Anybody used DM355 IPIPE for image width > 1344?
I just wanted to know if anybody was able to use IPIPE on DM355 to process a frame width larger than 1344 pixels. If you did, how?
1. Did you use supplied driver or you wrote your own driver? What DVSDK version did you use?
2. Did you read the left and right parts directly from the original frame or you had it split using DMA or some other copy method?
3. If you read subframes directly from the original frames, what registers did you use to define the subframe?
Thank you
