Part Number: PROCESSOR-SDK-AM335X
Other Parts Discussed in Thread: AM3352, TPS65910, AM3354
We want to show images in panel and change the image every 5s. However, we always got kernel error messages after few minutes. We just write a simple script with the cat command or using ioctl to implement the function.
=========================Log==================================
U-Boot 2018.01 (Nov 28 2019 - 15:06:38 +0800)
CPU : AM335X-GP rev 2.1
Model: TI AM335x EVM
DRAM: 512 MiB
NAND: 2048 MiB
MMC: OMAP SD/MMC: 0
** Bad device mmc 0 **
Using default environment
<ethaddr> not set. Validating first E-fuse MAC
Net: Could not get PHY for cpsw: addr 0
cpsw, usb_ether
Hit any key to stop autoboot: 0
Booting from nand ...
NAND read: device 0 offset 0x200000, size 0x80000
524288 bytes read: OK
NAND read: device 0 offset 0x400000, size 0xa00000
10485760 bytes read: OK
NAND read: device 0 offset 0x1800000, size 0x1800000
Skipping bad block 0x02d00000
Skipping bad block 0x02d80000
25165824 bytes read: OK
## Flattened Device Tree blob at 80f80000
Booting using the fdt blob at 0x80f80000
Loading Device Tree to 9def8000, end 9df050a8 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.59 (jason@jason-vb) (gcc version 6.2.1 20161016 (Linaro GCC 6.2-2016.11) ) #18 PREEMPT Fri Nov 29 16:51:39 CST 2019
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt:Machine model: TI AM335x EVM
[ 0.000000] efi: Getting EFI parameters from FDT:
[ 0.000000] efi: UEFI not found.
[ 0.000000] cma: Reserved 48 MiB at 0x9a800000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (neon)
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129920
[ 0.000000] Kernel command line: console=ttyS0,115200n8 consoleblank=0 vt.global_cursor_default=0 mem=512M root=/dev/ram0 rw rootfstype=ext4 initrd=0x81000000,64M ramdisk_size=67108864
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 390300K/524288K available (9216K kernel code, 317K rwdata, 2704K rodata, 1024K init, 321K bss, 84836K reserved, 49152K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0a00000 (10208 kB)
[ 0.000000] .init : 0xc0d00000 - 0xc0e00000 (1024 kB)
[ 0.000000] .data : 0xc0e00000 - 0xc0e4f4c0 ( 318 kB)
[ 0.000000] .bss : 0xc0e4f4c0 - 0xc0e9fad4 ( 322 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000019] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000047] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000060] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000295] clocksource_probe: no matching clocksources found
[ 0.000507] Console: colour dummy device 80x30
[ 0.000557] Calibrating delay loop... 597.60 BogoMIPS (lpj=2988032)
[ 0.118785] pid_max: default: 32768 minimum: 301
[ 0.118954] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.118969] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.120016] CPU: Testing write buffer coherency: ok
[ 0.120479] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.121582] EFI services will not be available.
[ 0.123403] devtmpfs: initialized
[ 0.140611] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.141053] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.141085] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.145651] pinctrl core: initialized pinctrl subsystem
[ 0.147285] NET: Registered protocol family 16
[ 0.150118] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.169925] omap_hwmod: debugss: _wait_target_disable failed
[ 0.248791] cpuidle: using governor ladder
[ 0.278777] cpuidle: using governor menu
[ 0.287240] OMAP GPIO hardware version 0.1
[ 0.307593] omap-gpmc 50000000.gpmc: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/nandflash_pins_default, deferring probe
[ 0.310560] No ATAGs?
