Other Parts Discussed in Thread: TRF7970A, AM3352, TPS65910
Dear TI Team,
On our custom board, we are supporting a 4G module over USB1 interface and also we have a wifi modulu that is connected to USB0 over a USB Hub.
In problematic case, once our device attempts to send/receive data over 4G module, after a period of time module losses its IP address interestingly. You can find our log prints in below. As far as we checked, IP is lost after a reset taken at timestamp "[Thu Nov 21 15:20:54 2019] [ 894.396000] usb 2-1: reset high-speed USB device number 2 using musb-hdrc [Thu Nov 21 15:20:54 2019] [ 894.555964] usb 2-1: device descriptor read/64, error -71". And also there is an error with the code -71. Could you pls. help to check this to be able to understand the issue root cause?
Device OS information
ID="arago"
NAME="Arago"
VERSION="2018.08"
VERSION_ID="2018.08"
PRETTY_NAME="Arago 2018.08"
Operating System: Arago 2018.08
Kernel: Linux 4.14.67-gd315a9bb00
Log Prints:
[Thu Nov 21 15:05:52 2019]
[Thu Nov 21 15:05:52 2019] U-Boot SPL 2018.01-gcdb1cc0a9e (Oct 16 2019 - 11:05:27)
[Thu Nov 21 15:05:52 2019] Trying to boot from MMC2
[Thu Nov 21 15:05:52 2019] ** Bad device mmc 0 **
[Thu Nov 21 15:05:52 2019] Using default environment
[Thu Nov 21 15:05:52 2019] U-Boot 2018.01-gcdb1cc0a9e (Oct 16 2019 - 11:05:27 +0000)
[Thu Nov 21 15:05:52 2019] CPU : AM335X-GP rev 2.1
[Thu Nov 21 15:05:52 2019] Model: TI AM335x EVM-SK
[Thu Nov 21 15:05:52 2019] DRAM: 256 MiB
[Thu Nov 21 15:05:53 2019] NAND: 0 MiB
[Thu Nov 21 15:05:53 2019] MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
[Thu Nov 21 15:05:53 2019] ** Bad device mmc 0 **
[Thu Nov 21 15:05:53 2019] Using default environment
[Thu Nov 21 15:05:53 2019] <ethaddr> not set. Validating first E-fuse MAC
[Thu Nov 21 15:05:53 2019] Net: cpsw, usb_ether
[Thu Nov 21 15:05:53 2019] Hit any key to stop autoboot: 2 1 0
[Thu Nov 21 15:05:55 2019] 423 bytes read in 11 ms (37.1 KiB/s)
[Thu Nov 21 15:05:55 2019] 3981824 bytes read in 342 ms (11.1 MiB/s)
[Thu Nov 21 15:05:55 2019] 38289 bytes read in 12 ms (3 MiB/s)
[Thu Nov 21 15:05:56 2019] 1798722 bytes read in 160 ms (10.7 MiB/s)
[Thu Nov 21 15:05:56 2019] ## Flattened Device Tree blob at 88000000
[Thu Nov 21 15:05:56 2019] Booting using the fdt blob at 0x88000000
[Thu Nov 21 15:05:56 2019] Loading Ramdisk to 8dd58000, end 8df0f242 ... OK
[Thu Nov 21 15:05:56 2019] Loading Device Tree to 8dd4b000, end 8dd57590 ... OK
[Thu Nov 21 15:05:56 2019] Starting kernel ...
[Thu Nov 21 15:06:00 2019] [ 0.000000] Booting Linux on physical CPU 0x0
[Thu Nov 21 15:06:00 2019] [ 0.000000] Linux version 4.14.67-gd315a9bb00 (oe-user@oe-host) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #1 PREEMPT Mon Nov 18 13:40:22 UTC 2019
[Thu Nov 21 15:06:00 2019] [ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[Thu Nov 21 15:06:00 2019] [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[Thu Nov 21 15:06:00 2019] [ 0.000000] OF: fdt: Machine model: TI AM335x EVM-SK
[Thu Nov 21 15:06:00 2019] [ 0.000000] Memory policy: Data cache writeback
[Thu Nov 21 15:06:00 2019] [ 0.000000] efi: Getting EFI parameters from FDT:
[Thu Nov 21 15:06:00 2019] [ 0.000000] efi: UEFI not found.
[Thu Nov 21 15:06:00 2019] [ 0.000000] cma: Reserved 48 MiB at 0x8a800000
[Thu Nov 21 15:06:00 2019] [ 0.000000] CPU: All CPU(s) started in SVC mode.
[Thu Nov 21 15:06:00 2019] [ 0.000000] AM335X ES2.1 (sgx neon)
[Thu Nov 21 15:06:00 2019] [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 64960
[Thu Nov 21 15:06:00 2019] [ 0.000000] Kernel command line: ostree=/ostree/boot.1/arago/201c3845a3c953f5e7d4bfdac781b769fb146aba6d268efe63de52dd29278ffc/0 console=ttyO0,115200n8 ostree_root=/dev/mmcblk1p2
[Thu Nov 21 15:06:00 2019] [ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[Thu Nov 21 15:06:00 2019] [ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[Thu Nov 21 15:06:00 2019] [ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[Thu Nov 21 15:06:00 2019] [ 0.000000] Memory: 195504K/262144K available (8192K kernel code, 320K rwdata, 2608K rodata, 1024K init, 278K bss, 17488K reserved, 49152K cma-reserved, 0K highmem)
[Thu Nov 21 15:06:00 2019] [ 0.000000] Virtual kernel memory layout:
[Thu Nov 21 15:06:00 2019] [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[Thu Nov 21 15:06:00 2019] [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[Thu Nov 21 15:06:00 2019] [ 0.000000] vmalloc : 0xd0800000 - 0xff800000 ( 752 MB)
[Thu Nov 21 15:06:00 2019] [ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[Thu Nov 21 15:06:00 2019] [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[Thu Nov 21 15:06:00 2019] [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[Thu Nov 21 15:06:00 2019] [ 0.000000] .text : 0xc0008000 - 0xc0900000 (9184 kB)
[Thu Nov 21 15:06:00 2019] [ 0.000000] .init : 0xc0c00000 - 0xc0d00000 (1024 kB)
[Thu Nov 21 15:06:00 2019] [ 0.000000] .data : 0xc0d00000 - 0xc0d50128 ( 321 kB)
[Thu Nov 21 15:06:00 2019] [ 0.000000] .bss : 0xc0d50128 - 0xc0d959c4 ( 279 kB)
[Thu Nov 21 15:06:00 2019] [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[Thu Nov 21 15:06:00 2019] [ 0.000000] Preemptible hierarchical RCU implementation.
[Thu Nov 21 15:06:00 2019] [ 0.000000] Tasks RCU enabled.
[Thu Nov 21 15:06:00 2019] [ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[Thu Nov 21 15:06:00 2019] [ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[Thu Nov 21 15:06:00 2019] [ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[Thu Nov 21 15:06:00 2019] [ 0.000017] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[Thu Nov 21 15:06:00 2019] [ 0.000044] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[Thu Nov 21 15:06:00 2019] [ 0.000058] OMAP clocksource: timer1 at 24000000 Hz
[Thu Nov 21 15:06:00 2019] [ 0.000282] timer_probe: no matching timers found
[Thu Nov 21 15:06:00 2019] [ 0.000544] Console: colour dummy device 80x30
[Thu Nov 21 15:06:00 2019] [ 0.000583] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[Thu Nov 21 15:06:00 2019] [ 0.000593] This ensures that you still see kernel messages. Please
[Thu Nov 21 15:06:00 2019] [ 0.000602] update your kernel commandline.
[Thu Nov 21 15:06:00 2019] [ 0.000642] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
[Thu Nov 21 15:06:00 2019] [ 0.118796] pid_max: default: 32768 minimum: 301
[Thu Nov 21 15:06:00 2019] [ 0.119047] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[Thu Nov 21 15:06:00 2019] [ 0.119067] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[Thu Nov 21 15:06:00 2019] [ 0.120106] CPU: Testing write buffer coherency: ok
[Thu Nov 21 15:06:00 2019] [ 0.121032] Setting up static identity map for 0x80100000 - 0x80100060
[Thu Nov 21 15:06:00 2019] [ 0.121236] Hierarchical SRCU implementation.
[Thu Nov 21 15:06:00 2019] [ 0.121700] EFI services will not be available.
[Thu Nov 21 15:06:00 2019] [ 0.123442] devtmpfs: initialized
[Thu Nov 21 15:06:00 2019] [ 0.134376] random: get_random_u32 called from bucket_table_alloc+0x8c/0x1ac with crng_init=0
[Thu Nov 21 15:06:00 2019] [ 0.134945] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[Thu Nov 21 15:06:00 2019] [ 0.135326] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[Thu Nov 21 15:06:00 2019] [ 0.135367] futex hash table entries: 256 (order: -1, 3072 bytes)
[Thu Nov 21 15:06:00 2019] [ 0.140073] pinctrl core: initialized pinctrl subsystem
[Thu Nov 21 15:06:00 2019] [ 0.140968] DMI not present or invalid.
[Thu Nov 21 15:06:00 2019] [ 0.141471] NET: Registered protocol family 16
[Thu Nov 21 15:06:00 2019] [ 0.144297] DMA: preallocated 256 KiB pool for atomic coherent allocations
[Thu Nov 21 15:06:00 2019] [ 0.162573] omap_hwmod: debugss: _wait_target_disable failed
[Thu Nov 21 15:06:00 2019] [ 0.217219] cpuidle: using governor ladder
[Thu Nov 21 15:06:00 2019] [ 0.217270] cpuidle: using governor menu
[Thu Nov 21 15:06:00 2019] [ 0.223115] OMAP GPIO hardware version 0.1
[Thu Nov 21 15:06:00 2019] [ 0.237946] No ATAGs?
[Thu Nov 21 15:06:00 2019] [ 0.237970] hw-breakpoint: debug architecture 0x4 unsupported.
[Thu Nov 21 15:06:00 2019] [ 0.255638] edma 49000000.edma: TI EDMA DMA engine driver
[Thu Nov 21 15:06:00 2019] [ 0.257098] reg-fixed-voltage fixedregulator2: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_wl12xx_gpio, deferring probe
[Thu Nov 21 15:06:00 2019] [ 0.261368] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[Thu Nov 21 15:06:00 2019] [ 0.261572] media: Linux media interface: v0.10
[Thu Nov 21 15:06:00 2019] [ 0.261636] Linux video capture interface: v2.00
[Thu Nov 21 15:06:00 2019] [ 0.261765] pps_core: LinuxPPS API ver. 1 registered
[Thu Nov 21 15:06:00 2019] [ 0.261776] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[Thu Nov 21 15:06:00 2019] [ 0.261808] PTP clock support registered
[Thu Nov 21 15:06:00 2019] [ 0.261854] EDAC MC: Ver: 3.0.0
[Thu Nov 21 15:06:00 2019] [ 0.262439] dmi: Firmware registration failed.
[Thu Nov 21 15:06:00 2019] [ 0.262993] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[Thu Nov 21 15:06:00 2019] [ 0.263443] Advanced Linux Sound Architecture Driver Initialized.
[Thu Nov 21 15:06:00 2019] [ 0.265153] nfc: nfc_init: NFC Core ver 0.1
[Thu Nov 21 15:06:00 2019] [ 0.265271] NET: Registered protocol family 39
[Thu Nov 21 15:06:00 2019] [ 0.265699] clocksource: Switched to clocksource timer1
[Thu Nov 21 15:06:00 2019] [ 0.276804] NET: Registered protocol family 2
[Thu Nov 21 15:06:00 2019] [ 0.277771] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[Thu Nov 21 15:06:00 2019] [ 0.277819] TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
[Thu Nov 21 15:06:00 2019] [ 0.277857] TCP: Hash tables configured (established 2048 bind 2048)
[Thu Nov 21 15:06:00 2019] [ 0.277978] UDP hash table entries: 256 (order: 0, 4096 bytes)
[Thu Nov 21 15:06:00 2019] [ 0.278005] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[Thu Nov 21 15:06:00 2019] [ 0.278202] NET: Registered protocol family 1
[Thu Nov 21 15:06:00 2019] [ 0.278763] RPC: Registered named UNIX socket transport module.
[Thu Nov 21 15:06:00 2019] [ 0.278783] RPC: Registered udp transport module.
[Thu Nov 21 15:06:00 2019] [ 0.278793] RPC: Registered tcp transport module.
[Thu Nov 21 15:06:00 2019] [ 0.278802] RPC: Registered tcp NFSv4.1 backchannel transport module.
[Thu Nov 21 15:06:00 2019] [ 0.279485] Trying to unpack rootfs image as initramfs...
[Thu Nov 21 15:06:00 2019] [ 0.464463] Freeing initrd memory: 1760K
[Thu Nov 21 15:06:00 2019] [ 0.465054] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[Thu Nov 21 15:06:00 2019] [ 0.465219] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[Thu Nov 21 15:06:00 2019] [ 0.467577] workingset: timestamp_bits=14 max_order=16 bucket_order=2
[Thu Nov 21 15:06:00 2019] [ 0.473269] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[Thu Nov 21 15:06:00 2019] [ 0.474274] NFS: Registering the id_resolver key type
[Thu Nov 21 15:06:00 2019] [ 0.474331] Key type id_resolver registered
[Thu Nov 21 15:06:00 2019] [ 0.474343] Key type id_legacy registered
[Thu Nov 21 15:06:00 2019] [ 0.474399] ntfs: driver 2.1.32 [Flags: R/O].
