On our hardware a GPIO interrupt (bank 5) is used to request a realtime data transfer on the EMIFA bus to an FPGA driving lots of ADCs.
The rate can reach 80kHz.
At present time, some other activities of the DSP software (mainly UDP/ NDK, UART)are causing extra delays on the interrupt response time. I think other interrupts can preempt the GPIO interrupt routine. We are using DSP/BIOS 5.41, NDK2.0, CCS3.3 and PSP 1.30 on a C6747 dsp.
Is it possible to increase the GPIO interrupt priority using PSP driver with DSP/BIOS ?
Do you have any advice ?
Frederic
Below is an extract of the TCF file :
/* ECM configuration from PSP drivers documentation*/ bios.HWI.instance("HWI_INT7").interruptSelectNumber = 0; bios.HWI.instance("HWI_INT8").interruptSelectNumber = 1; bios.HWI.instance("HWI_INT9").interruptSelectNumber = 2; bios.HWI.instance("HWI_INT10").interruptSelectNumber = 3;
And of the C code :
void my_gpio_init(void)
LOG_printf(&trace, "GPIO Initilisation.\n");
/* Configure GPIO_FPGA_RS# pin as an output */
UserPinCmdArg.pin = GPIO_FPGA_nRS;
UserPinCmdArg.value = Gpio_Direction_Output;
Gpio_setPinDir(hGpio,&UserPinCmdArg);
/* Configure GPIO_FPGA_INT# pin as an input */
UserPinCmdArg.pin = GPIO_FPGA_nINT;
UserPinCmdArg.value = Gpio_Direction_Input;
/* Reset logiciel du FPGA avant de configurer l'interruption */
fpga_reset();
/* Configure GPIO_FPGA_INT# to generate interrupt on falling edge */
Gpio_setFallingEdgeTrigger(hGpio,GPIO_FPGA_nINT);
/* Enable GPIO Bank interrupt */
Gpio_bankInterruptEnable(hGpio,GPIO_BANK_5);
UserIntrCmdArg.value = GPIO_BANK_5;
UserIntrCmdArg.bankOrPin = Gpio_BankOrPin_isBank;
UserIntrCmdArg.isrHandler = (Gpio_Isr)&gpio_isr;
Gpio_regIntHandler(hGpio,&UserIntrCmdArg);
int uart_init_ll(void) {
Uart_init();
uart_uartParams = Uart_PARAMS;
//extrait de Uart.h (pspdrivers_01_30_01\packages\ti\pspiom\uart)
//const struct Uart_Params Uart_PARAMS = {
// TRUE, /* cacheEnable */
// TRUE, /* fifoEnable */
// Uart_OpMode_INTERRUPT, /* opMode */
// FALSE, /* loopbackEnabled */
// Uart_BaudRate_115_2K, /* baudRate */
// Uart_NumStopBits_1, /* stopBits */
// Uart_CharLen_8, /* charLen */
// Uart_Parity_NONE, /* parity */
// Uart_RxTrigLvl_14, /* rxThreshold */
// { /* fc */
// Uart_FcType_NONE,
// Uart_FcParam_NONE
// 0, /* edmaRxTC */
// 0, /* edmaTxTC */
// 0, /* hwiNumber */
// 0xffffffff, /* polledModeTimeout */
// 1, /* softTxFifoThreshold */
// FALSE, /* PSC control disabled */
// Uart_pllDomain_0 /* PLL domain used by the driver */
//utilisation des interruptions pour la gestion de l'UART 2
uart_uartParams.hwiNumber = 9;
uart_uartParams.opMode = Uart_OpMode_INTERRUPT;
uart_uartParams.rxThreshold = Uart_RxTrigLvl_1;
return 0;
int usb_init_ll(void) {
Uart_init();
usb_uartParams = Uart_PARAMS;
// { /* fc */
//utilisation des interruptions pour la gestion de l'UART 0 sur USB
usb_uartParams.hwiNumber = 8;
usb_uartParams.opMode = Uart_OpMode_INTERRUPT;//Uart_OpMode_POLLED;//
usb_uartParams.baudRate = 86616u;
usb_uartParams.rxThreshold = Uart_RxTrigLvl_1;
return 0;
