TDA2EVM5777: Why could not get frameId after Decode ?
Part Number: TDA2EVM5777
My visionSDK version is 3.07.I use Decode link to decode h264 stream, and use Display link to display video.But I found the frameId always 0 in display link.
I believe there's a bug in Decode link that doesn't delivered the value of frameId.But I don't know how to fix it.Could you give some help?
Here's my chains
NullSource -> Decode -> Display_Video
    Which frame Id you are referring.
    Can you please show the code here.
    If it is inside process function and used for for loop index then it is correct.
    It counts the number of frame received and max time 1 frame is only received.
    Anuj
