Part Number: AM5708
Hi everyone
During the test recently, it was found that the video dropped frames was very serious.
Looking through the debug serial port, I found the following information:
[ 201.419164] remoteproc remoteproc1: handling crash #18 in 55020000.ipu
[ 201.427722] remoteproc remoteproc1: recovering 55020000.ipu
[ 201.481867] remoteproc remoteproc1: stopped remote processor 55020000.ipu
[ 201.494440] remoteproc remoteproc1: powering up 55020000.ipu
[ 201.518999] remoteproc remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3743096
[ 201.529345] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[ 201.698886] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 201.707912] remoteproc remoteproc1: registered virtio0 (type 7)
[ 201.733915] remoteproc remoteproc1: remote processor 55020000.ipu is now up
[ 201.748807] prueth pruss2_eth: pruss MC Mask 0:0:0:0:0:0
[ 201.764263] prueth pruss2_eth: port 1: using random MAC addr: d6:eb:51:01:cf:2f
[ 211.702792] remoteproc remoteproc1: crash detected in 55020000.ipu: type watchdog
[ 211.710361] remoteproc remoteproc1: handling crash #19 in 55020000.ipu
[ 211.718256] remoteproc remoteproc1: recovering 55020000.ipu
[ 211.773069] remoteproc remoteproc1: stopped remote processor 55020000.ipu
[ 211.786397] remoteproc remoteproc1: powering up 55020000.ipu
[ 211.812596] remoteproc remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3743096
[ 211.829385] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[ 211.994069] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 212.000711] remoteproc remoteproc1: registered virtio0 (type 7)
[ 212.029830] remoteproc remoteproc1: remote processor 55020000.ipu is now up
[ 212.047842] prueth pruss2_eth: pruss MC Mask 0:0:0:0:0:0
[ 212.060836] prueth pruss2_eth: port 1: using random MAC addr: 56:97:c2:a8:a8:f9
[ 221.996304] remoteproc remoteproc1: crash detected in 55020000.ipu: type watchdog
[ 222.004052] remoteproc remoteproc1: handling crash #20 in 55020000.ipu
root@AM57xx-Tronlong:~# [ 222.017200] remoteproc remoteproc1: recovering 55020000.ipu
[ 222.066549] remoteproc remoteproc1: stopped remote processor 55020000.ipu
[ 222.078790] remoteproc remoteproc1: powering up 55020000.ipu
[ 222.106811] remoteproc remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 3743096
[ 222.123257] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
The above information has been printed frequently.
Recalling the recent changes, mainly the related settings of spi were modified in the device tree.
&mcspi1 {
status = "okay";
pinctrl-names = "default";
pinctrl-0 = <&spi1_pins_default>;
ti,pindir-d0-out-d1-in;
spi1@0 {
#address-cells = <1>;
#size-cells = <0>;
compatible = "spidev";
reg = <0>;
spi-max-frequency = <50000000>;
spi-cpha;
I don't have much experience with the device tree, please help check it out. Thanks.
* Copyright (C) 2015 GuangZhou Tronlong co., LTD - http://www.tronlong.com
* This program is free software; you can redistribute it and/or modify
* it under the terms of the GNU General Public License version 2 as
* published by the Free Software Foundation.
