[TDA4M] No TARGET_COMBOS remain! Nothing to make Error
I try run Auto Valet Park demo from Vision Apps User Guide.
I have problem in Part Build Instruction à Quick Steps to build vision apps for Linux+TI-RTOS mode
cd vision_apps
make vision-apps
I have following error
alex-linux@LinuxV18:/opt/psdk_rtos_auto_j7_06_01_00_15/vision_apps$ make vision_apps
SHELL=/bin/sh
TARGET_MAKEFILES=applibs/srv_bowl_lut_gen_applib/concerto.mak applibs/srv_calibration_applib/concerto.mak applibs/test/concerto.mak apps/basic_demos/app_c7x_kernel/c7x/concerto.mak apps/basic_demos/app_c7x_kernel/concerto.mak apps/basic_demos/app_dof/concerto.mak apps/basic_demos/app_linux_arm_ipc/concerto.mak apps/basic_demos/app_linux_arm_mem/concerto.mak apps/basic_demos/app_linux_arm_opengl_mosaic/concerto.mak apps/basic_demos/app_linux_arm_remote_log/concerto.mak apps/basic_demos/app_multi_cam/concerto.mak apps/basic_demos/app_single_cam/concerto.mak apps/basic_demos/app_stereo/concerto.mak apps/basic_demos/app_test_framework/concerto.mak apps/basic_demos/app_tirtos/common/concerto.mak apps/basic_demos/app_tirtos/tirtos_linux/c66x_1/concerto.mak apps/basic_demos/app_tirtos/tirtos_linux/c66x_2/concerto.mak apps/basic_demos/app_tirtos/tirtos_linux/c7x_1/concerto.mak apps/basic_demos/app_tirtos/tirtos_linux/mcu2_0/concerto.mak apps/basic_demos/app_tirtos/tirtos_linux/mcu2_1/concerto.mak apps/basic_demos/app_tirtos/tirtos_linux/mpu1/concerto.mak apps/basic_demos/app_vx_conformance/concerto.mak apps/basic_demos/app_vx_tutorial/concerto.mak apps/cockpit_demos/app_tirtos_linux/concerto.mak apps/dl_demos/app_tidl/concerto.mak apps/dl_demos/app_tidl_avp/concerto.mak apps/dl_demos/app_tidl_avp2/concerto.mak apps/dl_demos/app_visual_localization/concerto.mak apps/ptk_demos/app_common/concerto.mak apps/ptk_demos/app_dof_sfm_fisheye/concerto.mak apps/ptk_demos/app_ldc/concerto.mak apps/ptk_demos/app_ldc_dof/concerto.mak apps/ptk_demos/app_lidar_ogmap/concerto.mak apps/ptk_demos/app_radar_gtrack/concerto.mak apps/ptk_demos/app_sfm_fisheye/concerto.mak apps/ptk_demos/app_surround_radar_ogmap/concerto.mak apps/ptk_demos/app_valet_parking/concerto.mak apps/ptk_demos/applibs/fused_ogmap_applib/concerto.mak apps/ptk_demos/applibs/lidar_ogmap_applib/concerto.mak apps/ptk_demos/applibs/ps_mapping_applib/concerto.mak apps/ptk_demos/applibs/radar_gtrack_applib/concerto.mak apps/ptk_demos/applibs/surround_radar_ogmap_applib/concerto.mak apps/ptk_demos/applibs/surround_sfm_ogmap_applib/concerto.mak apps/srv_demos/app_srv_calibration/concerto.mak apps/srv_demos/app_srv_camera/concerto.mak apps/srv_demos/app_srv_fileio/concerto.mak kernels/common/target/concerto.mak