Other Parts Discussed in Thread: AM3359
AM3359 Industrial Communications Engine TMDSICE3359.
SDK 3.02.00.05.
Linux RT (default by create-sdcard.sh)
There are complaints about the bug.
From time to time an error on commands:
/sbin/shutdown -r
timedatectl
If I restart the device with the "/sbin/shutdown -r" command, then about 1 time out of 20 this command gives an error:
root@am335x-evm:~# /sbin/shutdown -r Failed to connect to bus: No such file or directory Failed to connect to bus: No such file or directory root@am335x-evm:~# /sbin/shutdown -r Failed to connect to bus: No such file or directory Failed to connect to bus: No such file or directory root@am335x-evm:~# timedatectl Failed to create bus connection: No such file or directory root@am335x-evm:~# timedatectl Failed to create bus connection: No such file or directory root@am335x-evm:~#
At the same time, the command "/sbin/shutdown -r" gives such an error before restarting the device.
Console listing the latest reboots, with the defective last:
g++
gawk-dev
gawk
gcc-symlinks
gcc
gdb
gdbserver
gstreamer1.0-libav
hidapi
libcairo-perf-utils
libgmp10
libidn11
libmpc3
libmpfr4
m4-dev
m4
make
nettle
swig-dev
swig
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[ OK ] Started weston.service.
[ OK ] Started Print notice about GPLv3 packages.
Starting telnetd.service...
[ OK ] Started telnetd.service.
Starting thttpd.service...
Starting busybox-udhcpd.service...
[ OK ] Started thttpd.service.
[ OK ] Started busybox-udhcpd.service.
Starting rng-tools.service...
[ OK ] Started rng-tools.service.
Starting matrix-gui-2.0.service...
[ OK ] Started matrix-gui-2.0.service.
Starting thermal-zone-init.service...
Starting parse-ip.service...
[ OK ] Started thermal-zone-init.service.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org am335x-evm ttyS3
Arago 2016.10 am335x-evm ttyS3
am335x-evm login: root
Shutdown scheduled for Wed 2016-12-14 23:31:53 UTC, use 'shutdown -c' to cancel.
root@am335x-evm:~# Stopping User Manager for UID 0...
Stopping Load/Save Random Seed...
[ OK ] Stopped target Multi-User System.
Stopping System Logging Service...
[ OK ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Stopping strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf...
Stopping Update UTMP about System Boot/Shutdown...
[ OK ] Stopped target Login Prompts.
Stopping Serial Getty on ttyS0...
[ OK ] Stopped target Timers.
[ OK ] Stopped target Swap.
Stopping thermal-zone-init.service...
Stopping Load/Save Screen Backlight...tness of backlight:ssd1307fb0...
Stopping parse-ip.service...
Stopping Session c1 of user root.
[ OK ] Stopped Daily Cleanup of Temporary Directories.
[ OK ] Stopped target System Time Synchronized.
Stopping Network Name Resolution...
Stopping Telephony service...
Stopping Serial Getty on ttyS3...
Stopping Getty on tty1...
Stopping Lightning Fast Webserver With Light System Requirements...
[ OK ] Stopped Setup Virtual Console.
Stopping Avahi mDNS/DNS-SD Stack...
[ OK ] Stopped Synchronize System and HW clocks.
Stopping Network Time Synchronization...
Stopping Kernel Logging Service...
[ OK ] Stopped Network Time Synchronization.
[ OK ] Stopped Telephony service.
[ OK ] Stopped Serial Getty on ttyS3.
[ OK ] Stopped Avahi mDNS/DNS-SD Stack.
[ OK ] Stopped Kernel Logging Service.
[ OK ] Stopped System Logging Service.
[ OK ] Stopped strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
[ OK ] Stopped Getty on tty1.
[ OK ] Stopped Network Name Resolution.
[ OK ] Stopped Lightning Fast Webserver With Light System Requirements.
[ OK ] Stopped User Manager for UID 0.
[ OK ] Stopped Serial Getty on ttyS0.
[ OK ] Stopped Load/Save Random Seed.
[ OK ] Stopped thermal-zone-init.service.
[ OK ] Stopped Load/Save Screen Backlight Brightness of backlight:ssd1307fb0.
[ OK ] Stopped parse-ip.service.
[ OK ] Stopped Session c1 of user root.
[ OK ] Stopped Update UTMP about System Boot/Shutdown.
[ OK ] Removed slice system-systemd\x2dbacklight.slice.
Stopping matrix-gui-2.0.service...
[ OK ] Removed slice User Slice of root.
Stopping Login Service...
[ OK ] Stopped target Network.
Stopping Network Service...
[ OK ] Removed slice system-getty.slice.
[ OK ] Removed slice system-serial\x2dgetty.slice.
Stopping Permit User Sessions...
[ OK ] Stopped Create Volatile Files and Directories.
[ OK ] Stopped target Local File Systems.
Unmounting /run/user/0...
Unmounting /media/ram...
Unmounting /run/media/mmcblk0p1...
[ OK ] Stopped Network Service.
[ OK ] Stopped Login Service.
[ OK ] Stopped matrix-gui-2.0.service.
[ OK ] Stopped Permit User Sessions.
[ OK ] Unmounted /run/user/0.
[ OK ] Unmounted /media/ram.
[ OK ] Unmounted /run/media/mmcblk0p1.
[ OK ] Stopped target Local File Systems (Pre).
[ OK ] Stopped Remount Root and Kernel File Systems.
[ OK ] Stopped Create Static Device Nodes in /dev.
Stopping rng-tools.service...
Stopping D-Bus System Message Bus...
[ OK ] Stopped Apply Kernel Variables.
[ OK ] Stopped Load Kernel Modules.
[ OK ] Stopped D-Bus System Message Bus.
[ OK ] Stopped rng-tools.service.
Stopping thttpd.service...
Stopping busybox-udhcpd.service...
[ OK ] Stopped thttpd.service.
[ OK ] Stopped busybox-udhcpd.service.
Stopping telnetd.service...
[ OK ] Stopped telnetd.service.
Stopping weston.service...
[ OK ] Stopped weston.service.
Stopping rc.pvr.service...
[ OK ] Stopped target Remote File Systems.
[ OK ] Stopped rc.pvr.service.
Stopping uim-sysfs.service...
[ OK ] Stopped uim-sysfs.service.
[ OK ] Stopped target Basic System.
[ OK ] Stopped target Paths.
[ OK ] Stopped Dispatch Password Requests to Console Directory Watch.
[ OK ] Stopped Forward Password Requests to Wall Directory Watch.
[ OK ] Stopped target Slices.
[ OK ] Removed slice User and Session Slice.
Unmounting Temporary Directory...
[ OK ] Stopped target Sockets.
[ OK ] Closed Syslog Socket.
[ OK ] Closed RPCbind Server Activation Socket.
[ OK ] Closed D-Bus System Message Bus Socket.
[ OK ] Closed Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Closed dropbear.socket.
[ OK ] Reached target Shutdown.
[ 869.181241] watchdog watchdog0: watchdog did not stop!
[ 869.206610] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[ 869.241778] systemd-journald[137]: Received SIGTERM from PID 1 (systemd-shutdow).
