Other Parts Discussed in Thread: TDA4VM, DP83867E
Actually, it is question about Ethernet PHY(DP83867ERGZ) and TDA4VM.
I have three qestions about RGMII RX signal (this signal goes to TDA4VM from ethernet PHY, DP83867E) of MCU ethernet PHY.
1. We have measured MCU ethernet RX signal, and this PHY signal is very unclean.
Q) We can't upload the graph of rx signal measured, so could you please share EVM's MCU ethernet RX signal if you have?
2. We normally change the RX signal strength using damping resistors.
Q) Could we change the RX signal strength by changing the register of PHY?
3. We try to change the internal CLK delay, when we measured the 1G ethernet.
Q) When we set the internal CLK delay as 2ns, this quality is not good. But, we set the internal CLK delay as 2.25ns or 2.5ns, the quallity is good.
Is it normal? We think the margin is not enough.
Please give me the commnets about the above questions.
Manwoo Kim
