TDA2PXEVM: Linux Boot up Issue
Part Number: TDA2PXEVM
Other Parts Discussed in Thread: PMP
Hello All,
I am currently working on TDA2PXEVM Linux Platform . I have build the default VISION SDK for linux platform but facing booting issue for the same. Same for TDA2XX Linux build is working fine on TDA2XX board. I have checked the pin configurations for both the boards as well.
Can anyone help me to resolve the issue. Any inputs would be of great help.
Shantanu Joshi
    did you changed the device tree file in uenv.txt? For TDA2Px you need to set "fdtfile= dra76-evm-infoada.dtb", please check section "3.1.2 SD only boot" in VisionSDK_Linux_UserGuide.pdf.
    Yordan
  • Hi Yordan,
    I have made the changes in uenv.txt file. But while boot up on TDA2PXEVM kernel image is not getting found. I am sharing the log.
    U-Boot SPL 2016.05-00010-g9551b3d (Dec 12 2019 - 14:29:16)
    DRA762-GP ES1.0
    no pinctrl for hs200_1_8v
    no pinctrl for ddr_1_8v
    Trying to boot from MMC1
    reading dra7-ipu2-fw.lzop
    spl_load_file_fat: error reading file dra7-ipu2-fw.lzop, err - -1
    spl: error reading image dra7-ipu2-fw.lzop, err - -1
    Error loading remotecore IPU2!,Continuing with boot ...
    reading dra7-dsp1-fw.lzop
    spl_load_file_fat: error reading file dra7-dsp1-fw.lzop, err - -1
    spl: error reading image dra7-dsp1-fw.lzop, err - -1
    Error loading remotecore DSP1!,Continuing with boot ...
    reading dra7-dsp2-fw.lzop
    spl_load_file_fat: error reading file dra7-dsp2-fw.lzop, err - -1
    spl: error reading image dra7-dsp2-fw.lzop, err - -1
    Error loading remotecore DSP2!,Continuing with boot ...
    reading dra7-ipu1-fw.lzop
    spl_load_file_fat: error reading file dra7-ipu1-fw.lzop, err - -1
    spl: error reading image dra7-ipu1-fw.lzop, err - -1
    Error loading remotecore IPU1!,Continuing with boot ...
    spl: falcon_args_file not set in environment, falling back to default
    reading single-stage-boot.dtb
    spl_load_image_fat_os: error reading image single-stage-boot.dtb, err - -1
    reading u-boot.img
    reading u-boot.img
    reading u-boot.img
    reading u-boot.img
    U-Boot 2016.05-00010-g9551b3d (Dec 12 2019 - 14:29:16 +0530)
    CPU : DRA762-GP ES1.0
    Model: TI DRA762 EVM
    Board: DRA74x EVM REV
    DRAM: 1.5 GiB
    MMC: mmc@4809c000: fail to find sdr104 mode FDT_ERR_NOTFOUND
    no pinctrl for sdr104
    mmc@4809c000: fail to find ddr50 mode FDT_ERR_NOTFOUND
    no pinctrl for ddr50
    mmc@4809c000: fail to find sdr50 mode FDT_ERR_NOTFOUND
    no pinctrl for sdr50
    mmc@4809c000: fail to find sdr25 mode FDT_ERR_NOTFOUND
    no pinctrl for sdr25
    mmc@4809c000: fail to find sdr12 mode FDT_ERR_NOTFOUND
    no pinctrl for sdr12
    OMAP SD/MMC: 0, OMAP SD/MMC: 1
    Warning: fastboot.board_rev: unknown board revision
    GUID Partition Table Header signature is wrong: 0x0 != 0x5452415020494645
    part_get_info_efi: *** ERROR: Invalid GPT ***
    part_get_info_efi: *** ERROR: Invalid Backup GPT ***
    ERROR: cannot find partition: 'userdata'
    at arch/arm/cpu/armv7/omap-common/utils.c:199/mmc_get_part_size()
    Warning: fastboot.userdata_size: unable to calc
    SCSI: SATA link 0 timeout.
    AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
    flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
    scanning bus for devices...
    Found 0 device(s).
    Net:
    Warning: ethernet@48484000 using MAC address from ROM
    eth0: ethernet@48484000
    Hit any key to stop autoboot: 0
    => env default -fa
    ## Resetting to default environment
    => saveenv
    Saving Environment to MMC...
