Compiler/TDA2PXEVM: TIDL object detection use case
Part Number: TDA2PXEVM
Other Parts Discussed in Thread: INA226, SYSCONFIG, TVP5158, TLC59108, PGA460, SYSBIOS
I am working on a custom board on which is having TDA2PX SoC
The current board has one image stitching application running on DSP
I have developed TIDL object detection use case which is running successfully on EVM
I want to add TIDL algorithm to this custom board. What all steps do I have to follow?
I have simply added the use-case and getting following errors
root@bhagyashree-Latitude-5490:/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/build# make -s depend
/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: ndk_PATH does not exist! ()
/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: nsp_PATH does not exist! ()
/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: avbtp_PATH does not exist! ()
mkdir: cannot create directory ‘/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/links_fw/include/config’: File exists
mkdir: cannot create directory ‘/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/links_fw/include/config/apps’: File exists
mkdir: cannot create directory ‘/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/links_fw/include/config/apps/tda2px_evm_bios_all’: File exists
# makeconfig: Config is [ tda2px_evm_bios_all ]
# makeconfig: Output file is @ /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/links_fw/include/config/apps/tda2px_evm_bios_all/system_cfg.h
# makeconfig: Input  file is @ /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/build/configs/tda2px_evm_bios_all/cfg.mk
# makeconfig: Generating header ...
# makeconfig: Generating alg plugin config ...
# makeconfig: Generating usecase config ...
# makeconfig: Generating footer ...
# makeconfig: Done !!!
# CPUs that are NOT required but included in config [ tda2px_evm_bios_all ],
# WARNING: IPU1_1 can be excluded from application
# CPUs that are required but not included in config [ tda2px_evm_bios_all ],
# Edit /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/build/configs/tda2px_evm_bios_all/cfg.mk to include or exclude CPUs in an application
# Compiling tda2px-evm:a15_0:release:edma3lld_drv: src/edma3_drv_init.c
# Compiling tda2px-evm:a15_0:release:edma3lld_drv: src/edma3_drv_basic.c
# Compiling tda2px-evm:a15_0:release:edma3lld_drv: src/edma3_drv_adv.c
# Archiving tda2px-evm:a15_0:release:edma3lld_drv
# Compiling tda2px-evm:a15_0:release:edma3lld_rm: src/edma3resmgr.c
# Compiling tda2px-evm:a15_0:release:edma3lld_rm: src/edma3_rm_gbl_data.c
# Compiling tda2px-evm:a15_0:release:edma3lld_rm: src/configs/edma3_tda2xx_cfg.c
# Archiving tda2px-evm:a15_0:release:edma3lld_rm
# Compiling tda2px-evm:ipu1_0:release:edma3lld_drv: src/edma3_drv_init.c
# Compiling tda2px-evm:ipu1_0:release:edma3lld_drv: src/edma3_drv_basic.c
# Compiling tda2px-evm:ipu1_0:release:edma3lld_drv: src/edma3_drv_adv.c
# Archiving tda2px-evm:ipu1_0:release:edma3lld_drv
# Compiling tda2px-evm:ipu1_0:release:edma3lld_rm: src/edma3resmgr.c
# Compiling tda2px-evm:ipu1_0:release:edma3lld_rm: src/edma3_rm_gbl_data.c
# Compiling tda2px-evm:ipu1_0:release:edma3lld_rm: src/configs/edma3_tda2xx_cfg.c
# Archiving tda2px-evm:ipu1_0:release:edma3lld_rm
# Compiling tda2px-evm:c66xdsp_1:release:edma3lld_drv: src/edma3_drv_init.c
# Compiling tda2px-evm:c66xdsp_1:release:edma3lld_drv: src/edma3_drv_basic.c
# Compiling tda2px-evm:c66xdsp_1:release:edma3lld_drv: src/edma3_drv_adv.c
# Archiving tda2px-evm:c66xdsp_1:release:edma3lld_drv
# Compiling tda2px-evm:c66xdsp_1:release:edma3lld_rm: src/edma3resmgr.c
# Compiling tda2px-evm:c66xdsp_1:release:edma3lld_rm: src/edma3_rm_gbl_data.c
# Compiling tda2px-evm:c66xdsp_1:release:edma3lld_rm: src/configs/edma3_tda2xx_cfg.c
# Archiving tda2px-evm:c66xdsp_1:release:edma3lld_rm
# Compiling tda2px-evm:arp32_1:release:edma3lld_drv: src/edma3_drv_init.c
# Compiling tda2px-evm:arp32_1:release:edma3lld_drv: src/edma3_drv_basic.c
# Compiling tda2px-evm:arp32_1:release:edma3lld_drv: src/edma3_drv_adv.c
# Archiving tda2px-evm:arp32_1:release:edma3lld_drv
# Compiling tda2px-evm:arp32_1:release:edma3lld_rm: src/edma3resmgr.c
# Compiling tda2px-evm:arp32_1:release:edma3lld_rm: src/edma3_rm_gbl_data.c
# Compiling tda2px-evm:arp32_1:release:edma3lld_rm: src/configs/edma3_tda2xx_cfg.c
# Archiving tda2px-evm:arp32_1:release:edma3lld_rm
Nothing to be done for tda2px ipu1_0 csl_init
Nothing to be done for tda2px csl_intc
# Compiling tda2px:ipu1_0:release:csl: ./soc/common/csl_device_xbar.c
# Compiling tda2px:ipu1_0:release:csl: ./soc/common/csl_device_common.c
# Compiling tda2px:ipu1_0:release:csl: ./arch/m4/src/interrupt.c
# Compiling tda2px:ipu1_0:release:csl: ./arch/m4/src/ipu_wugen.c
# Compiling tda2px:ipu1_0:release:csl: ./arch/m4/src/ammu.c
# Compiling tda2px:ipu1_0:release:csl: ./arch/m4/src/unicache.c
# Compiling tda2px:ipu1_0:release:csl: src/ip/dcan/V0/priv/dcan.c
# Compiling tda2px:ipu1_0:release:csl: src/ip/edma/V1/priv/edma.c
# Compiling tda2px:ipu1_0:release:csl: src/ip/elm/V0/priv/elm.c
# Compiling tda2px:ipu1_0:release:csl: src/ip/emif/V0/priv/emif.c
# Compiling tda2px:ipu1_0:release:csl: src/ip/epwm/V0/priv/csl_epwm.c
# Compiling tda2px:ipu1_0:release:csl: src/ip/gpio/V1/priv/gpio_v2.c
# Compiling tda2px:ipu1_0:release:csl: src/ip/gpmc/V1/priv/gpmc.c
# Compiling tda2px:ipu1_0:release:csl: src/ip/i2c/V2/priv/i2c.c
# Compiling tda2px:ipu1_0:release:csl: src/ip/l3fw/V0/priv/l3fw.c
# Compiling tda2px:ipu1_0:release:csl: src/ip/l4fw/V0/priv/l4fw.c
# Compiling tda2px:ipu1_0:release:csl: src/ip/mailbox/V0/priv/mailbox.c
# Compiling tda2px:ipu1_0:release:csl: src/ip/mcan/V0/priv/mcan.c
# Compiling tda2px:ipu1_0:release:csl: src/ip/mcasp/V0/priv/mcasp.c
# Compiling tda2px:ipu1_0:release:csl: src/ip/mcspi/V0/priv/mcspi.c
# Compiling tda2px:ipu1_0:release:csl: src/ip/mmc/V0/priv/mmcsd.c
# Compiling tda2px:ipu1_0:release:csl: src/ip/mmu/dsp/V0/priv/mmu.c
# Compiling tda2px:ipu1_0:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l1.c
# Compiling tda2px:ipu1_0:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l2.c
# Compiling tda2px:ipu1_0:release:csl: src/ip/qspi/V1/priv/qspi.c
# Compiling tda2px:ipu1_0:release:csl: src/ip/spinlock/V0/priv/spinlock.c
# Compiling tda2px:ipu1_0:release:csl: src/ip/timer/V1/priv/timer.c
# Compiling tda2px:ipu1_0:release:csl: src/ip/uart/V1/priv/uart.c
# Compiling tda2px:ipu1_0:release:csl: src/ip/wd_timer/V0/priv/wd_timer.c
# Compiling tda2px:ipu1_0:release:csl: src/ip/pcie/V1/priv/pcie.c
# Archiving tda2px:ipu1_0:release:csl into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/lib/tda2px/m4/release/ti.csl.aem4 ...
# Compiling tda2px:ipu1_0:release:csl_utils_common: ./src/app_utils.c
# Archiving tda2px:ipu1_0:release:csl_utils_common into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/common/lib/tda2px/m4/release/csl_utils_common.aem4 ...
# Compiling tda2px:ipu1_0:release:csl_uart_console: ./src/uartConfig.c
# Archiving tda2px:ipu1_0:release:csl_uart_console into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/uart_console/lib/tda2px/m4/release/csl_uart_console.aem4 ...
# Compiling tda2px:ipu1_0:release:csl_utils_i2c: ./src/i2c.c
# Archiving tda2px:ipu1_0:release:csl_utils_i2c into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/i2c/lib/tda2px/m4/release/csl_utils_i2c.aem4 ...
