When we tested on AM335x EVMSK, we found that the number of drivers loaded at each startup was different.
The two startup logs are as follows:
U-Boot SPL 2018.01-g9d984f4548 (Apr 06 2019 - 07:42:30) Trying to boot from MMC1 *** Warning - bad CRC, using default environment U-Boot 2018.01-g9d984f4548 (Apr 06 2019 - 07:42:30 +0000) CPU : AM335X-GP rev 2.1 Model: TI AM335x EVM-SK DRAM: 256 MiB NAND: 0 MiB MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1 *** Warning - bad CRC, using default environment <ethaddr> not set. Validating first E-fuse MAC Net: cpsw, usb_ether Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device SD/MMC found on device 0 ** Unable to read file boot.scr ** ** Unable to read file uEnv.txt ** switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... switch to partitions #0, OK mmc0 is current device SD/MMC found on device 0 3871232 bytes read in 357 ms (10.3 MiB/s) 40033 bytes read in 48 ms (814.5 KiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 8df01000, end 8df0dc60 ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.14.79-ge669d52447 (oe-user@oe-host) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #1 PREEMPT Sat Apr 6 03:14:17 UTC 2019 [ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: TI AM335x EVM-SK [ 0.000000] Memory policy: Data cache writeback [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] cma: Reserved 48 MiB at 0x8a800000 [ 0.000000] CPU: All CPU(s) started in SVC mode. [ 0.000000] AM335X ES2.1 (sgx neon) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 64960 [ 0.000000] Kernel command line: console=ttyO0,115200n8 root=PARTUUID=00037e34-02 rw rootfstype=ext4 rootwait [ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes) [ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) [ 0.000000] Memory: 197276K/262144K available (8192K kernel code, 319K rwdata, 2544K rodata, 1024K init, 267K bss, 15716K reserved, 49152K cma-reserved, 0K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000] vmalloc : 0xd0800000 - 0xff800000 ( 752 MB) [ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0900000 (9184 kB) [ 0.000000] .init : 0xc0c00000 - 0xc0d00000 (1024 kB) [ 0.000000] .data : 0xc0d00000 - 0xc0d4fd40 ( 320 kB) [ 0.000000] .bss : 0xc0d4fd40 - 0xc0d92a8c ( 268 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] Tasks RCU enabled. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts [ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz [ 0.000014] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns [ 0.000031] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.000041] OMAP clocksource: timer1 at 24000000 Hz [ 0.000207] timer_probe: no matching timers found [ 0.000404] Console: colour dummy device 80x30 [ 0.000431] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0' [ 0.000437] This ensures that you still see kernel messages. Please [ 0.000442] update your kernel commandline. [ 0.000472] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736) [ 0.089181] pid_max: default: 32768 minimum: 301 [ 0.089355] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.089370] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.090116] CPU: Testing write buffer coherency: ok [ 0.090178] CPU0: Spectre v2: using BPIALL workaround [ 0.090852] Setting up static identity map for 0x80100000 - 0x80100060 [ 0.090994] Hierarchical SRCU implementation. [ 0.091311] EFI services will not be available. [ 0.092537] devtmpfs: initialized [ 0.099888] random: get_random_u32 called from bucket_table_alloc+0x8c/0x1ac with crng_init=0 [ 0.100340] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 [ 0.100624] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.100647] futex hash table entries: 256 (order: -1, 3072 bytes) [ 0.104149] pinctrl core: initialized pinctrl subsystem [ 0.104864] DMI not present or invalid. [ 0.105258] NET: Registered protocol family 16 [ 0.107359] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.120094] omap_hwmod: debugss: _wait_target_disable failed [ 0.172058] cpuidle: using governor ladder [ 0.172093] cpuidle: using governor menu [ 0.176079] OMAP GPIO hardware version 0.1 [ 0.185704] No ATAGs? [ 0.185721] hw-breakpoint: debug architecture 0x4 unsupported. [ 0.197685] edma 49000000.edma: TI EDMA DMA engine driver [ 0.198703] reg-fixed-voltage fixedregulator2: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_wl12xx_gpio, deferring probe [ 0.201565] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe [ 0.201717] media: Linux media interface: v0.10 [ 0.201758] Linux video capture interface: v2.00 [ 0.201857] pps_core: LinuxPPS API ver. 1 registered [ 0.201865] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.201885] PTP clock support registered [ 0.201916] EDAC MC: Ver: 3.0.0 [ 0.202377] dmi: Firmware registration failed. [ 0.202785] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400 [ 0.203124] Advanced Linux Sound Architecture Driver Initialized. [ 0.204247] clocksource: Switched to clocksource timer1 [ 0.211679] NET: Registered protocol family 2 [ 0.212389] TCP established hash table entries: 2048 (order: 1, 8192 bytes) [ 0.212420] TCP bind hash table entries: 2048 (order: 1, 8192 bytes) [ 0.212443] TCP: Hash tables configured (established 2048 bind 2048) [ 0.212544] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.212561] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.212712] NET: Registered protocol family 1 [ 0.213155] RPC: Registered named UNIX socket transport module. [ 0.213168] RPC: Registered udp transport module. [ 0.213174] RPC: Registered tcp transport module. [ 0.213180] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.214045] hw perfevents: no interrupt-affinity property for /pmu, guessing. [ 0.214169] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available [ 0.215798] workingset: timestamp_bits=14 max_order=16 bucket_order=2 [ 0.219545] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.220361] NFS: Registering the id_resolver key type [ 0.220405] Key type id_resolver registered [ 0.220412] Key type id_legacy registered [ 0.220453] ntfs: driver 2.1.32 [Flags: R/O]. [ 0.222405] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 0.222426] io scheduler noop registered [ 0.222434] io scheduler deadline registered [ 0.222629] io scheduler cfq registered (default) [ 0.222640] io scheduler mq-deadline registered [ 0.222646] io scheduler kyber registered [ 0.223831] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568 [ 0.227062] pwm-backlight backlight: backlight supply power not found, using dummy regulator [ 0.270530] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 0.273442] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 30, base_baud = 3000000) is a 8250 [ 0.916013] console [ttyS0] enabled [ 0.921337] omap_rng 48310000.rng: Random Number Generator ver. 20 [ 0.929278] panel panel: found backlight [ 0.933533] OF: graph: no port node found in /ocp/lcdc@4830e000 [ 0.939760] OF: graph: no port node found in /ocp/lcdc@4830e000 [ 0.946217] OF: graph: no port node found in /ocp/lcdc@4830e000 [ 0.952172] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 0.958856] [drm] No driver support for vblank timestamp query. [ 1.008059] Console: switching to colour frame buffer device 60x34 [ 1.031932] tilcdc 4830e000.lcdc: fb0: frame buffer device [ 1.038075] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on minor 0 [ 1.056335] brd: module loaded [ 1.066015] loop: module loaded [ 1.071150] libphy: Fixed MDIO Bus: probed [ 1.144298] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000 [ 1.152011] davinci_mdio 4a101000.mdio: detected phy mask fffffffc [ 1.160199] libphy: 4a101000.mdio: probed [ 1.164345] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver Atheros 8031 ethernet [ 1.173622] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver Atheros 8031 ethernet [ 1.183883] cpsw 4a100000.ethernet: Detected MACID = c4:ed:ba:8d:4c:7b [ 1.190764] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4 [ 1.197217] cpsw 4a100000.ethernet: ALE Table size 1024 [ 1.202522] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies) [ 1.210494] cpsw 4a100000.ethernet: cpsw: Detected MACID = c4:ed:ba:8d:4c:7d [ 1.218859] i2c /dev entries driver [ 1.222848] IR NEC protocol handler initialized [ 1.227464] IR RC5(x/sz) protocol handler initialized [ 1.232536] IR RC6 protocol handler initialized [ 1.237108] IR JVC protocol handler initialized [ 1.241654] IR Sony protocol handler initialized [ 1.246300] IR SANYO protocol handler initialized [ 1.251020] IR Sharp protocol handler initialized [ 1.255755] IR MCE Keyboard/mouse protocol handler initialized [ 1.261609] IR XMP protocol handler initialized [ 1.267857] cpuidle: enable-method property 'ti,am3352' found operations [ 1.275048] sdhci: Secure Digital Host Controller Interface driver [ 1.281257] sdhci: Copyright(c) Pierre Ossman [ 1.286170] omap_hsmmc 48060000.mmc: Got CD GPIO [ 1.292361] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.299565] ledtrig-cpu: registered to indicate activity on CPUs [ 1.309792] NET: Registered protocol family 10 [ 1.315673] Segment Routing with IPv6 [ 1.319434] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 1.326204] NET: Registered protocol family 17 [ 1.330965] Key type dns_resolver registered [ 1.335583] omap_voltage_late_init: Voltage driver support not added [ 1.374470] tps65910 0-002d: No interrupt support, no core IRQ [ 1.382194] vrtc: supplied by vbat [ 1.389380] vio: supplied by vbat [ 1.394192] vdd1: supplied by vbat [ 1.399416] vdd2: supplied by vbat [ 1.404261] random: fast init done [ 1.409352] vdig1: supplied by vbat [ 1.414181] vdig2: supplied by vbat [ 1.419039] vpll: supplied by vbat [ 1.423755] vdac: supplied by vbat [ 1.428513] vaux1: supplied by vbat [ 1.433351] vaux2: supplied by vbat [ 1.438213] vaux33: supplied by vbat [ 1.443085] vmmc: supplied by vbat [ 1.447860] vbb: supplied by vbat [ 1.452769] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz [ 1.460484] omap_hsmmc 48060000.mmc: Got CD GPIO [ 1.571503] mmc0: host does not support reading read-only switch, assuming write-enable [ 1.581606] mmc0: new high speed SDHC card at address 1234 [ 1.587798] mmcblk0: mmc0:1234 SA08G 7.21 GiB [ 1.594049] mmcblk0: p1 p2 [ 1.677619] input: gpio_buttons0 as /devices/platform/gpio_buttons0/input/input0 [ 1.689567] hctosys: unable to open rtc device (rtc0) [ 1.695124] omap_hsmmc 481d8000.mmc: card claims to support voltages below defined range [ 1.703723] lis3_reg: disabling [ 1.707431] ALSA device list: [ 1.710618] No soundcards found. [ 1.724162] mmc1: new SDIO card at address 0001 [ 1.750161] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 1.758841] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 1.774753] devtmpfs: mounted [ 1.779405] Freeing unused kernel memory: 1024K [ 2.220612] systemd[1]: System time before build time, advancing clock. [ 2.325309] systemd[1]: systemd 234 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN default-hierarchy=hybrid) [ 2.347356] systemd[1]: Detected architecture arm. Welcome to Arago 2018.10! [ 2.396474] systemd[1]: Set hostname to <am335x-evm>. [ 2.798999] systemd[1]: /lib/systemd/system/gadget-init.service:15: Unknown lvalue 'ExecStopPre' in section 'Service' [ 2.995437] systemd[1]: Configuration file /etc/systemd/system/bootcount.service is marked executable. Please remove executable permission bits. Proceeding anyway. [ 3.114620] random: systemd: uninitialized urandom read (16 bytes read) [ 3.125264] systemd[1]: Created slice User and Session Slice. [ OK ] Created slice User and Session Slice. [ 3.220492] random: systemd: uninitialized urandom read (16 bytes read) [ 3.231046] systemd[1]: Created slice System Slice. [ OK ] Created slice System Slice. [ 3.265481] random: systemd: uninitialized urandom read (16 bytes read) [ 3.276592] systemd[1]: Created slice system-getty.slice. [ OK ] Created slice system-getty.slice. [ 3.307034] systemd[1]: Listening on udev Kernel Socket. [ OK ] Listening on udev Kernel Socket. [ 3.335230] systemd[1]: Listening on udev Control Socket. [ OK ] Listening on udev Control Socket. [ OK ] Reached target Slices. [ OK ] Reached target Swap. [ OK ] Listening on /dev/initctl Compatibility Named Pipe. [ OK ] Listening on Journal Socket (/dev/log). [ OK ] Listening on Syslog Socket. [ OK ] Listening on Journal Socket. Starting Create list of required st…ce nodes for the current kernel... Mounting Temporary Directory (/tmp)... Starting Remount Root and Kernel File Systems... Starting Journal Service... [ 3.692390] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) Starting Load Kernel Modules... [ OK ] Listening on Process Core Dump Socket. Mounting POSIX Message Queue File System... Mounting Kernel Debug File System... [ 3.841651] cryptodev: loading out-of-tree module taints kernel. [ OK ] Started Dispatch Password Requests to Console[ 3.866879] cryptodev: driver 1.9 loaded. Directory Watch. [ OK ] Created slice system-serial\x2dgetty.slice. [ 3.919363] usbcore: registered new interface driver usbfs [ OK ] Started Forward Password Requests to Wall Directory Watch. [ 3.941877] usbcore: registered new interface driver hub [ 3.955013] usbcore: registered new device driver usb [ OK ] Reached target Paths. [ 3.971984] usbcore: registered new interface driver usbserial [ OK ] Reached target Remote File Systems. [ 3.999741] usbcore: registered new interface driver ftdi_sio [ 4.025411] usbserial: USB Serial support registered for FTDI USB Serial Device [ OK ] Mounted Kernel Debug File System. