloadmanager/downloadmanager.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/serialization'
    cd savegame/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/corelib/serialization/savegame/savegame.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/dbus/pingpong'
    cd complexpingpong/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/dbus/complexpingpong/complexpingpong.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/io/qiodevice'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/io/qiodevice'
    cd qtemporaryfile/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/io/qtemporaryfile/qtemporaryfile.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/io/qfileinfo'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/io/qfileinfo'
    cd qtextstream/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/io/qtextstream/qtextstream.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qeventloop'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qeventloop'
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/downloadmanager'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/downloadmanager'
    cd qmath/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/kernel/qmath/qmath.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd dnslookup/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/network/dnslookup/dnslookup.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/dbus/complexpingpong'
    ( test -e Makefile.complexping || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile.complexping /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/dbus/complexpingpong/complexping.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile.complexping
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/serialization/savegame'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/serialization/savegame'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/serialization'
    cd threads/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/corelib/threads/threads.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/dnslookup'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/dnslookup'
    cd blockingfortuneclient/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/network/blockingfortuneclient/blockingfortuneclient.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/io/qtemporaryfile'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/io/qtextstream'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/io/qtextstream'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/io/qtemporaryfile'
    cd qprocess/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/io/qprocess/qprocess.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd dbus/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/dbus/dbus.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/threads'
    cd semaphores/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/corelib/threads/semaphores/semaphores.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/dbus/complexpingpong'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/dbus/complexpingpong'
    ( test -e Makefile.complexpong || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile.complexpong /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/dbus/complexpingpong/complexpong.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile.complexpong
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qmath'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qmath'
    cd qmetaobject/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/kernel/qmetaobject/qmetaobject.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/blockingfortuneclient'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/blockingfortuneclient'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/io/qprocess'
    cd broadcastreceiver/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/network/broadcastreceiver/broadcastreceiver.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd testProcessLoopback/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/io/qprocess/testProcessLoopback/testProcessLoopback.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/threads/semaphores'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/threads/semaphores'
    cd waitconditions/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/corelib/threads/waitconditions/waitconditions.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/dbus'
    cd qdbustype/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/dbus/qdbustype/qdbustype.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/io/qprocess/testProcessLoopback'
    make[6]: Nothing to be done for 'first'.
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/io/qprocess/testProcessLoopback'
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/broadcastreceiver'
    make[3]: Nothing to be done for 'first'.
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/broadcastreceiver'
    cd broadcastsender/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/network/broadcastsender/broadcastsender.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd test/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/io/qprocess/test/test.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Nothing to be done for 'first'.
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/dbus/complexpingpong'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qmetaobject'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qmetaobject'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/threads/waitconditions'
    cd chat/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/dbus/chat/chat.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/threads/waitconditions'
    cd mandelbrot/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/corelib/threads/mandelbrot/mandelbrot.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qmetaobjectbuilder/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/kernel/qmetaobjectbuilder/qmetaobjectbuilder.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/broadcastsender'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/broadcastsender'
    cd http/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/network/http/http.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/threads/mandelbrot'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/threads/mandelbrot'
    cd queuedcustomtype/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/corelib/threads/queuedcustomtype/queuedcustomtype.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/dbus/qdbustype'
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/io/qprocess/test'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/io/qprocess/test'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/io/qprocess'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/io'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/dbus/qdbustype'
    cd json/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/json/json.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/http'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/http'
    cd qdbusperformance/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/dbus/qdbusperformance/qdbusperformance.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/dbus/chat'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/dbus/chat'
    cd loopback/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/network/loopback/loopback.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd remotecontrolledcar/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/dbus/remotecontrolledcar/remotecontrolledcar.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qmetaobjectbuilder'
    make[5]: Nothing to be done for 'first'.
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qmetaobjectbuilder'
    cd qmetamethod/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/kernel/qmetamethod/qmetamethod.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/dbus/qdbusperformance'
    cd server/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/dbus/qdbusperformance/server/server.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/threads/queuedcustomtype'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/threads/queuedcustomtype'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/threads'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qmetamethod'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qmetamethod'
    cd tools/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/corelib/tools/tools.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qmetaproperty/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/kernel/qmetaproperty/qmetaproperty.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/json'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/json'
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/dbus/remotecontrolledcar'
    cd mimetypes/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/mimetypes/mimetypes.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd car/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/dbus/remotecontrolledcar/car/car.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/tools'
    cd contiguouscache/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/corelib/tools/contiguouscache/contiguouscache.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/dbus/qdbusperformance/server'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/dbus/qdbusperformance/server'
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/loopback'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/loopback'
    cd test/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/dbus/qdbusperformance/test/test.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd threadedfortuneserver/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/network/threadedfortuneserver/threadedfortuneserver.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/tools/contiguouscache'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/tools/contiguouscache'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/mimetypes'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qmetaproperty'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qmetaproperty'
    cd customtype/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/corelib/tools/customtype/customtype.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qmetatype/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/kernel/qmetatype/qmetatype.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qmimedatabase/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/mimetypes/qmimedatabase/qmimedatabase.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/dbus/remotecontrolledcar/car'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/dbus/remotecontrolledcar/car'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/dbus/qdbusperformance/test'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/dbus/qdbusperformance/test'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/dbus/qdbusperformance'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/dbus'
    cd controller/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/dbus/remotecontrolledcar/controller/controller.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qmetaenum/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/kernel/qmetaenum/qmetaenum.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/threadedfortuneserver'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/threadedfortuneserver'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/tools/customtype'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/tools/customtype'
    cd googlesuggest/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/network/googlesuggest/googlesuggest.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd customtypesending/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/corelib/tools/customtypesending/customtypesending.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/mimetypes/qmimedatabase'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/mimetypes/qmimedatabase'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/mimetypes'
    cd kernel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/kernel/kernel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qmetatype'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qmetatype'
    cd dbus/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/dbus/dbus.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/dbus/remotecontrolledcar/controller'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/dbus/remotecontrolledcar/controller'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/dbus/remotecontrolledcar'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/dbus'
    cd qtestlib/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/qtestlib/qtestlib.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/googlesuggest'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/kernel'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qmetaenum'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/googlesuggest'
    cd events/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/kernel/events/events.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qmetaenum'
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/tools/customtypesending'
    cd torrent/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/network/torrent/torrent.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qmimedata/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/kernel/qmimedata/qmimedata.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qdbusconnection_delayed/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/dbus/qdbusconnection_delayed/qdbusconnection_delayed.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/tools/customtypesending'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib/tools'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/corelib'
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qtestlib'
    cd tutorial1/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/qtestlib/tutorial1/tutorial1.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qtconcurrent/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/qtconcurrent/qtconcurrent.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusconnection_delayed'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusconnection_delayed'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/kernel/events'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/kernel/events'
    cd qdbusabstractadaptor/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/dbus/qdbusabstractadaptor/qdbusabstractadaptor.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qmetaobject/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/kernel/qmetaobject/qmetaobject.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qtestlib/tutorial1'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qtestlib/tutorial1'
    cd tutorial2/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/qtestlib/tutorial2/tutorial2.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qtconcurrent'
    cd imagescaling/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/qtconcurrent/imagescaling/imagescaling.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/kernel/qmetaobject'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/kernel/qmetaobject'
    cd qmetatype/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/kernel/qmetatype/qmetatype.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qtconcurrent/imagescaling'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qtconcurrent/imagescaling'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusabstractadaptor'
    cd map/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/qtconcurrent/map/map.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qmyserver/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/dbus/qdbusabstractadaptor/qmyserver/qmyserver.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/torrent'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/torrent'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qmimedata'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qmimedata'
    cd multicastreceiver/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/network/multicastreceiver/multicastreceiver.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qobject/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/kernel/qobject/qobject.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qtestlib/tutorial2'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qtestlib/tutorial2'
    cd tutorial3/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/qtestlib/tutorial3/tutorial3.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/kernel/qmetatype'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/kernel/qmetatype'
    cd qobject/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/kernel/qobject/qobject.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qtconcurrent/map'
    make[3]: Nothing to be done for 'first'.
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qtconcurrent/map'
    cd progressdialog/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/qtconcurrent/progressdialog/progressdialog.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qobject'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusabstractadaptor/qmyserver'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusabstractadaptor/qmyserver'
    cd signalbug/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/kernel/qobject/signalbug/signalbug.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/multicastreceiver'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/multicastreceiver'
    cd qdbusabstractadaptor/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/dbus/qdbusabstractadaptor/qdbusabstractadaptor/qdbusabstractadaptor.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd multicastsender/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/network/multicastsender/multicastsender.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qtestlib/tutorial3'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qtestlib/tutorial3'
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qtconcurrent/progressdialog'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qtconcurrent/progressdialog'
    cd runfunction/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/qtconcurrent/runfunction/runfunction.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd tutorial4/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/qtestlib/tutorial4/tutorial4.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qobject/signalbug'
    make[6]: Nothing to be done for 'first'.
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qobject/signalbug'
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qtconcurrent/runfunction'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qtconcurrent/runfunction'
    cd wordcount/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/qtconcurrent/wordcount/wordcount.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd test/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/kernel/qobject/test/test.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/multicastsender'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/multicastsender'
    cd network-chat/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/network/network-chat/network-chat.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/kernel/qobject'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/kernel/qobject'
    cd qvariant/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/kernel/qvariant/qvariant.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qtestlib/tutorial4'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qtestlib/tutorial4'
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qtconcurrent/wordcount'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qtconcurrent/wordcount'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qtconcurrent'
    cd sql/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/sql/sql.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd tutorial5/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/qtestlib/tutorial5/tutorial5.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusabstractadaptor/qdbusabstractadaptor'
    make[5]: Nothing to be done for 'first'.
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusabstractadaptor/qdbusabstractadaptor'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusabstractadaptor'
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qobject/test'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qobject/test'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qobject'
    cd qdbusabstractinterface/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/dbus/qdbusabstractinterface/qdbusabstractinterface.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qpointer/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/kernel/qpointer/qpointer.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/network-chat'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/network-chat'
    cd bearermonitor/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/network/bearermonitor/bearermonitor.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/kernel/qvariant'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/kernel/qvariant'
    cd qcoreapplication/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/kernel/qcoreapplication/qcoreapplication.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/sql'
    cd books/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/sql/books/books.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qtestlib/tutorial5'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qtestlib/tutorial5'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/qtestlib'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusabstractinterface'
    cd drilldown/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/sql/drilldown/drilldown.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qpinger/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/dbus/qdbusabstractinterface/qpinger/qpinger.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qpointer'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qpointer'
    cd qsignalblocker/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/kernel/qsignalblocker/qsignalblocker.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/bearermonitor'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/bearermonitor'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/kernel/qcoreapplication'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/kernel/qcoreapplication'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/kernel'
    cd thread/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/thread/thread.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd fortuneclient/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/network/fortuneclient/fortuneclient.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/sql/books'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/sql/books'
    cd fortuneserver/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/network/fortuneserver/fortuneserver.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/sql/drilldown'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/sql/drilldown'
    cd cachedtable/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/sql/cachedtable/cachedtable.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusabstractinterface/qpinger'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusabstractinterface/qpinger'
    cd qdbusabstractinterface/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/dbus/qdbusabstractinterface/qdbusabstractinterface/qdbusabstractinterface.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/fortuneclient'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/fortuneclient'
    cd widgets/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/widgets.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/thread'
    cd qmutex/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/thread/qmutex/qmutex.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/fortuneserver'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/fortuneserver'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qsignalblocker'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qsignalblocker'
    cd securesocketclient/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/network/securesocketclient/securesocketclient.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qsignalmapper/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/kernel/qsignalmapper/qsignalmapper.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/sql/cachedtable'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/sql/cachedtable'
    cd querymodel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/sql/querymodel/querymodel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets'
    cd animation/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/animation/animation.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/securesocketclient'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network/securesocketclient'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/network'
    cd xml/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/xml/xml.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusabstractinterface/qdbusabstractinterface'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusabstractinterface/qdbusabstractinterface'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusabstractinterface'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/thread/qmutex'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/thread/qmutex'
    cd qdbusconnection/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/dbus/qdbusconnection/qdbusconnection.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qreadwritelock/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/thread/qreadwritelock/qreadwritelock.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/xml'
    cd htmlinfo/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/xml/htmlinfo/htmlinfo.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/animation'
    cd animatedtiles/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/animation/animatedtiles/animatedtiles.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/sql/querymodel'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/sql/querymodel'
    cd relationaltablemodel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/sql/relationaltablemodel/relationaltablemodel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/thread/qreadwritelock'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/thread/qreadwritelock'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusconnection'
    make[4]: Nothing to be done for 'first'.
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusconnection'
    cd qdbusconnection_no_app/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/dbus/qdbusconnection_no_app/qdbusconnection_no_app.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qsignalmapper'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qsignalmapper'
    cd qsystemsemaphore/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/kernel/qsystemsemaphore/qsystemsemaphore.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/xml/htmlinfo'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/xml/htmlinfo'
    cd qthreadstorage/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/thread/qthreadstorage/qthreadstorage.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd xmlstreamlint/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/xml/xmlstreamlint/xmlstreamlint.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/animation/animatedtiles'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/animation/animatedtiles'
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/sql/relationaltablemodel'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/sql/relationaltablemodel'
    cd easing/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/animation/easing/easing.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd sqlwidgetmapper/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/sql/sqlwidgetmapper/sqlwidgetmapper.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qsystemsemaphore'
    cd systemsemaphorehelper/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/kernel/qsystemsemaphore/systemsemaphorehelper/systemsemaphorehelper.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusconnection_no_app'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusconnection_no_app'
    cd qdbusconnection_no_bus/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/dbus/qdbusconnection_no_bus/qdbusconnection_no_bus.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/xml/xmlstreamlint'
    make[3]: Nothing to be done for 'first'.
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/xml/xmlstreamlint'
    cd dombookmarks/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/xml/dombookmarks/dombookmarks.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qsystemsemaphore/systemsemaphorehelper'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qsystemsemaphore/systemsemaphorehelper'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/thread/qthreadstorage'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/thread/qthreadstorage'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/animation/easing'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/animation/easing'
    cd test/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/kernel/qsystemsemaphore/test/test.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qthreadpool/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/thread/qthreadpool/qthreadpool.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd moveblocks/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/animation/moveblocks/moveblocks.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/sql/sqlwidgetmapper'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/sql/sqlwidgetmapper'
    cd tablemodel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/sql/tablemodel/tablemodel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusconnection_no_bus'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusconnection_no_bus'
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/xml/dombookmarks'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/xml/dombookmarks'
    cd qdbusconnection_no_libdbus/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/dbus/qdbusconnection_no_libdbus/qdbusconnection_no_libdbus.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd saxbookmarks/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/xml/saxbookmarks/saxbookmarks.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/animation/moveblocks'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/animation/moveblocks'
    cd states/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/animation/states/states.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/sql/tablemodel'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/sql/tablemodel'
    cd masterdetail/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/sql/masterdetail/masterdetail.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qsystemsemaphore/test'
    make[6]: Nothing to be done for 'first'.