[ 879.265714] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[ 879.292308] systemd-shutdown[1]: Sending SIGKILL to PID 898 (rngd).
[ 879.303912] systemd-shutdown[1]: Hardware watchdog 'OMAP Watchdog', version 0
[ 879.313380] systemd-shutdown[1]: Unmounting file systems.
[ 879.320066] systemd-shutdown[1]: Remounting '/var/volatile' read-only with options 'size=51200k'.
[ 879.330204] systemd-shutdown[1]: Unmounting /var/volatile.
[ 879.365973] systemd-shutdown[1]: Remounting '/' read-only with options 'data=ordered'.
[ 881.880303] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
[ 881.896054] systemd-shutdown[1]: Remounting '/' read-only with options 'data=ordered'.
[ 881.905139] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
[ 881.911150] systemd-shutdown[1]: Remounting '/' read-only with options 'data=ordered'.
[ 881.920165] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
[ 881.926156] systemd-shutdown[1]: All filesystems unmounted.
[ 881.931766] systemd-shutdown[1]: Deactivating swaps.
[ 881.937183] systemd-shutdown[1]: All swaps deactivated.
[ 881.942456] systemd-shutdown[1]: Detaching loop devices.
[ 881.957435] systemd-shutdown[1]: All loop devices detached.
[ 881.963076] systemd-shutdown[1]: Detaching DM devices.
[ 881.968917] systemd-shutdown[1]: All DM devices detached.
[ 881.987784] systemd-shutdown[1]: Rebooting.
[ 882.004107] reboot: Restarting system
U-Boot SPL 2016.05-g6c5519b6fc (Dec 14 2016 - 20:07:58)
Trying to boot from MMC1
reading args
spl_load_image_fat_os: error reading image args, err - -1
reading u-boot.img
reading u-boot.img
reading u-boot.img
reading u-boot.img
U-Boot 2016.05-g6c5519b6fc (Dec 14 2016 - 20:07:58 -0500)
CPU : AM335X-GP rev 2.1
Model: TI AM3359 ICE-V2
Watchdog enabled
DRAM: 256 MiB
ETH0, CPSW
ETH1, CPSW
NAND: 0 MiB
MMC: OMAP SD/MMC: 0
reading uboot.env
** Unable to read "uboot.env" from mmc0:1 **
Using default environment
<ethaddr> not set. Validating first E-fuse MAC
Net: eth0: ethernet@4a100000
Press SPACE to abort autoboot in 2 seconds
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
reading boot.scr
** Unable to read file boot.scr **
reading uEnv.txt
** Unable to read file uEnv.txt **
Scanning mmc 0:1...
3432000 bytes read in 279 ms (11.7 MiB/s)
38912 bytes read in 38 ms (1000 KiB/s)
Kernel image @ 0x82000000 [ 0x000000 - 0x345e40 ]
Loading Device Tree to 8ef1b000, end 8ef277ff ... OK
Fixing up ETH0 & ETH1 to CPSW Ethernet
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.32-rt41-ge26c84b0ac (gtbldadm@ubuntu-16) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 PREEMPT RT Wed Dec 14 19:20:59 EST 2016
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: TI AM3359 ICE-V2
[ 0.000000] cma: Reserved 48 MiB at 0x8b800000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon )
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64960
[ 0.000000] Kernel command line: console=ttyO3,115200n8 root=PARTUUID=24eadd8d-02 rw rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 200520K/262144K available (6335K kernel code, 321K rwdata, 2396K rodata, 260K init, 310K bss, 12472K reserved, 49152K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xd0800000 - 0xff800000 ( 752 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc088eff4 (8732 kB)
[ 0.000000] .init : 0xc088f000 - 0xc08d0000 ( 260 kB)
[ 0.000000] .data : 0xc08d0000 - 0xc0920580 ( 322 kB)
[ 0.000000] .bss : 0xc0920580 - 0xc096df14 ( 311 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU kthread priority: 1.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000015] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000029] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000035] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000203] clocksource_probe: no matching clocksources found
[ 0.000382] Console: colour dummy device 80x30
[ 0.000547] WARNING: Your 'console=ttyO3' has been replaced by 'ttyS3'
[ 0.000549] This ensures that you still see kernel messages. Please
[ 0.000551] update your kernel commandline.
[ 0.089111] Calibrating delay loop... 795.44 BogoMIPS (lpj=3977216)
[ 0.089116] pid_max: default: 32768 minimum: 301
[ 0.089246] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.089252] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.089979] Initializing cgroup subsys io
[ 0.089999] Initializing cgroup subsys memory
[ 0.090034] Initializing cgroup subsys devices
[ 0.090045] Initializing cgroup subsys freezer
[ 0.090056] Initializing cgroup subsys perf_event
[ 0.090064] Initializing cgroup subsys pids
[ 0.090132] CPU: Testing write buffer coherency: ok
[ 0.090494] Setting up static identity map for 0x80008200 - 0x80008258
[ 0.093187] devtmpfs: initialized
[ 0.106751] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.121619] omap_hwmod: debugss: _wait_target_disable failed
[ 0.177111] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.181269] pinctrl core: initialized pinctrl subsystem
[ 0.182636] NET: Registered protocol family 16
[ 0.185263] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.190568] GPIO line 7 (FET_SWITCH_CTRL) hogged as output/high
[ 0.191254] OMAP GPIO hardware version 0.1
[ 0.193914] GPIO line 100 (PR1_MII_CTRL) hogged as output/high
[ 0.193939] GPIO line 106 (MUX_MII_CTL1) hogged as output/high
[ 0.201381] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.238180] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.242418] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/i2c0_pins_default, deferring probe
[ 0.242549] media: Linux media interface: v0.10
[ 0.242623] Linux video capture interface: v2.00
[ 0.242675] pps_core: LinuxPPS API ver. 1 registered
[ 0.242683] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.242717] PTP clock support registered
[ 0.242777] EDAC MC: Ver: 3.0.0
[ 0.244007] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.244325] Advanced Linux Sound Architecture Driver Initialized.
[ 0.245561] clocksource: Switched to clocksource timer1
[ 0.257408] NET: Registered protocol family 2
[ 0.258280] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.258330] TCP bind hash table entries: 2048 (order: 3, 49152 bytes)
[ 0.258431] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.258509] UDP hash table entries: 256 (order: 2, 16384 bytes)
[ 0.258547] UDP-Lite hash table entries: 256 (order: 2, 16384 bytes)
[ 0.258757] NET: Registered protocol family 1
[ 0.259245] RPC: Registered named UNIX socket transport module.
[ 0.259260] RPC: Registered udp transport module.
[ 0.259268] RPC: Registered tcp transport module.