kernels/img_proc/arm/concerto.mak kernels/img_proc/c66/concerto.mak kernels/img_proc/host/concerto.mak kernels/lidar/arm/concerto.mak kernels/lidar/host/concerto.mak kernels/park_assist/host/concerto.mak kernels/park_assist/target/concerto.mak kernels/park_assist/test/concerto.mak kernels/sample/a72/concerto.mak kernels/sample/host/concerto.mak kernels/srv/c66/concerto.mak kernels/srv/gpu/3dsrv/Tools/concerto.mak kernels/srv/gpu/3dsrv/concerto.mak kernels/srv/gpu/concerto.mak kernels/srv/host/concerto.mak kernels/srv/test/concerto.mak kernels/stereo/arm/concerto.mak kernels/stereo/c7x/concerto.mak kernels/stereo/host/concerto.mak utils/console_io/src/concerto.mak utils/draw2d/src/concerto.mak utils/dss/src/concerto.mak utils/grpx/src/concerto.mak utils/hwa/src/concerto.mak utils/ipc/src/concerto.mak utils/iss/src/concerto.mak utils/mem/src/concerto.mak utils/misc/src/concerto.mak utils/mmc_sd/src/concerto.mak utils/opengl/src/a72/concerto.mak utils/opengl/src/pc/concerto.mak utils/perf_stats/src/concerto.mak utils/remote_service/src/concerto.mak utils/sciclient/src/concerto.mak utils/sensors/src/concerto.mak utils/udma/src/concerto.mak
file TIARMCGT_ROOT=$(PSDK_PATH)/ti-cgt-arm_18.12.1.LTS
file GCC_SYSBIOS_ARM_ROOT=$(PSDK_PATH)/gcc-linaro-7.2.1-2017.11-x86_64_aarch64-elf
file CGT6X_ROOT=$(PSDK_PATH)/ti-cgt-c6000_8.3.2
file CGT7X_ROOT=$(PSDK_PATH)/ti-cgt-c7000_1.2.0.STS
undefined GCC_WINDOWS_ROOT=
file GCC_LINUX_ROOT=/usr/
concerto/combo_filters.mak:72: *** No TARGET_COMBOS remain! Nothing to make. Stop.
  • Hi Alex,
    Please make sure you follow the instruction under "Build Environment Setup" without any error.
    If no error, please do "make sdk_show_config" and share the log. Thanks.
    Stanley
  • alex-linux@LinuxV18:/opt/psdk_rtos_auto_j7_06_01_00_15$ make sdk_show_config
    make: *** No rule to make target 'sdk_show_config'.  Stop.
  • It should be done from ~\vision_apps\ folder. Same as the build.
  • alex-linux@LinuxV18:/opt/psdk_rtos_auto_j7_06_01_00_15/vision_apps$ make sdk_show_config
    SHELL=/bin/sh
  • We expect to see below in the build.
    TARGET_COMBO=J7:LINUX:A72:1:release:GCC_LINUX_ARM
    Did you modify anything before you build? For example, did you modify ~/tiovx/build_flags.mak?
    Could you also share environments from "export" command?
  • Hi, Alex:
    I believe there is something wrong with your TDA4 build environment setup.
    Are there any errors as you follow the guide from psdk_rtos_auto_j7_06_01_00_15/vision_apps/docs/user_guide/ENVIRONMENT_SETUP.html?
    Here is my setup:
