Compiler/TDA2PXEVM: Linux: Assertion while creating new plugin in linux:
Part Number: TDA2PXEVM
Hi all,
I created new plugin which for DSP1 and my usecase is as follows:
NullSource (A15) -> Decode -> VPE -> Alg_plugin (DSP1) -> Display
I have created plugin in rtos and my usecase is in hlos/adas/src/usecases .
I'm getting following assertion.
 [HOST] [HOST  ]     77.551302 s:  IPC_OUT_0   : Create in progress !!!
 [HOST] [HOST  ]     77.551363 s:  IPC_OUT_0   : Create Done !!!
 [HOST] [IPU2  ]     77.551515 s:  IPC_IN_0   : Create in progress !!!
 [HOST] [IPU2  ]     77.552705 s:  IPC_IN_0   : Create Done !!!
 [HOST] [IPU2  ]     77.553162 s:  DECODE: Create in progress ... !!!
 [HOST] [IPU2  ]     77.762856 s:  DECODE: Creating CH0 of 1280 x 720 [1] [0],target bitrate = 10000 Kbps ...
 [HOST] [IPU2  ]     77.763771 s:  DECODE: All CH Create ... DONE !!!
 [HOST] [IPU2  ]     77.765875 s:  DECODE: Create ... DONE !!!
 [HOST] [IPU2  ]     77.766363 s:  VPE: Create in progress !!!
 ASSERT (chains_nullSrc_Display_priv.c|chains_nullSrc_Display_Create|190)
 [HOST] [DSP1  ]     77.901238 s:  IPC_IN_0   : Create in progress !!!
 [HOST] [DSP1  ]     77.901665 s:  IPC_IN_0   : Create Done !!!
 [HOST] [DSP1  ]     77.901878 s:  ALG: ERROR: Invalid alg ID specified  (algId = 42) !!!
 [HOST] [IPU2  ]     77.899682 s:  VPE: Loading Down-scaling Co-effs
 [HOST] [IPU2  ]     77.899926 s:  VPE: Co-effs Loading ... DONE !!!
 [HOST] [IPU2  ]     77.900170 s:  VPE: Create Done !!!
 [HOST] [IPU2  ]     77.900567 s:  IPC_OUT_0   : Create in progress !!!
 [HOST] [IPU2  ]     77.900902 s:  IPC_OUT_0   : Create Done !!!
Can you please suggest me solution for this?
    Please check value of ALGORITHM_LINK_DSP_ALG_MAXNUM and this should be higher than your new algorithm ID.
    Generally we assign ALGORITHM_LINK_DSP_ALG_MAXNUM's value to new alg id and increase ALGORITHM_LINK_DSP_ALG_MAXNUM by 1.
    Anuj
  • yes ALGORITHM_LINK_DSP_ALG_MAXNUM value is higher than new algorithm ID.
    I changed core from DSP1 to A15 and changed files accordingly but still getting following assertion. [HOST] [HOST  ]     46.536844 s:  IPC_OUT_0   : Create in progress !!!
     [HOST] [HOST  ]     46.536905 s:  IPC_OUT_0   : Create Done !!!
     [HOST] [IPU2  ]     46.537089 s:  IPC_IN_0   : Create in progress !!!
     [HOST] [IPU2  ]     46.538278 s:  IPC_IN_0   : Create Done !!!
     [HOST] [IPU2  ]     46.538705 s:  DECODE: Create in progress ... !!!
     [HOST] [IPU2  ]     46.745379 s:  DECODE: Creating CH0 of 1280 x 720 [1] [0],target bitrate = 10000 Kbps ...
     [HOST] [IPU2  ]     46.746263 s:  DECODE: All CH Create ... DONE !!!
     [HOST] [IPU2  ]     46.748276 s:  DECODE: Create ... DONE !!!
     [HOST] [IPU2  ]     46.748703 s:  VPE: Create in progress !!!
     [HOST] algId = 15  ALGORITHM_LINK_ALG_MAXNUM = 16 ASSERT (chains_nullSrc_Display_priv.c|chains_nullSrc_Display_Create|190)
     [HOST] [HOST  ]     46.881778 s:  IPC_IN_0   : Create in progress !!!
     [HOST] [HOST  ]     46.882236 s:  IPC_IN_0   : Create Done !!!
     [HOST] [HOST  ]     46.882327 s:  ALG: ERROR: No alg create function specified  (algId = 15) !!!
     [HOST] [IPU2  ]     46.880314 s:  VPE: Loading Down-scaling Co-effs
     [HOST] [IPU2  ]     46.880558 s:  VPE: Co-effs Loading ... DONE !!!
     [HOST] [IPU2  ]     46.880772 s:  VPE: Create Done !!!
     [HOST] [IPU2  ]     46.881168 s:  IPC_OUT_0   : Create in progress !!!
     [HOST] [IPU2  ]     46.881504 s:  IPC_OUT_0   : Create Done !!!
    Any other linux specific changes needed to be done?
    If you move this alg link to A15 then you have to create a new link on hlos side.
    From the above error it seems its init function is not being called where you assign all calback function for create process and delete.
    Anuj
  • Hi Anuj,
    I created the same plugin on hlos side and called the init function in algorithmLink_cfg.c file but getting following error while compilation.