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qsystemsemaphore/test'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qsystemsemaphore'
    cd qtimer/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/kernel/qtimer/qtimer.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/thread/qthreadpool'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/thread/qthreadpool'
    cd qwaitcondition/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/thread/qwaitcondition/qwaitcondition.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/xml/saxbookmarks'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/xml/saxbookmarks'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusconnection_no_libdbus'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusconnection_no_libdbus'
    cd qdbusconnection_spyhook/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/dbus/qdbusconnection_spyhook/qdbusconnection_spyhook.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd streambookmarks/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/xml/streambookmarks/streambookmarks.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/animation/states'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/animation/states'
    cd stickman/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/animation/stickman/stickman.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/sql/masterdetail'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/sql/masterdetail'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/sql'
    cd sub-attaq/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/animation/sub-attaq/sub-attaq.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qtimer'
    make[5]: Nothing to be done for 'first'.
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qtimer'
    cd qtranslator/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/kernel/qtranslator/qtranslator.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/thread/qwaitcondition'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/thread/qwaitcondition'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/thread'
    cd tools/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/tools/tools.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/animation/stickman'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/animation/stickman'
    cd desktop/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/desktop/desktop.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/xml/streambookmarks'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/xml/streambookmarks'
    cd rsslisting/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/xml/rsslisting/rsslisting.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusconnection_spyhook'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusconnection_spyhook'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qtranslator'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qtranslator'
    cd qdbuscontext/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/dbus/qdbuscontext/qdbuscontext.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qvariant/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/kernel/qvariant/qvariant.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/desktop'
    cd screenshot/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/desktop/screenshot/screenshot.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools'
    cd containers-associative/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/tools/containers-associative/containers-associative.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/animation/sub-attaq'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/animation/sub-attaq'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/animation'
    cd systray/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/desktop/systray/systray.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbuscontext'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/containers-associative'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/containers-associative'
    cd containers-sequential/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/tools/containers-sequential/containers-sequential.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbuscontext'
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/xml/rsslisting'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/xml/rsslisting'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/xml'
    cd qdbusinterface/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/dbus/qdbusinterface/qdbusinterface.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd gui/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/gui/gui.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/desktop/screenshot'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/desktop/screenshot'
    cd opengl/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/opengl/opengl.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qvariant'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel/qvariant'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/kernel'
    cd animation/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/animation/animation.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/desktop/systray'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/desktop/systray'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/desktop'
    cd dialogs/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/dialogs/dialogs.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/containers-sequential'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/containers-sequential'
    cd qbytearray/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/tools/qbytearray/qbytearray.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/gui'
    cd analogclock/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/gui/analogclock/analogclock.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[2]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/opengl'
    cd hellowindow/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/opengl/hellowindow/hellowindow.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusinterface'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/animation'
    cd qmyserver/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/dbus/qdbusinterface/qmyserver/qmyserver.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qabstractanimation/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/animation/qabstractanimation/qabstractanimation.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/dialogs'
    cd classwizard/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/dialogs/classwizard/classwizard.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/gui/analogclock'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/gui/analogclock'
    cd rasterwindow/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/gui/rasterwindow/rasterwindow.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/opengl/hellowindow'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/opengl/hellowindow'
    cd paintedwindow/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/opengl/paintedwindow/paintedwindow.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qbytearray'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qbytearray'
    cd qcontiguouscache/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/tools/qcontiguouscache/qcontiguouscache.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusinterface/qmyserver'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusinterface/qmyserver'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/animation/qabstractanimation'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/animation/qabstractanimation'
    cd qdbusinterface/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/dbus/qdbusinterface/qdbusinterface/qdbusinterface.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qanimationgroup/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/animation/qanimationgroup/qanimationgroup.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/dialogs/classwizard'
    make[4]: Nothing to be done for 'first'.
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/dialogs/classwizard'
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/gui/rasterwindow'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/gui/rasterwindow'
    cd openglwindow/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/gui/openglwindow/openglwindow.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd extension/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/dialogs/extension/extension.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/opengl/paintedwindow'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/opengl/paintedwindow'
    cd qopenglwindow/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/opengl/qopenglwindow/qopenglwindow.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qcontiguouscache'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qcontiguouscache'
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/gui/openglwindow'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/gui/openglwindow'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/gui'
    cd qcryptographichash/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/tools/qcryptographichash/qcryptographichash.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd contextinfo/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/opengl/contextinfo/contextinfo.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/animation/qanimationgroup'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/animation/qanimationgroup'
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/opengl/contextinfo'
    make[3]: Nothing to be done for 'first'.
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/opengl/contextinfo'
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/opengl/qopenglwindow'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/opengl/qopenglwindow'
    cd qparallelanimationgroup/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/animation/qparallelanimationgroup/qparallelanimationgroup.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd threadedqopenglwidget/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/opengl/threadedqopenglwidget/threadedqopenglwidget.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd 2dpainting/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/opengl/2dpainting/2dpainting.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/dialogs/extension'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/dialogs/extension'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusinterface/qdbusinterface'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusinterface/qdbusinterface'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusinterface'
    cd findfiles/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/dialogs/findfiles/findfiles.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qdbuslocalcalls/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/dbus/qdbuslocalcalls/qdbuslocalcalls.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qcryptographichash'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qcryptographichash'
    cd qdatetime/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/tools/qdatetime/qdatetime.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/opengl/threadedqopenglwidget'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/opengl/threadedqopenglwidget'
    cd hellogl2/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/opengl/hellogl2/hellogl2.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/animation/qparallelanimationgroup'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/animation/qparallelanimationgroup'
    cd qpauseanimation/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/animation/qpauseanimation/qpauseanimation.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/opengl/2dpainting'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/opengl/2dpainting'
    cd qopenglwidget/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/opengl/qopenglwidget/qopenglwidget.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qdatetime'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qdatetime'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/dialogs/findfiles'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/dialogs/findfiles'
    cd qlist/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/tools/qlist/qlist.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/opengl/hellogl2'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/opengl/hellogl2'
    cd cube/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/opengl/cube/cube.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd licensewizard/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/dialogs/licensewizard/licensewizard.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbuslocalcalls'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbuslocalcalls'
    cd qdbusmetaobject/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/dbus/qdbusmetaobject/qdbusmetaobject.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/animation/qpauseanimation'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/animation/qpauseanimation'
    cd qpropertyanimation/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/animation/qpropertyanimation/qpropertyanimation.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/opengl/qopenglwidget'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/opengl/qopenglwidget'
    cd textures/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/opengl/textures/textures.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qlist'
    make[5]: Nothing to be done for 'first'.
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qlist'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/dialogs/licensewizard'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/dialogs/licensewizard'
    cd qlocale/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/tools/qlocale/qlocale.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd standarddialogs/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/dialogs/standarddialogs/standarddialogs.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/animation/qpropertyanimation'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/animation/qpropertyanimation'
    cd qsequentialanimationgroup/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/animation/qsequentialanimationgroup/qsequentialanimationgroup.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/opengl/cube'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/opengl/cube'
    cd hellogles3/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/opengl/hellogles3/hellogles3.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/opengl/textures'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/opengl/textures'
    cd computegles31/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/opengl/computegles31/computegles31.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusmetaobject'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusmetaobject'
    cd qdbusmetatype/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/dbus/qdbusmetatype/qdbusmetatype.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/dialogs/standarddialogs'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/dialogs/standarddialogs'
    cd tabdialog/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/dialogs/tabdialog/tabdialog.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/animation/qsequentialanimationgroup'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/animation/qsequentialanimationgroup'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qlocale'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qlocale'
    cd qvariantanimation/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/animation/qvariantanimation/qvariantanimation.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qmap/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/tools/qmap/qmap.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/opengl/computegles31'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/opengl/computegles31'
    cd trivialwizard/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/dialogs/trivialwizard/trivialwizard.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/opengl/hellogles3'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/opengl/hellogles3'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/opengl'
    cd draganddrop/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/draganddrop/draganddrop.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusmetatype'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusmetatype'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/dialogs/tabdialog'
    cd qdbuspendingcall/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/dbus/qdbuspendingcall/qdbuspendingcall.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/dialogs/tabdialog'
    cd effects/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/effects/effects.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/dialogs/trivialwizard'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/animation/qvariantanimation'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/animation/qvariantanimation'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/animation'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/dialogs/trivialwizard'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/dialogs'
    cd codecs/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/codecs/codecs.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd gestures/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/gestures/gestures.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/draganddrop'
    cd draggableicons/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/draganddrop/draggableicons/draggableicons.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qmap'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qmap'
    cd qrect/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/tools/qrect/qrect.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/effects'
    cd blurpicker/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/effects/blurpicker/blurpicker.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/gestures'
    cd imagegestures/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/gestures/imagegestures/imagegestures.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/draganddrop/draggableicons'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/draganddrop/draggableicons'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbuspendingcall'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbuspendingcall'
    cd draggabletext/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/draganddrop/draggabletext/draggabletext.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qdbuspendingreply/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/dbus/qdbuspendingreply/qdbuspendingreply.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/codecs'
    cd qtextcodec/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/codecs/qtextcodec/qtextcodec.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qrect'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qrect'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/draganddrop/draggabletext'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/draganddrop/draggabletext'
    cd dropsite/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/draganddrop/dropsite/dropsite.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qringbuffer/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/tools/qringbuffer/qringbuffer.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbuspendingreply'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbuspendingreply'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/gestures/imagegestures'
    make[4]: Nothing to be done for 'first'.
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/gestures/imagegestures'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/gestures'
    cd qdbusreply/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/dbus/qdbusreply/qdbusreply.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/effects/blurpicker'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/effects/blurpicker'
    cd fademessage/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/effects/fademessage/fademessage.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd fridgemagnets/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/draganddrop/fridgemagnets/fridgemagnets.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/codecs/qtextcodec'
    cd test/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/codecs/qtextcodec/test/test.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/draganddrop/dropsite'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/draganddrop/dropsite'
    cd graphicsview/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/graphicsview/graphicsview.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qringbuffer'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qringbuffer'
    cd qstack/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/tools/qstack/qstack.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/effects/fademessage'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/effects/fademessage'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/effects'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/draganddrop/fridgemagnets'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/draganddrop/fridgemagnets'
    cd puzzle/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/draganddrop/puzzle/puzzle.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusreply'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusreply'
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/graphicsview'
    cd itemviews/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/itemviews/itemviews.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qdbusservicewatcher/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/dbus/qdbusservicewatcher/qdbusservicewatcher.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd chip/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/graphicsview/chip/chip.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qstack'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qstack'
    cd qstring/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/tools/qstring/qstring.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/codecs/qtextcodec/test'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/draganddrop/puzzle'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/draganddrop/puzzle'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/draganddrop'
    make[6]: Nothing to be done for 'first'.
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/codecs/qtextcodec/test'
    cd layouts/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/layouts/layouts.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd echo/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/codecs/qtextcodec/echo/echo.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews'
    cd addressbook/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/itemviews/addressbook/addressbook.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusservicewatcher'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/graphicsview/chip'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/graphicsview/chip'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusservicewatcher'
    cd elasticnodes/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/graphicsview/elasticnodes/elasticnodes.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/codecs/qtextcodec/echo'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/codecs/qtextcodec/echo'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/codecs/qtextcodec'
    cd qdbustype/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/dbus/qdbustype/qdbustype.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/layouts'
    cd basiclayouts/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/layouts/basiclayouts/basiclayouts.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd utf8/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/codecs/utf8/utf8.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/layouts/basiclayouts'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/addressbook'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/addressbook'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/layouts/basiclayouts'
    cd basicsortfiltermodel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/itemviews/basicsortfiltermodel/basicsortfiltermodel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd borderlayout/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/layouts/borderlayout/borderlayout.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/graphicsview/elasticnodes'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/graphicsview/elasticnodes'
    cd embeddeddialogs/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/graphicsview/embeddeddialogs/embeddeddialogs.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbustype'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbustype'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qstring'
    make[5]: Nothing to be done for 'first'.
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qstring'
    cd qstringbuilder/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/tools/qstringbuilder/qstringbuilder.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qdbusthreading/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/dbus/qdbusthreading/qdbusthreading.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/codecs/utf8'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/codecs/utf8'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/codecs'
    cd global/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/global/global.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/basicsortfiltermodel'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/basicsortfiltermodel'
    cd chart/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/itemviews/chart/chart.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/layouts/borderlayout'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/layouts/borderlayout'
    cd dynamiclayouts/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/layouts/dynamiclayouts/dynamiclayouts.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qstringbuilder'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qstringbuilder'
    cd qstringlist/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/tools/qstringlist/qstringlist.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/graphicsview/embeddeddialogs'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/graphicsview/embeddeddialogs'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusthreading'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusthreading'
    cd qdbusxmlparser/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/dbus/qdbusxmlparser/qdbusxmlparser.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd collidingmice/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/graphicsview/collidingmice/collidingmice.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global'
    cd qflags/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/global/qflags/qflags.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/layouts/dynamiclayouts'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/layouts/dynamiclayouts'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/chart'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/chart'
    cd coloreditorfactory/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/itemviews/coloreditorfactory/coloreditorfactory.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd flowlayout/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/layouts/flowlayout/flowlayout.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qstringlist'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qstringlist'
    cd qvector/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/tools/qvector/qvector.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/graphicsview/collidingmice'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/graphicsview/collidingmice'
    cd padnavigator/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/graphicsview/padnavigator/padnavigator.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusxmlparser'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus/qdbusxmlparser'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/dbus'
    cd gui/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/gui.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/layouts/flowlayout'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/layouts/flowlayout'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/layouts'
    cd mainwindows/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/mainwindows/mainwindows.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/qflags'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/qflags'
    cd q_func_info/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/global/q_func_info/q_func_info.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui'
    cd kernel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/kernel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/coloreditorfactory'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/coloreditorfactory'
    cd combowidgetmapper/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/itemviews/combowidgetmapper/combowidgetmapper.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qvector'
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/mainwindows'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qvector'
    cd qalgorithms/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/tools/qalgorithms/qalgorithms.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/graphicsview/padnavigator'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/graphicsview/padnavigator'
    cd application/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/mainwindows/application/application.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd basicgraphicslayouts/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/graphicsview/basicgraphicslayouts/basicgraphicslayouts.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/combowidgetmapper'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/combowidgetmapper'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/q_func_info'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/q_func_info'
    cd customsortfiltermodel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/itemviews/customsortfiltermodel/customsortfiltermodel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qgetputenv/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/global/qgetputenv/qgetputenv.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel'
    cd qbackingstore/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qbackingstore/qbackingstore.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/mainwindows/application'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/qgetputenv'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/qgetputenv'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/graphicsview/basicgraphicslayouts'
    make[4]: Nothing to be done for 'first'.