    peterli@peterli-Latitude-E7440:/media/peterli/work/SDK/J7SDK_06_01_00/psdk_rtos_auto_j7_06_01_00_15/vision_apps$ make sdk_show_config
    SHELL=/bin/sh
    TARGET_COMBO=J7:SYSBIOS:R5F:3:debug:TIARMCGT
    HOST_ROOT=/media/peterli/work/SDK/J7SDK_06_01_00/psdk_rtos_auto_j7_06_01_00_15/vision_apps
    HOST_COMPILER=TIARMCGT
    HOST_PLATFORM=PC
    HOST_OS=LINUX
    HOST_CPU=x86_64
    HOST_ARCH=64
    HOST_FAMILY=x86_64
    HOST_NUM_CORES=4
    TARGET_OS=SYSBIOS
    TARGET_CPU=R5F
    TARGET_ARCH=32
    TARGET_FAMILY=ARM
    TARGET_NUM_CORES=3
    TARGET_PLATFORM=J7
    TARGET_BUILD=debug
    TARGET_OUT=/media/peterli/work/SDK/J7SDK_06_01_00/psdk_rtos_auto_j7_06_01_00_15/vision_apps/out/J7/R5F/SYSBIOS/debug
    TARGET_DOC=/media/peterli/work/SDK/J7SDK_06_01_00/psdk_rtos_auto_j7_06_01_00_15/vision_apps/out/J7/R5F/SYSBIOS/debug/docs
    BUILD_DEFS =  CUSTOM_KERNEL_PATH BUILD_TUTORIAL BUILD_CONFORMANCE_TEST
    J7_SYSBIOS_R5F_3_debug_TIARMCGT_DEFS = SYSBIOS J7 R5F="R5F" TARGET_NUM_CORES=3 TARGET_ARCH=32 ARCH_32 ARM TARGET_BUILD=2
    J7_SYSBIOS_R5F_3_debug_TIARMCGT_LDIRS =
    SCM_ROOT=
    SCM_VERSION=
    TARGET_COMBO=J7:SYSBIOS:A72:1:debug:GCC_SYSBIOS_ARM
    HOST_COMPILER=GCC_SYSBIOS_ARM
    HOST_PLATFORM=PC
    HOST_OS=LINUX
    HOST_CPU=x86_64
    HOST_ARCH=64
    HOST_FAMILY=x86_64
    HOST_NUM_CORES=4
    TARGET_OS=SYSBIOS
    TARGET_CPU=A72
    TARGET_ARCH=64
    TARGET_FAMILY=ARM
    TARGET_NUM_CORES=1
    TARGET_PLATFORM=J7
    TARGET_BUILD=debug
    TARGET_OUT=/media/peterli/work/SDK/J7SDK_06_01_00/psdk_rtos_auto_j7_06_01_00_15/vision_apps/out/J7/A72/SYSBIOS/debug
    TARGET_DOC=/media/peterli/work/SDK/J7SDK_06_01_00/psdk_rtos_auto_j7_06_01_00_15/vision_apps/out/J7/A72/SYSBIOS/debug/docs
    J7_SYSBIOS_A72_1_debug_GCC_SYSBIOS_ARM_DEFS = SYSBIOS J7 A72="A72" TARGET_NUM_CORES=1 TARGET_ARCH=64 ARCH_64 ARM TARGET_BUILD=2
    J7_SYSBIOS_A72_1_debug_GCC_SYSBIOS_ARM_LDIRS =
    SCM_ROOT=
    SCM_VERSION=
    TARGET_COMBO=J7:SYSBIOS:C66:2:debug:CGT6X
    HOST_COMPILER=CGT6X
    HOST_PLATFORM=PC
    HOST_OS=LINUX
    HOST_CPU=x86_64
    HOST_ARCH=64
    HOST_FAMILY=x86_64
    HOST_NUM_CORES=4
    TARGET_OS=SYSBIOS
    TARGET_CPU=C66
    TARGET_ARCH=32
    TARGET_FAMILY=DSP
    TARGET_NUM_CORES=2
    TARGET_PLATFORM=J7
    TARGET_BUILD=debug
    TARGET_OUT=/media/peterli/work/SDK/J7SDK_06_01_00/psdk_rtos_auto_j7_06_01_00_15/vision_apps/out/J7/C66/SYSBIOS/debug
    TARGET_DOC=/media/peterli/work/SDK/J7SDK_06_01_00/psdk_rtos_auto_j7_06_01_00_15/vision_apps/out/J7/C66/SYSBIOS/debug/docs
    J7_SYSBIOS_C66_2_debug_CGT6X_DEFS = SYSBIOS J7 C66="C66" TARGET_NUM_CORES=2 TARGET_ARCH=32 ARCH_32 DSP TARGET_BUILD=2
    J7_SYSBIOS_C66_2_debug_CGT6X_LDIRS =
    SCM_ROOT=