    Writing to MMC(1)... done
    DRA762-GP ES1.0
    reading u-boot.img
    reading u-boot.img
    reading u-boot.img
    reading u-boot.img
    DRAM: 1.5 GiB
    Found 0 device(s).
    Net:
    ## Error: "board_findfdt" not defined
    switch to partitions #0, OK
    mmc0 is current device
    SD/MMC found on device 0
    reading boot.scr
    ** Unable to read file boot.scr **
    reading uEnv.txt
    173 bytes read in 2 ms (84 KiB/s)
    Loaded env from uEnv.txt
    Importing environment from mmc0 ...
    3555816 bytes read in 170 ms (19.9 MiB/s)
    ** File not found /boot/dra76-evm-infoada.dtb **
    Booting from mmc0 ...
    Kernel image @ 0x82000000 [ 0x000000 - 0x3641e8 ]
    ERROR: Did not find a cmdline Flattened Device Tree
    Could not find a valid device tree
    mmc1(part 0) is current device
    mmc - MMC sub system
    Usage:
    mmc info - display info of the current MMC device
    mmc read addr blk# cnt
    mmc write addr blk# cnt
    mmc erase blk# cnt
    mmc rescan
    mmc part - lists available partition on current mmc device
    mmc dev [dev] [part] - show or set current mmc device [partition]
    mmc list - lists available devices
    mmc hwpartition [args...] - does hardware partitioning
    arguments (sizes in 512-byte blocks):
    [user [enh start cnt] [wrrel {on|off}]] - sets user data area attributes
    [gp1|gp2|gp3|gp4 cnt [enh] [wrrel {on|off}]] - general purpose partition
    [check|set|complete] - mode, complete set partitioning completed
    WARNING: Partitioning is a write-once setting once it is set to complete.
    Power cycling is required to initialize partitions after set to complete.
    mmc bootbus dev boot_bus_width reset_boot_bus_width boot_mode
    - Set the BOOT_BUS_WIDTH field of the specified device
    mmc bootpart-resize <dev> <boot part size MB> <RPMB part size MB>
    - Change sizes of boot and RPMB partitions of specified device
    mmc partconf dev boot_ack boot_partition partition_access
    - Change the bits of the PARTITION_CONFIG field of the specified device
    mmc rst-function dev value
    - Change the RST_n_FUNCTION field of the specified device
    WARNING: This is a write-once field and 0 / 1 / 2 are the only valid values.
    mmc setdsr <value> - set DSR register value
    Usage:
    mmc erase blk# cnt
    mmc rescan
    Booting from eMMC ...
    Wrong Image Format for bootm command
    ERROR: can't get kernel image!
    PS: Please note that I have change the boot environment to default also. Still I'm facing the same error for kernel image.
    Shantanu Joshi
  • Hello Yordan,
    This is just a reminder as I have been stuck in the issue for last two days.
    Shantanu Joshi
    can you check this post and the following discussion and see if it can give you any directions:
    Yordan
    I have seen the post suggested by you and follow the steps as well. But now while booting on TDA2Px kernel is getting panic.
    I am sharing the snapshot of log as well.
    Starting kernel ...