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/graphicsview/basicgraphicslayouts'
    cd qglobal/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/global/qglobal/qglobal.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/mainwindows/application'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qalgorithms'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools/qalgorithms'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/tools'
    cd diagramscene/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/graphicsview/diagramscene/diagramscene.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd codecs/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/codecs/codecs.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd dockwidgets/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/mainwindows/dockwidgets/dockwidgets.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/customsortfiltermodel'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/customsortfiltermodel'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qbackingstore'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qbackingstore'
    cd qclipboard/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qclipboard/qclipboard.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd dirview/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/itemviews/dirview/dirview.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/qglobal'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/qglobal'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/graphicsview/diagramscene'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/graphicsview/diagramscene'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/codecs'
    cd qnumeric/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/global/qnumeric/qnumeric.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd dragdroprobot/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/graphicsview/dragdroprobot/dragdroprobot.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qtextcodec/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/codecs/qtextcodec/qtextcodec.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qclipboard'
    cd copier/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qclipboard/copier/copier.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/mainwindows/dockwidgets'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/dirview'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/dirview'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/mainwindows/dockwidgets'
    cd editabletreemodel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/itemviews/editabletreemodel/editabletreemodel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd mainwindow/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/mainwindows/mainwindow/mainwindow.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/graphicsview/dragdroprobot'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/graphicsview/dragdroprobot'
    cd flowlayout/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/graphicsview/flowlayout/flowlayout.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/codecs/qtextcodec'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/codecs/qtextcodec'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/codecs'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/qnumeric'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/qnumeric'
    cd plugin/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/plugin/plugin.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qclipboard/copier'
    make[6]: Nothing to be done for 'first'.
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qclipboard/copier'
    cd qfloat16/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/global/qfloat16/qfloat16.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd paster/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qclipboard/paster/paster.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/editabletreemodel'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/editabletreemodel'
    cd fetchmore/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/itemviews/fetchmore/fetchmore.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/mainwindows/mainwindow'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/mainwindows/mainwindow'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/plugin'
    cd mdi/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/mainwindows/mdi/mdi.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd quuid/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/corelib/plugin/quuid/quuid.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/graphicsview/flowlayout'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/graphicsview/flowlayout'
    cd anchorlayout/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/graphicsview/anchorlayout/anchorlayout.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qclipboard/paster'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qclipboard/paster'
    cd test/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qclipboard/test/test.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/mainwindows/mdi'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/mainwindows/mdi'
    cd menus/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/mainwindows/menus/menus.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/qfloat16'
    make[5]: Nothing to be done for 'first'.
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/qfloat16'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/fetchmore'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/fetchmore'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/plugin/quuid'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/plugin/quuid'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib/plugin'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/corelib'
    cd qrand/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/global/qrand/qrand.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd flattreeview/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/itemviews/flattreeview/flattreeview.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd network/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/network/network.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/graphicsview/anchorlayout'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/graphicsview/anchorlayout'
    cd simpleanchorlayout/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/graphicsview/simpleanchorlayout/simpleanchorlayout.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/network'
    cd access/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/network/access/access.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/mainwindows/menus'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/mainwindows/menus'
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qclipboard/test'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qclipboard/test'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qclipboard'
    cd sdi/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/mainwindows/sdi/sdi.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qcursor/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qcursor/qcursor.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/graphicsview/simpleanchorlayout'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/graphicsview/simpleanchorlayout'
    cd weatheranchorlayout/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/graphicsview/weatheranchorlayout/weatheranchorlayout.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/network/access'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/flattreeview'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/flattreeview'
    cd qfile_vs_qnetworkaccessmanager/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/network/access/qfile_vs_qnetworkaccessmanager/qfile_vs_qnetworkaccessmanager.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/qrand'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/qrand'
    cd frozencolumn/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/itemviews/frozencolumn/frozencolumn.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qrandomgenerator/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/global/qrandomgenerator/qrandomgenerator.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/mainwindows/sdi'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/mainwindows/sdi'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/mainwindows'
    cd painting/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/painting/painting.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qcursor'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qcursor'
    cd qdrag/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qdrag/qdrag.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/frozencolumn'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/frozencolumn'
    cd interview/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/itemviews/interview/interview.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/network/access/qfile_vs_qnetworkaccessmanager'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/network/access/qfile_vs_qnetworkaccessmanager'
    cd qnetworkreply/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/network/access/qnetworkreply/qnetworkreply.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/qrandomgenerator'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/qrandomgenerator'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/graphicsview/weatheranchorlayout'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/graphicsview/weatheranchorlayout'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/graphicsview'
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/painting'
    cd qlogging/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/global/qlogging/qlogging.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd richtext/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/richtext/richtext.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd basicdrawing/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/painting/basicdrawing/basicdrawing.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/interview'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/interview'
    cd pixelator/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/itemviews/pixelator/pixelator.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/richtext'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qdrag'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qdrag'
    cd calendar/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/richtext/calendar/calendar.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qevent/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qevent/qevent.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/qlogging'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/painting/basicdrawing'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/painting/basicdrawing'
    cd concentriccircles/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/painting/concentriccircles/concentriccircles.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/network/access/qnetworkreply'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/network/access/qnetworkreply'
    cd app/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/global/qlogging/app/app.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qnetworkreply_from_cache/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/network/access/qnetworkreply_from_cache/qnetworkreply_from_cache.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/pixelator'
    make[4]: Nothing to be done for 'first'.
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/pixelator'
    cd puzzle/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/itemviews/puzzle/puzzle.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/painting/concentriccircles'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/painting/concentriccircles'
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/qlogging/app'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/qlogging/app'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/richtext/calendar'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/richtext/calendar'
    cd test/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/global/qlogging/test/test.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd orderform/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/richtext/orderform/orderform.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd affine/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/painting/affine/affine.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qevent'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qevent'
    cd qfileopenevent/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qfileopenevent/qfileopenevent.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/network/access/qnetworkreply_from_cache'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/network/access/qnetworkreply_from_cache'
    cd qnetworkdiskcache/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/network/access/qnetworkdiskcache/qnetworkdiskcache.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qfileopenevent'
    cd test/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qfileopenevent/test/test.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/qlogging/test'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/qlogging/test'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/qlogging'
    cd qtendian/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/global/qtendian/qtendian.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/puzzle'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/puzzle'
    cd simpledommodel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/itemviews/simpledommodel/simpledommodel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/richtext/orderform'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/richtext/orderform'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/painting/affine'
    cd syntaxhighlighter/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/richtext/syntaxhighlighter/syntaxhighlighter.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/painting/affine'
    cd composition/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/painting/composition/composition.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qfileopenevent/test'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qfileopenevent/test'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/qtendian'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/qtendian'
    cd qfileopeneventexternal/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qfileopenevent/qfileopeneventexternal/qfileopeneventexternal.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qglobalstatic/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/global/qglobalstatic/qglobalstatic.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/network/access/qnetworkdiskcache'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/network/access/qnetworkdiskcache'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/network/access'
    cd kernel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/network/kernel/kernel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/simpledommodel'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/simpledommodel'
    cd simpletreemodel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/itemviews/simpletreemodel/simpletreemodel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/richtext/syntaxhighlighter'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/richtext/syntaxhighlighter'
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qfileopenevent/qfileopeneventexternal'
    make[6]: Nothing to be done for 'first'.
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qfileopenevent/qfileopeneventexternal'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qfileopenevent'
    cd qguieventdispatcher/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qguieventdispatcher/qguieventdispatcher.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd textedit/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/richtext/textedit/textedit.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/network/kernel'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/painting/composition'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/painting/composition'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/network/kernel'
    cd socket/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/network/socket/socket.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/qglobalstatic'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/qglobalstatic'
    cd qhooks/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/global/qhooks/qhooks.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd deform/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/painting/deform/deform.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/simpletreemodel'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/simpletreemodel'
    cd simplewidgetmapper/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/itemviews/simplewidgetmapper/simplewidgetmapper.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/network/socket'
    cd qtcpserver/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/network/socket/qtcpserver/qtcpserver.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qguieventdispatcher'
    make[5]: Nothing to be done for 'first'.
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qguieventdispatcher'
    cd qguieventloop/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qguieventloop/qguieventloop.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/painting/deform'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/painting/deform'
    cd gradients/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/painting/gradients/gradients.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/simplewidgetmapper'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/simplewidgetmapper'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/richtext/textedit'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/richtext/textedit'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/richtext'
    cd spinboxdelegate/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/itemviews/spinboxdelegate/spinboxdelegate.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd pathstroke/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/painting/pathstroke/pathstroke.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/qhooks'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global/qhooks'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/global'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qguieventloop'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qguieventloop'
    cd io/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/io.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qguimetatype/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qguimetatype/qguimetatype.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/network/socket/qtcpserver'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/network/socket/qtcpserver'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/network/socket'
    cd ssl/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/network/ssl/ssl.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/spinboxdelegate'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/spinboxdelegate'
    cd spreadsheet/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/itemviews/spreadsheet/spreadsheet.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/painting/gradients'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/painting/gradients'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io'
    cd stardelegate/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/itemviews/stardelegate/stardelegate.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qbuffer/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qbuffer/qbuffer.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/network/ssl'
    cd qsslsocket/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/network/ssl/qsslsocket/qsslsocket.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qguimetatype'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qguimetatype'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/painting/pathstroke'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/painting/pathstroke'
    cd qguitimer/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qguitimer/qguitimer.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd imagecomposition/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/painting/imagecomposition/imagecomposition.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/stardelegate'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/stardelegate'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/spreadsheet'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/spreadsheet'
    cd painterpaths/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/painting/painterpaths/painterpaths.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd storageview/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/itemviews/storageview/storageview.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qbuffer'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qbuffer'
    cd qdataurl/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qdataurl/qdataurl.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/network/ssl/qsslsocket'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/network/ssl/qsslsocket'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/network/ssl'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/network'
    cd gui/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/gui.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/painting/imagecomposition'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/painting/imagecomposition'
    cd scroller/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/scroller/scroller.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui'
    cd animation/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/animation/animation.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qdataurl'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qdataurl'
    cd qdebug/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qdebug/qdebug.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/storageview'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews/storageview'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/itemviews'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/painting/painterpaths'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/painting/painterpaths'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qguitimer'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qguitimer'
    cd statemachine/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/statemachine/statemachine.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qguivariant/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qguivariant/qguivariant.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd transformations/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/painting/transformations/transformations.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/scroller'
    cd graphicsview/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/scroller/graphicsview/graphicsview.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qguivariant'
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/statemachine'
    cd test/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qguivariant/test/test.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/animation'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qdebug'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qdebug'
    cd factorial/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/statemachine/factorial/factorial.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qdir/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qdir/qdir.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qanimation/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/animation/qanimation/qanimation.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/scroller/graphicsview'
    make[4]: Nothing to be done for 'first'.
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/scroller/graphicsview'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/scroller'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/painting/transformations'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/painting/transformations'
    cd tools/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tools/tools.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd fontsampler/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/painting/fontsampler/fontsampler.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/statemachine/factorial'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/statemachine/factorial'
    cd pingpong/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/statemachine/pingpong/pingpong.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools'
    cd codecs/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tools/codecs/codecs.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/animation/qanimation'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/animation/qanimation'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/animation'
    cd graphicsview/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/graphicsview/graphicsview.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qdir'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qdir'
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qguivariant/test'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qguivariant/test'
    cd qdiriterator/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qdiriterator/qdiriterator.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd no_application/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qguivariant/no_application/no_application.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/painting/fontsampler'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/painting/fontsampler'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/painting'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/statemachine/pingpong'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/statemachine/pingpong'
    cd tutorials/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/tutorials.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd eventtransitions/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/statemachine/eventtransitions/eventtransitions.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/graphicsview'
    cd functional/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/graphicsview/functional/functional.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/codecs'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/codecs'
    cd completer/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tools/completer/completer.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials'
    cd addressbook/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/addressbook/addressbook.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qdiriterator'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qdiriterator'
    cd qfile/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qfile/qfile.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qguivariant/no_application'
    make[6]: Nothing to be done for 'first'.
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qguivariant/no_application'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qguivariant'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/statemachine/eventtransitions'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/graphicsview/functional'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/graphicsview/functional'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/statemachine/eventtransitions'
    cd qinputmethod/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qinputmethod/qinputmethod.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd rogue/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/statemachine/rogue/rogue.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qgraphicsanchorlayout/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/graphicsview/qgraphicsanchorlayout/qgraphicsanchorlayout.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/completer'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/completer'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/addressbook'
    cd part1/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/addressbook/part1/part1.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd customcompleter/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tools/customcompleter/customcompleter.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qfile'
    cd test/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qfile/test/test.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/statemachine/rogue'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/statemachine/rogue'
    cd trafficlight/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/statemachine/trafficlight/trafficlight.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/addressbook/part1'
    make[5]: Nothing to be done for 'first'.
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/addressbook/part1'
    cd part2/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/addressbook/part2/part2.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/graphicsview/qgraphicsanchorlayout'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/graphicsview/qgraphicsanchorlayout'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qinputmethod'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qinputmethod'
    cd qkeyevent/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qkeyevent/qkeyevent.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qgraphicsitem/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/graphicsview/qgraphicsitem/qgraphicsitem.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/customcompleter'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/customcompleter'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/statemachine/trafficlight'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/statemachine/trafficlight'
    cd echoplugin/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tools/echoplugin/echoplugin.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd twowaybutton/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/statemachine/twowaybutton/twowaybutton.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qfile/test'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qfile/test'
    cd stdinprocess/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qfile/stdinprocess/stdinprocess.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/addressbook/part2'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/addressbook/part2'
    cd part3/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/addressbook/part3/part3.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/echoplugin'
    cd echowindow/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tools/echoplugin/echowindow/echowindow.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/statemachine/twowaybutton'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/statemachine/twowaybutton'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/statemachine'
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qfile/stdinprocess'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qfile/stdinprocess'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qfile'
    cd plugin/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tools/echoplugin/plugin/plugin.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd largefile/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/largefile/largefile.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qkeyevent'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qkeyevent'
    cd qkeysequence/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qkeysequence/qkeysequence.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/addressbook/part3'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/addressbook/part3'
    cd part4/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/addressbook/part4/part4.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/echoplugin/echowindow'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/echoplugin/echowindow'
    cd part5/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/addressbook/part5/part5.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/graphicsview/qgraphicsitem'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/graphicsview/qgraphicsitem'
    cd qgraphicsscene/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/graphicsview/qgraphicsscene/qgraphicsscene.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/echoplugin/plugin'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/echoplugin/plugin'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/echoplugin'
    cd i18n/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tools/i18n/i18n.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/largefile'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/largefile'
    cd qfileselector/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qfileselector/qfileselector.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/addressbook/part4'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/addressbook/part4'
    cd part6/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/addressbook/part6/part6.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qkeysequence'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qkeysequence'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/addressbook/part5'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/addressbook/part5'
    cd qmouseevent/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qmouseevent/qmouseevent.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd part7/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/addressbook/part7/part7.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/addressbook/part6'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/addressbook/part6'
    cd plugandpaint/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tools/plugandpaint/plugandpaint.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/graphicsview/qgraphicsscene'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/graphicsview/qgraphicsscene'
    cd qgraphicsview/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/graphicsview/qgraphicsview/qgraphicsview.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/addressbook/part7'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/addressbook/part7'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/addressbook'
    cd widgets/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/widgets/widgets.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qmouseevent'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qmouseevent'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/i18n'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/i18n'
    cd regexp/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tools/regexp/regexp.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qmouseevent_modal/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qmouseevent_modal/qmouseevent_modal.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/plugandpaint'
    cd plugins/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tools/plugandpaint/plugins/plugins.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/widgets'
    cd toplevel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/widgets/toplevel/toplevel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/regexp'
    make[4]: Nothing to be done for 'first'.