    SCM_VERSION=
    TARGET_COMBO=J7:SYSBIOS:C71:1:debug:CGT7X
    HOST_COMPILER=CGT7X
    HOST_PLATFORM=PC
    HOST_OS=LINUX
    HOST_CPU=x86_64
    HOST_ARCH=64
    HOST_FAMILY=x86_64
    HOST_NUM_CORES=4
    TARGET_OS=SYSBIOS
    TARGET_CPU=C71
    TARGET_ARCH=64
    TARGET_FAMILY=DSP
    TARGET_NUM_CORES=1
    TARGET_PLATFORM=J7
    TARGET_BUILD=debug
    TARGET_OUT=/media/peterli/work/SDK/J7SDK_06_01_00/psdk_rtos_auto_j7_06_01_00_15/vision_apps/out/J7/C71/SYSBIOS/debug
    TARGET_DOC=/media/peterli/work/SDK/J7SDK_06_01_00/psdk_rtos_auto_j7_06_01_00_15/vision_apps/out/J7/C71/SYSBIOS/debug/docs
    J7_SYSBIOS_C71_1_debug_CGT7X_DEFS = SYSBIOS J7 C71="C71" TARGET_NUM_CORES=1 TARGET_ARCH=64 ARCH_64 DSP TARGET_BUILD=2
    J7_SYSBIOS_C71_1_debug_CGT7X_LDIRS =
    SCM_ROOT=
    SCM_VERSION=
    TARGET_COMBO=J7:LINUX:A72:1:debug:GCC_LINUX_ARM
    HOST_COMPILER=GCC_LINUX_ARM
    HOST_PLATFORM=PC
    HOST_OS=LINUX
    HOST_CPU=x86_64
    HOST_ARCH=64
    HOST_FAMILY=x86_64
    HOST_NUM_CORES=4
    TARGET_OS=LINUX
    TARGET_CPU=A72
    TARGET_ARCH=64
    TARGET_FAMILY=ARM
    TARGET_NUM_CORES=1
    TARGET_PLATFORM=J7
    TARGET_BUILD=debug
    TARGET_OUT=/media/peterli/work/SDK/J7SDK_06_01_00/psdk_rtos_auto_j7_06_01_00_15/vision_apps/out/J7/A72/LINUX/debug
    TARGET_DOC=/media/peterli/work/SDK/J7SDK_06_01_00/psdk_rtos_auto_j7_06_01_00_15/vision_apps/out/J7/A72/LINUX/debug/docs
    J7_LINUX_A72_1_debug_GCC_LINUX_ARM_DEFS = LINUX J7 A72="A72" TARGET_NUM_CORES=1 TARGET_ARCH=64 ARCH_64 ARM TARGET_BUILD=2
    J7_LINUX_A72_1_debug_GCC_LINUX_ARM_LDIRS =
    SCM_ROOT=
    SCM_VERSION=
    ### Below make variables control how the SDK is built. Modify as required.
    ### Build flags in vision_apps/vision_apps_build_flags.mak,
    # BUILD_CPU_MPU1=yes
    # BUILD_CPU_MCU2_0=yes
    # BUILD_CPU_MCU2_1=yes
    # BUILD_CPU_C6x_1=yes
    # BUILD_CPU_C6x_2=yes
    # BUILD_CPU_C7x_1=yes
    # BUILD_CPU_MCU1_0=no
    # BUILD_CPU_MCU1_1=no
    # BUILD_CPU_MCU3_0=no
    # BUILD_CPU_MCU3_1=no
    # BUILD_APP_TIRTOS_FILEIO=no
    # BUILD_APP_TIRTOS_LINUX=yes
    # BUILD_PDK_BOARD=j721e_evm
    ### Build flags in tiovx/build_flags.mak,
    # PROFILE=debug
    # BUILD_TARGET_MODE=yes
    # BUILD_EMULATION_MODE=no
    # BUILD_LINUX_A72=yes
    # BUILD_CT_KHR=yes
    # BUILD_CT_TIOVX=yes
    # BUILD_CT_TIOVX_TEST_KERNELS=yes
    # BUILD_CT_TIOVX_IVISION=yes
    # BUILD_CT_TIOVX_TIDL=yes
    # BUILD_CT_TIOVX_HWA=yes
    # BUILD_CT_TIOVX_HWA_NEGATIVE_TESTS=yes
    # BUILD_CONFORMANCE_TEST=yes
    # BUILD_TUTORIAL=yes
    # BUILD_BAM=no
    # BUILD_EMULATION_ARCH=x86_64
  • I restart my PC and received other result and error.