    [ 0.000000] Booting Linux on physical CPU 0x0
    [ 0.000000] Initializing cgroup subsys cpuset
    [ 0.000000] Initializing cgroup subsys cpuacct
    [ 0.000000] Linux version 4.4.84+ (linux@linux-pc) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 SMP PREEMPT Mon Dec 16 16:31:54
    IST 2019
    [ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
    [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
    [ 0.000000] Machine model: TI DRA762 EVM
    [ 0.000000] Reserved memory: created DMA memory pool at 0x0000000040300000, size 3 MiB
    [ 0.000000] Reserved memory: initialized node cmem@40300000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: regions without no-map are not yet supported
    [ 0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 80 MiB
    [ 0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created CMA memory pool at 0x000000009e000000, size 32 MiB
    [ 0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000a1000000, size 32 MiB
    [ 0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created CMA memory pool at 0x00000000a3000000, size 32 MiB
    [ 0.000000] Reserved memory: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool
    [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 64 MiB
    [ 0.000000] Reserved memory: initialized node cmem@A9000000, compatible id shared-dma-pool
    [ 0.000000] cma: Reserved 64 MiB at 0x00000000bbc00000
    [ 0.000000] Forcing write-allocate cache policy for SMP
    [ 0.000000] Memory policy: Data cache writealloc
    [ 0.000000] OMAP4: Map 0x00000000bfd00000 to fe600000 for dram barrier
    [ 0.000000] DRA762 ES1.0
    [ 0.000000] PERCPU: Embedded 11 pages/cpu @ef635000 s14912 r8192 d21952 u45056
    [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 243008
    [ 0.000000] Kernel command line: console=ttyO0,115200n8 vram=16M root=PARTUUID=e2eed36f-02 rw rootwait ip=none mem=1024M cma=64M
    [ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
    [ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    [ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    [ 0.000000] Memory: 371984K/978944K available (5106K kernel code, 230K rwdata, 980K rodata, 296K init, 260K bss, 361200K reserved, 245760K c
    ma-reserved, 192512K highmem)
    [ 0.000000] Virtual kernel memory layout:
    [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
    [ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
    [ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
    [ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
    [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
    [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
    [ 0.000000] .text : 0xc0008000 - 0xc05f9f74 (6088 kB)
    [ 0.000000] .init : 0xc05fa000 - 0xc0644000 ( 296 kB)
    [ 0.000000] .data : 0xc0644000 - 0xc067d978 ( 231 kB)
    [ 0.000000] .bss : 0xc067f000 - 0xc06c01b4 ( 261 kB)
    [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
    [ 0.000000] Preemptible hierarchical RCU implementation.
    [ 0.000000] Build-time adjustment of leaf fanout to 32.
    [ 0.000000] NR_IRQS:16 nr_irqs:16 16
    [ 0.000000] ti_dt_clocks_register: failed to lookup clock node gmac_gmii_ref_clk_div
    [ 0.000000] OMAP clockevent source: timer1 at 32786 Hz
    [ 0.000000] Architected cp15 timer(s) running at 6.14MHz (phys).
    [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
    [ 0.000004] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
    [ 0.000016] Switching to timer-based delay loop, resolution 162ns
    [ 0.000331] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
    [ 0.000339] OMAP clocksource: 32k_counter at 32768 Hz
    [ 0.000766] Console: colour dummy device 80x30
    [ 0.000782] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
    [ 0.000788] This ensures that you still see kernel messages. Please
    [ 0.000794] update your kernel commandline.
    [ 0.000808] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
    [ 0.000821] pid_max: default: 32768 minimum: 301
    [ 0.000918] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [ 0.000928] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
    [ 0.001461] Initializing cgroup subsys io
    [ 0.001478] Initializing cgroup subsys memory
    [ 0.001501] Initializing cgroup subsys devices
    [ 0.001513] Initializing cgroup subsys freezer
    [ 0.001524] Initializing cgroup subsys perf_event
    [ 0.001536] Initializing cgroup subsys pids
    [ 0.001561] CPU: Testing write buffer coherency: ok
    [ 0.001758] /cpus/cpu@0 missing clock-frequency property
    [ 0.001774] /cpus/cpu@1 missing clock-frequency property
    [ 0.001785] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    [ 0.001799] Setting up static identity map for 0x80008380 - 0x800083e0
    [ 0.080055] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
    [ 0.080122] Brought up 2 CPUs
    [ 0.080136] SMP: Total of 2 processors activated (24.59 BogoMIPS).
    [ 0.080142] CPU: All CPU(s) started in HYP mode.
    [ 0.080147] CPU: Virtualization extensions available.
