I am trying to run two seperate TIDL networks on the two EVEs - EVE1 and EVE2. EVE2 doesnt get connected when I choose 'connect target'. How do I fix this?
Are you able to connect EVE1 core and facing issue only with EVE2 core?
Praveen
Hello Praveen,
Yes, the issue is with EVE2 only. When I run a standalone .out from vision_sdk, EVE2 connects, but upon loading the .out the core doesnt halt. Specifically, the program doesnt hit the main().
When try to use EVE2 in my application, its not even getting connected.
Can you define the below macro to 1 in the "_multicore_reset.gel" gel file and try connecting
#define EVE_SW_CONFIG 1 /* Applicable for EVE_SW users only
* Effective only when
* VISION_SDK_CONFIG == 0
Praveen
Hey, thanks for suggesting. I will try this out, and get back to you within a couple of hours.
Sorry for the tremendous delay in response from my end.
Apparently, there is no EVE_SW_CONFIG macro defined in the DRA7xx_multicore_reset.gel file at my end.
Below are the file contents:
/* This GEL file is loaded on the command line of Code Composer */
/* The StartUp() function is called every time you start */
/* Code Composer. You can customize this function to */
/* initialize wait states or to perform other initialization. */
/* DRA7xx multicore reset config */
#define WR_MEM_32(addr, data) *(unsigned int*)(addr) =(unsigned int)(data)
#define RD_MEM_32(addr) *(unsigned int*)(addr)
#define uint32_t unsigned int
#define DEBUG_PRINT 1
DRA7xx Registers Map Defines: CortexA15_CPU1 view
#define GPMC_TARG 0x00000000
#define MPU_RAM 0x402F0000
#define OCMC_RAM1_TARG 0x40300000
#define OCMC_RAM2_TARG 0x40400000
#define OCMC_RAM3_TARG 0x40500000
#define DSP1_L2_SRAM_TARG 0x40800000
#define DSP1_SYSTEM_TARG 0x40D00000
#define DSP1_MMU0CFG_TARG 0x40D01000
#define DSP1_MMU1CFG_TARG 0x40D02000
#define DSP1_FW0CFG_TARG 0x40D03000
#define DSP1_FW1CFG_TARG 0x40D04000
#define DSP1_EDMA_TC0_TARG 0x40D05000
#define DSP1_EDMA_TC1_TARG 0x40D06000
#define DSP1_NoC_TARG 0x40D07000
#define DSP1_EDMA_CC_TARG 0x40D10000
#define DSP1_L1P_SRAM_TARG 0x40E00000
#define DSP1_L1D_SRAM_TARG 0x40F00000
#define DSP2_L2_SRAM_TARG 0x41000000
#define DSP2_SYSTEM_TARG 0x41500000
#define DSP2_MMU0CFG_TARG 0x41501000
#define DSP2_MMU1CFG_TARG 0x41502000
#define DSP2_FW0CFG_TARG 0x41503000
#define DSP2_FW1CFG_TARG 0x41504000
#define DSP2_EDMA_TC0_TARG 0x41505000
#define DSP2_EDMA_TC1_TARG 0x41506000
#define DSP2_NoC_TARG 0x41507000
#define DSP2_EDMA_CC_TARG 0x41510000
#define DSP2_L1P_SRAM_TARG 0x41600000
#define DSP2_L1D_SRAM_TARG 0x41700000
#define OCMC_RAM1_CBUF_TARG 0x41800000
#define EVE1_TARG 0x42000000
#define EVE2_TARG 0x42100000
#define EVE3_TARG 0x42200000
#define EVE4_TARG 0x42300000
#define EDMA_TPCC_TARG 0x43300000
#define EDMA_TC0_TARG 0x43400000