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/regexp'
    cd childwidget/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/widgets/childwidget/childwidget.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/plugandpaint/plugins'
    cd basictools/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tools/plugandpaint/plugins/basictools/basictools.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/graphicsview/qgraphicsview'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/graphicsview/qgraphicsview'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qfileselector'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qfileselector'
    cd qgraphicswidget/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/graphicsview/qgraphicswidget/qgraphicswidget.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qfilesystemmetadata/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qfilesystemmetadata/qfilesystemmetadata.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/widgets/toplevel'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/widgets/toplevel'
    cd extrafilters/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tools/plugandpaint/plugins/extrafilters/extrafilters.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qmouseevent_modal'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qmouseevent_modal'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/widgets/childwidget'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/widgets/childwidget'
    cd qpalette/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qpalette/qpalette.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/plugandpaint/plugins/basictools'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/plugandpaint/plugins/basictools'
    cd nestedlayouts/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/widgets/nestedlayouts/nestedlayouts.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd windowlayout/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/widgets/windowlayout/windowlayout.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/graphicsview/qgraphicswidget'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/graphicsview/qgraphicswidget'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/graphicsview'
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/plugandpaint/plugins/extrafilters'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/plugandpaint/plugins/extrafilters'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/plugandpaint/plugins'
    cd image/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/image/image.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd app/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tools/plugandpaint/app/app.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qfilesystemmetadata'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qfilesystemmetadata'
    cd qfilesystementry/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qfilesystementry/qfilesystementry.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/widgets/windowlayout'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/widgets/windowlayout'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/widgets/nestedlayouts'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/widgets/nestedlayouts'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/widgets'
    cd modelview/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/modelview/modelview.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd gettingStarted/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/gettingStarted/gettingStarted.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qpalette'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qpalette'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/plugandpaint/app'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/plugandpaint/app'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/plugandpaint'
    cd regularexpression/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tools/regularexpression/regularexpression.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qscreen/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qscreen/qscreen.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/image'
    cd blendbench/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/image/blendbench/blendbench.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/modelview'
    cd 1_readonly/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/modelview/1_readonly/1_readonly.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/gettingStarted'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/regularexpression'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/regularexpression'
    cd settingseditor/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tools/settingseditor/settingseditor.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd gsQt/ && ( test -e Makefile.gsqt || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile.gsqt /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/gettingStarted/gsQt/gsqt.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile.gsqt
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qfilesystementry'
    make[5]: Nothing to be done for 'first'.
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qfilesystementry'
    cd qfilesystemwatcher/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qfilesystemwatcher/qfilesystemwatcher.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/image/blendbench'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/image/blendbench'
    cd qimageconversion/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/image/qimageconversion/qimageconversion.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/gettingStarted/gsQt'
    cd part1/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/gettingStarted/gsQt/part1/part1.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/settingseditor'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/settingseditor'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qscreen'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qscreen'
    cd qsurfaceformat/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qsurfaceformat/qsurfaceformat.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd styleplugin/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tools/styleplugin/styleplugin.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/modelview/1_readonly'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/modelview/1_readonly'
    cd 2_formatting/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/modelview/2_formatting/2_formatting.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/gettingStarted/gsQt/part1'
    make[6]: Nothing to be done for 'first'.
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/gettingStarted/gsQt/part1'
    cd part2/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/gettingStarted/gsQt/part2/part2.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qfilesystemwatcher'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qfilesystemwatcher'
    cd qiodevice/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qiodevice/qiodevice.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qsurfaceformat'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qsurfaceformat'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/styleplugin'
    cd qtouchevent/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qtouchevent/qtouchevent.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/image/qimageconversion'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/image/qimageconversion'
    cd stylewindow/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tools/styleplugin/stylewindow/stylewindow.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qimagereader/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/image/qimagereader/qimagereader.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/modelview/2_formatting'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/modelview/2_formatting'
    cd 3_changingmodel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/modelview/3_changingmodel/3_changingmodel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/gettingStarted/gsQt/part2'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/gettingStarted/gsQt/part2'
    cd part3/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/gettingStarted/gsQt/part3/part3.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/styleplugin/stylewindow'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/styleplugin/stylewindow'
    cd plugin/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tools/styleplugin/plugin/plugin.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qtouchevent'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qtouchevent'
    cd qwindow/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qwindow/qwindow.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qiodevice'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qiodevice'
    cd qlockfile/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qlockfile/qlockfile.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/modelview/3_changingmodel'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/modelview/3_changingmodel'
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/gettingStarted/gsQt/part3'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/gettingStarted/gsQt/part3'
    cd 4_headers/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/modelview/4_headers/4_headers.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd part4/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/gettingStarted/gsQt/part4/part4.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/image/qimagereader'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/image/qimagereader'
    cd qimagescale/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/image/qimagescale/qimagescale.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/styleplugin/plugin'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/styleplugin/plugin'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/styleplugin'
    cd treemodelcompleter/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tools/treemodelcompleter/treemodelcompleter.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/gettingStarted/gsQt/part4'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/gettingStarted/gsQt/part4'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qlockfile'
    cd part5/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/gettingStarted/gsQt/part5/part5.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    ( test -e Makefile.tst_qlockfile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile.tst_qlockfile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qlockfile/tst_qlockfile.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile.tst_qlockfile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/modelview/4_headers'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/modelview/4_headers'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/image/qimagescale'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/image/qimagescale'
    cd qpixmap/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/image/qpixmap/qpixmap.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd 5_edit/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/modelview/5_edit/5_edit.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qwindow'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qwindow'
    cd qguiapplication/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qguiapplication/qguiapplication.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qlockfile'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qlockfile'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/treemodelcompleter'
    make[4]: Nothing to be done for 'first'.
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/treemodelcompleter'
    cd qlockfiletesthelper/ && ( test -e Makefile.qlockfile_test_helper || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile.qlockfile_test_helper /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qlockfile/qlockfiletesthelper/qlockfile_test_helper.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile.qlockfile_test_helper
    cd undo/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tools/undo/undo.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/image/qpixmap'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/image/qpixmap'
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/gettingStarted/gsQt/part5'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/gettingStarted/gsQt/part5'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/gettingStarted/gsQt'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/gettingStarted'
    cd qpixmapcache/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/image/qpixmapcache/qpixmapcache.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd 6_treeview/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/modelview/6_treeview/6_treeview.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/modelview/5_edit'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/modelview/5_edit'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qguiapplication'
    cd widgets/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/widgets/widgets.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    Some of the required modules (qtConfig(private_tests)) are not available.
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/modelview/6_treeview'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/modelview/6_treeview'
    Skipped.
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qguiapplication'
    cd qpixelformat/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qpixelformat/qpixelformat.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qlockfile/qlockfiletesthelper'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qlockfile/qlockfiletesthelper'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qlockfile'
    cd 7_selections/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/modelview/7_selections/7_selections.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qloggingcategory/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qloggingcategory/qloggingcategory.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/undo'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/undo'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/image/qpixmapcache'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/image/qpixmapcache'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/image'
    cd undoframework/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tools/undoframework/undoframework.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd itemviews/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/itemviews/itemviews.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets'
    cd analogclock/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/widgets/analogclock/analogclock.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/modelview/7_selections'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/modelview/7_selections'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/modelview'
    cd notepad/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/tutorials/notepad/notepad.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qloggingcategory'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qloggingcategory'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/undoframework'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools/undoframework'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tools'
    cd qnodebug/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qnodebug/qnodebug.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd calculator/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/widgets/calculator/calculator.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qpixelformat'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qpixelformat'
    cd qopenglwindow/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qopenglwindow/qopenglwindow.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/itemviews'
    cd qtableview/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/itemviews/qtableview/qtableview.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/analogclock'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/analogclock'
    cd windowcontainer/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/windowcontainer/windowcontainer.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/notepad'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials/notepad'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/tutorials'
    cd calendarwidget/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/widgets/calendarwidget/calendarwidget.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qnodebug'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qnodebug'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/calculator'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/calculator'
    cd charactermap/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/widgets/charactermap/charactermap.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qprocess/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qprocess/qprocess.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/itemviews/qtableview'
    make[5]: Nothing to be done for 'first'.
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/itemviews/qtableview'
    cd qheaderview/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/itemviews/qheaderview/qheaderview.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qopenglwindow'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qopenglwindow'
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/windowcontainer'
    make[3]: Nothing to be done for 'first'.
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/windowcontainer'
    cd qrasterwindow/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/kernel/qrasterwindow/qrasterwindow.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd codeeditor/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/widgets/codeeditor/codeeditor.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/calendarwidget'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/calendarwidget'
    cd digitalclock/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/widgets/digitalclock/digitalclock.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd testProcessCrash/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qprocess/testProcessCrash/testProcessCrash.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/charactermap'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/charactermap'
    cd elidedlabel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/widgets/elidedlabel/elidedlabel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/codeeditor'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/codeeditor'
    cd groupbox/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/widgets/groupbox/groupbox.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/itemviews/qheaderview'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/itemviews/qheaderview'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/itemviews'
    cd kernel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/kernel/kernel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/digitalclock'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/digitalclock'
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testProcessCrash'
    make[6]: Nothing to be done for 'first'.
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testProcessCrash'
    cd icons/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/widgets/icons/icons.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd testProcessEcho/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qprocess/testProcessEcho/testProcessEcho.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/elidedlabel'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/elidedlabel'
    cd imageviewer/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/widgets/imageviewer/imageviewer.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/kernel'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qrasterwindow'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel/qrasterwindow'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/kernel'
    cd image/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/image/image.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qapplication/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/kernel/qapplication/qapplication.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/icons'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/icons'
    cd lineedits/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/widgets/lineedits/lineedits.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/groupbox'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/groupbox'
    cd movie/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/widgets/movie/movie.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testProcessEcho'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testProcessEcho'
    cd testProcessEcho2/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qprocess/testProcessEcho2/testProcessEcho2.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/lineedits'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/lineedits'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/image'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/imageviewer'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/imageviewer'
    cd mousebuttons/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/widgets/mousebuttons/mousebuttons.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qimagereader/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/image/qimagereader/qimagereader.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd scribble/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/widgets/scribble/scribble.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testProcessEcho2'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testProcessEcho2'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/movie'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/movie'
    cd shapedclock/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/widgets/shapedclock/shapedclock.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd testProcessEcho3/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qprocess/testProcessEcho3/testProcessEcho3.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/kernel/qapplication'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/kernel/qapplication'
    cd qwidget/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/kernel/qwidget/qwidget.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/mousebuttons'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/mousebuttons'
    cd sliders/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/widgets/sliders/sliders.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/scribble'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/scribble'
    cd spinboxes/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/widgets/spinboxes/spinboxes.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testProcessEcho3'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testProcessEcho3'
    cd testProcessEnvironment/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qprocess/testProcessEnvironment/testProcessEnvironment.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/kernel/qwidget'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/kernel/qwidget'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/image/qimagereader'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/image/qimagereader'
    cd qguimetatype/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/kernel/qguimetatype/qguimetatype.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qicoimageformat/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/image/qicoimageformat/qicoimageformat.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/shapedclock'
    make[4]: Nothing to be done for 'first'.
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/shapedclock'
    cd styles/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/widgets/styles/styles.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/sliders'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/sliders'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/spinboxes'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/spinboxes'
    cd stylesheet/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/widgets/stylesheet/stylesheet.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd tablet/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/widgets/tablet/tablet.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testProcessEnvironment'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testProcessEnvironment'
    cd testProcessHang/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qprocess/testProcessHang/testProcessHang.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/kernel/qguimetatype'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/kernel/qguimetatype'
    cd qguivariant/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/kernel/qguivariant/qguivariant.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/styles'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/styles'
    cd tetrix/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/widgets/tetrix/tetrix.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/image/qicoimageformat'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/image/qicoimageformat'
    cd qpixmap/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/image/qpixmap/qpixmap.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/tablet'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/tablet'
    cd tooltips/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/widgets/tooltips/tooltips.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/kernel/qguivariant'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/kernel/qguivariant'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/kernel'
    cd math3d/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/math3d/math3d.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testProcessHang'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testProcessHang'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/stylesheet'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/stylesheet'
    cd validators/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/widgets/validators/validators.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd testProcessNormal/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qprocess/testProcessNormal/testProcessNormal.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/tetrix'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/tetrix'
    cd wiggly/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/widgets/wiggly/wiggly.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/math3d'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/validators'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/validators'
    cd qmatrix4x4/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/math3d/qmatrix4x4/qmatrix4x4.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd windowflags/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/examples/widgets/widgets/windowflags/windowflags.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testProcessNormal'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testProcessNormal'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/tooltips'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/tooltips'
    cd testProcessOutput/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qprocess/testProcessOutput/testProcessOutput.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/image/qpixmap'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/image/qpixmap'
    cd qimage/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/image/qimage/qimage.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/wiggly'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/wiggly'
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testProcessOutput'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testProcessOutput'
    cd testProcessDeadWhileReading/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qprocess/testProcessDeadWhileReading/testProcessDeadWhileReading.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/windowflags'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets/windowflags'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets/widgets'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples/widgets'
    make[1]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/examples'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/math3d/qmatrix4x4'
    make[5]: Nothing to be done for 'first'.
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/math3d/qmatrix4x4'
    cd qquaternion/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/math3d/qquaternion/qquaternion.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testProcessDeadWhileReading'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testProcessDeadWhileReading'
    cd testProcessEOF/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qprocess/testProcessEOF/testProcessEOF.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/image/qimage'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/image/qimage'
    cd qimageiohandler/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/image/qimageiohandler/qimageiohandler.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testProcessEOF'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testProcessEOF'
    cd testExitCodes/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qprocess/testExitCodes/testExitCodes.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/math3d/qquaternion'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/math3d/qquaternion'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/math3d'
    cd painting/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/painting/painting.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testExitCodes'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testExitCodes'
    cd testForwarding/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qprocess/testForwarding/testForwarding.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/image/qimageiohandler'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/image/qimageiohandler'
    cd qimagewriter/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/image/qimagewriter/qimagewriter.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/painting'
    cd drawtexture/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/painting/drawtexture/drawtexture.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testForwarding'
    make[6]: Nothing to be done for 'first'.