[ 0.259274] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.260226] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 0.262332] futex hash table entries: 256 (order: 1, 8192 bytes)
[ 0.271277] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.272120] NFS: Registering the id_resolver key type
[ 0.272190] Key type id_resolver registered
[ 0.272199] Key type id_legacy registered
[ 0.272288] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.276160] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.276195] io scheduler noop registered
[ 0.276208] io scheduler deadline registered
[ 0.276504] io scheduler cfq registered (default)
[ 0.277706] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.346090] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.349631] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 158, base_baud = 3000000) is a 8250
[ 0.951587] console [ttyS3] enabled
[ 0.956130] [drm] Initialized drm 1.1.0 20060810
[ 0.968911] loop: module loaded
[ 0.975015] m25p80 spi1.0: found s25fl064k, expected w25q64
[ 0.980647] m25p80 spi1.0: s25fl064k (8192 Kbytes)
[ 0.985498] 4 ofpart partitions found on MTD device spi1.0
[ 0.991009] Creating 4 MTD partitions on "spi1.0":
[ 0.995830] 0x000000000000-0x000000080000 : "u-boot-spl"
[ 1.002592] 0x000000080000-0x000000180000 : "u-boot"
[ 1.008878] 0x000000180000-0x0000001a0000 : "u-boot-env"
[ 1.015448] 0x0000001a0000-0x000000800000 : "misc"
[ 1.022770] libphy: Fixed MDIO Bus: probed
[ 1.085586] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 1.091721] davinci_mdio 4a101000.mdio: detected phy mask fffffff5
[ 1.099562] libphy: 4a101000.mdio: probed
[ 1.103609] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver TI TLK10X 10/100 Mbps PHY
[ 1.113225] davinci_mdio 4a101000.mdio: phy[3]: device 4a101000.mdio:03, driver TI TLK10X 10/100 Mbps PHY
[ 1.123622] cpsw 4a100000.ethernet: Detected MACID = 2c:6b:7d:46:58:3b
[ 1.130354] cpsw 4a100000.ethernet: cpts: overflow check period 850
[ 1.137534] cpsw 4a100000.ethernet: cpsw: Detected MACID = 2c:6b:7d:46:58:3d
[ 1.146376] mousedev: PS/2 mouse device common for all mice
[ 1.152703] i2c /dev entries driver
[ 1.162801] NET: Registered protocol family 10
[ 1.168929] sit: IPv6 over IPv4 tunneling driver
[ 1.174370] NET: Registered protocol family 17
[ 1.179200] Key type dns_resolver registered
[ 1.183758] omap_voltage_late_init: Voltage driver support not added
[ 1.205855] tps65910 0-002d: No interrupt support, no core IRQ
[ 1.264624] Console: switching to mono frame buffer device 12x2
[ 1.297403] ssd1307fb 0-003c: fb0: Solomon SSD1307 framebuffer device registered, using 192 bytes of video memory
[ 1.307977] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.314942] vmmc: supplied by vbat
[ 1.356478] hctosys: unable to open rtc device (rtc0)
[ 1.367666] ALSA device list:
[ 1.375509] No soundcards found.
[ 1.379987] Waiting for root device PARTUUID=24eadd8d-02...
[ 1.403827] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.415002] mmc0: new high speed SDHC card at address 0007
[ 1.421273] mmcblk0: mmc0:0007 APUSD 7.42 GiB
[ 1.427307] mmcblk0: p1 p2
[ 1.511226] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.519481] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 1.528369] devtmpfs: mounted
[ 1.531727] Freeing unused kernel memory: 260K (c088f000 - c08d0000)
[ 1.867812] systemd[1]: System time before build time, advancing clock.
[ 1.934896] random: systemd: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 1.949792] random: systemd: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 1.969761] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 1.988648] systemd[1]: Detected architecture arm.
Welcome to Arago 2016.10!
[ 2.017445] systemd[1]: Set hostname to <am335x-evm>.
[ 2.112142] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
[ 2.134124] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
[ 2.142359] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
[ 2.148931] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 24 bits of entropy available)
[ 2.202630] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 25 bits of entropy available)
[ 2.310248] random: systemd: uninitialized urandom read (16 bytes read, 29 bits of entropy available)
[ 2.320250] random: systemd: uninitialized urandom read (16 bytes read, 29 bits of entropy available)
[ 2.331010] random: systemd: uninitialized urandom read (16 bytes read, 29 bits of entropy available)
[ 2.685969] systemd[1]: [/lib/systemd/system/gadget-init.service:15] Unknown lvalue 'ExecStopPre' in section 'Service'
[ 2.982782] systemd[1]: alignment.service: Found ordering cycle on alignment.service/start
[ 2.991203] systemd[1]: alignment.service: Found dependency on sysinit.target/start
[ 2.998934] systemd[1]: alignment.service: Found dependency on alignment.service/start
[ 3.006917] systemd[1]: alignment.service: Breaking ordering cycle by deleting job alignment.service/start
[ 3.016639] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with alignment.service/start
[ SKIP ] Ordering cycle found, skipping alignment.service
[ 3.062141] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 3.096366] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 3.144442] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 3.166362] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 3.198541] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 3.217530] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 3.236274] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 3.257222] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 3.276206] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 3.296008] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 3.316303] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 3.345964] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 3.366563] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 3.396258] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 3.415986] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 3.436537] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 3.470915] systemd[1]: Starting Create list of required static device nodes for the current kernel...
Starting Create list of required st... nodes for the current kernel...
[ 3.533316] systemd[1]: Starting Load Kernel Modules...
[ 3.570965] systemd[1]: Starting Journal Service...
[ 3.590538] cryptodev: driver 1.8 loaded.
[ 3.621179] systemd[1]: Mounting Debug File System...
[ 3.681189] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.750773] systemd[1]: Starting Setup Virtual Console...
[ 3.797846] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 3.830870] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 3.910197] systemd[1]: Mounting Temporary Directory...
[ 3.949212] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.025976] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted POSIX Message Queue File System.
[ 4.046352] systemd[1]: Mounted Debug File System.
[ OK ] Mounted Debug File System.
[ 4.066230] systemd[1]: Mounted Temporary Directory.
[ OK ] Mounted Temporary Directory.
[ 4.086793] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Started Create list of required sta...ce nodes for the current kernel.
[ OK ] Started Load Kernel Modules.
[ OK ] Started Setup Virtual Console.
[ OK ] Started Remount Root and Kernel File Systems.
Starting udev Coldplug all Devices...
Starting Apply Kernel Variables...
Starting Create Static Device Nodes in /dev...
Starting Flush Journal to Persistent Storage...
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
[ 5.766436] systemd-journald[113]: Received request to flush runtime journal from PID 1
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
Mounting /var/volatile...
Starting udev Kernel Device Manager...
[ OK ] Mounted /var/volatile.
[ OK ] Mounted /media/ram.
[ OK ] Started udev Coldplug all Devices.
[ OK ] Started udev Kernel Device Manager.
Starting Load/Save Random Seed...
[ 7.291815] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ OK ] Reached target Local File Systems.
[ 7.392056] omap_rtc 44e3e000.rtc: already running
Starting Create Volatile Files and Directories...
[ 7.436965] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Create Volatile Files and Directories.
[ 8.215190] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[ OK ] Found device /dev/ttyS3.
[ 8.788640] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 8.957153] remoteproc0: wkup_m3 is available
[ 8.961646] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 9.070998] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 9.226145] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 9.430025] remoteproc0: powering up wkup_m3
[ 9.435497] remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217284
[ 9.544283] rotary-encoder rotary-in0: Using poll mode
[ 9.544673] input: rotary-in0 as /devices/platform/rotary-in0/input/input0
[ 9.693932] remoteproc0: remote processor wkup_m3 is now up
[ 9.693993] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[ OK ] Found device /dev/ttyS0.