# Compiling tda2px:ipu1_0:release:pm_hal: prcm/pmhal_vm.c
# Compiling tda2px:ipu1_0:release:pm_hal: prcm/V5/hw_pmhal_vmdata.c
# Compiling tda2px:ipu1_0:release:pm_hal: prcm/V5/hw_pmhal_data.c
# Compiling tda2px:ipu1_0:release:pm_hal: prcm/V5/hw_pmhal_data_names.c
# Compiling tda2px:ipu1_0:release:pm_hal: prcm/pmhal_pmic.c
# Compiling tda2px:ipu1_0:release:pm_hal: prcm/pmhal_pmicComm.c
# Compiling tda2px:ipu1_0:release:pm_hal: prcm/pmhal_i2cComm.c
# Compiling tda2px:ipu1_0:release:pm_hal: prcm/pmhal_mm.c
# Compiling tda2px:ipu1_0:release:pm_hal: prcm/pmhal_prm_int.c
# Compiling tda2px:ipu1_0:release:pm_hal: prcm/pmhal_bgap.c
# Compiling tda2px:ipu1_0:release:pm_hal: prcm/V5/hw_pmhal_bgap_data.c
# Compiling tda2px:ipu1_0:release:pm_hal: prcm/pmhal_pdm.c
# Compiling tda2px:ipu1_0:release:pm_hal: prcm/pmhal_rm.c
# Compiling tda2px:ipu1_0:release:pm_hal: prcm/pmhal_sd.c
# Compiling tda2px:ipu1_0:release:pm_hal: prcm/pmhal_cm.c
# Compiling tda2px:ipu1_0:release:pm_hal: prcm/common/hw_pmhal_bgap_common_data.c
# Compiling tda2px:ipu1_0:release:pm_hal: prcm/V5/hw_pmhal_prmdata.c
# Compiling tda2px:ipu1_0:release:pm_hal: prcm/pm_utils.c
# Compiling tda2px:ipu1_0:release:pm_hal: prcm/V5/hw_pmhal_clocktree_data.c
# Compiling tda2px:ipu1_0:release:pm_hal: prcm/pmhal_prcm_stats.c
# Compiling tda2px:ipu1_0:release:pm_hal: prcm/pmhal_clocktree.c
# Compiling tda2px:ipu1_0:release:pm_hal: prcm/V5/pmhal_videopll.c
# Compiling tda2px:ipu1_0:release:pm_hal: prcm/V5/hw_pmhal_videopll_data.c
# Compiling tda2px:ipu1_0:release:pm_hal: prcm/V5/hw_pmhal_ina226data.c
# Compiling tda2px:ipu1_0:release:pm_hal: prcm/pmhal_ina226.c
# Compiling tda2px:ipu1_0:release:pm_hal: prcm/pmhal_lp87565.c
# Compiling tda2px:ipu1_0:release:pm_hal: prcm/pmhal_tps65917.c
# Archiving tda2px:ipu1_0:release:pm_hal into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2px/m4/release/pm_hal.aem4 ...
# Compiling tda2px:ipu1_0:release:pm_hal_optimized: prcm/pmhal_vm.c
# Compiling tda2px:ipu1_0:release:pm_hal_optimized: prcm/V5/hw_pmhal_vmdata.c
# Compiling tda2px:ipu1_0:release:pm_hal_optimized: prcm/V5/hw_pmhal_data.c
# Compiling tda2px:ipu1_0:release:pm_hal_optimized: prcm/V5/hw_pmhal_data_names.c
# Compiling tda2px:ipu1_0:release:pm_hal_optimized: prcm/pmhal_pmic.c
# Compiling tda2px:ipu1_0:release:pm_hal_optimized: prcm/pmhal_pmicComm.c
# Compiling tda2px:ipu1_0:release:pm_hal_optimized: prcm/pmhal_i2cComm.c
# Compiling tda2px:ipu1_0:release:pm_hal_optimized: prcm/pmhal_mm.c
# Compiling tda2px:ipu1_0:release:pm_hal_optimized: prcm/pmhal_prm_int.c
# Compiling tda2px:ipu1_0:release:pm_hal_optimized: prcm/pmhal_bgap.c
# Compiling tda2px:ipu1_0:release:pm_hal_optimized: prcm/V5/hw_pmhal_bgap_data.c
# Compiling tda2px:ipu1_0:release:pm_hal_optimized: prcm/pmhal_pdm.c
# Compiling tda2px:ipu1_0:release:pm_hal_optimized: prcm/pmhal_rm.c
# Compiling tda2px:ipu1_0:release:pm_hal_optimized: prcm/pmhal_sd.c
# Compiling tda2px:ipu1_0:release:pm_hal_optimized: prcm/pmhal_cm.c
# Compiling tda2px:ipu1_0:release:pm_hal_optimized: prcm/common/hw_pmhal_bgap_common_data.c
# Compiling tda2px:ipu1_0:release:pm_hal_optimized: prcm/V5/hw_pmhal_prmdata.c
# Compiling tda2px:ipu1_0:release:pm_hal_optimized: prcm/pm_utils.c
# Compiling tda2px:ipu1_0:release:pm_hal_optimized: prcm/V5/hw_pmhal_clocktree_data.c
# Compiling tda2px:ipu1_0:release:pm_hal_optimized: prcm/pmhal_prcm_stats.c
# Compiling tda2px:ipu1_0:release:pm_hal_optimized: prcm/pmhal_clocktree.c
# Compiling tda2px:ipu1_0:release:pm_hal_optimized: prcm/V5/pmhal_videopll.c
# Compiling tda2px:ipu1_0:release:pm_hal_optimized: prcm/V5/hw_pmhal_videopll_data.c
# Compiling tda2px:ipu1_0:release:pm_hal_optimized: prcm/V5/hw_pmhal_ina226data.c
# Compiling tda2px:ipu1_0:release:pm_hal_optimized: prcm/pmhal_ina226.c
# Compiling tda2px:ipu1_0:release:pm_hal_optimized: prcm/pmhal_lp87565.c
# Compiling tda2px:ipu1_0:release:pm_hal_optimized: prcm/pmhal_tps65917.c
# Archiving tda2px:ipu1_0:release:pm_hal_optimized into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2px/m4/release/pm_hal_optimized.aem4 ...
# Compiling tda2px:ipu1_0:release:pm_lib: prcm/pmlib_cpuidle_utils_m4.asm
# Compiling tda2px:ipu1_0:release:pm_lib: prcm/pmlib_sysconfig.c
# Compiling tda2px:ipu1_0:release:pm_lib: prcm/pmlib_clkrate.c
# Compiling tda2px:ipu1_0:release:pm_lib: prcm/V5/pmlib_boardconfig.c
# Compiling tda2px:ipu1_0:release:pm_lib: prcm/V5/pmlib_videopll_data.c
# Compiling tda2px:ipu1_0:release:pm_lib: prcm/pmlib_videopll.c
# Compiling tda2px:ipu1_0:release:pm_lib: prcm/V5/pmlib_clk_rate_data_tda2px.c
# Compiling tda2px:ipu1_0:release:pm_lib: prcm/pmlib_cpuidle_m4.c
# Archiving tda2px:ipu1_0:release:pm_lib into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2px/m4/release/pm_lib.aem4 ...
# Compiling tda2px:ipu1_0:release:pm_lib_optimized: prcm/pmlib_cpuidle_utils_m4.asm
# Compiling tda2px:ipu1_0:release:pm_lib_optimized: prcm/pmlib_sysconfig.c
# Compiling tda2px:ipu1_0:release:pm_lib_optimized: prcm/pmlib_clkrate.c
# Compiling tda2px:ipu1_0:release:pm_lib_optimized: prcm/V5/pmlib_boardconfig.c
# Compiling tda2px:ipu1_0:release:pm_lib_optimized: prcm/V5/pmlib_videopll_data.c
# Compiling tda2px:ipu1_0:release:pm_lib_optimized: prcm/pmlib_videopll.c
# Compiling tda2px:ipu1_0:release:pm_lib_optimized: prcm/V5/pmlib_clk_rate_data_tda2px.c
# Compiling tda2px:ipu1_0:release:pm_lib_optimized: prcm/pmlib_cpuidle_m4.c
# Archiving tda2px:ipu1_0:release:pm_lib_optimized into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2px/m4/release/pm_lib_optimized.aem4 ...
Nothing to be done for tda2px pm_rtos
# Compiling tda2px-evm:tda2px:ipu1_0:release:sbl_lib: src/sbl_lib_common.c
# Compiling tda2px-evm:tda2px:ipu1_0:release:sbl_lib: src/sbl_lib_board.c
# Compiling tda2px-evm:tda2px:ipu1_0:release:sbl_lib: src/sbl_lib_weak.c
# Compiling tda2px-evm:tda2px:ipu1_0:release:sbl_lib: src/tda2xx/sbl_lib_tda2xx_platform.c
# Compiling tda2px-evm:tda2px:ipu1_0:release:sbl_lib: src/tda2xx/sbl_lib_tda2xx_prcm_dpll.c
# Compiling tda2px-evm:tda2px:ipu1_0:release:sbl_lib: src/tda2xx/sbl_lib_tda2xx_hs.c
# Archiving tda2px-evm:tda2px:ipu1_0:release:sbl_lib into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/boot/sbl_auto/lib/tda2px-evm/m4/release/sbl_lib.aem4 ...
Nothing to be done for tda2px ipu1_0 sbl_utils
# Compiling tda2px:ipu1_0:release:diag: src/diagLib_utils.c
# Compiling tda2px:ipu1_0:release:diag: src/diagLib_ecc.c
# Compiling tda2px:ipu1_0:release:diag: src/diagLib_eccEmif.c
# Compiling tda2px:ipu1_0:release:diag: src/diagLib_eccOcmc.c
# Compiling tda2px:ipu1_0:release:diag: src/diagLib_mcspi.c
# Compiling tda2px:ipu1_0:release:diag: src/diagLib_can.c
# Archiving tda2px:ipu1_0:release:diag into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/diag/lib/tda2px/m4/release/diag.aem4 ...
# Compiling tda2px:ipu1_0:release:firewall_l3l4: src/fwlibl3.c
# Compiling tda2px:ipu1_0:release:firewall_l3l4: src/fwlibl4.c
# Archiving tda2px:ipu1_0:release:firewall_l3l4 into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/fw_l3l4/lib/tda2px/m4/release/firewall_l3l4.aem4 ...
