Compiler/EVMK2EX: make ti-ipc-linux
Part Number: EVMK2EX
        Recently,  I just run the TI IPC demo, I installed the PRO SDK and RTOS SDK on Ubuntu 16.04 LTS.
        When I built IPC, the terminal showed as the following:
       " If you wish to build IPC, please install Processor SDK RTOS 06.01.00.08 for k2e-evm and set TI_RTOS_PATH in Rules.make."
        And I tried to set the path in the Rules.make, but it showed: " No such file or directory ."
        Any solutions to solve this problem?
        yours,
       Suafie
    You want to build the linux example, right? In this case check the IPC guide:
      Needed commands are:
    export PATH=<sdk path>/linux-devkit/sysroots/x86_64-arago-linux/usr/bin:$PATH
    export TI_RTOS_PATH=<RTOS_SDK_INSTALL_DIR>
    export IPC_INSTALL_PATH=<RTOS_SDK_IPC_DIR>
    make ti-ipc-linux
    Yordan
