WMA encoder integration into codec server
Hi
I integrated the WMA encoder in the CODEC server package.
While trying to build the codec server, i get error as below
Also i have attached the entire build log please checka and let us know your feedback
; package ti.sdo.ce.osal.bios [in /home/magesh/dvsdk/dvsdk_3_01_00_10/codec_engine_2_25_02_11/packages/ti/sdo/ce/osal/bios/] was built using 'ti.targets.C64P' [1,0,6.0,16]
; package ti.bios.utils [in /home/magesh/dvsdk/dvsdk_3_01_00_10/biosutils_1_02_02/packages/ti/bios/utils/] was built using 'ti.targets.C64P' [1,0,6.0,14]
will link with ti.sdo.ce.universal:lib/release/universal.a64P
will link with ti.sdo.ce.image1:lib/release/imgdec1.a64P;lib/release/imgenc1.a64P
will link with ti.sdo.ce.video1:lib/release/viddec1.a64P;lib/release/videnc1.a64P
will link with ti.sdo.ce.video2:lib/release/viddec2.a64P
will link with ti.sdo.ce.speech1:lib/release/sphdec1.a64P;lib/release/sphenc1.a64P
will link with ti.sdo.ce.audio1:lib/release/auddec1.a64P;lib/release/audenc1.a64P
will link with ti.sdo.ce.bioslog:lib/release/bioslog.a64P
will link with ti.sdo.ce:lib/release/ce.a64P
will link with ti.sdo.ce.alg:lib/release/Algorithm_BIOS.a64P
will link with ti.sdo.ce.ipc.bios:lib/release/ipc_bios.a64P
will link with ti.sdo.ce.osal.bios:lib/osal_bios.a64P
will link with ti.sdo.ce.osal.bios:lib/osal_bios_pwrm.a64P
will link with ti.bios.utils:lib/utils.a64P
will link with ti.sdo.fc.acpy3:lib/release/acpy3.a64P
will link with ti.sdo.fc.memutils:lib/release/memutils.a64P
will link with ti.sdo.ce.node:lib/release/node.a64P
will link with ti.sdo.ce.utils.xdm:lib/release/XdmUtils.a64P
will link with ti.sdo.fc.dman3:lib/release/dman3Cfg.a64P
will link with ti.sdo.fc.dskt2:lib/release/dskt2.a64P
will link with ti.sdo.utils.trace:lib/release/gt.a64P
will link with ti.sdo.codecs.wmaenc:null
will link with ti.sdo.codecs.deinterlacer:lib/i2p_ti.l64p
will link with ti.sdo.codecs.mpeg4enc:lib/mp4venc_ti.l64P
will link with ti.sdo.codecs.mpeg4dec:lib/m4h3dec_ti.l64P
will link with ti.sdo.codecs.mpeg2dec:lib/mpeg2vdec_ti.l64P
will link with ti.sdo.codecs.jpegenc:lib/dmjpge_tigem.l64P
will link with ti.sdo.codecs.jpegdec:lib/jpegdec_ti.l64P
will link with ti.sdo.codecs.h264enc:lib/h264venc_ti.l64P
will link with ti.sdo.codecs.h264dec:lib/h264vdec_ti.l64P
will link with ti.sdo.codecs.g711enc:lib/g711enc_tii.l64P
will link with ti.sdo.codecs.g711dec:lib/g711dec_tii.l64P
will link with ti.sdo.codecs.aachedec:lib/aacdec_tii.l64P
rm -f package/cfg/bin/cs/main.o64P
# cl64P main.c ...
/home/magesh/dvsdk/dvsdk_3_01_00_10/cs1omap3530_1_01_00/bin/cl6x -c -qq -pdsw225 -mv64p -eo.o64P -ea.s64P -Dxdc_cfg__header__='ti/sdo/server/cs/package/cfg/bin/cs_x64P.h' -Dxdc_target_name__=C64P -Dxdc_target_types__=ti/targets/std.h -Dxdc_bld__profile_release -Dxdc_bld__vers_ -O2 -I. -I/home/magesh/dvsdk/dvsdk_3_01_00_10/cs1omap3530_1_01_00 -I/home/magesh/dvsdk/dvsdk_3_01_00_10/cs1omap3530_1_01_00/packages -I/home/magesh/dvsdk/dvsdk_3_01_00_10/xdais_6_25_02_11/packages -I/home/magesh/dvsdk/dvsdk_3_01_00_10/framework_components_2_25_01_05/packages -I/home/magesh/dvsdk/dvsdk_3_01_00_10/framework_components_2_25_01_05/fctools/packages -I/home/magesh/dvsdk/dvsdk_3_01_00_10/bios_5_41_00_06/packages -I/home/magesh/dvsdk/dvsdk_3_01_00_10/biosutils_1_02_02/packages -I/home/magesh/dvsdk/dvsdk_3_01_00_10/linuxutils_2_25_02_08/packages -I/home/magesh/dvsdk/dvsdk_3_01_00_10/dsplink_linux_1_65_00_02/packages -I/home/magesh/dvsdk/dvsdk_3_01_00_10/dsplink_linux_1_65_00_02 -I/home/magesh/dvsdk/dvsdk_3_01_00_10/codec_engine_2_25_02_11/packages -I/home/magesh/dvsdk/dvsdk_3_01_00_10/codec_engine_2_25_02_11/cetools/packages -I/home/magesh/dvsdk/dvsdk_3_01_00_10/xdctools_3_16_01_27/packages -I../../../.. -I/home/magesh/dvsdk/dvsdk_3_01_00_10/bios_5_41_00_06/packages/ti/bios/include -I/home/magesh/dvsdk/dvsdk_3_01_00_10/cs1omap3530_1_01_00/include -fs=./package/cfg/bin/cs -fr=./package/cfg/bin/cs -fc main.c
gmake[1]: /home/magesh/dvsdk/dvsdk_3_01_00_10/cs1omap3530_1_01_00/bin/cl6x: Command not found
gmake[1]: *** [package/cfg/bin/cs/main.o64P] Error 127
gmake: *** [packages/ti/sdo/server/cs,.executables] Error 2
make: *** [.all-packages] Error 2
Please check and let us know your feedback
 ------------------------------------------------------------------------5672.log.txt
  • Maybe I'm missing something, but it just seems that your CG tools are not where you have pointed the build.
    The error:
    states clearly that the 'cl6x' command is not in the location /home/magesh/dvsdk/dvsdk_3_01_00_10/cs1omap3530_1_01_00/bin
    - Rob