# Compiling tda2px:ipu1_0:release:ipc_lib: src/tda2px/ipclib_interruptTda2px.c
# Compiling tda2px:ipu1_0:release:ipc_lib: src/tda2px/ipclib_interruptTda2pxMailboxCfg.c
# Compiling tda2px:ipu1_0:release:ipc_lib: src/tda2px/ipclib_interruptTda2pxProcCfg.c
# Compiling tda2px:ipu1_0:release:ipc_lib: src/tda2px/ipclib_interruptTda2pxXbarCfg.c
# Compiling tda2px:ipu1_0:release:ipc_lib: src/ipclib_interrupt.c
# Archiving tda2px:ipu1_0:release:ipc_lib into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/ipc_lite/lib/tda2px/ipu1_0/release/ipc_lib.aem4 ...
# Compiling tda2px:ipu1_0:release:norflash_lib: src/nor_flash.c
# Compiling tda2px:ipu1_0:release:norflash_lib: src/debug.c
# Archiving tda2px:ipu1_0:release:norflash_lib into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/boot/sbl_auto/norflash/lib/tda2px/m4/release/norflash_lib.aem4 ...
# Compiling tda2px:ipu1_0:release:qspiflash_lib: src/qspi_cmd_init.c
# Compiling tda2px:ipu1_0:release:qspiflash_lib: src/qspi_flash.c
# Archiving tda2px:ipu1_0:release:qspiflash_lib into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/boot/sbl_auto/qspiflash/lib/tda2px/m4/release/qspiflash_lib.aem4 ...
# Compiling tda2px:ipu1_0:release:i2c_lld: src/lld_hsi2c.c
# Compiling tda2px:ipu1_0:release:i2c_lld: src/lld_hsi2c_edma.c
# Archiving tda2px:ipu1_0:release:i2c_lld into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/i2clld/lib/tda2px/m4/release/i2c_lld.aem4 ...
# Compiling tda2px:ipu1_0:release:stw_platform: src/platform.c
# Compiling tda2px:ipu1_0:release:stw_platform: src/stw_platform.c
# Compiling tda2px:ipu1_0:release:stw_platform: src/tda2xx/irq_xbar.c
# Compiling tda2px:ipu1_0:release:stw_platform: src/tda2xx/dma_xbar.c
# Compiling tda2px:ipu1_0:release:stw_platform: src/tda2xx/chip_config.c
# Compiling tda2px:ipu1_0:release:stw_platform: src/tda2xx/platform_tda2xx.c
# Compiling tda2px:ipu1_0:release:stw_platform: src/tda2xx/platform_tda2xx_pad_config.c
# Compiling tda2px:ipu1_0:release:stw_platform: src/tda2xx/stw_platformTda2xx.c
# Archiving tda2px:ipu1_0:release:stw_platform into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/platform/lib/tda2px/m4/release/stw_platform.aem4 ...
# Compiling tda2px:ipu1_0:release:stw_uartconsole: src/uartConsole.c
# Compiling tda2px:ipu1_0:release:stw_uartconsole: src/uartStdio.c
# Archiving tda2px:ipu1_0:release:stw_uartconsole into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/uartconsole/lib/tda2px/m4/release/stw_uartconsole.aem4 ...
# Compiling tda2px:ipu1_0:release:stw_fatlib: src/fat_mmcsd.c
# Compiling tda2px:ipu1_0:release:stw_fatlib: fatfs/ff.c
# Compiling tda2px:ipu1_0:release:stw_fatlib: src/hs_mmcsdlib.c
# Compiling tda2px:ipu1_0:release:stw_fatlib: src/mmcsd_proto.c
# Compiling tda2px:ipu1_0:release:stw_fatlib: src/hsmmcsd_API.c
# Archiving tda2px:ipu1_0:release:stw_fatlib into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/fatlib/lib/tda2px/m4/release/stw_fatlib.aem4 ...
# Compiling tda2px:ipu1_0:release:stw_fatlib_edma: fatlib_edma/hsmmcsd_edma.c
# Archiving tda2px:ipu1_0:release:stw_fatlib_edma into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/fatlib/lib/tda2px/m4/release/stw_fatlib_edma.aem4 ...
# Compiling tda2px:ipu1_0:release:stw_boards: src/stw_board.c
# Compiling tda2px:ipu1_0:release:stw_boards: src/stw_boardTda2xx.c
# Compiling tda2px:ipu1_0:release:stw_boards: src/stw_boardTda2xxPinmuxData.c
# Archiving tda2px:ipu1_0:release:stw_boards into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/boards/lib/tda2px/m4/release/stw_boards.aem4 ...
# Compiling tda2px:ipu1_0:release:stw_devices: src/stw_device.c
# Compiling tda2px:ipu1_0:release:stw_devices: src/stw_deviceI2c.c
# Compiling tda2px:ipu1_0:release:stw_devices: src/ioexp/stw_deviceIoexpTca64xx.c
# Archiving tda2px:ipu1_0:release:stw_devices into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/devices/lib/tda2px/m4/release/stw_devices.aem4 ...
# Compiling tda2px:ipu1_0:release:stw_examples_utility: src/stwutils_app.c
# Archiving tda2px:ipu1_0:release:stw_examples_utility into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/examples/utility/lib/tda2px/m4/release/stw_examples_utility.aem4 ...
# Compiling tda2px:ipu1_0:release:vps_osal_baremetal: osal.c
# Compiling tda2px:ipu1_0:release:vps_osal_baremetal: osal_cache.c
# Archiving tda2px:ipu1_0:release:vps_osal_baremetal into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2px/ipu1_0/release/vps_osal_baremetal.aem4 ...
# Compiling tda2px:ipu1_0:release:vps_common: src/bsp_common.c
# Compiling tda2px:ipu1_0:release:vps_common: src/bsp_utils.c
# Compiling tda2px:ipu1_0:release:vps_common: src/bsp_utilsQue.c
# Compiling tda2px:ipu1_0:release:vps_common: src/trace.c
# Archiving tda2px:ipu1_0:release:vps_common into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2px/m4/release/vps_common.aem4 ...
# Compiling tda2px:ipu1_0:release:vpslib: hal/src/vpshal.c
# Compiling tda2px:ipu1_0:release:vpslib: hal/src/vpshal_csc.c
# Compiling tda2px:ipu1_0:release:vpslib: hal/src/vpshal_sc.c
# Compiling tda2px:ipu1_0:release:vpslib: hal/src/vpshal_vpdma.c
# Compiling tda2px:ipu1_0:release:vpslib: hal/src/vpshal_vipPort.c
# Compiling tda2px:ipu1_0:release:vpslib: hal/src/vpshal_vipTop.c
# Compiling tda2px:ipu1_0:release:vpslib: hal/src/vpshal_vpeTop.c
# Compiling tda2px:ipu1_0:release:vpslib: hal/src/vpshal_dei.c
# Compiling tda2px:ipu1_0:release:vpslib: hal/src/vpshal_chrus.c
# Compiling tda2px:ipu1_0:release:vpslib: hal/src/vpshal_dssDispcVid.c
# Compiling tda2px:ipu1_0:release:vpslib: hal/src/vpshal_dssDispcOvly.c
# Compiling tda2px:ipu1_0:release:vpslib: hal/src/vpshal_dssHdmi.c
# Compiling tda2px:ipu1_0:release:vpslib: hal/src/vpshal_iss.c
# Compiling tda2px:ipu1_0:release:vpslib: hal/src/vpshal_issvtnf.c
# Compiling tda2px:ipu1_0:release:vpslib: hal/src/vpshal_isssimcop.c
# Compiling tda2px:ipu1_0:release:vpslib: hal/src/wdrldc/vpshal_issldc.c
# Compiling tda2px:ipu1_0:release:vpslib: hal/src/vpshal_isscal.c
# Compiling tda2px:ipu1_0:release:vpslib: hal/src/vpshal_calCsi2Tda2px.c
# Compiling tda2px:ipu1_0:release:vpslib: hal/src/vpshal_issnsf3.c
# Compiling tda2px:ipu1_0:release:vpslib: hal/src/vpshal_isslvdsrx.c
# Compiling tda2px:ipu1_0:release:vpslib: hal/src/vpshal_issipipe.c
# Compiling tda2px:ipu1_0:release:vpslib: hal/src/vpshal_issisif.c
# Compiling tda2px:ipu1_0:release:vpslib: hal/src/vpshal_issrsz.c
# Compiling tda2px:ipu1_0:release:vpslib: hal/src/vpshal_issipipeif.c
# Compiling tda2px:ipu1_0:release:vpslib: hal/src/vpshal_issh3a.c
# Compiling tda2px:ipu1_0:release:vpslib: hal/src/wdrldc/vpshal_issglbce.c
# Compiling tda2px:ipu1_0:release:vpslib: common/src/vps_evtMgr.c
# Compiling tda2px:ipu1_0:release:vpslib: common/src/vps_resrcMgr.c
# Compiling tda2px:ipu1_0:release:vpslib: common/src/vps_graph.c
# Compiling tda2px:ipu1_0:release:vpslib: common/src/vpslib_initTda2px.c
# Compiling tda2px:ipu1_0:release:vpslib: common/src/iem_evtmgr.c
# Compiling tda2px:ipu1_0:release:vpslib: common/src/irm_resrcMgr.c
# Compiling tda2px:ipu1_0:release:vpslib: common/src/cal_evtmgr.c
# Compiling tda2px:ipu1_0:release:vpslib: captcore/src/vpscore_vip.c
# Compiling tda2px:ipu1_0:release:vpslib: captcore/src/vpscore_vipDefaults.c
# Compiling tda2px:ipu1_0:release:vpslib: captcore/src/vpscore_vipVipControl.c
# Compiling tda2px:ipu1_0:release:vpslib: vpecore/src/vpscore_vpeDei.c
# Compiling tda2px:ipu1_0:release:vpslib: vpecore/src/vpscore_vpeApi.c
# Compiling tda2px:ipu1_0:release:vpslib: vpecore/src/vpscore_vpeCommon.c
# Compiling tda2px:ipu1_0:release:vpslib: vpecore/src/vpscore_vpeHal.c
# Compiling tda2px:ipu1_0:release:vpslib: vpecore/src/vpscore_vpeWb.c
# Compiling tda2px:ipu1_0:release:vpslib: dispcore/src/vpscore_dss.c
# Compiling tda2px:ipu1_0:release:vpslib: dispcore/src/vpscore_dctrl.c
# Compiling tda2px:ipu1_0:release:vpslib: dispcore/src/vpscore_dctrlDefaults.c
# Compiling tda2px:ipu1_0:release:vpslib: dispcore/src/vpscore_dctrlGraph.c
# Compiling tda2px:ipu1_0:release:vpslib: dispcore/src/vpscore_dssWb.c
# Compiling tda2px:ipu1_0:release:vpslib: isscore/src/vpscore_isscommon.c
# Compiling tda2px:ipu1_0:release:vpslib: isscore/src/vpscore_simcop.c
# Compiling tda2px:ipu1_0:release:vpslib: isscore/src/vpscore_ispapi.c
# Compiling tda2px:ipu1_0:release:vpslib: isscore/src/vpscore_isp.c
# Compiling tda2px:ipu1_0:release:vpslib: isscore/src/vpscore_calm2m.c
# Compiling tda2px:ipu1_0:release:vpslib: calcore/src/vpscore_calapi.c
# Archiving tda2px:ipu1_0:release:vpslib into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2px/m4/release/vpslib.aem4 ...
