TDA2EVM5777: Nullsource multi channels decode error
Part Number: TDA2EVM5777
I make my customer usecase to decode and display video.It woks well if only one channel.
NullSource -> Decode -> Display_Video
But if I change Nullsource channels more than 1,the decode link error occurred. Here's the log
[IPU1-0]      6.525742 s:
[IPU1-0]      6.525834 s: input channels you need
[IPU1-0]      7.653602 s: #############################width 768,height 320
[IPU1-0]      7.653724 s: #############################width 768,height 320
[IPU1-0]      7.653785 s: #############################width 768,height 320
[IPU1-0]      7.653907 s: #############################width 768,height 320
[IPU1-0]      7.692429 s: ########## enter NullSrcLink_create, channel 4
[IPU1-0]      7.725157 s:  FILE: Reading file [inHeader_OD] ...
[IPU1-0]      7.729518 s:  FILE: File read Done. [12000 bytes]
[IPU1-0]      7.744006 s:  FILE: Reading file [inHeader_OD] ...
[IPU1-0]      7.748185 s:  FILE: File read Done. [12000 bytes]
[IPU1-0]      7.762612 s:  FILE: Reading file [inHeader_OD] ...
[IPU1-0]      7.766851 s:  FILE: File read Done. [12000 bytes]
[IPU1-0]      7.781309 s:  FILE: Reading file [inHeader_OD] ...
[IPU1-0]      7.785457 s:  FILE: File read Done. [12000 bytes]
[IPU1-0]      7.895839 s:  DECODE: Create in progress ... !!!
[IPU1-0]      8.144878 s:  DECODE: Creating CH0 of 768 x 320 [1] [0],target bitrate = 10000 Kbps ...
[IPU1-0]      8.391325 s:  DECODE: Creating CH1 of 768 x 320 [1] [0],target bitrate = 10000 Kbps ...
[IPU1-0]      8.638077 s:  DECODE: Creating CH2 of 768 x 320 [1] [0],target bitrate = 10000 Kbps ...
[IPU1-0]      8.884432 s:  DECODE: Creating CH3 of 768 x 320 [1] [0],target bitrate = 10000 Kbps ...
[IPU1-0]      8.885255 s:  DECODE: All CH Create ... DONE !!!
[IPU1-0]      8.887207 s:  DECODE: Create ... DONE !!!
[IPU1-0]      8.887573 s:  DISPLAY: Create in progress !!!
[IPU1-0]      8.888153 s:  DISPLAY: Create Done !!!
[IPU1-0]      8.888488 s:  GRPXSRC: Create in progress !!!
[IPU1-0]     10.561459 s:  GRPXSRC: Create Done !!!
[IPU1-0]     10.561855 s:  DISPLAY: Create in progress !!!
[IPU1-0]     10.562374 s:  DISPLAY: Create Done !!!
[IPU1-0]     10.562770 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1022
[IPU1-0]     10.562953 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 246336 B (240 KB)
[IPU1-0]     10.563106 s:  SYSTEM: Heap = SR_OCMC              @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
[IPU1-0]     10.563258 s:  SYSTEM: Heap = SR_DDR_CACHED        @ 0x85483000, Total size = 733990912 B (699 MB), Free size = 651388928 B (621 MB)
[IPU1-0]     10.563441 s:  SYSTEM: Heap = SR_DDR_NON_CACHED    @ 0xb8000000, Total size = 127872 B (0 MB), Free size = 106368 B (0 MB)
[IPU1-0]     10.569877 s:  DISPLAY: Start in progress !!!
[IPU1-0]     10.569968 s:  DISPLAY: Start Done !!!
[IPU1-0]     10.571402 s:  *** UTILS: CPU KHz = 20000 Khz ***
[IPU1-0]     10.581010 s: display format 0
[IPU1-0]     10.581284 s:  DISPLAY: Start in progress !!!
[IPU1-0]     10.581376 s:  DISPLAY: Start Done !!!
[IPU1-0]     10.583267 s:
[IPU1-0]
[IPU1-0]  ====================
[IPU1-0]  Chains Run-time Menu
[IPU1-0]
[IPU1-0]  0: Stop Chain
[IPU1-0]
[IPU1-0]  2: Pause Capture
[IPU1-0]  3: Resume Capture
[IPU1-0]  4: Demonstrate Task Timer utility
[IPU1-0]
[IPU1-0]  p: Print Performance Statistics
[IPU1-0]
[IPU1-0]  Enter Choice:
[IPU1-0]
[IPU1-1]     10.564173 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[IPU1-1]     10.564295 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 655360 B (640 KB), Free size = 645280 B (630 KB)
[HOST  ]      7.748002 s:  NETWORK_CTRL: Starting Server (port=5000) !!!
[HOST  ]      7.748032 s:  NETWORK_CTRL: Starting Server ... DONE (port=5000) !!!