[Thu Nov 21 15:06:00 2019] [ 0.477327] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[Thu Nov 21 15:06:00 2019] [ 0.477358] io scheduler noop registered
[Thu Nov 21 15:06:00 2019] [ 0.477370] io scheduler deadline registered
[Thu Nov 21 15:06:00 2019] [ 0.477672] io scheduler cfq registered (default)
[Thu Nov 21 15:06:00 2019] [ 0.477686] io scheduler mq-deadline registered
[Thu Nov 21 15:06:00 2019] [ 0.477698] io scheduler kyber registered
[Thu Nov 21 15:06:00 2019] [ 0.479657] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[Thu Nov 21 15:06:00 2019] [ 0.548066] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[Thu Nov 21 15:06:00 2019] [ 0.552058] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 30, base_baud = 3000000) is a 8250
[Thu Nov 21 15:06:00 2019] [ 1.205798] console [ttyS0] enabled
[Thu Nov 21 15:06:00 2019] [ 1.210636] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 31, base_baud = 3000000) is a 8250
[Thu Nov 21 15:06:00 2019] [ 1.221193] omap_uart 48024000.serial: no wakeirq for uart2
[Thu Nov 21 15:06:00 2019] [ 1.227230] 48024000.serial: ttyO2 at MMIO 0x48024000 (irq = 32, base_baud = 3000000) is a OMAP UART2
[Thu Nov 21 15:06:00 2019] [ 1.237226] omap_uart 481a6000.serial: no wakeirq for uart3
[Thu Nov 21 15:06:00 2019] [ 1.243037] 481a6000.serial: ttyO3 at MMIO 0x481a6000 (irq = 33, base_baud = 3000000) is a OMAP UART3
[Thu Nov 21 15:06:00 2019] [ 1.253912] omap_rng 48310000.rng: Random Number Generator ver. 20
[Thu Nov 21 15:06:00 2019] [ 1.262636] panel panel: found backlight
[Thu Nov 21 15:06:00 2019] [ 1.267095] OF: graph: no port node found in /ocp/lcdc@4830e000
[Thu Nov 21 15:06:00 2019] [ 1.273335] OF: graph: no port node found in /ocp/lcdc@4830e000
[Thu Nov 21 15:06:00 2019] [ 1.279996] OF: graph: no port node found in /ocp/lcdc@4830e000
[Thu Nov 21 15:06:00 2019] [ 1.286015] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[Thu Nov 21 15:06:00 2019] [ 1.292661] [drm] No driver support for vblank timestamp query.
[Thu Nov 21 15:06:01 2019] [ 1.344270] Console: switching to colour frame buffer device 60x34
[Thu Nov 21 15:06:01 2019] [ 1.367142] tilcdc 4830e000.lcdc: fb0: frame buffer device
[Thu Nov 21 15:06:01 2019] [ 1.373432] [drm] Initialized tilcdc 1.0.0 20121205 for 4830e000.lcdc on minor 0
[Thu Nov 21 15:06:01 2019] [ 1.395490] brd: module loaded
[Thu Nov 21 15:06:01 2019] [ 1.407308] loop: module loaded
[Thu Nov 21 15:06:01 2019] [ 1.415443] trf7970a spi1.0: spi1.0 supply vdd-io not found, using dummy regulator
[Thu Nov 21 15:06:01 2019] [ 1.451992] libphy: Fixed MDIO Bus: probed
[Thu Nov 21 15:06:01 2019] [ 1.457779] qcaspi spi0.0: ver=0.2.7-i, clkspeed=10000000, burst_len=5000, pluggable=0
[Thu Nov 21 15:06:01 2019] [ 1.465892] qcaspi spi0.0: Using random MAC address: 42:79:ad:a4:6c:af
[Thu Nov 21 15:06:01 2019] [ 1.472595] qcaspi spi0.0: Invalid signature (0xFFFF)
[Thu Nov 21 15:06:01 2019] [ 1.477771] qcaspi: probe of spi0.0 failed with error -14
[Thu Nov 21 15:06:01 2019] [ 1.555737] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[Thu Nov 21 15:06:01 2019] [ 1.563464] davinci_mdio 4a101000.mdio: detected phy mask fffffffc
[Thu Nov 21 15:06:01 2019] [ 1.583772] libphy: 4a101000.mdio: probed
[Thu Nov 21 15:06:01 2019] [ 1.588046] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver Micrel KSZ8041RNLI
[Thu Nov 21 15:06:01 2019] [ 1.597340] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver Micrel KSZ8041RNLI
[Thu Nov 21 15:06:01 2019] [ 1.607692] cpsw 4a100000.ethernet: Detected MACID = 18:62:e4:e7:4a:80
[Thu Nov 21 15:06:01 2019] [ 1.614459] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[Thu Nov 21 15:06:01 2019] [ 1.620996] cpsw 4a100000.ethernet: ALE Table size 1024
[Thu Nov 21 15:06:01 2019] [ 1.626353] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies)
[Thu Nov 21 15:06:01 2019] [ 1.635365] i2c /dev entries driver
[Thu Nov 21 15:06:01 2019] [ 1.639569] IR NEC protocol handler initialized
[Thu Nov 21 15:06:01 2019] [ 1.644163] IR RC5(x/sz) protocol handler initialized
[Thu Nov 21 15:06:01 2019] [ 1.649287] IR RC6 protocol handler initialized
[Thu Nov 21 15:06:01 2019] [ 1.653838] IR JVC protocol handler initialized
[Thu Nov 21 15:06:01 2019] [ 1.658417] IR Sony protocol handler initialized
[Thu Nov 21 15:06:01 2019] [ 1.663056] IR SANYO protocol handler initialized
[Thu Nov 21 15:06:01 2019] [ 1.667799] IR Sharp protocol handler initialized
[Thu Nov 21 15:06:01 2019] [ 1.672524] IR MCE Keyboard/mouse protocol handler initialized
[Thu Nov 21 15:06:01 2019] [ 1.678536] IR XMP protocol handler initialized
[Thu Nov 21 15:06:01 2019] [ 1.685191] cpuidle: enable-method property 'ti,am3352' found operations
[Thu Nov 21 15:06:01 2019] [ 1.692530] sdhci: Secure Digital Host Controller Interface driver
[Thu Nov 21 15:06:01 2019] [ 1.698793] sdhci: Copyright(c) Pierre Ossman
[Thu Nov 21 15:06:01 2019] [ 1.706029] sdhci-pltfm: SDHCI platform and OF driver helper
[Thu Nov 21 15:06:01 2019] [ 1.712724] ledtrig-cpu: registered to indicate activity on CPUs
[Thu Nov 21 15:06:01 2019] [ 1.723136] NET: Registered protocol family 10
[Thu Nov 21 15:06:01 2019] [ 1.729525] Segment Routing with IPv6
[Thu Nov 21 15:06:01 2019] [ 1.733316] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[Thu Nov 21 15:06:01 2019] [ 1.740328] NET: Registered protocol family 17
[Thu Nov 21 15:06:01 2019] [ 1.745182] Key type dns_resolver registered
[Thu Nov 21 15:06:01 2019] [ 1.749857] omap_voltage_late_init: Voltage driver support not added
[Thu Nov 21 15:06:01 2019] [ 1.785993] tps65910 0-002d: No interrupt support, no core IRQ
[Thu Nov 21 15:06:01 2019] [ 1.794326] vrtc: supplied by vbat
[Thu Nov 21 15:06:01 2019] [ 1.801715] vio: supplied by vbat
[Thu Nov 21 15:06:01 2019] [ 1.806455] random: fast init done
[Thu Nov 21 15:06:01 2019] [ 1.810158] vdd1: supplied by vbat
[Thu Nov 21 15:06:01 2019] [ 1.815546] vdd2: supplied by vbat
[Thu Nov 21 15:06:01 2019] [ 1.822630] vdig1: supplied by vbat
[Thu Nov 21 15:06:01 2019] [ 1.827720] vdig2: supplied by vbat
[Thu Nov 21 15:06:01 2019] [ 1.832753] vpll: supplied by vbat
[Thu Nov 21 15:06:01 2019] [ 1.837744] vdac: supplied by vbat
[Thu Nov 21 15:06:01 2019] [ 1.842705] vaux1: supplied by vbat
[Thu Nov 21 15:06:01 2019] [ 1.847742] vaux2: supplied by vbat
[Thu Nov 21 15:06:01 2019] [ 1.852771] vaux33: supplied by vbat
[Thu Nov 21 15:06:01 2019] [ 1.857921] vmmc: supplied by vbat
[Thu Nov 21 15:06:01 2019] [ 1.862882] vbb: supplied by vbat
[Thu Nov 21 15:06:01 2019] [ 1.867965] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[Thu Nov 21 15:06:01 2019] [ 1.997183] hctosys: unable to open rtc device (rtc0)
[Thu Nov 21 15:06:01 2019] [ 2.003253] lis3_reg: disabling
[Thu Nov 21 15:06:01 2019] [ 2.008204] vwl1271: disabling
[Thu Nov 21 15:06:01 2019] [ 2.013530] ALSA device list:
[Thu Nov 21 15:06:01 2019] [ 2.016722] No soundcards found.
[Thu Nov 21 15:06:01 2019] [ 2.022632] Freeing unused kernel memory: 1024K
[Thu Nov 21 15:06:01 2019] /init[1]: Starting OSTree initrd script
[Thu Nov 21 15:06:01 2019] /init[1]: mounting FS: proc /proc
[Thu Nov 21 15:06:01 2019] /init[1]: mounting FS: sysfs /sys
[Thu Nov 21 15:06:01 2019] /init[1]: mounting FS: devtmpfs /dev
[Thu Nov 21 15:06:01 2019] [ 2.081370] mmc1: new high speed MMC card at address 0001
[Thu Nov 21 15:06:01 2019] [ 2.096032] mmcblk1: mmc1:0001 4FTE4R 3.64 GiB
[Thu Nov 21 15:06:01 2019] /init[1]: mounting FS: devpts /dev/pts[ 2.103325] mmcblk1boot0: mmc1:0001 4FTE4R partition 1 4.00 MiB
[Thu Nov 21 15:06:01 2019] [ 2.124100] mmcblk1boot1: mmc1:0001 4FTE4R partition 2 4.00 MiB
[Thu Nov 21 15:06:01 2019] /init[1]: mounting FS: tmpfs /dev/shm[ 2.143009] mmcblk1rpmb: mmc1:0001 4FTE4R partition 3 512 KiB
[Thu Nov 21 15:06:01 2019] [ 2.164524] mmcblk1: p1 p2 p3
[Thu Nov 21 15:06:01 2019] /init[1]: mounting FS: tmpfs /run
[Thu Nov 21 15:06:02 2019] [ 2.567385] EXT4-fs (mmcblk1p2): 7 orphan inodes deleted
[Thu Nov 21 15:06:02 2019] [ 2.572755] EXT4-fs (mmcblk1p2): recovery complete
[Thu Nov 21 15:06:02 2019] [ 2.585343] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[Thu Nov 21 15:06:02 2019] Resolved OSTree target to: /sysroot/ostree/deploy/arago/deploy/513d0229d6136905a3a09c07c869df89d8c74fb42ed3871d811d7b633a01b716.0
[Thu Nov 21 15:06:02 2019] /init[1]: Switching to rootfs
[Thu Nov 21 15:06:02 2019] System time before build time, advancing clock.
[Thu Nov 21 15:06:02 2019] [ 2.874624] systemd[1]: systemd 234 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN default-hierarchy=hybrid)
[Thu Nov 21 15:06:02 2019] [ 2.896907] systemd[1]: Detected architecture arm.
[Thu Nov 21 15:06:02 2019] Welcome to Arago 2018.08!
[Thu Nov 21 15:06:02 2019] [ 2.927834] systemd[1]: Set hostname to <am335x-evmsk>.
[Thu Nov 21 15:06:02 2019] [ 2.935823] NOHZ: local_softirq_pending 40
[Thu Nov 21 15:06:03 2019] [ 3.355780] NOHZ: local_softirq_pending 202
[Thu Nov 21 15:06:03 2019] [ 3.360038] NOHZ: local_softirq_pending 202
[Thu Nov 21 15:06:03 2019] [ 3.426813] systemd[1]: /lib/systemd/system/gadget-init.service:15: Unknown lvalue 'ExecStopPre' in section 'Service'
[Thu Nov 21 15:06:03 2019] [ 3.520864] systemd[1]: Configuration file /etc/systemd/system/uid-reader.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[Thu Nov 21 15:06:03 2019] [ 3.535959] systemd[1]: Configuration file /etc/systemd/system/uid-reader.service is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway.
[Thu Nov 21 15:06:03 2019] [ 3.557277] systemd[1]: Configuration file /etc/systemd/system/ui.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[Thu Nov 21 15:06:03 2019] [ 3.571594] systemd[1]: Configuration file /etc/systemd/system/ui.service is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway.
[Thu Nov 21 15:06:03 2019] [ 3.638726] systemd[1]: Configuration file /etc/systemd/system/ocpp.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[Thu Nov 21 15:06:03 2019] [ 3.653230] systemd[1]: Configuration file /etc/systemd/system/ocpp.service is marked world-inaccessible. This has no effect as configuration data is accessible via APIs without restrictions. Proceeding anyway.
[Thu Nov 21 15:06:03 2019] [ 3.789871] random: systemd: uninitialized urandom read (16 bytes read)
[Thu Nov 21 15:06:03 2019] [ OK ] Listening on Process Core Dump Socket.
[Thu Nov 21 15:06:03 2019] [ 3.837214] random: systemd: uninitialized urandom read (16 bytes read)
[Thu Nov 21 15:06:03 2019] [ OK ] Listening on udev Control Socket.
[Thu Nov 21 15:06:03 2019] [ 3.866122] random: systemd: uninitialized urandom read (16 bytes read)
[Thu Nov 21 15:06:03 2019] [ OK ] Listening on Syslog Socket.
[Thu Nov 21 15:06:03 2019] [ OK ] Created slice User and Session Slice.
[Thu Nov 21 15:06:03 2019] [ OK ] Listening on Journal Socket.