    SHELL=/bin/sh
    TARGET_COMBO=J7:SYSBIOS:R5F:3:release:TIARMCGT
    HOST_ROOT=/opt/psdk_rtos_auto_j7_06_01_00_15/vision_apps
    HOST_PLATFORM=PC
    HOST_OS=LINUX
    HOST_CPU=x86_64
    HOST_ARCH=64
    HOST_FAMILY=x86_64
    HOST_NUM_CORES=8
    TARGET_OS=SYSBIOS
    TARGET_CPU=R5F
    TARGET_ARCH=32
    TARGET_FAMILY=ARM
    TARGET_NUM_CORES=3
    TARGET_PLATFORM=J7
    TARGET_BUILD=release
    TARGET_OUT=/opt/psdk_rtos_auto_j7_06_01_00_15/vision_apps/out/J7/R5F/SYSBIOS/release
    TARGET_DOC=/opt/psdk_rtos_auto_j7_06_01_00_15/vision_apps/out/J7/R5F/SYSBIOS/release/docs
    J7_SYSBIOS_R5F_3_release_TIARMCGT_DEFS = SYSBIOS J7 R5F="R5F" TARGET_NUM_CORES=3 TARGET_ARCH=32 ARCH_32 ARM TARGET_BUILD=1
    J7_SYSBIOS_R5F_3_release_TIARMCGT_LDIRS =
    SCM_ROOT=
    SCM_VERSION=
    TARGET_COMBO=J7:SYSBIOS:A72:1:release:GCC_SYSBIOS_ARM
    HOST_PLATFORM=PC
    HOST_OS=LINUX
    HOST_CPU=x86_64
    HOST_ARCH=64
    HOST_FAMILY=x86_64
    HOST_NUM_CORES=8
    TARGET_OS=SYSBIOS
    TARGET_CPU=A72
    TARGET_ARCH=64
    TARGET_FAMILY=ARM
    TARGET_NUM_CORES=1
    TARGET_PLATFORM=J7
    TARGET_OUT=/opt/psdk_rtos_auto_j7_06_01_00_15/vision_apps/out/J7/A72/SYSBIOS/release
    TARGET_DOC=/opt/psdk_rtos_auto_j7_06_01_00_15/vision_apps/out/J7/A72/SYSBIOS/release/docs
    J7_SYSBIOS_A72_1_release_GCC_SYSBIOS_ARM_DEFS = SYSBIOS J7 A72="A72" TARGET_NUM_CORES=1 TARGET_ARCH=64 ARCH_64 ARM TARGET_BUILD=1
    J7_SYSBIOS_A72_1_release_GCC_SYSBIOS_ARM_LDIRS =
    SCM_ROOT=
    SCM_VERSION=
    TARGET_COMBO=J7:SYSBIOS:C66:2:release:CGT6X
    HOST_COMPILER=CGT6X
    HOST_PLATFORM=PC
    HOST_OS=LINUX
    HOST_CPU=x86_64
    HOST_ARCH=64
    HOST_FAMILY=x86_64
    HOST_NUM_CORES=8
    TARGET_OS=SYSBIOS
    TARGET_CPU=C66
    TARGET_ARCH=32
    TARGET_FAMILY=DSP
    TARGET_NUM_CORES=2
    TARGET_PLATFORM=J7
    TARGET_OUT=/opt/psdk_rtos_auto_j7_06_01_00_15/vision_apps/out/J7/C66/SYSBIOS/release
    TARGET_DOC=/opt/psdk_rtos_auto_j7_06_01_00_15/vision_apps/out/J7/C66/SYSBIOS/release/docs
    J7_SYSBIOS_C66_2_release_CGT6X_DEFS = SYSBIOS J7 C66="C66" TARGET_NUM_CORES=2 TARGET_ARCH=32 ARCH_32 DSP TARGET_BUILD=1
    J7_SYSBIOS_C66_2_release_CGT6X_LDIRS =
    SCM_ROOT=
    SCM_VERSION=
    TARGET_COMBO=J7:SYSBIOS:C71:1:release:CGT7X
    HOST_COMPILER=CGT7X
    HOST_PLATFORM=PC
    HOST_OS=LINUX
    HOST_CPU=x86_64
    HOST_ARCH=64
    HOST_FAMILY=x86_64
    HOST_NUM_CORES=8
    TARGET_OS=SYSBIOS
    TARGET_CPU=C71
    TARGET_ARCH=64
    TARGET_FAMILY=DSP
    TARGET_NUM_CORES=1
    TARGET_PLATFORM=J7
    TARGET_OUT=/opt/psdk_rtos_auto_j7_06_01_00_15/vision_apps/out/J7/C71/SYSBIOS/release
    TARGET_DOC=/opt/psdk_rtos_auto_j7_06_01_00_15/vision_apps/out/J7/C71/SYSBIOS/release/docs
    J7_SYSBIOS_C71_1_release_CGT7X_DEFS = SYSBIOS J7 C71="C71" TARGET_NUM_CORES=1 TARGET_ARCH=64 ARCH_64 DSP TARGET_BUILD=1
    J7_SYSBIOS_C71_1_release_CGT7X_LDIRS =