[ 0.310587] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.360244] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.365444] SCSI subsystem initialized
[ 0.365837] usbcore: registered new interface driver usbfs
[ 0.365927] usbcore: registered new interface driver hub
[ 0.366062] usbcore: registered new device driver usb
[ 0.366597] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/i2c0_pins_default, deferring probe
[ 0.366769] media: Linux media interface: v0.10
[ 0.366845] Linux video capture interface: v2.00
[ 0.366901] pps_core: LinuxPPS API ver. 1 registered
[ 0.366912] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.366943] PTP clock support registered
[ 0.366993] EDAC MC: Ver: 3.0.0
[ 0.368366] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.369646] Bluetooth: Core ver 2.22
[ 0.369721] NET: Registered protocol family 31
[ 0.369735] Bluetooth: HCI device and connection manager initialized
[ 0.369757] Bluetooth: HCI socket layer initialized
[ 0.369774] Bluetooth: L2CAP socket layer initialized
[ 0.369817] Bluetooth: SCO socket layer initialized
[ 0.371046] nfc: nfc_init: NFC Core ver 0.1
[ 0.371133] NET: Registered protocol family 39
[ 0.371669] clocksource: Switched to clocksource timer1
[ 0.385924] NET: Registered protocol family 2
[ 0.386914] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.386989] TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.387051] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.387141] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.387166] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.387342] NET: Registered protocol family 1
[ 0.388071] Trying to unpack rootfs image as initramfs...
[ 0.389105] rootfs image is not initramfs (no cpio magic); looks like an initrd
[ 0.928928] Freeing initrd memory: 65536K
[ 0.929670] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 0.933303] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.944056] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.944460] jffs2: version 2.2. (NAND) (SUMMARY) c 2001-2006 Red Hat, Inc.
[ 0.951860] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.951890] io scheduler noop registered
[ 0.951901] io scheduler deadline registered
[ 0.952107] io scheduler cfq registered (default)
[ 0.954066] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.958454] backlight supply power not found, using dummy regulator
[ 1.042621] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 1.047914] console [ttyS0] disabled
[ 1.048034] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 158, base_baud = 3000000) is a 8250
[ 1.675317] console [ttyS0] enabled
[ 1.680279] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 159, base_baud = 3000000) is a 8250
[ 1.690523] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 160, base_baud = 3000000) is a 8250
[ 1.700672] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 161, base_baud = 3000000) is a 8250
[ 1.710805] 481aa000.serial: ttyS5 at MMIO 0x481aa000 (irq = 162, base_baud = 3000000) is a 8250
[ 1.722182] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[ 1.728992] [drm] Initialized
[ 1.732791] panel panel: found backlight
[ 1.738100] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.744844] [drm] No driver support for vblank timestamp query.
[ 1.781175] Console: switching to colour frame buffer device 100x30
[ 1.795154] tilcdc 4830e000.lcdc: fb0: frame buffer device
[ 1.824768] brd: module loaded
[ 1.836785] loop: module loaded
[ 1.843024] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 1.853145] libphy: Fixed MDIO Bus: probed
[ 1.858887] CAN device driver interface
[ 1.864487] c_can_platform 481cc000.can: c_can_platform device registered (regs=fa1cc000, irq=166)
[ 1.874734] c_can_platform 481d0000.can: c_can_platform device registered (regs=fa1d0000, irq=167)
[ 1.951729] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 1.957914] davinci_mdio 4a101000.mdio: detected phy mask 3f3f3f01
[ 1.972588] libphy: 4a101000.mdio: probed
[ 1.976651] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver unknown
[ 1.984797] davinci_mdio 4a101000.mdio: phy[2]: device 4a101000.mdio:02, driver unknown
[ 1.993125] davinci_mdio 4a101000.mdio: phy[3]: device 4a101000.mdio:03, driver unknown
[ 2.001217] davinci_mdio 4a101000.mdio: phy[4]: device 4a101000.mdio:04, driver unknown
[ 2.009323] davinci_mdio 4a101000.mdio: phy[5]: device 4a101000.mdio:05, driver unknown
[ 2.017451] davinci_mdio 4a101000.mdio: phy[6]: device 4a101000.mdio:06, driver unknown
[ 2.025521] davinci_mdio 4a101000.mdio: phy[7]: device 4a101000.mdio:07, driver unknown
[ 2.033613] davinci_mdio 4a101000.mdio: phy[14]: device 4a101000.mdio:0e, driver unknown
[ 2.041766] davinci_mdio 4a101000.mdio: phy[15]: device 4a101000.mdio:0f, driver unknown
[ 2.049926] davinci_mdio 4a101000.mdio: phy[22]: device 4a101000.mdio:16, driver unknown
[ 2.058078] davinci_mdio 4a101000.mdio: phy[23]: device 4a101000.mdio:17, driver unknown
[ 2.066256] davinci_mdio 4a101000.mdio: phy[30]: device 4a101000.mdio:1e, driver unknown
[ 2.074491] davinci_mdio 4a101000.mdio: phy[31]: device 4a101000.mdio:1f, driver unknown
[ 2.083645] cpsw 4a100000.ethernet: Missing dual_emac_res_vlan in DT.