    [ 0.080518] devtmpfs: initialized
    [ 0.109317] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
    [ 0.110023] omap_hwmod: l3_main_2 using broken dt data from ocp
    [ 0.113465] omap_hwmod: mcan: cannot clk_get main_clk mcan_clk
    [ 0.113479] omap_hwmod: mcan: cannot _init_clocks
    [ 0.113486] ------------[ cut here ]------------
    [ 0.113495] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2608 0xc0606e74()
    [ 0.113501] omap_hwmod: mcan: couldn't init clocks
    [ 0.113507] Modules linked in:
    [ 0.113520] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 4.4.84+ #1
    [ 0.113528] Hardware name: Generic DRA74X (Flattened Device Tree)
    [ 0.113534] Backtrace:
    [ 0.113544] Function entered at [<c0013134>] from [<c0013320>]
    [ 0.113551] r7:c0606e74 r6:60000013 r5:00000000 r4:c0660750
    [ 0.113570] Function entered at [<c0013308>] from [<c0234328>]
    [ 0.113577] Function entered at [<c023429c>] from [<c0036ca8>]
    [ 0.113583] r7:c0606e74 r6:00000a30 r5:00000009 r4:ef075e30
    [ 0.113601] Function entered at [<c0036c20>] from [<c0036d10>]
    [ 0.113607] r8:00000065 r7:c0634820 r6:c063f8b4 r5:c05f7c30 r4:c05069cc
    [ 0.113626] Function entered at [<c0036cdc>] from [<c0606e74>]
    [ 0.113632] r3:c056bcc4 r2:c05069cc
    [ 0.113642] r4:c0607bf0
    [ 0.113650] Function entered at [<c0606cac>] from [<c0026da8>]
    [ 0.113656] Function entered at [<c0026d44>] from [<c0607bb0>]
    [ 0.113662] Function entered at [<c0607b74>] from [<c0607c28>]
    [ 0.113668] Function entered at [<c0607bf0>] from [<c00098a0>]
    [ 0.113673] Function entered at [<c0009794>] from [<c05faf2c>]
    [ 0.113679] r10:00000002 r9:c05fa578 r8:00000065 r7:c0634820 r6:c063f8b4 r5:c05f7c30
    [ 0.113700] r4:c067f000
    [ 0.113707] Function entered at [<c05fad58>] from [<c04fe3fc>]
    [ 0.113713] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c04fe3e4
    [ 0.113734] r4:c067f000
    [ 0.113741] Function entered at [<c04fe3e4>] from [<c000fb08>]
    [ 0.113747] r5:c04fe3e4 r4:00000000
    [ 0.113770] ---[ end trace c502d65d0199ea73 ]---
    [ 0.122105] omap_hwmod: dcan1: _wait_target_disable failed
    [ 0.221076] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [ 0.221092] futex hash table entries: 512 (order: 3, 32768 bytes)
    [ 0.226136] pinctrl core: initialized pinctrl subsystem
    [ 0.226816] NET: Registered protocol family 16
    [ 0.227709] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [ 0.250141] cpuidle: using governor ladder
    [ 0.280173] cpuidle: using governor menu
    [ 0.286757] platform 43300000.edma: Cannot lookup hwmod 'tpcc'
    [ 0.287051] platform 43400000.tptc: Cannot lookup hwmod 'tptc0'
    [ 0.287332] platform 43500000.tptc: Cannot lookup hwmod 'tptc1'
    [ 0.288421] OMAP GPIO hardware version 0.1
    [ 0.294851] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
    [ 0.317361] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    [ 0.317371] hw-breakpoint: maximum watchpoint size is 8 bytes.
    [ 0.317794] omap4_sram_init:Unable to allocate sram needed to handle errata I688
    [ 0.317803] omap4_sram_init:Unable to get sram pool needed to handle errata I688
    [ 0.318052] OMAP DMA hardware revision 0.0
    [ 0.360893] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
    [ 0.361420] edma3-tptc 43400000.tptc: _od_fail_runtime_resume: FIXME: missing hwmod/omap_dev info
    [ 0.361469] edma3-tptc 43500000.tptc: _od_fail_runtime_resume: FIXME: missing hwmod/omap_dev info
    [ 0.361706] edma 43300000.edma: _od_fail_runtime_resume: FIXME: missing hwmod/omap_dev info
    [ 0.361718] edma 43300000.edma: pm_runtime_get_sync() failed
    [ 0.365671] omap-iommu 40d01000.mmu: 40d01000.mmu registered
    [ 0.365828] omap-iommu 40d02000.mmu: 40d02000.mmu registered
    [ 0.365968] omap-iommu 58882000.mmu: 58882000.mmu registered
    [ 0.366105] omap-iommu 55082000.mmu: 55082000.mmu registered
    [ 0.366352] omap-iommu 41501000.mmu: 41501000.mmu registered
    [ 0.366512] omap-iommu 41502000.mmu: 41502000.mmu registered
    [ 0.369336] palmas 0-0058: IRQ missing: skipping irq request
    [ 0.380613] palmas 0-0058: Muxing GPIO 51, PWM 0, LED 2
    [ 0.431031] irq: no irq domain found for /ocp/i2c@48070000/tps65917@58 !