[Thu Nov 21 15:06:03 2019] [ OK ] Started Forward Password Requests to Wall Directory Watch.
[Thu Nov 21 15:06:03 2019] [ OK ] Started Dispatch Password Requests to Console Directory Watch.
[Thu Nov 21 15:06:03 2019] [ OK ] Reached target Remote File Systems.
[Thu Nov 21 15:06:03 2019] [ OK ] Listening on Journal Socket (/dev/log).
[Thu Nov 21 15:06:03 2019] [ OK ] Reached target Swap.
[Thu Nov 21 15:06:03 2019] [ OK ] Listening on Network Service Netlink Socket.
[Thu Nov 21 15:06:03 2019] [ OK ] Reached target Paths.
[Thu Nov 21 15:06:03 2019] [ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[Thu Nov 21 15:06:03 2019] [ OK ] Listening on udev Kernel Socket.
[Thu Nov 21 15:06:03 2019] [ OK ] Created slice System Slice.
[Thu Nov 21 15:06:03 2019] Mounting POSIX Message Queue File System...
[Thu Nov 21 15:06:03 2019] [ OK ] Reached target Slices.
[Thu Nov 21 15:06:04 2019] [ OK ] Created slice system-serial\x2dgetty.slice.
[Thu Nov 21 15:06:04 2019] Mounting Kernel Debug File System...
[Thu Nov 21 15:06:04 2019] Starting Load Kernel Modules...
[Thu Nov 21 15:06:04 2019] [ OK ] Created slice system-getty.slice.
[Thu Nov 21 15:06:04 2019] Starting Remount Root and Kernel File Systems...
[Thu Nov 21 15:06:04 2019] [ 4.483941] cryptodev: loading out-of-tree module taints kernel.
[Thu Nov 21 15:06:04 2019] [ 4.515026] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null)
[Thu Nov 21 15:06:04 2019] Starting Journal Service...
[Thu Nov 21 15:06:04 2019] [ 4.577128] cryptodev: driver 1.9 loaded.
[Thu Nov 21 15:06:04 2019] [ OK ] Mounted Kernel Debug File System.
[Thu Nov 21 15:06:04 2019] [ OK ] Mounted POSIX Message Queue File System.
[Thu Nov 21 15:06:04 2019] [ OK ] Started Load Kernel Modules.
[Thu Nov 21 15:06:04 2019] [ OK ] Started Remount Root and Kernel File Systems.
[Thu Nov 21 15:06:04 2019] Starting udev Coldplug all Devices...
[Thu Nov 21 15:06:04 2019] Starting OSTree Remount OS/ Bind Mounts...
[Thu Nov 21 15:06:04 2019] Starting Create Static Device Nodes in /dev...
[Thu Nov 21 15:06:04 2019] Starting Apply Kernel Variables...
[Thu Nov 21 15:06:04 2019] Mounting Kernel Configuration File System...
[Thu Nov 21 15:06:04 2019] [ OK ] Started Journal Service.
[Thu Nov 21 15:06:04 2019] [ OK ] Started OSTree Remount OS/ Bind Mounts.
[Thu Nov 21 15:06:04 2019] [ OK ] Started Create Static Device Nodes in /dev.
[Thu Nov 21 15:06:04 2019] [ OK ] Started Apply Kernel Variables.
[Thu Nov 21 15:06:04 2019] [ OK ] Mounted Kernel Configuration File System.
[Thu Nov 21 15:06:04 2019] Starting udev Kernel Device Manager...
[Thu Nov 21 15:06:04 2019] [ OK ] Reached target Local File Systems (Pre).
[Thu Nov 21 15:06:04 2019] Mounting /var...
[Thu Nov 21 15:06:04 2019] [ OK ] Mounted /var.
[Thu Nov 21 15:06:04 2019] [ OK ] Started udev Kernel Device Manager.
[Thu Nov 21 15:06:05 2019] Mounting /var/rootdirs/media/ram...
[Thu Nov 21 15:06:05 2019] Starting Flush Journal to Persistent Storage...
[Thu Nov 21 15:06:05 2019] Mounting /var/volatile...
[Thu Nov 21 15:06:05 2019] [ OK ] Mounted /var/rootdirs/media/ram.
[Thu Nov 21 15:06:05 2019] [ OK ] Mounted /var/volatile.
[Thu Nov 21 15:06:05 2019] [ 5.777769] systemd-journald[107]: Received request to flush runtime journal from PID 1
[Thu Nov 21 15:06:05 2019] Starting Load/Save Random Seed...
[Thu Nov 21 15:06:05 2019] [ OK ] Reached target Local File Systems.
[Thu Nov 21 15:06:05 2019] [ OK ] Started Flush Journal to Persistent Storage.
[Thu Nov 21 15:06:05 2019] Starting Create Volatile Files and Directories...
[Thu Nov 21 15:06:05 2019] [ OK ] Started Load/Save Random Seed.
[Thu Nov 21 15:06:05 2019] [ OK ] Started Create Volatile Files and Directories.
[Thu Nov 21 15:06:05 2019] Starting Update UTMP about System Boot/Shutdown...
[Thu Nov 21 15:06:06 2019] [ OK ] Started Update UTMP about System Boot/Shutdown.
[Thu Nov 21 15:06:06 2019] [ OK ] Created slice system-systemd\x2dbacklight.slice.
[Thu Nov 21 15:06:07 2019] Starting Load/Save Screen Backlight…ightness of backlight:backlight...
[Thu Nov 21 15:06:07 2019] [ 7.388261] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[Thu Nov 21 15:06:07 2019] [ 7.485659] omap_rtc 44e3e000.rtc: registered as rtc0
[Thu Nov 21 15:06:07 2019] [ OK ] Found device /dev/ttyS0.
[Thu Nov 21 15:06:07 2019] [ OK ] Started udev Coldplug all Devices.
[Thu Nov 21 15:06:07 2019] [ OK ] Started Load/Save Screen Backlight Brightness of backlight:backlight.
[Thu Nov 21 15:06:07 2019] [ OK ] Reached target System Initialization.
[Thu Nov 21 15:06:07 2019] [ OK ] Listening on dropbear.socket.
[Thu Nov 21 15:06:07 2019] Starting Network Service...
[Thu Nov 21 15:06:07 2019] [ OK ] Started Daily Cleanup of Temporary Directories.
[Thu Nov 21 15:06:07 2019] [ OK ] Reached target Timers.
[Thu Nov 21 15:06:07 2019] [ OK ] Listening on RPCbind Server Activation Socket.
[Thu Nov 21 15:06:07 2019] [ OK ] Listening on D-Bus System Message Bus Socket.
[Thu Nov 21 15:06:07 2019] [ OK ] Reached target Sockets.
[Thu Nov 21 15:06:07 2019] [ OK ] Reached target Basic System.
[Thu Nov 21 15:06:07 2019] Starting Login Service...
[Thu Nov 21 15:06:07 2019] Starting Print notice about GPLv3 packages...
[Thu Nov 21 15:06:07 2019] [ OK ] Reached target Containers.
[Thu Nov 21 15:06:08 2019] Starting neard...
[Thu Nov 21 15:06:08 2019] [ OK ] Started D-Bus System Message Bus.
[Thu Nov 21 15:06:08 2019] [ 8.633716] omap_hwmod: pruss: _wait_target_ready failed: -16
[Thu Nov 21 15:06:08 2019] grep: /var/lib/opkg/info/*.control: No such file or directory
[Thu Nov 21 15:06:08 2019] [ 8.831456] pruss-soc-bus 4a326004.pruss-soc-bus: use pm_runtime_put_sync_suspend() in driver?
[Thu Nov 21 15:06:08 2019] [ 8.926048] pruss-soc-bus 4a326004.pruss-soc-bus: couldn't enable module
[Thu Nov 21 15:06:08 2019] [ 8.932883] pruss-soc-bus: probe of 4a326004.pruss-soc-bus failed with error -16
[Thu Nov 21 15:06:08 2019] [ 9.037445] remoteproc remoteproc0: wkup_m3 is available
[Thu Nov 21 15:06:08 2019] [ 9.096038] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[Thu Nov 21 15:06:08 2019] [ 9.224357] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[Thu Nov 21 15:06:08 2019] [ 9.254705] omap-aes 53500000.aes: will run requests pump with realtime priority
[Thu Nov 21 15:06:09 2019] [ 9.364709] remoteproc remoteproc0: powering up wkup_m3
[Thu Nov 21 15:06:09 2019] [ 9.371862] PM: Cannot get wkup_m3_ipc handle
[Thu Nov 21 15:06:09 2019] [ 9.374500] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 224672
[Thu Nov 21 15:06:09 2019] [ 9.374771] remoteproc remoteproc0: remote processor wkup_m3 is now up
[Thu Nov 21 15:06:09 2019] [ 9.374800] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[Thu Nov 21 15:06:09 2019] [ OK ] Started System Logging Service.
[Thu Nov 21 15:06:09 2019] Starting uim-sysfs.service...
[Thu Nov 21 15:06:09 2019] [ 9.963583] PM: bootloader does not support rtc-only!
[Thu Nov 21 15:06:09 2019] [ 9.994729] [drm] Initialized pvr 1.14.3699939 20110701 for 56000000.sgx on minor 1
[Thu Nov 21 15:06:09 2019] Starting RPC Bind Service...
[Thu Nov 21 15:06:09 2019] [ 10.102763] net eth0: initializing cpsw version 1.12 (0)
[Thu Nov 21 15:06:09 2019] [ OK ] Started Kernel Logging Service.
[Thu Nov 21 15:06:09 2019] [ 10.236391] Micrel KSZ8041RNLI 4a101000.mdio:00: attached PHY driver [Micrel KSZ8041RNLI] (mii_bus:phy_addr=4a101000.mdio:00, irq=POLL)
[Thu Nov 21 15:06:10 2019] [ OK ] Started Network Service.
[Thu Nov 21 15:06:10 2019] [ 10.513405] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[Thu Nov 21 15:06:10 2019] [ OK ] Started Print notice about GPLv3 packages.
[Thu Nov 21 15:06:10 2019] [ OK ] Started neard.
[Thu Nov 21 15:06:10 2019] [ OK ] Started RPC Bind Service.
[Thu Nov 21 15:06:11 2019] [ 11.978824] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[Thu Nov 21 15:06:12 2019] [ 12.487161] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[Thu Nov 21 15:06:12 2019] [ 12.565618] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[Thu Nov 21 15:06:14 2019] [ OK ] Started Login Service.
[Thu Nov 21 15:06:14 2019] [ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[Thu Nov 21 15:06:14 2019] Starting neard-setup...
[Thu Nov 21 15:06:14 2019] [ OK ] Reached target Network.
[Thu Nov 21 15:06:14 2019] Starting Lightning Fast Webserver With Light System Requirements...
[Thu Nov 21 15:06:14 2019] Starting Permit User Sessions...
[Thu Nov 21 15:06:14 2019] Starting Network Name Resolution...
[Thu Nov 21 15:06:14 2019] [ OK ] Started Lightning Fast Webserver With Light System Requirements.
[Thu Nov 21 15:06:15 2019] [ OK ] Started Permit User Sessions.
[Thu Nov 21 15:06:15 2019] Starting Load/Save RF Kill Switch Status...
[Thu Nov 21 15:06:15 2019] [ OK ] Started Serial Getty on ttyS0.
[Thu Nov 21 15:06:15 2019] [ OK ] Started Getty on tty1.
[Thu Nov 21 15:06:15 2019] [ OK ] Started Load/Save RF Kill Switch Status.
[Thu Nov 21 15:06:15 2019] [ OK ] Started Network Name Resolution.