# Compiling tda2px:ipu1_0:release:vpsdrv_baremetal: src/vps_initDrv.c
# Compiling tda2px:ipu1_0:release:vpsdrv_baremetal: src/vps_vipDrv.c
# Compiling tda2px:ipu1_0:release:vpsdrv_baremetal: src/vps_dctrlDrv.c
# Compiling tda2px:ipu1_0:release:vpsdrv_baremetal: src/vps_dssDrv.c
# Archiving tda2px:ipu1_0:release:vpsdrv_baremetal into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2px/m4/release/vpsdrv_baremetal.aem4 ...
# Compiling tda2px:ipu1_0:release:fvid2: src/fvid2_drvMgr.c
# Archiving tda2px:ipu1_0:release:fvid2 into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2px/m4/release/fvid2.aem4 ...
# Compiling tda2px:ipu1_0:release:vps_osal_tirtos: bsp_osal.c
# Archiving tda2px:ipu1_0:release:vps_osal_tirtos into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2px/m4/release/vps_osal_tirtos.aem4 ...
Nothing to be done for tda2px ipu1_0 vps_osal_tirtos_smp
# Compiling tda2px:ipu1_0:release:vpsdrv: src/vpsdrv_init.c
# Compiling tda2px:ipu1_0:release:vpsdrv: src/vpsdrv_control.c
# Compiling tda2px:ipu1_0:release:vpsdrv: captdrv/src/vpsdrv_captureApi.c
# Compiling tda2px:ipu1_0:release:vpsdrv: captdrv/src/vpsdrv_captureProc.c
# Compiling tda2px:ipu1_0:release:vpsdrv: captdrv/src/vpsdrv_captureCore.c
# Compiling tda2px:ipu1_0:release:vpsdrv: captdrv/src/vpsdrv_capturePriv.c
# Compiling tda2px:ipu1_0:release:vpsdrv: vpedrv/src/vps_mlm.c
# Compiling tda2px:ipu1_0:release:vpsdrv: vpedrv/src/vpsdrv_m2mSlice.c
# Compiling tda2px:ipu1_0:release:vpsdrv: vpedrv/src/vpsdrv_m2mVpeApi.c
# Compiling tda2px:ipu1_0:release:vpsdrv: vpedrv/src/vpsdrv_m2mVpeCore.c
# Compiling tda2px:ipu1_0:release:vpsdrv: vpedrv/src/vpsdrv_m2mVpeFmd.c
# Compiling tda2px:ipu1_0:release:vpsdrv: vpedrv/src/vpsdrv_m2mVpePriv.c
# Compiling tda2px:ipu1_0:release:vpsdrv: vpedrv/src/vpsdrv_m2mVpeReq.c
# Compiling tda2px:ipu1_0:release:vpsdrv: dispdrv/src/vpsdrv_displayApi.c
# Compiling tda2px:ipu1_0:release:vpsdrv: dispdrv/src/vpsdrv_displayProc.c
# Compiling tda2px:ipu1_0:release:vpsdrv: dispdrv/src/vpsdrv_displayCore.c
# Compiling tda2px:ipu1_0:release:vpsdrv: dispdrv/src/vpsdrv_displayPriv.c
# Compiling tda2px:ipu1_0:release:vpsdrv: dispdrv/src/vpsdrv_dctrl.c
# Compiling tda2px:ipu1_0:release:vpsdrv: m2mdrv_dss/src/vpsdrv_m2mDssApi.c
# Compiling tda2px:ipu1_0:release:vpsdrv: m2mdrv_dss/src/vpsdrv_m2mDssCore.c
# Compiling tda2px:ipu1_0:release:vpsdrv: m2mdrv_dss/src/vpsdrv_m2mDssProc.c
# Compiling tda2px:ipu1_0:release:vpsdrv: m2mdrv_dss/src/vpsdrv_m2mDssPriv.c
# Compiling tda2px:ipu1_0:release:vpsdrv: m2mdrv/src/vpsdrv_m2mIntfApi.c
# Compiling tda2px:ipu1_0:release:vpsdrv: m2mdrv/src/vpsdrv_m2mIssCore.c
# Archiving tda2px:ipu1_0:release:vpsdrv into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2px/m4/release/vpsdrv.aem4 ...
# Compiling tda2px:ipu1_0:release:vps_platforms: src/bsp_platform.c
# Compiling tda2px:ipu1_0:release:vps_platforms: src/bsp_platformTda2xx.c
# Archiving tda2px:ipu1_0:release:vps_platforms into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2px/m4/release/vps_platforms.aem4 ...
# Compiling tda2px:ipu1_0:release:vps_devices: src/bsp_device.c
# Compiling tda2px:ipu1_0:release:vps_devices: src/bsp_deviceI2c.c
# Compiling tda2px:ipu1_0:release:vps_devices: tvp5158/src/bspdrv_tvp5158Api.c
# Compiling tda2px:ipu1_0:release:vps_devices: tvp5158/src/bspdrv_tvp5158I2c.c
# Compiling tda2px:ipu1_0:release:vps_devices: tvp5158/src/bspdrv_tvp5158Reg.c
# Compiling tda2px:ipu1_0:release:vps_devices: sii9127/src/bspdrv_sii9127Api.c
# Compiling tda2px:ipu1_0:release:vps_devices: sii9127/src/bspdrv_sii9127I2c.c
# Compiling tda2px:ipu1_0:release:vps_devices: ov1063x/src/bspdrv_ov1063xApi.c
# Compiling tda2px:ipu1_0:release:vps_devices: ov1063x/src/bspdrv_ov1063xI2c.c
# Compiling tda2px:ipu1_0:release:vps_devices: ov1063x/src/bspdrv_ov10x3xReg.c
# Compiling tda2px:ipu1_0:release:vps_devices: lcdCtrl/src/bspdrv_lcdCtrlApi.c
# Compiling tda2px:ipu1_0:release:vps_devices: lcdCtrl/src/bspdrv_tc358778Ctrl.c
# Compiling tda2px:ipu1_0:release:vps_devices: tlc59108/src/bsp_tlc59108.c
# Compiling tda2px:ipu1_0:release:vps_devices: ar0132/src/bspdrv_ar0132Api.c
# Compiling tda2px:ipu1_0:release:vps_devices: ar0132/src/bspdrv_ar0132I2c.c
# Compiling tda2px:ipu1_0:release:vps_devices: ar0132/src/bspdrv_ar0132Reg.c
# Compiling tda2px:ipu1_0:release:vps_devices: ar0140/src/bspdrv_ar0140Api.c
# Compiling tda2px:ipu1_0:release:vps_devices: ar0140/src/bspdrv_ar0140I2c.c
# Compiling tda2px:ipu1_0:release:vps_devices: ar0132rccc/src/bspdrv_ar0132rcccApi.c
# Compiling tda2px:ipu1_0:release:vps_devices: ar0132rccc/src/bspdrv_ar0132rcccI2c.c
# Compiling tda2px:ipu1_0:release:vps_devices: ar0132rccc/src/bspdrv_ar0132rcccReg.c
# Compiling tda2px:ipu1_0:release:vps_devices: sii9022a/src/bspdrv_sii9022a.c
# Compiling tda2px:ipu1_0:release:vps_devices: ds90uh925/src/bspdrv_ds90uh925Api.c
# Compiling tda2px:ipu1_0:release:vps_devices: ds90uh925/src/bspdrv_ds90uh925I2c.c
# Compiling tda2px:ipu1_0:release:vps_devices: ds90uh926/src/bspdrv_ds90uh926Api.c
# Compiling tda2px:ipu1_0:release:vps_devices: ds90uh926/src/bspdrv_ds90uh926I2c.c
# Compiling tda2px:ipu1_0:release:vps_devices: ioexp/src/bspdrv_ioexpTca64xx.c
# Compiling tda2px:ipu1_0:release:vps_devices: pga450/src/bspdrv_pga450.c
# Compiling tda2px:ipu1_0:release:vps_devices: pga460/src/bspdrv_pga460.c
# Compiling tda2px:ipu1_0:release:vps_devices: adv7611/src/bspdrv_adv7611Api.c
# Compiling tda2px:ipu1_0:release:vps_devices: adv7611/src/bspdrv_adv7611I2c.c
# Compiling tda2px:ipu1_0:release:vps_devices: ov10640/src/bspdrv_ov10640Api.c
# Compiling tda2px:ipu1_0:release:vps_devices: ov10640/src/bspdrv_ov10640I2c.c
# Compiling tda2px:ipu1_0:release:vps_devices: imx224/src/bspdrv_imx224Api.c
# Compiling tda2px:ipu1_0:release:vps_devices: imx224/src/bspdrv_imx224I2c.c
# Compiling tda2px:ipu1_0:release:vps_devices: imx224/src/bspdrv_imx224Reg_30fps_DOL_MIPI_4Lane.c
# Compiling tda2px:ipu1_0:release:vps_devices: imx224/src/bspdrv_imx224Reg_30fps_Linear.c
# Compiling tda2px:ipu1_0:release:vps_devices: imx290/src/bspdrv_imx290Api.c
# Compiling tda2px:ipu1_0:release:vps_devices: ov2775/src/bspdrv_ov2775Api.c
# Compiling tda2px:ipu1_0:release:vps_devices: ov2775/src/bspdrv_ov2775I2c.c
# Compiling tda2px:ipu1_0:release:vps_devices: ov2775/src/bspdrv_ov2775.c
# Compiling tda2px:ipu1_0:release:vps_devices: ov2659/src/bspdrv_ov2659Api.c
# Compiling tda2px:ipu1_0:release:vps_devices: ov2659/src/bspdrv_ov2659I2c.c
# Compiling tda2px:ipu1_0:release:vps_devices: ov2659/src/bspdrv_ov2659Reg.c
# Compiling tda2px:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar12xx.c
# Compiling tda2px:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar12xxPriv.c
# Compiling tda2px:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar12xxMcspiCfgPriv.c
# Compiling tda2px:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar12xxGpioCfgPriv.c
# Compiling tda2px:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar12xxOsalPriv.c
# Compiling tda2px:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar12xxUartCfgPriv.c
# Compiling tda2px:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar12xxFmwPriv.c
# Compiling tda2px:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar1243cfg.c
# Compiling tda2px:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar12xxCrc.c
# Compiling tda2px:ipu1_0:release:vps_devices: radar_ar12xx/src/bspdrv_ar12xxInternal.c
# Compiling tda2px:ipu1_0:release:vps_devices: ov490/src/bspdrv_ov490Api.c
# Compiling tda2px:ipu1_0:release:vps_devices: ov490/src/bspdrv_ov490I2c.c
# Compiling tda2px:ipu1_0:release:vps_devices: ov490/src/bspdrv_ov490Reg.c
# Archiving tda2px:ipu1_0:release:vps_devices into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2px/m4/release/vps_devices.aem4 ...
