AM3358: Linux boot file sequence
Part Number: AM3358
hello
my question is to which file first execute in sitara kit after power ON
and next file sequence whenever we turn on the sitara kit power on
i am gone through sys_info.c and board.c
but before sys_info.c which files running and its possible to add printf in those files so that i can print file name of files in terminal log while file called...?
  • Raju,
    can you provide some more details of what are you trying to do? What software are you running?
    Regards, Andreas
  • hi
    thank you so much for your interest with this matter
    and sorry for UN-sufficient information in question
    right now i am working in ti AM335x Starter Kit and using ti latest sdk 6
    i want to understand the file execution sequence in kit
    but i am unable to find which file execute after power on in AM335x Starter Kit and file sequence i which files execute in kit ...?
    aim to understand this file sequence in depth we have developing a custom board with ref design of AM335x Starter Kit and in future we are planning to port linux to that board.
    yah RBL load SPL/MLO in internal RAM and
    MLO load uboot in external RAM and U-boot load linux kernel in RAM
  • hello
    really very sorry to bothering you
    but i am still unable to here any reply from your side
    Thank You !..
    Yes this is essentially the start of the sequence. Then also...
    • U-Boot also loads the device tree file (alongside with the Kernel) needed for the boot, in your case the dtb file for the AM335x Starter Kit
    • Kernel loads various drivers (modules) and firmwares as needed
    • Kernel loads and runs /sbin/init which is really the first process run by the system
    If you need any more details on any of those items a quick google search should produce a wealth of information, there is nothing "TI-special" really about the entire flow.
    Regards, Andreas
  • hello,
    I am grateful for your support.
    your reply really appreciated, Thank you for your assistance with this matter
    Thank You !..