#define EDMA_TC1_TARG 0x43500000
#define OCMC_ROM_TARG 0x43A00000
#define SN_L3_MAIN_TARG 0x44000000
#define McASP1_TARG 0x45800000
#define McASP2_TARG 0x45C00000
#define McASP3_TARG 0x46000000
#define L4_PER1_TARG 0x48000000
#define MPU_MA 0x482AF000
#define L4_PER2_TARG 0x48400000
#define L4_PER3_TARG 0x48800000
#define OCMC_RAM2_CBUF_TARG 0x49000000
#define OCMC_RAM3_CBUF_TARG 0x49800000
#define L4_CFG_TARG 0x4A000000
#define L4_WKUP_TARG 0x4AE00000
#define QSPI_ADDRSP0_TARG 0x4B300000
#define EMIF1_CONF_REGS 0x4C000000
#define EMIF2_CONF_REGS 0x4D000000
#define DMM_CONF_REGS_TARG 0x4E000000
#define GPMC_CONF_REGS_TARG 0x50000000
#define IPU2_TARGET_TARG 0x55000000
#define GPU_TARG 0x56000000
#define DSS_TARG 0x58000000
#define IPU1_TARGET_TARG 0x58800000
#define BB2D_TARG 0x59000000
#define IVA_CONFIG_TARG 0x5A000000
#define IVA_SL2IF_TARG 0x5B000000
#define QSPI_ADDRSP1_TARG 0x5C000000
#define TILER 0x60000000
#define EMIF1_SDRAM_CS0 0x80000000
#define EMIF2_SDRAM_CS0 0xC0000000
L4_CFG Registers Map Defines: CortexA15_CPU1 view
#define CTRL_MODULE_CORE (L4_CFG_TARG + 0x2000)
#define CM_CORE_AON (L4_CFG_TARG + 0x5000)
#define CM_CORE (L4_CFG_TARG + 0x8000)
L4_WKUP Registers Map Defines: CortexA15_CPU1 view
#define PRM (L4_WKUP_TARG + 0x6000)
PRCM Registers Map Defines: CortexA15_CPU1 view
#define IPU_CM_CORE_AON (CM_CORE_AON + 0x500)
#define DSP1_CM_CORE_AON (CM_CORE_AON + 0x400)
#define DSP2_CM_CORE_AON (CM_CORE_AON + 0x600)
#define EVE1_CM_CORE_AON (CM_CORE_AON + 0x640)
#define EVE2_CM_CORE_AON (CM_CORE_AON + 0x680)
#define EVE3_CM_CORE_AON (CM_CORE_AON + 0x6C0)
#define EVE4_CM_CORE_AON (CM_CORE_AON + 0x700)
#define CORE_CM_CORE (CM_CORE + 0x700)
#define IVA_CM_CORE (CM_CORE + 0xF00)
#define DSP1_PRM (PRM + 0x400)
#define IPU_PRM (PRM + 0x500)
#define CORE_PRM (PRM + 0x700)
#define IVA_PRM (PRM + 0xF00)
#define DSP2_PRM (PRM + 0x1B00)
#define EVE1_PRM (PRM + 0x1B40)
#define EVE2_PRM (PRM + 0x1B80)
#define EVE3_PRM (PRM + 0x1BC0)
#define EVE4_PRM (PRM + 0x1C00)
IPU1 Address Map defines: CortexA15_CPU1 view
#define RM_IPU1_RSTCTRL (IPU_PRM + 0x10)
#define RM_IPU1_RSTST (IPU_PRM + 0x14)
#define CM_IPU1_CLKSTCTRL (IPU_CM_CORE_AON + 0x0)
#define CM_IPU1_IPU1_CLKCTRL (IPU_CM_CORE_AON + 0x20)
#define IPU1_BASE_ADDR (IPU1_TARGET_TARG + 0x20000)
#define IPU1_MMU_CFG (IPU1_TARGET_TARG + 0x80000)
IPU2 Address Map defines: CortexA15_CPU1 view
#define RM_IPU2_RSTCTRL (CORE_PRM + 0x210)
#define RM_IPU2_RSTST (CORE_PRM + 0x214)
#define CM_IPU2_CLKSTCTRL (CORE_CM_CORE + 0x200)
#define CM_IPU2_IPU2_CLKCTRL (CORE_CM_CORE + 0x220)
#define IPU2_BASE_ADDR (IPU2_TARGET_TARG + 0x20000)
#define IPU2_MMU_CFG (IPU2_TARGET_TARG + 0x80000)
IPU CPU Independent defines
#define RM_IPU_RSTCTRL ((cpu_num == 1) ? (RM_IPU1_RSTCTRL) : (RM_IPU2_RSTCTRL))