    SCM_ROOT=
    SCM_VERSION=
    HOST_PLATFORM=PC
    HOST_OS=LINUX
    HOST_CPU=x86_64
    HOST_ARCH=64
    HOST_FAMILY=x86_64
    HOST_NUM_CORES=8
    TARGET_OS=LINUX
    TARGET_CPU=A72
    TARGET_ARCH=64
    TARGET_FAMILY=ARM
    TARGET_NUM_CORES=1
    TARGET_PLATFORM=J7
    TARGET_OUT=/opt/psdk_rtos_auto_j7_06_01_00_15/vision_apps/out/J7/A72/LINUX/release
    TARGET_DOC=/opt/psdk_rtos_auto_j7_06_01_00_15/vision_apps/out/J7/A72/LINUX/release/docs
    J7_LINUX_A72_1_release_GCC_LINUX_ARM_DEFS = LINUX J7 A72="A72" TARGET_NUM_CORES=1 TARGET_ARCH=64 ARCH_64 ARM TARGET_BUILD=1
    J7_LINUX_A72_1_release_GCC_LINUX_ARM_LDIRS =
    SCM_ROOT=
    SCM_VERSION=
    # SDK paths OK !!!
    concerto/prelude.mak:107: recipe for target
    '/opt/psdk_rtos_auto_j7_06_01_00_15/vision_apps/out/J7/R5F/SYSBIOS/release/module/apps.basic_demos.app_tirtos.common+mcu2_1/.gitignor
    failed
    make:
    [/opt/psdk_rtos_auto_j7_06_01_00_15/vision_apps/out/J7/R5F/SYSBIOS/release/module/apps.basic_demos.app_tirtos.common+mcu2_1/.gitignor
    Error 1 (ignored)
    touch: cannot touch
    No such file or directory
    failed
    make:
    Error 1 (ignored)
    [TIARM] Compiling C app_run.c
    Command-line error: cannot open preprocessing output file
    "/opt/psdk_rtos_auto_j7_06_01_00_15/vision_apps/out/J7/R5F/SYSBIOS/release/module/apps.basic_demos.app_tirtos.common+mcu2_1/app_run.d
    1 catastrophic error detected in the compilation of
    "/opt/psdk_rtos_auto_j7_06_01_00_15/vision_apps/apps/basic_demos/app_tirtos/common/app_run.c".
    Compilation terminated.
    >> Compilation failure
    concerto/finale.mak:304: recipe for target
    '/opt/psdk_rtos_auto_j7_06_01_00_15/vision_apps/out/J7/R5F/SYSBIOS/release/module/apps.basic_demos.app_tirtos.common+mcu2_1/app_run.o
    failed
    make: ***
    [/opt/psdk_rtos_auto_j7_06_01_00_15/vision_apps/out/J7/R5F/SYSBIOS/release/module/apps.basic_demos.app_tirtos.common+mcu2_1/app_run.o
    Error 1
    build_flags.mak I changed settings according to document
    BUILD_LINUX_A72=yes
    PROFILE=release
    build_flags.mak
    # currently required to be set to yes
    BUILD_CONFORMANCE_TEST?=yes
    BUILD_TUTORIAL?=yes
    # currently required to be set to no
    BUILD_BAM?=no
    BUILD_IGNORE_LIB_ORDER?=yes
    # Build for SoC
    # Build for x86 PC
    # valid values: X86 x86_64 all
    BUILD_EMULATION_ARCH?=x86_64
    # Flags to enable disable, groups of conformance tests (CT)
    BUILD_CT_KHR=yes
    BUILD_CT_TIOVX=yes
    BUILD_CT_TIOVX_HWA_CAPTURE_TESTS=no
    BUILD_CT_TIOVX_HWA_DISPLAY_TESTS=no
    # valid values: release debug all
    PROFILE=release
    # Applied to target mode only
    BUILD_LINUX_A72=yes
    BUILD_VLAB?=no
  • Alex,
    It looks like maybe the installation was bad or something went wrong during the "Download and install additional dependencies" step.