# Compiling tda2px-evm:tda2px:ipu1_0:release:vps_boards: src/bsp_board.c
# Compiling tda2px-evm:tda2px:ipu1_0:release:vps_boards: src/bsp_boardTda2xx.c
# Compiling tda2px-evm:tda2px:ipu1_0:release:vps_boards: src/bsp_boardTda2ex.c
# Compiling tda2px-evm:tda2px:ipu1_0:release:vps_boards: src/bsp_boardTda3xx.c
# Archiving tda2px-evm:tda2px:ipu1_0:release:vps_boards into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2px-evm/m4/release/vps_boards.aem4 ...
# Compiling tda2px-evm:tda2px:ipu1_0:release:vps_examples_utility: src/bsputils_app.c
# Compiling tda2px-evm:tda2px:ipu1_0:release:vps_examples_utility: src/bsputils_buf.c
# Compiling tda2px-evm:tda2px:ipu1_0:release:vps_examples_utility: src/bsputils_mbx.c
# Compiling tda2px-evm:tda2px:ipu1_0:release:vps_examples_utility: src/bsputils_tsk.c
# Compiling tda2px-evm:tda2px:ipu1_0:release:vps_examples_utility: src/bsputils_prf.c
# Compiling tda2px-evm:tda2px:ipu1_0:release:vps_examples_utility: src/bsputils_mem.c
# Compiling tda2px-evm:tda2px:ipu1_0:release:vps_examples_utility: src/bsputils_mem_default.c
# Compiling tda2px-evm:tda2px:ipu1_0:release:vps_examples_utility: src/bsputils_tiler.c
# Compiling tda2px-evm:tda2px:ipu1_0:release:vps_examples_utility: src/bsputils_ub960.c
# Compiling tda2px-evm:tda2px:ipu1_0:release:vps_examples_utility: src/bsputils_ub95x.c
# Compiling tda2px-evm:tda2px:ipu1_0:release:vps_examples_utility: src/bsputils_lvds.c
# Compiling tda2px-evm:tda2px:ipu1_0:release:vps_examples_utility: src/bsputils_fileio.c
# Compiling tda2px-evm:tda2px:ipu1_0:release:vps_examples_utility: src/bsputils_uart.c
# Archiving tda2px-evm:tda2px:ipu1_0:release:vps_examples_utility into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2px-evm/m4/release/vps_examples_utility.aem4 ...
# Compiling tda2px:ipu1_0:release:bsp_i2c: src/bsp_i2cdrv.c
# Archiving tda2px:ipu1_0:release:bsp_i2c into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/bsp_lld/i2c/lib/tda2px/m4/release/bsp_i2c.aem4 ...
# Compiling tda2px:ipu1_0:release:bsp_uart: src/bspdrv_uart.c
# Compiling tda2px:ipu1_0:release:bsp_uart: src/bspdrv_uartEdma.c
# Archiving tda2px:ipu1_0:release:bsp_uart into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/bsp_lld/uart/lib/tda2px/m4/release/bsp_uart.aem4 ...
# Compiling tda2px:ipu1_0:release:bsp_mcspi: src/bsp_mcspi.c
# Compiling tda2px:ipu1_0:release:bsp_mcspi: src/bsp_mcspiEdma.c
# Archiving tda2px:ipu1_0:release:bsp_mcspi into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/bsp_lld/mcspi/lib/tda2px/m4/release/bsp_mcspi.aem4 ...
Nothing to be done for tda2px ipu1_1 csl_init
Nothing to be done for tda2px ipu1_1 csl_utils_common
Nothing to be done for tda2px ipu1_1 csl_uart_console
Nothing to be done for tda2px ipu1_1 csl_utils_i2c
Nothing to be done for tda2px ipu1_1 pm_hal
Nothing to be done for tda2px ipu1_1 pm_hal_optimized
Nothing to be done for tda2px ipu1_1 pm_lib
Nothing to be done for tda2px ipu1_1 pm_lib_optimized
Nothing to be done for tda2px ipu1_1 sbl_lib
Nothing to be done for tda2px ipu1_1 sbl_utils
Nothing to be done for tda2px ipu1_1 diag
Nothing to be done for tda2px ipu1_1 firewall_l3l4
# Compiling tda2px:ipu1_1:release:ipc_lib: src/tda2px/ipclib_interruptTda2px.c
# Compiling tda2px:ipu1_1:release:ipc_lib: src/tda2px/ipclib_interruptTda2pxMailboxCfg.c
# Compiling tda2px:ipu1_1:release:ipc_lib: src/tda2px/ipclib_interruptTda2pxProcCfg.c
# Compiling tda2px:ipu1_1:release:ipc_lib: src/tda2px/ipclib_interruptTda2pxXbarCfg.c
# Compiling tda2px:ipu1_1:release:ipc_lib: src/ipclib_interrupt.c
# Archiving tda2px:ipu1_1:release:ipc_lib into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/ipc_lite/lib/tda2px/ipu1_1/release/ipc_lib.aem4 ...
Nothing to be done for tda2px ipu1_1 norflash_lib
Nothing to be done for tda2px ipu1_1 qspiflash_lib
Nothing to be done for tda2px ipu1_1 i2c_lld
Nothing to be done for tda2px ipu1_1 stw_platform
Nothing to be done for tda2px ipu1_1 stw_uartconsole
Nothing to be done for tda2px ipu1_1 stw_fatlib
Nothing to be done for tda2px ipu1_1 stw_fatlib_edma
Nothing to be done for tda2px ipu1_1 stw_boards
Nothing to be done for tda2px ipu1_1 stw_devices
Nothing to be done for tda2px ipu1_1 stw_examples_utility
# Compiling tda2px:ipu1_1:release:vps_osal_baremetal: osal.c
# Compiling tda2px:ipu1_1:release:vps_osal_baremetal: osal_cache.c
# Archiving tda2px:ipu1_1:release:vps_osal_baremetal into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2px/ipu1_1/release/vps_osal_baremetal.aem4 ...