#define RM_IPU_RSTST ((cpu_num == 1) ? (RM_IPU1_RSTST) : (RM_IPU2_RSTST))
#define IPU_BASE_ADDR ((cpu_num == 1) ? (IPU1_BASE_ADDR) : (IPU2_BASE_ADDR))
#define IPU_MMU_CFG ((cpu_num == 1) ? (IPU1_MMU_CFG) : (IPU2_MMU_CFG))
DSPSS1 Address Map defines: CortexA15_CPU1 view
#define CM_DSP1_CLKSTCTRL (DSP1_CM_CORE_AON + 0x0)
#define CM_DSP1_DSP1_CLKCTRL (DSP1_CM_CORE_AON + 0x20)
#define RM_DSP1_RSTCTRL (DSP1_PRM + 0x10)
#define RM_DSP1_RSTST (DSP1_PRM + 0x14)
#define DSPSS1BOOTADDR (CTRL_MODULE_CORE + 0x55C)
#define DSPSS1BOOTADDRVALUE (DSP1_L2_SRAM_TARG - 0x40000000)
DSPSS2 Address Map defines: CortexA15_CPU1 view
#define CM_DSP2_CLKSTCTRL (DSP2_CM_CORE_AON + 0x0)
#define CM_DSP2_DSP2_CLKCTRL (DSP2_CM_CORE_AON + 0x20)
#define RM_DSP2_RSTCTRL (DSP2_PRM + 0x10)
#define RM_DSP2_RSTST (DSP2_PRM + 0x14)
#define DSPSS2BOOTADDR (CTRL_MODULE_CORE + 0x560)
#define DSPSS2BOOTADDRVALUE (DSP2_L2_SRAM_TARG - 0x40800000)
DSPSS CPU Independent defines
#define CM_DSP_CLKSTCTRL ((cpu_num == 1) ? (CM_DSP1_CLKSTCTRL) : (CM_DSP2_CLKSTCTRL))
#define CM_DSP_DSP_CLKCTRL ((cpu_num == 1) ? (CM_DSP1_DSP1_CLKCTRL) : (CM_DSP2_DSP2_CLKCTRL))
#define RM_DSP_RSTCTRL ((cpu_num == 1) ? (RM_DSP1_RSTCTRL) : (RM_DSP2_RSTCTRL))
#define RM_DSP_RSTST ((cpu_num == 1) ? (RM_DSP1_RSTST) : (RM_DSP2_RSTST))
#define DSPSSBOOTADDR ((cpu_num == 1) ? (DSPSS1BOOTADDR) : (DSPSS2BOOTADDR))
#define DSPSSBOOTADDRVALUE ((cpu_num == 1) ? (DSPSS1BOOTADDRVALUE) : (DSPSS2BOOTADDRVALUE))
#define DSP_L2_SRAM_TARG ((cpu_num == 1) ? (DSP1_L2_SRAM_TARG) : (DSP2_L2_SRAM_TARG))
EVESS1 Address Map defines: CortexA15_CPU1 view
#define CM_EVE1_CLKSTCTRL (EVE1_CM_CORE_AON + 0x0)
#define CM_EVE1_EVE1_CLKCTRL (EVE1_CM_CORE_AON + 0x20)
#define RM_EVE1_RSTCTRL (EVE1_PRM + 0x10)
#define RM_EVE1_RSTST (EVE1_PRM + 0x14)
#define EVE1_MMU0_BASE (EVE1_TARG + 0x81000)
#define EVE1_MMU1_BASE (EVE1_TARG + 0x82000)
EVESS2 Address Map defines: CortexA15_CPU1 view
#define CM_EVE2_CLKSTCTRL (EVE2_CM_CORE_AON + 0x0)
#define CM_EVE2_EVE2_CLKCTRL (EVE2_CM_CORE_AON + 0x20)
#define RM_EVE2_RSTCTRL (EVE2_PRM + 0x10)
#define RM_EVE2_RSTST (EVE2_PRM + 0x14)
#define EVE2_MMU0_BASE (EVE2_TARG + 0x81000)
#define EVE2_MMU1_BASE (EVE2_TARG + 0x82000)
EVESS3 Address Map defines: CortexA15_CPU1 view
#define CM_EVE3_CLKSTCTRL (EVE3_CM_CORE_AON + 0x0)
#define CM_EVE3_EVE3_CLKCTRL (EVE3_CM_CORE_AON + 0x20)
#define RM_EVE3_RSTCTRL (EVE3_PRM + 0x10)
#define RM_EVE3_RSTST (EVE3_PRM + 0x14)
#define EVE3_MMU0_BASE (EVE3_TARG + 0x81000)
#define EVE3_MMU1_BASE (EVE3_TARG + 0x82000)
EVESS4 Address Map defines: CortexA15_CPU1 view
#define CM_EVE4_CLKSTCTRL (EVE4_CM_CORE_AON + 0x0)
#define CM_EVE4_EVE4_CLKCTRL (EVE4_CM_CORE_AON + 0x20)
#define RM_EVE4_RSTCTRL (EVE4_PRM + 0x10)
#define RM_EVE4_RSTST (EVE4_PRM + 0x14)