    Are you sure when you run "./psdk_rtos_auto/scripts/setup_psdk_rtos_auto.sh", you didn't see any error?
    Stanley
    Get:1 security.ubuntu.com/ubuntu bionic-security InRelease [88.7 kB]
    Hit:2 ca.archive.ubuntu.com/ubuntu bionic InRelease
    Get:3 ca.archive.ubuntu.com/ubuntu bionic-updates InRelease [88.7 kB]
    Get:4 ca.archive.ubuntu.com/ubuntu bionic-backports InRelease [74.6 kB]
    Get:5 security.ubuntu.com/ubuntu bionic-security/main amd64 DEP-11 Metadata [38.5 kB]
    Get:6 ca.archive.ubuntu.com/ubuntu bionic-updates/main amd64 Packages [817 kB]
    Get:7 security.ubuntu.com/ubuntu bionic-security/main DEP-11 48x48 Icons [17.6 kB]
    Get:8 security.ubuntu.com/ubuntu bionic-security/main DEP-11 64x64 Icons [41.5 kB]
    Get:9 security.ubuntu.com/ubuntu bionic-security/universe amd64 DEP-11 Metadata [42.1 kB]
    Get:10 security.ubuntu.com/ubuntu bionic-security/universe DEP-11 48x48 Icons [16.4 kB]
    Get:11 security.ubuntu.com/ubuntu bionic-security/universe DEP-11 64x64 Icons [116 kB]
    Get:12 security.ubuntu.com/ubuntu bionic-security/multiverse amd64 DEP-11 Metadata [2,464 B]
    Get:13 ca.archive.ubuntu.com/ubuntu bionic-updates/main i386 Packages [625 kB]
    Get:14 ca.archive.ubuntu.com/ubuntu bionic-updates/main amd64 DEP-11 Metadata [294 kB]
    Get:15 ca.archive.ubuntu.com/ubuntu bionic-updates/main DEP-11 48x48 Icons [73.8 kB]
    Get:16 ca.archive.ubuntu.com/ubuntu bionic-updates/main DEP-11 64x64 Icons [143 kB]
    Get:17 ca.archive.ubuntu.com/ubuntu bionic-updates/universe i386 Packages [997 kB]
    Get:18 ca.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 Packages [1,033 kB]
    Get:19 ca.archive.ubuntu.com/ubuntu bionic-updates/universe amd64 DEP-11 Metadata [264 kB]
    Get:20 ca.archive.ubuntu.com/ubuntu bionic-updates/universe DEP-11 48x48 Icons [201 kB]
    Get:21 ca.archive.ubuntu.com/ubuntu bionic-updates/universe DEP-11 64x64 Icons [447 kB]
    Get:22 ca.archive.ubuntu.com/ubuntu bionic-updates/multiverse amd64 DEP-11 Metadata [2,464
    B]
    Get:23 ca.archive.ubuntu.com/ubuntu bionic-backports/universe amd64 DEP-11 Metadata [7,976
    B]
    Fetched 5,432 kB in 3s (1,949 kB/s)
    Reading package lists... Done
    Building dependency tree
    Reading state information... Done
    Note, selecting 'libgl1-mesa-dev' instead of 'libgl-dev'
    Note, selecting 'libosmesa6-dev' instead of 'libosmesa-dev'
    Note, selecting 'zlib1g:i386' instead of 'libz1:i386'
    bison is already the newest version (2:3.0.4.dfsg-1build1).