#include "am57xx-evm-common.dtsi"
model = "TI AM5718 IDK";
compatible = "ti,am5718-idk", "ti,am5718", "ti,dra7";
aliases {
rtc0 = &ds1340;
//ethernet2 = &pruss2_emac0;
//ethernet3 = &pruss2_emac1;
ocp {
cal: cal@4845b000 {
compatible = "ti,dra72-cal";
ti,hwmods = "cal";
reg = <0x4845B000 0x400>,
<0x4845B800 0x40>,
<0x4845B900 0x40>;
reg-names = "cal_top",
"cal_rx_core0",
"cal_rx_core1";
interrupts = <GIC_SPI 119 IRQ_TYPE_LEVEL_HIGH>;
syscon-camerrx = <&scm_conf 0xE94>;
#size-cells = <0>;
status = "disabled";
ports {
#size-cells = <0>;
csi2_0: port@0 {
reg = <0>;
csi2_1: port@1 {
reg = <1>;
mclk: master_clock {
compatible = "fixed-clock";
#clock-cells = <0>;
clock-frequency = <24000000>;
clock-output-names = "mclk";
leds {
pinctrl-0 = <&leds_pins_default>;
compatible = "gpio-leds";
led0 {
label = "tl570x:green:heartbeat";
gpios = <&gpio8 30 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "heartbeat";
default-state = "off";
led1 {
label = "tl570x:green:cpu0";
gpios = <&gpio8 31 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "cpu0";
led2 {
label = "user-led0";
gpios = <&gpio4 4 GPIO_ACTIVE_HIGH>;
default-state = "on";
gpio_keys {
compatible = "gpio-keys";
pinctrl-0 = <&keys_pins_default>;
#size-cells = <0>;
autorepeat;
USER1 {
label = "user-key0";
linux,code = <KEY_PROG1>;
gpios = <&gpio4 5 GPIO_ACTIVE_LOW>;
USER2 {
label = "user-key1";
linux,code = <KEY_PROG2>;
gpios = <&gpio6 20 GPIO_ACTIVE_LOW>;
sound0: sound0 {
compatible = "simple-audio-card";
simple-audio-card,name = "TL570x EVM";
simple-audio-card,widgets =
"Line", "Line Out",
"Microphone", "Mic Jack",
"Line", "Line In";
simple-audio-card,routing =
"Line Out", "LLOUT",
"Line Out", "RLOUT",
"MIC3L", "Mic Jack",
"MIC3R", "Mic Jack",
"Mic Jack", "Mic Bias",
"LINE1L", "Line In",
"LINE1R", "Line In";
simple-audio-card,format = "dsp_b";
simple-audio-card,bitclock-master = <&sound0_master>;
simple-audio-card,frame-master = <&sound0_master>;
simple-audio-card,bitclock-inversion;
simple-audio-card,cpu {
sound-dai = <&mcasp8>;
sound0_master: simple-audio-card,codec {
sound-dai = <&tlv320aic3106>;
clocks = <&clkout2_clk>;
extcon_usb2_0: extcon_usb2_0 {
compatible = "linux,extcon-usb-gpio";
ti,enable-id-detection;
id-gpio = <&gpio3 28 GPIO_ACTIVE_HIGH>;
#if 0
/* Dual-MAC Ethernet application node on PRU-ICSS2 */
pruss2_eth: pruss2_eth {
compatible = "ti,am57-prueth";
pruss = <&pruss2>;
sram = <&ocmcram1>;
interrupt-parent = <&pruss2_intc>;
/*rx-queue-size = /bits/ 16 <254 134 134 254 48>;*/ /* RED */
/*rx-queue-size = /bits/ 16 <194 194 194 194 48>;*/ /* EMAC */
/* map is lowpcp-to->hipcp where val 3=q4, 2=q3, 1=q2, 0=q1 */
/*pcp-rxq-map = /bits/ 8 <3 3 2 2 1 1 0 0>;*/
pruss2_emac0: ethernet-mii0 {
phy-handle = <&pruss2_eth0_phy>;
phy-mode = "mii";