#define EVE4_MMU0_BASE (EVE4_TARG + 0x81000)
#define EVE4_MMU1_BASE (EVE4_TARG + 0x82000)
EVESS CPU Independent defines
#define CM_EVE_CLKSTCTRL ((cpu_num == 1) ? (CM_EVE1_CLKSTCTRL) : ((cpu_num == 2) ? (CM_EVE2_CLKSTCTRL) : ((cpu_num == 3) ? (CM_EVE3_CLKSTCTRL) : (CM_EVE4_CLKSTCTRL))))
#define CM_EVE_EVE_CLKCTRL ((cpu_num == 1) ? (CM_EVE1_EVE1_CLKCTRL) : ((cpu_num == 2) ? (CM_EVE2_EVE2_CLKCTRL) : ((cpu_num == 3) ? (CM_EVE3_EVE3_CLKCTRL) : (CM_EVE4_EVE4_CLKCTRL))))
#define RM_EVE_RSTCTRL ((cpu_num == 1) ? (RM_EVE1_RSTCTRL) : ((cpu_num == 2) ? (RM_EVE2_RSTCTRL) : ((cpu_num == 3) ? (RM_EVE3_RSTCTRL) : (RM_EVE4_RSTCTRL))))
#define RM_EVE_RSTST ((cpu_num == 1) ? (RM_EVE1_RSTST) : ((cpu_num == 2) ? (RM_EVE2_RSTST) : ((cpu_num == 3) ? (RM_EVE3_RSTST) : (RM_EVE4_RSTST))))
#define EVE_MMU0_BASE ((cpu_num == 1) ? (EVE1_MMU0_BASE) : ((cpu_num == 2) ? (EVE2_MMU0_BASE) : ((cpu_num == 3) ? (EVE3_MMU0_BASE) : (EVE4_MMU0_BASE))))
#define EVE_MMU1_BASE ((cpu_num == 1) ? (EVE1_MMU1_BASE) : ((cpu_num == 2) ? (EVE2_MMU1_BASE) : ((cpu_num == 3) ? (EVE3_MMU1_BASE) : (EVE4_MMU1_BASE))))
#define EVE_MMU_PAGESIZE_1M 0
#define EVE_MMU_PAGESIZE_64K 1
#define EVE_MMU_PAGESIZE_4K 2
#define EVE_MMU_PAGESIZE_16M 3
#define EVE_MMU_BASE ((mmu_num == 0) ? (EVE_MMU0_BASE) : (EVE_MMU1_BASE))
#define EVE_MMU_SYSCONFIG ( EVE_MMU_BASE + 0x10 )
#define EVE_MMU_SYSSTATUS ( EVE_MMU_BASE + 0x14 )
#define EVE_MMU_CNTL ( EVE_MMU_BASE + 0x44 )
#define EVE_MMU_FAULT_AD ( EVE_MMU_BASE + 0x48 )
#define EVE_MMU_CAM ( EVE_MMU_BASE + 0x58 )
#define EVE_MMU_RAM ( EVE_MMU_BASE + 0x5c )
#define EVE_MMU_LOCK ( EVE_MMU_BASE + 0x50 )
#define EVE_MMU_LD_TLB ( EVE_MMU_BASE + 0x54 )
#define EVE_MMU_EMU_FAULT_AD ( EVE_MMU_BASE + 0x70 )
IVASS Address Map defines: CortexA15_CPU1 view
#define CM_IVA_CLKSTCTRL (IVA_CM_CORE + 0x0)
#define CM_IVA_IVA_CLKCTRL (IVA_CM_CORE + 0x20)
#define CM_IVA_SL2_CLKCTRL (IVA_CM_CORE + 0x28)
#define RM_IVA_RSTCTRL (IVA_PRM + 0x10)
#define RM_IVA_RSTST (IVA_PRM + 0x14)
#define ICONT1_ITCM (IVA_CONFIG_TARG + 0x08000)
#define ICONT2_ITCM (IVA_CONFIG_TARG + 0x18000)
menuitem "DRA7xx MULTICORE Initialization"
/************ Enable all slave cores ***************/
hotmenu DRA7xx_MULTICORE_EnableAllCores()
IPU1SSClkEnable_API();
IPU2SSClkEnable_API(); /* REMOVE FOR ADAS */
DSP1SSClkEnable_API();
DSP2SSClkEnable_API();
EVE1SSClkEnable_API();
EVE2SSClkEnable_API();
EVE3SSClkEnable_API();
EVE4SSClkEnable_API();
IVAHDSSClkEnable_API();
PRUSS_1_2_ClkEnable();
/************ Enable the PRUSS Clocks **************/
hotmenu PRUSS_1_2_ClkEnable()
GEL_TextOut("--->>> PRUSS 1 and 2 Initialization is in progress ... <<<---\n");
WR_MEM_32(0x4a009718, 0x0); //PRUSS_1_CLKCTRL
WR_MEM_32(0x4a009720, 0x0); //PRUSS_2_CLKCTRL
WR_MEM_32(0x4a009718, 0x2); //PRUSS_1_CLKCTRL
WR_MEM_32(0x4a009720, 0x2); //PRUSS_2_CLKCTRL
