I have run the appended network in an adapted tidl demo, but the execution hangs after the function tivxKernelTIDLDumpToFile() was called for layer 20, so I assume the execution hangs in either
- layer 20 (inception2_t0_0_relu)
- layer 23 (inception2_t0_1_relu)
- layer 21 (inception2_t1_0_relu).
Question: Is tivxKernelTIDLDumpToFile() called before or after the corresponding layer execution?
In host emulation, everything is fine. Other networks also run.
To make it run I needed to increase the scratch memory by editing psdk_rtos_auto_j7_06_01_00_15/vision_apps/apps/basic_demos/app_tirtos/common/app_cfg_c7x_1.h:
#define DDR_SCRATCH_SIZE ((46)*0x100000u) // earlier 16MB
layer {
type: "Input"
top: "input_1"
input_param {
shape {
dim: 1
dim: 3
dim: 512
dim: 1024
layer {
type: "Convolution"
bottom: "input_1"
top: "conv0_0"
convolution_param {
num_output: 16
bias_term: true
pad: 3
kernel_size: 7
stride: 1
layer {
type: "ReLU"
bottom: "conv0_0"
top: "conv0_0_relu"
layer {
type: "Convolution"
bottom: "conv0_0_relu"
top: "conv0_2"
convolution_param {
num_output: 16
bias_term: true
pad: 2
kernel_size: 5
stride: 1
layer {
type: "ReLU"
bottom: "conv0_2"
top: "conv0_2_relu"
layer {
type: "Convolution"
bottom: "conv0_2_relu"
top: "conv0_4"
convolution_param {
num_output: 32
bias_term: true
pad: 1
kernel_size: 3
stride: 2
layer {
type: "ReLU"
bottom: "conv0_4"
top: "conv0_4_relu"
layer {
type: "Convolution"
bottom: "conv0_4_relu"
top: "conv1_0"
convolution_param {
num_output: 32
bias_term: true
pad: 2
kernel_size: 5
stride: 1
layer {
type: "ReLU"
bottom: "conv1_0"
top: "conv1_0_relu"
layer {
type: "Convolution"
bottom: "conv1_0_relu"
top: "conv1_2"
convolution_param {
num_output: 32
bias_term: true
pad: 1
kernel_size: 3
stride: 1
layer {
type: "ReLU"
bottom: "conv1_2"
top: "conv1_2_relu"
layer {
type: "Convolution"
bottom: "conv1_2_relu"
top: "conv1_3"
convolution_param {
num_output: 32
bias_term: true
pad: 1
kernel_size: 3
stride: 1
layer {
type: "ReLU"
bottom: "conv1_3"
top: "conv1_3_relu"
layer {
type: "Convolution"
bottom: "conv1_3_relu"
top: "conv1_4"
convolution_param {
num_output: 64
bias_term: true
pad: 1
kernel_size: 3
stride: 1
layer {
type: "ReLU"
bottom: "conv1_4"
top: "conv1_4_relu"
layer {
type: "Convolution"
bottom: "conv1_4_relu"
top: "inception1_t0_0"
convolution_param {
num_output: 48
bias_term: true
kernel_size: 1
stride: 1
layer {
type: "Convolution"
top: "inception1_t1_0"
convolution_param {
num_output: 48
bias_term: true
kernel_size: 1
stride: 1
layer {
type: "ReLU"
bottom: "inception1_t0_0"
top: "inception1_t0_0_relu"
layer {
type: "ReLU"
bottom: "inception1_t1_0"
top: "inception1_t1_0_relu"
layer {
type: "Pooling"
top: "inception1_t3_0"
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: "Convolution"
bottom: "inception1_t0_0_relu"
top: "inception1_t0_1"
convolution_param {
num_output: 48
bias_term: true
pad: 1
kernel_size: 3
stride: 2
layer {