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testForwarding'
    cd testForwardingHelper/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qprocess/testForwardingHelper/testForwardingHelper.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testForwardingHelper'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testForwardingHelper'
    cd testGuiProcess/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qprocess/testGuiProcess/testGuiProcess.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/image/qimagewriter'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/image/qimagewriter'
    cd qmovie/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/image/qmovie/qmovie.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/painting/drawtexture'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/painting/drawtexture'
    cd qcolor/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/painting/qcolor/qcolor.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testGuiProcess'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testGuiProcess'
    cd testDetached/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qprocess/testDetached/testDetached.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/painting/qcolor'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/painting/qcolor'
    cd qpainter/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/painting/qpainter/qpainter.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/image/qmovie'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/image/qmovie'
    cd qpicture/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/image/qpicture/qpicture.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testDetached'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testDetached'
    cd fileWriterProcess/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qprocess/fileWriterProcess/fileWriterProcess.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/fileWriterProcess'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/fileWriterProcess'
    cd testSetWorkingDirectory/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qprocess/testSetWorkingDirectory/testSetWorkingDirectory.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/painting/qpainter'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/painting/qpainter'
    cd qregion/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/painting/qregion/qregion.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/image/qpicture'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/image/qpicture'
    cd qicon/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/image/qicon/qicon.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testSetWorkingDirectory'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testSetWorkingDirectory'
    cd testSoftExit/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qprocess/testSoftExit/testSoftExit.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/painting/qregion'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/painting/qregion'
    cd qtransform/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/painting/qtransform/qtransform.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testSoftExit'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testSoftExit'
    cd testProcessSpacesArgs/ && ( test -e Makefile.nospace || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile.nospace /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qprocess/testProcessSpacesArgs/nospace.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile.nospace
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/image/qicon'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/image/qicon'
    cd qiconhighdpi/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/image/qiconhighdpi/qiconhighdpi.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testProcessSpacesArgs'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testProcessSpacesArgs'
    cd testProcessSpacesArgs/ && ( test -e Makefile.onespace || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile.onespace /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qprocess/testProcessSpacesArgs/onespace.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile.onespace
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/image/qiconhighdpi'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/image/qiconhighdpi'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/image'
    cd math3d/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/math3d/math3d.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/painting/qtransform'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/painting/qtransform'
    cd qtbench/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/painting/qtbench/qtbench.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd testProcessSpacesArgs/ && ( test -e Makefile.twospaces || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile.twospaces /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qprocess/testProcessSpacesArgs/twospaces.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile.twospaces
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/math3d'
    cd qquaternion/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/math3d/qquaternion/qquaternion.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/painting/qtbench'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/painting/qtbench'
    cd lancebench/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/painting/lancebench/lancebench.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd testSpaceInName/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qprocess/testSpaceInName/testSpaceInName.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testSpaceInName'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/testSpaceInName'
    cd test/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qprocess/test/test.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/math3d/qquaternion'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/math3d/qquaternion'
    cd qvectornd/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/math3d/qvectornd/qvectornd.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/painting/lancebench'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/painting/lancebench'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/painting'
    cd styles/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/styles/styles.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/math3d/qvectornd'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/math3d/qvectornd'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/styles'
    cd qmatrixnxn/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/math3d/qmatrixnxn/qmatrixnxn.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qstylesheetstyle/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/styles/qstylesheetstyle/qstylesheetstyle.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/test'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess/test'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess'
    cd qprocess-noapplication/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qprocess-noapplication/qprocess-noapplication.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess-noapplication'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocess-noapplication'
    cd qprocessenvironment/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qprocessenvironment/qprocessenvironment.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/styles/qstylesheetstyle'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/styles/qstylesheetstyle'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/styles'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/math3d/qmatrixnxn'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/math3d/qmatrixnxn'
    cd text/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/text/text.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/math3d'
    cd painting/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/painting/painting.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocessenvironment'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qprocessenvironment'
    cd qresourceengine/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qresourceengine/qresourceengine.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting'
    cd qpainterpath/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/painting/qpainterpath/qpainterpath.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/text'
    cd qfontmetrics/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/text/qfontmetrics/qfontmetrics.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qresourceengine'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qresourceengine'
    cd qsettings/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qsettings/qsettings.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qpainterpath'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qpainterpath'
    cd qpainterpathstroker/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/painting/qpainterpathstroker/qpainterpathstroker.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/text/qfontmetrics'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/text/qfontmetrics'
    cd qtext/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/text/qtext/qtext.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qsettings'
    make[5]: Nothing to be done for 'first'.
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qsettings'
    cd qsavefile/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qsavefile/qsavefile.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qpainterpathstroker'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qpainterpathstroker'
    cd qcolor/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/painting/qcolor/qcolor.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/text/qtext'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/text/qtext'
    cd qtextdocument/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/gui/text/qtextdocument/qtextdocument.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qsavefile'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qsavefile'
    cd qstandardpaths/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qstandardpaths/qstandardpaths.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qcolor'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qcolor'
    cd qbrush/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/painting/qbrush/qbrush.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/text/qtextdocument'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/text/qtextdocument'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui/text'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/gui'
    cd widgets/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/widgets/widgets.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qstandardpaths'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qstandardpaths'
    cd qstorageinfo/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qstorageinfo/qstorageinfo.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/widgets'
    cd widgets/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/widgets/widgets/widgets.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qbrush'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qbrush'
    cd qregion/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/painting/qregion/qregion.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/widgets/widgets'
    cd qtextbrowser/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/benchmarks/widgets/widgets/qtextbrowser/qtextbrowser.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qstorageinfo'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qstorageinfo'
    cd qtemporarydir/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qtemporarydir/qtemporarydir.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/widgets/widgets/qtextbrowser'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/widgets/widgets/qtextbrowser'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/widgets/widgets'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks/widgets'
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/benchmarks'
    cd qtemporaryfile/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qtemporaryfile/qtemporaryfile.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qregion'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qregion'
    cd qpagelayout/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/painting/qpagelayout/qpagelayout.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qtemporarydir'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qtemporarydir'
    cd qpagesize/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/painting/qpagesize/qpagesize.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qtemporaryfile'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qtemporaryfile'
    cd qurl/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qurl/qurl.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qpagelayout'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qpagelayout'
    cd qurlquery/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/io/qurlquery/qurlquery.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qpagesize'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qpagesize'
    cd qpainter/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/painting/qpainter/qpainter.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qurlquery'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qurlquery'
    cd qpdfwriter/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/painting/qpdfwriter/qpdfwriter.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qurl'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io/qurl'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/io'
    cd itemmodels/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/itemmodels/itemmodels.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qpdfwriter'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qpdfwriter'
    cd mimetypes/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/mimetypes/mimetypes.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/itemmodels'
    cd qabstractitemmodel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/itemmodels/qabstractitemmodel/qabstractitemmodel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qpainter'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qpainter'
    cd qpen/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/painting/qpen/qpen.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/mimetypes'
    cd qmimedatabase/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/mimetypes/qmimedatabase/qmimedatabase.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/itemmodels/qabstractitemmodel'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/itemmodels/qabstractitemmodel'
    cd qstringlistmodel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/itemmodels/qstringlistmodel/qstringlistmodel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qpen'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qpen'
    cd qpaintengine/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/painting/qpaintengine/qpaintengine.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/mimetypes/qmimedatabase'
    cd qmimedatabase-xml/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/mimetypes/qmimedatabase/qmimedatabase-xml/qmimedatabase-xml.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qpaintengine'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qpaintengine'
    cd qtransform/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/painting/qtransform/qtransform.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/mimetypes/qmimedatabase/qmimedatabase-xml'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/itemmodels/qstringlistmodel'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/itemmodels/qstringlistmodel'
    Some of the required modules (qtConfig(private_tests)) are not available.
    cd qabstractproxymodel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/itemmodels/qabstractproxymodel/qabstractproxymodel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    Skipped.
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/mimetypes/qmimedatabase/qmimedatabase-xml'
    cd qmimedatabase-cache/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/mimetypes/qmimedatabase/qmimedatabase-cache/qmimedatabase-cache.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/mimetypes/qmimedatabase/qmimedatabase-cache'
    Skipped.
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/mimetypes/qmimedatabase/qmimedatabase-cache'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/mimetypes/qmimedatabase'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/mimetypes'
    cd qidentityproxymodel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/itemmodels/qidentityproxymodel/qidentityproxymodel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qtransform'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qtransform'
    cd qwmatrix/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/painting/qwmatrix/qwmatrix.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/itemmodels/qidentityproxymodel'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/itemmodels/qidentityproxymodel'
    cd qpolygon/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/painting/qpolygon/qpolygon.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/itemmodels/qabstractproxymodel'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/itemmodels/qabstractproxymodel'
    cd qitemselectionmodel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/itemmodels/qitemselectionmodel/qitemselectionmodel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qpolygon'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qpolygon'
    cd qsortfilterproxymodel_recursive/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/itemmodels/qsortfilterproxymodel_recursive/qsortfilterproxymodel_recursive.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qwmatrix'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting/qwmatrix'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/painting'
    cd qopenglconfig/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/qopenglconfig/qopenglconfig.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/itemmodels/qitemselectionmodel'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/itemmodels/qitemselectionmodel'
    cd qopengl/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/qopengl/qopengl.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/itemmodels/qsortfilterproxymodel_recursive'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/itemmodels/qsortfilterproxymodel_recursive'
    cd qsortfilterproxymodel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/itemmodels/qsortfilterproxymodel/qsortfilterproxymodel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/itemmodels/qsortfilterproxymodel'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/itemmodels/qsortfilterproxymodel'
    cd qitemmodel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/itemmodels/qitemmodel/qitemmodel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/qopenglconfig'
    make[4]: Nothing to be done for 'first'.
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/qopenglconfig'
    cd network/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/network.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/qopengl'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/qopengl'
    cd text/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/text/text.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text'
    cd qabstracttextdocumentlayout/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/text/qabstracttextdocumentlayout/qabstracttextdocumentlayout.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network'
    cd access/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/access/access.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/itemmodels/qitemmodel'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/itemmodels/qitemmodel'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/itemmodels'
    cd plugin/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/plugin/plugin.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/access'
    cd qnetworkdiskcache/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/access/qnetworkdiskcache/qnetworkdiskcache.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin'
    cd qfactoryloader/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/plugin/qfactoryloader/qfactoryloader.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qabstracttextdocumentlayout'
    make[5]: Nothing to be done for 'first'.
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qabstracttextdocumentlayout'
    cd qfont/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/text/qfont/qfont.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qfactoryloader'
    cd plugin1/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/plugin/qfactoryloader/plugin1/plugin1.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qfactoryloader/plugin1'
    make[6]: Nothing to be done for 'first'.
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qfactoryloader/plugin1'
    cd plugin2/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/plugin/qfactoryloader/plugin2/plugin2.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/access/qnetworkdiskcache'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/access/qnetworkdiskcache'
    cd qnetworkcookiejar/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/access/qnetworkcookiejar/qnetworkcookiejar.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qfactoryloader/plugin2'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qfactoryloader/plugin2'
    cd test/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/plugin/qfactoryloader/test/test.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qfont'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qfont'
    cd qfontdatabase/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/text/qfontdatabase/qfontdatabase.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qfactoryloader/test'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qfactoryloader/test'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qfactoryloader'
    cd quuid/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/plugin/quuid/quuid.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/access/qnetworkcookiejar'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/access/qnetworkcookiejar'
    cd qnetworkaccessmanager/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/access/qnetworkaccessmanager/qnetworkaccessmanager.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/quuid'
    cd testProcessUniqueness/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/plugin/quuid/testProcessUniqueness/testProcessUniqueness.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qfontdatabase'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qfontdatabase'
    cd qfontmetrics/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/text/qfontmetrics/qfontmetrics.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/quuid/testProcessUniqueness'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/quuid/testProcessUniqueness'
    cd test/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/plugin/quuid/test/test.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/access/qnetworkaccessmanager'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/access/qnetworkaccessmanager'
    cd qnetworkcookie/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/access/qnetworkcookie/qnetworkcookie.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/quuid/test'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/quuid/test'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/quuid'
    cd qpluginloader/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/plugin/qpluginloader/qpluginloader.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qfontmetrics'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qfontmetrics'
    cd qglyphrun/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/text/qglyphrun/qglyphrun.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qpluginloader'
    cd lib/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/plugin/qpluginloader/lib/lib.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/access/qnetworkcookie'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/access/qnetworkcookie'
    cd qnetworkrequest/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/access/qnetworkrequest/qnetworkrequest.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qglyphrun'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qglyphrun'
    cd qrawfont/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/text/qrawfont/qrawfont.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qpluginloader/lib'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qpluginloader/lib'
    cd theplugin/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/plugin/qpluginloader/theplugin/theplugin.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qrawfont'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qrawfont'
    cd qstatictext/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/text/qstatictext/qstatictext.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qpluginloader/theplugin'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qpluginloader/theplugin'
    cd almostplugin/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/plugin/qpluginloader/almostplugin/almostplugin.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/access/qnetworkrequest'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/access/qnetworkrequest'
    cd qnetworkreply/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/access/qnetworkreply/qnetworkreply.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/access/qnetworkreply'
    cd echo/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/access/qnetworkreply/echo/echo.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qpluginloader/almostplugin'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qpluginloader/almostplugin'
    cd tst/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/plugin/qpluginloader/tst/tst.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/access/qnetworkreply/echo'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/access/qnetworkreply/echo'
    cd test/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/access/qnetworkreply/test/test.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qstatictext'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qstatictext'
    cd qsyntaxhighlighter/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/text/qsyntaxhighlighter/qsyntaxhighlighter.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/access/qnetworkreply/test'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/access/qnetworkreply/test'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/access/qnetworkreply'
    cd spdy/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/access/spdy/spdy.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qpluginloader/tst'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qpluginloader/tst'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qpluginloader'
    cd qplugin/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/plugin/qplugin/qplugin.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qsyntaxhighlighter'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qsyntaxhighlighter'
    cd qtextblock/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/text/qtextblock/qtextblock.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/access/spdy'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/access/spdy'
    cd qnetworkcachemetadata/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/access/qnetworkcachemetadata/qnetworkcachemetadata.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qplugin'
    cd invalidplugin/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/plugin/qplugin/invalidplugin/invalidplugin.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qtextblock'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qtextblock'
    cd qtextcursor/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/text/qtextcursor/qtextcursor.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qplugin/invalidplugin'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qplugin/invalidplugin'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/access/qnetworkcachemetadata'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/access/qnetworkcachemetadata'
    cd debugplugin/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/plugin/qplugin/debugplugin/debugplugin.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qabstractnetworkcache/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/access/qabstractnetworkcache/qabstractnetworkcache.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qplugin/debugplugin'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qplugin/debugplugin'
    cd releaseplugin/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/plugin/qplugin/releaseplugin/releaseplugin.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qtextcursor'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qtextcursor'
    cd qtextdocument/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/text/qtextdocument/qtextdocument.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/access/qabstractnetworkcache'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/access/qabstractnetworkcache'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/access'
    cd bearer/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/bearer/bearer.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qplugin/releaseplugin'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qplugin/releaseplugin'
    ( test -e Makefile.tst_qplugin || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile.tst_qplugin /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/plugin/qplugin/tst_qplugin.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile.tst_qplugin
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qtextdocument'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qtextdocument'
    cd qtextdocumentfragment/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/text/qtextdocumentfragment/qtextdocumentfragment.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/bearer'
    cd qnetworkconfiguration/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/bearer/qnetworkconfiguration/qnetworkconfiguration.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qplugin'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qplugin'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qplugin'
    cd qlibrary/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/plugin/qlibrary/qlibrary.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qtextdocumentfragment'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qtextdocumentfragment'
    cd qtextdocumentlayout/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/text/qtextdocumentlayout/qtextdocumentlayout.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/bearer/qnetworkconfiguration'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/bearer/qnetworkconfiguration'
    cd qnetworkconfigurationmanager/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/bearer/qnetworkconfigurationmanager/qnetworkconfigurationmanager.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qlibrary'
    cd lib/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/plugin/qlibrary/lib/lib.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qtextdocumentlayout'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qtextdocumentlayout'
    cd qtextformat/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/text/qtextformat/qtextformat.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/bearer/qnetworkconfigurationmanager'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/bearer/qnetworkconfigurationmanager'
    cd qnetworkconfigurationmanagerqappless/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/bearer/qnetworkconfigurationmanagerqappless/qnetworkconfigurationmanagerqappless.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qlibrary/lib'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qlibrary/lib'
    cd lib2/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/plugin/qlibrary/lib2/lib2.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/bearer/qnetworkconfigurationmanagerqappless'
    make[5]: Nothing to be done for 'first'.