while ((RD_MEM_32(0x4a0098FC) & 0x100) != 0x100); //L4PER2 - ICSS_CLKACTIVITY
GEL_TextOut("--->>> PRUSS 1 and 2 Initialization is in complete ... <<<---\n");
/************ Enable the IPU1 Clocks ***************/
hotmenu IPU1SSClkEnable_API()
IPUSSClkEnable(1);
/* BEGIN REMOVE FOR ADAS */
/************ Enable the IPU2 Clocks ***************/
hotmenu IPU2SSClkEnable_API()
IPUSSClkEnable(2);
/* END REMOVE FOR ADAS */
/************ Enable the DSP1 Clocks ***************/
hotmenu DSP1SSClkEnable_API()
DSPSSClkEnable(1);
/************ Enable the DSP2 Clocks ***************/
hotmenu DSP2SSClkEnable_API()
DSPSSClkEnable(2);
/************ Enable the EVE1 Clocks ***************/
hotmenu EVE1SSClkEnable_API()
EVESSClkEnable(1);
/************ Enable the EVE2 Clocks ***************/
hotmenu EVE2SSClkEnable_API()
EVESSClkEnable(2);
/************ Enable the EVE3 Clocks ***************/
hotmenu EVE3SSClkEnable_API()
EVESSClkEnable(3);
/************ Enable the EVE4 Clocks ***************/
hotmenu EVE4SSClkEnable_API()
EVESSClkEnable(4);
/************ Enable the IVA Clocks ***************/
hotmenu IVAHDSSClkEnable_API()
IVAHDSSClkEnable();
IPUSSClkEnable(uint32_t cpu_num)
uint32_t regVal, regAddr;
GEL_TextOut("--->>> IPU%dSS Initialization is in progress ... <<<---\n",,,,, cpu_num);
/* Reset asserted for IPU CPU0, CPU1, Unicache and MMU */
WR_MEM_32(RM_IPU_RSTCTRL, 0x7);
/* Reset deassertion for IPU Unicache/MMU */
WR_MEM_32(RM_IPU_RSTST, 0x7);
WR_MEM_32(RM_IPU_RSTCTRL, 0x3);
while ((RD_MEM_32(RM_IPU_RSTST) & 0x4) != 0x4);
/*---------------- Setup the UNICACHE MMU -----------------*/
/*Large Page Translations */
/* Logical Address */
regAddr = IPU_MMU_CFG;
regAddr += 0x800;
WR_MEM_32(regAddr, 0x40000000); regAddr += 0x4;
WR_MEM_32(regAddr, 0x80000000); regAddr += 0x4;
WR_MEM_32(regAddr, 0xA0000000); regAddr += 0x4;
WR_MEM_32(regAddr, 0x60000000); regAddr += 0x4;
/* Physical Address */
regAddr += 0x820;
/* Policy Register */
regAddr += 0x840;
WR_MEM_32(regAddr, 0x00000007); regAddr += 0x4;
WR_MEM_32(regAddr, 0x000B0007); regAddr += 0x4;
WR_MEM_32(regAddr, 0x00020007); regAddr += 0x4;
/*Medium Page*/
regAddr += 0x860;
WR_MEM_32(regAddr, 0x00300000); regAddr += 0x4;
WR_MEM_32(regAddr, 0x00400000); regAddr += 0x4;
regAddr += 0x8A0;
WR_MEM_32(regAddr, 0x40300000); regAddr += 0x4;
WR_MEM_32(regAddr, 0x40400000); regAddr += 0x4;
regAddr += 0x8E0;
/*Small Page*/
regAddr += 0x920;
WR_MEM_32(regAddr, 0x00000000); regAddr += 0x4;
WR_MEM_32(regAddr, 0x00004000); regAddr += 0x4;
WR_MEM_32(regAddr, 0x00008000); regAddr += 0x4;
WR_MEM_32(regAddr, 0x20000000); regAddr += 0x4;
regAddr += 0x9A0;
WR_MEM_32(regAddr, 0x55020000); regAddr += 0x4;
WR_MEM_32(regAddr, 0x55080000); regAddr += 0x4;
WR_MEM_32(regAddr, 0x55024000); regAddr += 0x4;