interrupts = <20>, <22>, <23>;
interrupt-names = "rx", "tx", "ptp_tx";
/* Filled in by bootloader */
local-mac-address = [00 00 00 00 00 00];
/*tx-queue-size = /bits/ 16 <97 97 97 97 48>;*/
pruss2_emac1: ethernet-mii1 {
phy-handle = <&pruss2_eth1_phy>;
phy-mode = "mii";
interrupts = <21>, <23>, <24>;
#endif
ptp_bc: ptp_bc {
compatible = "ti,am57-bc";
pwm_timer4: dmtimer-pwm@4 {
pinctrl-0 = <&pwm_fan_pins_default>;
compatible = "ti,omap-dmtimer-pwm";
ti,timers = <&timer4>;
#pwm-cells = <3>;
ti,prescaler = <7>;
ti,clock-source = <0x00>;
pwm_fan: pwm_fan {
compatible = "pwm-fan";
cooling-min-state = <0>;
cooling-max-state = <3>;
#cooling-cells = <2>;
pwms = <&pwm_timer4 0 10000 0>;
cooling-levels = <102 153 204 250>;
&dra7_pmx_core {
pinctrl-0 = <&watchdog_pins_default &usb2_pins_default>;
watchdog_pins_default: watchdog_pins_default {
pinctrl-single,pins = <
DRA7XX_CORE_IOPAD(0x3690, PIN_OUTPUT_PULLDOWN | MUX_MODE14) /* gpio6_16.gpio6_16 */
DRA7XX_CORE_IOPAD(0x364c, PIN_OUTPUT_PULLUP | MUX_MODE14) /* uart3_txd.gpio5_19 */
usb2_pins_default: usb2_pins_default {
DRA7XX_CORE_IOPAD(0x3554, PIN_INPUT_PULLUP | MUX_MODE14) /* vin2a_clk0.gpio3_28 */
DRA7XX_CORE_IOPAD(0x3684, PIN_OUTPUT_PULLUP | MUX_MODE0) /* usb2_drvvbus.usb2_drvvbus */
leds_pins_default: leds_pins_default {
//DRA7XX_CORE_IOPAD(0x3848, (PIN_OUTPUT | MUX_MODE14)) /* emu0.gpio8_30 (som led1) C21 */
//DRA7XX_CORE_IOPAD(0x384c, (PIN_OUTPUT | MUX_MODE14)) /* emu1.gpio8_31 (som led1) C22 */
//DRA7XX_CORE_IOPAD(0x3574, (PIN_OUTPUT | MUX_MODE14)) /* vin2a_d3.gpio4_4 (user led1) A9 */
//DRA7XX_CORE_IOPAD(0x36BC, (PIN_OUTPUT | MUX_MODE14)) /* mcasp1_axr2.gpio5_4 (user led2) C14 */
//DRA7XX_CORE_IOPAD(0x36C0, (PIN_OUTPUT | MUX_MODE14)) /* mcasp1_axr3.gpio5_5 (user led3) B15 */
keys_pins_default: keys_pins_default {
//DRA7XX_CORE_IOPAD(0x3578, PIN_INPUT_PULLUP | MUX_MODE14) /* vin2a_d4.gpio4_5 */
//DRA7XX_CORE_IOPAD(0x36A0, PIN_INPUT_PULLUP | MUX_MODE14) /* xref_clk3.gpio6_25 */
//DRA7XX_CORE_IOPAD(0x36A0, PIN_INPUT_PULLUP | MUX_MODE14) /* xref_clk3.gpio6_20 */
DRA7XX_CORE_IOPAD(0x36BC, (PIN_INPUT_PULLUP | MUX_MODE14)) /* mcasp1_axr2.gpio5_4 */
DRA7XX_CORE_IOPAD(0x36C0, (PIN_INPUT_PULLUP | MUX_MODE14)) /* mcasp1_axr3.gpio5_5 */
#if 0
ehrpwm0_pins: ehrpwm0_pins {
DRA7XX_CORE_IOPAD(0x3780, (PIN_OUTPUT | MUX_MODE10)) /* mmc3_cmd.eCAP2_in_PWM2_out */
#endif
ehrpwm1_pins: ehrpwm1_pins {
lcd_pins_default: lcd_pins_default {
DRA7XX_CORE_IOPAD(0x35c4, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vin2a_d23.vout2_d0 */
DRA7XX_CORE_IOPAD(0x35c0, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vin2a_d22.vout2_d1 */
DRA7XX_CORE_IOPAD(0x35bc, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vin2a_d21.vout2_d2 */
DRA7XX_CORE_IOPAD(0x35b8, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vin2a_d20.vout2_d3 */