[Thu Nov 21 15:06:17 2019] [ 17.818146] TI-am335x-tsc 44e0d000.tscadc:tsc: ti,charge-delay not specified
[Thu Nov 21 15:06:17 2019] [ 17.825567] input: ti-tsc as /devices/platform/ocp/44e0d000.tscadc/44e0d000.tscadc:tsc/input/input0
[Thu Nov 21 15:06:17 2019] [ 18.006671] am335x-phy-driver 47401300.usb-phy: 47401300.usb-phy supply vcc not found, using dummy regulator
[Thu Nov 21 15:06:17 2019] [ 18.007833] am335x-phy-driver 47401b00.usb-phy: 47401b00.usb-phy supply vcc not found, using dummy regulator
[Thu Nov 21 15:06:17 2019] [ 18.066748] usbcore: registered new interface driver usbfs
[Thu Nov 21 15:06:17 2019] [ 18.066809] usbcore: registered new interface driver hub
[Thu Nov 21 15:06:18 2019] [ 18.066953] usbcore: registered new device driver usb
[Thu Nov 21 15:06:18 2019] [ 18.195463] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[Thu Nov 21 15:06:18 2019] [ 18.195514] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
[Thu Nov 21 15:06:18 2019] [ 18.236391] hub 1-0:1.0: USB hub found
[Thu Nov 21 15:06:18 2019] [ 18.236470] hub 1-0:1.0: 1 port detected
[Thu Nov 21 15:06:18 2019] [ 18.245508] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[Thu Nov 21 15:06:18 2019] [ 18.245543] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
[Thu Nov 21 15:06:18 2019] [ 18.386656] hub 2-0:1.0: USB hub found
[Thu Nov 21 15:06:18 2019] [ 18.386716] hub 2-0:1.0: 1 port detected
[Thu Nov 21 15:06:18 2019] [ 18.735892] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[Thu Nov 21 15:06:18 2019] [ 18.826325] usb 2-1: new high-speed USB device number 2 using musb-hdrc
[Thu Nov 21 15:06:18 2019] [ 18.918592] hub 1-1:1.0: USB hub found
[Thu Nov 21 15:06:18 2019] [ 18.918952] hub 1-1:1.0: 4 ports detected
[Thu Nov 21 15:06:18 2019] [ 19.245913] usb 1-1.2: new high-speed USB device number 3 using musb-hdrc
[Thu Nov 21 15:06:18 2019] [ 19.306583] usbcore: registered new interface driver cdc_wdm
[Thu Nov 21 15:06:18 2019] [ 19.316256] usbcore: registered new interface driver usbserial
[Thu Nov 21 15:06:19 2019] [ 19.390759] usbcore: registered new interface driver option
[Thu Nov 21 15:06:19 2019] [ 19.429358] qmi_wwan 2-1:1.4: cdc-wdm0: USB WDM device
[Thu Nov 21 15:06:19 2019] [ 19.438686] usbserial: USB Serial support registered for GSM modem (1-port)
[Thu Nov 21 15:06:19 2019] [ 19.486596] qmi_wwan 2-1:1.4: Quectel EC25&EC21&EG91&EG95&EG06&EP06&EM06&BG96&AG35 work on RawIP mode
[Thu Nov 21 15:06:19 2019] [ 19.516781] qmi_wwan 2-1:1.4 wwan0: register 'qmi_wwan' at usb-musb-hdrc.1-1, WWAN/QMI device, 2e:4c:2a:b2:8e:0a
[Thu Nov 21 15:06:19 2019] [ 19.517072] usbcore: registered new interface driver qmi_wwan
[Thu Nov 21 15:06:19 2019] [ 19.648258] Bluetooth: Core ver 2.22
[Thu Nov 21 15:06:19 2019] [ 19.650570] NET: Registered protocol family 31
[Thu Nov 21 15:06:19 2019] [ 19.650581] Bluetooth: HCI device and connection manager initialized
[Thu Nov 21 15:06:19 2019] [ 19.650610] Bluetooth: HCI socket layer initialized
[Thu Nov 21 15:06:19 2019] [ 19.650623] Bluetooth: L2CAP socket layer initialized
[Thu Nov 21 15:06:19 2019] [ 19.650671] Bluetooth: SCO socket layer initialized
[Thu Nov 21 15:06:19 2019] [ 19.664880] Bluetooth: MTK BT Driver Version : 6.2.19062601
[Thu Nov 21 15:06:19 2019] [ 19.685302] Bluetooth: btusb_init: BT_majorfwlog 243, devIDfwlog 254803968
[Thu Nov 21 15:06:19 2019] [ 19.687420] Bluetooth: ChipID: 0x00000000
[Thu Nov 21 15:06:19 2019] [ 19.687614] Bluetooth: 7668 detected
[Thu Nov 21 15:06:19 2019] [ 19.689739] Bluetooth: 7668 Firmware Version = 8B01
[Thu Nov 21 15:06:19 2019] [ 19.697980] Bluetooth: MTK Bluetooth firmware file: mt7668_patch_e2_hdr.bin
[Thu Nov 21 15:06:19 2019] [ 19.697989] Bluetooth: btmtk_usb_load_rom_patch_7668: begin
[Thu Nov 21 15:06:19 2019] [ 19.841508] Bluetooth: btmtk_usb_load_rom_patch_7668: FW Version = 20190830161323f
[Thu Nov 21 15:06:19 2019] [ 19.841518] Bluetooth: btmtk_usb_load_rom_patch_7668: build Time = 20190830161323f
[Thu Nov 21 15:06:19 2019] [ 19.841522] Bluetooth: btmtk_usb_load_rom_patch_7668: platform = mp2_
[Thu Nov 21 15:06:19 2019] [ 19.841526] Bluetooth: btmtk_usb_load_rom_patch_7668: HW/SW version = 1802
[Thu Nov 21 15:06:20 2019] [ 19.841529] Bluetooth: loading rom patch...
[Thu Nov 21 15:06:20 2019] [ 19.841533] Bluetooth: btmtk_usb_load_rom_patch_7668: loading ILM rom patch...
[Thu Nov 21 15:06:20 2019] [ 19.841572] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: patch_len = 196608
[Thu Nov 21 15:06:20 2019] [ 19.841587] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 0, phase = 1
[Thu Nov 21 15:06:20 2019] [ 19.843745] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:20 2019] [ 19.844763] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 2039, phase = 2
[Thu Nov 21 15:06:20 2019] [ 19.857398] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:20 2019] [ 19.858428] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 4078, phase = 2
[Thu Nov 21 15:06:20 2019] [ 19.863227] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:20 2019] [ 19.864249] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 6117, phase = 2
[Thu Nov 21 15:06:20 2019] [ 19.880825] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:20 2019] [ 19.881854] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 8156, phase = 2
[Thu Nov 21 15:06:20 2019] [ 19.891692] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:20 2019] [ 19.892754] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 10195, phase = 2
[Thu Nov 21 15:06:20 2019] [ 19.915930] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:20 2019] [ 19.916963] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 12234, phase = 2
[Thu Nov 21 15:06:20 2019] [ 19.931775] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:20 2019] [ 19.932796] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 14273, phase = 2
[Thu Nov 21 15:06:20 2019] [ 19.945963] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:20 2019] [ 19.946992] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 16312, phase = 2
[Thu Nov 21 15:06:20 2019] [ 19.955319] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:21 2019] [ 19.956668] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 18351, phase = 2
[Thu Nov 21 15:06:21 2019] [ 19.971495] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:21 2019] [ 19.972518] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 20390, phase = 2
[Thu Nov 21 15:06:21 2019] [ 19.995892] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:21 2019] [ 19.996916] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 22429, phase = 2
[Thu Nov 21 15:06:21 2019] [ 20.003523] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:21 2019] [ 20.004546] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 24468, phase = 2
[Thu Nov 21 15:06:21 2019] [ 20.009248] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:21 2019] [ 20.010271] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 26507, phase = 2
[Thu Nov 21 15:06:21 2019] [ 20.025989] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:21 2019] [ 20.027016] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 28546, phase = 2
[Thu Nov 21 15:06:21 2019] [ 20.040817] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:21 2019] [ 20.041836] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 30585, phase = 2
[Thu Nov 21 15:06:21 2019] [ 20.064784] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:21 2019] [ 20.072449] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 32624, phase = 2
[Thu Nov 21 15:06:21 2019] [ 20.091065] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:21 2019] [ 20.092085] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 34663, phase = 2
[Thu Nov 21 15:06:21 2019] [ 20.100175] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:21 2019] [ 20.101202] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 36702, phase = 2
[Thu Nov 21 15:06:21 2019] [ 20.114046] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:21 2019] [ 20.115073] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 38741, phase = 2
[Thu Nov 21 15:06:22 2019] [ 20.125911] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:22 2019] [ 20.126942] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 40780, phase = 2
[Thu Nov 21 15:06:22 2019] [ 20.129622] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:22 2019] [ 20.130643] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 42819, phase = 2
[Thu Nov 21 15:06:22 2019] [ 20.151737] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:22 2019] [ 20.152768] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 44858, phase = 2
[Thu Nov 21 15:06:22 2019] [ 20.154903] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:22 2019] [ 20.156042] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 46897, phase = 2
[Thu Nov 21 15:06:22 2019] [ 20.165106] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:22 2019] [ 20.172242] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 48936, phase = 2
[Thu Nov 21 15:06:22 2019] [ 20.177159] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:22 2019] [ 20.178183] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 50975, phase = 2
[Thu Nov 21 15:06:22 2019] [ 20.190075] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:22 2019] [ 20.191103] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 53014, phase = 2
[Thu Nov 21 15:06:22 2019] [ 20.206334] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:22 2019] [ 20.207352] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 55053, phase = 2
[Thu Nov 21 15:06:22 2019] [ 20.225922] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:22 2019] [ 20.226951] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 57092, phase = 2
[Thu Nov 21 15:06:22 2019] [ 20.235493] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:22 2019] [ 20.236679] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 59131, phase = 2
[Thu Nov 21 15:06:22 2019] [ 20.244994] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:22 2019] [ 20.249435] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 61170, phase = 2
[Thu Nov 21 15:06:22 2019] [ 20.265829] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:22 2019] [ 20.266854] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 63209, phase = 2
[Thu Nov 21 15:06:22 2019] [ 20.268982] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:22 2019] [ 20.269999] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 65248, phase = 2
[Thu Nov 21 15:06:23 2019] [ 20.276490] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:23 2019] [ 20.277518] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 67287, phase = 2
[Thu Nov 21 15:06:23 2019] [ 20.292054] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:23 2019] [ 20.293114] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 69326, phase = 2
[Thu Nov 21 15:06:23 2019] [ 20.296037] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:23 2019] [ 20.297061] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 71365, phase = 2
[Thu Nov 21 15:06:23 2019] [ 20.315909] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:23 2019] [ 20.316937] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 73404, phase = 2
[Thu Nov 21 15:06:23 2019] [ 20.325952] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:23 2019] [ 20.326978] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 75443, phase = 2
[Thu Nov 21 15:06:23 2019] [ 20.335900] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:23 2019] [ 20.336928] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 77482, phase = 2
[Thu Nov 21 15:06:23 2019] [ 20.353891] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:23 2019] [ 20.354913] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 79521, phase = 2
[Thu Nov 21 15:06:23 2019] [ 20.365915] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:23 2019] [ 20.366945] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 81560, phase = 2
[Thu Nov 21 15:06:23 2019] [ 20.376006] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:23 2019] [ 20.377177] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 83599, phase = 2
[Thu Nov 21 15:06:23 2019] [ 20.395220] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:23 2019] [ 20.396392] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 85638, phase = 2
[Thu Nov 21 15:06:23 2019] [ 20.403408] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:23 2019] [ 20.404422] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 87677, phase = 2
[Thu Nov 21 15:06:23 2019] [ 20.409269] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:23 2019] [ 20.410295] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 89716, phase = 2
[Thu Nov 21 15:06:23 2019] [ 20.432548] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:23 2019] [ 20.433572] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 91755, phase = 2
[Thu Nov 21 15:06:23 2019] [ 20.447323] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:23 2019] [ 20.459138] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 93794, phase = 2
[Thu Nov 21 15:06:24 2019] [ 20.461290] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:24 2019] [ 20.462310] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 95833, phase = 2
[Thu Nov 21 15:06:24 2019] [ 20.474794] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:24 2019] [ 20.476247] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 97872, phase = 2
[Thu Nov 21 15:06:24 2019] [ 20.480626] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:24 2019] [ 20.481654] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 99911, phase = 2
[Thu Nov 21 15:06:24 2019] [ 20.487708] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:24 2019] [ 20.488733] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 101950, phase = 2
[Thu Nov 21 15:06:24 2019] [ 20.505950] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:24 2019] [ 20.506983] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 103989, phase = 2
[Thu Nov 21 15:06:24 2019] [ 20.524051] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:24 2019] [ 20.525069] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 106028, phase = 2
[Thu Nov 21 15:06:24 2019] [ 20.533577] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:24 2019] [ 20.534605] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 108067, phase = 2
[Thu Nov 21 15:06:24 2019] [ 20.541603] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:24 2019] [ 20.542660] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 110106, phase = 2
[Thu Nov 21 15:06:24 2019] [ 20.544753] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:24 2019] [ 20.545924] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 112145, phase = 2
[Thu Nov 21 15:06:24 2019] [ 20.555960] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:24 2019] [ 20.556990] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 114184, phase = 2
[Thu Nov 21 15:06:24 2019] [ 20.573163] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:24 2019] [ 20.574183] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 116223, phase = 2
[Thu Nov 21 15:06:24 2019] [ 20.579702] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:24 2019] [ 20.580724] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 118262, phase = 2
[Thu Nov 21 15:06:24 2019] [ 20.604595] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:24 2019] [ 20.605622] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 120301, phase = 2
[Thu Nov 21 15:06:24 2019] [ 20.625936] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:24 2019] [ 20.626955] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 122340, phase = 2
[Thu Nov 21 15:06:25 2019] [ 20.634541] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:25 2019] [ 20.635568] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 124379, phase = 2
[Thu Nov 21 15:06:25 2019] [ 20.652221] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:25 2019] [ 20.653250] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 126418, phase = 2
[Thu Nov 21 15:06:25 2019] [ 20.661655] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:25 2019] [ 20.662682] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 128457, phase = 2
[Thu Nov 21 15:06:25 2019] [ 20.665848] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:25 2019] [ 20.666874] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 130496, phase = 2
[Thu Nov 21 15:06:25 2019] [ 20.693150] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:25 2019] [ 20.694172] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 132535, phase = 2
[Thu Nov 21 15:06:25 2019] [ 20.698938] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:25 2019] [ 20.699962] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 134574, phase = 2
[Thu Nov 21 15:06:25 2019] [ 20.705340] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:25 2019] [ 20.713504] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 136613, phase = 2
[Thu Nov 21 15:06:25 2019] [ 20.730745] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:25 2019] [ 20.731771] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 138652, phase = 2
[Thu Nov 21 15:06:25 2019] [ 20.735888] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:25 2019] [ 20.736907] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 140691, phase = 2
[Thu Nov 21 15:06:25 2019] [ 20.746140] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:25 2019] [ 20.747166] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 142730, phase = 2
[Thu Nov 21 15:06:25 2019] [ 20.760979] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:25 2019] [ 20.762005] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 144769, phase = 2
[Thu Nov 21 15:06:26 2019] [ 20.764111] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:26 2019] [ 20.765128] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 146808, phase = 2
[Thu Nov 21 15:06:26 2019] [ 20.795667] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:26 2019] [ 20.796826] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 148847, phase = 2
[Thu Nov 21 15:06:26 2019] [ 20.802174] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:26 2019] [ 20.803198] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 150886, phase = 2
[Thu Nov 21 15:06:26 2019] [ 20.808895] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:26 2019] [ 20.809951] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 152925, phase = 2
[Thu Nov 21 15:06:26 2019] [ 20.824518] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:26 2019] [ 20.825544] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 154964, phase = 2
[Thu Nov 21 15:06:26 2019] [ 20.830206] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:26 2019] [ 20.831233] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 157003, phase = 2
[Thu Nov 21 15:06:26 2019] [ 20.847944] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:26 2019] [ 20.848972] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 159042, phase = 2
[Thu Nov 21 15:06:26 2019] [ 20.862900] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:26 2019] [ 20.863928] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 161081, phase = 2
[Thu Nov 21 15:06:26 2019] [ 20.873062] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:26 2019] [ 20.874080] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 163120, phase = 2
[Thu Nov 21 15:06:26 2019] [ 20.877802] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:26 2019] [ 20.878824] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 165159, phase = 2
[Thu Nov 21 15:06:26 2019] [ 20.896400] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:26 2019] [ 20.897430] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 167198, phase = 2
[Thu Nov 21 15:06:26 2019] [ 20.903223] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:26 2019] [ 20.904248] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 169237, phase = 2
[Thu Nov 21 15:06:26 2019] [ 20.920775] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:26 2019] [ 20.921801] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 171276, phase = 2
[Thu Nov 21 15:06:26 2019] [ 20.933554] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:26 2019] [ 20.934584] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 173315, phase = 2
[Thu Nov 21 15:06:26 2019] [ 20.948768] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:26 2019] [ 20.949796] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 175354, phase = 2
[Thu Nov 21 15:06:26 2019] [ 20.952579] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:26 2019] [ 20.953601] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 177393, phase = 2
[Thu Nov 21 15:06:26 2019] [ 20.966528] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:26 2019] [ 20.967551] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 179432, phase = 2
[Thu Nov 21 15:06:26 2019] [ 20.975914] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:26 2019] [ 20.976941] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 181471, phase = 2
[Thu Nov 21 15:06:26 2019] [ 20.985910] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:26 2019] [ 20.986939] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 183510, phase = 2
[Thu Nov 21 15:06:26 2019] [ 21.008586] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:27 2019] [ 21.009623] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 185549, phase = 2
[Thu Nov 21 15:06:27 2019] [ 21.015888] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:27 2019] [ 21.016914] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 187588, phase = 2
[Thu Nov 21 15:06:27 2019] [ 21.025900] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:27 2019] [ 21.026926] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 189627, phase = 2
[Thu Nov 21 15:06:27 2019] [ 21.036072] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:27 2019] [ 21.037099] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 191666, phase = 2
[Thu Nov 21 15:06:27 2019] [ 21.044739] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:27 2019] [ 21.055998] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 193705, phase = 2
[Thu Nov 21 15:06:27 2019] [ 21.064148] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:27 2019] [ 21.065161] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 864, cur_len = 195744, phase = 3
[Thu Nov 21 15:06:27 2019] [ 21.076911] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:27 2019] [ 21.077925] Bluetooth: btmtk_usb_load_partial_rom_patch end
[Thu Nov 21 15:06:27 2019] [ 21.077931] Bluetooth: btmtk_usb_load_rom_patch_7668: loading ILM rom patch... Done
[Thu Nov 21 15:06:27 2019] [ 21.195884] Bluetooth: Check reset wmt result: OK
[Thu Nov 21 15:06:27 2019] [ 21.195897] Bluetooth: btmtk_usb_load_rom_patch_7668: loading sysram3 rom patch...