Nothing to be done for tda2px ipu1_1 vps_common
Nothing to be done for tda2px ipu1_1 vpslib
Nothing to be done for tda2px ipu1_1 vpsdrv_baremetal
Nothing to be done for tda2px ipu1_1 fvid2
Nothing to be done for tda2px ipu1_1 vps_osal_tirtos
Nothing to be done for tda2px ipu1_1 vps_osal_tirtos_smp
Nothing to be done for tda2px ipu1_1 vps_platforms
Nothing to be done for tda2px ipu1_1 vps_devices
Nothing to be done for tda2px ipu1_1 vps_boards
Nothing to be done for tda2px ipu1_1 vps_examples_utility
Nothing to be done for tda2px ipu1_1 bsp_i2c
Nothing to be done for tda2px ipu1_1 bsp_uart
Nothing to be done for tda2px ipu1_1 bsp_mcspi
Nothing to be done for tda2px ipu2_0 csl_init
Nothing to be done for tda2px ipu2_0 csl_utils_common
Nothing to be done for tda2px ipu2_0 csl_uart_console
Nothing to be done for tda2px ipu2_0 csl_utils_i2c
Nothing to be done for tda2px ipu2_0 pm_hal
Nothing to be done for tda2px ipu2_0 pm_hal_optimized
Nothing to be done for tda2px ipu2_0 pm_lib
Nothing to be done for tda2px ipu2_0 pm_lib_optimized
Nothing to be done for tda2px ipu2_0 sbl_lib
Nothing to be done for tda2px ipu2_0 sbl_utils
Nothing to be done for tda2px ipu2_0 diag
Nothing to be done for tda2px ipu2_0 firewall_l3l4
# Compiling tda2px:ipu2_0:release:ipc_lib: src/tda2px/ipclib_interruptTda2px.c
# Compiling tda2px:ipu2_0:release:ipc_lib: src/tda2px/ipclib_interruptTda2pxMailboxCfg.c
# Compiling tda2px:ipu2_0:release:ipc_lib: src/tda2px/ipclib_interruptTda2pxProcCfg.c
# Compiling tda2px:ipu2_0:release:ipc_lib: src/tda2px/ipclib_interruptTda2pxXbarCfg.c
# Compiling tda2px:ipu2_0:release:ipc_lib: src/ipclib_interrupt.c
# Archiving tda2px:ipu2_0:release:ipc_lib into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/ipc_lite/lib/tda2px/ipu2_0/release/ipc_lib.aem4 ...
Nothing to be done for tda2px ipu2_0 norflash_lib
Nothing to be done for tda2px ipu2_0 qspiflash_lib
Nothing to be done for tda2px ipu2_0 i2c_lld
Nothing to be done for tda2px ipu2_0 stw_platform
Nothing to be done for tda2px ipu2_0 stw_uartconsole
Nothing to be done for tda2px ipu2_0 stw_fatlib
Nothing to be done for tda2px ipu2_0 stw_fatlib_edma
Nothing to be done for tda2px ipu2_0 stw_boards
Nothing to be done for tda2px ipu2_0 stw_devices
Nothing to be done for tda2px ipu2_0 stw_examples_utility
# Compiling tda2px:ipu2_0:release:vps_osal_baremetal: osal.c
# Compiling tda2px:ipu2_0:release:vps_osal_baremetal: osal_cache.c
# Archiving tda2px:ipu2_0:release:vps_osal_baremetal into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2px/ipu2_0/release/vps_osal_baremetal.aem4 ...
Nothing to be done for tda2px ipu2_0 vps_common
Nothing to be done for tda2px ipu2_0 vpslib
Nothing to be done for tda2px ipu2_0 vpsdrv_baremetal
Nothing to be done for tda2px ipu2_0 fvid2
Nothing to be done for tda2px ipu2_0 vps_osal_tirtos
Nothing to be done for tda2px ipu2_0 vps_osal_tirtos_smp
Nothing to be done for tda2px ipu2_0 vps_platforms
Nothing to be done for tda2px ipu2_0 vps_devices
Nothing to be done for tda2px ipu2_0 vps_boards
Nothing to be done for tda2px ipu2_0 vps_examples_utility
Nothing to be done for tda2px ipu2_0 bsp_i2c
Nothing to be done for tda2px ipu2_0 bsp_uart
Nothing to be done for tda2px ipu2_0 bsp_mcspi
Nothing to be done for tda2px c66x csl_init
# Compiling tda2px:c66x:release:csl: ./arch/c66x/src/intvecs.asm
# Compiling tda2px:c66x:release:csl: ./arch/c66x/src/swenr.asm
# Compiling tda2px:c66x:release:csl: ./soc/common/csl_device_xbar.c
# Compiling tda2px:c66x:release:csl: ./soc/common/csl_device_common.c
# Compiling tda2px:c66x:release:csl: ./arch/c66x/src/interrupt.c
# Compiling tda2px:c66x:release:csl: ./arch/c66x/src/dsp_wugen.c
# Compiling tda2px:c66x:release:csl: ./arch/c66x/src/dsp_config.c
# Compiling tda2px:c66x:release:csl: ./arch/c66x/src/dsp_ecc.c
# Compiling tda2px:c66x:release:csl: ./arch/c66x/src/dsp_icfg.c
# Compiling tda2px:c66x:release:csl: ./arch/c66x/src/dsp_usrSpvSupport.c
# Compiling tda2px:c66x:release:csl: ./arch/c66x/src/dsp_xmc.c
# Compiling tda2px:c66x:release:csl: src/ip/dcan/V0/priv/dcan.c
# Compiling tda2px:c66x:release:csl: src/ip/edma/V1/priv/edma.c
# Compiling tda2px:c66x:release:csl: src/ip/elm/V0/priv/elm.c
# Compiling tda2px:c66x:release:csl: src/ip/emif/V0/priv/emif.c
# Compiling tda2px:c66x:release:csl: src/ip/epwm/V0/priv/csl_epwm.c
# Compiling tda2px:c66x:release:csl: src/ip/gpio/V1/priv/gpio_v2.c
# Compiling tda2px:c66x:release:csl: src/ip/gpmc/V1/priv/gpmc.c
# Compiling tda2px:c66x:release:csl: src/ip/i2c/V2/priv/i2c.c
# Compiling tda2px:c66x:release:csl: src/ip/l3fw/V0/priv/l3fw.c
# Compiling tda2px:c66x:release:csl: src/ip/l4fw/V0/priv/l4fw.c
# Compiling tda2px:c66x:release:csl: src/ip/mailbox/V0/priv/mailbox.c
# Compiling tda2px:c66x:release:csl: src/ip/mcan/V0/priv/mcan.c
# Compiling tda2px:c66x:release:csl: src/ip/mcasp/V0/priv/mcasp.c
# Compiling tda2px:c66x:release:csl: src/ip/mcspi/V0/priv/mcspi.c
# Compiling tda2px:c66x:release:csl: src/ip/mmc/V0/priv/mmcsd.c
# Compiling tda2px:c66x:release:csl: src/ip/mmu/dsp/V0/priv/mmu.c
# Compiling tda2px:c66x:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l1.c
# Compiling tda2px:c66x:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l2.c
# Compiling tda2px:c66x:release:csl: src/ip/qspi/V1/priv/qspi.c
# Compiling tda2px:c66x:release:csl: src/ip/spinlock/V0/priv/spinlock.c
# Compiling tda2px:c66x:release:csl: src/ip/timer/V1/priv/timer.c
# Compiling tda2px:c66x:release:csl: src/ip/uart/V1/priv/uart.c
# Compiling tda2px:c66x:release:csl: src/ip/wd_timer/V0/priv/wd_timer.c
# Compiling tda2px:c66x:release:csl: src/ip/pcie/V1/priv/pcie.c
# Archiving tda2px:c66x:release:csl into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/lib/tda2px/c66/release/ti.csl.ae66 ...
# Compiling tda2px:c66x:release:csl_utils_common: ./src/app_utils.c
# Archiving tda2px:c66x:release:csl_utils_common into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/common/lib/tda2px/c66/release/csl_utils_common.ae66 ...
# Compiling tda2px:c66x:release:csl_uart_console: ./src/uartConfig.c
# Archiving tda2px:c66x:release:csl_uart_console into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/uart_console/lib/tda2px/c66/release/csl_uart_console.ae66 ...
# Compiling tda2px:c66x:release:csl_utils_i2c: ./src/i2c.c
# Archiving tda2px:c66x:release:csl_utils_i2c into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/i2c/lib/tda2px/c66/release/csl_utils_i2c.ae66 ...
# Compiling tda2px:c66x:release:pm_hal: prcm/pmhal_vm.c
# Compiling tda2px:c66x:release:pm_hal: prcm/V5/hw_pmhal_vmdata.c
# Compiling tda2px:c66x:release:pm_hal: prcm/V5/hw_pmhal_data.c
# Compiling tda2px:c66x:release:pm_hal: prcm/V5/hw_pmhal_data_names.c
# Compiling tda2px:c66x:release:pm_hal: prcm/pmhal_pmic.c
# Compiling tda2px:c66x:release:pm_hal: prcm/pmhal_pmicComm.c
# Compiling tda2px:c66x:release:pm_hal: prcm/pmhal_i2cComm.c
# Compiling tda2px:c66x:release:pm_hal: prcm/pmhal_mm.c
# Compiling tda2px:c66x:release:pm_hal: prcm/pmhal_prm_int.c
# Compiling tda2px:c66x:release:pm_hal: prcm/pmhal_bgap.c
# Compiling tda2px:c66x:release:pm_hal: prcm/V5/hw_pmhal_bgap_data.c
# Compiling tda2px:c66x:release:pm_hal: prcm/pmhal_pdm.c
# Compiling tda2px:c66x:release:pm_hal: prcm/pmhal_rm.c
# Compiling tda2px:c66x:release:pm_hal: prcm/pmhal_sd.c
# Compiling tda2px:c66x:release:pm_hal: prcm/pmhal_cm.c
# Compiling tda2px:c66x:release:pm_hal: prcm/common/hw_pmhal_bgap_common_data.c
# Compiling tda2px:c66x:release:pm_hal: prcm/V5/hw_pmhal_prmdata.c
# Compiling tda2px:c66x:release:pm_hal: prcm/pm_utils.c
# Compiling tda2px:c66x:release:pm_hal: prcm/V5/hw_pmhal_clocktree_data.c
# Compiling tda2px:c66x:release:pm_hal: prcm/pmhal_prcm_stats.c
# Compiling tda2px:c66x:release:pm_hal: prcm/pmhal_clocktree.c
# Compiling tda2px:c66x:release:pm_hal: prcm/V5/pmhal_videopll.c
# Compiling tda2px:c66x:release:pm_hal: prcm/V5/hw_pmhal_videopll_data.c
# Compiling tda2px:c66x:release:pm_hal: prcm/V5/hw_pmhal_ina226data.c
# Compiling tda2px:c66x:release:pm_hal: prcm/pmhal_ina226.c
# Compiling tda2px:c66x:release:pm_hal: prcm/pmhal_lp87565.c
# Compiling tda2px:c66x:release:pm_hal: prcm/pmhal_tps65917.c
# Archiving tda2px:c66x:release:pm_hal into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2px/c66/release/pm_hal.ae66 ...