    [ 0.431936] pcf857x 0-0020: probed
    [ 0.432512] pcf857x 0-0021: probed
    [ 0.432885] GPIO line 465 (vin6_sel_s0) hogged as output/low
    [ 0.432975] pcf857x 0-0026: probed
    [ 0.433113] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
    [ 0.433493] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
    [ 0.433674] media: Linux media interface: v0.10
    [ 0.433718] Linux video capture interface: v2.00
    [ 0.433761] EDAC MC: Ver: 3.0.0
    [ 0.434440] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
    [ 0.434715] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
    [ 0.435552] clocksource: Switched to clocksource arch_sys_counter
    [ 0.444629] NET: Registered protocol family 2
    [ 0.445116] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
    [ 0.445180] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
    [ 0.445305] TCP: Hash tables configured (established 8192 bind 8192)
    [ 0.445351] UDP hash table entries: 512 (order: 2, 16384 bytes)
    [ 0.445382] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
    [ 0.445515] NET: Registered protocol family 1
    [ 0.446489] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
    [ 0.447407] ------------[ cut here ]------------
    [ 0.447418] WARNING: CPU: 0 PID: 1 at arch/arm/mach-omap2/omap_hwmod.c:2116 0xc00259b4()
    [ 0.447425] omap_hwmod: timer12: enabled state can only be entered from initialized, idle, or disabled state
    [ 0.447432] Modules linked in:
    [ 0.447445] CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 4.4.84+ #1
    [ 0.447452] Hardware name: Generic DRA74X (Flattened Device Tree)
    [ 0.447459] Backtrace:
    [ 0.447468] Function entered at [<c0013134>] from [<c0013320>]
    [ 0.447475] r7:c00259b4 r6:20000093 r5:00000000 r4:c0660750
    [ 0.447495] Function entered at [<c0013308>] from [<c0234328>]
    [ 0.447501] Function entered at [<c023429c>] from [<c0036ca8>]
    [ 0.447506] r7:c00259b4 r6:00000844 r5:00000009 r4:ef075c28
    [ 0.447524] Function entered at [<c0036c20>] from [<c0036d10>]
    [ 0.447530] r8:00000004 r7:c0028908 r6:ef23e1c0 r5:00000000 r4:c05066d0
    [ 0.447550] Function entered at [<c0036cdc>] from [<c00259b4>]
    [ 0.447556] r3:c056bedc r2:c05066d0
    [ 0.447565] r4:00000001
    [ 0.447573] Function entered at [<c00258c8>] from [<c0027110>]
    [ 0.447579] Function entered at [<c00270c4>] from [<c00288b8>]
    [ 0.447585] Function entered at [<c0028870>] from [<c0028920>]
    [ 0.447590] r7:c0028908 r6:c0028908 r5:ef239e74 r4:ef239e10
    [ 0.447607] Function entered at [<c0028908>] from [<c0332474>]
    [ 0.447612] r5:ef239e74 r4:ef239e10
    [ 0.447623] Function entered at [<c0332440>] from [<c03324d0>]
    [ 0.447628] r7:c0028908 r6:ef204c10 r5:ef239e10 r4:ef239e10
    [ 0.447645] Function entered at [<c03324a8>] from [<c03333b4>]
    [ 0.447650] r7:c0028908 r6:ef204c10 r5:c0646100 r4:ef239e10
    [ 0.447666] Function entered at [<c0333040>] from [<c0333600>]
    [ 0.447672] r10:00000000 r9:ef237a00 r8:00000000 r7:60000013 r6:00000004 r5:ef239e74
    [ 0.447693] r4:ef239e10
    [ 0.447701] Function entered at [<c03335ac>] from [<c0032ff4>]
    [ 0.447706] r7:c0507c44 r6:ef239e10 r5:ef239e00 r4:ef353790
    [ 0.447722] Function entered at [<c0032e44>] from [<c032b444>]
    [ 0.447728] r9:c05fa578 r8:00000000 r7:fffffdfb r6:c06553dc r5:ef239e10 r4:c06b7514
    [ 0.447748] Function entered at [<c032b3f0>] from [<c03299cc>]
    [ 0.447753] r7:c06553dc r6:00000000 r5:ef239e10 r4:c06b7514
    [ 0.447770] Function entered at [<c03297c8>] from [<c0329b54>]
    [ 0.447775] r9:c05fa578 r8:00000065 r7:00000000 r6:ef239e44 r5:c06553dc r4:ef239e10
    [ 0.447796] Function entered at [<c0329ac0>] from [<c0327c54>]
    [ 0.447801] r7:00000000 r6:c0329ac0 r5:c06553dc r4:00000000
    [ 0.447817] Function entered at [<c0327be4>] from [<c03292b8>]
    [ 0.447823] r6:c066c348 r5:ef340a80 r4:c06553dc