[Thu Nov 21 15:06:27 2019] [ 21.195922] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: patch_len = 16386
[Thu Nov 21 15:06:27 2019] [ 21.195939] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 0, phase = 1
[Thu Nov 21 15:06:27 2019] [ 21.198041] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:27 2019] [ 21.199060] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 2039, phase = 2
[Thu Nov 21 15:06:27 2019] [ 21.205210] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:27 2019] [ 21.216738] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 4078, phase = 2
[Thu Nov 21 15:06:27 2019] [ 21.218878] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:27 2019] [ 21.219900] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 6117, phase = 2
[Thu Nov 21 15:06:27 2019] [ 21.226005] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:27 2019] [ 21.227030] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 8156, phase = 2
[Thu Nov 21 15:06:27 2019] [ 21.235953] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:27 2019] [ 21.236981] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 10195, phase = 2
[Thu Nov 21 15:06:27 2019] [ 21.248790] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:27 2019] [ 21.249817] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 12234, phase = 2
[Thu Nov 21 15:06:27 2019] [ 21.268616] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:27 2019] [ 21.269646] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 2039, cur_len = 14273, phase = 2
[Thu Nov 21 15:06:27 2019] [ 21.293668] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:27 2019] [ 21.294688] Bluetooth: btmtk_usb_load_partial_rom_patch_7668: sent_len = 74, cur_len = 16312, phase = 3
[Thu Nov 21 15:06:27 2019] [ 21.300130] Bluetooth: Get rom patch result: OK
[Thu Nov 21 15:06:27 2019] [ 21.301141] Bluetooth: btmtk_usb_load_partial_rom_patch end
[Thu Nov 21 15:06:27 2019] [ 21.301147] Bluetooth: btmtk_usb_load_rom_patch_7668: loading sysram3 rom patch... Done
[Thu Nov 21 15:06:27 2019] [ 21.407294] Bluetooth: btmtk_usb_send_power_on_cmd_7668: Send command : 0x6F FC 06 01 06 02 00 00 01
[Thu Nov 21 15:06:27 2019] [ 25.803231] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
[Thu Nov 21 15:06:28 2019] [ 28.366464] option 2-1:1.0: GSM modem (1-port) converter detected
[Thu Nov 21 15:06:28 2019] [ 28.368287] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB0
[Thu Nov 21 15:06:28 2019] [ 28.368899] option 2-1:1.1: GSM modem (1-port) converter detected
[Thu Nov 21 15:06:28 2019] [ 28.396940] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB1
[Thu Nov 21 15:06:28 2019] [ 28.397634] option 2-1:1.2: GSM modem (1-port) converter detected
[Thu Nov 21 15:06:28 2019] [ 28.399097] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB2
[Thu Nov 21 15:06:28 2019] [ 28.399644] option 2-1:1.3: GSM modem (1-port) converter detected
[Thu Nov 21 15:06:28 2019] [ 28.400970] usb 2-1: GSM modem (1-port) converter now attached to ttyUSB3
[Thu Nov 21 15:06:28 2019] [ 28.529880] random: crng init done
[Thu Nov 21 15:06:28 2019] [ 28.529895] random: 7 urandom warning(s) missed due to ratelimiting
[Thu Nov 21 15:06:29 2019] _____ _____ _ _
[Thu Nov 21 15:06:29 2019] | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
[Thu Nov 21 15:06:29 2019] | | _| .'| . | . | | __| _| . | | | -_| _| _|
[Thu Nov 21 15:06:29 2019] |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
[Thu Nov 21 15:06:29 2019] |___| |___|
[Thu Nov 21 15:06:29 2019] Arago Project http://arago-project.org am335x-evmsk ttyS0
[Thu Nov 21 15:06:29 2019] Arago 2018.08 am335x-evmsk ttyS0
[Thu Nov 21 15:06:29 2019] am335x-evmsk login: [ 30.387921] Bluetooth: btmtk_usb_send_power_on_cmd_7668: OK
[Thu Nov 21 15:06:30 2019] [ 30.387921]
[Thu Nov 21 15:06:30 2019] [ 30.395088] Bluetooth: btmtk_usb_eeprom_bin_file: 7668 series
[Thu Nov 21 15:06:30 2019] [ 30.478112] bluetooth (null): Direct firmware load for wifi.cfg failed with error -2
[Thu Nov 21 15:06:30 2019] [ 30.517968] Bluetooth: btmtk_usb_eeprom_bin_file: Configure file not found, ignore EEPROM bin file
[Thu Nov 21 15:06:30 2019] [ 30.875959] Bluetooth: btmtk_usb_send_power_off_cmd_7668: OK
[Thu Nov 21 15:06:30 2019] [ 30.883204] Bluetooth: btmtk_usb_load_rom_patch end
[Thu Nov 21 15:06:30 2019] [ 30.964636] usbcore: registered new interface driver btusb
[Thu Nov 21 15:06:31 2019] [ 30.983676] Bluetooth: btusb_open
[Thu Nov 21 15:06:31 2019] [ 31.004258] Bluetooth: btmtk_usb_send_power_on_cmd_7668: Send command : 0x6F FC 06 01 06 02 00 00 01
[Thu Nov 21 15:06:32 2019] [ 33.172897] Bluetooth: btmtk_usb_send_power_on_cmd_7668: OK
[Thu Nov 21 15:06:32 2019] [ 33.180080] Bluetooth: btmtk_usb_eeprom_bin_file: 7668 series
[Thu Nov 21 15:06:32 2019] [ 33.187582] bluetooth hci0: Direct firmware load for wifi.cfg failed with error -2
[Thu Nov 21 15:06:32 2019] [ 33.195213] Bluetooth: btmtk_usb_eeprom_bin_file: Configure file not found, ignore EEPROM bin file
[Thu Nov 21 15:06:32 2019] [ 33.206091] ------------[ cut here ]------------
[Thu Nov 21 15:06:32 2019] [ 33.211049] WARNING: CPU: 0 PID: 587 at /home/mehmetk/Development/TI/tisdkNew/build/arago-tmp-external-linaro-toolchain/work-shared/am335x-evmsk/kernel-source/drivers/usb/core/hcd.c:1598 usb_hcd_map_urb_for_dma+0x60c/0x614 [usbcore]
[Thu Nov 21 15:06:32 2019] [ 33.237084] transfer buffer is on stack
[Thu Nov 21 15:06:32 2019] [ 33.240968] Modules linked in: bc_example(O) btmtk_usb(O) bluetooth ecdh_generic qmi_wwan option usb_wwan cdc_wdm usbnet usbserial musb_dsps musb_hdrc udc_core usbcore phy_am335x phy_generic usb_common phy_am335x_control ti_am335x_tsc pm33xx wkup_m3_ipc wkup_m3_rproc remoteproc pvrsrvkm(O) omap_aes_driver crypto_engine omap_crypto omap_sham ti_emif_sram pruss_soc_bus musb_am335x ti_am335x_tscadc rtc_omap omap_wdt sch_fq_codel cryptodev(O)
[Thu Nov 21 15:06:32 2019] [ 33.286009] CPU: 0 PID: 587 Comm: kworker/u3:0 Tainted: G O 4.14.67-gd315a9bb00 #1
[Thu Nov 21 15:06:32 2019] [ 33.294851] Hardware name: Generic AM33XX (Flattened Device Tree)
[Thu Nov 21 15:06:32 2019] [ 33.301362] Workqueue: hci0 hci_power_on [bluetooth]
[Thu Nov 21 15:06:32 2019] [ 33.306483] Backtrace:
[Thu Nov 21 15:06:32 2019] [ 33.308979] [<c010ba48>] (dump_backtrace) from [<c010bd2c>] (show_stack+0x18/0x1c)
[Thu Nov 21 15:06:32 2019] [ 33.316905] r7:00000009 r6:00000000 r5:bf16a6b8 r4:c76e1b28
[Thu Nov 21 15:06:32 2019] [ 33.322619] [<c010bd14>] (show_stack) from [<c08733a8>] (dump_stack+0x24/0x28)
[Thu Nov 21 15:06:32 2019] [ 33.330021] [<c0873384>] (dump_stack) from [<c0128af4>] (__warn+0xe8/0x100)
[Thu Nov 21 15:06:32 2019] [ 33.345601] [<c0128a0c>] (__warn) from [<c0128b4c>] (warn_slowpath_fmt+0x40/0x48)
[Thu Nov 21 15:06:33 2019] [ 33.353871] r9:bf1688c4 r8:01400000 r7:01400000 r6:fffffff5 r5:ce151000 r4:bf16a7ac
[Thu Nov 21 15:06:33 2019] [ 33.362118] [<c0128b10>] (warn_slowpath_fmt) from [<bf155280>] (usb_hcd_map_urb_for_dma+0x60c/0x614 [usbcore])
[Thu Nov 21 15:06:33 2019] [ 33.373390] r3:00000001 r2:bf16a7ac
[Thu Nov 21 15:06:33 2019] [ 33.377176] r4:c715eb00
[Thu Nov 21 15:06:33 2019] [ 33.380030] [<bf154c74>] (usb_hcd_map_urb_for_dma [usbcore]) from [<bf1f6354>] (musb_map_urb_for_dma+0x54/0x120 [musb_hdrc])
[Thu Nov 21 15:06:33 2019] [ 33.395907] r8:01400000 r7:c715eb08 r6:01400000 r5:ce151000 r4:c715eb00
[Thu Nov 21 15:06:33 2019] [ 33.402969] [<bf1f6300>] (musb_map_urb_for_dma [musb_hdrc]) from [<bf155548>] (usb_hcd_submit_urb+0x90/0x95c [usbcore])
[Thu Nov 21 15:06:33 2019] [ 33.414326] r7:c715eb08 r6:00000003 r5:ce151000 r4:c715eb00
[Thu Nov 21 15:06:33 2019] [ 33.420442] [<bf1554b8>] (usb_hcd_submit_urb [usbcore]) from [<bf157018>] (usb_submit_urb+0x348/0x4e8 [usbcore])
[Thu Nov 21 15:06:33 2019] [ 33.430783] r10:0ccccb60 r9:bf1688c4 r8:00000200 r7:01400000 r6:00000003 r5:ce0b4000
[Thu Nov 21 15:06:33 2019] [ 33.438689] r4:c715eb00
[Thu Nov 21 15:06:33 2019] [ 33.441431] [<bf156cd0>] (usb_submit_urb [usbcore]) from [<bf1578cc>] (usb_start_wait_urb+0x54/0xc4 [usbcore])
[Thu Nov 21 15:06:33 2019] [ 33.451998] r10:0ccccb60 r9:00000100 r8:000007d0 r7:c76e1d34 r6:00000000 r5:c76e1c98
[Thu Nov 21 15:06:33 2019] [ 33.460011] r4:c715eb00
[Thu Nov 21 15:06:33 2019] [ 33.462816] [<bf157878>] (usb_start_wait_urb [usbcore]) from [<bf157d7c>] (usb_bulk_msg+0x98/0x128 [usbcore])
[Thu Nov 21 15:06:33 2019] [ 33.475925] r8:c76e1d40 r7:ce5bfe40 r6:ce0b4000 r5:00000000 r4:40008380
[Thu Nov 21 15:06:33 2019] [ 33.483088] [<bf157ce4>] (usb_bulk_msg [usbcore]) from [<bf157e30>] (usb_interrupt_msg+0x24/0x2c [usbcore])