[HOST  ]     10.564692 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[HOST  ]     10.564692 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 6291456 B (6144 KB), Free size = 6247792 B (6101 KB)
[DSP1  ]     10.564936 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[DSP1  ]     10.564966 s:  SYSTEM: Heap = LOCAL_L2             @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
[DSP1  ]     10.564997 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 524288 B (512 KB), Free size = 516416 B (504 KB)
[DSP2  ]     10.565271 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[DSP2  ]     10.565302 s:  SYSTEM: Heap = LOCAL_L2             @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
[DSP2  ]     10.565332 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 524288 B (512 KB), Free size = 516416 B (504 KB)
[EVE1  ]     10.565973 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[EVE1  ]     10.566217 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
[EVE1  ]     10.566674 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254248 B (248 KB)
[EVE2  ]     10.567833 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[EVE2  ]     10.568077 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
[EVE2  ]     10.568535 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254248 B (248 KB)
[IPU2  ]     10.569480 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[IPU2  ]     10.569602 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 252016 B (246 KB)
[IPU1-0]     11.592386 s: enter NullSrcLink_processData,channel 0,buf 1
[IPU1-0]     11.596687 s: enter NullSrcLink_processData,channel 1,buf 2
[IPU1-0]     11.601110 s: enter NullSrcLink_processData,channel 2,buf 3
[IPU1-0]     11.605837 s: enter NullSrcLink_processData,channel 3,buf 4
[IPU1-0]     11.609894 s: display format 7
[IPU1-0]     11.619136 s:  DECODE: ERROR: ALGPROCESS FAILED (status=0x00000a10) !!!
[IPU1-0]     11.619258 s:  DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 1 Error: 0xa10
[IPU1-0]     11.619349 s:  DEC_LINK: Sequence called number 1
[IPU1-0]     11.629140 s:  DECODE: ERROR: ALGPROCESS FAILED (status=0x00000a10) !!!
[IPU1-0]     11.629231 s:  DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 2 Error: 0xa10
[IPU1-0]     11.629353 s:  DEC_LINK: Sequence called number 1
[IPU1-0]     11.639053 s:  DECODE: ERROR: ALGPROCESS FAILED (status=0x00000a10) !!!
[IPU1-0]     11.639175 s:  DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 3 Error: 0xa10
[IPU1-0]     11.639266 s:  DEC_LINK: Sequence called number 1
[IPU1-0]     12.588116 s: enter NullSrcLink_processData,channel 0,buf 1
[IPU1-0]     12.592875 s: enter NullSrcLink_processData,channel 1,buf 2
[IPU1-0]     12.597206 s: enter NullSrcLink_processData,channel 2,buf 3
[IPU1-0]     12.601506 s: enter NullSrcLink_processData,channel 3,buf 4
[IPU1-0]     12.604251 s:  DECODE: ERROR: ALGPROCESS FAILED (status=0x00000401) !!!
[IPU1-0]     12.604373 s:  DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 3 Error: 0x401
[IPU1-0]     12.604495 s:  DEC_LINK: Sequence called number 2
[IPU1-0]     12.607088 s: display format 7
[IPU1-0]     12.609253 s:  DECODE: ERROR: ALGPROCESS FAILED (status=0x00000401) !!!
[IPU1-0]     12.609345 s:  DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 1 Error: 0x401
[IPU1-0]     12.609467 s:  DEC_LINK: Sequence called number 2
[IPU1-0]     12.612090 s:  DECODE: ERROR: ALGPROCESS FAILED (status=0x00000401) !!!
[IPU1-0]     12.612212 s:  DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 2 Error: 0x401
[IPU1-0]     12.612334 s:  DEC_LINK: Sequence called number 2
[IPU1-0]     13.587567 s: enter NullSrcLink_processData,channel 0,buf 1
[IPU1-0]     13.592722 s: enter NullSrcLink_processData,channel 1,buf 2
[IPU1-0]     13.597694 s: enter NullSrcLink_processData,channel 2,buf 3
[IPU1-0]     13.602635 s: enter NullSrcLink_processData,channel 3,buf 4
[IPU1-0]     13.606203 s:  DECODE: ERROR: ALGPROCESS FAILED (status=0x00000a10) !!!
[IPU1-0]     13.606295 s:  DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 2 Error: 0xa10
[IPU1-0]     13.606417 s:  DEC_LINK: Sequence called number 3
[IPU1-0]     13.609497 s:  DECODE: ERROR: ALGPROCESS FAILED (status=0x00000a10) !!!
[IPU1-0]     13.609619 s:  DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 3 Error: 0xa10
[IPU1-0]     13.609711 s:  DEC_LINK: Sequence called number 3
[IPU1-0]     13.616879 s: display format 7
[IPU1-0]     14.588208 s: enter NullSrcLink_processData,channel 0,buf 1
[IPU1-0]     14.593515 s: enter NullSrcLink_processData,channel 1,buf 2
[IPU1-0]     14.598517 s: enter NullSrcLink_processData,channel 2,buf 3
[IPU1-0]     14.604800 s: enter NullSrcLink_processData,channel 3,buf 4
[IPU1-0]     14.614805 s:  DECODE: ERROR: ALGPROCESS FAILED (status=0x00000a10) !!!