    [ 0.447836] Function entered at [<c0329294>] from [<c0328ef4>]
    [ 0.447842] Function entered at [<c0328d4c>] from [<c032a2f4>]
    [ 0.447847] r7:c0634834 r6:c063fb9c r5:c05f7c30 r4:c06553dc
    [ 0.447864] Function entered at [<c032a274>] from [<c032b36c>]
    [ 0.447869] r5:c05f7c30 r4:c066c348
    [ 0.447879] Function entered at [<c032b324>] from [<c060a6f8>]
    [ 0.447884] r5:c05f7c30 r4:c060a6e0
    [ 0.447895] Function entered at [<c060a6e0>] from [<c00098a0>]
    [ 0.447901] Function entered at [<c0009794>] from [<c05faf2c>]
    [ 0.447906] r10:00000007 r9:c05fa578 r8:00000065 r7:c0634834 r6:c063fb9c r5:c05f7c30
    [ 0.447926] r4:c067f000
    [ 0.447934] Function entered at [<c05fad58>] from [<c04fe3fc>]
    [ 0.447939] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c04fe3e4
    [ 0.447959] r4:c067f000
    [ 0.447967] Function entered at [<c04fe3e4>] from [<c000fb08>]
    [ 0.447972] r5:c04fe3e4 r4:00000000
    [ 0.447983] ---[ end trace c502d65d0199ea74 ]---
    [ 0.447995] omap_timer 4ae20000.timer: omap_dm_timer_probe: pm_runtime_get_sync failed!
    [ 0.448013] omap_timer: probe of 4ae20000.timer failed with error -22
    [ 0.456366] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [ 0.456378] ntfs: driver 2.1.32 [Flags: R/O].
    [ 0.457430] bounce: pool size: 64 pages
    [ 0.457569] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
    [ 0.457579] io scheduler noop registered
    [ 0.457587] io scheduler deadline registered
    [ 0.457615] io scheduler cfq registered (default)
    [ 0.461921] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
    [ 0.518913] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
    [ 0.521593] omap8250 4806a000.serial: Can't verify DMA configuration (-19)
    [ 0.522094] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 301, base_baud = 3000000) is a 8250
    [ 1.948514] console [ttyS0] enabled
    [ 1.952444] omap8250 4806c000.serial: Can't verify DMA configuration (-19)
    [ 1.959816] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 302, base_baud = 3000000) is a 8250
    [ 1.969081] omap8250 48020000.serial: Can't verify DMA configuration (-19)
    [ 1.976460] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 303, base_baud = 3000000) is a 8250
    [ 1.986427] [drm] Initialized drm 1.1.0 20060810
    [ 1.992587] vsys_3v3: supplied by vsys_12v0
    [ 1.996815] ldo5: supplied by vsys_3v3
    [ 2.001115] OMAP DSS rev 6.1
    [ 2.004844] omapdss_dss 58000000.dss: bound 58001000.dispc (ops 0xc0541c54)
    [ 2.012477] omapdss_dss 58000000.dss: bound 58040000.encoder (ops 0xc0542ce4)
    [ 2.024412] vmemexp device MAJOR num = 248
    [ 2.028558] vmemexp class registered
    [ 2.032270] /dev/vmemexp device registered
    [ 2.036467] ioctl DBUFIOC_EXPORT_VIRTMEM = -1072899120
    [ 2.043682] i2c /dev entries driver
    [ 2.049750] omap_hsmmc 4809c000.mmc: Got CD GPIO
    [ 2.054564] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode
    [ 2.061057] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode
    [ 2.067455] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode
    [ 2.073836] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode
    [ 2.080237] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode
    [ 2.086805] vio_3v3: supplied by vsys_3v3
    [ 2.090842] vio_3v3_sd: supplied by vio_3v3
    [ 2.095153] vsys_5v0: supplied by vsys_12v0
    [ 2.099382] ldo4: supplied by vsys_5v0
    [ 2.136098] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
    [ 2.142483] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
    [ 2.149042] smps5: supplied by vsys_3v3
    [ 2.153072] vio_1v8: supplied by smps5
    [ 2.197219] ledtrig-cpu: registered to indicate activity on CPUs
    [ 2.204745] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
    [ 2.212584] remoteproc0: 55020000.ipu is available
    [ 2.217496] remoteproc0: Note: remoteproc is still under development and considered experimental.