DRA7XX_CORE_IOPAD(0x35b4, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vin2a_d19.vout2_d4 */
DRA7XX_CORE_IOPAD(0x35b0, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vin2a_d18.vout2_d5 */
DRA7XX_CORE_IOPAD(0x35ac, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vin2a_d17.vout2_d6 */
DRA7XX_CORE_IOPAD(0x35a8, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vin2a_d16.vout2_d7 */
DRA7XX_CORE_IOPAD(0x35a4, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vin2a_d15.vout2_d8 */
DRA7XX_CORE_IOPAD(0x35a0, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vin2a_d14.vout2_d9 */
DRA7XX_CORE_IOPAD(0x359c, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vin2a_d13.vout2_d10 */
DRA7XX_CORE_IOPAD(0x3598, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vin2a_d12.vout2_d11 */
DRA7XX_CORE_IOPAD(0x3594, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vin2a_d11.vout2_d12 */
DRA7XX_CORE_IOPAD(0x3590, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vin2a_d10.vout2_d13 */
DRA7XX_CORE_IOPAD(0x358c, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vin2a_d9.vout2_d14 */
DRA7XX_CORE_IOPAD(0x3588, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vin2a_d8.vout2_d15 */
DRA7XX_CORE_IOPAD(0x3584, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vout2_d16 */
DRA7XX_CORE_IOPAD(0x3580, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vout2_d17 */
DRA7XX_CORE_IOPAD(0x357c, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vout2_d18 */
DRA7XX_CORE_IOPAD(0x3578, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vout2_d19 */
DRA7XX_CORE_IOPAD(0x3574, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vout2_d20 */
DRA7XX_CORE_IOPAD(0x3570, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vout2_d21 */
DRA7XX_CORE_IOPAD(0x356c, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vout2_d22 */
DRA7XX_CORE_IOPAD(0x3568, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vout2_d23 */
DRA7XX_CORE_IOPAD(0x3558, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vin2a_de0.vout2_de */
DRA7XX_CORE_IOPAD(0x355c, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vin2a_fld0.vout2_clk */
DRA7XX_CORE_IOPAD(0x3560, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vin2a_hsync0.vout2_hsync */
DRA7XX_CORE_IOPAD(0x3564, (PIN_INPUT_PULLDOWN | MUX_MODE4)) /* vin2a_vsync0.vout2_vsync */
ads7846_pins_default: ads7846_pins_default {
DRA7XX_CORE_IOPAD(0x3770, (PIN_INPUT_PULLUP | MUX_MODE14)) /* mmc1_sdwp.gpio6_28 */
spi1_pins_default: spi1_pins_default {
DRA7XX_CORE_IOPAD(0x37a4, (PIN_OUTPUT | MUX_MODE0)) /* spi1_sclk.spi1_sclk (C24) */
DRA7XX_CORE_IOPAD(0x37a8, (INPUT_EN | MUX_MODE0)) /* spi1_d1.spi1_d1 (D24) */
DRA7XX_CORE_IOPAD(0x37ac, (PIN_OUTPUT | MUX_MODE0)) /* spi1_d0.spi1_d0 (D25) */