[ 10.085924] ti-pruss 4a300000.pruss: creating PRU cores and other child platform devices
[ 10.095352] irq: no irq domain found for /ocp/pruss@4a300000/intc@4a320000 !
[ 10.253302] irq: no irq domain found for /ocp/pruss@4a300000/intc@4a320000 !
[ OK ] Created slice system-systemd\x2dbacklight.slice.
[ 10.393289] PM: bootloader does not support rtc-only!
[ 10.462028] remoteproc1: 4a334000.pru0 is available
[ 10.462035] remoteproc1: Note: remoteproc is still under development and considered experimental.
Starting Load/Save Screen Backlight...tness of backlight:ssd1307fb0...
[ 10.462041] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 10.493775] pru-rproc 4a334000.pru0: PRU rproc node /ocp/pruss@4a300000/pru0@4a334000 probed successfully
[ 10.494321] remoteproc2: 4a338000.pru1 is available
[ 10.494326] remoteproc2: Note: remoteproc is still under development and considered experimental.
[ 10.494331] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 10.494511] pru-rproc 4a338000.pru1: PRU rproc node /ocp/pruss@4a300000/pru1@4a338000 probed successfully
Starting Network Time Synchronization...
Starting Update UTMP about System Boot/Shutdown...
[ OK ] Started Network Time Synchronization.
[ OK ] Started Load/Save Screen Backlight Brightness of backlight:ssd1307fb0.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Found device /dev/mmcblk0p1.
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ OK ] Reached target System Time Synchronized.
Starting Synchronize System and HW clocks...
[ OK ] Started Synchronize System and HW clocks.
[ OK ] Reached target System Initialization.
[ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[ OK ] Listening on dropbear.socket.
[ OK ] Listening on RPCbind Server Activation Socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting Telephony service...
[ OK ] Started System Logging Service.
Starting Print notice about GPLv3 packages...
Starting Permit User Sessions...
Starting uim-sysfs.service...
Starting Avahi mDNS/DNS-SD Stack...
[ OK ] Started D-Bus System Message Bus.
[ OK ] Started Telephony service.
[ OK ] Started Avahi mDNS/DNS-SD Stack.
[ 15.495994] random: nonblocking pool is initializedsing ipsec.conf.
Starting Network Service...
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ 15.593327] Bluetooth: Core ver 2.21
[ 15.628690] NET: Registered protocol family 31
[ 15.633187] Bluetooth: HCI device and connection manager initialized
Starting Login Service...
[ 15.734469] Bluetooth: HCI socket layer initialized
[ 15.751301] Bluetooth: L2CAP socket layer initialized
[ OK ] Started Kernel Logging Service.
[ 15.833897] Bluetooth: SCO socket layer initialized
Starting Start USB gadget...
[ OK ] Started Permit User Sessions.
[ OK ] Started Network Service.
[ 16.296229] net eth1: initializing cpsw version 1.12 (0)
[ 16.371693] net eth0: initialized cpsw ale version 1.4
[ 16.424063] net eth0: ALE Table size 1024
[ 16.586115] net eth1: phy found : id is : 0x2000a211
[ 16.660408] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 16.733459] NET: Registered protocol family 15
[ 16.787388] net eth0: initializing cpsw version 1.12 (0)
[ 16.896201] net eth0: phy found : id is : 0x2000a211
[ 16.948593] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[FAILED] Failed to start Start USB gadget.
See 'systemctl status gadget-init.service' for details.
[ 17.669127] Initializing XFRM netlink socket
Mounting Configuration File System...
[ OK ] Reached target Network.
Starting Lightning Fast Webserver With Light System Requirements...
Starting Network Name Resolution...
[ OK ] Started Serial Getty on ttyS0.
[ OK ] Started Serial Getty on ttyS3.
[ OK ] Started Getty on tty1.
[ OK ] Mounted Configuration File System.
[ OK ] Started Network Name Resolution.
[ OK ] Started Lightning Fast Webserver With Light System Requirements.
[ OK ] Started Login Service.
[ OK ] Started uim-sysfs.service.
Starting rc.pvr.service...
[ OK ] Started rc.pvr.service.
Starting weston.service...
NOTICE: This file system contains the following GPLv3 packages:
autoconf
binutils
bison-dev
bison
cpp-symlinks
cpp
dosfstools
g++-symlinks
g++
gawk-dev
gawk
gcc-symlinks
gcc
gdb
gdbserver
gstreamer1.0-libav
hidapi
libcairo-perf-utils
libgmp10
libidn11
libmpc3
libmpfr4
m4-dev
m4
make
nettle
swig-dev
swig
_____ _____ _ _
|___| |___|
Shutdown scheduled for Wed 2016-12-14 23:19:24 UTC, use 'shutdown -c' to cancel.
root@am335x-evm:~# [ OK ] Stopped target Multi-User System.
[ OK ] Closed Load/Save RF Kill Switch Status /de Stopping Session c1 of user root.
Unmounting /var/volatile...
[ OK ] Unmounted /var/volatile.
[ 119.900182] watchdog watchdog0: watchdog did not stop!
[ 119.926633] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[ 119.958839] systemd-journald[113]: Received SIGTERM from PID 1 (systemd-shutdow).
[ 129.985710] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[ 130.013148] systemd-shutdown[1]: Sending SIGKILL to PID 887 (rngd).
[ 130.020819] systemd-shutdown[1]: Hardware watchdog 'OMAP Watchdog', version 0
[ 130.030246] systemd-shutdown[1]: Unmounting file systems.
[ 130.036907] systemd-shutdown[1]: Remounting '/' read-only with options 'data=ordered'.
[ 132.102464] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
[ 132.117540] systemd-shutdown[1]: Remounting '/' read-only with options 'data=ordered'.
[ 132.126762] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
[ 132.132760] systemd-shutdown[1]: All filesystems unmounted.
[ 132.138439] systemd-shutdown[1]: Deactivating swaps.
[ 132.143867] systemd-shutdown[1]: All swaps deactivated.
[ 132.149213] systemd-shutdown[1]: Detaching loop devices.
[ 132.163720] systemd-shutdown[1]: All loop devices detached.
[ 132.169458] systemd-shutdown[1]: Detaching DM devices.
[ 132.175316] systemd-shutdown[1]: All DM devices detached.
[ 132.194092] systemd-shutdown[1]: Rebooting.
[ 132.210336] reboot: Restarting system
reading args
reading u-boot.img
reading u-boot.img
reading u-boot.img
reading u-boot.img
Watchdog enabled
DRAM: 256 MiB
ETH0, CPSW
ETH1, CPSW
NAND: 0 MiB
MMC: OMAP SD/MMC: 0
reading uboot.env
reading boot.scr
reading uEnv.txt
Scanning mmc 0:1...
38912 bytes read in 39 ms (973.6 KiB/s)
Starting kernel ...
[ 0.000210] clocksource_probe: no matching clocksources found
[ 0.000393] Console: colour dummy device 80x30
[ 0.000555] WARNING: Your 'console=ttyO3' has been replaced by 'ttyS3'
[ 0.000557] This ensures that you still see kernel messages. Please
[ 0.000559] update your kernel commandline.