WR_MEM_32(regAddr, 0x55028000); regAddr += 0x4;
regAddr += 0xA20;
WR_MEM_32(regAddr, 0x0001000B); regAddr += 0x4;
WR_MEM_32(regAddr, 0x0000000B); regAddr += 0x4;
WR_MEM_32(regAddr, 0x00010007); regAddr += 0x4;
/*---------------- Write IPU IRAM Boot Image ---------------*/
/* This puts the cores into dummy loops to prevent them from running bad code */
WR_MEM_32(IPU_BASE_ADDR, 0x10000);
WR_MEM_32(IPU_BASE_ADDR + 0x4, 0x9);
WR_MEM_32(IPU_BASE_ADDR + 0x8, 0xE7FEE7FE);
while (RD_MEM_32(IPU_BASE_ADDR) != 0x10000);
while (RD_MEM_32(IPU_BASE_ADDR + 0x4) != 0x9);
while (RD_MEM_32(IPU_BASE_ADDR + 0x8) != 0xE7FEE7FE);
/* Reset deassertion for IPU CPU0, CPU1 */
WR_MEM_32(RM_IPU_RSTCTRL, 0x0);
/* Check the reset state: IPU CPU0, CPU1, Unicache and MMU are out of reset */
while ((RD_MEM_32(RM_IPU_RSTST) & 0x3) != 0x3);
GEL_TextOut("--->>> IPU%dSS Initialization is DONE! <<<---\n",,,,,cpu_num);
DSPSSClkEnable(uint32_t cpu_num)
uint32_t i, fail = 0;
GEL_TextOut("--->>> DSP%dSS Initialization is in progress ... <<<---\n",,,,,cpu_num);
/* DSPSS Boot Address */
WR_MEM_32(DSPSSBOOTADDR, (DSPSSBOOTADDRVALUE >> 10));
/* Ware reset asserted for DSP_LRST, DSP Cache and Slave */
WR_MEM_32(RM_DSP_RSTCTRL, 0x3);
/* Start a SW force wakeup for DSPSS */
WR_MEM_32(CM_DSP_CLKSTCTRL, 0x2);
/* Enable DSPSS clock */
WR_MEM_32(CM_DSP_DSP_CLKCTRL, 0x1);
/* Check whether GFCLK is gated or not */
while ((RD_MEM_32(CM_DSP_CLKSTCTRL) & 0x100) != 0x100);
if (DEBUG_PRINT)
GEL_TextOut("DEBUG: Clock is active ... \n");
/* Reset de-assertion for DSPSS */
WR_MEM_32(RM_DSP_RSTCTRL, 0x1);
/* Check the reset state: DSPSS */
while ((RD_MEM_32(RM_DSP_RSTST) & 0x2) != 0x2);
WR_MEM_32(DSP_L2_SRAM_TARG, 0x0000A120); //Self branch loop for DSP
/* Reset de-assertion for DSP CPUs */
WR_MEM_32(RM_DSP_RSTCTRL, 0x0);
/* Check the reset state: DSPSS Core, Cache and Slave interface */
while ((RD_MEM_32(RM_DSP_RSTST) & 0x3) != 0x3);
/* Check module mode */
while ((RD_MEM_32(CM_DSP_DSP_CLKCTRL) & 0x30000) != 0x0);
if (DEBUG_PRINT)
GEL_TextOut("DEBUG: Checking for data integrity in DSPSS L2RAM ... \n");
for (i = 1; i < 16; i++)
WR_MEM_32((DSP_L2_SRAM_TARG + (i << 2)), 0x12345678);
if (RD_MEM_32(DSP_L2_SRAM_TARG + (i << 2)) != 0x12345678)
fail++;
break;
if (fail)
GEL_TextOut("ERROR: Data integrity check in GEM L2RAM has failed! \n");
else
if (DEBUG_PRINT)
GEL_TextOut("DEBUG: Data integrity check in GEM L2RAM is sucessful! \n");
GEL_TextOut("--->>> DSP%dSS Initialization is DONE! <<<---\n",,,,,cpu_num);
EVESSClkEnable(uint32_t cpu_num)
GEL_TextOut("--->>> EVE%dSS Initialization is in progress ... <<<---\n",,,,, cpu_num);
/* Ware reset asserted for EVE_LRST, EVE Cache and Slave */
WR_MEM_32(RM_EVE_RSTCTRL, 0x3);
/* Start a SW force wakeup for EVESS */
WR_MEM_32(CM_EVE_CLKSTCTRL, 0x2);