DRA7XX_CORE_IOPAD(0x37b0, (PIN_OUTPUT | MUX_MODE0)) /* spi1_cs0.spi1_cs0 (B24) */
i2c4_pins_default: i2c4_pins_default {
DRA7XX_CORE_IOPAD(0x36ac, (PIN_INPUT_PULLUP | MUX_MODE10)) /* mcasp1_aclkr.i2c4_sda */
DRA7XX_CORE_IOPAD(0x36b0, (PIN_INPUT_PULLUP | MUX_MODE10)) /* mcasp1_fsr.i2c4_scl */
mcasp8_pins_default: mcasp8_pins_default {
DRA7XX_CORE_IOPAD(0x371c, (PIN_INPUT_PULLDOWN | MUX_MODE1)) /* mcasp2_axr6.mcsap8_aclkx */
DRA7XX_CORE_IOPAD(0x3720, (PIN_INPUT_PULLDOWN | MUX_MODE1)) /* mcasp2_axr7.mcsap8_fsx */
DRA7XX_CORE_IOPAD(0x3714, (PIN_INPUT_PULLDOWN | MUX_MODE1)) /* mcasp2_axr4.mcsap8_axr0 */
DRA7XX_CORE_IOPAD(0x3718, (PIN_OUTPUT_PULLDOWN | MUX_MODE1)) /* mcasp2_axr5.mcsap8_axr1 */
dcan2_pins_default: dcan2_pins_default {
DRA7XX_CORE_IOPAD(0x3688, (PIN_INPUT_PULLUP | MUX_MODE2)) /* dcan2_tx.tx */
DRA7XX_CORE_IOPAD(0x368c, (PIN_INPUT_PULLUP | MUX_MODE2)) /* dcan2_rx.rx */
pru2_mii_pins_default: pru2_mii_pins_default {
#if 0
DRA7XX_CORE_IOPAD(0x36b8, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mcasp1_axr1.pr2_mii_mt0_clk (F12)*/
DRA7XX_CORE_IOPAD(0x36d4, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mcasp1_axr8.pr2_mii0_txen (B12) */
DRA7XX_CORE_IOPAD(0x36e4, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mcasp1_axr12.pr2_mii0_txd0 (E14) */
DRA7XX_CORE_IOPAD(0x36e0, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mcasp1_axr11.pr2_mii0_txd1 (A12) */
DRA7XX_CORE_IOPAD(0x36dc, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mcasp1_axr10.pr2_mii0_txd2 (B13) */
DRA7XX_CORE_IOPAD(0x36d8, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mcasp1_axr9.pr2_mii0_txd3 (A11) */
DRA7XX_CORE_IOPAD(0x36e8, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mcasp1_axr13.pr2_mii_mr0_clk (A13) */
DRA7XX_CORE_IOPAD(0x36ec, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mcasp1_axr14.pr2_mii0_rxdv (G14) */
DRA7XX_CORE_IOPAD(0x36b4, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mcasp1_axr0.pr2_mii0_rxer (G12) */
DRA7XX_CORE_IOPAD(0x3724, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mcasp3_aclkx.pr2_mii0_crs (B18) */
DRA7XX_CORE_IOPAD(0x3728, (PIN_INPUT_PULLUP | MUX_MODE11)) /* mcasp3_fsx.pr2_mii0_col (F15) */
DRA7XX_CORE_IOPAD(0x3710, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mcasp2_axr3.pr2_mii0_rxlink (A16) */
DRA7XX_CORE_IOPAD(0x370c, (PIN_INPUT_PULLUP | MUX_MODE11)) /* mcasp2_axr2.pr2_mii0_rxd0 (C15) */
DRA7XX_CORE_IOPAD(0x36f8, (PIN_INPUT_PULLUP | MUX_MODE11)) /* mcasp2_fsx.pr2_mii0_rxd1 (A18) */
DRA7XX_CORE_IOPAD(0x36f4, (PIN_INPUT_PULLUP | MUX_MODE11)) /* mcasp2_acllx.pr2_mii0_rxd2 (A19) */
DRA7XX_CORE_IOPAD(0x36f0, (PIN_INPUT_PULLUP | MUX_MODE11)) /* mcasp1_axr15.pr2_mii0_rxd3 (F14) */
DRA7XX_CORE_IOPAD(0x3774, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* gpio6_10.pr2_mii_mt1_clk (AC5) */