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Mounted Temporary Directory (/tmp). [ OK ] Started Journal Service. [ OK ] Started Create list of required sta…vice nodes for the current kernel. [ OK ] Started Remount Root and Kernel File Systems. [ OK ] Started Load Kernel Modules. Starting Apply Kernel Variables... Mounting Kernel Configuration File System... Starting Rebuild Hardware Database... Starting Create System Users... Starting Flush Journal to Persistent Storage... [ OK ] Mounted Kernel Configuration File System. [ OK ] Started Apply Kernel Variables. [ OK ] Started Create System Users. [ 4.735897] systemd-journald[68]: Received request to flush runtime journal from PID 1 Starting Create Static Device Nodes in /dev... [ OK ] Started Flush Journal to Persistent Storage. [ OK ] Started Create Static Device Nodes in /dev. [ OK ] Reached target Local File Systems (Pre). Mounting /media/ram... Mounting /var/volatile... Starting udev Kernel Device Manager... [ OK ] Mounted /var/volatile. [ OK ] Mounted /media/ram. Starting Load/Save Random Seed... [ OK ] Reached target Local File Systems. Starting Rebuild Dynamic Linker Cache... Starting Rebuild Journal Catalog... Starting Create Volatile Files and Directories... [ OK ] Started udev Kernel Device Manager. [ OK ] Started Load/Save Random Seed. [ OK ] Started Create Volatile Files and Directories. Starting Update UTMP about System Boot/Shutdown... Starting Network Time Synchronization... [ OK ] Started Rebuild Journal Catalog. [ OK ] Started Update UTMP about System Boot/Shutdown. [ OK ] Started Rebuild Dynamic Linker Cache. [ OK ] Started Network Time Synchronization. [ OK ] Reached target System Time Synchronized. [ OK ] Started Rebuild Hardware Database. Starting udev Coldplug all Devices... Starting Update is Completed... [ OK ] Started Update is Completed. [ OK ] Created slice system-systemd\x2dbacklight.slice. Starting Load/Save Screen Backlight…ightness of backlight:backlight... [ 12.710192] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec [ OK ] Found device /dev/ttyS0. [ 12.817625] omap_rtc 44e3e000.rtc: already running [ 12.887430] tlv320aic3x-codec 0-001b: Too high supply voltage(s) AVDD: 3300000, DVDD: 5000000 [ OK ] Started udev Coldplug all Devices. [ 12.978821] omap_rtc 44e3e000.rtc: registered as rtc0 [ OK ] Started Load/Save Screen Backlight Brightness of backlight:backlight. [ OK ] Reached target System Initialization. [ OK ] Listening on D-Bus System Message Bus Socket. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Listening on RPCbind Server Activation Socket. [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. Starting Network Service... [ OK ] Started Daily rotation of log files. [ OK ] Reached target Timers. [ OK ] Listening on dropbear.socket. [ OK ] Reached target Sockets. [ OK ] Reached target Basic System. Starting RPC Bind Service... Starting Avahi mDNS/DNS-SD Stack... [ OK ] Started D-Bus System Message Bus. [ 13.873718] omap-sham 53100000.sham: hw accel on OMAP rev 4.3 [ 14.077796] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2 [ 14.114897] omap-aes 53500000.aes: will run requests pump with realtime priority [ 14.255839] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle [ 14.285251] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle [ 14.310681] [drm] Initialized pvr 1.14.3699939 20110701 for 56000000.sgx on minor 1 [ 14.379572] remoteproc remoteproc0: wkup_m3 is available [ 14.387035] remoteproc remoteproc0: powering up wkup_m3 [ 14.394221] PM: Cannot get wkup_m3_ipc handle [ 14.406560] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 224628 [ 14.406818] remoteproc remoteproc0: remote processor wkup_m3 is now up [ 14.406846] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192 [ 14.945104] asoc-simple-card sound: tlv320aic3x-hifi <-> 4803c000.mcasp mapping ok [ 14.945174] asoc-simple-card sound: ASoC: no DMI vendor name! [ 14.993171] PM: bootloader does not support rtc-only! [ OK ] Started Avahi mDNS/DNS-SD Stack. [ OK ] Reached target Containers. [ 15.301327] net eth1: initializing cpsw version 1.12 (0) Starting System Boot count... Starting uim-sysfs.service... [ 15.536193] Atheros 8031 ethernet 4a101000.mdio:01: attached PHY driver [Atheros 8031 ethernet] (mii_bus:phy_addr=4a101000.mdio:01, irq=POLL) [ OK ] Started Job spooling tools. Starting Login Service... [ 15.807038] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready [ OK ] Started Hardware RNG Entropy Gatherer Daemon. [ OK ] Started Kernel Logging Service. [ 16.051892] net eth0: initializing cpsw version 1.12 (0) [ 16.186086] Atheros 8031 ethernet 4a101000.mdio:00: attached PHY driver [Atheros 8031 ethernet] (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL) [ 16.229779] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 17.641132] random: crng init done [ 17.694753] random: 7 urandom warning(s) missed due to ratelimiting [ OK ] Started Periodic Command Scheduler. Starting Print notice about GPLv3 packages... Starting Save/Restore Sound Card State... [ 18.326380] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx [ 18.372317] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ OK ] Started System Logging Service. [ OK ] Started Network Service. [ OK ] Started RPC Bind Service. [ OK ] Started System Boot count. [ OK ] Started uim-sysfs.service. [ OK ] Started Save/Restore Sound Card State. [ OK ] Found device /dev/ttyS3. [ OK ] Found device /dev/mmcblk0p1. [ 21.506240] TI-am335x-tsc 44e0d000.tscadc:tsc: ti,charge-delay not specified [ 21.513614] input: ti-tsc as /devices/platform/ocp/44e0d000.tscadc/44e0d000.tscadc:tsc/input/input1 [ 21.826383] am335x-phy-driver 47401300.usb-phy: 47401300.usb-phy supply vcc not found, using dummy regulator [ 21.939089] musb-hdrc musb-hdrc.0: MUSB HDRC host driver [ 22.031795] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1 [ 22.120052] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 22.202292] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 22.237482] pruss 4a300000.pruss: creating PRU cores and other child platform devices [ 22.354155] usb usb1: Product: MUSB HDRC host driver [ 22.400087] usb usb1: Manufacturer: Linux 4.14.79-ge669d52447 musb-hcd [ 22.458404] usb usb1: SerialNumber: musb-hdrc.0 [ 22.522248] hub 1-0:1.0: USB hub found [ 22.564716] hub 1-0:1.0: 1 port detected [ 22.622566] am335x-phy-driver 47401b00.usb-phy: 47401b00.usb-phy supply vcc not found, using dummy regulator [ 22.668295] remoteproc remoteproc1: 4a334000.pru is available [ 22.668363] pru-rproc 4a334000.pru: PRU rproc node /ocp/pruss_soc_bus@4a326004/pruss@0/pru@34000 probed successfully [ 22.669090] remoteproc remoteproc2: 4a338000.pru is available [ 22.669168] pru-rproc 4a338000.pru: PRU rproc node /ocp/pruss_soc_bus@4a326004/pruss@0/pru@38000 probed successfully [ 22.943962] musb-hdrc musb-hdrc.1: MUSB HDRC host driver [ 22.976730] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2 [ 23.011908] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 23.046777] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 23.085397] usb usb2: Product: MUSB HDRC host driver [ 23.101958] usb usb2: Manufacturer: Linux 4.14.79-ge669d52447 musb-hcd [ 23.136436] usb usb2: SerialNumber: musb-hdrc.1 [ 23.171242] hub 2-0:1.0: USB hub found [ 23.185803] hub 2-0:1.0: 1 port detected [ OK ] Started Login Service. [ OK ] Reached target Sound Card. Starting Start USB gadget... [ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. Starting rc.pvr.service... Starting Wait for Network to be Configured... [ OK ] Reached target Network. [ OK ] Started Redis In-Memory Data Store. Starting Simple Network Management Protocol (SNMP) Daemon.... Starting Enable and configure wl18xx bluetooth stack... Starting Network Name Resolution... [ 26.141803] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ] [ 26.205380] using random self ethernet address [ 26.205388] using random host ethernet address [ 26.205400] using host ethernet address: C4:ED:BA:8D:4C:7D [ 26.205427] using random self ethernet address [ 26.205431] using random host ethernet address [ 26.205446] using host ethernet address: C4:ED:BA:8D:4C:7D [ 26.208688] usb0: HOST MAC c4:ed:ba:8d:4c:7d [ 26.209077] usb0: MAC 46:b3:0f:0a:4b:5a Starting Lightning Fast Webserver With Light System Requirements... Starting Permit User Sessions... [ 26.721022] Mass Storage Function, version: 2009/09/11 [ OK ] Found device /dev/ttyGS0. [ 26.763503] LUN: removable file: (no medium) [ 26.841752] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready [ 26.962079] LUN: removable read only file: /dev/mmcblk0p1 [ OK ] Started Permit User Sessions. [ 27.057786] Number of LUNs=1 [ OK ] Started Lightning Fast Webserver With Light System Requirements. [ 27.078666] g_multi gadget: Multifunction Composite Gadget [ OK ] Started rc.pvr.service. [ 27.153436] g_multi gadget: g_multi ready Starting weston.service... [ OK ] Started Serial Getty on ttyS3. [ OK ] Started Getty on tty1. [ OK ] Started Serial Getty on ttyS0. [ 27.487904] g_multi gadget: high-speed config #1: Multifunction with RNDIS [ 27.495229] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready [ OK ] Started Network Name Resolution. [ OK ] Reached target Host and Network Name Lookups. [ OK ] Started NFS status monitor for NFSv2/3 locking.. [ OK ] Started weston.service. Starting telnetd.service... Starting Matrix GUI... [ OK ] Started telnetd.service. Starting busybox-udhcpd.service... Starting thttpd.service... [ OK ] Started Start USB gadget. [ OK ] Started Matrix GUI. [ OK ] Started busybox-udhcpd.service. [ OK ] Started Serial Getty on ttyGS0. [ OK ] Reached target Login Prompts. Starting Synchronize System and HW clocks... [ OK ] Started Enable and configure wl18xx bluetooth stack. [ OK ] Started thttpd.service. [ OK ] Started Synchronize System and HW clocks. [ OK ] Started Simple Network Management Protocol (SNMP) Daemon.. Starting rng-tools.service... *************************************************************** *************************************************************** NOTICE: This file system contains the following GPLv3 packages: autoconf bash-dev bash binutils cifs-utils cpio cpp-symlinks cpp dosfstools elfutils findutils g++-symlinks g++ gawk gcc-symlinks gcc gdb gdbserver gettext glmark2 gstreamer1.0-libav gzip hidapi libdw1 libelf1 libgdbm-compat4 libgdbm-dev libgdbm4 libgettextlib libgettextsrc libgmp10 libidn11 libmavconn libmpc3 libmpfr4 libreadline-dev libreadline7 libunistring2 m4-dev m4 make mavlink mavros-extras mavros-msgs mavros nettle python3-pycairo socketcan-interface which If you do not wish to distribute GPLv3 components please remove the above packages prior to distribution. This can be done using the opkg remove command. i.e.: opkg remove <package> Where <package> is the name printed in the list above NOTE: If the package is a dependency of another package you will be notified of the dependent packages. You should use the --force-removal-of-dependent-packages option to also remove the dependent packages as well *************************************************************** *************************************************************** [ OK ] Started rng-tools.service. [ OK ] Started Print notice about GPLv3 packages. _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | .[ 33.465022] hrtimer: interrupt took 184417 ns | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project http://arago-project.org am335x-evm ttyS0 Arago 2018.10 am335x-evm ttyS0 am335x-evm login: root root@am335x-evm:~# lsmod | wc | awk '{print $1}' 47 root@am335x-evm:~# lsmod Module Size Used by bc_example 16384 0 usb_f_acm 16384 1 u_serial 20480 3 usb_f_acm usb_f_ecm 16384 1 g_multi 16384 0 usb_f_mass_storage 40960 2 g_multi usb_f_rndis 24576 2 g_multi u_ether 20480 3 usb_f_ecm,g_multi,usb_f_rndis libcomposite 53248 5 usb_f_ecm,usb_f_acm,usb_f_mass_storage,g_multi,usb_f_rndis pru_rproc 20480 0 pruss_intc 16384 1 pru_rproc pruss 16384 1 pru_rproc musb_dsps 20480 0 musb_hdrc 98304 1 musb_dsps phy_am335x 16384 2 udc_core 28672 8 usb_f_ecm,usb_f_acm,usb_f_mass_storage,u_serial,musb_hdrc,u_ether,usb_f_rndis,libcomposite phy_generic 16384 1 phy_am335x phy_am335x_control 16384 1 phy_am335x ti_am335x_tsc 16384 0 snd_soc_simple_card 16384 0 snd_soc_simple_card_utils 16384 1 snd_soc_simple_card pm33xx 16384 0 wkup_m3_rproc 16384 1 wkup_m3_ipc 16384 1 pm33xx pvrsrvkm 413696 5 bc_example remoteproc 40960 3 pru_rproc,wkup_m3_rproc,wkup_m3_ipc omap_aes_driver 24576 0 crypto_engine 16384 1 omap_aes_driver omap_crypto 16384 1 omap_aes_driver omap_sham 28672 0 ti_emif_sram 16384 1 pm33xx pruss_soc_bus 16384 0 wlcore_sdio 16384 0 snd_soc_tlv320aic3x 57344 1 musb_am335x 16384 0 rtc_omap 20480 2 omap_wdt 16384 0 ti_am335x_tscadc 16384 1 ti_am335x_tsc sch_fq_codel 20480 4 uio_module_drv 16384 0 uio 20480 1 uio_module_drv ftdi_sio 40960 0 usbserial 36864 1 ftdi_sio usbcore 204800 3 ftdi_sio,musb_hdrc,usbserial usb_common 16384 6 phy_am335x,udc_core,musb_hdrc,libcomposite,musb_dsps,usbcore cryptodev 45056 0 root@am335x-evm:~# dmesg [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.14.79-ge669d52447 (oe-user@oe-host) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #1 PREEMPT Sat Apr 6 03:14:17 UTC 2019 [ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: TI AM335x EVM-SK [ 0.000000] Memory policy: Data cache writeback [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] cma: Reserved 48 MiB at 0x8a800000 [ 0.000000] On node 0 totalpages: 65536 [ 0.000000] free_area_init_node: node 0, pgdat c0d4d4b0, node_mem_map cfda1000 [ 0.000000] Normal zone: 576 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 65536 pages, LIFO batch:15 [ 0.000000] CPU: All CPU(s) started in SVC mode. [ 0.000000] AM335X ES2.1 (sgx neon) [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 [ 0.000000] pcpu-alloc: [0] 0 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 64960 [ 0.000000] Kernel command line: console=ttyO0,115200n8 root=PARTUUID=00037e34-02 rw rootfstype=ext4 rootwait [ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes) [ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) [ 0.000000] Memory: 197276K/262144K available (8192K kernel code, 319K rwdata, 2544K rodata, 1024K init, 267K bss, 15716K reserved, 49152K cma-reserved, 0K highmem) [ 0.000000] Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xffc00000 - 0xfff00000 (3072 kB) vmalloc : 0xd0800000 - 0xff800000 ( 752 MB) lowmem : 0xc0000000 - 0xd0000000 ( 256 MB) pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) modules : 0xbf000000 - 0xbfe00000 ( 14 MB) .text : 0xc0008000 - 0xc0900000 (9184 kB) .init : 0xc0c00000 - 0xc0d00000 (1024 kB) .data : 0xc0d00000 - 0xc0d4fd40 ( 320 kB) .bss : 0xc0d4fd40 - 0xc0d92a8c ( 268 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] Tasks RCU enabled. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts [ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz [ 0.000014] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns [ 0.000031] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.000041] OMAP clocksource: timer1 at 24000000 Hz [ 0.000207] timer_probe: no matching timers found [ 0.000404] Console: colour dummy device 80x30 [ 0.000431] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0' [ 0.000437] This ensures that you still see kernel messages. Please [ 0.000442] update your kernel commandline. [ 0.000472] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736) [ 0.089181] pid_max: default: 32768 minimum: 301 [ 0.089355] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.089370] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.090116] CPU: Testing write buffer coherency: ok [ 0.090178] CPU0: Spectre v2: using BPIALL workaround [ 0.090852] Setting up static identity map for 0x80100000 - 0x80100060 [ 0.090994] Hierarchical SRCU implementation. [ 0.091311] EFI services will not be available. [ 0.092537] devtmpfs: initialized [ 0.099888] random: get_random_u32 called from bucket_table_alloc+0x8c/0x1ac with crng_init=0 [ 0.100340] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 [ 0.100624] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.100647] futex hash table entries: 256 (order: -1, 3072 bytes) [ 0.104149] pinctrl core: initialized pinctrl subsystem [ 0.104864] DMI not present or invalid. [ 0.105258] NET: Registered protocol family 16 [ 0.107359] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.120094] omap_hwmod: debugss: _wait_target_disable failed [ 0.172058] cpuidle: using governor ladder [ 0.172093] cpuidle: using governor menu [ 0.175929] gpio gpiochip0: (gpio): added GPIO chardev (254:0) [ 0.176019] gpiochip_setup_dev: registered GPIOs 0 to 31 on device: gpiochip0 (gpio) [ 0.176079] OMAP GPIO hardware version 0.1 [ 0.176811] gpio gpiochip1: (gpio): added GPIO chardev (254:1) [ 0.176883] gpiochip_setup_dev: registered GPIOs 32 to 63 on device: gpiochip1 (gpio) [ 0.177552] gpio gpiochip2: (gpio): added GPIO chardev (254:2) [ 0.177617] gpiochip_setup_dev: registered GPIOs 64 to 95 on device: gpiochip2 (gpio) [ 0.178248] gpio gpiochip3: (gpio): added GPIO chardev (254:3) [ 0.178327] gpiochip_setup_dev: registered GPIOs 96 to 127 on device: gpiochip3 (gpio) [ 0.185704] No ATAGs? [ 0.185721] hw-breakpoint: debug architecture 0x4 unsupported. [ 0.197685] edma 49000000.edma: TI EDMA DMA engine driver [ 0.198232] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator0[0]' [ 0.198511] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator1[0]' [ 0.198703] reg-fixed-voltage fixedregulator2: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_wl12xx_gpio, deferring probe [ 0.198805] of_get_named_gpiod_flags: parsed 'gpio' property of node '/fixedregulator3[0]' - status (0) [ 0.201565] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe [ 0.201717] media: Linux media interface: v0.10 [ 0.201758] Linux video capture interface: v2.00 [ 0.201857] pps_core: LinuxPPS API ver. 1 registered [ 0.201865] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.201885] PTP clock support registered [ 0.201916] EDAC MC: Ver: 3.0.0 [ 0.202377] dmi: Firmware registration failed. [ 0.202785] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400 [ 0.203124] Advanced Linux Sound Architecture Driver Initialized. [ 0.204247] clocksource: Switched to clocksource timer1 [ 0.211679] NET: Registered protocol family 2 [ 0.212389] TCP established hash table entries: 2048 (order: 1, 8192 bytes) [ 0.212420] TCP bind hash table entries: 2048 (order: 1, 8192 bytes) [ 0.212443] TCP: Hash tables configured (established 2048 bind 2048) [ 0.212544] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.212561] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.212712] NET: Registered protocol family 1 [ 0.213155] RPC: Registered named UNIX socket transport module. [ 0.213168] RPC: Registered udp transport module. [ 0.213174] RPC: Registered tcp transport module. [ 0.213180] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.213194] PCI: CLS 0 bytes, default 64 [ 0.214045] hw perfevents: no interrupt-affinity property for /pmu, guessing. [ 0.214169] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available [ 0.215798] workingset: timestamp_bits=14 max_order=16 bucket_order=2 [ 0.219545] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.220361] NFS: Registering the id_resolver key type [ 0.220405] Key type id_resolver registered [ 0.220412] Key type id_legacy registered [ 0.220453] ntfs: driver 2.1.32 [Flags: R/O]. [ 0.222405] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 0.222426] io scheduler noop registered [ 0.222434] io scheduler deadline registered [ 0.222629] io scheduler cfq registered (default) [ 0.222640] io scheduler mq-deadline registered [ 0.222646] io scheduler kyber registered [ 0.223831] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568 [ 0.226988] pwm-backlight backlight: GPIO lookup for consumer enable [ 0.227000] pwm-backlight backlight: using device tree for GPIO lookup [ 0.227017] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/backlight[0]' [ 0.227025] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/backlight[0]' [ 0.227031] pwm-backlight backlight: using lookup tables for GPIO lookup [ 0.227038] pwm-backlight backlight: lookup for GPIO enable failed [ 0.227062] pwm-backlight backlight: backlight supply power not found, using dummy regulator [ 0.270530] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 0.273442] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 30, base_baud = 3000000) is a 8250 [ 0.916013] console [ttyS0] enabled [ 0.921337] omap_rng 48310000.rng: Random Number Generator ver. 20 [ 0.929278] panel panel: found backlight [ 0.933234] panel panel: GPIO lookup for consumer enable [ 0.933239] panel panel: using device tree for GPIO lookup [ 0.933255] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/panel[0]' [ 0.933263] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/panel[0]' [ 0.933269] panel panel: using lookup tables for GPIO lookup [ 0.933276] panel panel: lookup for GPIO enable failed [ 0.933533] OF: graph: no port node found in /ocp/lcdc@4830e000 [ 0.939760] OF: graph: no port node found in /ocp/lcdc@4830e000 [ 0.946217] OF: graph: no port node found in /ocp/lcdc@4830e000 [ 0.952172] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 0.958856] [drm] No driver support for vblank timestamp query. [ 1.008059] Console: switching to colour frame buffer device 60x34 [ 1.031932] tilcdc 4830e000.lcdc: fb0: frame buffer device [ 1.038075] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on minor 0 [ 1.056335] brd: module loaded [ 1.066015] loop: module loaded [ 1.071109] mdio_bus fixed-0: GPIO lookup for consumer reset [ 1.071121] mdio_bus fixed-0: using lookup tables for GPIO lookup [ 1.071129] mdio_bus fixed-0: lookup for GPIO reset failed [ 1.071150] libphy: Fixed MDIO Bus: probed [ 1.090803] mdio_bus 4a101000.mdio: GPIO lookup for consumer reset [ 1.090816] mdio_bus 4a101000.mdio: using lookup tables for GPIO lookup [ 1.090822] mdio_bus 4a101000.mdio: lookup for GPIO reset failed [ 1.144298] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000 [ 1.152011] davinci_mdio 4a101000.mdio: detected phy mask fffffffc [ 1.160199] libphy: 4a101000.mdio: probed [ 1.164345] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver Atheros 8031 ethernet [ 1.173622] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver Atheros 8031 ethernet [ 1.183883] cpsw 4a100000.ethernet: Detected MACID = c4:ed:ba:8d:4c:7b [ 1.190764] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4 [ 1.197217] cpsw 4a100000.ethernet: ALE Table size 1024 [ 1.202522] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies) [ 1.210494] cpsw 4a100000.ethernet: cpsw: Detected MACID = c4:ed:ba:8d:4c:7d [ 1.218859] i2c /dev entries driver [ 1.222848] IR NEC protocol handler initialized [ 1.227464] IR RC5(x/sz) protocol handler initialized [ 1.232536] IR RC6 protocol handler initialized [ 1.237108] IR JVC protocol handler initialized [ 1.241654] IR Sony protocol handler initialized [ 1.246300] IR SANYO protocol handler initialized [ 1.251020] IR Sharp protocol handler initialized [ 1.255755] IR MCE Keyboard/mouse protocol handler initialized [ 1.261609] IR XMP protocol handler initialized [ 1.267857] cpuidle: enable-method property 'ti,am3352' found operations [ 1.275048] sdhci: Secure Digital Host Controller Interface driver [ 1.281257] sdhci: Copyright(c) Pierre Ossman [ 1.286108] omap_hsmmc 48060000.mmc: GPIO lookup for consumer cd [ 1.286116] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup [ 1.286150] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/ocp/mmc@48060000[0]' - status (0) [ 1.286170] omap_hsmmc 48060000.mmc: Got CD GPIO [ 1.290837] omap_hsmmc 48060000.mmc: GPIO lookup for consumer wp [ 1.290843] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup [ 1.290851] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@48060000[0]' [ 1.290858] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@48060000[0]' [ 1.290864] omap_hsmmc 48060000.mmc: using lookup tables for GPIO lookup [ 1.290872] omap_hsmmc 48060000.mmc: lookup for GPIO wp failed [ 1.291708] omap_hsmmc 481d8000.mmc: GPIO lookup for consumer cd [ 1.291717] omap_hsmmc 481d8000.mmc: using device tree for GPIO lookup [ 1.291730] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/mmc@481d8000[0]' [ 1.291738] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/mmc@481d8000[0]' [ 1.291743] omap_hsmmc 481d8000.mmc: using lookup tables for GPIO lookup [ 1.291749] omap_hsmmc 481d8000.mmc: lookup for GPIO cd failed [ 1.291757] omap_hsmmc 481d8000.mmc: GPIO lookup for consumer wp [ 1.291762] omap_hsmmc 481d8000.mmc: using device tree for GPIO lookup [ 