[ 2.090135] cpsw 4a100000.ethernet: Using 1 as Reserved VLAN for 0 slave
[ 2.097100] cpsw 4a100000.ethernet: Missing dual_emac_res_vlan in DT.
[ 2.103611] cpsw 4a100000.ethernet: Using 2 as Reserved VLAN for 1 slave
[ 2.110391] cpsw 4a100000.ethernet: Detected MACID = 78:04:73:2a:83:66
[ 2.117154] cpsw 4a100000.ethernet: device node lookup for pps timer failed
[ 2.124272] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies)
[ 2.133002] cpsw 4a100000.ethernet: cpsw: Detected MACID = 78:04:73:2a:83:68
[ 2.141950] PPP generic driver version 2.4.2
[ 2.146643] PPP BSD Compression module registered
[ 2.151442] PPP Deflate Compression module registered
[ 2.156591] PPP MPPE Compression module registered
[ 2.161409] NET: Registered protocol family 24
[ 2.166058] usbcore: registered new interface driver cdc_ether
[ 2.172107] usbcore: registered new interface driver rndis_host
[ 2.178894] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.185586] ehci-pci: EHCI PCI platform driver
[ 2.190173] ehci-platform: EHCI generic platform driver
[ 2.195746] ehci-omap: OMAP-EHCI Host Controller driver
[ 2.201825] usbcore: registered new interface driver cdc_acm
[ 2.207515] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 2.215697] usbcore: registered new interface driver cdc_wdm
[ 2.221438] usbcore: registered new interface driver usbtmc
[ 2.227191] usbcore: registered new interface driver usb-storage
[ 2.233314] usbcore: registered new interface driver ums-sddr09
[ 2.239309] usbcore: registered new interface driver ums-sddr55
[ 2.245366] usbcore: registered new interface driver ums-usbat
[ 2.251373] usbcore: registered new interface driver usbserial
[ 2.257367] usbcore: registered new interface driver usbserial_generic
[ 2.264005] usbserial: USB Serial support registered for generic
[ 2.270088] usbcore: registered new interface driver ftdi_sio
[ 2.275970] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2.283388] usbcore: registered new interface driver ipw
[ 2.288807] usbserial: USB Serial support registered for IPWireless converter
[ 2.296058] usbcore: registered new interface driver option
[ 2.301728] usbserial: USB Serial support registered for GSM modem (1-port)
[ 2.308807] usbcore: registered new interface driver pl2303
[ 2.314427] random: fast init done
[ 2.317928] usbserial: USB Serial support registered for pl2303
[ 2.323949] usbcore: registered new interface driver qcserial
[ 2.329767] usbserial: USB Serial support registered for Qualcomm USB modem
[ 2.339431] 47401300.usb-phy supply vcc not found, using dummy regulator
[ 2.352058] 47401b00.usb-phy supply vcc not found, using dummy regulator
[ 2.372750] mousedev: PS/2 mouse device common for all mice
[ 2.378921] i2c /dev entries driver
[ 2.385154] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 2.403935] ISDN subsystem Rev: 1.1.2.3/[ 2.407734] 1.1.2.2/
1.1.2.3/[ 2.410742] none/
1.1.2.2[ 2.413352]
[ 2.414990] Modular ISDN core version 1.1.29
[ 2.419606] NET: Registered protocol family 34
[ 2.424163] gigaset: Driver for Gigaset 307x
[ 2.428455] gigaset: Kernel CAPI interface
[ 2.433974] cpuidle: enable-method property 'ti,am3352' found operations
[ 2.441577] sdhci: Secure Digital Host Controller Interface driver
[ 2.447878] sdhci: Copyright(c) Pierre Ossman
[ 2.453649] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 2.459778] Synopsys Designware Multimedia Card Interface Driver
[ 2.466808] VUB300 Driver rom wait states = 1C irqpoll timeout = 0400[ 2.473871] usbcore: registered new interface driver vub300
[ 2.479561] usbcore: registered new interface driver ushc
[ 2.485529] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.492077] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.498412] usbcore: registered new interface driver usbhid
[ 2.504126] usbhid: USB HID core driver
[ 2.509923] Netfilter messages via NETLINK v0.30.