DRA7XX_CORE_IOPAD(0x3778, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* gpio6_11.pr2_mii1_txen (AB4) */
DRA7XX_CORE_IOPAD(0x377c, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mmc3_clk.pr2_mii1_txd3 (AD4) */
DRA7XX_CORE_IOPAD(0x3780, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mmc3_cmd.pr2_mii1_txd2 (AC4) */
DRA7XX_CORE_IOPAD(0x36a4, (PIN_INPUT_PULLUP | MUX_MODE11)) /* mcasp1_aclkx.pr2_mdio_mdclk (C14) */
DRA7XX_CORE_IOPAD(0x36a8, (PIN_INPUT_PULLUP | MUX_MODE11)) /* mcasp1_fsx.pr2_mdio_data (D14) */
DRA7XX_CORE_IOPAD(0x3784, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mmc3_dat0.pr2_mii1_txd1 (AC7) */
DRA7XX_CORE_IOPAD(0x3788, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* immc3_dat1.pr2_mii1_txd0 (AC6) */
DRA7XX_CORE_IOPAD(0x378c, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mmc3_dat2.pr2_mii_mr1_clk (AC9) */
DRA7XX_CORE_IOPAD(0x3790, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mmc3_dat3.pr2_mii1_rxdv (AC3) */
DRA7XX_CORE_IOPAD(0x3794, (PIN_INPUT_PULLUP | MUX_MODE11)) /* mmc3_dat4.pr2_mii1_rxd3 (AC8) */
DRA7XX_CORE_IOPAD(0x3798, (PIN_INPUT_PULLUP | MUX_MODE11)) /* mmc3_dat5.pr2_mii1_rxd2 (AD6) */
DRA7XX_CORE_IOPAD(0x379c, (PIN_INPUT_PULLUP | MUX_MODE11)) /* mmc3_dat6.pr2_mii1_rxd1 (AB8) */
DRA7XX_CORE_IOPAD(0x37a0, (PIN_INPUT_PULLUP | MUX_MODE11)) /* mmc3_dat7.pr2_mii1_rxd0 (AB5) */
DRA7XX_CORE_IOPAD(0x372c, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mcasp3_axr0.pr2_mii1_rxer (B19) */
DRA7XX_CORE_IOPAD(0x3730, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mcasp3_axr1.pr2_mii1_rxlink (C17) */
DRA7XX_CORE_IOPAD(0x3694, (PIN_INPUT_PULLUP | MUX_MODE11)) /* xref_clk0.pr2_mii1_col (D18) */
DRA7XX_CORE_IOPAD(0x3698, (PIN_INPUT_PULLDOWN | MUX_MODE11)) /* mcasp2_axr9.pr2_mii1_crs (E17) */
DRA7XX_CORE_IOPAD(0x357c, (PIN_INPUT_PULLUP | MUX_MODE14)) /* vin2a_d5.gpio4_6 */
DRA7XX_CORE_IOPAD(0x3580, (PIN_INPUT_PULLUP | MUX_MODE14)) /* vin2a_d6.gpio4_7 */
DRA7XX_CORE_IOPAD(0x3644, (PIN_OUTPUT_PULLUP | MUX_MODE14)) /* RMII_MHZ_50_CLK.gpio5_17 */
DRA7XX_CORE_IOPAD(0x3584, (PIN_OUTPUT_PULLUP | MUX_MODE14)) /* vin2a_d7.gpio4_8 */
#endif
uart2_pins_default: uart2_pins_default {
DRA7XX_CORE_IOPAD(0x37F4, (PIN_INPUT_PULLUP | MUX_MODE4)) /* uart2_txd.uart2_txd */
DRA7XX_CORE_IOPAD(0x37F0, (PIN_INPUT_PULLUP | MUX_MODE4)) /* uart2_rxd.uart2_rxd */
pwm_fan_pins_default: pwm_fan_pins_default {
DRA7XX_CORE_IOPAD(0x36D0, (PIN_OUTPUT_PULLUP | MUX_MODE10)) /* mcasp1_axr7.timer4 */
&i2c1 {
status = "okay";
tps659038: tps659038@58 {
status = "disbale";
lp8720@60 {
compatible = "ti,lp8720";
reg = <0x60>;
/* Enable BUCK1,2, no DVS, normal LDO mode, timestep is 256usec */
ti,general-config = /bits/ 8 <0xdd>;
ti,update-config;