1.291768] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@481d8000[0]' [ 1.291775] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@481d8000[0]' [ 1.291780] omap_hsmmc 481d8000.mmc: using lookup tables for GPIO lookup [ 1.291785] omap_hsmmc 481d8000.mmc: lookup for GPIO wp failed [ 1.292361] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.298793] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led1[0]' - status (0) [ 1.298846] no flags found for gpios [ 1.298992] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led2[0]' - status (0) [ 1.298998] no flags found for gpios [ 1.299080] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led3[0]' - status (0) [ 1.299085] no flags found for gpios [ 1.299179] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led4[0]' - status (0) [ 1.299184] no flags found for gpios [ 1.299565] ledtrig-cpu: registered to indicate activity on CPUs [ 1.309792] NET: Registered protocol family 10 [ 1.315673] Segment Routing with IPv6 [ 1.319434] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 1.326204] NET: Registered protocol family 17 [ 1.330965] Key type dns_resolver registered [ 1.335583] omap_voltage_late_init: Voltage driver support not added [ 1.347307] of_get_named_gpiod_flags: parsed 'gpio' property of node '/fixedregulator2[0]' - status (0) [ 1.374470] tps65910 0-002d: No interrupt support, no core IRQ [ 1.380548] tps65910-gpio tps65910-gpio: ti,en-gpio-sleep not specified [ 1.380573] gpiochip_find_base: found new base at 506 [ 1.380783] gpio gpiochip4: (tps65910): added GPIO chardev (254:4) [ 1.380859] gpiochip_setup_dev: registered GPIOs 506 to 511 on device: gpiochip4 (tps65910) [ 1.382194] vrtc: supplied by vbat [ 1.389380] vio: supplied by vbat [ 1.394192] vdd1: supplied by vbat [ 1.399416] vdd2: supplied by vbat [ 1.404261] random: fast init done [ 1.409352] vdig1: supplied by vbat [ 1.414181] vdig2: supplied by vbat [ 1.419039] vpll: supplied by vbat [ 1.423755] vdac: supplied by vbat [ 1.428513] vaux1: supplied by vbat [ 1.433351] vaux2: supplied by vbat [ 1.438213] vaux33: supplied by vbat [ 1.443085] vmmc: supplied by vbat [ 1.447860] vbb: supplied by vbat [ 1.452769] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz [ 1.460412] omap_hsmmc 48060000.mmc: GPIO lookup for consumer cd [ 1.460426] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup [ 1.460463] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/ocp/mmc@48060000[0]' - status (0) [ 1.460484] omap_hsmmc 48060000.mmc: Got CD GPIO [ 1.465293] omap_hsmmc 48060000.mmc: GPIO lookup for consumer wp [ 1.465299] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup [ 1.465311] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@48060000[0]' [ 1.465319] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@48060000[0]' [ 1.465325] omap_hsmmc 48060000.mmc: using lookup tables for GPIO lookup [ 1.465332] omap_hsmmc 48060000.mmc: lookup for GPIO wp failed [ 1.526560] omap_hsmmc 481d8000.mmc: GPIO lookup for consumer cd [ 1.526587] omap_hsmmc 481d8000.mmc: using device tree for GPIO lookup [ 1.526625] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/mmc@481d8000[0]' [ 1.526649] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/mmc@481d8000[0]' [ 1.526667] omap_hsmmc 481d8000.mmc: using lookup tables for GPIO lookup [ 1.526686] omap_hsmmc 481d8000.mmc: lookup for GPIO cd failed [ 1.526713] omap_hsmmc 481d8000.mmc: GPIO lookup for consumer wp [ 1.526728] omap_hsmmc 481d8000.mmc: using device tree for GPIO lookup [ 1.526749] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@481d8000[0]' [ 1.526770] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@481d8000[0]' [ 1.526786] omap_hsmmc 481d8000.mmc: using lookup tables for GPIO lookup [ 1.526802] omap_hsmmc 481d8000.mmc: lookup for GPIO wp failed [ 1.571503] mmc0: host does not support reading read-only switch, assuming write-enable [ 1.581606] mmc0: new high speed SDHC card at address 1234 [ 1.587798] mmcblk0: mmc0:1234 SA08G 7.21 GiB [ 1.594049] mmcblk0: p1 p2 [ 1.676132] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_buttons0/switch1[0]' - status (0) [ 1.676600] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_buttons0/switch2[0]' - status (0) [ 1.676819] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_buttons0/switch3[0]' - status (0) [ 1.677042] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_buttons0/switch4[0]' - status (0) [ 1.677619] input: gpio_buttons0 as /devices/platform/gpio_buttons0/input/input0 [ 1.689567] hctosys: unable to open rtc device (rtc0) [ 1.695124] omap_hsmmc 481d8000.mmc: card claims to support voltages below defined range [ 1.703723] lis3_reg: disabling [ 1.707431] ALSA device list: [ 1.710618] No soundcards found. [ 1.724162] mmc1: new SDIO card at address 0001 [ 1.750161] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 1.758841] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 1.774753] devtmpfs: mounted [ 1.779405] Freeing unused kernel memory: 1024K [ 2.220612] systemd[1]: System time before build time, advancing clock. [ 2.325309] systemd[1]: systemd 234 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN default-hierarchy=hybrid) [ 2.347356] systemd[1]: Detected architecture arm. [ 2.396474] systemd[1]: Set hostname to <am335x-evm>. [ 2.798999] systemd[1]: /lib/systemd/system/gadget-init.service:15: Unknown lvalue 'ExecStopPre' in section 'Service' [ 2.995437] systemd[1]: Configuration file /etc/systemd/system/bootcount.service is marked executable. Please remove executable permission bits. Proceeding anyway. [ 3.114620] random: systemd: uninitialized urandom read (16 bytes read) [ 3.125264] systemd[1]: Created slice User and Session Slice. [ 3.220492] random: systemd: uninitialized urandom read (16 bytes read) [ 3.231046] systemd[1]: Created slice System Slice. [ 3.265481] random: systemd: uninitialized urandom read (16 bytes read) [ 3.276592] systemd[1]: Created slice system-getty.slice. [ 3.307034] systemd[1]: Listening on udev Kernel Socket. [ 3.335230] systemd[1]: Listening on udev Control Socket. [ 3.692390] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) [ 3.841651] cryptodev: loading out-of-tree module taints kernel. [ 3.866879] cryptodev: driver 1.9 loaded. [ 3.919363] usbcore: registered new interface driver usbfs [ 3.941877] usbcore: registered new interface driver hub [ 3.955013] usbcore: registered new device driver usb [ 3.971984] usbcore: registered new interface driver usbserial [ 3.999741] usbcore: registered new interface driver ftdi_sio [ 4.025411] usbserial: USB Serial support registered for FTDI USB Serial Device [ 4.735897] systemd-journald[68]: Received request to flush runtime journal from PID 1 [ 12.710192] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec [ 12.817625] omap_rtc 44e3e000.rtc: already running [ 12.887113] of_get_named_gpiod_flags: can't parse 'gpio-reset' property of node '/ocp/i2c@44e0b000/tlv320aic3106@1b[0]' [ 12.887430] tlv320aic3x-codec 0-001b: Too high supply voltage(s) AVDD: 3300000, DVDD: 5000000 [ 12.978640] omap_rtc 44e3e000.rtc: char device (253:0) [ 12.978821] omap_rtc 44e3e000.rtc: registered as rtc0 [ 13.873718] omap-sham 53100000.sham: hw accel on OMAP rev 4.3 [ 14.077796] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2 [ 14.114897] omap-aes 53500000.aes: will run requests pump with realtime priority [ 14.255839] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle [ 14.285251] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle [ 14.310681] [drm] Initialized pvr 1.14.3699939 20110701 for 56000000.sgx on minor 1 [ 14.379572] remoteproc remoteproc0: wkup_m3 is available [ 14.387035] remoteproc remoteproc0: powering up wkup_m3 [ 14.394221] PM: Cannot get wkup_m3_ipc handle [ 14.406560] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 224628 [ 14.406818] remoteproc remoteproc0: remote processor wkup_m3 is now up [ 14.406846] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192 [ 14.911741] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound[0]' [ 14.911753] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound[0]' [ 14.945104] asoc-simple-card sound: tlv320aic3x-hifi <-> 4803c000.mcasp mapping ok [ 14.945174] asoc-simple-card sound: ASoC: no DMI vendor name! [ 14.993171] PM: bootloader does not support rtc-only! [ 15.301327] net eth1: initializing cpsw version 1.12 (0) [ 15.536193] Atheros 8031 ethernet 4a101000.mdio:01: attached PHY driver [Atheros 8031 ethernet] (mii_bus:phy_addr=4a101000.mdio:01, irq=POLL) [ 15.807038] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready [ 16.051892] net eth0: initializing cpsw version 1.12 (0) [ 16.186086] Atheros 8031 ethernet 4a101000.mdio:00: attached PHY driver [Atheros 8031 ethernet] (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL) [ 16.229779] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 17.641132] random: crng init done [ 17.694753] random: 7 urandom warning(s) missed due to ratelimiting [ 18.326380] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx [ 18.372317] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 21.506240] TI-am335x-tsc 44e0d000.tscadc:tsc: ti,charge-delay not specified [ 21.513614] input: ti-tsc as /devices/platform/ocp/44e0d000.tscadc/44e0d000.tscadc:tsc/input/input1 [ 21.826183] am335x-phy-driver 47401300.usb-phy: GPIO lookup for consumer reset [ 21.826199] am335x-phy-driver 47401300.usb-phy: using device tree for GPIO lookup [ 21.826222] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp/usb@47400000/usb-phy@47401300[0]' [ 21.826231] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp/usb@47400000/usb-phy@47401300[0]' [ 21.826237] am335x-phy-driver 47401300.usb-phy: using lookup tables for GPIO lookup [ 21.826245] am335x-phy-driver 47401300.usb-phy: lookup for GPIO reset failed [ 21.826254] am335x-phy-driver 47401300.usb-phy: GPIO lookup for consumer vbus-detect [ 21.826259] am335x-phy-driver 47401300.usb-phy: using device tree for GPIO lookup [ 21.826267] of_get_named_gpiod_flags: can't parse 'vbus-detect-gpios' property of node '/ocp/usb@47400000/usb-phy@47401300[0]' [ 21.826274] of_get_named_gpiod_flags: can't parse 'vbus-detect-gpio' property of node '/ocp/usb@47400000/usb-phy@47401300[0]' [ 21.826279] am335x-phy-driver 47401300.usb-phy: using lookup tables for GPIO lookup [ 21.826285] am335x-phy-driver 47401300.usb-phy: lookup for GPIO vbus-detect failed [ 21.826383] am335x-phy-driver 47401300.usb-phy: 47401300.usb-phy supply vcc not found, using dummy regulator [ 21.939089] musb-hdrc musb-hdrc.0: MUSB HDRC host driver [ 22.031795] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1 [ 22.120052] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 22.202292] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 22.237482] pruss 4a300000.pruss: creating PRU cores and other child platform devices [ 22.354155] usb usb1: Product: MUSB HDRC host driver [ 22.400087] usb usb1: Manufacturer: Linux 4.14.79-ge669d52447 musb-hcd [ 22.458404] usb usb1: SerialNumber: musb-hdrc.0 [ 22.522248] hub 1-0:1.0: USB hub found [ 22.564716] hub 1-0:1.0: 1 port detected [ 22.622371] am335x-phy-driver 47401b00.usb-phy: GPIO lookup for consumer reset [ 22.622386] am335x-phy-driver 47401b00.usb-phy: using device tree for GPIO lookup [ 22.622405] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp/usb@47400000/usb-phy@47401b00[0]' [ 22.622414] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp/usb@47400000/usb-phy@47401b00[0]' [ 22.622420] am335x-phy-driver 47401b00.usb-phy: using lookup tables for GPIO lookup [ 22.622427] am335x-phy-driver 47401b00.usb-phy: lookup for GPIO reset failed [ 22.622437] am335x-phy-driver 47401b00.usb-phy: GPIO lookup for consumer vbus-detect [ 22.622442] am335x-phy-driver 47401b00.usb-phy: using device tree for GPIO lookup [ 22.622450] of_get_named_gpiod_flags: can't parse 'vbus-detect-gpios' property of node '/ocp/usb@47400000/usb-phy@47401b00[0]' [ 22.622457] of_get_named_gpiod_flags: can't parse 'vbus-detect-gpio' property of node '/ocp/usb@47400000/usb-phy@47401b00[0]' [ 22.622462] am335x-phy-driver 47401b00.usb-phy: using lookup tables for GPIO lookup [ 22.622468] am335x-phy-driver 47401b00.usb-phy: lookup for GPIO vbus-detect failed [ 22.622566] am335x-phy-driver 47401b00.usb-phy: 47401b00.usb-phy supply vcc not found, using dummy regulator [ 22.668295] remoteproc remoteproc1: 4a334000.pru is available [ 22.668363] pru-rproc 4a334000.pru: PRU rproc node /ocp/pruss_soc_bus@4a326004/pruss@0/pru@34000 probed successfully [ 22.669090] remoteproc remoteproc2: 4a338000.pru is available [ 22.669168] pru-rproc 4a338000.pru: PRU rproc node /ocp/pruss_soc_bus@4a326004/pruss@0/pru@38000 probed successfully [ 22.943962] musb-hdrc musb-hdrc.1: MUSB HDRC host driver [ 22.976730] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2 [ 23.011908] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 23.046777] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 23.085397] usb usb2: Product: MUSB HDRC host driver [ 23.101958] usb usb2: Manufacturer: Linux 4.14.79-ge669d52447 musb-hcd [ 23.136436] usb usb2: SerialNumber: musb-hdrc.1 [ 23.171242] hub 2-0:1.0: USB hub found [ 23.185803] hub 2-0:1.0: 1 port detected [ 26.141803] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ] [ 26.205380] using random self ethernet address [ 26.205388] using random host ethernet address [ 26.205400] using host ethernet address: C4:ED:BA:8D:4C:7D [ 26.205427] using random self ethernet address [ 26.205431] using random host ethernet address [ 26.205446] using host ethernet address: C4:ED:BA:8D:4C:7D [ 26.208688] usb0: HOST MAC c4:ed:ba:8d:4c:7d [ 26.209077] usb0: MAC 46:b3:0f:0a:4b:5a [ 26.721022] Mass Storage Function, version: 2009/09/11 [ 26.763503] LUN: removable file: (no medium) [ 26.841752] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready [ 26.962079] LUN: removable read only file: /dev/mmcblk0p1 [ 27.057786] Number of LUNs=1 [ 27.078666] g_multi gadget: Multifunction Composite Gadget [ 27.153436] g_multi gadget: g_multi ready [ 27.487904] g_multi gadget: high-speed config #1: Multifunction with RNDIS [ 27.495229] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready [ 33.465022] hrtimer: interrupt took 184417 ns