type: "Convolution"
bottom: "inception1_t1_0_relu"
top: "inception1_t1_1"
convolution_param {
num_output: 48
bias_term: true
pad: 2
kernel_size: 5
stride: 2
layer {
type: "Convolution"
bottom: "inception1_t3_0"
top: "inception1_t3_1"
convolution_param {
num_output: 48
bias_term: true
kernel_size: 1
stride: 1
layer {
type: "ReLU"
bottom: "inception1_t0_1"
top: "inception1_t0_1_relu"
layer {
type: "ReLU"
bottom: "inception1_t1_1"
top: "inception1_t1_1_relu"
layer {
type: "ReLU"
bottom: "inception1_t3_1"
top: "inception1_t3_1_relu"
layer {
type: "Concat"
bottom: "inception1_t0_1_relu"
bottom: "inception1_t1_1_relu"
bottom: "inception1_t3_1_relu"
top: "inception1concat"
layer {
type: "Convolution"
bottom: "inception1concat"
top: "inception1_dim_red"
convolution_param {
num_output: 64
bias_term: true
kernel_size: 1
stride: 1
layer {
type: "ReLU"
bottom: "inception1_dim_red"
top: "inception1_dim_red_relu"
layer {
type: "Convolution"
bottom: "inception1_dim_red_relu"
top: "conv2_0"
convolution_param {
num_output: 64
bias_term: true
pad: 1
kernel_size: 3
stride: 1
layer {
type: "ReLU"
bottom: "conv2_0"
top: "conv2_0_relu"
layer {
type: "Convolution"
bottom: "conv2_0_relu"
top: "conv2_1"
convolution_param {
num_output: 64
bias_term: true
pad: 1
kernel_size: 3
stride: 1
layer {
type: "ReLU"
bottom: "conv2_1"
top: "conv2_1_relu"
layer {
type: "Convolution"
bottom: "conv2_1_relu"
top: "conv2_3"
convolution_param {
num_output: 96
bias_term: true
pad: 1
kernel_size: 3
stride: 1
layer {
type: "ReLU"
bottom: "conv2_3"
top: "conv2_3_relu"
layer {
type: "Convolution"
bottom: "conv2_3_relu"
top: "inception2_t0_0"
convolution_param {
num_output: 72
bias_term: true
kernel_size: 1
stride: 1
layer {
type: "Convolution"
top: "inception2_t1_0"
convolution_param {
num_output: 72
bias_term: true
kernel_size: 1
stride: 1
layer {
type: "ReLU"
bottom: "inception2_t0_0"
top: "inception2_t0_0_relu"
layer {
type: "ReLU"
bottom: "inception2_t1_0"
top: "inception2_t1_0_relu"
layer {
type: "Pooling"
top: "inception2_t3_0"
pooling_param {
pool: MAX
kernel_size: 2
stride: 2
layer {
type: "Convolution"
bottom: "inception2_t0_0_relu"
top: "inception2_t0_1"
convolution_param {
num_output: 72
bias_term: true
pad: 1
kernel_size: 3
stride: 2
layer {
type: "Convolution"
bottom: "inception2_t1_0_relu"
top: "inception2_t1_1"
convolution_param {
num_output: 72
bias_term: true
pad: 2
kernel_size: 5
stride: 2
layer {
type: "Convolution"
bottom: "inception2_t3_0"
top: "inception2_t3_1"
convolution_param {
num_output: 72
bias_term: true
kernel_size: 1
stride: 1
layer {
type: "ReLU"
bottom: "inception2_t0_1"
top: "inception2_t0_1_relu"
layer {
type: "ReLU"
bottom: "inception2_t1_1"
top: "inception2_t1_1_relu"
layer {
type: "ReLU"
bottom: "inception2_t3_1"
top: "inception2_t3_1_relu"
layer {
type: "Concat"
bottom: "inception2_t0_1_relu"
bottom: "inception2_t1_1_relu"
bottom: "inception2_t3_1_relu"
top: "inception2concat"
