Compiler/TDA2EX17EVM: [Build Issue] errors encountered during linking
Part Number: TDA2EX17EVM
Other Parts Discussed in Thread: TDA2, SYSBIOS
Hi TI Team
I modify usecase framecopy (vision_sdk\apps\src\rtos\alg_plugins\framecopy) to be my algorithm link and add a API in "Alg_FrameCopyProcess"(frameCopyAlgoLocalDma.c).But I build SDK fail and have the errors as below:
"E:/jacob_adb/PROCESSOR_SDK_VISION_03_07_00_00/vision_sdk/binaries/apps/tda2ex_evm_bios_all/obj/vision_sdk/tda2ex-evm/c66xdsp_1/release/vision_sdk_configuro/linker_mod.cmd", line 202: error:
program will not fit into available memory. placement with alignment fails
for section ".cinit" size 0x35c8be . Available memory ranges:
DSP1_DATA_MEM size: 0xd00000 unused: 0x2db2b2 max hole: 0x2db2a4
error: errors encountered during linking;
ex_evm_bios_all/vision_sdk/bin/tda2ex-evm/vision_sdk_c66xdsp_1_release.xe66"
not built
gmake[7]: *** [E:/jacob_adb/PROCESSOR_SDK_VISION_03_07_00_00/vision_sdk/binaries/apps/tda2ex_evm_bios_all/vision_sdk/bin/tda2ex-evm/vision_sdk_c66xdsp_1_release.xe66] Error 1
gmake[7]: Leaving directory `E:/jacob_adb/PROCESSOR_SDK_VISION_03_07_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2ex/dsp1'
gmake[6]: *** [c66xdsp_1] Error 2
gmake[6]: Leaving directory `E:/jacob_adb/PROCESSOR_SDK_VISION_03_07_00_00/vision_sdk/links_fw/src/rtos/bios_app_common/tda2ex/dsp1'
gmake[5]: *** [apps_dsp1] Error 2
gmake[5]: Leaving directory `E:/jacob_adb/PROCESSOR_SDK_VISION_03_07_00_00/vision_sdk/links_fw/src/rtos'
gmake[4]: *** [apps] Error 2
gmake[4]: Leaving directory `E:/jacob_adb/PROCESSOR_SDK_VISION_03_07_00_00/vision_sdk/links_fw/src/rtos'
gmake[3]: *** [apps] Error 2
gmake[3]: Leaving directory `E:/jacob_adb/PROCESSOR_SDK_VISION_03_07_00_00/vision_sdk/apps'
gmake[2]: *** [apps_exe] Error 2
gmake[2]: Leaving directory `E:/jacob_adb/PROCESSOR_SDK_VISION_03_07_00_00/vision_sdk/build'
gmake[1]: *** [apps] Error 2
gmake[1]: Leaving directory `E:/jacob_adb/PROCESSOR_SDK_VISION_03_07_00_00/vision_sdk/build'
gmake: *** [vision_sdk] Error 2
I add the same API in "Alg_FrameCopyProcess"(frameCopyAlgoCpu.c) and it's OK.Could you give me some suggestions for the issue? Thanks so much.
Jacob Lin
    Its better that you increase your DSP data memory in memory map file by reducing any unwanted section size.
    please refer below doc
    vision_sdk\docs\FeatureSpecificUserGuides\VisionSDK_UserGuide_MemoryMap.pdf
    Anuj
  • Hi Anuj
    I refer the document to modify the DSP1_DATA_MEM and get another error as below:
    [IPU1-1] 13.359330 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [IPU1-1] 13.359482 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254984 B (249 KB)
    [HOST ] 13.359940 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [HOST ] 13.359940 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 6291456 B (6144 KB), Free size = 6250736 B (6104 KB)
    [DSP1 ] 11.861038 s: IPC_IN_0 : Create in progress !!!
    [DSP1 ] 11.861465 s: IPC_IN_0 : Create Done !!!
    [DSP1 ] 11.861648 s: ALGORITHM: Create in progress (algId = 0) !!!
    [DSP1 ] 11.861739 s: ALG_FRAMECOPY: DMA: Allocated CH (TCC) = 0 (0)
    [DSP1 ] 11.873574 s: ALGORITHM: Create Done (algId = 0) !!!
    [DSP1 ] 11.873726 s: IPC_OUT_0 : Create in progress !!!
    [DSP1 ] 11.873787 s: IPC_OUT_0 : Create Done !!!
    [DSP1 ] 13.360184 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [DSP1 ] 13.360214 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
    [DSP1 ] 13.360245 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 504528 B (492 KB)
    [IPU2 ] 13.360733 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
    [IPU2 ] 13.360855 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254936 B (248 KB)
    [DSP1 ] 13.859177 s:
    [DSP1 ] 13.859208 s: ### XDC ASSERT - ERROR CALLBACK START ###
    [DSP1 ] 13.859238 s:
    [DSP1 ] 13.859299 s: out of memory: handle=0x83d8b9b0, size=3686408
    [DSP1 ] 13.859330 s:
    [DSP1 ] 13.859330 s: ### XDC ASSERT - ERROR CALLBACK END ###
    [DSP1 ] 13.859360 s:
    [DSP1 ] 13.859482 s: ti.sysbios.heaps.HeapMem: line 221: ti.sysbios.heaps.HeapMem: line 221: out of memory: handle=0x83d8b9b0, size=3686408
    Do you give me suggestion again? Thanks a lot.
    Jacob Lin
    Why are you allocating 3 MB of data from DSP1 local heap.
    We allocate only very small data from local heap.
    If the data size is large then please use Ulits_memAlloc() ang provide heapId as SR1.
    Anuj
  • Hi Anuj
    OK and I have resolved the issue.Thanks.
    Jacob Lin