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/bearer/qnetworkconfigurationmanagerqappless'
    cd qnetworksession/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/bearer/qnetworksession/qnetworksession.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qtextformat'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qtextformat'
    cd qtextlist/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/text/qtextlist/qtextlist.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qlibrary/lib2'
    make[6]: Nothing to be done for 'first'.
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qlibrary/lib2'
    cd tst/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/plugin/qlibrary/tst/tst.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/bearer/qnetworksession'
    cd lackey/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/bearer/qnetworksession/lackey/lackey.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qlibrary/tst'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qlibrary/tst'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin/qlibrary'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/plugin'
    cd serialization/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/serialization/serialization.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qtextlist'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qtextlist'
    cd qtextobject/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/text/qtextobject/qtextobject.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/bearer/qnetworksession/lackey'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/bearer/qnetworksession/lackey'
    cd test/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/bearer/qnetworksession/test/test.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/serialization'
    cd json/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/serialization/json/json.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qtextobject'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qtextobject'
    cd qtextscriptengine/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/text/qtextscriptengine/qtextscriptengine.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/bearer/qnetworksession/test'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/bearer/qnetworksession/test'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/bearer/qnetworksession'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/bearer'
    cd kernel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/kernel/kernel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/serialization/json'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/serialization/json'
    cd qdatastream/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/serialization/qdatastream/qdatastream.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qtextscriptengine'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qtextscriptengine'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/kernel'
    cd qtexttable/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/text/qtexttable/qtexttable.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qdnslookup/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/kernel/qdnslookup/qdnslookup.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/serialization/qdatastream'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/serialization/qdatastream'
    cd qtextstream/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/serialization/qtextstream/qtextstream.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/serialization/qtextstream'
    cd test/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/serialization/qtextstream/test/test.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/kernel/qdnslookup'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/kernel/qdnslookup'
    cd qdnslookup_appless/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/kernel/qdnslookup_appless/qdnslookup_appless.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qtexttable'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qtexttable'
    cd qinputcontrol/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/text/qinputcontrol/qinputcontrol.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/kernel/qdnslookup_appless'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/kernel/qdnslookup_appless'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qinputcontrol'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text/qinputcontrol'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/text'
    cd qnetworkproxyfactory/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/kernel/qnetworkproxyfactory/qnetworkproxyfactory.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd util/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/util/util.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/kernel/qnetworkproxyfactory'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/kernel/qnetworkproxyfactory'
    cd qnetworkproxy/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/kernel/qnetworkproxy/qnetworkproxy.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/util'
    cd qdesktopservices/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/util/qdesktopservices/qdesktopservices.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/kernel/qnetworkproxy'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/kernel/qnetworkproxy'
    cd qnetworkinterface/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/kernel/qnetworkinterface/qnetworkinterface.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/util/qdesktopservices'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/util/qdesktopservices'
    cd qdoublevalidator/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/util/qdoublevalidator/qdoublevalidator.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/kernel/qnetworkinterface'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/kernel/qnetworkinterface'
    cd qnetworkdatagram/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/kernel/qnetworkdatagram/qnetworkdatagram.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/kernel/qnetworkdatagram'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/kernel/qnetworkdatagram'
    cd qnetworkaddressentry/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/kernel/qnetworkaddressentry/qnetworkaddressentry.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/util/qdoublevalidator'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/util/qdoublevalidator'
    cd qintvalidator/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/util/qintvalidator/qintvalidator.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/kernel/qnetworkaddressentry'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/kernel/qnetworkaddressentry'
    cd qhostaddress/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/kernel/qhostaddress/qhostaddress.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/kernel/qhostaddress'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/kernel/qhostaddress'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/kernel'
    cd ssl/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/ssl/ssl.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/util/qintvalidator'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/util/qintvalidator'
    cd qregexpvalidator/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/util/qregexpvalidator/qregexpvalidator.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/ssl'
    cd qsslcertificate/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/ssl/qsslcertificate/qsslcertificate.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/ssl/qsslcertificate'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/ssl/qsslcertificate'
    cd qsslcipher/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/ssl/qsslcipher/qsslcipher.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/util/qregexpvalidator'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/util/qregexpvalidator'
    cd qregularexpressionvalidator/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/util/qregularexpressionvalidator/qregularexpressionvalidator.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/ssl/qsslcipher'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/ssl/qsslcipher'
    cd qsslellipticcurve/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/ssl/qsslellipticcurve/qsslellipticcurve.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/util/qregularexpressionvalidator'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/util/qregularexpressionvalidator'
    cd qshadergenerator/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/util/qshadergenerator/qshadergenerator.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/util/qshadergenerator'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/util/qshadergenerator'
    cd qshadergraph/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/util/qshadergraph/qshadergraph.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/ssl/qsslellipticcurve'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/ssl/qsslellipticcurve'
    cd qsslerror/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/ssl/qsslerror/qsslerror.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/util/qshadergraph'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/util/qshadergraph'
    cd qshadergraphloader/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/util/qshadergraphloader/qshadergraphloader.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/ssl/qsslerror'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/ssl/qsslerror'
    cd qsslkey/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/ssl/qsslkey/qsslkey.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/util/qshadergraphloader'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/util/qshadergraphloader'
    cd qshadernodes/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/util/qshadernodes/qshadernodes.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/ssl/qsslkey'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/ssl/qsslkey'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/ssl'
    cd socket/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/socket/socket.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/util/qshadernodes'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/util/qshadernodes'
    cd qshadernodesloader/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/util/qshadernodesloader/qshadernodesloader.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/serialization/qtextstream/test'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/serialization/qtextstream/test'
    cd stdinProcess/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/serialization/qtextstream/stdinProcess/stdinProcess.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/socket'
    cd qudpsocket/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/socket/qudpsocket/qudpsocket.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/serialization/qtextstream/stdinProcess'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/serialization/qtextstream/stdinProcess'
    cd readAllStdinProcess/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/serialization/qtextstream/readAllStdinProcess/readAllStdinProcess.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/util/qshadernodesloader'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/util/qshadernodesloader'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/util'
    cd itemmodels/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/itemmodels/itemmodels.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/socket/qudpsocket'
    cd clientserver/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/socket/qudpsocket/clientserver/clientserver.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/itemmodels'
    cd qstandarditem/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/itemmodels/qstandarditem/qstandarditem.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/serialization/qtextstream/readAllStdinProcess'
    make[6]: Nothing to be done for 'first'.
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/serialization/qtextstream/readAllStdinProcess'
    cd readLineStdinProcess/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/serialization/qtextstream/readLineStdinProcess/readLineStdinProcess.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/socket/qudpsocket/clientserver'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/socket/qudpsocket/clientserver'
    cd test/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/socket/qudpsocket/test/test.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/serialization/qtextstream/readLineStdinProcess'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/serialization/qtextstream/readLineStdinProcess'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/serialization/qtextstream'
    cd qxmlstream/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/serialization/qxmlstream/qxmlstream.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/socket/qudpsocket/test'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/socket/qudpsocket/test'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/socket/qudpsocket'
    cd qlocalsocket/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/socket/qlocalsocket/qlocalsocket.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/itemmodels/qstandarditem'
    make[5]: Nothing to be done for 'first'.
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/itemmodels/qstandarditem'
    cd qstandarditemmodel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/gui/itemmodels/qstandarditemmodel/qstandarditemmodel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/socket/qlocalsocket'
    cd test/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/socket/qlocalsocket/test/test.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/serialization/qxmlstream'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/serialization/qxmlstream'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/serialization'
    cd statemachine/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/statemachine/statemachine.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/socket/qlocalsocket/test'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/socket/qlocalsocket/test'
    cd socketprocess/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/socket/qlocalsocket/socketprocess/socketprocess.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/itemmodels/qstandarditemmodel'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/itemmodels/qstandarditemmodel'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui/itemmodels'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/gui'
    cd thread/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/thread.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/socket/qlocalsocket/socketprocess'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/socket/qlocalsocket/socketprocess'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/socket/qlocalsocket'
    cd qtcpserver/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/socket/qtcpserver/qtcpserver.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/statemachine'
    cd qstate/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/statemachine/qstate/qstate.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread'
    cd qatomicint/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qatomicint/qatomicint.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/socket/qtcpserver'
    cd test/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/socket/qtcpserver/test/test.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/statemachine/qstate'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/statemachine/qstate'
    cd qstatemachine/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/statemachine/qstatemachine/qstatemachine.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicint'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicint'
    cd qatomicinteger/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qatomicinteger/qatomicinteger.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/statemachine/qstatemachine'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/statemachine/qstatemachine'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/statemachine'
    cd qatomicpointer/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qatomicpointer/qatomicpointer.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/socket/qtcpserver/test'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/socket/qtcpserver/test'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger'
    cd crashingServer/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/socket/qtcpserver/crashingServer/crashingServer.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd char/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qatomicinteger/char/char.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/char'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/char'
    cd char16_t/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qatomicinteger/char16_t/char16_t.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/socket/qtcpserver/crashingServer'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/socket/qtcpserver/crashingServer'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/socket/qtcpserver'
    cd qabstractsocket/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/network/socket/qabstractsocket/qabstractsocket.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/char16_t'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/char16_t'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicpointer'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicpointer'
    cd char32_t/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qatomicinteger/char32_t/char32_t.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd int/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qatomicinteger/int/int.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/socket/qabstractsocket'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/socket/qabstractsocket'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network/socket'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/network'
    cd long/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qatomicinteger/long/long.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/int'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/int'
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/char32_t'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/char32_t'
    cd qresultstore/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qresultstore/qresultstore.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qfuture/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qfuture/qfuture.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/long'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/long'
    cd qptrdiff/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qatomicinteger/qptrdiff/qptrdiff.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qresultstore'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qresultstore'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qfuture'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qfuture'
    cd quintptr/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qatomicinteger/quintptr/quintptr.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd schar/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qatomicinteger/schar/schar.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/qptrdiff'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/qptrdiff'
    cd tools/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/tools.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools'
    cd collections/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/collections/collections.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/quintptr'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/quintptr'
    cd containerapisymmetry/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/containerapisymmetry/containerapisymmetry.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/schar'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/schar'
    cd short/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qatomicinteger/short/short.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/containerapisymmetry'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/containerapisymmetry'
    cd uchar/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qatomicinteger/uchar/uchar.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/short'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/short'
    cd qfuturesynchronizer/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qfuturesynchronizer/qfuturesynchronizer.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/collections'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/collections'
    cd qalgorithms/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qalgorithms/qalgorithms.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/uchar'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/uchar'
    cd uint/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qatomicinteger/uint/uint.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qfuturesynchronizer'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qfuturesynchronizer'
    cd ulong/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qatomicinteger/ulong/ulong.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/uint'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/uint'
    cd opengl/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/opengl/opengl.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/opengl'
    cd qgl/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/opengl/qgl/qgl.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qalgorithms'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qalgorithms'
    cd qarraydata/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qarraydata/qarraydata.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/ulong'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/ulong'
    cd ushort/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qatomicinteger/ushort/ushort.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/opengl/qgl'
    make[4]: Nothing to be done for 'first'.
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/opengl/qgl'
    cd qglbuffer/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/opengl/qglbuffer/qglbuffer.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/ushort'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/ushort'
    cd wchar_t/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qatomicinteger/wchar_t/wchar_t.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qarraydata'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qarraydata'
    cd qarraydata_strictiterators/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qarraydata_strictiterators/qarraydata_strictiterators.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/opengl/qglbuffer'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/opengl/qglbuffer'
    cd qglfunctions/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/opengl/qglfunctions/qglfunctions.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/wchar_t'
    make[6]: Nothing to be done for 'first'.
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger/wchar_t'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qatomicinteger'
    cd qmutex/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qmutex/qmutex.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/opengl/qglfunctions'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/opengl/qglfunctions'
    cd qglthreads/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/opengl/qglthreads/qglthreads.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qarraydata_strictiterators'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qarraydata_strictiterators'
    cd qbitarray/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qbitarray/qbitarray.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qmutex'
    make[5]: Nothing to be done for 'first'.
