Our system need more memory to do more algorithm, so our new platforms contain 2GB DDR memory. (M4 does not need to manage the memory area whose memory address is over 512MB)
After reading the URL http://processors.wiki.ti.com/index.php/VSDK/VisionSDK_UserGuide_MemoryMap#Memory_Map_of_the_Application, our adjustments are still fail.
Our testing code on EVE can access at 0xC0000000 ~ 0xD0000000 ( by modify "/vision_sdk/links_fw/src/rtos/bios_app_common/tda2xx/eve_common/tlb_config_eve_common.c" )
But the same testing code on DSP1/DSP2 cannot work. ( Note : the testing code is to access the memory address directly )
There are some error message about omap-iommu fault....
Could you help us ?
Thank you very much.
Eten
