TDA2HG: linux boot fail based on VSDK 03 05
Part Number: TDA2HG
Other Parts Discussed in Thread: DRA742, PCF8575, PMP
We use TDA2HG device. The Linux  will boot fail on custom board based on VSDK 03 05. Could you help to have a look?
Terence
U-Boot 2016.05 (Oct 28 2019 - 16:19:38 +0800)
CPU : DRA752-GP ES2.0
Model: TI DRA742
Board: DRA74x EVM REV
DRAM: 1 GiB
MMC: i2c_write: error waiting for data ACK (status=0x116)
pcf8575_i2c_write_le16 i2c write failed to addr 21
OMAP SD/MMC: 0, OMAP SD/MMC: 1
*** Warning - bad CRC, using default environment
Warning: fastboot.board_rev: unknown board revision
GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
part_get_info_efi: *** ERROR: Invalid GPT ***
part_get_info_efi: *** ERROR: Invalid Backup GPT ***
ERROR: cannot find partition: 'userdata'
at arch/arm/cpu/armv7/omap-common/utils.c:199/mmc_get_part_size()
Warning: fastboot.userdata_size: unable to calc
SCSI: SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
scanning bus for devices...
Found 0 device(s).
Net:
Warning: ethernet@48484000 using MAC address from ROM
eth0: ethernet@48484000
Hit any key to stop autoboot: 0
=> MC: i2c_write: error waiting for data ACK (status=0x116)
Unknown command 'MC:' - try 'help'
=> pcf2> MC: i2c_write: error waiting for data ACK (status=0x116>>
    I see so may errors in the log. (MMC, i2c, SATA)
    Have you ported the u-boot to your custom board?
    Can you be specific where you need help? What step in the u-boot is failing?
    Nikhil D
  • Hi Nikhil,
    We have ported the u-boot to our custom board.  The most boards can boot normal. We don't understand below log:
    What do you mean by 'most boards boot fine'?
    Is this issue only on a specific board? Is this any issue with the specific MMC card being used?
    Nikhil D
  • Hi Nikhil,
    Yes,  this issue only on a specific board. We use the same code, include SD boot & EMMC boot.
    Terence
    If this is happening on a custom board, I doubt it is some issue with the i2c connection.
    The error message is regarding sending i2c messages to configure the GPIO expanders.
    Nikhil D