[Thu Nov 21 15:06:33 2019] [ 33.493903] r9:40008080 r8:c76e1d34 r7:bf496a68 r6:0000000a r5:ce064510 r4:0000000b
[Thu Nov 21 15:06:33 2019] [ 33.506170] [<bf157e0c>] (usb_interrupt_msg [usbcore]) from [<bf491200>] (btmtk_usb_send_tci_set_sleep_cmd_7668+0x108/0x218 [btmtk_usb])
[Thu Nov 21 15:06:33 2019] [ 33.518729] [<bf4910f8>] (btmtk_usb_send_tci_set_sleep_cmd_7668 [btmtk_usb]) from [<bf492bc4>] (btusb_open+0x190/0x19c [btmtk_usb])
[Thu Nov 21 15:06:33 2019] [ 33.530698] r10:c0d15280 r9:00000000 r8:ce0aea00 r7:00000000 r6:bf498240 r5:ce6e2000
[Thu Nov 21 15:06:33 2019] [ 33.538599] r4:ce064510
[Thu Nov 21 15:06:33 2019] [ 33.541418] [<bf492a34>] (btusb_open [btmtk_usb]) from [<bf368aa8>] (hci_dev_do_open+0x54/0x578 [bluetooth])
[Thu Nov 21 15:06:33 2019] [ 33.551649] r7:00000000 r6:ce6e2808 r5:ce6e2000 r4:ce6e2000
[Thu Nov 21 15:06:33 2019] [ 33.557633] [<bf368a54>] (hci_dev_do_open [bluetooth]) from [<bf36a434>] (hci_power_on+0x3c/0x20c [bluetooth])
[Thu Nov 21 15:06:33 2019] [ 33.567782] r7:00000000 r6:ce6e200c r5:ce6e2000 r4:ce6e261c
[Thu Nov 21 15:06:33 2019] [ 33.573575] [<bf36a3f8>] (hci_power_on [bluetooth]) from [<c013fcfc>] (process_one_work+0x1f8/0x444)
[Thu Nov 21 15:06:33 2019] [ 33.584089] r7:00000000 r6:ce32fe00 r5:c768de00 r4:ce6e261c
[Thu Nov 21 15:06:33 2019] [ 33.589940] [<c013fb04>] (process_one_work) from [<c013ffcc>] (worker_thread+0x84/0x680)
[Thu Nov 21 15:06:33 2019] [ 33.598146] r10:c0d15280 r9:00000088 r8:ce0aea14 r7:ffffe000 r6:c768de18 r5:ce0aea00
[Thu Nov 21 15:06:33 2019] [ 33.606112] r4:c768de00
[Thu Nov 21 15:06:33 2019] [ 33.608673] [<c013ff48>] (worker_thread) from [<c0145d4c>] (kthread+0x15c/0x164)
[Thu Nov 21 15:06:33 2019] [ 33.616157] r10:ce17faac r9:c013ff48 r8:c768de00 r7:c76e0000 r6:00000000 r5:c76c2940
[Thu Nov 21 15:06:33 2019] [ 33.624020] r4:c76c2740
[Thu Nov 21 15:06:33 2019] [ 33.626637] [<c0145bf0>] (kthread) from [<c0107e08>] (ret_from_fork+0x14/0x2c)
[Thu Nov 21 15:06:33 2019] [ 33.633896] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c0145bf0
[Thu Nov 21 15:06:33 2019] [ 33.653495] r4:c76c2940
[Thu Nov 21 15:06:33 2019] [ 33.656202] ---[ end trace 02848d53f945e99a ]---
[Thu Nov 21 15:06:33 2019] [ 33.660896] Bluetooth: btmtk_usb_send_tci_set_sleep_cmd_7668: error2(-11)
[Thu Nov 21 15:06:33 2019] [ 33.676895] Bluetooth: btmtk_usb_send_hci_cmd: got unknown event:(3/6)
[Thu Nov 21 15:06:33 2019] [ 33.695857] Bluetooth: btmtk_usb_send_hci_reset_cmd: OK
[Thu Nov 21 15:06:33 2019] [ 33.705894] btmtk_usb fwlog queue size is full(bluetooth_kpi)
[Thu Nov 21 15:06:33 2019] [ 33.927450] [wlan][529]mtk_usb_probe:(HAL EVENT) mtk_usb_probe()
[Thu Nov 21 15:06:33 2019] [ 33.992772] [wlan][529]mtk_usb_probe:(HAL EVENT) wlan_probe()
[Thu Nov 21 15:06:33 2019] [ 34.030271] [wlan][529]glSetHifInfo:(HAL STATE) USB Device speed: 3 [512]
[Thu Nov 21 15:06:33 2019] [ 34.115582] usb 1-1.2: Direct firmware load for wifi.cfg failed with error -2
[Thu Nov 21 15:06:35 2019] [ 36.109262] [wlan][529]wlanAdapterStart:(INIT WARN) Send a Dummy CMD as workaround
[Thu Nov 21 15:06:35 2019] [ 36.138188] [wlan][529]kalDevPortRead:(HAL WARN) usb_bulk_msg(IN=4) Warning. Data is not completed. (receive 80/148)
[Thu Nov 21 15:06:35 2019] [ 36.198701] [wlan][529]wlanQueryNicCapability:(INIT WARN) wlanQueryNicCapability: skip unexpected event ID[0x27]
[Thu Nov 21 15:06:35 2019] [ 36.245611] [wlan][529]kalDevPortRead:(HAL WARN) usb_bulk_msg(IN=4) Warning. Data is not completed. (receive 136/2356)
[Thu Nov 21 15:06:35 2019] [ 36.323447] [wlan][529]wlanAdapterStart:(INIT WARN) wlanAdapterStart: load manufacture data fail
[Thu Nov 21 15:06:41 2019] [ 42.157639] [wlan][529]mtk_reg_notify:(RLM WARN) County Code is not assigned. Use default WW.
[Thu Nov 21 15:06:41 2019] [ 42.231913] [wlan][529]rlmDomainSearchRegdomainFromLocalDataBase:(RLM ERROR) rlmDomainSearchRegdomainFromLocalDataBase(): Error, Cannot find the correct RegDomain. country = 00.
[Thu Nov 21 15:06:42 2019] [ 42.436822] usb 1-1.2: Direct firmware load for TxPwrLimit_MT76x8.dat failed with error -2
[Thu Nov 21 15:06:42 2019] [ 42.586669] [wlan][529]wlanProbe:(INIT EVENT) wlanProbe: probe success
[Thu Nov 21 15:06:42 2019] [ 42.675230] usbcore: registered new interface driver wlan
[Thu Nov 21 15:06:46 2019] [ 46.661240] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[Thu Nov 21 15:06:54 2019] [ 55.258030] Bluetooth: RFCOMM socket layer initialized
[Thu Nov 21 15:06:54 2019] [ 55.265972] Bluetooth: RFCOMM ver 1.11
[Thu Nov 21 15:06:59 2019] [ 59.441010] [wlan][737]mtk_cfg80211_scan:(REQ WARN) scan channel num (39) exceeds 32, do a full scan instead
[Thu Nov 21 15:06:59 2019] [ 59.452417] [wlan][607]aisFsmSteps:(AIS STATE) [AIS]TRANSITION: [IDLE] -> [SCAN]
[Thu Nov 21 15:06:59 2019] [ 59.465269] [wlan][607]scnFsmSteps:(SCN STATE) [SCAN]TRANSITION: [IDLE] -> [SCANNING]
[Thu Nov 21 15:06:59 2019] [ 59.825998] NOHZ: local_softirq_pending 40
[Thu Nov 21 15:07:00 2019] [ 60.696091] NOHZ: local_softirq_pending 40
[Thu Nov 21 15:07:00 2019] [ 60.700276] NOHZ: local_softirq_pending 40
[Thu Nov 21 15:07:00 2019] [ 60.736035] NOHZ: local_softirq_pending 40
[Thu Nov 21 15:07:00 2019] [ 60.740190] NOHZ: local_softirq_pending 40
[Thu Nov 21 15:07:00 2019] [ 61.286298] [wlan][607]scnFsmSteps:(SCN STATE) [SCAN]TRANSITION: [SCANNING] -> [IDLE]
[Thu Nov 21 15:07:00 2019] [ 61.309697] [wlan][607]aisFsmSteps:(AIS STATE) [AIS]TRANSITION: [SCAN] -> [IDLE]
[Thu Nov 21 15:07:00 2019] [ 61.337831] [wlan][737]mtk_cfg80211_connect:(SEC WARN) [wapi] set wapi assoc info error:0xc0010014
[Thu Nov 21 15:07:00 2019] [ 61.347899] [wlan][607]aisFsmRunEventAbort:(AIS STATE) EVENT-ABORT: Current State IDLE, ucReasonOfDisconnect:4
[Thu Nov 21 15:07:01 2019] [ 61.365682] [wlan][607]aisFsmRunEventAbort:(AIS STATE) ucReasonOfDisconnect:4
[Thu Nov 21 15:07:01 2019] [ 61.375000] [wlan][607]aisFsmStateAbort:(AIS STATE) aisFsmStateAbort DiscReason[4], CurState[0]
[Thu Nov 21 15:07:01 2019] [ 61.385951] [wlan][607]rlmObssAbortScan:(RLM STATE) SCAN IDLE Do Nothing
[Thu Nov 21 15:07:01 2019] [ 61.396193] [wlan][607]aisFsmSteps:(AIS STATE) [AIS]TRANSITION: [IDLE] -> [IDLE]
[Thu Nov 21 15:07:01 2019] [ 61.406191] [wlan][607]aisFsmSteps:(AIS STATE) [AIS]TRANSITION: [IDLE] -> [SEARCH]
[Thu Nov 21 15:07:01 2019] [ 61.415385] [wlan][607]aisFsmSteps:(AIS STATE) [AIS]TRANSITION: [SEARCH] -> [REQ_CHANNEL_JOIN]
[Thu Nov 21 15:07:01 2019] [ 61.478849] [wlan][607]aisFsmSteps:(AIS STATE) [AIS]TRANSITION: [REQ_CHANNEL_JOIN] -> [JOIN]
[Thu Nov 21 15:07:01 2019] [ 61.488940] [wlan][607]saaFsmSteps:(SAA STATE) [SAA]TRANSITION: [AA_IDLE] -> [SAA_SEND_AUTH1]
[Thu Nov 21 15:07:01 2019] [ 61.510571] [wlan][607]saaFsmSteps:(SAA STATE) [SAA]TRANSITION: [SAA_SEND_AUTH1] -> [SAA_WAIT_AUTH2]
[Thu Nov 21 15:07:01 2019] [ 61.521070] [wlan][607]saaFsmSteps:(SAA STATE) [SAA]TRANSITION: [SAA_WAIT_AUTH2] -> [SAA_SEND_ASSOC1]
[Thu Nov 21 15:07:01 2019] [ 61.544659] [wlan][607]saaFsmSteps:(SAA STATE) [SAA]TRANSITION: [SAA_SEND_ASSOC1] -> [AA_IDLE]
[Thu Nov 21 15:07:01 2019] [ 61.554796] [wlan][607]nicQmUpdateWmmParms:(QM EVENT) sizeof(AC_QUE_PARMS_T): 10
[Thu Nov 21 15:07:01 2019] [ 61.562436] [wlan][607]nicRxProcessDataPacket:(RSN WARN) Re-enqueue EAPOL frame: State[1], retry[1]
[Thu Nov 21 15:07:01 2019] [ 61.575853] [wlan][607]nicQmUpdateWmmParms:(QM EVENT) sizeof(CMD_UPDATE_WMM_PARMS): 44
[Thu Nov 21 15:07:01 2019] [ 61.586092] [wlan][607]nicQmUpdateWmmParms:(QM EVENT) sizeof(WIFI_CMD_T): 64
[Thu Nov 21 15:07:01 2019] [ 61.609283] [wlan][607]aisFsmSteps:(AIS STATE) [AIS]TRANSITION: [JOIN] -> [NORMAL_TR]
[Thu Nov 21 15:07:01 2019] [ 61.620729] [wlan][607]kalRxIndicateOnePkt:(RSN STATE) Rx EAPOL Frame [Len: 121]
[Thu Nov 21 15:07:01 2019] [ 61.637713] [wlan][737]kalQoSFrameClassifierAndPacketInfo:(RSN STATE) Tx EAPOL Frame[Len:135, KeyInfo:266]
[Thu Nov 21 15:07:02 2019] [ 62.545887] [wlan][0]kalRxIndicateOnePkt:(RSN STATE) Rx EAPOL Frame [Len: 121]
[Thu Nov 21 15:07:02 2019] [ 62.560031] [wlan][737]kalQoSFrameClassifierAndPacketInfo:(RSN STATE) Tx EAPOL Frame[Len:135, KeyInfo:266]
[Thu Nov 21 15:07:02 2019] [ 62.584239] [wlan][0]kalRxIndicateOnePkt:(RSN STATE) Rx EAPOL Frame [Len: 155]
[Thu Nov 21 15:07:02 2019] [ 62.593082] [wlan][737]kalQoSFrameClassifierAndPacketInfo:(RSN STATE) Tx EAPOL Frame[Len:113, KeyInfo:778]
[Thu Nov 21 15:07:02 2019] [ 62.611394] [wlan][607]nicEventAddPkeyDone:(RSN EVENT) EVENT_ID_ADD_PKEY_DONE BSSIDX=0 0c:9d:92:4d:bc:b0
[Thu Nov 21 15:07:02 2019] [ 62.621530] [wlan][607]nicEventAddPkeyDone:(RSN EVENT) STA 0c:9d:92:4d:bc:b0 Add Key Done!!