/* Enable EVESS clock */
WR_MEM_32(CM_EVE_EVE_CLKCTRL, 0x1);
while ((RD_MEM_32(CM_EVE_CLKSTCTRL) & 0x100) != 0x100);
if (DEBUG_PRINT)
/* Reset de-assertion for EVESS */
WR_MEM_32(RM_EVE_RSTCTRL, 0x1);
/* Check the reset state: EVESS */
while ((RD_MEM_32(RM_EVE_RSTST) & 0x2) != 0x2);
EVE_MMU0_Config(cpu_num);
/* Reset de-assertion for EVESS CPUs */
WR_MEM_32(RM_EVE_RSTCTRL, 0x0);
/* Check the reset state: EVESS Core, Cache and Slave interface */
while ((RD_MEM_32(RM_EVE_RSTST) & 0x3) != 0x3);
while ((RD_MEM_32(CM_EVE_EVE_CLKCTRL) & 0x30000) != 0x0);
WR_MEM_32(RM_EVE_RSTST, 0x3);
GEL_TextOut("--->>> EVE%dSS Initialization is DONE! <<<---\n",,,,, cpu_num);
IVAHDSSClkEnable()
GEL_TextOut("--->>> IVAHD Initialization is in progress ... <<<---\n");
/* Start a SW force wakeup for IVASS */
WR_MEM_32(CM_IVA_CLKSTCTRL, 0x2);
/* Enable IVASS clock */
WR_MEM_32(CM_IVA_IVA_CLKCTRL, 0x1);
/* Enable IVA SL2 clock */
WR_MEM_32(CM_IVA_SL2_CLKCTRL, 0x1);
while ((RD_MEM_32(CM_IVA_CLKSTCTRL) & 0x100) != 0x100);
if (DEBUG_PRINT)
/* Warm reset asserted for CPU1, CPU2, IVA Logic */
WR_MEM_32(RM_IVA_RSTCTRL, 0x7);
WR_MEM_32(RM_IVA_RSTST, 0x7);
/* Warm reset asserted for CPU1, CPU2 */
WR_MEM_32(RM_IVA_RSTCTRL, 0x3);
/* Check the reset state: IVA Logic */
while ((RD_MEM_32(RM_IVA_RSTST) & 0x4) != 0x4);
/* Self branch instruction */
WR_MEM_32(ICONT1_ITCM, 0xEAFFFFFE);
WR_MEM_32(ICONT2_ITCM, 0xEAFFFFFE);
/* Reset de-assertion for CPU1, CPU2 */
WR_MEM_32(RM_IVA_RSTCTRL, 0x1);
while ((RD_MEM_32(RM_IVA_RSTST) & 0x6) != 0x6);
WR_MEM_32(RM_IVA_RSTCTRL, 0x0);
while ((RD_MEM_32(RM_IVA_RSTST) & 0x7) != 0x7);
GEL_TextOut("--->>> IVAHD Initialization is DONE! ... <<<---\n");
SetupEveMmuEntry(uint32_t cpu_num, uint32_t mmu_num, uint32_t entryNum, uint32_t virtAddr, uint32_t physAddr, uint32_t pageSize)
GEL_TextOut("DEBUG: Configuring EVE%d MMU%d TLB entry %u: %x --> %x \n",,,,, cpu_num, mmu_num, entryNum, virtAddr, physAddr);
WR_MEM_32(EVE_MMU_CAM, 0x0000000c | (pageSize & 3) | (virtAddr & 0xFFFFE000));
WR_MEM_32(EVE_MMU_RAM, 0x000001c0 | (physAddr & 0xFFFFE000));
WR_MEM_32(EVE_MMU_LOCK, ((RD_MEM_32(EVE_MMU_LOCK)) & 0xFFFFFE0F) | ( entryNum << 4 ));
WR_MEM_32(EVE_MMU_LD_TLB, 1);
EVE_MMU0_Config(uint32_t cpu_num)
uint32_t mmu_num = 0;
/* Reset the MMU */
GEL_TextOut("DEBUG: Resetting EVE MMU ... \n",,,,,,);
WR_MEM_32(EVE_MMU_SYSCONFIG, 2);
/* Wait until MMU reset finished */
while((RD_MEM_32(EVE_MMU_SYSSTATUS) & 1) == 0);
/* Configure the MMU */
/* CAM[1:0] - Page Size: 0=1MB, 1=64kB, 2=4kB, 3=16MB */
/* CAM[2] - Valid bit */
/* CAM[3] - Preserved (protected against flushs) */
/* CAM[31:12] - Virtual address tag */
/* CAM = 0xC --> 1 MB */
/* CAM = 0xF --> 16 MB */
/* RAM[6] - Mixed page attribute: 0 use TLB element size, 1 use CPU element size */