# Compiling tda2px:c66x:release:pm_hal_optimized: prcm/pmhal_vm.c
# Compiling tda2px:c66x:release:pm_hal_optimized: prcm/V5/hw_pmhal_vmdata.c
# Compiling tda2px:c66x:release:pm_hal_optimized: prcm/V5/hw_pmhal_data.c
# Compiling tda2px:c66x:release:pm_hal_optimized: prcm/V5/hw_pmhal_data_names.c
# Compiling tda2px:c66x:release:pm_hal_optimized: prcm/pmhal_pmic.c
# Compiling tda2px:c66x:release:pm_hal_optimized: prcm/pmhal_pmicComm.c
# Compiling tda2px:c66x:release:pm_hal_optimized: prcm/pmhal_i2cComm.c
# Compiling tda2px:c66x:release:pm_hal_optimized: prcm/pmhal_mm.c
# Compiling tda2px:c66x:release:pm_hal_optimized: prcm/pmhal_prm_int.c
# Compiling tda2px:c66x:release:pm_hal_optimized: prcm/pmhal_bgap.c
# Compiling tda2px:c66x:release:pm_hal_optimized: prcm/V5/hw_pmhal_bgap_data.c
# Compiling tda2px:c66x:release:pm_hal_optimized: prcm/pmhal_pdm.c
# Compiling tda2px:c66x:release:pm_hal_optimized: prcm/pmhal_rm.c
# Compiling tda2px:c66x:release:pm_hal_optimized: prcm/pmhal_sd.c
# Compiling tda2px:c66x:release:pm_hal_optimized: prcm/pmhal_cm.c
# Compiling tda2px:c66x:release:pm_hal_optimized: prcm/common/hw_pmhal_bgap_common_data.c
# Compiling tda2px:c66x:release:pm_hal_optimized: prcm/V5/hw_pmhal_prmdata.c
# Compiling tda2px:c66x:release:pm_hal_optimized: prcm/pm_utils.c
# Compiling tda2px:c66x:release:pm_hal_optimized: prcm/V5/hw_pmhal_clocktree_data.c
# Compiling tda2px:c66x:release:pm_hal_optimized: prcm/pmhal_prcm_stats.c
# Compiling tda2px:c66x:release:pm_hal_optimized: prcm/pmhal_clocktree.c
# Compiling tda2px:c66x:release:pm_hal_optimized: prcm/V5/pmhal_videopll.c
# Compiling tda2px:c66x:release:pm_hal_optimized: prcm/V5/hw_pmhal_videopll_data.c
# Compiling tda2px:c66x:release:pm_hal_optimized: prcm/V5/hw_pmhal_ina226data.c
# Compiling tda2px:c66x:release:pm_hal_optimized: prcm/pmhal_ina226.c
# Compiling tda2px:c66x:release:pm_hal_optimized: prcm/pmhal_lp87565.c
# Compiling tda2px:c66x:release:pm_hal_optimized: prcm/pmhal_tps65917.c
# Archiving tda2px:c66x:release:pm_hal_optimized into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2px/c66/release/pm_hal_optimized.ae66 ...
# Compiling tda2px:c66x:release:pm_lib: prcm/pmlib_sysconfig.c
# Compiling tda2px:c66x:release:pm_lib: prcm/pmlib_clkrate.c
# Compiling tda2px:c66x:release:pm_lib: prcm/V5/pmlib_boardconfig.c
# Compiling tda2px:c66x:release:pm_lib: prcm/V5/pmlib_videopll_data.c
# Compiling tda2px:c66x:release:pm_lib: prcm/pmlib_videopll.c
# Compiling tda2px:c66x:release:pm_lib: prcm/V5/pmlib_clk_rate_data_tda2px.c
# Compiling tda2px:c66x:release:pm_lib: prcm/pmlib_cpuidle_c66x.c
# Archiving tda2px:c66x:release:pm_lib into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2px/c66/release/pm_lib.ae66 ...
# Compiling tda2px:c66x:release:pm_lib_optimized: prcm/pmlib_sysconfig.c
# Compiling tda2px:c66x:release:pm_lib_optimized: prcm/pmlib_clkrate.c
# Compiling tda2px:c66x:release:pm_lib_optimized: prcm/V5/pmlib_boardconfig.c
# Compiling tda2px:c66x:release:pm_lib_optimized: prcm/V5/pmlib_videopll_data.c
# Compiling tda2px:c66x:release:pm_lib_optimized: prcm/pmlib_videopll.c
# Compiling tda2px:c66x:release:pm_lib_optimized: prcm/V5/pmlib_clk_rate_data_tda2px.c
# Compiling tda2px:c66x:release:pm_lib_optimized: prcm/pmlib_cpuidle_c66x.c
# Archiving tda2px:c66x:release:pm_lib_optimized into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2px/c66/release/pm_lib_optimized.ae66 ...
Nothing to be done for tda2px c66x sbl_lib
Nothing to be done for tda2px c66x sbl_utils
Nothing to be done for tda2px c66x diag
# Compiling tda2px:c66x:release:firewall_l3l4: src/fwlibl3.c
# Compiling tda2px:c66x:release:firewall_l3l4: src/fwlibl4.c
# Archiving tda2px:c66x:release:firewall_l3l4 into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/fw_l3l4/lib/tda2px/c66/release/firewall_l3l4.ae66 ...
Nothing to be done for tda2px c66x ipc_lib
Nothing to be done for tda2px c66x norflash_lib
Nothing to be done for tda2px c66x qspiflash_lib
# Compiling tda2px:c66x:release:i2c_lld: src/lld_hsi2c.c
# Compiling tda2px:c66x:release:i2c_lld: src/lld_hsi2c_edma.c
# Archiving tda2px:c66x:release:i2c_lld into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/i2clld/lib/tda2px/c66/release/i2c_lld.ae66 ...
# Compiling tda2px:c66x:release:stw_platform: src/platform.c
# Compiling tda2px:c66x:release:stw_platform: src/stw_platform.c
# Compiling tda2px:c66x:release:stw_platform: src/tda2xx/irq_xbar.c
# Compiling tda2px:c66x:release:stw_platform: src/tda2xx/dma_xbar.c
# Compiling tda2px:c66x:release:stw_platform: src/tda2xx/chip_config.c
# Compiling tda2px:c66x:release:stw_platform: src/tda2xx/platform_tda2xx.c
# Compiling tda2px:c66x:release:stw_platform: src/tda2xx/platform_tda2xx_pad_config.c
# Compiling tda2px:c66x:release:stw_platform: src/tda2xx/stw_platformTda2xx.c
# Archiving tda2px:c66x:release:stw_platform into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/platform/lib/tda2px/c66/release/stw_platform.ae66 ...
# Compiling tda2px:c66x:release:stw_uartconsole: src/uartConsole.c
# Compiling tda2px:c66x:release:stw_uartconsole: src/uartStdio.c
# Archiving tda2px:c66x:release:stw_uartconsole into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/uartconsole/lib/tda2px/c66/release/stw_uartconsole.ae66 ...
Nothing to be done for tda2px c66x stw_fatlib
Nothing to be done for tda2px c66x stw_fatlib_edma
# Compiling tda2px:c66x:release:stw_boards: src/stw_board.c
# Compiling tda2px:c66x:release:stw_boards: src/stw_boardTda2xx.c
# Compiling tda2px:c66x:release:stw_boards: src/stw_boardTda2xxPinmuxData.c
# Archiving tda2px:c66x:release:stw_boards into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/boards/lib/tda2px/c66/release/stw_boards.ae66 ...
# Compiling tda2px:c66x:release:stw_devices: src/stw_device.c
# Compiling tda2px:c66x:release:stw_devices: src/stw_deviceI2c.c
# Compiling tda2px:c66x:release:stw_devices: src/ioexp/stw_deviceIoexpTca64xx.c
# Archiving tda2px:c66x:release:stw_devices into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/devices/lib/tda2px/c66/release/stw_devices.ae66 ...
# Compiling tda2px:c66x:release:stw_examples_utility: src/stwutils_app.c
# Archiving tda2px:c66x:release:stw_examples_utility into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/examples/utility/lib/tda2px/c66/release/stw_examples_utility.ae66 ...
Nothing to be done for tda2px c66x vps_osal_baremetal
Nothing to be done for tda2px c66x vps_common
Nothing to be done for tda2px c66x vpslib
Nothing to be done for tda2px c66x vpsdrv_baremetal
Nothing to be done for tda2px c66x fvid2
# Compiling tda2px:c66x:release:vps_osal_tirtos: bsp_osal.c
# Archiving tda2px:c66x:release:vps_osal_tirtos into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2px/c66/release/vps_osal_tirtos.ae66 ...
