Other Parts Discussed in Thread: OMAP3530
I am trying to change the default DSPLink memory map and run the Readwrite example but keep getting this error:
root@beagleboard:~# ./readwritegpp readwrite.out 0x89930080 4096 0
============= Sample Application : READWRITE ==========
Entered RDWR_Create ()
[ 128.977783] Error: DSP-side memory map does not match configuration.
[ 128.977813] Compare DSP-side TCF/MAP file with /dsplink/config/all/CFG_<PLATF
ORM>.c
PROC_load failed. Status: [0x80008013]
Leaving RDWR_Create ()
Create phase failed. Status: [0x80008013]
Entered RDWR_Delete ()
Assertion failed (IS_VALID_MSGQ (msgqQueue)). File : msgq.c Line : 484
MSGQ_release () failed. Status = [0x8000800b]
MSGQ_transportClose () failed. Status = [0x80008000]
Leaving RDWR_Delete ()
Here are the changes I made in CFG_OMAP3530_SHMEM.c (only the beginning of the file, the rest left unchanged):
* @file CFG_OMAP3530_SHMEM.c
* @path $(DSPLINK)/config/all/
* @desc Defines the configuration information for DSP/BIOS LINK for the
* OMAP platform.
* @ver 1.61.03
* Copyright (c) Texas Instruments Incorporated 2002-2008
* Use of this software is controlled by the terms and conditions found in the
* license agreement under which this software has been supplied or provided.
/* ----------------------------------- DSP/BIOS LINK Headers */
#include <dsplink.h>
#include <procdefs.h>
#if defined (__cplusplus)
EXTERN "C" {
#endif /* defined (__cplusplus) */
* DSPLINK MEMORY SECTION DIAGRAM
* |--------------[ 0xXXXXXX00 ]---------------------------------|
* | RESET VECTOR (0x80) |
* | Last two nibbles must be zero |
* | DSP CODE/DATA |
* | DSP executable is loaded to this section |
* | DSPLINK SHARED MEMORY0 |
* | Shared control structure is loaded here |
* | DSPLINK SHARED MEMORY1 |
* | POOL Buffer Memory |
* | Pool's buffers are created in this area |
* @name DRVHANDSHAKEPOLLCOUNT
* @desc POLL Count for Driver handshake.
#define DRVHANDSHAKEPOLLCOUNT ((Uint32) 0xFFFFFFFu)
* @name RESETCTRLADDR
* @desc Indicates the start address of Reset Ctrl memory region.
* last two nibbles must be zero i.e. align to 256 boundary.
#define RSTENTRYID 0u
#define RESETCTRLADDR 0x87E00000u
#define RESETCTRLSIZE 0x80u
* @name CODEMEMORYADDR/CODEMEMORYSIZE
* @desc Indicates startaddress/size for dsplink code region.
#define CODEENTRYID 1u
#define CODEMEMORYADDR (RESETCTRLADDR + RESETCTRLSIZE)
#define CODEMEMORYSIZE 0x1aFFF80u
* @name SHAREDENTRYID/SHAREDMEMORYADDR/SHAREDMEMORYSIZE
* @desc Indicates startaddress/size for dsplink shared memory region.
#define SHAREDENTRYID0 2u
#define SHAREDMEMORYADDR0 (CODEMEMORYADDR + CODEMEMORYSIZE)
#define SHAREDMEMORYSIZE0 0x5000u
#define SHAREDENTRYID1 3u
#define SHAREDMEMORYADDR1 (SHAREDMEMORYADDR0 + SHAREDMEMORYSIZE0)
#define SHAREDMEMORYSIZE1 0x2B000u
* @name POOLMEMORYADDR/POOLMEMORYSIZE
* @desc Indicates startaddress/size for dsplink POOL memory region.
#define POOLENTRYID 4u
#define POOLMEMORYADDR (SHAREDMEMORYADDR1 + SHAREDMEMORYSIZE1)
#define POOLMEMORYSIZE 0x004D0000u
* @name LINKCFG_memTable_00
* @desc Memory table ID 0.
STATIC LINKCFG_MemEntry LINKCFG_memTable_00 [] =
RSTENTRYID, /* ENTRY : Entry number */
"RESETCTRL", /* NAME : Name of the memory region */
RESETCTRLADDR, /* ADDRPHYS : Physical address */
RESETCTRLADDR, /* ADDRDSPVIRT : DSP virtual address */
(Uint32) -1u, /* ADDRGPPVIRT : GPP virtual address (if known) */
RESETCTRLSIZE, /* SIZE : Size of the memory region */
TRUE, /* SHARED : Shared access memory? */
FALSE, /* SYNCD : Synchornized? */
CODEENTRYID, /* ENTRY : Entry number */
"DDR2", /* NAME : Name of the memory region */
CODEMEMORYADDR, /* ADDRPHYS : Physical address */
CODEMEMORYADDR, /* ADDRDSPVIRT : DSP virtual address */
CODEMEMORYSIZE, /* SIZE : Size of the memory region */
SHAREDENTRYID0, /* ENTRY : Entry number */
"DSPLINKMEM", /* NAME : Name of the memory region */
SHAREDMEMORYADDR0, /* ADDRPHYS : Physical address */
SHAREDMEMORYADDR0, /* ADDRDSPVIRT : DSP virtual address */
SHAREDMEMORYSIZE0, /* SIZE : Size of the memory region */
SHAREDENTRYID1, /* ENTRY : Entry number */
"DSPLINKMEM1", /* NAME : Name of the memory region */
SHAREDMEMORYADDR1, /* ADDRPHYS : Physical address */
