Part Number: PROCESSOR-SDK-TDAX
Hello There,
Recently i use TIDL to quickly deploy my own caffe models.
During running import model it will show some warnings like:
WARNING: [TIDL_ConvolutionLayer] conv_botneck_encode_4_2_2 kernel size 1x3 or 1x5 is supported by MMALIB, but not validated by TIDL. Be careful.
WARNING: [TIDL_ConvolutionLayer] conv_botneck_encode_4_2_2 Paramater is not validated. Please be carefull with this layer!
Kernel 3x1 Stride 1x1 dilation 1x1 Pad 1x0 Bias 1
WARNING: [TIDL_ConvolutionLayer] conv_botneck_encode_6_2_1 kernel size 1x3 or 1x5 is supported by MMALIB, but not validated by TIDL. Be careful.
WARNING: [TIDL_ConvolutionLayer] conv_botneck_encode_6_2_1 Paramater is not validated. Please be carefull with this layer!
Kernel 1x3 Stride 1x1 dilation 1x1 Pad 0x1 Bias 1
WARNING: [TIDL_ConvolutionLayer] conv_botneck_encode_6_2_2 kernel size 1x3 or 1x5 is supported by MMALIB, but not validated by TIDL. Be careful.
WARNING: [TIDL_ConvolutionLayer] conv_botneck_encode_6_2_2 Paramater is not validated. Please be carefull with this layer!
WARNING: [TIDL_ConvolutionLayer] conv_botneck_encode_8_2_1 Paramater is not validated. Please be carefull with this layer!
Kernel 1x7 Stride 1x1 dilation 1x1 Pad 0x3 Bias 1
WARNING: [TIDL_ConvolutionLayer] conv_botneck_encode_8_2_2 Paramater is not validated. Please be carefull with this layer!
Kernel 7x1 Stride 1x1 dilation 1x1 Pad 3x0 Bias 1
WARNING: [TIDL_ConvolutionLayer] conv_botneck_encode_10_2_1 kernel size 1x3 or 1x5 is supported by MMALIB, but not validated by TIDL. Be careful.
WARNING: [TIDL_ConvolutionLayer] conv_botneck_encode_10_2_1 Paramater is not validated. Please be carefull with this layer!
or
SUGGESTION: [TIDL_Deconv2DLayer] LAYER_ID_XX Please change to Upsample/Resize if possible. Upsample/Resize will be more efficient.
In PC TIDL simulation my model wull runs less than 20 TSC Mega Cycles, but in EVM J721E emulation, it will shows more than 20000 TSC Mega Cycles,
My Question is: what's the difference between EVM and ti_cnnperfsim.out? i think the optimized MMA code should both enabled in PC simulation and EVM emulation.
Also could you please point me how to enable the trace like: "-------------------------Network summary-----------------------" in EVM emulation
Thanks a lot!
SAMUEL