[ 2.514877] ip_set: protocol 6
[ 2.518248] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.523643] Initializing XFRM netlink socket
[ 2.528600] NET: Registered protocol family 10
[ 2.535108] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 2.540550] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 2.547748] NET: Registered protocol family 17
[ 2.552357] NET: Registered protocol family 15
[ 2.556907] Bridge firewalling registered
[ 2.560999] Ebtables v2.0 registered
[ 2.564623] can: controller area network core (rev 20120528 abi 9)
[ 2.570932] NET: Registered protocol family 29
[ 2.575506] can: raw protocol (rev 20120528)
[ 2.579799] can: broadcast manager protocol (rev 20161123 t)
[ 2.585522] can: netlink gateway (rev 20130117) max_hops=1
[ 2.591568] NET: Registered protocol family 36
[ 2.596184] Key type dns_resolver registered
[ 2.600790] omap_voltage_late_init: Voltage driver support not added
[ 2.614928] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[ 2.620258] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[ 2.628923] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0x48
[ 2.635533] nand: Micron MT29F16G08ABACAWP
[ 2.639661] nand: 2048 MiB, SLC, erase size: 512 KiB, page size: 4096, OOB size: 224
[ 2.647513] using OMAP_ECC_BCH16_CODE_HW ECC scheme
[ 2.652650] 15 ofpart partitions found on MTD device omap2-nand.0
[ 2.658775] Creating 15 MTD partitions on "omap2-nand.0":
[ 2.664260] 0x000000000000-0x000000080000 : "NAND.SPL"
[ 2.671425] 0x000000080000-0x000000100000 : "NAND.SPL.backup1"
[ 2.679053] 0x000000100000-0x000000180000 : "NAND.SPL.backup2"
[ 2.686563] 0x000000180000-0x000000200000 : "NAND.SPL.backup3"
[ 2.694007] 0x000000200000-0x000000280000 : "NAND.kernel-fdt"
[ 2.701346] 0x000000280000-0x000000380000 : "NAND.u-boot"
[ 2.708430] 0x000000380000-0x000000400000 : "NAND.u-boot-env"
[ 2.715908] 0x000000400000-0x000000e00000 : "Primary kernel"
[ 2.723864] 0x000000e00000-0x000001800000 : "Secondary kernel"
[ 2.732078] 0x000001800000-0x000003000000 : "Primary rootfs"
[ 2.740981] 0x000003000000-0x000004800000 : "Secondary rootfs"
[ 2.749954] 0x000004800000-0x000004e00000 : "Primary user configuration"
[ 2.758705] 0x000004e00000-0x000005400000 : "Secondary user configuration"
[ 2.767591] 0x000005400000-0x000005a00000 : "Factory default configuration"
[ 2.776621] 0x000005a00000-0x000080000000 : "Storage"
[ 2.941971] tps65910 0-002d: No interrupt support, no core IRQ
[ 2.950329] vrtc: supplied by vbat
[ 2.957861] vio: supplied by vbat
[ 2.962939] vdd1: supplied by vbat
[ 2.968403] vdd2: supplied by vbat
[ 2.975445] vdig1: supplied by vbat
[ 2.980522] vdig2: supplied by vbat
[ 2.985713] vpll: supplied by vbat
[ 2.990682] vdac: supplied by vbat
[ 2.995741] vaux1: supplied by vbat
