Part Number: DRA746
Hi TI team,
We met the issue, play a video and switch to next, got error “ducati gstducatividdec.c(571):codec_process:<decoder> err=-5”. And also we see our process exit from g_main_loop_run().
Attached the log, videos trasfer to link
. It is once rare occurrence. Could you please provide some comments from your POV. Thanks.
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/drop_5F00_out_5F00_mediaOneonly.7z
Detail in log.
1. Here the previous song(Jimikki Kammal Dance - ஜிமிக்கி கம்மல் - ജിമ്മിക്കി കമ്മൽ കിടുവേ - Sheril Dance - Mohanlal.mp4) playback to the end:
3263744 2019/11/11 16:19:15.000000 401.0277 87 ECU1 CrM API 2397 log info verbose 1 T2397 CgstPlayerApi::gstBusCallback() Got eos message
3263745 2019/11/11 16:19:15.000000 401.0277 220 ECU1 CrM HMPE 2397 log info verbose 1 T2397 CgstBasePlayer::onHandleEOS() called
2. Here try to stop the playback:
3263814 2019/11/11 16:19:15.000000 401.0307 89 ECU1 CrM API 2397 log info verbose 1 T2561 CgstPlayerApi:stop() set state to stop
3263815 2019/11/11 16:19:15.000000 401.0307 90 ECU1 CrM API 2397 log info verbose 1 T2561 CgstPlayerApi:stopAsync() set state to stop
3. Try to playback the next track(Maan Karate - Darling Dambakku Video - Anirudh - Sivakarthikeyan.mp4):
3264184 2019/11/11 16:19:16.000000 401.3929 135 ECU1 CrM API 2397 log info verbose 1 T2561 CgstPlayerApi:playAsync() set state to playing
3264193 2019/11/11 16:19:16.000000 401.3992 138 ECU1 CrM API 2397 log info verbose 1 T2561 CgstPlayerApi:waitFor() Wait for PLAYING
4. But the playback not happened, instead we get an error, which cause our progress drop out, I guess maybe this error make our progress jump out g_main_loop_run().
3264659 2019/11/11 16:19:16.000000 401.7268 209 ECU1 CrM API 2397 log info verbose 1 T4862 GSTLogs WARN waylandsink wlvideoformat.c(102):gst_wl_shm_format_to_video_format: gst video format not found
3264660 2019/11/11 16:19:16.000000 401.7269 210 ECU1 CrM API 2397 log info verbose 1 T4862 GSTLogs WARN waylandsink wlvideoformat.c(102):gst_wl_shm_format_to_video_format: gst video format not found
3264662 2019/11/11 16:19:16.000000 401.7395 211 ECU1 CrM API 2397 log info verbose 1 T4862 GSTLogs WARN waylandsink wlvideoformat.c(102):gst_wl_shm_format_to_video_format: gst video format not found
3264663 2019/11/11 16:19:16.000000 401.7397 212 ECU1 CrM API 2397 log info verbose 1 T4862 GSTLogs WARN waylandsink wlvideoformat.c(102):gst_wl_shm_format_to_video_format: gst video format not found
3264756 2019/11/11 16:19:16.000000 401.8302 234 ECU1 CrM API 2397 log info verbose 1 T4862 GSTLogs WARN ducati gstducatividdec.c(571):codec_process:<decoder> err=-5, extendedError=00000000
3264840 2019/11/11 16:19:16.000000 401.8383 20 ECU1 CrM HMPE 2397 log info verbose 1 T4862 CBTDevicePlayer::~CBTDevicePlayer()
3264841 2019/11/11 16:19:16.000000 401.8383 21 ECU1 CrM HMPE 2397 log info verbose 1 T4862 CBTDevicePlayer::deInitialize()