    [ 2.226504] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [ 2.236979] remoteproc0: Direct firmware load for dra7-ipu2-fw.xem4 failed with error -2
    [ 2.245190] remoteproc0: Falling back to user helper
    [ 2.250437] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
    [ 2.258368] remoteproc1: 40800000.dsp is available
    [ 2.263268] remoteproc1: Note: remoteproc is still under development and considered experimental.
    [ 2.272282] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [ 2.283008] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@9f000000
    [ 2.290876] remoteproc2: 41000000.dsp is available
    [ 2.295794] remoteproc2: Note: remoteproc is still under development and considered experimental.
    [ 2.304859] remoteproc1: Direct firmware load for dra7-dsp1-fw.xe66 failed with error -2
    [ 2.313100] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
    [ 2.323508] remoteproc1: Falling back to user helper
    [ 2.329814] NET: Registered protocol family 10
    [ 2.344768] remoteproc2: Direct firmware load for dra7-dsp2-fw.xe66 failed with error -2
    [ 2.353214] sit: IPv6 over IPv4 tunneling driver
    [ 2.358446] NET: Registered protocol family 17
    [ 2.362923] NET: Registered protocol family 41
    [ 2.367424] remoteproc2: Falling back to user helper
    [ 2.372730] omap_voltage_late_init: Voltage driver support not added
    [ 2.379661] Power Management for TI OMAP4+ devices.
    [ 2.384735] Registering SWP/SWPB emulation handler
    [ 2.391755] dmm 4e000000.dmm: initialized all PAT entries
    [ 2.397621] ldo1: supplied by vsys_3v3
    [ 2.405061] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
    [ 2.411780] [drm] No driver support for vblank timestamp query.
    [ 2.417798] omapdrm omapdrm.0: No connectors reported connected with modes
    [ 2.424750] [drm] Cannot find any crtc or sizes - going 1024x768
    [ 2.434508] [drm] Enabling DMM ywrap scrolling
    [ 2.439214] omapdrm omapdrm.0: fb0: omapdrm frame buffer device
    [ 2.466521] [drm] Initialized omapdrm 1.0.0 20110917 on minor 0
    [ 2.483532] input: gpio_keys as /devices/platform/gpio_keys/input/input0
    [ 2.490541] hctosys: unable to open rtc device (rtc0)
    [ 2.496054] aic_dvdd: disabling
    [ 2.500010] omap8250 4806a000.serial: failed to request DMA
    [ 2.505762] Waiting for root device PARTUUID=e2eed36f-02...
    [ 2.667714] mmc0: host does not support reading read-only switch, assuming write-enable
    [ 2.681921] mmc0: new high speed SDHC card at address aaaa
    [ 2.697898] mmcblk0: mmc0:aaaa SS08G 7.40 GiB
    [ 2.707861] mmcblk0: p1 p2
    [ 2.728884] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
    [ 2.750498] mmc1: MAN_BKOPS_EN bit is not set
    [ 2.756803] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [ 2.764967] VFS: Mounted root (ext4 filesystem) on device 179:2.
    [ 2.782461] devtmpfs: mounted
    [ 2.785673] Freeing unused kernel memory: 296K
    [ 2.790137] This architecture does not have kernel memory protection.