[Thu Nov 21 15:07:02 2019] [ 62.632844] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[Thu Nov 21 15:07:02 2019] [ 62.640477] [wlan][607]nicEventAddPkeyDone:(RSN EVENT) EVENT_ID_ADD_PKEY_DONE BSSIDX=0 ff:ff:ff:ff:ff:ff
[Thu Nov 21 15:07:02 2019] [ 62.683144] NOHZ: local_softirq_pending 40
[Thu Nov 21 15:07:04 2019] [ 64.601415] NOHZ: local_softirq_pending 08
[Thu Nov 21 15:09:48 2019] [A
[Thu Nov 21 15:09:50 2019] _____ _____ _ _
[Thu Nov 21 15:09:50 2019] | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
[Thu Nov 21 15:09:50 2019] | | _| .'| . | . | | __| _| . | | | -_| _| _|
[Thu Nov 21 15:09:50 2019] |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
[Thu Nov 21 15:09:50 2019] |___| |___|
[Thu Nov 21 15:09:50 2019] Arago Project http://arago-project.org am335x-evmsk ttyS0
[Thu Nov 21 15:09:50 2019] Arago 2018.08 am335x-evmsk ttyS0
[Thu Nov 21 15:09:50 2019] am335x-evmsk login: root
[Thu Nov 21 15:09:52 2019] Last login: Wed Oct 16 08:31:04 UTC 2019 on ttyS0
[Thu Nov 21 15:09:53 2019] root@am335x-evmsk:~# ifconfig
[Thu Nov 21 15:09:57 2019] eth0 Link encap:Ethernet HWaddr 18:62:E4:E7:4A:80
[Thu Nov 21 15:09:57 2019] inet addr:192.168.0.10 Bcast:192.168.0.255 Mask:255.255.255.0
[Thu Nov 21 15:09:57 2019] inet6 addr: fe80::1a62:e4ff:fee7:4a80%763612/64 Scope:Link
[Thu Nov 21 15:09:57 2019] UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
[Thu Nov 21 15:09:57 2019] RX packets:54 errors:0 dropped:0 overruns:0 frame:0
[Thu Nov 21 15:09:57 2019] TX packets:52 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:09:57 2019] collisions:0 txqueuelen:1000
[Thu Nov 21 15:09:57 2019] RX bytes:3647 (3.5 KiB) TX bytes:3872 (3.7 KiB)
[Thu Nov 21 15:09:57 2019] Interrupt:49
[Thu Nov 21 15:09:57 2019] lo Link encap:Local Loopback
[Thu Nov 21 15:09:57 2019] inet addr:127.0.0.1 Mask:255.0.0.0
[Thu Nov 21 15:09:57 2019] inet6 addr: ::1%763612/128 Scope:Host
[Thu Nov 21 15:09:57 2019] UP LOOPBACK RUNNING MTU:65536 Metric:1
[Thu Nov 21 15:09:57 2019] RX packets:45 errors:0 dropped:0 overruns:0 frame:0
[Thu Nov 21 15:09:57 2019] TX packets:45 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:09:57 2019] RX bytes:3837 (3.7 KiB) TX bytes:3837 (3.7 KiB)
[Thu Nov 21 15:09:57 2019] wlan0 Link encap:Ethernet HWaddr 70:54:B4:A2:94:7A
[Thu Nov 21 15:09:57 2019] inet addr:192.168.2.148 Bcast:192.168.2.255 Mask:255.255.255.0
[Thu Nov 21 15:09:57 2019] inet6 addr: fe80::7254:b4ff:fea2:947a%763612/64 Scope:Link
[Thu Nov 21 15:09:57 2019] RX packets:1882 errors:0 dropped:0 overruns:0 frame:0
[Thu Nov 21 15:09:57 2019] TX packets:39 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:09:57 2019] RX bytes:214599 (209.5 KiB) TX bytes:3855 (3.7 KiB)
[Thu Nov 21 15:09:57 2019] wwan0 Link encap:Ethernet HWaddr 2E:4C:2A:B2:8E:0A
[Thu Nov 21 15:09:57 2019] inet addr:172.21.29.235 Bcast:172.21.29.239 Mask:255.255.255.248
[Thu Nov 21 15:09:57 2019] UP BROADCAST RUNNING NOARP MULTICAST MTU:1500 Metric:1
[Thu Nov 21 15:09:57 2019] RX packets:117 errors:0 dropped:0 overruns:0 frame:0
[Thu Nov 21 15:09:57 2019] TX packets:157 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:09:57 2019] RX bytes:16299 (15.9 KiB) TX bytes:19175 (18.7 KiB)
[Thu Nov 21 15:09:57 2019] root@am335x-evmsk:~# ifconfig
[Thu Nov 21 15:13:35 2019] eth0 Link encap:Ethernet HWaddr 18:62:E4:E7:4A:80
[Thu Nov 21 15:13:35 2019] inet addr:192.168.0.10 Bcast:192.168.0.255 Mask:255.255.255.0
[Thu Nov 21 15:13:35 2019] inet6 addr: fe80::1a62:e4ff:fee7:4a80%763612/64 Scope:Link
[Thu Nov 21 15:13:35 2019] UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
[Thu Nov 21 15:13:35 2019] RX packets:126 errors:0 dropped:0 overruns:0 frame:0
[Thu Nov 21 15:13:35 2019] TX packets:75 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:13:35 2019] collisions:0 txqueuelen:1000
[Thu Nov 21 15:13:35 2019] RX bytes:8831 (8.6 KiB) TX bytes:10768 (10.5 KiB)
[Thu Nov 21 15:13:35 2019] Interrupt:49
[Thu Nov 21 15:13:35 2019] lo Link encap:Local Loopback
[Thu Nov 21 15:13:35 2019] inet addr:127.0.0.1 Mask:255.0.0.0
[Thu Nov 21 15:13:35 2019] inet6 addr: ::1%763612/128 Scope:Host
[Thu Nov 21 15:13:35 2019] UP LOOPBACK RUNNING MTU:65536 Metric:1
[Thu Nov 21 15:13:36 2019] RX packets:45 errors:0 dropped:0 overruns:0 frame:0
[Thu Nov 21 15:13:36 2019] TX packets:45 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:13:36 2019] collisions:0 txqueuelen:1000
[Thu Nov 21 15:13:36 2019] RX bytes:3837 (3.7 KiB) TX bytes:3837 (3.7 KiB)
[Thu Nov 21 15:13:36 2019] wlan0 Link encap:Ethernet HWaddr 70:54:B4:A2:94:7A
[Thu Nov 21 15:13:36 2019] inet addr:192.168.2.148 Bcast:192.168.2.255 Mask:255.255.255.0
[Thu Nov 21 15:13:36 2019] inet6 addr: fe80::7254:b4ff:fea2:947a%763612/64 Scope:Link
[Thu Nov 21 15:13:36 2019] UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
[Thu Nov 21 15:13:36 2019] RX packets:4877 errors:0 dropped:0 overruns:0 frame:0
[Thu Nov 21 15:13:36 2019] TX packets:42 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:13:36 2019] RX bytes:582610 (568.9 KiB) TX bytes:4129 (4.0 KiB)
[Thu Nov 21 15:13:36 2019] wwan0 Link encap:Ethernet HWaddr 2E:4C:2A:B2:8E:0A
[Thu Nov 21 15:13:36 2019] inet addr:172.21.29.235 Bcast:172.21.29.239 Mask:255.255.255.248
[Thu Nov 21 15:13:36 2019] UP BROADCAST RUNNING NOARP MULTICAST MTU:1500 Metric:1
[Thu Nov 21 15:13:36 2019] RX packets:244 errors:0 dropped:0 overruns:0 frame:0
[Thu Nov 21 15:13:36 2019] TX packets:284 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:13:36 2019] RX bytes:25787 (25.1 KiB) TX bytes:29315 (28.6 KiB)
[Thu Nov 21 15:13:36 2019] root@am335x-evmsk:~# [ 540.725385] [wlan][0]kalRxIndicateOnePkt:(RSN STATE) Rx EAPOL Frame [Len: 131]
[Thu Nov 21 15:15:00 2019] [ 540.735480] [wlan][737]kalQoSFrameClassifierAndPacketInfo:(RSN STATE) Tx EAPOL Frame[Len:113, KeyInfo:770]
[Thu Nov 21 15:15:00 2019] [ 540.747405] [wlan][607]nicEventAddPkeyDone:(RSN EVENT) EVENT_ID_ADD_PKEY_DONE BSSIDX=0 ff:ff:ff:ff:ff:ff
[Thu Nov 21 15:15:00 2019] [ 540.798708] [wlan][0]kalRxIndicateOnePkt:(RSN STATE) Rx EAPOL Frame [Len: 131]
[Thu Nov 21 15:15:00 2019] [ 540.808114] [wlan][737]kalQoSFrameClassifierAndPacketInfo:(RSN STATE) Tx EAPOL Frame[Len:113, KeyInfo:770]
[Thu Nov 21 15:20:54 2019] [ 894.396000] usb 2-1: reset high-speed USB device number 2 using musb-hdrc
[Thu Nov 21 15:20:54 2019] [ 894.555964] usb 2-1: device descriptor read/64, error -71
[Thu Nov 21 15:29:28 2019] [ 1408.736256] usb 2-1: reset high-speed USB device number 2 using musb-hdrc
[Thu Nov 21 15:29:28 2019] [ 1408.886126] usb 2-1: device descriptor read/64, error -71
[Thu Nov 21 15:42:19 2019] ifconfig
[Thu Nov 21 15:42:20 2019] eth0 Link encap:Ethernet HWaddr 18:62:E4:E7:4A:80
[Thu Nov 21 15:42:20 2019] inet addr:192.168.0.10 Bcast:192.168.0.255 Mask:255.255.255.0
[Thu Nov 21 15:42:20 2019] inet6 addr: fe80::1a62:e4ff:fee7:4a80%763612/64 Scope:Link
[Thu Nov 21 15:42:20 2019] UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
[Thu Nov 21 15:42:20 2019] RX packets:640 errors:0 dropped:0 overruns:0 frame:0
[Thu Nov 21 15:42:20 2019] TX packets:77 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:42:20 2019] collisions:0 txqueuelen:1000
[Thu Nov 21 15:42:20 2019] RX bytes:42473 (41.4 KiB) TX bytes:10908 (10.6 KiB)
[Thu Nov 21 15:42:20 2019] Interrupt:49
[Thu Nov 21 15:42:20 2019] lo Link encap:Local Loopback
[Thu Nov 21 15:42:20 2019] inet addr:127.0.0.1 Mask:255.0.0.0
[Thu Nov 21 15:42:20 2019] inet6 addr: ::1%763612/128 Scope:Host
[Thu Nov 21 15:42:20 2019] UP LOOPBACK RUNNING MTU:65536 Metric:1
[Thu Nov 21 15:42:20 2019] RX packets:48 errors:0 dropped:0 overruns:0 frame:0
[Thu Nov 21 15:42:20 2019] TX packets:48 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:42:20 2019] RX bytes:4158 (4.0 KiB) TX bytes:4158 (4.0 KiB)
[Thu Nov 21 15:42:20 2019] wlan0 Link encap:Ethernet HWaddr 70:54:B4:A2:94:7A
[Thu Nov 21 15:42:20 2019] inet addr:192.168.2.148 Bcast:192.168.2.255 Mask:255.255.255.0
[Thu Nov 21 15:42:20 2019] inet6 addr: fe80::7254:b4ff:fea2:947a%763612/64 Scope:Link
[Thu Nov 21 15:42:20 2019] RX packets:27431 errors:0 dropped:0 overruns:0 frame:0
[Thu Nov 21 15:42:20 2019] TX packets:692 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:42:20 2019] RX bytes:3183732 (3.0 MiB) TX bytes:72726 (71.0 KiB)
[Thu Nov 21 15:42:20 2019] wwan0 Link encap:Ethernet HWaddr 2E:4C:2A:B2:8E:0A
[Thu Nov 21 15:42:20 2019] inet6 addr: fe80::2c4c:2aff:feb2:8e0a%763612/64 Scope:Link
[Thu Nov 21 15:42:20 2019] UP BROADCAST RUNNING NOARP MULTICAST MTU:1500 Metric:1
[Thu Nov 21 15:42:20 2019] RX packets:480 errors:0 dropped:0 overruns:0 frame:0
[Thu Nov 21 15:42:20 2019] TX packets:603 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:42:20 2019] RX bytes:42974 (41.9 KiB) TX bytes:62195 (60.7 KiB)
[Thu Nov 21 15:42:20 2019] root@am335x-evmsk:~# ifconfig
[Thu Nov 21 15:42:38 2019] eth0 Link encap:Ethernet HWaddr 18:62:E4:E7:4A:80
[Thu Nov 21 15:42:38 2019] inet addr:192.168.0.10 Bcast:192.168.0.255 Mask:255.255.255.0
[Thu Nov 21 15:42:38 2019] inet6 addr: fe80::1a62:e4ff:fee7:4a80%763612/64 Scope:Link
[Thu Nov 21 15:42:38 2019] UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
[Thu Nov 21 15:42:38 2019] RX packets:643 errors:0 dropped:0 overruns:0 frame:0
[Thu Nov 21 15:42:38 2019] TX packets:77 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:42:38 2019] collisions:0 txqueuelen:1000
[Thu Nov 21 15:42:38 2019] RX bytes:42665 (41.6 KiB) TX bytes:10908 (10.6 KiB)
[Thu Nov 21 15:42:38 2019] Interrupt:49
[Thu Nov 21 15:42:38 2019] lo Link encap:Local Loopback
[Thu Nov 21 15:42:38 2019] inet addr:127.0.0.1 Mask:255.0.0.0
[Thu Nov 21 15:42:38 2019] inet6 addr: ::1%763612/128 Scope:Host
[Thu Nov 21 15:42:38 2019] UP LOOPBACK RUNNING MTU:65536 Metric:1
[Thu Nov 21 15:42:38 2019] RX packets:48 errors:0 dropped:0 overruns:0 frame:0
[Thu Nov 21 15:42:38 2019] TX packets:48 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:42:38 2019] RX bytes:4158 (4.0 KiB) TX bytes:4158 (4.0 KiB)
[Thu Nov 21 15:42:38 2019] wlan0 Link encap:Ethernet HWaddr 70:54:B4:A2:94:7A
[Thu Nov 21 15:42:38 2019] inet addr:192.168.2.148 Bcast:192.168.2.255 Mask:255.255.255.0
[Thu Nov 21 15:42:38 2019] inet6 addr: fe80::7254:b4ff:fea2:947a%763612/64 Scope:Link
[Thu Nov 21 15:42:38 2019] RX packets:27684 errors:0 dropped:0 overruns:0 frame:0
[Thu Nov 21 15:42:38 2019] TX packets:701 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:42:38 2019] RX bytes:3216922 (3.0 MiB) TX bytes:73495 (71.7 KiB)
[Thu Nov 21 15:42:38 2019] wwan0 Link encap:Ethernet HWaddr 2E:4C:2A:B2:8E:0A
[Thu Nov 21 15:42:38 2019] inet6 addr: fe80::2c4c:2aff:feb2:8e0a%763612/64 Scope:Link
[Thu Nov 21 15:42:38 2019] UP BROADCAST RUNNING NOARP MULTICAST MTU:1500 Metric:1
[Thu Nov 21 15:42:38 2019] RX packets:480 errors:0 dropped:0 overruns:0 frame:0
[Thu Nov 21 15:42:38 2019] TX packets:603 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:42:38 2019] RX bytes:42974 (41.9 KiB) TX bytes:62195 (60.7 KiB)
[Thu Nov 21 15:42:38 2019] root@am335x-evmsk:~# [ 2356.408397] [wlan][0]kalRxIndicateOnePkt:(RSN STATE) Rx EAPOL Frame [Len: 131]
[Thu Nov 21 15:45:15 2019] [ 2356.418671] [wlan][737]kalQoSFrameClassifierAndPacketInfo:(RSN STATE) Tx EAPOL Frame[Len:113, KeyInfo:770]
[Thu Nov 21 15:45:15 2019] [ 2356.431320] [wlan][607]nicEventAddPkeyDone:(RSN EVENT) EVENT_ID_ADD_PKEY_DONE BSSIDX=0 ff:ff:ff:ff:ff:ff
[Thu Nov 21 15:46:10 2019]
[Thu Nov 21 15:46:10 2019] root@am335x-evmsk:~#
[Thu Nov 21 15:46:10 2019] root@am335x-evmsk:~# ifconfig systemctl disable systemd restart systemd-networkd
[Thu Nov 21 15:46:50 2019] Job for systemd-networkd.service failed because the service did not take the steps required by its unit configuration.