[ 0.089103] Calibrating delay loop... 795.44 BogoMIPS (lpj=3977216)
[ 0.089109] pid_max: default: 32768 minimum: 301
[ 0.089238] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.089245] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.089971] Initializing cgroup subsys io
[ 0.089990] Initializing cgroup subsys memory
[ 0.090024] Initializing cgroup subsys devices
[ 0.090034] Initializing cgroup subsys freezer
[ 0.090045] Initializing cgroup subsys perf_event
[ 0.090054] Initializing cgroup subsys pids
[ 0.090124] CPU: Testing write buffer coherency: ok
[ 0.090477] Setting up static identity map for 0x80008200 - 0x80008258
[ 0.093181] devtmpfs: initialized
[ 0.106745] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.121621] omap_hwmod: debugss: _wait_target_disable failed
[ 0.177127] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.182634] NET: Registered protocol family 16
[ 0.185267] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.190549] GPIO line 7 (FET_SWITCH_CTRL) hogged as output/high
[ 0.191226] OMAP GPIO hardware version 0.1
[ 0.193884] GPIO line 100 (PR1_MII_CTRL) hogged as output/high
[ 0.193911] GPIO line 106 (MUX_MII_CTL1) hogged as output/high
[ 0.201350] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.238175] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.242445] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/i2c0_pins_default, deferring probe
[ 0.242580] media: Linux media interface: v0.10
[ 0.242653] Linux video capture interface: v2.00
[ 0.242703] pps_core: LinuxPPS API ver. 1 registered
[ 0.242712] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.242746] PTP clock support registered
[ 0.242807] EDAC MC: Ver: 3.0.0
[ 0.244040] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.244350] Advanced Linux Sound Architecture Driver Initialized.
[ 0.245578] clocksource: Switched to clocksource timer1
[ 0.257429] NET: Registered protocol family 2
[ 0.258299] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.258350] TCP bind hash table entries: 2048 (order: 3, 49152 bytes)
[ 0.258451] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.258527] UDP hash table entries: 256 (order: 2, 16384 bytes)
[ 0.258566] UDP-Lite hash table entries: 256 (order: 2, 16384 bytes)
[ 0.258780] NET: Registered protocol family 1
[ 0.259274] RPC: Registered named UNIX socket transport module.
[ 0.259290] RPC: Registered udp transport module.
[ 0.259297] RPC: Registered tcp transport module.
[ 0.259304] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.260261] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 0.262361] futex hash table entries: 256 (order: 1, 8192 bytes)
[ 0.271290] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.272130] NFS: Registering the id_resolver key type
[ 0.272199] Key type id_resolver registered
[ 0.272208] Key type id_legacy registered
[ 0.272297] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.276153] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.276187] io scheduler noop registered
[ 0.276200] io scheduler deadline registered
[ 0.276495] io scheduler cfq registered (default)
[ 0.277694] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.346092] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.349624] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 158, base_baud = 3000000) is a 8250
[ 0.951607] console [ttyS3] enabled
[ 0.956151] [drm] Initialized drm 1.1.0 20060810
[ 0.968960] loop: module loaded
[ 0.975063] m25p80 spi1.0: found s25fl064k, expected w25q64
[ 0.980693] m25p80 spi1.0: s25fl064k (8192 Kbytes)
[ 0.985545] 4 ofpart partitions found on MTD device spi1.0
[ 0.991056] Creating 4 MTD partitions on "spi1.0":
[ 0.995877] 0x000000000000-0x000000080000 : "u-boot-spl"
[ 1.002663] 0x000000080000-0x000000180000 : "u-boot"
[ 1.008986] 0x000000180000-0x0000001a0000 : "u-boot-env"
[ 1.015561] 0x0000001a0000-0x000000800000 : "misc"
[ 1.022961] libphy: Fixed MDIO Bus: probed
[ 1.085605] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 1.091740] davinci_mdio 4a101000.mdio: detected phy mask fffffff5
[ 1.099541] libphy: 4a101000.mdio: probed
[ 1.103593] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver TI TLK10X 10/100 Mbps PHY
[ 1.113211] davinci_mdio 4a101000.mdio: phy[3]: device 4a101000.mdio:03, driver TI TLK10X 10/100 Mbps PHY
[ 1.123608] cpsw 4a100000.ethernet: Detected MACID = 2c:6b:7d:46:58:3b
[ 1.130306] cpsw 4a100000.ethernet: cpts: overflow check period 850
[ 1.137487] cpsw 4a100000.ethernet: cpsw: Detected MACID = 2c:6b:7d:46:58:3d
[ 1.146320] mousedev: PS/2 mouse device common for all mice
[ 1.152646] i2c /dev entries driver
[ 1.162769] NET: Registered protocol family 10
[ 1.168942] sit: IPv6 over IPv4 tunneling driver
[ 1.174391] NET: Registered protocol family 17
[ 1.183761] omap_voltage_late_init: Voltage driver support not added
[ 1.205873] tps65910 0-002d: No interrupt support, no core IRQ
[ 1.264551] Console: switching to mono frame buffer device 12x2
[ 1.297339] ssd1307fb 0-003c: fb0: Solomon SSD1307 framebuffer device registered, using 192 bytes of video memory
[ 1.307908] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.314863] vmmc: supplied by vbat
[ 1.356495] hctosys: unable to open rtc device (rtc0)
[ 1.367684] ALSA device list:
[ 1.375526] No soundcards found.
[ 1.379998] Waiting for root device PARTUUID=24eadd8d-02...
[ 1.403850] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.415010] mmc0: new high speed SDHC card at address 0007
[ 1.421280] mmcblk0: mmc0:0007 APUSD 7.42 GiB
[ 1.427305] mmcblk0: p1 p2
[ 1.511299] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.519585] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 1.528393] devtmpfs: mounted
[ 1.531751] Freeing unused kernel memory: 260K (c088f000 - c08d0000)
[ 1.864524] systemd[1]: System time before build time, advancing clock.
[ 1.931520] random: systemd: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 1.946353] random: systemd: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 1.966262] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 1.985118] systemd[1]: Detected architecture arm.
[ 2.017421] systemd[1]: Set hostname to <am335x-evm>.
[ 2.121111] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
[ 2.131815] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
[ 2.139145] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
[ 2.145192] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 24 bits of entropy available)
[ 2.204841] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 26 bits of entropy available)
[ 2.308801] random: systemd: uninitialized urandom read (16 bytes read, 29 bits of entropy available)
[ 2.318792] random: systemd: uninitialized urandom read (16 bytes read, 29 bits of entropy available)
[ 2.329550] random: systemd: uninitialized urandom read (16 bytes read, 29 bits of entropy available)
[ 2.686522] systemd[1]: [/lib/systemd/system/gadget-init.service:15] Unknown lvalue 'ExecStopPre' in section 'Service'
[ 2.982943] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
[ 2.990877] systemd[1]: sysinit.target: Found dependency on alignment.service/start
[ 2.998609] systemd[1]: sysinit.target: Found dependency on basic.target/start
[ 3.005889] systemd[1]: sysinit.target: Found dependency on sockets.target/start
[ 3.013334] systemd[1]: sysinit.target: Found dependency on dropbear.socket/stop
[ 3.020779] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
[ 3.028228] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
[ 3.037690] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
[ 3.081562] systemd[1]: Reached target Remote File Systems.