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qmutex'
    cd qmutexlocker/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qmutexlocker/qmutexlocker.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/opengl/qglthreads'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/opengl/qglthreads'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/opengl'
    cd qreadlocker/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qreadlocker/qreadlocker.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qbitarray'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qbitarray'
    cd qbytearray/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qbytearray/qbytearray.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qmutexlocker'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qmutexlocker'
    cd qbytearraylist/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qbytearraylist/qbytearraylist.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qreadlocker'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qreadlocker'
    cd qreadwritelock/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qreadwritelock/qreadwritelock.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qbytearray'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qbytearray'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qbytearraylist'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qbytearraylist'
    cd qsemaphore/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qsemaphore/qsemaphore.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qbytearraymatcher/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qbytearraymatcher/qbytearraymatcher.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qreadwritelock'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qreadwritelock'
    cd qbytedatabuffer/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qbytedatabuffer/qbytedatabuffer.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qbytearraymatcher'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qbytearraymatcher'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qbytedatabuffer'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qbytedatabuffer'
    cd sql/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/sql/sql.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qcache/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qcache/qcache.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qsemaphore'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qsemaphore'
    cd qthread/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qthread/qthread.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql'
    cd kernel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/sql/kernel/kernel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/kernel'
    cd qsqlfield/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/sql/kernel/qsqlfield/qsqlfield.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qcache'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qcache'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qthread'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qthread'
    cd qchar/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qchar/qchar.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qthreadonce/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qthreadonce/qthreadonce.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/kernel/qsqlfield'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/kernel/qsqlfield'
    cd qsqldatabase/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/sql/kernel/qsqldatabase/qsqldatabase.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qchar'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qchar'
    cd qcollator/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qcollator/qcollator.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qthreadonce'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qthreadonce'
    cd qthreadpool/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qthreadpool/qthreadpool.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qthreadpool'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qthreadpool'
    cd qthreadstorage/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qthreadstorage/qthreadstorage.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/kernel/qsqldatabase'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/kernel/qsqldatabase'
    cd qsqlerror/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/sql/kernel/qsqlerror/qsqlerror.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qcollator'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qcollator'
    cd qcommandlineparser/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qcommandlineparser/qcommandlineparser.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qthreadstorage'
    cd crashonexit/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qthreadstorage/crashonexit/crashonexit.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qcommandlineparser'
    ( test -e Makefile.tst_qcommandlineparser || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile.tst_qcommandlineparser /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qcommandlineparser/tst_qcommandlineparser.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile.tst_qcommandlineparser
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/kernel/qsqlerror'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/kernel/qsqlerror'
    cd qsqldriver/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/sql/kernel/qsqldriver/qsqldriver.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qthreadstorage/crashonexit'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qthreadstorage/crashonexit'
    cd test/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qthreadstorage/test/test.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/kernel/qsqldriver'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/kernel/qsqldriver'
    cd qsqlquery/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/sql/kernel/qsqlquery/qsqlquery.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qcommandlineparser'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qcommandlineparser'
    cd testhelper/ && ( test -e Makefile.qcommandlineparser_test_helper || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile.qcommandlineparser_test_helper /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qcommandlineparser/testhelper/qcommandlineparser_test_helper.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile.qcommandlineparser_test_helper
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qthreadstorage/test'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qthreadstorage/test'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qthreadstorage'
    cd qwaitcondition/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qwaitcondition/qwaitcondition.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qcommandlineparser/testhelper'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qcommandlineparser/testhelper'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qcommandlineparser'
    cd qcontiguouscache/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qcontiguouscache/qcontiguouscache.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/kernel/qsqlquery'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/kernel/qsqlquery'
    cd qsqlrecord/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/sql/kernel/qsqlrecord/qsqlrecord.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qwaitcondition'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qwaitcondition'
    cd qwritelocker/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qwritelocker/qwritelocker.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qcontiguouscache'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qcontiguouscache'
    cd qcryptographichash/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qcryptographichash/qcryptographichash.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/kernel/qsqlrecord'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/kernel/qsqlrecord'
    cd qsqlthread/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/sql/kernel/qsqlthread/qsqlthread.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qwritelocker'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qwritelocker'
    cd qfuturewatcher/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/thread/qfuturewatcher/qfuturewatcher.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qcryptographichash'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qcryptographichash'
    cd qdate/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qdate/qdate.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qfuturewatcher'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread/qfuturewatcher'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/thread'
    cd qdatetime/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qdatetime/qdatetime.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/kernel/qsqlthread'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/kernel/qsqlthread'
    cd qsql/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/sql/kernel/qsql/qsql.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qdatetime'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qdatetime'
    cd qsqlresult/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/sql/kernel/qsqlresult/qsqlresult.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qdate'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qdate'
    cd qeasingcurve/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qeasingcurve/qeasingcurve.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/kernel/qsql'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/kernel/qsql'
    cd qexplicitlyshareddatapointer/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qexplicitlyshareddatapointer/qexplicitlyshareddatapointer.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/kernel/qsqlresult'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/kernel/qsqlresult'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/kernel'
    cd models/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/sql/models/models.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qeasingcurve'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qeasingcurve'
    cd testlib/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/testlib.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/models'
    cd qsqlquerymodel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/sql/models/qsqlquerymodel/qsqlquerymodel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qexplicitlyshareddatapointer'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qexplicitlyshareddatapointer'
    cd qfreelist/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qfreelist/qfreelist.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib'
    cd qsignalspy/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/qsignalspy/qsignalspy.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/models/qsqlquerymodel'
    make[5]: Nothing to be done for 'first'.
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/models/qsqlquerymodel'
    cd qsqlrelationaltablemodel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/sql/models/qsqlrelationaltablemodel/qsqlrelationaltablemodel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qfreelist'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qfreelist'
    cd qhash/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qhash/qhash.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/qsignalspy'
    make[4]: Nothing to be done for 'first'.
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/qsignalspy'
    cd selftests/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/selftests.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qhash'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qhash'
    cd qhash_strictiterators/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qhash_strictiterators/qhash_strictiterators.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/models/qsqlrelationaltablemodel'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/models/qsqlrelationaltablemodel'
    cd qsqltablemodel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/sql/models/qsqltablemodel/qsqltablemodel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests'
    cd assert/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/assert/assert.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qhash_strictiterators'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qhash_strictiterators'
    cd qhashfunctions/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qhashfunctions/qhashfunctions.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/models/qsqltablemodel'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/models/qsqltablemodel'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql/models'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/sql'
    cd qlatin1string/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qlatin1string/qlatin1string.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/assert'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/assert'
    cd badxml/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/badxml/badxml.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qhashfunctions'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qhashfunctions'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qlatin1string'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qlatin1string'
    cd benchlibcallgrind/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/benchlibcallgrind/benchlibcallgrind.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qline/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qline/qline.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/badxml'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/badxml'
    cd qlinkedlist/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qlinkedlist/qlinkedlist.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/benchlibcallgrind'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/benchlibcallgrind'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qline'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qline'
    cd xml/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/xml/xml.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd benchlibcounting/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/benchlibcounting/benchlibcounting.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qlinkedlist'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qlinkedlist'
    cd qlist/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qlist/qlist.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/xml'
    cd dom/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/xml/dom/dom.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qlist'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qlist'
    cd qlist_strictiterators/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qlist_strictiterators/qlist_strictiterators.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/benchlibcounting'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/benchlibcounting'
    cd benchlibeventcounter/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/benchlibeventcounter/benchlibeventcounter.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/xml/dom'
    cd qdom/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/xml/dom/qdom/qdom.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qlist_strictiterators'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qlist_strictiterators'
    cd qlocale/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qlocale/qlocale.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/benchlibeventcounter'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/benchlibeventcounter'
    cd benchliboptions/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/benchliboptions/benchliboptions.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qlocale'
    cd test/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qlocale/test/test.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/xml/dom/qdom'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/xml/dom/qdom'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/xml/dom'
    cd sax/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/xml/sax/sax.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qlocale/test'
    make[6]: Nothing to be done for 'first'.
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qlocale/test'
    cd syslocaleapp/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qlocale/syslocaleapp/syslocaleapp.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/benchliboptions'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/benchliboptions'
    cd benchlibtickcounter/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/benchlibtickcounter/benchlibtickcounter.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/xml/sax'
    cd qxml/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/xml/sax/qxml/qxml.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qlocale/syslocaleapp'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qlocale/syslocaleapp'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qlocale'
    cd qmap/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qmap/qmap.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/benchlibtickcounter'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/benchlibtickcounter'
    cd benchlibwalltime/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/benchlibwalltime/benchlibwalltime.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/xml/sax/qxml'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/xml/sax/qxml'
    cd qxmlinputsource/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/xml/sax/qxmlinputsource/qxmlinputsource.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/benchlibwalltime'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/benchlibwalltime'
    cd blacklisted/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/blacklisted/blacklisted.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qmap'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qmap'
    cd qmap_strictiterators/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qmap_strictiterators/qmap_strictiterators.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/blacklisted'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/blacklisted'
    cd cmptest/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/cmptest/cmptest.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/xml/sax/qxmlinputsource'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/xml/sax/qxmlinputsource'
    cd qxmlsimplereader/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/xml/sax/qxmlsimplereader/qxmlsimplereader.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/cmptest'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/cmptest'
    cd commandlinedata/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/commandlinedata/commandlinedata.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qmap_strictiterators'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qmap_strictiterators'
    cd qmargins/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qmargins/qmargins.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/commandlinedata'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/commandlinedata'
    cd counting/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/counting/counting.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/xml/sax/qxmlsimplereader'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/xml/sax/qxmlsimplereader'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/xml/sax'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/xml'
    cd crashes/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/crashes/crashes.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qmargins'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qmargins'
    cd qmessageauthenticationcode/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qmessageauthenticationcode/qmessageauthenticationcode.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/counting'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/counting'
    cd qpair/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qpair/qpair.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qmessageauthenticationcode'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qmessageauthenticationcode'
    cd concurrent/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/concurrent/concurrent.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/crashes'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/crashes'
    cd datatable/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/datatable/datatable.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qpair'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qpair'
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/concurrent'
    cd qpoint/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qpoint/qpoint.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qtconcurrentfilter/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/concurrent/qtconcurrentfilter/qtconcurrentfilter.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/datatable'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/datatable'
    cd datetime/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/datetime/datetime.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/datetime'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/datetime'
    cd deleteLater/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/deleteLater/deleteLater.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/concurrent/qtconcurrentfilter'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/concurrent/qtconcurrentfilter'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qpoint'
    make[5]: Nothing to be done for 'first'.
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qpoint'
    cd qtconcurrentiteratekernel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/concurrent/qtconcurrentiteratekernel/qtconcurrentiteratekernel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qpointf/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qpointf/qpointf.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/concurrent/qtconcurrentiteratekernel'
    make[4]: Nothing to be done for 'first'.
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/concurrent/qtconcurrentiteratekernel'
    cd qtconcurrentmap/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/concurrent/qtconcurrentmap/qtconcurrentmap.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/deleteLater'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/deleteLater'
    cd deleteLater_noApp/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/deleteLater_noApp/deleteLater_noApp.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qpointf'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qpointf'
    cd qqueue/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qqueue/qqueue.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/concurrent/qtconcurrentmap'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/concurrent/qtconcurrentmap'
    cd qtconcurrentmedian/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/concurrent/qtconcurrentmedian/qtconcurrentmedian.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/concurrent/qtconcurrentmedian'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/concurrent/qtconcurrentmedian'
    cd qtconcurrentrun/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/concurrent/qtconcurrentrun/qtconcurrentrun.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/deleteLater_noApp'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/deleteLater_noApp'
    cd differentexec/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/differentexec/differentexec.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qqueue'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qqueue'
    cd qrect/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qrect/qrect.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qrect'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qrect'
    cd qregexp/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qregexp/qregexp.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/concurrent/qtconcurrentrun'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/concurrent/qtconcurrentrun'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/differentexec'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/differentexec'
    cd qtconcurrentthreadengine/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/concurrent/qtconcurrentthreadengine/qtconcurrentthreadengine.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd exceptionthrow/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/exceptionthrow/exceptionthrow.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qregexp'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qregexp'
    cd qregularexpression/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qregularexpression/qregularexpression.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qregularexpression'
    cd defaultoptimize/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qregularexpression/defaultoptimize/defaultoptimize.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/exceptionthrow'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/exceptionthrow'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/concurrent/qtconcurrentthreadengine'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/concurrent/qtconcurrentthreadengine'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/concurrent'
    cd expectfail/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/expectfail/expectfail.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd failcleanup/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/failcleanup/failcleanup.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qregularexpression/defaultoptimize'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qregularexpression/defaultoptimize'
    cd forceoptimize/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qregularexpression/forceoptimize/forceoptimize.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/failcleanup'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/failcleanup'
    cd qabstractitemmodeltester/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/qabstractitemmodeltester/qabstractitemmodeltester.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/expectfail'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/expectfail'
    cd failinit/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/failinit/failinit.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/qabstractitemmodeltester'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/qabstractitemmodeltester'
    cd failinitdata/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/failinitdata/failinitdata.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qregularexpression/forceoptimize'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qregularexpression/forceoptimize'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qregularexpression'
    cd qringbuffer/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qringbuffer/qringbuffer.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/failinitdata'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/failinitdata'
    cd qscopedpointer/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qscopedpointer/qscopedpointer.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/failinit'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/failinit'
    cd fetchbogus/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/fetchbogus/fetchbogus.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qscopedpointer'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qscopedpointer'
    cd findtestdata/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/findtestdata/findtestdata.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qringbuffer'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qringbuffer'
    cd qscopedvaluerollback/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qscopedvaluerollback/qscopedvaluerollback.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/fetchbogus'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/fetchbogus'
    cd qset/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qset/qset.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/findtestdata'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/findtestdata'
    cd float/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/float/float.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qscopedvaluerollback'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qscopedvaluerollback'
    cd globaldata/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/globaldata/globaldata.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/globaldata'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/globaldata'
    cd other/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/other/other.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qset'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qset'
    cd qsharedpointer/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qsharedpointer/qsharedpointer.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/float'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/float'
    cd longstring/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/longstring/longstring.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other'
    cd gestures/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/other/gestures/gestures.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/gestures'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/gestures'
    cd lancelot/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/other/lancelot/lancelot.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qsharedpointer'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qsharedpointer'
    cd qsize/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qsize/qsize.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/longstring'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/longstring'
    cd maxwarnings/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/maxwarnings/maxwarnings.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qsize'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qsize'
    cd qsizef/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qsizef/qsizef.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/lancelot'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/lancelot'
    cd languagechange/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/other/languagechange/languagechange.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/maxwarnings'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/maxwarnings'
    cd multiexec/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/multiexec/multiexec.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qsizef'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qsizef'
    cd qstl/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qstl/qstl.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstl'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstl'
    cd qstring/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qstring/qstring.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/languagechange'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/languagechange'
    cd networkselftest/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/other/networkselftest/networkselftest.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/multiexec'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/multiexec'
    cd pairdiagnostics/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/pairdiagnostics/pairdiagnostics.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/networkselftest'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/networkselftest'
    cd qaccessibility/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/other/qaccessibility/qaccessibility.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstring'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstring'
    cd qstring_no_cast_from_bytearray/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qstring_no_cast_from_bytearray/qstring_no_cast_from_bytearray.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/pairdiagnostics'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/pairdiagnostics'
    cd printdatatags/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/printdatatags/printdatatags.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/qaccessibility'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/qaccessibility'
    cd qcomplextext/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/other/qcomplextext/qcomplextext.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstring_no_cast_from_bytearray'
    make[5]: Nothing to be done for 'first'.