vcam_io_1: ldo1 {
regulator-min-microvolt = <3300000>;
regulator-max-microvolt = <3300000>;
vcam_core_1: ldo2 {
lp8720@61 {
reg = <0x61>;
ti,update-config;
vcam_io_2: ldo1 {
regulator-min-microvolt = <1800000>;
regulator-max-microvolt = <1800000>;
vcam_core_2: ldo2 {
&i2c4 {
status = "okay";
clock-frequency = <400000>;
pinctrl-0 = <&i2c4_pins_default>;
ina220@40 {
compatible = "ti,ina220";
reg = <0x40>;
shunt-resistor = <18690>; /* tl570x-evm: Maximum Expected Current = 2 A,R_SHUNT = 20m ohm */
ina220@41 {
reg = <0x41>;
shunt-resistor = <18690>; /* som-tl570x: Maximum Expected Current = 3 A,R_SHUNT = 20m ohm */
ds1340: rtc@68 {
compatible = "dallas,ds1340";
reg = <0x68>;
trickle-resistor-ohms = <250>;
tlv320aic3106: tlv320aic3106@18 {
#sound-dai-cells = <0>;
compatible = "ti,tlv320aic3106";
reg = <0x18>;
status = "okay";
assigned-clocks = <&clkoutmux2_clk_mux>;
assigned-clock-parents = <&sys_clk2_dclk_div>;
adc-settle-ms = <40>;
/* Derived from VBAT: Baseboard 3.3V / 1.8V */
AVDD-supply = <&vdd_3v3>;
IOVDD-supply = <&vdd_3v3>;
DRVDD-supply = <&vdd_3v3>;
DVDD-supply = <&aic_dvdd>;
&mmc1 {
vmmc_aux-supply = <>;
pinctrl-0 = <&mmc1_pins_default>;
&mmc2 {
pinctrl-0 = <&mmc2_pins_default>;
&lcd0 {
pinctrl-0 = <&lcd_pins_default>;
enable-gpios = <>;
panel-timing {
clock-frequency = <68200000>;
hactive = <1280>;
vactive = <800>;
hfront-porch = <59>;
hback-porch = <5>;
hsync-len = <5>;
vback-porch = <2>;
vfront-porch = <35>;
vsync-len = <5>;
hsync-active = <0>;
vsync-active = <0>;
de-active = <1>;
pixelclk-active = <1>;
&lcd_in {
remote-endpoint = <&dpi_out_1>;
&lcd_bl {
pwms = <&ecap1 0 20000 0>;
brightness-levels = <0 10 50 100 130 160 180 200 220 240 255>;
default-brightness-level = <8>;
&vip1 {
status = "okay";
&mailbox5 {
status = "okay";
mbox_ipu1_ipc3x: mbox_ipu1_ipc3x {
status = "okay";
mbox_dsp1_ipc3x: mbox_dsp1_ipc3x {
status = "okay";
&mailbox6 {
status = "okay";
mbox_ipu2_ipc3x: mbox_ipu2_ipc3x {
status = "okay";
mbox_dsp2_ipc3x: mbox_dsp2_ipc3x {
status = "disable";
&mmu0_dsp1 {
status = "okay";
&mmu1_dsp1 {
status = "okay";
&mmu_ipu1 {
status = "okay";
&mmu_ipu2 {
status = "okay";
&ipu2 {
status = "okay";
memory-region = <&ipu2_cma_pool>;
mboxes = <&mailbox6 &mbox_ipu2_ipc3x>;
timers = <&timer3>;
watchdog-timers = <&timer12>, <&timer9>;
&ipu1 {
status = "okay";
memory-region = <&ipu1_cma_pool>;
mboxes = <&mailbox5 &mbox_ipu1_ipc3x>;
timers = <&timer11>;
watchdog-timers = <&timer7>, <&timer8>;
&dsp1 {
status = "okay";
memory-region = <&dsp1_cma_pool>;
mboxes = <&mailbox5 &mbox_dsp1_ipc3x>;
timers = <&timer5>;
watchdog-timers = <&timer10>;
&pcie1_rc {
status = "okay";
&pcie1_ep {
* To enable PCIe EP functionality, set the status of
* this node to "okay" and the status of pcie1_rc node
* above to "disabled".