/* RAM[8:7] - Element size 0=8 bits, 1=16 bits, 2=32 bits, 3=no translation */
/* RAM[9] - Endianness of the page (0=little, 1=big) */
/* RAM[31:12] - Physical address of the page */
/* RAM = 0x1C0 --> CPU element size, no translation */
/* TLB 1 is zero virtual address mapped to OCMC3 (required for the CPU to work) */
/* Translate only small page (4kB) for reset vector */
SetupEveMmuEntry(cpu_num, mmu_num, 1, 0x00000000, 0x40500000, EVE_MMU_PAGESIZE_4K);
/* Writing a Self branch loop at reset address (required for the CPU to connect reliably) */
WR_MEM_32(0x40500000, 0x00000100);
WR_MEM_32(0x40500100, 0x004a03FF);
WR_MEM_32(0x40500104, 0x03FF03FF);
/* Enable access to entire DDR */
SetupEveMmuEntry(cpu_num, mmu_num, 2, 0x80000000, 0x80000000, EVE_MMU_PAGESIZE_16M);
SetupEveMmuEntry(cpu_num, mmu_num, 3, 0x81000000, 0x81000000, EVE_MMU_PAGESIZE_16M);
SetupEveMmuEntry(cpu_num, mmu_num, 4, 0x82000000, 0x82000000, EVE_MMU_PAGESIZE_16M);
SetupEveMmuEntry(cpu_num, mmu_num, 5, 0x83000000, 0x83000000, EVE_MMU_PAGESIZE_16M);
SetupEveMmuEntry(cpu_num, mmu_num, 6, 0x84000000, 0x84000000, EVE_MMU_PAGESIZE_16M);
SetupEveMmuEntry(cpu_num, mmu_num, 7, 0x85000000, 0x85000000, EVE_MMU_PAGESIZE_16M);
SetupEveMmuEntry(cpu_num, mmu_num, 8, 0x86000000, 0x86000000, EVE_MMU_PAGESIZE_16M);
SetupEveMmuEntry(cpu_num, mmu_num, 9, 0x87000000, 0x87000000, EVE_MMU_PAGESIZE_16M);
/* Enable access to some of configuration space and OCMC memories */
SetupEveMmuEntry(cpu_num, mmu_num, 10, 0x40000000, 0x40000000, EVE_MMU_PAGESIZE_16M);
/* Enable MMU */
WR_MEM_32(EVE_MMU_CNTL, ((RD_MEM_32(EVE_MMU_CNTL)) & 0xFFFFFFFD) | 0x2);
GEL_TextOut("DEBUG: MMU0 configured for EVE%d \n",,,,,, cpu_num);
How to proceed further?
Can you try with below...
IPUSSClkEnable(1);
IPUSSClkEnable(2);
DSPSSClkEnable(1);
DSPSSClkEnable(2);
EVESSClkEnable(1);
EVESSClkEnable(2);
EVESSClkEnable(3);
EVESSClkEnable(4);
IVAHDSSClkEnable();
regAddr += 0x800;
regAddr += 0x820;
regAddr += 0x840;
/*Medium Page*/
regAddr += 0x860;
WR_MEM_32(regAddr, 0x80300000); regAddr += 0x4;
regAddr += 0x8A0;
regAddr += 0x8E0;
/*Small Page*/
regAddr += 0x920;
regAddr += 0x9A0;
regAddr += 0xA20;
if (DEBUG_PRINT)
if (DEBUG_PRINT)
fail++;
break;
if (fail)
else
if (DEBUG_PRINT)
if (DEBUG_PRINT)
IVAHDSSClkEnable()
if (DEBUG_PRINT)
/* Reset the MMU */
SetupEveMmuEntry(cpu_num, mmu_num, 1, 0x00000000, 0x80000000, EVE_MMU_PAGESIZE_4K);
WR_MEM_32(0x80000000, 0x00000100);
WR_MEM_32(0x80000100, 0x004a03FF);
WR_MEM_32(0x80000104, 0x03FF03FF);
SetupEveMmuEntry(cpu_num, mmu_num, 11, 0x45000000, 0x45000000, EVE_MMU_PAGESIZE_16M);
/* Enable MMU */
Praveen
I haven't heard back from you, I'm assuming you were able to resolve your issue.
If not, just post a reply below (or create a new thread if the thread has locked due to time-out).
Praveen