    /home/megha/VSDK_3_7/vision_sdk/binaries/apps/tda2px_evm_linux_all/lib/tda2px-evm/a15_0/release/links_a15_algorithm.a(algorithmLink_cfg.o): In function `AlgorithmLink_initAlgPlugins':
    algorithmLink_cfg.c:(.text+0x18): undefined reference to `AlgorithmLink_SurroundView3d_initPlugin'
    collect2: error: ld returned 1 exit status
    /home/megha/VSDK_3_7/vision_sdk/build/hlos/makerules/linux/common_footer_a15.mk:93: recipe for target 'exe' failed
    make[6]: *** [exe] Error 1
    Please refer below alg plugin
    vision_sdk\apps\src\hlos\adas\src\alg_plugins\framecopy
    You are getting undefined reference that means you have not defined AlgorithmLink_SurroundView3d_initPlugin function in correct file.
    Anuj
  • Thanks for the reply.
    I referred the framecopy plugin but still i'm facing following issue while adding plugin in MAKEFILE_adas.MK.
    '/home/megha/VSDK_3_7/vision_sdk/binaries/apps/tda2px_evm_linux_all/obj/vision_sdk/tda2px-evm/ipu2/release/vision_sdk_configuro/osa_mem_map.h' -> '/home/megha/VSDK_3_7/vision_sdk/links_fw/src/hlos/osa/include/osa_mem_map.h'
    # links_a15_algorithm: tda2px-evm: Compiling algorithmLink_cfg.c
    # links_a15_algorithm: tda2px-evm: Creating archive links_a15_algorithm.a
    # system: tda2px-evm: Compiling system_common.c
    # system: tda2px-evm: Compiling system_ipc.c
    # osa: tda2px-evm: Compiling osa_mem.c
    # osa: tda2px-evm: Compiling osa_remote_log_client.c
    # osa: tda2px-evm: Compiling osa_remote_log_server.c
    # system: tda2px-evm: Creating archive system.a
    # osa: tda2px-evm: Creating archive osa.a
    make[6]: MAKEFILE.MK: No such file or directory
    make[6]: *** No rule to make target 'MAKEFILE.MK'.  Stop.
    MAKEFILE_adas.MK:14: recipe for target 'vision_sdk_linux_demo' failed
    make[5]: *** [vision_sdk_linux_demo] Error 2
    MAKEFILE_adas.MK:5: recipe for target 'apps' failed
    make[4]: *** [apps] Error 2
    Makefile:187: recipe for target 'apps_exe_hlos' failed
    make[3]: *** [apps_exe_hlos] Error 2
    Makefile:68: recipe for target 'apps_hlos' failed
    make[2]: *** [apps_hlos] Error 2
    Makefile:38: recipe for target 'apps' failed
    make[1]: *** [apps] Error 2
    Makefile:12: recipe for target 'vision_sdk' failed
    make: *** [vision_sdk] Error 2
    and algorithmLink_surroundView3d.h is not getting added in MAKEFILE.DEPEND.
    Please suggest me the solution to resolve my issue.
  • Hi Anuj,
    I created plugin in hlos and it worked for A15 successfully.
    But I want that plugin to work for DSP1. I made corresponding changes in usecase but it is giving following assertion in runtime:
     [HOST] [HOST  ]     49.126913 s:  IPC_OUT_0   : Create in progress !!!
     [HOST] [HOST  ]     49.126974 s:  IPC_OUT_0   : Create Done !!!
     [HOST] [IPU2  ]     49.127127 s:  IPC_IN_0   : Create in progress !!!
     [HOST] [IPU2  ]     49.128377 s:  IPC_IN_0   : Create Done !!!
     [HOST] [IPU2  ]     49.128774 s:  DECODE: Create in progress ... !!!
     [HOST] [IPU2  ]     49.338803 s:  DECODE: Creating CH0 of 1280 x 720 [1] [0],target bitrate = 10000 Kbps ...
     [HOST] [IPU2  ]     49.339687 s:  DECODE: All CH Create ... DONE !!!
     [HOST] [IPU2  ]     49.341731 s:  DECODE: Create ... DONE !!!
     [HOST] [IPU2  ]     49.342127 s:  VPE: Create in progress !!!
     ASSERT (chains_nullSrc_Display_priv.c|chains_nullSrc_Display_Create|220)
     [HOST] [DSP1  ]     49.477032 s:  IPC_IN_0   : Create in progress !!!
     [HOST] [DSP1  ]     49.477490 s:  IPC_IN_0   : Create Done !!!
     [HOST] [DSP1  ]     49.477703 s:  ALG: ERROR: Invalid alg ID specified  (algId = 42) !!!
     [HOST] [IPU2  ]     49.475599 s:  VPE: Loading Down-scaling Co-effs
     [HOST] [IPU2  ]     49.475843 s:  VPE: Co-effs Loading ... DONE !!!
     [HOST] [IPU2  ]     49.476056 s:  VPE: Create Done !!!
     [HOST] [IPU2  ]     49.476422 s:  IPC_OUT_0   : Create in progress !!!
     [HOST] [IPU2  ]     49.476758 s:  IPC_OUT_0   : Create Done !!!
    The value of ALGORITHM_LINK_DSP_ALG_MAXNUM is 43 and ALGORITHM_LINK_DSP_ALG_SURROUNDVIEW3D = 42.
    What changes do I need to do to resolve this issue.
  • Can anybody suggest the answer?
    if(algId>=ALGORITHM_LINK_ALG_MAXNUM)
           Vps_printf(" ALG: ERROR: Invalid alg ID specified "
                      " (algId = %d) !!!\n", pObj->algId);
           status = SYSTEM_LINK_STATUS_EINVALID_PARAMS;
    Print the value of "ALGORITHM_LINK_ALG_MAXNUM" in Vps_printf & let me know the value of this macro
    filename: links_fw/src/rtos/links_common/algorithm/algorithmLink_tsk.c
    Gaviraju