U-Boot SPL 2018.01-g9d984f4548 (Apr 06 2019 - 07:42:30) Trying to boot from MMC1 *** Warning - bad CRC, using default environment U-Boot 2018.01-g9d984f4548 (Apr 06 2019 - 07:42:30 +0000) CPU : AM335X-GP rev 2.1 Model: TI AM335x EVM-SK DRAM: 256 MiB NAND: 0 MiB MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1 *** Warning - bad CRC, using default environment <ethaddr> not set. Validating first E-fuse MAC Net: cpsw, usb_ether Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc0 is current device SD/MMC found on device 0 ** Unable to read file boot.scr ** ** Unable to read file uEnv.txt ** switch to partitions #0, OK mmc0 is current device Scanning mmc 0:1... switch to partitions #0, OK mmc0 is current device SD/MMC found on device 0 3871232 bytes read in 357 ms (10.3 MiB/s) 40033 bytes read in 48 ms (814.5 KiB/s) ## Flattened Device Tree blob at 88000000 Booting using the fdt blob at 0x88000000 Loading Device Tree to 8df01000, end 8df0dc60 ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.14.79-ge669d52447 (oe-user@oe-host) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #1 PREEMPT Sat Apr 6 03:14:17 UTC 2019 [ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: TI AM335x EVM-SK [ 0.000000] Memory policy: Data cache writeback [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] cma: Reserved 48 MiB at 0x8a800000 [ 0.000000] CPU: All CPU(s) started in SVC mode. [ 0.000000] AM335X ES2.1 (sgx neon) [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 64960 [ 0.000000] Kernel command line: console=ttyO0,115200n8 root=PARTUUID=00037e34-02 rw rootfstype=ext4 rootwait [ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes) [ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) [ 0.000000] Memory: 197276K/262144K available (8192K kernel code, 319K rwdata, 2544K rodata, 1024K init, 267K bss, 15716K reserved, 49152K cma-reserved, 0K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB) [ 0.000000] vmalloc : 0xd0800000 - 0xff800000 ( 752 MB) [ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc0900000 (9184 kB) [ 0.000000] .init : 0xc0c00000 - 0xc0d00000 (1024 kB) [ 0.000000] .data : 0xc0d00000 - 0xc0d4fd40 ( 320 kB) [ 0.000000] .bss : 0xc0d4fd40 - 0xc0d92a8c ( 268 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] Tasks RCU enabled. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts [ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz [ 0.000014] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns [ 0.000032] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.000042] OMAP clocksource: timer1 at 24000000 Hz [ 0.000213] timer_probe: no matching timers found [ 0.000412] Console: colour dummy device 80x30 [ 0.000440] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0' [ 0.000447] This ensures that you still see kernel messages. Please [ 0.000452] update your kernel commandline. [ 0.000481] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736) [ 0.089180] pid_max: default: 32768 minimum: 301 [ 0.089352] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.089366] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.090112] CPU: Testing write buffer coherency: ok [ 0.090175] CPU0: Spectre v2: using BPIALL workaround [ 0.090848] Setting up static identity map for 0x80100000 - 0x80100060 [ 0.090994] Hierarchical SRCU implementation. [ 0.091305] EFI services will not be available. [ 0.092527] devtmpfs: initialized [ 0.099878] random: get_random_u32 called from bucket_table_alloc+0x8c/0x1ac with crng_init=0 [ 0.100330] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 [ 0.100616] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.100639] futex hash table entries: 256 (order: -1, 3072 bytes) [ 0.104112] pinctrl core: initialized pinctrl subsystem [ 0.104825] DMI not present or invalid. [ 0.105216] NET: Registered protocol family 16 [ 0.107314] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.120053] omap_hwmod: debugss: _wait_target_disable failed [ 0.172013] cpuidle: using governor ladder [ 0.172045] cpuidle: using governor menu [ 0.176033] OMAP GPIO hardware version 0.1 [ 0.185725] No ATAGs? [ 0.185744] hw-breakpoint: debug architecture 0x4 unsupported. [ 0.197668] edma 49000000.edma: TI EDMA DMA engine driver [ 0.198687] reg-fixed-voltage fixedregulator2: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_wl12xx_gpio, deferring probe [ 0.201532] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe [ 0.201685] media: Linux media interface: v0.10 [ 0.201724] Linux video capture interface: v2.00 [ 0.201827] pps_core: LinuxPPS API ver. 1 registered [ 0.201835] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.201855] PTP clock support registered [ 0.201887] EDAC MC: Ver: 3.0.0 [ 0.202344] dmi: Firmware registration failed. [ 0.202744] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400 [ 0.203088] Advanced Linux Sound Architecture Driver Initialized. [ 0.204209] clocksource: Switched to clocksource timer1 [ 0.211642] NET: Registered protocol family 2 [ 0.212338] TCP established hash table entries: 2048 (order: 1, 8192 bytes) [ 0.212368] TCP bind hash table entries: 2048 (order: 1, 8192 bytes) [ 0.212391] TCP: Hash tables configured (established 2048 bind 2048) [ 0.212495] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.212512] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.212662] NET: Registered protocol family 1 [ 0.213096] RPC: Registered named UNIX socket transport module. [ 0.213108] RPC: Registered udp transport module. [ 0.213114] RPC: Registered tcp transport module. [ 0.213119] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.213990] hw perfevents: no interrupt-affinity property for /pmu, guessing. [ 0.214119] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available [ 0.215750] workingset: timestamp_bits=14 max_order=16 bucket_order=2 [ 0.219489] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.220291] NFS: Registering the id_resolver key type [ 0.220333] Key type id_resolver registered [ 0.220339] Key type id_legacy registered [ 0.220380] ntfs: driver 2.1.32 [Flags: R/O]. [ 0.222329] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 0.222348] io scheduler noop registered [ 0.222355] io scheduler deadline registered [ 0.222560] io scheduler cfq registered (default) [ 0.222570] io scheduler mq-deadline registered [ 0.222577] io scheduler kyber registered [ 0.223761] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568 [ 0.226988] pwm-backlight backlight: backlight supply power not found, using dummy regulator [ 0.270523] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 0.273451] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 30, base_baud = 3000000) is a 8250 [ 0.916040] console [ttyS0] enabled [ 0.921353] omap_rng 48310000.rng: Random Number Generator ver. 20 [ 0.929304] panel panel: found backlight [ 0.933556] OF: graph: no port node found in /ocp/lcdc@4830e000 [ 0.939789] OF: graph: no port node found in /ocp/lcdc@4830e000 [ 0.946237] OF: graph: no port node found in /ocp/lcdc@4830e000 [ 0.952191] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 0.958871] [drm] No driver support for vblank timestamp query. [ 1.008054] Console: switching to colour frame buffer device 60x34 [ 1.031925] tilcdc 4830e000.lcdc: fb0: frame buffer device [ 1.038074] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on minor 0 [ 1.056396] brd: module loaded [ 1.066062] loop: module loaded [ 1.071204] libphy: Fixed MDIO Bus: probed [ 1.144261] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000 [ 1.151974] davinci_mdio 4a10 [ 2.981575] systemd[1]: Configuration file /etc/systemd/system/bootcount.service is marked executable. Please remove executable permission bits. Proceeding anyway. [ 3.106830] random: systemd: uninitialized urandom read (16 bytes read) [ 3.113833] systemd[1]: Listening on Network Service Netlink Socket. [ OK ] Listening on Network Service Netlink Socket. [ 3.222374] random: systemd: uninitialized urandom read (16 bytes read) [ 3.230351] systemd[1]: Listening on Journal Socket (/dev/log). [ OK ] Listening on Journal Socket (/dev/log). [ 3.265238] random: systemd: uninitialized urandom read (16 bytes read) [ 3.289854] systemd[1]: Listening on Process Core Dump Socket. [ OK ] Listening on Process Core Dump Socket. [ 3.325024] systemd[1]: Listening on udev Kernel Socket. [ OK ] Listening on udev Kernel Socket. [ 3.355249] systemd[1]: Reached target Remote File Systems. [ OK ] Reached target Remote File Systems. [ OK ] Listening on Syslog Socket. [ OK ] Created slice System Slice. Mounting Kernel Debug File System... [ OK ] Started Dispatch Password Requests to Console Directory Watch. [ OK ] Listening on Journal Socket. Starting Remount Root and Kernel File Systems... [ OK ] Created slice User and Session Slice. [ OK ] Reached target Slices. [ 3.601552] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) Starting Load Kernel Modules... [ OK ] Started Forward Password Requests to Wall Dir[ 3.661345] cryptodev: loading out-of-tree module taints kernel. ectory Watch. [ 3.669916] cryptodev: driver 1.9 loaded. [ OK ] Reached target Paths. [ 3.709055] usbcore: registered new interface driver usbfs [ 3.714809] usbcore: registered new interface driver hub [ 3.720365] usbcore: registered new device driver usb [ OK ] Reached target Swap. [ 3.735491] usbcore: registered new interface driver usbserial Mounting POSIX Message Queue File System... [ 3.774980] usbcore: registered new interface driver ftdi_sio [ 3.780840] usbserial: USB Serial support registered for FTDI USB Serial Device Starting Create list of required st…ce nodes for the current kernel... [ OK ] Listening on /dev/initctl Compatibility Named Pipe. [ OK ] Created slice system-serial\x2dgetty.slice. [ OK ] Listening on udev Control Socket. Mounting Temporary Directory (/tmp)... Starting Journal Service... [ OK ] Created slice system-getty.slice. [ OK ] Mounted Kernel Debug File System. [ OK ] Mounted POSIX Message Queue File System. [ OK ] Mounted Temporary Directory (/tmp). [ OK ] Started Remount Root and Kernel File Systems. [ OK ] Started Load Kernel Modules. [ OK ] Started Create list of required sta…vice nodes for the current kernel. [ OK ] Started Journal Service. Mounting Kernel Configuration File System... Starting Apply Kernel Variables... Starting Flush Journal to Persistent Storage... Starting Create System Users... Starting Rebuild Hardware Database... [ OK ] Mounted Kernel Configuration File System. [ OK ] Started Apply Kernel Variables. [ OK ] Started Create System Users. [ 4.585680] systemd-journald[72]: Received request to flush runtime journal from PID 1 Starting Create Static Device Nodes in /dev... [ OK ] Started Flush Journal to Persistent Storage. [ OK ] Started Create Static Device Nodes in /dev. Starting udev Kernel Device Manager... [ OK ] Reached target Local File Systems (Pre). Mounting /var/volatile... Mounting /media/ram... [ OK ] Mounted /var/volatile. [ OK ] Mounted /media/ram. Starting Load/Save Random Seed... [ OK ] Reached target Local File Systems. Starting Rebuild Journal Catalog... Starting Create Volatile Files and Directories... Starting Rebuild Dynamic Linker Cache... [ OK ] Started udev Kernel Device Manager. [ OK ] Started Load/Save Random Seed. [ OK ] Started Create Volatile Files and Directories. Starting Update UTMP about System