[Thu Nov 21 15:46:50 2019] See "systemctl status systemd-networkd.service" and "journalctl -xe" for details.
[Thu Nov 21 15:46:51 2019] root@am335x-evmsk:~# systemctl restart systemd-networkd
[Thu Nov 21 15:47:04 2019] root@am335x-evmsk:~# systemctl restart systemd-networkdroot@am335x-evmsk:~# ifconfig
[Thu Nov 21 15:47:07 2019] eth0 Link encap:Ethernet HWaddr 18:62:E4:E7:4A:80
[Thu Nov 21 15:47:07 2019] inet addr:192.168.0.10 Bcast:192.168.0.255 Mask:255.255.255.0
[Thu Nov 21 15:47:07 2019] inet6 addr: fe80::1a62:e4ff:fee7:4a80%763612/64 Scope:Link
[Thu Nov 21 15:47:07 2019] UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
[Thu Nov 21 15:47:07 2019] RX packets:709 errors:0 dropped:0 overruns:0 frame:0
[Thu Nov 21 15:47:07 2019] TX packets:85 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:47:07 2019] collisions:0 txqueuelen:1000
[Thu Nov 21 15:47:07 2019] RX bytes:47080 (45.9 KiB) TX bytes:11459 (11.1 KiB)
[Thu Nov 21 15:47:07 2019] Interrupt:49
[Thu Nov 21 15:47:07 2019] lo Link encap:Local Loopback
[Thu Nov 21 15:47:07 2019] inet addr:127.0.0.1 Mask:255.0.0.0
[Thu Nov 21 15:47:07 2019] inet6 addr: ::1%763612/128 Scope:Host
[Thu Nov 21 15:47:07 2019] UP LOOPBACK RUNNING MTU:65536 Metric:1
[Thu Nov 21 15:47:07 2019] RX packets:54 errors:0 dropped:0 overruns:0 frame:0
[Thu Nov 21 15:47:07 2019] TX packets:54 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:47:07 2019] RX bytes:4608 (4.5 KiB) TX bytes:4608 (4.5 KiB)
[Thu Nov 21 15:47:07 2019] wlan0 Link encap:Ethernet HWaddr 70:54:B4:A2:94:7A
[Thu Nov 21 15:47:07 2019] inet addr:192.168.2.148 Bcast:192.168.2.255 Mask:255.255.255.0
[Thu Nov 21 15:47:07 2019] inet6 addr: fe80::7254:b4ff:fea2:947a%763612/64 Scope:Link
[Thu Nov 21 15:47:07 2019] RX packets:30672 errors:0 dropped:1 overruns:0 frame:0
[Thu Nov 21 15:47:07 2019] TX packets:858 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:47:07 2019] RX bytes:3590433 (3.4 MiB) TX bytes:87279 (85.2 KiB)
[Thu Nov 21 15:47:07 2019] wwan0 Link encap:Ethernet HWaddr 2E:4C:2A:B2:8E:0A
[Thu Nov 21 15:47:07 2019] inet6 addr: fe80::2c4c:2aff:feb2:8e0a%763612/64 Scope:Link
[Thu Nov 21 15:47:07 2019] UP BROADCAST RUNNING NOARP MULTICAST MTU:1500 Metric:1
[Thu Nov 21 15:47:07 2019] RX packets:480 errors:0 dropped:0 overruns:0 frame:0
[Thu Nov 21 15:47:07 2019] TX packets:614 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:47:07 2019] RX bytes:42974 (41.9 KiB) TX bytes:64559 (63.0 KiB)
[Thu Nov 21 15:47:07 2019] root@am335x-evmsk:~# ifconfig
[Thu Nov 21 15:47:25 2019] eth0 Link encap:Ethernet HWaddr 18:62:E4:E7:4A:80
[Thu Nov 21 15:47:25 2019] inet addr:192.168.0.10 Bcast:192.168.0.255 Mask:255.255.255.0
[Thu Nov 21 15:47:25 2019] inet6 addr: fe80::1a62:e4ff:fee7:4a80%763612/64 Scope:Link
[Thu Nov 21 15:47:25 2019] UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
[Thu Nov 21 15:47:25 2019] RX packets:713 errors:0 dropped:0 overruns:0 frame:0
[Thu Nov 21 15:47:25 2019] TX packets:87 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:47:25 2019] collisions:0 txqueuelen:1000
[Thu Nov 21 15:47:25 2019] RX bytes:47336 (46.2 KiB) TX bytes:11599 (11.3 KiB)
[Thu Nov 21 15:47:25 2019] Interrupt:49
[Thu Nov 21 15:47:25 2019] lo Link encap:Local Loopback
[Thu Nov 21 15:47:25 2019] inet addr:127.0.0.1 Mask:255.0.0.0
[Thu Nov 21 15:47:25 2019] inet6 addr: ::1%763612/128 Scope:Host
[Thu Nov 21 15:47:25 2019] UP LOOPBACK RUNNING MTU:65536 Metric:1
[Thu Nov 21 15:47:25 2019] RX packets:54 errors:0 dropped:0 overruns:0 frame:0
[Thu Nov 21 15:47:25 2019] TX packets:54 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:47:25 2019] RX bytes:4608 (4.5 KiB) TX bytes:4608 (4.5 KiB)
[Thu Nov 21 15:47:25 2019] wlan0 Link encap:Ethernet HWaddr 70:54:B4:A2:94:7A
[Thu Nov 21 15:47:25 2019] inet addr:192.168.2.148 Bcast:192.168.2.255 Mask:255.255.255.0
[Thu Nov 21 15:47:25 2019] inet6 addr: fe80::7254:b4ff:fea2:947a%763612/64 Scope:Link
[Thu Nov 21 15:47:25 2019] RX packets:30888 errors:0 dropped:1 overruns:0 frame:0
[Thu Nov 21 15:47:25 2019] TX packets:872 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:47:25 2019] RX bytes:3616395 (3.4 MiB) TX bytes:88515 (86.4 KiB)
[Thu Nov 21 15:47:25 2019] wwan0 Link encap:Ethernet HWaddr 2E:4C:2A:B2:8E:0A
[Thu Nov 21 15:47:25 2019] inet6 addr: fe80::2c4c:2aff:feb2:8e0a%763612/64 Scope:Link
[Thu Nov 21 15:47:25 2019] UP BROADCAST RUNNING NOARP MULTICAST MTU:1500 Metric:1
[Thu Nov 21 15:47:25 2019] RX packets:480 errors:0 dropped:0 overruns:0 frame:0
[Thu Nov 21 15:47:25 2019] TX packets:622 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:47:25 2019] RX bytes:42974 (41.9 KiB) TX bytes:65901 (64.3 KiB)
[Thu Nov 21 15:47:25 2019] root@am335x-evmsk:~# ifconfig wwan0 down
[Thu Nov 21 15:47:40 2019] root@am335x-evmsk:~# ifconfig wwan0 down up
[Thu Nov 21 15:47:44 2019] root@am335x-evmsk:~#
[Thu Nov 21 15:47:45 2019] root@am335x-evmsk:~#
[Thu Nov 21 15:47:45 2019] root@am335x-evmsk:~# ifconfig wwan0 updown
[Thu Nov 21 15:47:47 2019] eth0 Link encap:Ethernet HWaddr 18:62:E4:E7:4A:80
[Thu Nov 21 15:47:47 2019] inet addr:192.168.0.10 Bcast:192.168.0.255 Mask:255.255.255.0
[Thu Nov 21 15:47:47 2019] inet6 addr: fe80::1a62:e4ff:fee7:4a80%763612/64 Scope:Link
[Thu Nov 21 15:47:47 2019] UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
[Thu Nov 21 15:47:47 2019] RX packets:719 errors:0 dropped:0 overruns:0 frame:0
[Thu Nov 21 15:47:47 2019] TX packets:88 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:47:47 2019] collisions:0 txqueuelen:1000
[Thu Nov 21 15:47:47 2019] RX bytes:47720 (46.6 KiB) TX bytes:11669 (11.3 KiB)
[Thu Nov 21 15:47:47 2019] Interrupt:49
[Thu Nov 21 15:47:47 2019] lo Link encap:Local Loopback
[Thu Nov 21 15:47:47 2019] inet addr:127.0.0.1 Mask:255.0.0.0
[Thu Nov 21 15:47:47 2019] inet6 addr: ::1%763612/128 Scope:Host
[Thu Nov 21 15:47:47 2019] UP LOOPBACK RUNNING MTU:65536 Metric:1
[Thu Nov 21 15:47:47 2019] RX packets:57 errors:0 dropped:0 overruns:0 frame:0
[Thu Nov 21 15:47:47 2019] TX packets:57 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:47:47 2019] RX bytes:4929 (4.8 KiB) TX bytes:4929 (4.8 KiB)
[Thu Nov 21 15:47:47 2019] wlan0 Link encap:Ethernet HWaddr 70:54:B4:A2:94:7A
[Thu Nov 21 15:47:47 2019] inet addr:192.168.2.148 Bcast:192.168.2.255 Mask:255.255.255.0
[Thu Nov 21 15:47:47 2019] inet6 addr: fe80::7254:b4ff:fea2:947a%763612/64 Scope:Link
[Thu Nov 21 15:47:47 2019] RX packets:31205 errors:0 dropped:1 overruns:0 frame:0
[Thu Nov 21 15:47:47 2019] TX packets:884 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:47:47 2019] RX bytes:3664239 (3.4 MiB) TX bytes:89522 (87.4 KiB)
[Thu Nov 21 15:47:47 2019] wwan0 Link encap:Ethernet HWaddr 2E:4C:2A:B2:8E:0A
[Thu Nov 21 15:47:47 2019] inet6 addr: fe80::2c4c:2aff:feb2:8e0a%763612/64 Scope:Link
[Thu Nov 21 15:47:47 2019] UP BROADCAST RUNNING NOARP MULTICAST MTU:1500 Metric:1
[Thu Nov 21 15:47:47 2019] RX packets:480 errors:0 dropped:0 overruns:0 frame:0
[Thu Nov 21 15:47:47 2019] TX packets:637 errors:0 dropped:0 overruns:0 carrier:0
[Thu Nov 21 15:47:47 2019] RX bytes:42974 (41.9 KiB) TX bytes:67796 (66.2 KiB)
[Thu Nov 21 15:47:47 2019] root@am335x-evmsk:~#
Zafer Çalışkan