SHAREDMEMORYADDR1, /* ADDRDSPVIRT : DSP virtual address */
SHAREDMEMORYSIZE1, /* SIZE : Size of the memory region */
POOLENTRYID, /* ENTRY : Entry number */
"POOLMEM", /* NAME : Name of the memory region */
POOLMEMORYADDR, /* ADDRPHYS : Physical address */
POOLMEMORYADDR, /* ADDRDSPVIRT : DSP virtual address */
POOLMEMORYSIZE, /* SIZE : Size of the memory region */
TRUE, /* SHARED : Shared access memory? Logically */
5, /* ENTRY : Entry number */
"DSPIRAM", /* NAME : Name of the memory region */
0x5c7f8000, /* ADDRPHYS : Physical address */
0x107f8000, /* ADDRDSPVIRT : DSP virtual address */
(Uint32) -1, /* ADDRGPPVIRT : GPP virtual address (if known) */
0x00018000, /* SIZE : Size of the memory region */
FALSE /* SYNCD : Synchornized? */
6, /* ENTRY : Entry number */
"DSPL1PRAM", /* NAME : Name of the memory region */
0x5cE00000, /* ADDRPHYS : Physical address */
0x10E00000, /* ADDRDSPVIRT : DSP virtual address */
0x00008000, /* SIZE : Size of the memory region */
7, /* ENTRY : Entry number */
"DSPL1DRAM", /* NAME : Name of the memory region */
0x5cF04000, /* ADDRPHYS : Physical address */
0x10F04000, /* ADDRDSPVIRT : DSP virtual address */
0x00014000, /* SIZE : Size of the memory region */
8, /* ENTRY : Entry number */
"L4_CORE", /* NAME : Name of the memory region */
0x48000000, /* ADDRPHYS : Physical address */
0x48000000, /* ADDRDSPVIRT : DSP virtual address */
0x01000000, /* SIZE : Size of the memory region */
FALSE, /* SHARED : Shared access memory? */
9, /* ENTRY : Entry number */
"L4_PER", /* NAME : Name of the memory region */
0x49000000, /* ADDRPHYS : Physical address */
0x49000000, /* ADDRDSPVIRT : DSP virtual address */
0x00100000, /* SIZE : Size of the memory region */
* OMAP platform.
* @ver 1.61.03
EXTERN "C" {
* | DSP CODE/DATA |
Here are the changesi made in dsplink-omap3530-base.tci :
* @file dsplink-omap3530-base.tci
* @path $(DSPLINK)/dsp/inc/DspBios/5.XX/OMAP3530/
* @desc This file defines base configuration for DSP/BIOS LINK.
* @ver 1.61.03
* Load assert support
utils.importFile("assert.tci");
* Load base TCI file.
utils.loadPlatform("ti.platforms.evm3530");
* Enable common BIOS features used by all examples
bios.disableRealTimeAnalysis(prog);
bios.enableMemoryHeaps(prog);
bios.disableRtdx(prog);
bios.enableTskManager(prog);
* GBL
* Enable 32K of L2 cache, 32K of L1D cache and 16K for L1P.
* Adjust the size of IRAM, L1DSRAM, L1PSRAM accordingly.
* Enable caching for addresses 0x8700_0000 - 0x87FF_FFFF by setting MAR135
prog.module("GBL").ENABLEALLTRC = false ;
prog.module("GBL").PROCID = parseInt (arguments [0]) ;
prog.module("GBL").C64PLUSCONFIGURE = true ;
prog.module("GBL").C64PLUSL2CFG = "32k" ;
prog.module("GBL").C64PLUSL1DCFG = "32k" ;
prog.module("GBL").C64PLUSL1PCFG = "16k";
prog.module("GBL").C64PLUSMAR128to159 = 0x00000380 ;
var IRAM = prog.module("MEM").instance("IRAM");
IRAM.len = IRAM.len - 0x8000;
var L1DSRAM = prog.module("MEM").instance("L1DSRAM");
L1DSRAM.len = L1DSRAM.len - 0x8000;
/* Was defined for sdp3430, but not for evm3530, hence commented
var L1PSRAM = prog.module("MEM").instance("L1PSRAM");
L1PSRAM.len = L1PSRAM.len - 0x4000;
* MEM
prog.module("MEM").STACKSIZE = 0x1000 ;
* MEM : RESET_VECTOR
var RESET_VECTOR = prog.module("MEM").create("RESET_VECTOR");
RESET_VECTOR.base = 0x87E00000 ;
RESET_VECTOR.len = 0x00000080;
RESET_VECTOR.space = "code/data";
RESET_VECTOR.createHeap = false;
RESET_VECTOR.comment = "RESET_VECTOR";
* MEM : Adjust DDR2
var DDR2 = prog.module("MEM").instance("DDR2");
DDR2.base = RESET_VECTOR.base + RESET_VECTOR.len ;
DDR2.len = 0x01aFFF80;
DDR2.space = "code/data";
DDR2.createHeap = true;
DDR2.heapSize = 0x1000000;
DDR2.comment = "DDR2";
* MEM : DSPLINKMEM
var DSPLINKMEM = prog.module("MEM").create("DSPLINKMEM");
DSPLINKMEM.base = DDR2.base + DDR2.len ;
DSPLINKMEM.len = 0x00030000;
DSPLINKMEM.createHeap = false;
DSPLINKMEM.comment = "DSPLINKMEM";
* MEM : DSPLINKMEM
var POOLMEM = prog.module("MEM").create("POOLMEM");
POOLMEM.base = DSPLINKMEM.base + DSPLINKMEM.len ;
POOLMEM.len = 0x4D0000;
POOLMEM.createHeap = false;
POOLMEM.comment = "POOLMEM";
* @ver 1.61.03
* GBL
* MEM
* MEM : Adjust DDR2
* MEM : DSPLINKMEM
* MEM : DSPLINKMEM
Can anyone tell me what's wrong?
Yony