[ 3.000897] vaux2: supplied by vbat
[ 3.005939] vaux33: supplied by vbat
[ 3.010998] vmmc: supplied by vbat
[ 3.016118] vbb: supplied by vbat
[ 3.020893] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 3.036400] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[ 3.042184] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
[ 3.049948] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.056824] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.064144] usb usb1: Product: MUSB HDRC host driver
[ 3.069137] usb usb1: Manufacturer: Linux 4.9.59 musb-hcd
[ 3.074612] usb usb1: SerialNumber: musb-hdrc.0
[ 3.080101] hub 1-0:1.0: USB hub found
[ 3.084032] hub 1-0:1.0: 1 port detected
[ 3.098370] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 3.104237] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
[ 3.111962] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 3.118843] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 3.126136] usb usb2: Product: MUSB HDRC host driver
[ 3.131127] usb usb2: Manufacturer: Linux 4.9.59 musb-hcd
[ 3.136610] usb usb2: SerialNumber: musb-hdrc.1
[ 3.142174] hub 2-0:1.0: USB hub found
[ 3.145997] hub 2-0:1.0: 1 port detected
[ 3.153244] omap_hsmmc 48060000.mmc: Got CD GPIO
[ 3.212788] hctosys: unable to open rtc device (rtc0)
[ 3.218442] lis3_reg: disabling
[ 3.221846] mmc0: mmc_rescan_try_freq: trying to init card at 400000 Hz
[ 3.232848] RAMDISK: gzip image found at block 0
[ 5.228121] EXT4-fs (ram0): mounted filesystem without journal. Opts: (null)
[ 5.235633] VFS: Mounted root (ext4 filesystem) on device 1:0.
[ 5.242348] devtmpfs: mounted
[ 5.246971] Freeing unused kernel memory: 1024K
Bad inittab entry at line 2
[ 5.985714] jffs2: notice: (110) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
/ # [Info] Number of Image: 3
/ # echo 8 > /proc/sys/kernel/printk
/ # cat /proc/sys/kernel/printk
8 4 1 7
/ # [ 159.373936] random: crng init done
/ # uptime
00:03:01 up 3 min, 0 users, load average: 0.00, 0.00, 0.00
/ # [ 1380.081722] Unable to handle kernel paging request at virtual address c0e01ce8
[ 1380.088998] pgd = c1510000
[ 1380.091715] [c0e01ce8] *pgd=80e0041e(bad)
[ 1380.095763] Internal error: Oops: 8000000d [#1] PREEMPT ARM
[ 1380.101359] Modules linked in:
[ 1380.104438] CPU: 0 PID: 0 Comm: swapper Not tainted 4.9.59 #18
[ 1380.110295] Hardware name: Generic AM33XX (Flattened Device Tree)
[ 1380.116413] task: c0e060c0 task.stack: c0e00000
[ 1380.120978] PC is at init_thread_union+0x1ce8/0x2000
[ 1380.125977] LR is at rpm_suspend+0x48/0x5c4
[ 1380.130179] pc : [<c0e01ce8>] lr : [<c04fecbc>] psr: 60000193
[ 1380.130179] sp : c0e01d3c ip : c0e01ce8 fp : 60000113
[ 1380.141706] r10: df020010 r9 : c061a1b0 r8 : c0e13840
[ 1380.146952] r7 : c0e14940 r6 : 0000000d r5 : 60000113 r4 : d7505210