[ 3.106408] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.128739] systemd[1]: Created slice User and Session Slice.
[ 3.146663] systemd[1]: Listening on Network Service Netlink Socket.
[ 3.176428] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 3.206175] systemd[1]: Listening on udev Kernel Socket.
[ 3.226440] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.256005] systemd[1]: Reached target Paths.
[ 3.276237] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 3.333350] systemd[1]: Reached target Swap.
[ 3.356319] systemd[1]: Listening on Syslog Socket.
[ 3.376363] systemd[1]: Listening on udev Control Socket.
[ 3.396330] systemd[1]: Listening on Journal Socket.
[ 3.417499] systemd[1]: Created slice System Slice.
[ 3.441155] systemd[1]: Starting Setup Virtual Console...
[ 3.489924] systemd[1]: Mounting Temporary Directory...
[ 3.541003] systemd[1]: Starting Journal Service...
[ 3.576612] systemd[1]: Reached target Slices.
[ 3.602112] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.651665] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 3.740787] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 3.794941] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.869279] systemd[1]: Starting Load Kernel Modules...
[ 3.908121] systemd[1]: Created slice system-getty.slice.
[ 3.925164] cryptodev: driver 1.8 loaded.
[ 3.934582] systemd[1]: Mounting Debug File System...
[ 3.967851] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 4.033978] systemd[1]: Mounted POSIX Message Queue File System.
[ 4.056420] systemd[1]: Mounted Debug File System.
[ 4.076232] systemd[1]: Mounted Temporary Directory.
[ 4.096814] systemd[1]: Started Journal Service.
[ 5.692679] systemd-journald[113]: Received request to flush runtime journal from PID 1
[ 7.403539] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 7.484253] omap_rtc 44e3e000.rtc: already running
[ 7.507492] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 8.287288] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[ 8.904245] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 9.128731] remoteproc0: wkup_m3 is available
[ 9.134373] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 9.213566] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 9.575565] remoteproc0: powering up wkup_m3
[ 9.582455] remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217284
[ 9.671960] remoteproc0: remote processor wkup_m3 is now up
[ 9.672005] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[ 9.766300] rotary-encoder rotary-in0: Using poll mode
[ 9.771882] input: rotary-in0 as /devices/platform/rotary-in0/input/input0
[ 9.909300] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 10.237963] ti-pruss 4a300000.pruss: creating PRU cores and other child platform devices
[ 10.246283] irq: no irq domain found for /ocp/pruss@4a300000/intc@4a320000 !
[ 10.246957] irq: no irq domain found for /ocp/pruss@4a300000/intc@4a320000 !
[ 10.256030] PM: bootloader does not support rtc-only!
[ 10.341988] remoteproc1: 4a334000.pru0 is available
[ 10.341995] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ 10.342000] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 10.342116] pru-rproc 4a334000.pru0: PRU rproc node /ocp/pruss@4a300000/pru0@4a334000 probed successfully
[ 10.342526] remoteproc2: 4a338000.pru1 is available
[ 10.342531] remoteproc2: Note: remoteproc is still under development and considered experimental.
[ 10.342535] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 10.342604] pru-rproc 4a338000.pru1: PRU rproc node /ocp/pruss@4a300000/pru1@4a338000 probed successfully
[ OK ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
[ 16.052189] net eth1: initializing cpsw version 1.12 (0)
[ 16.092305] net eth0: initialized cpsw ale version 1.4
[ 16.162087] net eth0: ALE Table size 1024
[ 16.169005] random: nonblocking pool is initialized
[ 16.244321] Bluetooth: Core ver 2.21
[ 16.286293] net eth1: phy found : id is : 0x2000a211
[ 16.294355] NET: Registered protocol family 31
[ 16.324278] Bluetooth: HCI device and connection manager initialized
[ 16.354613] Bluetooth: HCI socket layer initialized
[ 16.360724] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 16.430964] net eth0: initializing cpsw version 1.12 (0)
[ 16.526172] net eth0: phy found : id is : 0x2000a211
[ 16.531897] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 16.628250] Bluetooth: L2CAP socket layer initialized
[ 16.633424] Bluetooth: SCO socket layer initialized
[ 16.862411] NET: Registered protocol family 15
[ 17.606562] Initializing XFRM netlink socket
autoconf
binutils
bison-dev
bison
cpp-symlinks
cpp
dosfstools
g++-symlinks
g++
gawk-dev
gawk
gcc-symlinks
gcc
gdb
gdbserver
gstreamer1.0-libav
hidapi
libcairo-perf-utils
libgmp10
libidn11
libmpc3
libmpfr4
m4-dev
m4
make
nettle
swig-dev
swig
_____ _____ _ _
|___| |___|
Shutdown scheduled for Wed 2016-12-14 23:19:39 UTC, use 'shutdown -c' to cancel.
root@am335x-evm:~# [ OK ] Stopped Synchronize System and HW clocks.
[ OK ] Closed Load/Save RF Ki Stopping Session c1 of user root.
[ 135.341316] watchdog watchdog0: watchdog did not stop!
[ 135.366628] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[ 135.401763] systemd-journald[113]: Received SIGTERM from PID 1 (systemd-shutdow).
[ 145.425723] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[ 145.453634] systemd-shutdown[1]: Sending SIGKILL to PID 896 (rngd).
[ 145.463703] systemd-shutdown[1]: Hardware watchdog 'OMAP Watchdog', version 0
[ 145.473203] systemd-shutdown[1]: Unmounting file systems.
[ 145.479915] systemd-shutdown[1]: Remounting '/var/volatile' read-only with options 'size=51200k'.
[ 145.490091] systemd-shutdown[1]: Unmounting /var/volatile.
[ 145.526541] systemd-shutdown[1]: Remounting '/' read-only with options 'data=ordered'.
[ 147.554109] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
[ 147.569235] systemd-shutdown[1]: Remounting '/' read-only with options 'data=ordered'.
[ 147.578328] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
[ 147.584343] systemd-shutdown[1]: Remounting '/' read-only with options 'data=ordered'.
[ 147.593371] EXT4-fs (mmcblk0p2): re-mounted. Opts: data=ordered
[ 147.599372] systemd-shutdown[1]: All filesystems unmounted.
[ 147.604984] systemd-shutdown[1]: Deactivating swaps.
[ 147.610399] systemd-shutdown[1]: All swaps deactivated.
[ 147.615693] systemd-shutdown[1]: Detaching loop devices.
[ 147.630681] systemd-shutdown[1]: All loop devices detached.
[ 147.636388] systemd-shutdown[1]: Detaching DM devices.
[ 147.642248] systemd-shutdown[1]: All DM devices detached.
[ 147.660751] systemd-shutdown[1]: Rebooting.
[ 147.677111] reboot: Restarting system
reading args
reading u-boot.img
reading u-boot.img
reading u-boot.img
reading u-boot.img
Watchdog enabled
DRAM: 256 MiB
ETH0, CPSW
ETH1, CPSW
NAND: 0 MiB
MMC: OMAP SD/MMC: 0
reading uboot.env
reading boot.scr
reading uEnv.txt
Scanning mmc 0:1...
Starting kernel ...
