CCS/TMS320C6678: Edit Platform
Part Number: TMS320C6678
Hi
CCS version: 7
OS: win7
When I edit the platform the CCS print that " platform build successfully", but when I checked the platform didn't modified!!!
Please, guide me to solve the problem.
Best Regards
  • Hi Dariush,
    Can you give more details and some pictures of what exactly you are trying to do?
    Todd
  • Hi
    I want to edit my platform that I declared before, the steps are as below:
    1)
    2)
    3)
    4)
    5)
    6)
    7) when I check the platform again, nothing changed!!!! What should I do?
    Best Regards
  • dariush,
    can you look into the directory C:/<>/Desktop/New Folder (12)/Test/packages/MA_Platform_Design, and check the last modification time for the files in there?
    When you say that nothing changed, does it mean you loaded the platform using the same steps as in the images above, and the memory map has five segments instead of four?
    There is a log file in your workspace, in the subdirectory .metadata. Delete the file, and then repeat the steps above and then open the new log file to check for any error messages.
  • Hi
    I will check your tests.
    [/quote]
    Yes, I load the platform using the same steps and the memory map have five segments.