[ 1380.153505] r3 : 00000004 r2 : c01594f4 r1 : 00000001 r0 : fffffff5
[ 1380.160063] Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment none
[ 1380.167315] Control: 10c5387d Table: 81510019 DAC: 00000051
[ 1380.173084] Process swapper (pid: 0, stack limit = 0xc0e00208)
[ 1380.178941] Stack: (0xc0e01d3c to 0xc0e02000)
[ 1380.183316] 1d20: c04fec80
[ 1380.191533] 1d40: 40000113 00000000 d7505210 df020010 c0e01d7c c0e01d60 c061a2b8 c0500668
[ 1380.199749] 1d60: ffffe000 00000101 c061a1b0 00000000 c0e01da4 c0e01d80 c017a484 c061a1bc
[ 1380.207966] 1d80: c0e14a78 c0e01d90 c04ae714 c0e00000 c0e01dd8 00000200 c0e01dd4 c0e01da8
[ 1380.216181] 1da0: c017a5dc c017a460 c0e01dd8 00000001 c0e01dd4 c0e13840 c0e14940 c0e13840
[ 1380.224399] 1dc0: c0e50280 40000001 c0e01e1c c0e01dd8 c017a6a0 c017a500 00000000 c0e01de8
[ 1380.232616] 1de0: c016900c c0119f34 0000c8b0 0001a5e8 c0e01e2c c0e01e00 c048a7ec 00000000
[ 1380.240831] 1e00: 00000001 c0e00000 c0e50284 00000101 c0e01e7c c0e01e20 c012ee7c c017a5fc
[ 1380.249047] 1e20: c0e01e4c c0e01e30 c01690f0 00200100 c0e14940 0001a5e9 0000000a c0a03154
[ 1380.257264] 1e40: ffffe000 c0e50240 c0e103e8 c0e50280 00000000 c0e1d180 00000010 00000000
[ 1380.265479] 1e60: 00000000 df006000 c0e00000 00000000 c0e01e8c c0e01e80 c012f360 c012ed9c
[ 1380.273695] 1e80: c0e01eb4 c0e01e90 c01688b4 c012f22c c0e8d1c0 20000013 ffffffff c0e01f04
[ 1380.281912] 1ea0: 001d7b5d c0e00000 c0e01ecc c0e01eb8 c0101484 c0168860 c06af2e0 20000013
[ 1380.290128] 1ec0: c0e01f54 c0e01ed0 c010c5cc c0101454 00000000 00000141 d32d9c16 c0e0fea8
[ 1380.298343] 1ee0: 53293c72 00000141 00000000 d757a600 001d7b5d 00000141 00000000 c0e01f54
[ 1380.306559] 1f00: c0e01f20 c0e01f20 c06af2d8 c06af2e0 20000013 ffffffff 00000051 00000000
[ 1380.314775] 1f20: 00000000 00000000 001da21c d757a600 c0e00000 c0e42440 c0e028c8 c0e42000
[ 1380.322993] 1f40: c0e028d0 c0e4e2eb c0e01f64 c0e01f58 c06af458 c06af160 c0e01f74 c0e01f68
[ 1380.331208] 1f60: c0159ba8 c06af448 c0e01f94 c0e01f78 c0159dd0 c0159b8c c093b2b0 c0bc93f4
[ 1380.339424] 1f80: 00000002 c0e02840 c0e01fac c0e01f98 c0939f70 c0159cf4 c0e4f50c 00000000
[ 1380.347640] 1fa0: c0e01ff4 c0e01fb0 c0d00d44 c0939ef0 ffffffff ffffffff 00000000 c0d00704
[ 1380.355856] 1fc0: 00000000 c0d3ca28 00000000 c0e4f694 c0e0285c c0d3ca24 c0e0740c 80004059
[ 1380.364071] 1fe0: 413fc082 00000000 00000000 c0e01ff8 80008078 c0d009a8 00000000 00000000
[ 1380.372278] Backtrace: invalid frame pointer 0x60000113
[ 1380.377540] Code: 60000113 c0e01ce8 c010c764 c01013ac (fffffff5)
[ 1380.383670] ---[ end trace 2d370cefb5844926 ]---
[ 1380.388307] Kernel panic - not syncing: Fatal exception in interrupt
[ 1380.394689] ---[ end Kernel panic - not syncing: Fatal exception in interrupt