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstring_no_cast_from_bytearray'
    cd qstringapisymmetry/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qstringapisymmetry/qstringapisymmetry.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/qcomplextext'
    make[4]: Nothing to be done for 'first'.
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/qcomplextext'
    cd qfocusevent/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/other/qfocusevent/qfocusevent.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/printdatatags'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/printdatatags'
    cd printdatatagswithglobaltags/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/printdatatagswithglobaltags/printdatatagswithglobaltags.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstringapisymmetry'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstringapisymmetry'
    cd qstringbuilder/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qstringbuilder/qstringbuilder.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/qfocusevent'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/qfocusevent'
    cd qnetworkaccessmanager_and_qprogressdialog/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/other/qnetworkaccessmanager_and_qprogressdialog/qnetworkaccessmanager_and_qprogressdialog.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/printdatatagswithglobaltags'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/printdatatagswithglobaltags'
    cd qexecstringlist/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/qexecstringlist/qexecstringlist.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstringbuilder'
    cd qstringbuilder1/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qstringbuilder/qstringbuilder1/qstringbuilder1.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/qnetworkaccessmanager_and_qprogressdialog'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/qnetworkaccessmanager_and_qprogressdialog'
    cd qobjectrace/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/other/qobjectrace/qobjectrace.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstringbuilder/qstringbuilder1'
    make[6]: Nothing to be done for 'first'.
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstringbuilder/qstringbuilder1'
    cd qstringbuilder2/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qstringbuilder/qstringbuilder2/qstringbuilder2.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/qexecstringlist'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/qexecstringlist'
    cd silent/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/silent/silent.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstringbuilder/qstringbuilder2'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstringbuilder/qstringbuilder2'
    cd qstringbuilder3/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qstringbuilder/qstringbuilder3/qstringbuilder3.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/qobjectrace'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/qobjectrace'
    cd qsharedpointer_and_qwidget/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/other/qsharedpointer_and_qwidget/qsharedpointer_and_qwidget.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/silent'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/silent'
    cd singleskip/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/singleskip/singleskip.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstringbuilder/qstringbuilder3'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstringbuilder/qstringbuilder3'
    cd qstringbuilder4/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qstringbuilder/qstringbuilder4/qstringbuilder4.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/qsharedpointer_and_qwidget'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/qsharedpointer_and_qwidget'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/singleskip'
    cd qprocess_and_guieventloop/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/other/qprocess_and_guieventloop/qprocess_and_guieventloop.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/singleskip'
    cd skip/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/skip/skip.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/qprocess_and_guieventloop'
    cd write-read-write/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/other/qprocess_and_guieventloop/write-read-write/write-read-write.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/qprocess_and_guieventloop/write-read-write'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/qprocess_and_guieventloop/write-read-write'
    ( test -e Makefile.test || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile.test /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/other/qprocess_and_guieventloop/test.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile.test
    make[6]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstringbuilder/qstringbuilder4'
    make[6]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstringbuilder/qstringbuilder4'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstringbuilder'
    cd qstringiterator/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qstringiterator/qstringiterator.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/skip'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/skip'
    cd skipcleanup/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/skipcleanup/skipcleanup.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/qprocess_and_guieventloop'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/qprocess_and_guieventloop'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/qprocess_and_guieventloop'
    cd qtokenautomaton/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/other/qtokenautomaton/qtokenautomaton.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstringiterator'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstringiterator'
    cd qstringlist/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qstringlist/qstringlist.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/qtokenautomaton'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/qtokenautomaton'
    cd toolsupport/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/other/toolsupport/toolsupport.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/skipcleanup'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/skipcleanup'
    cd skipinit/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/skipinit/skipinit.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/toolsupport'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other/toolsupport'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/other'
    cd skipinitdata/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/skipinitdata/skipinitdata.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstringlist'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstringlist'
    cd qstringmatcher/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qstringmatcher/qstringmatcher.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/skipinitdata'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/skipinitdata'
    cd qstringref/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qstringref/qstringref.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/skipinit'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/skipinit'
    cd sleep/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/sleep/sleep.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/sleep'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/sleep'
    cd strcmp/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/strcmp/strcmp.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstringmatcher'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstringmatcher'
    cd subtest/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/subtest/subtest.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstringref'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstringref'
    cd qstringview/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qstringview/qstringview.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/strcmp'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/strcmp'
    cd qtextboundaryfinder/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qtextboundaryfinder/qtextboundaryfinder.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstringview'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qstringview'
    cd widgets/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/widgets.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/subtest'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/subtest'
    cd verbose1/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/verbose1/verbose1.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qtextboundaryfinder'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qtextboundaryfinder'
    cd qtime/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qtime/qtime.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets'
    cd dialogs/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/dialogs/dialogs.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/verbose1'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/verbose1'
    cd verbose2/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/verbose2/verbose2.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/dialogs'
    cd qcolordialog/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/dialogs/qcolordialog/qcolordialog.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qtime'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qtime'
    cd qtimezone/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qtimezone/qtimezone.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/verbose2'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/verbose2'
    cd verifyexceptionthrown/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/verifyexceptionthrown/verifyexceptionthrown.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qtimezone'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qtimezone'
    cd qtimeline/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qtimeline/qtimeline.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/dialogs/qcolordialog'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/dialogs/qcolordialog'
    cd qdialog/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/dialogs/qdialog/qdialog.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qtimeline'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qtimeline'
    cd qvarlengtharray/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qvarlengtharray/qvarlengtharray.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/verifyexceptionthrown'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/verifyexceptionthrown'
    cd warnings/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/warnings/warnings.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/dialogs/qdialog'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/dialogs/qdialog'
    cd qerrormessage/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/dialogs/qerrormessage/qerrormessage.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qvarlengtharray'
    make[5]: Nothing to be done for 'first'.
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qvarlengtharray'
    cd qvector/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qvector/qvector.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/dialogs/qerrormessage'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/dialogs/qerrormessage'
    cd qfiledialog/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/dialogs/qfiledialog/qfiledialog.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/warnings'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/warnings'
    cd xunit/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/xunit/xunit.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/dialogs/qfiledialog'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/dialogs/qfiledialog'
    cd qfiledialog2/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/dialogs/qfiledialog2/qfiledialog2.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qvector'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qvector'
    cd qvector_strictiterators/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qvector_strictiterators/qvector_strictiterators.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/xunit'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/xunit'
    cd mouse/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/mouse/mouse.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/dialogs/qfiledialog2'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/dialogs/qfiledialog2'
    cd qfilesystemmodel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/dialogs/qfilesystemmodel/qfilesystemmodel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qvector_strictiterators'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qvector_strictiterators'
    cd qversionnumber/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/corelib/tools/qversionnumber/qversionnumber.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/mouse'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/mouse'
    cd test/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/testlib/selftests/test/test.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/dialogs/qfilesystemmodel'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/dialogs/qfilesystemmodel'
    cd qfontdialog/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/dialogs/qfontdialog/qfontdialog.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/dialogs/qfontdialog'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/dialogs/qfontdialog'
    cd qinputdialog/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/dialogs/qinputdialog/qinputdialog.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qversionnumber'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools/qversionnumber'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib/tools'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/corelib'
    cd qmessagebox/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/dialogs/qmessagebox/qmessagebox.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/dialogs/qinputdialog'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/dialogs/qinputdialog'
    cd effects/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/effects/effects.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/dialogs/qmessagebox'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/dialogs/qmessagebox'
    cd qprogressdialog/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/dialogs/qprogressdialog/qprogressdialog.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/test'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests/test'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib/selftests'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/testlib'
    cd qwizard/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/dialogs/qwizard/qwizard.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/effects'
    cd qgraphicseffect/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/effects/qgraphicseffect/qgraphicseffect.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/dialogs/qprogressdialog'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/dialogs/qprogressdialog'
    cd qpixmapfilter/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/effects/qpixmapfilter/qpixmapfilter.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/effects/qgraphicseffect'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/effects/qgraphicseffect'
    cd printsupport/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/printsupport/printsupport.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/dialogs/qwizard'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/dialogs/qwizard'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/dialogs'
    cd graphicsview/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/graphicsview/graphicsview.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[3]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/printsupport'
    cd dialogs/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/printsupport/dialogs/dialogs.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/graphicsview'
    cd qgraphicseffectsource/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/graphicsview/qgraphicseffectsource/qgraphicseffectsource.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/effects/qpixmapfilter'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/effects/qpixmapfilter'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/effects'
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/printsupport/dialogs'
    cd qgraphicsgridlayout/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/graphicsview/qgraphicsgridlayout/qgraphicsgridlayout.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qabstractprintdialog/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/printsupport/dialogs/qabstractprintdialog/qabstractprintdialog.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/graphicsview/qgraphicseffectsource'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/graphicsview/qgraphicseffectsource'
    cd kernel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/printsupport/kernel/kernel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/printsupport/kernel'
    cd qprintdevice/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/printsupport/kernel/qprintdevice/qprintdevice.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/graphicsview/qgraphicsgridlayout'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/graphicsview/qgraphicsgridlayout'
    cd qgraphicsitemanimation/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/graphicsview/qgraphicsitemanimation/qgraphicsitemanimation.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/printsupport/dialogs/qabstractprintdialog'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/printsupport/dialogs/qabstractprintdialog'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/printsupport/dialogs'
    cd qgraphicslayout/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/graphicsview/qgraphicslayout/qgraphicslayout.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/graphicsview/qgraphicsitemanimation'
    make[5]: *** No rule to make target '.obj/tst_qgraphicsitemanimation.o', needed by 'tst_qgraphicsitemanimation'. Stop.
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/graphicsview/qgraphicsitemanimation'
    Makefile:104: recipe for target 'sub-qgraphicsitemanimation-make_first' failed
    make[4]: *** [sub-qgraphicsitemanimation-make_first] Error 2
    make[4]: *** Waiting for unfinished jobs....
    cd qprinter/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/printsupport/kernel/qprinter/qprinter.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/printsupport/kernel/qprintdevice'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/printsupport/kernel/qprintdevice'
    cd itemviews/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/itemviews/itemviews.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/printsupport/kernel/qprinter'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/printsupport/kernel/qprinter'
    cd qprinterinfo/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/printsupport/kernel/qprinterinfo/qprinterinfo.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/graphicsview/qgraphicslayout'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/graphicsview/qgraphicslayout'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/graphicsview'
    Makefile:101: recipe for target 'sub-graphicsview-make_first' failed
    make[3]: *** [sub-graphicsview-make_first] Error 2
    make[3]: *** Waiting for unfinished jobs....
    make[4]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews'
    cd qabstractitemview/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/itemviews/qabstractitemview/qabstractitemview.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    cd qdatawidgetmapper/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/itemviews/qdatawidgetmapper/qdatawidgetmapper.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/printsupport/kernel/qprinterinfo'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/printsupport/kernel/qprinterinfo'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/printsupport/kernel'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/printsupport'
    cd qdirmodel/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/itemviews/qdirmodel/qdirmodel.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qdatawidgetmapper'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qdatawidgetmapper'
    cd qfileiconprovider/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/itemviews/qfileiconprovider/qfileiconprovider.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qdirmodel'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qdirmodel'
    cd qheaderview/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/itemviews/qheaderview/qheaderview.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qabstractitemview'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qabstractitemview'
    cd qitemdelegate/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/itemviews/qitemdelegate/qitemdelegate.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qfileiconprovider'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qfileiconprovider'
    cd qitemeditorfactory/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/itemviews/qitemeditorfactory/qitemeditorfactory.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qheaderview'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qheaderview'
    cd qitemview/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/itemviews/qitemview/qitemview.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qitemdelegate'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qitemdelegate'
    cd qlistview/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/itemviews/qlistview/qlistview.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qitemeditorfactory'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qitemeditorfactory'
    cd qtableview/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/itemviews/qtableview/qtableview.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qlistview'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qlistview'
    cd qtablewidget/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/itemviews/qtablewidget/qtablewidget.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qitemview'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qitemview'
    cd qtreeview/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/itemviews/qtreeview/qtreeview.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qtablewidget'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qtablewidget'
    cd qtreewidget/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/itemviews/qtreewidget/qtreewidget.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qtableview'
    make[5]: Nothing to be done for 'first'.
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qtableview'
    cd qtreewidgetitemiterator/ && ( test -e Makefile || /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/recipe-sysroot-native/usr/bin/qmake -o Makefile /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/git/tests/auto/widgets/itemviews/qtreewidgetitemiterator/qtreewidgetitemiterator.pro -qtconf /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/bin/qt.conf ) && make -f Makefile
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qtreeview'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qtreeview'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qtreewidget'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qtreewidget'
    make[5]: Entering directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qtreewidgetitemiterator'
    make[5]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews/qtreewidgetitemiterator'
    make[4]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets/itemviews'
    make[3]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto/widgets'
    Makefile:305: recipe for target 'sub-widgets-make_first' failed
    make[2]: *** [sub-widgets-make_first] Error 2
    make[2]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests/auto'
    Makefile:45: recipe for target 'sub-auto-make_first' failed
    make[1]: *** [sub-auto-make_first] Error 2
    make[1]: Leaving directory '/home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/build/tests'
    Makefile:98: recipe for target 'sub-tests-make_first' failed
    make: *** [sub-tests-make_first] Error 2
    ERROR: oe_runmake failed
    WARNING: /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/temp/run.do_compile.6504:1 exit 1 from 'exit 1'
    ERROR: Function failed: do_compile (log file is located at /home/tshelbur/sandbox/Jacinto7/ti-processor-sdk-linux-automotive-j7-evm-06_01_00_05/yocto-build/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/temp/log.do_compile.6504)
    I checked the same package build log in the release build logs.
    The required object .obj/tst_qgraphicsitemanimation.o is built correctly. There is no failure.
    You might want to rerun the compilation for qtbase again.
    To do that, got to qtbase directory
    cd YOCTO_BUILD_DIR/build/arago-tmp-external-arm-toolchain/work/aarch64-linux/qtbase/5.11.3+gitAUTOINC+08de243eaa-r0.arago16/temp
    ./run.do_compile
    This will rebuild the failed package. If this works, then you can continue to build the filesystem.
    Nikhil D
  • I did this but I still get the following erros at the end of the log. Do I need to clean and rebuild or can I somehow delete the downloaded qtbase files to force the system to download them again in case they were corrupted initially?
    WARNING: ./run.do_compile:1 exit 1 from 'exit 1'
    You can run the yocto build with TOOLCHAIN_BASE=xxx MACHINE=yyy bitbakce-C fetch qtbase
    To force every step from fetch.
    Nikhil D
  • I haven't heard back from you, I'm assuming you were able to resolve your issue.
    If not, just post a reply below (or create a new thread if the thread has locked due to time-out).
  • Hi Nikhil
    I m there this friday and be back with more details
    thank you veyr much
    best regards
    Carlo
    Did you have any update?
    Nikhil D