[ 0.000036] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000211] clocksource_probe: no matching clocksources found
[ 0.000391] Console: colour dummy device 80x30
[ 0.000554] WARNING: Your 'console=ttyO3' has been replaced by 'ttyS3'
[ 0.089109] Calibrating delay loop... 795.44 BogoMIPS (lpj=3977216)
[ 0.089114] pid_max: default: 32768 minimum: 301
[ 0.089241] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.089247] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.089969] Initializing cgroup subsys io
[ 0.089991] Initializing cgroup subsys memory
[ 0.090025] Initializing cgroup subsys devices
[ 0.090036] Initializing cgroup subsys freezer
[ 0.090047] Initializing cgroup subsys perf_event
[ 0.090055] Initializing cgroup subsys pids
[ 0.090127] CPU: Testing write buffer coherency: ok
[ 0.090482] Setting up static identity map for 0x80008200 - 0x80008258
[ 0.093162] devtmpfs: initialized
[ 0.106735] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.121613] omap_hwmod: debugss: _wait_target_disable failed
[ 0.177119] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.181271] pinctrl core: initialized pinctrl subsystem
[ 0.185260] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.190560] GPIO line 7 (FET_SWITCH_CTRL) hogged as output/high
[ 0.191239] OMAP GPIO hardware version 0.1
[ 0.193881] GPIO line 100 (PR1_MII_CTRL) hogged as output/high
[ 0.193905] GPIO line 106 (MUX_MII_CTL1) hogged as output/high
[ 0.201358] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.238205] edma 49000000.edma: TI EDMA DMA engine driver
[ 0.242460] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/i2c0_pins_default, deferring probe
[ 0.242587] media: Linux media interface: v0.10
[ 0.242662] Linux video capture interface: v2.00
[ 0.242712] pps_core: LinuxPPS API ver. 1 registered
[ 0.242721] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.242755] PTP clock support registered
[ 0.242814] EDAC MC: Ver: 3.0.0
[ 0.244043] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[ 0.244357] Advanced Linux Sound Architecture Driver Initialized.
[ 0.245579] clocksource: Switched to clocksource timer1
[ 0.257437] NET: Registered protocol family 2
[ 0.258310] TCP established hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.258362] TCP bind hash table entries: 2048 (order: 3, 49152 bytes)
[ 0.258462] TCP: Hash tables configured (established 2048 bind 2048)
[ 0.258538] UDP hash table entries: 256 (order: 2, 16384 bytes)
[ 0.258577] UDP-Lite hash table entries: 256 (order: 2, 16384 bytes)
[ 0.258788] NET: Registered protocol family 1
[ 0.259275] RPC: Registered named UNIX socket transport module.
[ 0.259291] RPC: Registered udp transport module.
[ 0.259299] RPC: Registered tcp transport module.
[ 0.259306] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.260267] hw perfevents: enabled with armv7_cortex_a8 PMU driver, 5 counters available
[ 0.262376] futex hash table entries: 256 (order: 1, 8192 bytes)
[ 0.271310] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.272150] NFS: Registering the id_resolver key type
[ 0.272222] Key type id_resolver registered
[ 0.272230] Key type id_legacy registered
[ 0.272317] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.276202] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.276235] io scheduler noop registered
[ 0.276247] io scheduler deadline registered
[ 0.276550] io scheduler cfq registered (default)
[ 0.277744] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.346117] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.349644] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 158, base_baud = 3000000) is a 8250
[ 0.956148] [drm] Initialized drm 1.1.0 20060810
[ 0.968967] loop: module loaded
[ 0.975070] m25p80 spi1.0: found s25fl064k, expected w25q64
[ 0.980698] m25p80 spi1.0: s25fl064k (8192 Kbytes)
[ 0.985548] 4 ofpart partitions found on MTD device spi1.0
[ 0.991059] Creating 4 MTD partitions on "spi1.0":
[ 0.995883] 0x000000000000-0x000000080000 : "u-boot-spl"
[ 1.002651] 0x000000080000-0x000000180000 : "u-boot"
[ 1.008941] 0x000000180000-0x0000001a0000 : "u-boot-env"
[ 1.015516] 0x0000001a0000-0x000000800000 : "misc"
[ 1.022837] libphy: Fixed MDIO Bus: probed
[ 1.085606] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 1.091739] davinci_mdio 4a101000.mdio: detected phy mask fffffff5
[ 1.099548] libphy: 4a101000.mdio: probed
[ 1.103599] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver TI TLK10X 10/100 Mbps PHY
[ 1.113216] davinci_mdio 4a101000.mdio: phy[3]: device 4a101000.mdio:03, driver TI TLK10X 10/100 Mbps PHY
[ 1.123612] cpsw 4a100000.ethernet: Detected MACID = 2c:6b:7d:46:58:3b
[ 1.130313] cpsw 4a100000.ethernet: cpts: overflow check period 850
[ 1.137492] cpsw 4a100000.ethernet: cpsw: Detected MACID = 2c:6b:7d:46:58:3d
[ 1.146311] mousedev: PS/2 mouse device common for all mice
[ 1.152640] i2c /dev entries driver
[ 1.162761] NET: Registered protocol family 10
[ 1.168959] sit: IPv6 over IPv4 tunneling driver
[ 1.174414] NET: Registered protocol family 17
[ 1.179307] Key type dns_resolver registered
[ 1.183872] omap_voltage_late_init: Voltage driver support not added
[ 1.205876] tps65910 0-002d: No interrupt support, no core IRQ
[ 1.264641] Console: switching to mono frame buffer device 12x2
[ 1.297425] ssd1307fb 0-003c: fb0: Solomon SSD1307 framebuffer device registered, using 192 bytes of video memory
[ 1.307993] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 1.314960] vmmc: supplied by vbat
[ 1.356490] hctosys: unable to open rtc device (rtc0)
[ 1.367670] ALSA device list:
[ 1.375512] No soundcards found.
[ 1.379995] Waiting for root device PARTUUID=24eadd8d-02...
[ 1.403835] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.414989] mmc0: new high speed SDHC card at address 0007
[ 1.421257] mmcblk0: mmc0:0007 APUSD 7.42 GiB
[ 1.427286] mmcblk0: p1 p2
[ 1.511288] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.519582] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 1.528422] devtmpfs: mounted
[ 1.531781] Freeing unused kernel memory: 260K (c088f000 - c08d0000)
[ 1.864880] systemd[1]: System time before build time, advancing clock.
[ 1.931564] random: systemd: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 1.946405] random: systemd: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 1.966266] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 2.017347] systemd[1]: Set hostname to <am335x-evm>.