status = "disable";
&pru2_0 {
ti,pruss-gp-mux-sel = <4>; /* MII2, needed for PRUSS1_MII0 */
&pru2_1 {
ti,pruss-gp-mux-sel = <4>; /* MII2, needed for PRUSS1_MII1 */
&epwmss0 {
status = "okay";
#if 0
&ecap0 {
status = "okay";
pinctrl-0 = <&ehrpwm0_pins>;
#endif
&ecap1 {
status = "okay";
pinctrl-0 = <&ehrpwm1_pins>;
&dss {
status = "okay";
vdda_video-supply = <>;
ports {
port@1 {
reg = <1>;
dpi_out_1: endpoint {
remote-endpoint = <&lcd_in>;
data-lines = <24>;
&mcspi1 {
status = "okay";
spi1@0 {
#size-cells = <0>;
reg = <0>;
spi-cpha;
#if 0
ads7846@0 {
pinctrl-0 = <&ads7846_pins_default>;
compatible = "ti,ads7846";
reg = <0>; /* CS0 */
spi-max-frequency = <1500000>;
interrupt-parent = <&gpio6>;
interrupts = <28 0>; /* gpio6_28 */
pendown-gpio = <&gpio6 28 0>;
ti,x-min = /bits/ 16 <0x0>;
ti,x-max = /bits/ 16 <0x0fff>;
ti,y-min = /bits/ 16 <0x0>;
ti,y-max = /bits/ 16 <0x0fff>;
ti,x-plate-ohms = /bits/ 16 <180>;
ti,pressure-max = /bits/ 16 <255>;
ti,debounce-max = /bits/ 16 <10>;
ti,debounce-tol = /bits/ 16 <30>;
ti,debounce-rep = /bits/ 16 <1>;
ti,settle-delay-usec = /bits/ 16 <150>;
ti,keep-vref-on = <1>;
linux,wakeup;
#endif
&mcasp8 {
status = "okay";
pinctrl-0 = <&mcasp8_pins_default>;
op-mode = <0>; /* MCASP_IIS_MODE */
tdm-slots = <2>;
/* 4 serializer */
serial-dir = < /* 0: INACTIVE, 1: TX, 2: RX */
2 1 0 0
tx-num-evt = <32>;
rx-num-evt = <32>;
&dcan2 {
status = "okay";
pinctrl-0 = <&dcan2_pins_default>;
&omap_dwc3_2 {
extcon = <&extcon_usb2_0>;
&usb2 {
dr_mode = "dual-role";
&pruss2_mdio {
status = "okay";
pinctrl-0 = <&pru2_mii_pins_default>;
reset-gpios = <&gpio5 17 GPIO_ACTIVE_LOW>,
<&gpio4 8 GPIO_ACTIVE_LOW>;
reset-delay-us = <2>; /* PHY datasheet states 1uS min */
pruss2_eth0_phy: ethernet-phy@0 {
reg = <0>;
interrupt-parent = <&gpio4>;
interrupts = <6 IRQ_TYPE_EDGE_FALLING>;
pruss2_eth1_phy: ethernet-phy@1 {
reg = <1>;
interrupts = <7 IRQ_TYPE_EDGE_FALLING>;
&qspi {
status = "disable";
&uart2 {
status = "okay";
pinctrl-0 = <&uart2_pins_default>;
&timer4 {
ti,timer-pwm;
&cpu_cooling_maps {
map1 {
trip = <&cpu_alert1>;
cooling-device = <&pwm_fan THERMAL_NO_LIMIT THERMAL_NO_LIMIT>;
&davinci_mdio {
status = "okay";
pinctrl-0 = <&rgmii0_pins_default>;
&rtc {
ti,hwmods = "";
&dsp2 {
&mmu0_dsp2 {
&mmu1_dsp2 {
&dsp2_cma_pool {
&dsp2dsp_shm {
&i2c5 {
&vdd_3v3 {
vin-supply = <>;
&aic_dvdd {
vin-supply = <>;
&vtt_fixed {
vin-supply = <>;
&cpu0 {
vdd-supply = <>;
&usb2_phy1 {
phy-supply = <>;
&usb2_phy2 {
phy-supply = <>;
&hdmi {
vdda-supply = <>;
&cmem_block_mem_1_ocmc3 {
&cmem_block_1 {
best regards
xiaoma