    [ 2.801437] mmc1: new HS200 MMC card at address 0001
    [ 2.806957] mmcblk1: mmc1:0001 MMC08G 7.25 GiB
    [ 2.813210] Starting init: /sbin/init exists but couldn't execute it (error -8)
    [ 2.821909] mmcblk1boot0: mmc1:0001 MMC08G partition 1 8.00 MiB
    [ 2.828179] mmcblk1boot1: mmc1:0001 MMC08G partition 2 8.00 MiB
    [ 2.834839] mmcblk1: p1 p2
    [ 2.839624] Starting init: /bin/sh exists but couldn't execute it (error -8)
    [ 2.846745] Kernel panic - not syncing: No working init found. Try passing init= option to kernel. See Linux Documentation/init.txt for gui
    dance.
    [ 2.859933] CPU1: stopping
    [ 2.862655] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G W 4.4.84+ #1
    [ 2.869907] Hardware name: Generic DRA74X (Flattened Device Tree)
    [ 2.876026] Backtrace:
    [ 2.878490] Function entered at [<c0013134>] from [<c0013320>]
    [ 2.884347] r7:ef0a5f40 r6:20000193 r5:00000000 r4:c0660750
    [ 2.890065] Function entered at [<c0013308>] from [<c0234328>]
    [ 2.895921] Function entered at [<c023429c>] from [<c0015780>]
    [ 2.901777] r7:ef0a5f40 r6:00000000 r5:00000001 r4:c064141c
    [ 2.907490] Function entered at [<c00155fc>] from [<c00094c4>]
    [ 2.913345] r7:fa212000 r6:ef0a5f40 r5:fa21200c r4:c06468e4
    [ 2.919059] Function entered at [<c000944c>] from [<c0013e00>]
    [ 2.924917] Exception stack(0xef0a5f40 to 0xef0a5f88)
    [ 2.929991] 5f40: 00000001 00000000 fe600000 00000000 ef0a4000 c06464ac 00000000 00000000
    [ 2.938206] 5f60: ef0a5fb0 c0507dc4 c064650c ef0a5f9c ef0a5f7c ef0a5f90 c0029d4c c0010580
    [ 2.946416] 5f80: 60000013 ffffffff
    [ 2.949917] r9:c0507dc4 r8:ef0a5fb0 r7:ef0a5f74 r6:ffffffff r5:60000013 r4:c0010580
    [ 2.957736] Function entered at [<c0010558>] from [<c0072aa8>]
    [ 2.963590] Function entered at [<c0072a80>] from [<c0072d08>]
    [ 2.969444] Function entered at [<c0072b08>] from [<c0015368>]
    [ 2.975297] r7:c067f298
    [ 2.977847] Function entered at [<c00151fc>] from [<8000956c>]
    [ 2.983700] r7:c067f298 r6:30c0387d r5:00000000 r4:af043d80
    [ 2.989421] ---[ end Kernel panic - not syncing: No working init found. Try passing init= option to kernel. See Linux Documentation/init.tx
    t for guidance.
    Please suggest how to proceed next?
    Shantanu Joshi
    I have followed the steps as per the suggested post by you. But now my kernel is getting panic.
    I am sharing snapshot of the log as well.
    Starting kernel ...
    IST 2019
    dance.
    t for guidance.
    How can I overcome this issue and proceed next?
    Shantanu Joshi
    some errors such as:
    indicates that there is mismatch between DTS files and the hardware.
    Can you show the contents of your uenv.txt and confirm if it is TDA2p EVM or a custom board?
    Yordan
    Contents of uenv.txt file :-
    fdtfile=dra76-evm-infoadas.dtb
    args_mmc=part uuid mmc 0:2 uuid; setenv bootargs "console=ttyO0,115200n8 vram=16M root=PARTUUID=${uuid} rw rootwait ip=none mem=1024M cma=64M"
    Shantanu
  • Hi Shantanu,
    what is the value of "MAKECONFIG" in Rules.make?
    Yordan
  • Hi Yordan,
    MAKECONFIG?=tda2px_evm_linux_all
    Shantanu
  • Hi Yordan,
    The issue is resolved as I re-installed VSDK 3.5 for TDA2PXEVM Linux platform. Now the issue is not coming as I have checked the same for 2-3 times.
    May be some files or directory was not get install correctly in previous one.
    Thanks for the inputs given by you. All are informative for me.
    Shantanu Joshi.
  • Hi Shantanu,
    I am glad to hear that the issue is resolved.
    Yordan