[ 2.129525] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
[ 2.130007] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
[ 2.136438] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
[ 2.148378] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 24 bits of entropy available)
[ 2.198854] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 25 bits of entropy available)
[ 2.307223] random: systemd: uninitialized urandom read (16 bytes read, 29 bits of entropy available)
[ 2.317210] random: systemd: uninitialized urandom read (16 bytes read, 29 bits of entropy available)
[ 2.328058] random: systemd: uninitialized urandom read (16 bytes read, 29 bits of entropy available)
[ 2.684869] systemd[1]: [/lib/systemd/system/gadget-init.service:15] Unknown lvalue 'ExecStopPre' in section 'Service'
[ 2.979504] systemd[1]: sockets.target: Found ordering cycle on sockets.target/start
[ 2.987433] systemd[1]: sockets.target: Found dependency on dbus.socket/start
[ 2.994631] systemd[1]: sockets.target: Found dependency on sysinit.target/start
[ 3.002083] systemd[1]: sockets.target: Found dependency on alignment.service/start
[ 3.009796] systemd[1]: sockets.target: Found dependency on basic.target/start
[ 3.017070] systemd[1]: sockets.target: Found dependency on sockets.target/start
[ 3.024513] systemd[1]: sockets.target: Breaking ordering cycle by deleting job dbus.socket/start
[ 3.033445] systemd[1]: dbus.socket: Job dbus.socket/start deleted to break ordering cycle starting with sockets.target/start
[ SKIP ] Ordering cycle found, skipping D-Bus System Message Bus Socket
[ 3.066378] systemd[1]: basic.target: Found ordering cycle on basic.target/start
[ 3.073845] systemd[1]: basic.target: Found dependency on sysinit.target/start
[ 3.081131] systemd[1]: basic.target: Found dependency on alignment.service/start
[ 3.088675] systemd[1]: basic.target: Found dependency on basic.target/start
[ 3.095778] systemd[1]: basic.target: Breaking ordering cycle by deleting job alignment.service/start
[ 3.105056] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with basic.target/start
[ 3.141811] systemd[1]: Listening on Journal Socket.
[ 3.166346] systemd[1]: Listening on udev Kernel Socket.
[ 3.186652] systemd[1]: Listening on Network Service Netlink Socket.
[ 3.218799] systemd[1]: Created slice System Slice.
[ 3.241164] systemd[1]: Mounting Debug File System...
[ 3.285521] systemd[1]: Mounting Temporary Directory...
[ 3.343003] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 3.376402] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 3.429038] systemd[1]: Starting Create list of required static device nodes for the current kernel...
[ 3.486488] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.520680] systemd[1]: Mounting POSIX Message Queue File System...
[ 3.573056] systemd[1]: Starting Load Kernel Modules...
[ 3.606553] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.624334] cryptodev: driver 1.8 loaded.
[ 3.633519] systemd[1]: Starting Setup Virtual Console...
[ 3.657593] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 3.706314] systemd[1]: Reached target Paths.
[ 3.726042] systemd[1]: Reached target Remote File Systems.
[ 3.747382] systemd[1]: Created slice User and Session Slice.
[ 3.766157] systemd[1]: Reached target Slices.
[ 3.790424] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 3.826278] systemd[1]: Reached target Swap.
[ 3.849344] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.856698] systemd[1]: Listening on udev Control Socket.
[ 3.898000] systemd[1]: Created slice system-getty.slice.
[ 3.916390] systemd[1]: Listening on Syslog Socket.
[ 3.940583] systemd[1]: Starting Journal Service...
[ 4.017934] systemd[1]: Mounted POSIX Message Queue File System.
[ 4.046372] systemd[1]: Mounted Debug File System.
[ 4.076384] systemd[1]: Mounted Temporary Directory.
[ 4.109385] systemd[1]: Started Create list of required static device nodes for the current kernel.
[ 4.158677] systemd[1]: Started Load Kernel Modules.
[ 4.178232] systemd[1]: Started Setup Virtual Console.
[ 4.198124] systemd[1]: Started Remount Root and Kernel File Systems.
[ 4.227074] systemd[1]: Started Journal Service.
[ 5.476409] systemd-journald[148]: Received request to flush runtime journal from PID 1
[ 7.332752] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 7.437365] omap_rtc 44e3e000.rtc: already running
[ 7.439391] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 8.289659] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20
[ 8.848833] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 9.049490] remoteproc0: wkup_m3 is available
[ 9.053985] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 9.143806] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 9.186156] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 9.537618] remoteproc0: powering up wkup_m3
[ 9.543147] remoteproc0: Booting fw image am335x-pm-firmware.elf, size 217284
[ 9.630776] remoteproc0: remote processor wkup_m3 is now up
[ 9.630820] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[ 9.728066] rotary-encoder rotary-in0: Using poll mode
[ 9.733639] input: rotary-in0 as /devices/platform/rotary-in0/input/input0
[ 9.974628] ti-pruss 4a300000.pruss: creating PRU cores and other child platform devices
[ 9.984187] irq: no irq domain found for /ocp/pruss@4a300000/intc@4a320000 !
[ 10.001665] PM: bootloader does not support rtc-only!
[ 10.198264] irq: no irq domain found for /ocp/pruss@4a300000/intc@4a320000 !
[ 10.351066] remoteproc1: 4a334000.pru0 is available
[ 10.425344] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ 10.444518] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 10.710963] pru-rproc 4a334000.pru0: PRU rproc node /ocp/pruss@4a300000/pru0@4a334000 probed successfully
[ 10.847657] remoteproc2: 4a338000.pru1 is available
[ 10.852676] remoteproc2: Note: remoteproc is still under development and considered experimental.
[ 10.983594] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 11.107955] pru-rproc 4a338000.pru1: PRU rproc node /ocp/pruss@4a300000/pru1@4a338000 probed successfully
[ 14.783170] net eth1: initializing cpsw version 1.12 (0)
[ 14.788538] net eth0: initialized cpsw ale version 1.4
[ 14.793704] net eth0: ALE Table size 1024
[ OK ] Started Daily Cleanup of Temporary Directorie[ 14.886193] net eth1: phy found : id is : 0x2000a211
s.
[ 14.940765] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 14.986123] net eth0: initializing cpsw version 1.12 (0)
[ 15.066174] net eth0: phy found : id is : 0x2000a211
[ 15.115966] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 15.916025] NET: Registered protocol family 15
[ 15.962311] random: nonblocking pool is initialized
[ 16.667116] Initializing XFRM netlink socket
[ OK ] Started weston.service.
autoconf
binutils
bison-dev
bison
cpp-symlinks
cpp
dosfstools
g++-symlinks
g++
gawk-dev
gawk
gcc-symlinks
gcc
gdb
gdbserver
gstreamer1.0-libav
hidapi
libcairo-perf-utils
libgmp10
libidn11
libmpc3
libmpfr4
m4-dev
m4
make
nettle
swig-dev
swig
Starting telnetd.service...
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[ OK ] Started Print notice about GPLv3 packages.
[ OK ] Started telnetd.service.
Starting thttpd.service...
Starting busybox-udhcpd.service...
[ OK ] Started thttpd.service.
[ OK ] Started busybox-udhcpd.service.
Starting rng-tools.service...
[ OK ] Started rng-tools.service.
Starting matrix-gui-2.0.service...
[ OK ] Started matrix-gui-2.0.service.
Starting parse-ip.service...
Starting thermal-zone-init.service...
[ OK ] Started thermal-zone-init.service.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org am335x-evm ttyS3
Arago 2016.10 am335x-evm ttyS3
am335x-evm login: root
root@am335x-evm:~# /sbin/shutdown -r
Failed to connect to bus: No such file or directory
root@am335x-evm:~# timedatectl
Failed to create bus connection: No such file or directory
root@am335x-evm:~#
After reboot, the bug disappears, until the next appearance with the random boot of the OS.
Please help.