Boot/Shutdown... Starting Network Time Synchronization... [ OK ] Started Rebuild Journal Catalog. [ OK ] Started Update UTMP about System Boot/Shutdown. [ OK ] Started Network Time Synchronization. [ OK ] Reached target System Time Synchronized. [ OK ] Started Rebuild Dynamic Linker Cache. [ OK ] Started Rebuild Hardware Database. Starting udev Coldplug all Devices... Starting Update is Completed... [ OK ] Started Update is Completed. [ OK ] Created slice system-systemd\x2dbacklight.slice. Starting Load/Save Screen Backlight…ightness of backlight:backlight... [ OK ] Started udev Coldplug all Devices. [ 17.456906] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec [ OK ] Found device /dev/ttyS0. [ OK ] Started Load/Save Screen Backlight Brightness of backlight:backlight. [ 17.598376] omap_rtc 44e3e000.rtc: already running [ OK ] Reached target System Initialization. [ OK ] Listening on D-Bus System Message Bus Socket. [ 17.657285] omap_rtc 44e3e000.rtc: registered as rtc0 [ 17.746302] tlv320aic3x-codec 0-001b: Too high supply voltage(s) AVDD: 3300000, DVDD: 5000000 [ OK ] Listening on dropbear.socket. [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. [ OK ] Listening on RPCbind Server Activation Socket. [ OK ] Reached target Sockets. [ OK ] Reached target Basic System. [ OK ] Reached target Containers. Starting System Boot count... [ OK ] Started System Logging Service. Starting Avahi mDNS/DNS-SD Stack... [ OK ] Started Periodic Command Scheduler. [ OK ] Started Hardware RNG Entropy Gatherer Daemon. Starting Print notice about GPLv3 packages... [ 18.684937] omap-sham 53100000.sham: hw accel on OMAP rev 4.3 Starting uim-sysfs.service... [ OK ] Started D-Bus System Message Bus. [ 18.856203] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2 [ 18.893480] omap-aes 53500000.aes: will run requests pump with realtime priority [ 19.117259] remoteproc remoteproc0: wkup_m3 is available [ 19.175020] [drm] Initialized pvr 1.14.3699939 20110701 for 56000000.sgx on minor 1 [ 19.209822] remoteproc remoteproc0: powering up wkup_m3 [ 19.284133] PM: Cannot get wkup_m3_ipc handle [ 19.315637] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 224628 [ 19.315895] remoteproc remoteproc0: remote processor wkup_m3 is now up [ 19.315920] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192 [ 19.533952] asoc-simple-card sound: tlv320aic3x-hifi <-> 4803c000.mcasp mapping ok [ 19.597322] asoc-simple-card sound: ASoC: no DMI vendor name! [ 19.668964] PM: bootloader does not support rtc-only! [ 20.116532] random: crng init done [ 20.138059] random: 7 urandom warning(s) missed due to ratelimiting [ 27.507684] am335x-phy-driver 47401300.usb-phy: 47401300.usb-phy supply vcc not found, using dummy regulator [ 27.543429] am335x-phy-driver 47401b00.usb-phy: 47401b00.usb-phy supply vcc not found, using dummy regulator [ 29.195390] TI-am335x-tsc 44e0d000.tscadc:tsc: ti,charge-delay not specified [ 29.290965] input: ti-tsc as /devices/platform/ocp/44e0d000.tscadc/44e0d000.tscadc:tsc/input/input1 [ 29.332401] musb-hdrc musb-hdrc.0: MUSB HDRC host driver [ 29.332443] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1 [ 29.369422] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 29.369432] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 29.369437] usb usb1: Product: MUSB HDRC host driver [ 29.369442] usb usb1: Manufacturer: Linux 4.14.79-ge669d52447 musb-hcd [ 29.369448] usb usb1: SerialNumber: musb-hdrc.0 [ 29.372556] hub 1-0:1.0: USB hub found [ 29.372608] hub 1-0:1.0: 1 port detected [ 29.383360] musb-hdrc musb-hdrc.1: MUSB HDRC host driver [ 29.383390] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2 [ 29.499558] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 29.499569] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 29.499574] usb usb2: Product: MUSB HDRC host driver [ 29.499579] usb usb2: Manufacturer: Linux 4.14.79-ge669d52447 musb-hcd [ 29.499584] usb usb2: SerialNumber: musb-hdrc.1 [ 29.500314] hub 2-0:1.0: USB hub found [ 29.500363] hub 2-0:1.0: 1 port detected [ 29.861057] pruss 4a300000.pruss: creating PRU cores and other child platform devices [ 30.128135] remoteproc remoteproc1: 4a334000.pru is available [ 30.128236] pru-rproc 4a334000.pru: PRU rproc node /ocp/pruss_soc_bus@4a326004/pruss@0/pru@34000 probed successfully [ 30.129851] remoteproc remoteproc2: 4a338000.pru is available [ 30.129912] pru-rproc 4a338000.pru: PRU rproc node /ocp/pruss_soc_bus@4a326004/pruss@0/pru@38000 probed successfully [ OK ] Started Avahi mDNS/DNS-SD Stack. Starting RPC Bind Service... Starting Login Service... [ OK ] Started Daily rotation of log files. Starting Network Service... [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Reached target Timers. [ OK ] Started Job spooling tools. [ OK ] Started Kernel Logging Service. [ OK ] Started System Boot count. [ OK ] Started uim-sysfs.service. [ OK ] Started RPC Bind Service. [ OK ] Found device /dev/ttyS3. [ OK ] Started Network Service. [ 31.326733] net eth1: initializing cpsw version 1.12 (0) [ 31.486250] Atheros 8031 ethernet 4a101000.mdio:01: attached PHY driver [Atheros 8031 ethernet] (mii_bus:phy_addr=4a101000.mdio:01, irq=POLL) [ 31.574769] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready [ 31.652526] net eth0: initializing cpsw version 1.12 (0) [ 31.796115] Atheros 8031 ethernet 4a101000.mdio:00: attached PHY driver [Atheros 8031 ethernet] (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL) [ 31.863976] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 33.926443] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx [ 33.959352] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ OK ] Found device /dev/mmcblk0p1. Starting Start USB gadget... [ OK ] Reached target Sound Card. [ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch. [ OK ] Reached target Network. Starting Permit User Sessions... Starting Enable and configure wl18xx bluetooth stack... Starting Lightning Fast Webserver With Light System Requirements... [ OK ] Started Redis In-Memory Data Store. Starting Simple Network Management Protocol (SNMP) Daemon.... Starting Wait for Network to be Configured... *************************************************************** *************************************************************** NOTICE: This file system contains the following GPLv3 packages: autoconf bash-dev bash binutils cifs-utils cpio cpp-symlinks cpp dosfstools elfutils findutils g++-symlinks g++ gawk gcc-symlinks gcc gdb gdbserver gettext glmark2 gstreamer1.0-libav gzip hidapi libdw1 libelf1 libgdbm-compat4 libgdbm-dev libgdbm4 libgettextlib libgettextsrc libgmp10 libidn11 libmavconn libmpc3 libmpfr4 libreadline-dev libreadline7 libunistring2 m4-dev m4 make mavlink mavros-extras mavros-msgs mavros nettle python3-pycairo socketcan-interface which If you do not wish to distribute GPLv3 components please remove the above packages prior to distribution. This can be done using the opkg remove command. i.e.: opkg remove <package> Where <package> is the name printed in the list above NOTE: If the package is a dependency of another package you will be notified of the dependent packages. You should use the --force-removal-of-dependent-packages option to also remove the dependent packages as well *************************************************************** ****************************[ 36.335436] using random self ethernet address *********************************** [ 36.380687] using random host ethernet address Starting Network Name Resolution... [ 36.413064] using host ethernet address: C4:ED:BA:8D:4C:7D [ 36.413147] using random self ethernet address Starting rc.pvr.service... [ 36.517841] using random host ethernet address [ 36.547314] using host ethernet address: C4:ED:BA:8D:4C:7D [ 36.567998] usb0: HOST MAC c4:ed:ba:8d:4c:7d [ 36.660214] usb0: MAC 82:7a:42:ba:1d:de [ OK ] Started Print notice about GPLv3 packages. [ OK ] Started Permit User Sessions. [ 36.752769] Mass Storage Function, version: 2009/09/11 [ 36.781949] LUN: removable file: (no medium) [ 36.791383] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ] [ OK ] Started Lightning Fast Webserver With Light S[ 36.881213] LUN: removable read only file: /dev/mmcblk0p1 ystem Requirements. [ OK ] Started Login Service. [ 36.977040] Number of LUNs=1 [ OK ] Found device /dev/ttyGS0. [ 37.064586] g_multi gadget: Multifunction Composite Gadget [ 37.070126] g_multi gadget: g_multi ready [ OK ] Started Getty on tty1. [ OK ] Started Serial Getty on ttyS0. [ OK ] Started Serial Getty on ttyS3. [ 37.315241] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready [ OK ] Started rc.pvr.service. [ OK ] Started Network Name Resolution. [ OK ] Reached target Host and Network Name Lookups. [ 37.459908] g_multi gadget: high-speed config #1: Multifunction with RNDIS [ 37.467214] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready [ OK ] Started NFS status monitor for NFSv2/3 locking.. Starting weston.service... [ OK ] Started Simple Network Management Protocol (SNMP) Daemon.. [ OK ] Started weston.service. [ OK ] Started Start USB gadget. [ OK ] Started Enable and configure wl18xx bluetooth stack. [ OK ] Started Serial Getty on ttyGS0. [ OK ] Reached target Login Prompts. Starting Synchronize System and HW clocks... Starting Matrix GUI... Starting telnetd.service... [ OK ] Started Synchronize System and HW clocks. [ OK ] Started Matrix GUI. [ OK ] Started telnetd.service. Starting busybox-udhcpd.service... Starting thttpd.service... [ OK ] Started busybox-udhcpd.service. [ OK ] Started thttpd.service. Starting rng-tools.service... [ OK ] Started rng-tools.service. _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|_[ 43.231465] hrtimer: interrupt took 176417 ns __ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project http://arago-project.org am335x-evm ttyS0 Arago 2018.10 am335x-evm ttyS0 am335x-evm login: root root@am335x-evm:~# [ 158.033380] NET: Registered protocol family 15 [ 158.602405] Initializing XFRM netlink socket root@am335x-evm:~# lsmod | wc | awk '{print $1}' 67 root@am335x-evm:~# lsmod Module Size Used by sha512_generic 20480 0 sha512_arm 24576 0 sha256_generic 20480 0 sha1_generic 16384 0 sha1_arm_neon 20480 0 sha1_arm 16384 1 sha1_arm_neon md5 16384 0 aes_arm_bs 20480 0 crypto_simd 16384 1 aes_arm_bs cryptd 24576 1 crypto_simd des_generic 28672 0 cbc 16384 0 xfrm_user 32768 2 xfrm4_tunnel 16384 0 ipcomp 16384 0 xfrm_ipcomp 16384 1 ipcomp esp4 20480 0 ah4 16384 0 af_key 36864 0 xfrm_algo 16384 5 xfrm_user,esp4,ah4,af_key,xfrm_ipcomp bc_example 16384 0 usb_f_acm 16384 1 u_serial 20480 3 usb_f_acm usb_f_ecm 16384 1 g_multi 16384 0 usb_f_mass_storage 40960 2 g_multi usb_f_rndis 24576 2 g_multi u_ether 20480 3 usb_f_ecm,g_multi,usb_f_rndis libcomposite 53248 5 usb_f_ecm,usb_f_acm,usb_f_mass_storage,g_multi,usb_f_rndis pru_rproc 20480 0 pruss_intc 16384 1 pru_rproc pruss 16384 1 pru_rproc musb_dsps 20480 0 musb_hdrc 98304 1 musb_dsps ti_am335x_tsc 16384 0 phy_am335x 16384 2 phy_generic 16384 1 phy_am335x udc_core 28672 8 usb_f_ecm,usb_f_acm,usb_f_mass_storage,u_serial,musb_hdrc,u_ether,usb_f_rndis,libcomposite phy_am335x_control 16384 1 phy_am335x snd_soc_simple_card 16384 0 snd_soc_simple_card_utils 16384 1 snd_soc_simple_card pm33xx 16384 0 wkup_m3_ipc 16384 1 pm33xx wkup_m3_rproc 16384 1 pvrsrvkm 413696 5 bc_example remoteproc 40960 3 pru_rproc,wkup_m3_rproc,wkup_m3_ipc omap_aes_driver 24576 0 crypto_engine 16384 1 omap_aes_driver omap_sham 28672 0 omap_crypto 16384 1 omap_aes_driver ti_emif_sram 16384 1 pm33xx pruss_soc_bus 16384 0 wlcore_sdio 16384 0 snd_soc_tlv320aic3x 57344 1 rtc_omap 20480 2 musb_am335x 16384 0 omap_wdt 16384 0 ti_am335x_tscadc 16384 1 ti_am335x_tsc sch_fq_codel 20480 4 uio_module_drv 16384 0 uio 20480 1 uio_module_drv ftdi_sio 40960 0 usbserial 36864 1 ftdi_sio usbcore 204800 3 ftdi_sio,musb_hdrc,usbserial usb_common 16384 6 phy_am335x,udc_core,musb_hdrc,libcomposite,musb_dsps,usbcore cryptodev 45056 1 root@am335x-evm:~# dmesg [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 4.14.79-ge669d52447 (oe-user@oe-host) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #1 PREEMPT Sat Apr 6 03:14:17 UTC 2019 [ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] OF: fdt: Machine model: TI AM335x EVM-SK [ 0.000000] Memory policy: Data cache writeback [ 0.000000] efi: Getting EFI parameters from FDT: [ 0.000000] efi: UEFI not found. [ 0.000000] cma: Reserved 48 MiB at 0x8a800000 [ 0.000000] On node 0 totalpages: 65536 [ 0.000000] free_area_init_node: node 0, pgdat c0d4d4b0, node_mem_map cfda1000 [ 0.000000] Normal zone: 576 pages used for memmap [ 0.000000] Normal zone: 0 pages reserved [ 0.000000] Normal zone: 65536 pages, LIFO batch:15 [ 0.000000] CPU: All CPU(s) started in SVC mode. [ 0.000000] AM335X