[IPU1-0]     14.614927 s:  DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 2 Error: 0xa10
[IPU1-0]     14.615079 s:  DEC_LINK: Sequence called number 4
[IPU1-0]     14.623833 s:  DECODE: ERROR: ALGPROCESS FAILED (status=0x00000a10) !!!
[IPU1-0]     14.623955 s:  DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0xa10
[IPU1-0]     14.624138 s:  DEC_LINK: Sequence called number 4
[IPU1-0]     15.587933 s: enter NullSrcLink_processData,channel 0,buf 1
[IPU1-0]     15.593302 s: enter NullSrcLink_processData,channel 1,buf 2
[IPU1-0]     15.598426 s: enter NullSrcLink_processData,channel 2,buf 3
[IPU1-0]     15.603550 s: enter NullSrcLink_processData,channel 3,buf 4
[IPU1-0]     15.610565 s:  DECODE: ERROR: ALGPROCESS FAILED (status=0x00000a10) !!!
[IPU1-0]     15.610656 s:  DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0xa10
[IPU1-0]     15.610778 s:  DEC_LINK: Sequence called number 5
[IPU1-0]     15.617123 s:  DECODE: ERROR: ALGPROCESS FAILED (status=0x00000a10) !!!
[IPU1-0]     15.617245 s:  DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 1 Error: 0xa10
[IPU1-0]     15.617367 s:  DEC_LINK: Sequence called number 5
[IPU1-0]     15.620600 s:  DECODE: ERROR: ALGPROCESS FAILED (status=0x00000a10) !!!
[IPU1-0]     15.620722 s:  DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 2 Error: 0xa10
[IPU1-0]     15.620813 s:  DEC_LINK: Sequence called number 5
[IPU1-0]     16.588421 s: enter NullSrcLink_processData,channel 0,buf 1
[IPU1-0]     16.593637 s: enter NullSrcLink_processData,channel 1,buf 2
[IPU1-0]     16.599188 s: enter NullSrcLink_processData,channel 2,buf 3
[IPU1-0]     16.604495 s: enter NullSrcLink_processData,channel 3,buf 4
[IPU1-0]     16.610199 s:  DECODE: ERROR: ALGPROCESS FAILED (status=0x00000a10) !!!
[IPU1-0]     16.610351 s:  DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 3 Error: 0xa10
[IPU1-0]     16.610473 s:  DEC_LINK: Sequence called number 6
[IPU1-0]     16.616787 s:  DECODE: ERROR: ALGPROCESS FAILED (status=0x00000a10) !!!
[IPU1-0]     16.616909 s:  DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0xa10
[IPU1-0]     16.617001 s:  DEC_LINK: Sequence called number 6
[IPU1-0]     16.623253 s:  DECODE: ERROR: ALGPROCESS FAILED (status=0x00000a10) !!!
[IPU1-0]     16.623375 s:  DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 1 Error: 0xa10
[IPU1-0]     16.623497 s:  DEC_LINK: Sequence called number 6
[IPU1-0]     16.626517 s:  DECODE: ERROR: ALGPROCESS FAILED (status=0x00000a10) !!!
[IPU1-0]     16.626639 s:  DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 2 Error: 0xa10
[IPU1-0]     16.626761 s:  DEC_LINK: Sequence called number 6
[IPU1-0]     17.588360 s: enter NullSrcLink_processData,channel 0,buf 1
[IPU1-0]     17.593607 s: enter NullSrcLink_processData,channel 1,buf 2
[IPU1-0]     17.598853 s: enter NullSrcLink_processData,channel 2,buf 3
[IPU1-0]     17.604282 s: enter NullSrcLink_processData,channel 3,buf 4
[IPU1-0]     17.611389 s:  DECODE: ERROR: ALGPROCESS FAILED (status=0x00000a10) !!!
[IPU1-0]     17.611511 s:  DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 3 Error: 0xa10
[IPU1-0]     17.611602 s:  DEC_LINK: Sequence called number 7
[IPU1-0]     17.617214 s:  DECODE: ERROR: ALGPROCESS FAILED (status=0x00000a10) !!!
[IPU1-0]     17.617336 s:  DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 0 Error: 0xa10
[IPU1-0]     17.617428 s:  DEC_LINK: Sequence called number 7
[IPU1-0]     17.623253 s:  DECODE: ERROR: ALGPROCESS FAILED (status=0x00000a10) !!!
[IPU1-0]     17.623375 s:  DEC_LINK: outArgs->viddec3OutArgs.extendedError for channel 1 Error: 0xa10
[IPU1-0]     17.623467 s:  DEC_LINK: Sequence called number 7
Could you help me to solve this problem?