    build-essential is already the newest version (12.4ubuntu1).
    diffstat is already the newest version (1.61-1build1).
    flex is already the newest version (2.6.4-6).
    gawk is already the newest version (1:4.1.4+dfsg-1build1).
    libc6-dev-i386 is already the newest version (2.27-3ubuntu1).
    libfreetype6-dev is already the newest version (2.8.1-2ubuntu2).
    libxi-dev is already the newest version (2:1.7.9-1).
    libxmu-dev is already the newest version (2:1.1.2-2).
    zlib1g-dev is already the newest version (1:1.2.11.dfsg-0ubuntu2).
    libc6:i386 is already the newest version (2.27-3ubuntu1).
    zlib1g:i386 is already the newest version (1:1.2.11.dfsg-0ubuntu2).
    chrpath is already the newest version (0.16-2).
    g++-5 is already the newest version (5.5.0-12ubuntu1).
    gcc-5 is already the newest version (5.5.0-12ubuntu1).
    graphviz is already the newest version (2.40.1-2).
    libdevil-dev is already the newest version (1.7.8-10build1).
    libsdl2-image-dev is already the newest version (2.0.3+dfsg1-1).
    mono-runtime is already the newest version (4.6.2.7+dfsg-1ubuntu1).
    texinfo is already the newest version (6.5.0.dfsg.1-2).
    curl is already the newest version (7.58.0-2ubuntu3.8).
    g++-multilib is already the newest version (4:7.4.0-1ubuntu2.3).
    git is already the newest version (1:2.17.1-1ubuntu0.5).
    libgl1-mesa-dev is already the newest version (19.0.8-0ubuntu0~18.04.3).
    libosmesa6-dev is already the newest version (19.0.8-0ubuntu0~18.04.3).
    libpng-dev is already the newest version (1.6.34-1ubuntu0.18.04.2).
    libssl-dev is already the newest version (1.1.1-1ubuntu2.1~18.04.5).
    libtiff-dev is already the newest version (4.0.9-5ubuntu0.3).
    python3 is already the newest version (3.6.7-1~18.04).
    u-boot-tools is already the newest version (2018.07~rc3+dfsg1-0ubuntu3~18.04.1).
    libncurses5:i386 is already the newest version (6.1-1ubuntu1.18.04).
    libstdc++6:i386 is already the newest version (8.3.0-6ubuntu1~18.04.1).
    libsdl2-dev is already the newest version (2.0.8+dfsg1-1ubuntu1.18.04.4).
    0 upgraded, 0 newly installed, 0 to remove and 19 not upgraded.
    [dof] Creating/Updating system link to libDOF.so ...
    [psdkla tisdk-rootfs-image-j7-evm.tar.xz] Checking ...
    [psdkla tisdk-rootfs-image-j7-evm.tar.xz] Done
    [psdkla boot-j7-evm.tar.gz] Checking ...
    [psdkla boot-j7-evm.tar.gz] Done
    [gcc-linaro-7.2.1-2017.11-x86_64_aarch64-elf] Checking ...
    [gcc-linaro-7.2.1-2017.11-x86_64_aarch64-elf] Done
    [gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf] Checking ...
    [gcc-arm-8.3-2019.03-x86_64-arm-linux-gnueabihf] Done
    [gcc-arm-8.3-2019.03-x86_64-aarch64-linux-gnu] Checking ...
    [gcc-arm-8.3-2019.03-x86_64-aarch64-linux-gnu] Done
    [glm] Checking ...
    [glm] Done
    [glew] Checking ...
    [glew] Done
    [pip] Checking ...
    [pip] Checking ... Done
  • Thanks. The script went thru without error.
    The step in make which generated error was try to create a file, /opt/psdk_rtos_auto_j7_06_01_00_15/vision_apps/out/J7/R5F/SYSBIOS/release/module/apps.basic_demos.app_tirtos.common+mcu2_1/.gitignore.
    This is probably a permission issue. Could you check if you can create the file manually under the above path.
    Stanley
  • Yes, it's permission issue. Currently I have ion.h error, but I see it's known error from trouble shooting part in user guide. I will try fix this according to user guide. Thanks
  • The issue was resolved