ES2.1 (sgx neon) [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768 [ 0.000000] pcpu-alloc: [0] 0 [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 64960 [ 0.000000] Kernel command line: console=ttyO0,115200n8 root=PARTUUID=00037e34-02 rw rootfstype=ext4 rootwait [ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes) [ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) [ 0.000000] Memory: 197276K/262144K available (8192K kernel code, 319K rwdata, 2544K rodata, 1024K init, 267K bss, 15716K reserved, 49152K cma-reserved, 0K highmem) [ 0.000000] Virtual kernel memory layout: vector : 0xffff0000 - 0xffff1000 ( 4 kB) fixmap : 0xffc00000 - 0xfff00000 (3072 kB) vmalloc : 0xd0800000 - 0xff800000 ( 752 MB) lowmem : 0xc0000000 - 0xd0000000 ( 256 MB) pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) modules : 0xbf000000 - 0xbfe00000 ( 14 MB) .text : 0xc0008000 - 0xc0900000 (9184 kB) .init : 0xc0c00000 - 0xc0d00000 (1024 kB) .data : 0xc0d00000 - 0xc0d4fd40 ( 320 kB) .bss : 0xc0d4fd40 - 0xc0d92a8c ( 268 kB) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1 [ 0.000000] Preemptible hierarchical RCU implementation. [ 0.000000] Tasks RCU enabled. [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16 [ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts [ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz [ 0.000014] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns [ 0.000032] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns [ 0.000042] OMAP clocksource: timer1 at 24000000 Hz [ 0.000213] timer_probe: no matching timers found [ 0.000412] Console: colour dummy device 80x30 [ 0.000440] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0' [ 0.000447] This ensures that you still see kernel messages. Please [ 0.000452] update your kernel commandline. [ 0.000481] Calibrating delay loop... 996.14 BogoMIPS (lpj=4980736) [ 0.089180] pid_max: default: 32768 minimum: 301 [ 0.089352] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.089366] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.090112] CPU: Testing write buffer coherency: ok [ 0.090175] CPU0: Spectre v2: using BPIALL workaround [ 0.090848] Setting up static identity map for 0x80100000 - 0x80100060 [ 0.090994] Hierarchical SRCU implementation. [ 0.091305] EFI services will not be available. [ 0.092527] devtmpfs: initialized [ 0.099878] random: get_random_u32 called from bucket_table_alloc+0x8c/0x1ac with crng_init=0 [ 0.100330] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 [ 0.100616] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns [ 0.100639] futex hash table entries: 256 (order: -1, 3072 bytes) [ 0.104112] pinctrl core: initialized pinctrl subsystem [ 0.104825] DMI not present or invalid. [ 0.105216] NET: Registered protocol family 16 [ 0.107314] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.120053] omap_hwmod: debugss: _wait_target_disable failed [ 0.172013] cpuidle: using governor ladder [ 0.172045] cpuidle: using governor menu [ 0.175883] gpio gpiochip0: (gpio): added GPIO chardev (254:0) [ 0.175972] gpiochip_setup_dev: registered GPIOs 0 to 31 on device: gpiochip0 (gpio) [ 0.176033] OMAP GPIO hardware version 0.1 [ 0.176765] gpio gpiochip1: (gpio): added GPIO chardev (254:1) [ 0.176839] gpiochip_setup_dev: registered GPIOs 32 to 63 on device: gpiochip1 (gpio) [ 0.177503] gpio gpiochip2: (gpio): added GPIO chardev (254:2) [ 0.177571] gpiochip_setup_dev: registered GPIOs 64 to 95 on device: gpiochip2 (gpio) [ 0.178223] gpio gpiochip3: (gpio): added GPIO chardev (254:3) [ 0.178303] gpiochip_setup_dev: registered GPIOs 96 to 127 on device: gpiochip3 (gpio) [ 0.185725] No ATAGs? [ 0.185744] hw-breakpoint: debug architecture 0x4 unsupported. [ 0.197668] edma 49000000.edma: TI EDMA DMA engine driver [ 0.198214] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator0[0]' [ 0.198491] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator1[0]' [ 0.198687] reg-fixed-voltage fixedregulator2: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_wl12xx_gpio, deferring probe [ 0.198788] of_get_named_gpiod_flags: parsed 'gpio' property of node '/fixedregulator3[0]' - status (0) [ 0.201532] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe [ 0.201685] media: Linux media interface: v0.10 [ 0.201724] Linux video capture interface: v2.00 [ 0.201827] pps_core: LinuxPPS API ver. 1 registered [ 0.201835] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.201855] PTP clock support registered [ 0.201887] EDAC MC: Ver: 3.0.0 [ 0.202344] dmi: Firmware registration failed. [ 0.202744] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400 [ 0.203088] Advanced Linux Sound Architecture Driver Initialized. [ 0.204209] clocksource: Switched to clocksource timer1 [ 0.211642] NET: Registered protocol family 2 [ 0.212338] TCP established hash table entries: 2048 (order: 1, 8192 bytes) [ 0.212368] TCP bind hash table entries: 2048 (order: 1, 8192 bytes) [ 0.212391] TCP: Hash tables configured (established 2048 bind 2048) [ 0.212495] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.212512] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.212662] NET: Registered protocol family 1 [ 0.213096] RPC: Registered named UNIX socket transport module. [ 0.213108] RPC: Registered udp transport module. [ 0.213114] RPC: Registered tcp transport module. [ 0.213119] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.213134] PCI: CLS 0 bytes, default 64 [ 0.213990] hw perfevents: no interrupt-affinity property for /pmu, guessing. [ 0.214119] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available [ 0.215750] workingset: timestamp_bits=14 max_order=16 bucket_order=2 [ 0.219489] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.220291] NFS: Registering the id_resolver key type [ 0.220333] Key type id_resolver registered [ 0.220339] Key type id_legacy registered [ 0.220380] ntfs: driver 2.1.32 [Flags: R/O]. [ 0.222329] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 0.222348] io scheduler noop registered [ 0.222355] io scheduler deadline registered [ 0.222560] io scheduler cfq registered (default) [ 0.222570] io scheduler mq-deadline registered [ 0.222577] io scheduler kyber registered [ 0.223761] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568 [ 0.226914] pwm-backlight backlight: GPIO lookup for consumer enable [ 0.226927] pwm-backlight backlight: using device tree for GPIO lookup [ 0.226943] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/backlight[0]' [ 0.226952] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/backlight[0]' [ 0.226958] pwm-backlight backlight: using lookup tables for GPIO lookup [ 0.226965] pwm-backlight backlight: lookup for GPIO enable failed [ 0.226988] pwm-backlight backlight: backlight supply power not found, using dummy regulator [ 0.270523] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled [ 0.273451] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 30, base_baud = 3000000) is a 8250 [ 0.916040] console [ttyS0] enabled [ 0.921353] omap_rng 48310000.rng: Random Number Generator ver. 20 [ 0.929304] panel panel: found backlight [ 0.933256] panel panel: GPIO lookup for consumer enable [ 0.933261] panel panel: using device tree for GPIO lookup [ 0.933277] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/panel[0]' [ 0.933286] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/panel[0]' [ 0.933292] panel panel: using lookup tables for GPIO lookup [ 0.933299] panel panel: lookup for GPIO enable failed [ 0.933556] OF: graph: no port node found in /ocp/lcdc@4830e000 [ 0.939789] OF: graph: no port node found in /ocp/lcdc@4830e000 [ 0.946237] OF: graph: no port node found in /ocp/lcdc@4830e000 [ 0.952191] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 0.958871] [drm] No driver support for vblank timestamp query. [ 1.008054] Console: switching to colour frame buffer device 60x34 [ 1.031925] tilcdc 4830e000.lcdc: fb0: frame buffer device [ 1.038074] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on minor 0 [ 1.056396] brd: module loaded [ 1.066062] loop: module loaded [ 1.071164] mdio_bus fixed-0: GPIO lookup for consumer reset [ 1.071177] mdio_bus fixed-0: using lookup tables for GPIO lookup [ 1.071184] mdio_bus fixed-0: lookup for GPIO reset failed [ 1.071204] libphy: Fixed MDIO Bus: probed [ 1.090839] mdio_bus 4a101000.mdio: GPIO lookup for consumer reset [ 1.090851] mdio_bus 4a101000.mdio: using lookup tables for GPIO lookup [ 1.090857] mdio_bus 4a101000.mdio: lookup for GPIO reset failed [ 1.144261] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000 [ 1.151974] davinci_mdio 4a101000.mdio: detected phy mask fffffffc [ 1.160147] libphy: 4a101000.mdio: probed [ 1.164297] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver Atheros 8031 ethernet [ 1.173578] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver Atheros 8031 ethernet [ 1.183847] cpsw 4a100000.ethernet: Detected MACID = c4:ed:ba:8d:4c:7b [ 1.190737] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4 [ 1.197187] cpsw 4a100000.ethernet: ALE Table size 1024 [ 1.202491] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies) [ 1.210472] cpsw 4a100000.ethernet: cpsw: Detected MACID = c4:ed:ba:8d:4c:7d [ 1.218831] i2c /dev entries driver [ 1.222821] IR NEC protocol handler initialized [ 1.227433] IR RC5(x/sz) protocol handler initialized [ 1.232504] IR RC6 protocol handler initialized [ 1.237074] IR JVC protocol handler initialized [ 1.241620] IR Sony protocol handler initialized [ 1.246264] IR SANYO protocol handler initialized [ 1.250983] IR Sharp protocol handler initialized [ 1.255718] IR MCE Keyboard/mouse protocol handler initialized [ 1.261572] IR XMP protocol handler initialized [ 1.267781] cpuidle: enable-method property 'ti,am3352' found operations [ 1.274980] sdhci: Secure Digital Host Controller Interface driver [ 1.281190] sdhci: Copyright(c) Pierre Ossman [ 1.286055] omap_hsmmc 48060000.mmc: GPIO lookup for consumer cd [ 1.286064] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup [ 1.286099] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/ocp/mmc@48060000[0]' - status (0) [ 1.286119] omap_hsmmc 48060000.mmc: Got CD GPIO [ 1.290787] omap_hsmmc 48060000.mmc: GPIO lookup for consumer wp [ 1.290792] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup [ 1.290800] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@48060000[0]' [ 1.290808] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@48060000[0]' [ 1.290814] omap_hsmmc 48060000.mmc: using lookup tables for GPIO lookup [ 1.290821] omap_hsmmc 48060000.mmc: lookup for GPIO wp failed [ 1.291674] omap_hsmmc 481d8000.mmc: GPIO lookup for consumer cd [ 1.291684] omap_hsmmc 481d8000.mmc: using device tree for GPIO lookup [ 1.291696] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/mmc@481d8000[0]' [ 1.291703] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/mmc@481d8000[0]' [ 1.291709] omap_hsmmc 481d8000.mmc: using lookup tables for GPIO lookup [ 1.291715] omap_hsmmc 481d8000.mmc: lookup for GPIO cd failed [ 1.291723] omap_hsmmc 481d8000.mmc: GPIO lookup for consumer wp [ 1.291728] omap_hsmmc 481d8000.mmc: using device tree for GPIO lookup [ 1.291734] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@481d8000[0]' [ 1.291741] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@481d8000[0]' [ 1.291746] omap_hsmmc 481d8000.mmc: using lookup tables for GPIO lookup [ 1.291751] omap_hsmmc 481d8000.mmc: lookup for GPIO wp failed [ 1.292328] sdhci-pltfm: SDHCI platform and OF driver helper [ 1.298765] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led1[0]' - status (0) [ 1.298820] no flags found for gpios [ 1.298956] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led2[0]' - status (0) [ 1.298962] no flags found for gpios [ 1.299048] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led3[0]' - status (0) [ 1.299053] no flags found for gpios [ 1.299148] of_get_named_gpiod_flags: parsed 'gpios' property of node '/leds/led4[0]' - status (0) [ 1.299154] no flags found for gpios [ 1.299530] ledtrig-cpu: registered to indicate activity on CPUs [ 1.309759] NET: Registered protocol family 10 [ 1.315665] Segment Routing with IPv6 [ 1.319431] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver [ 1.326173] NET: Registered protocol family 17 [ 1.330934] Key type dns_resolver registered [ 1.335547] omap_voltage_late_init: Voltage driver support not added [ 1.347286] of_get_named_gpiod_flags: parsed 'gpio' property of node '/fixedregulator2[0]' - status (0) [ 1.374433] tps65910 0-002d: No interrupt support, no core IRQ [ 1.380506] tps65910-gpio tps65910-gpio: ti,en-gpio-sleep not specified [ 1.380529] gpiochip_find_base: found new base at 506 [ 1.380752] gpio gpiochip4: (tps65910): added GPIO chardev (254:4) [ 1.380831] gpiochip_setup_dev: registered GPIOs 506 to 511 on device: gpiochip4 (tps65910) [ 1.382177] vrtc: supplied by vbat [ 1.389364] vio: supplied by vbat [ 1.394165] vdd1: supplied by vbat [ 1.399378] vdd2: supplied by vbat [ 1.404219] random: fast init done [ 1.409300] vdig1: supplied by vbat [ 1.414117] vdig2: supplied by vbat [ 1.418979] vpll: supplied by vbat [ 1.423699] vdac: supplied by vbat [ 1.428453] vaux1: supplied by vbat [ 1.433289] vaux2: supplied by vbat [ 1.438141] vaux33: supplied by vbat [ 1.443019] vmmc: supplied by vbat [ 1.447799] vbb: supplied by vbat [ 1.452712] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz [ 1.460373] omap_hsmmc 48060000.mmc: GPIO lookup for consumer cd [ 1.460386] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup [ 1.460419] of_get_named_gpiod_flags: parsed 'cd-gpios' property of node '/ocp/mmc@48060000[0]' - status (0) [ 1.460440] omap_hsmmc 48060000.mmc: Got CD GPIO [ 1.465249] omap_hsmmc 48060000.mmc: GPIO lookup for consumer wp [ 1.465255] omap_hsmmc 48060000.mmc: using device tree for GPIO lookup [ 1.46526iod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@48060000[0]' [ 1.465275] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@48060000[0]' [ 1.465281] omap_hsmmc 48060000.mmc: using lookup tables for GPIO lookup [ 1.465289] omap_hsmmc 48060000.mmc: lookup for GPIO wp failed [ 1.526516] omap_hsmmc 481d8000.mmc: GPIO lookup for consumer cd [ 1.526546] omap_hsmmc 481d8000.mmc: using device tree for GPIO lookup [ 1.526582] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp/mmc@481d8000[0]' [ 1.526607] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp/mmc@481d8000[0]' [ 1.526624] omap_hsmmc 481d8000.mmc: using lookup tables for GPIO lookup [ 1.526643] omap_hsmmc 481d8000.mmc: lookup for GPIO cd failed [ 1.526668] omap_hsmmc 481d8000.mmc: GPIO lookup for consumer wp [ 1.526684] omap_hsmmc 481d8000.mmc: using device tree for GPIO lookup [ 1.526706] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp/mmc@481d8000[0]' [ 1.526726] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp/mmc@481d8000[0]' [ 1.526742] omap_hsmmc 481d8000.mmc: using lookup tables for GPIO lookup [ 1.526759] omap_hsmmc 481d8000.mmc: lookup for GPIO wp failed [ 1.571460] mmc0: host does not support reading read-only switch, assuming write-enable [ 1.581562] mmc0: new high speed SDHC card at address 1234 [ 1.587761] mmcblk0: mmc0:1234 SA08G 7.21 GiB [ 1.594020] mmcblk0: p1 p2 [ 1.676096] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_buttons0/switch1[0]' - status (0) [ 1.676557] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_buttons0/switch2[0]' - status (0) [ 1.676779] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_buttons0/switch3[0]' - status (0) [ 1.677002] of_get_named_gpiod_flags: parsed 'gpios' property of node '/gpio_buttons0/switch4[0]' - status (0) [ 1.677577] input: gpio_buttons0 as /devices/platform/gpio_buttons0/input/input0 [ 1.689551] hctosys: unable to open rtc device (rtc0) [ 1.695106] omap_hsmmc 481d8000.mmc: card claims to support voltages below defined range [ 1.703705] lis3_reg: disabling [ 1.707422] ALSA device list: [ 1.710614] No soundcards found. [ 1.724159] mmc1: new SDIO card at address 0001 [ 1.736055] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 1.744444] VFS: Mounted root (ext4 filesystem) on device 179:2. [ 1.755298] devtmpfs: mounted [ 1.759791] Freeing unused kernel memory: 1024K [ 2.221190] systemd[1]: System time before build time, advancing clock. [ 2.300095] systemd[1]: systemd 234 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN default-hierarchy=hybrid) [ 2.322257] systemd[1]: Detected architecture arm. [ 2.376455] systemd[1]: Set hostname to <am335x-evm>. [ 2.783989] systemd[1]: /lib/systemd/system/gadget-init.service:15: Unknown lvalue 'ExecStopPre' in section 'Service' [ 2.981575] systemd[1]: Configuration file /etc/systemd/system/bootcount.service is marked executable. Please remove executable permission bits. Proceeding anyway. [ 3.106830] random: systemd: uninitialized urandom read (16 bytes read) [ 3.113833] systemd[1]: Listening on Network Service Netlink Socket. [ 3.222374] random: systemd: uninitialized urandom read (16 bytes read) [ 3.230351] systemd[1]: Listening on Journal Socket (/dev/log). [ 3.265238] random: systemd: uninitialized urandom read (16 bytes read) [ 3.289854] systemd[1]: Listening on Process Core Dump Socket. [ 3.325024] systemd[1]: Listening on udev Kernel Socket. [ 3.355249] systemd[1]: Reached target Remote File Systems. [ 3.601552] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) [ 3.661345] cryptodev: loading out-of-tree module taints kernel. [ 3.669916] cryptodev: driver 1.9 loaded. [ 3.709055] usbcore: registered new interface driver usbfs [ 3.714809] usbcore: registered new interface driver hub [ 3.720365] usbcore: registered new device driver usb [ 3.735491] usbcore: registered new interface driver usbserial [ 3.774980] usbcore: registered new interface driver ftdi_sio [ 3.780840] usbserial: USB Serial support registered for FTDI USB Serial Device [ 4.585680] systemd-journald[72]: Received request to flush runtime journal from PID 1 [ 17.456906] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec [ 17.598376] omap_rtc 44e3e000.rtc: already running [ 17.657092] omap_rtc 44e3e000.rtc: char device (253:0) [ 17.657285] omap_rtc 44e3e000.rtc: registered as rtc0 [ 17.745979] of_get_named_gpiod_flags: can't parse 'gpio-reset' property of node '/ocp/i2c@44e0b000/tlv320aic3106@1b[0]' [ 17.746302] tlv320aic3x-codec 0-001b: Too high supply voltage(s) AVDD: 3300000, DVDD: 5000000 [ 18.684937] omap-sham 53100000.sham: hw accel on OMAP rev 4.3 [ 18.856203] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2 [ 18.893480] omap-aes 53500000.aes: will run requests pump with realtime priority [ 19.117259] remoteproc remoteproc0: wkup_m3 is available [ 19.175020] [drm] Initialized pvr 1.14.3699939 20110701 for 56000000.sgx on minor 1 [ 19.209822] remoteproc remoteproc0: powering up wkup_m3 [ 19.284133] PM: Cannot get wkup_m3_ipc handle [ 19.315637] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 224628 [ 19.315895] remoteproc remoteproc0: remote processor wkup_m3 is now up [ 19.315920] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192 [ 19.532774] of_get_named_gpiod_flags: can't parse 'simple-audio-card,hp-det-gpio' property of node '/sound[0]' [ 19.532789] of_get_named_gpiod_flags: can't parse 'simple-audio-card,mic-det-gpio' property of node '/sound[0]' [ 19.533952] asoc-simple-card sound: tlv320aic3x-hifi <-> 4803c000.mcasp mapping ok [ 19.597322] asoc-simple-card sound: ASoC: no DMI vendor name! [ 19.668964] PM: bootloader does not support rtc-only! [ 20.116532] random: crng init done [ 20.138059] random: 7 urandom warning(s) missed due to ratelimiting [ 27.507485] am335x-phy-driver 47401300.usb-phy: GPIO lookup for consumer reset [ 27.507502] am335x-phy-driver 47401300.usb-phy: using device tree for GPIO lookup [ 27.507525] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp/usb@47400000/usb-phy@47401300[0]' [ 27.507534] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp/usb@47400000/usb-phy@47401300[0]' [ 27.507540] am335x-phy-driver 47401300.usb-phy: using lookup tables for GPIO lookup [ 27.507547] am335x-phy-driver 47401300.usb-phy: lookup for GPIO reset failed [ 27.507556] am335x-phy-driver 47401300.usb-phy: GPIO lookup for consumer vbus-detect [ 27.507561] am335x-phy-driver 47401300.usb-phy: using device tree for GPIO lookup [ 27.507568] of_get_named_gpiod_flags: can't parse 'vbus-detect-gpios' property of node '/ocp/usb@47400000/usb-phy@47401300[0]' [ 27.507576] of_get_named_gpiod_flags: can't parse 'vbus-detect-gpio' property of node '/ocp/usb@47400000/usb-phy@47401300[0]' [ 27.507581] am335x-phy-driver 47401300.usb-phy: using lookup tables for GPIO lookup [ 27.507587] am335x-phy-driver 47401300.usb-phy: lookup for GPIO vbus-detect failed [ 27.507684] am335x-phy-driver 47401300.usb-phy: 47401300.usb-phy supply vcc not found, using dummy regulator [ 27.543238] am335x-phy-driver 47401b00.usb-phy: GPIO lookup for consumer reset [ 27.543252] am335x-phy-driver 47401b00.usb-phy: using device tree for GPIO lookup [ 27.543272] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp/usb@47400000/usb-phy@47401b00[0]' [ 27.543281] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp/usb@47400000/usb-phy@47401b00[0]' [ 27.543287] am335x-phy-driver 47401b00.usb-phy: using lookup tables for GPIO lookup [ 27.543295] am335x-phy-driver 47401b00.usb-phy: lookup for GPIO reset failed [ 27.543304] am335x-phy-driver 47401b00.usb-phy: GPIO lookup for consumer vbus-detect [ 27.543309] am335x-phy-driver 47401b00.usb-phy: using device tree for GPIO lookup [ 27.543316] of_get_named_gpiod_flags: can't parse 'vbus-detect-gpios' property of node '/ocp/usb@47400000/usb-phy@47401b00[0]' [ 27.543323] of_get_named_gpiod_flags: can't parse 'vbus-detect-gpio' property of node '/ocp/usb@47400000/usb-phy@47401b00[0]' [ 27.543328] am335x-phy-driver 47401b00.usb-phy: using lookup tables for GPIO lookup [ 27.543334] am335x-phy-driver 47401b00.usb-phy: lookup for GPIO vbus-detect failed [ 27.543429] am335x-phy-driver 47401b00.usb-phy: 47401b00.usb-phy supply vcc not found, using dummy regulator [ 29.195390] TI-am335x-tsc 44e0d000.tscadc:tsc: ti,charge-delay not specified [ 29.290965] input: ti-tsc as /devices/platform/ocp/44e0d000.tscadc/44e0d000.tscadc:tsc/input/input1 [ 29.332401] musb-hdrc musb-hdrc.0: MUSB HDRC host driver [ 29.332443] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1 [ 29.369422] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002 [ 29.369432] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 29.369437] usb usb1: Product: MUSB HDRC host driver [ 29.369442] usb usb1: Manufacturer: Linux 4.14.79-ge669d52447 musb-hcd [ 29.369448] usb usb1: SerialNumber: musb-hdrc.0 [ 29.372556] hub 1-0:1.0: USB hub found [ 29.372608] hub 1-0:1.0: 1 port detected [ 29.383360] musb-hdrc musb-hdrc.1: MUSB HDRC host driver [ 29.383390] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2 [ 29.499558] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002 [ 29.499569] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 29.499574] usb usb2: Product: MUSB HDRC host driver [ 29.499579] usb usb2: Manufacturer: Linux 4.14.79-ge669d52447 musb-hcd [ 29.499584] usb usb2: SerialNumber: musb-hdrc.1 [ 29.500314] hub 2-0:1.0: USB hub found [ 29.500363] hub 2-0:1.0: 1 port detected [ 29.861057] pruss 4a300000.pruss: creating PRU cores and other child platform devices [ 30.128135] remoteproc remoteproc1: 4a334000.pru is available [ 30.128236] pru-rproc 4a334000.pru: PRU rproc node /ocp/pruss_soc_bus@4a326004/pruss@0/pru@34000 probed successfully [ 30.129851] remoteproc remoteproc2: 4a338000.pru is available [ 30.129912] pru-rproc 4a338000.pru: PRU rproc node /ocp/pruss_soc_bus@4a326004/pruss@0/pru@38000 probed successfully [ 31.326733] net eth1: initializing cpsw version 1.12 (0) [ 31.486250] Atheros 8031 ethernet 4a101000.mdio:01: attached PHY driver [Atheros 8031 ethernet] (mii_bus:phy_addr=4a101000.mdio:01, irq=POLL) [ 31.574769] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready [ 31.652526] net eth0: initializing cpsw version 1.12 (0) [ 31.796115] Atheros 8031 ethernet 4a101000.mdio:00: attached PHY driver [Atheros 8031 ethernet] (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL) [ 31.863976] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 33.926443] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx [ 33.959352] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready [ 36.335436] using random self ethernet address [ 36.380687] using random host ethernet address [ 36.413064] using host ethernet address: C4:ED:BA:8D:4C:7D [ 36.413147] using random self ethernet address [ 36.517841] using random host ethernet address [ 36.547314] using host ethernet address: C4:ED:BA:8D:4C:7D [ 36.567998] usb0: HOST MAC c4:ed:ba:8d:4c:7d [ 36.660214] usb0: MAC 82:7a:42:ba:1d:de [ 36.752769] Mass Storage Function, version: 2009/09/11 [ 36.781949] LUN: removable file: (no medium) [ 36.791383] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ] [ 36.881213] LUN: removable read only file: /dev/mmcblk0p1 [ 36.977040] Number of LUNs=1 [ 37.064586] g_multi gadget: Multifunction Composite Gadget [ 37.070126] g_multi gadget: g_multi ready [ 37.315241] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready [ 37.459908] g_multi gadget: high-speed config #1: Multifunction with RNDIS [ 37.467214] IPv6: ADDRCONF(NETDEV_CHANGE): usb0: link becomes ready [ 43.231465] hrtimer: interrupt took 176417 ns [ 158.033380] NET: Registered protocol family 15 [ 158.602405] Initializing XFRM netlink socket
SDK version: 05.03.00.07