Nothing to be done for tda2px c66x vps_osal_tirtos_smp
Nothing to be done for tda2px c66x vps_platforms
Nothing to be done for tda2px c66x vps_devices
Nothing to be done for tda2px c66x vps_boards
Nothing to be done for tda2px c66x vps_examples_utility
Nothing to be done for tda2px c66x bsp_i2c
Nothing to be done for tda2px c66x bsp_uart
Nothing to be done for tda2px c66x bsp_mcspi
Nothing to be done for tda2px c66xdsp_1 csl_init
Nothing to be done for tda2px c66xdsp_1 csl_utils_common
Nothing to be done for tda2px c66xdsp_1 csl_uart_console
Nothing to be done for tda2px c66xdsp_1 csl_utils_i2c
Nothing to be done for tda2px c66xdsp_1 pm_hal
Nothing to be done for tda2px c66xdsp_1 pm_hal_optimized
Nothing to be done for tda2px c66xdsp_1 pm_lib
Nothing to be done for tda2px c66xdsp_1 pm_lib_optimized
Nothing to be done for tda2px c66xdsp_1 sbl_lib
Nothing to be done for tda2px c66xdsp_1 sbl_utils
Nothing to be done for tda2px c66xdsp_1 diag
Nothing to be done for tda2px c66xdsp_1 firewall_l3l4
# Compiling tda2px:c66xdsp_1:release:ipc_lib: src/tda2px/ipclib_interruptTda2px.c
# Compiling tda2px:c66xdsp_1:release:ipc_lib: src/tda2px/ipclib_interruptTda2pxMailboxCfg.c
# Compiling tda2px:c66xdsp_1:release:ipc_lib: src/tda2px/ipclib_interruptTda2pxProcCfg.c
# Compiling tda2px:c66xdsp_1:release:ipc_lib: src/tda2px/ipclib_interruptTda2pxXbarCfg.c
# Compiling tda2px:c66xdsp_1:release:ipc_lib: src/ipclib_interrupt.c
# Archiving tda2px:c66xdsp_1:release:ipc_lib into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/ipc_lite/lib/tda2px/c66xdsp_1/release/ipc_lib.ae66 ...
Nothing to be done for tda2px c66xdsp_1 norflash_lib
Nothing to be done for tda2px c66xdsp_1 qspiflash_lib
Nothing to be done for tda2px c66xdsp_1 i2c_lld
Nothing to be done for tda2px c66xdsp_1 stw_platform
Nothing to be done for tda2px c66xdsp_1 stw_uartconsole
Nothing to be done for tda2px c66xdsp_1 stw_fatlib
Nothing to be done for tda2px c66xdsp_1 stw_fatlib_edma
Nothing to be done for tda2px c66xdsp_1 stw_boards
Nothing to be done for tda2px c66xdsp_1 stw_devices
Nothing to be done for tda2px c66xdsp_1 stw_examples_utility
# Compiling tda2px:c66xdsp_1:release:vps_osal_baremetal: osal.c
# Compiling tda2px:c66xdsp_1:release:vps_osal_baremetal: osal_cache.c
# Archiving tda2px:c66xdsp_1:release:vps_osal_baremetal into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2px/c66xdsp_1/release/vps_osal_baremetal.ae66 ...
Nothing to be done for tda2px c66xdsp_1 vps_common
Nothing to be done for tda2px c66xdsp_1 vpslib
Nothing to be done for tda2px c66xdsp_1 vpsdrv_baremetal
Nothing to be done for tda2px c66xdsp_1 fvid2
Nothing to be done for tda2px c66xdsp_1 vps_osal_tirtos
Nothing to be done for tda2px c66xdsp_1 vps_osal_tirtos_smp
Nothing to be done for tda2px c66xdsp_1 vps_platforms
Nothing to be done for tda2px c66xdsp_1 vps_devices
Nothing to be done for tda2px c66xdsp_1 vps_boards
Nothing to be done for tda2px c66xdsp_1 vps_examples_utility
Nothing to be done for tda2px c66xdsp_1 bsp_i2c
Nothing to be done for tda2px c66xdsp_1 bsp_uart
Nothing to be done for tda2px c66xdsp_1 bsp_mcspi
Nothing to be done for tda2px c66xdsp_2 csl_init
Nothing to be done for tda2px c66xdsp_2 csl_utils_common
Nothing to be done for tda2px c66xdsp_2 csl_uart_console
Nothing to be done for tda2px c66xdsp_2 csl_utils_i2c
Nothing to be done for tda2px c66xdsp_2 pm_hal
Nothing to be done for tda2px c66xdsp_2 pm_hal_optimized
Nothing to be done for tda2px c66xdsp_2 pm_lib
Nothing to be done for tda2px c66xdsp_2 pm_lib_optimized
Nothing to be done for tda2px c66xdsp_2 sbl_lib
Nothing to be done for tda2px c66xdsp_2 sbl_utils
Nothing to be done for tda2px c66xdsp_2 diag
Nothing to be done for tda2px c66xdsp_2 firewall_l3l4
# Compiling tda2px:c66xdsp_2:release:ipc_lib: src/tda2px/ipclib_interruptTda2px.c
# Compiling tda2px:c66xdsp_2:release:ipc_lib: src/tda2px/ipclib_interruptTda2pxMailboxCfg.c
# Compiling tda2px:c66xdsp_2:release:ipc_lib: src/tda2px/ipclib_interruptTda2pxProcCfg.c
# Compiling tda2px:c66xdsp_2:release:ipc_lib: src/tda2px/ipclib_interruptTda2pxXbarCfg.c
# Compiling tda2px:c66xdsp_2:release:ipc_lib: src/ipclib_interrupt.c
# Archiving tda2px:c66xdsp_2:release:ipc_lib into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/ipc_lite/lib/tda2px/c66xdsp_2/release/ipc_lib.ae66 ...
Nothing to be done for tda2px c66xdsp_2 norflash_lib
Nothing to be done for tda2px c66xdsp_2 qspiflash_lib
Nothing to be done for tda2px c66xdsp_2 i2c_lld
Nothing to be done for tda2px c66xdsp_2 stw_platform
Nothing to be done for tda2px c66xdsp_2 stw_uartconsole
Nothing to be done for tda2px c66xdsp_2 stw_fatlib
Nothing to be done for tda2px c66xdsp_2 stw_fatlib_edma
Nothing to be done for tda2px c66xdsp_2 stw_boards
Nothing to be done for tda2px c66xdsp_2 stw_devices
Nothing to be done for tda2px c66xdsp_2 stw_examples_utility
# Compiling tda2px:c66xdsp_2:release:vps_osal_baremetal: osal.c
# Compiling tda2px:c66xdsp_2:release:vps_osal_baremetal: osal_cache.c
# Archiving tda2px:c66xdsp_2:release:vps_osal_baremetal into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2px/c66xdsp_2/release/vps_osal_baremetal.ae66 ...
Nothing to be done for tda2px c66xdsp_2 vps_common
Nothing to be done for tda2px c66xdsp_2 vpslib
Nothing to be done for tda2px c66xdsp_2 vpsdrv_baremetal
Nothing to be done for tda2px c66xdsp_2 fvid2
Nothing to be done for tda2px c66xdsp_2 vps_osal_tirtos
Nothing to be done for tda2px c66xdsp_2 vps_osal_tirtos_smp
Nothing to be done for tda2px c66xdsp_2 vps_platforms
Nothing to be done for tda2px c66xdsp_2 vps_devices
Nothing to be done for tda2px c66xdsp_2 vps_boards
Nothing to be done for tda2px c66xdsp_2 vps_examples_utility
Nothing to be done for tda2px c66xdsp_2 bsp_i2c
Nothing to be done for tda2px c66xdsp_2 bsp_uart
Nothing to be done for tda2px c66xdsp_2 bsp_mcspi
Nothing to be done for tda2px arp32_1 csl_init
# Compiling tda2px:arp32_1:release:csl: ./arch/arp32/src/boot_arp32.asm
# Compiling tda2px:arp32_1:release:csl: ./soc/common/csl_device_xbar.c
# Compiling tda2px:arp32_1:release:csl: ./soc/common/csl_device_common.c
# Compiling tda2px:arp32_1:release:csl: ./arch/arp32/src/arp32_wugen.c
# Compiling tda2px:arp32_1:release:csl: ./arch/arp32/src/intctl.c
# Compiling tda2px:arp32_1:release:csl: ./arch/arp32/src/interrupt.c
# Compiling tda2px:arp32_1:release:csl: ./arch/arp32/src/inth.c
# Compiling tda2px:arp32_1:release:csl: src/ip/dcan/V0/priv/dcan.c
# Compiling tda2px:arp32_1:release:csl: src/ip/edma/V1/priv/edma.c
# Compiling tda2px:arp32_1:release:csl: src/ip/elm/V0/priv/elm.c
# Compiling tda2px:arp32_1:release:csl: src/ip/emif/V0/priv/emif.c
# Compiling tda2px:arp32_1:release:csl: src/ip/epwm/V0/priv/csl_epwm.c
# Compiling tda2px:arp32_1:release:csl: src/ip/gpio/V1/priv/gpio_v2.c
# Compiling tda2px:arp32_1:release:csl: src/ip/gpmc/V1/priv/gpmc.c
# Compiling tda2px:arp32_1:release:csl: src/ip/i2c/V2/priv/i2c.c
# Compiling tda2px:arp32_1:release:csl: src/ip/l3fw/V0/priv/l3fw.c
# Compiling tda2px:arp32_1:release:csl: src/ip/l4fw/V0/priv/l4fw.c
# Compiling tda2px:arp32_1:release:csl: src/ip/mailbox/V0/priv/mailbox.c
# Compiling tda2px:arp32_1:release:csl: src/ip/mcan/V0/priv/mcan.c
# Compiling tda2px:arp32_1:release:csl: src/ip/mcasp/V0/priv/mcasp.c
# Compiling tda2px:arp32_1:release:csl: src/ip/mcspi/V0/priv/mcspi.c
# Compiling tda2px:arp32_1:release:csl: src/ip/mmc/V0/priv/mmcsd.c
# Compiling tda2px:arp32_1:release:csl: src/ip/mmu/dsp/V0/priv/mmu.c
# Compiling tda2px:arp32_1:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l1.c
# Compiling tda2px:arp32_1:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l2.c
# Compiling tda2px:arp32_1:release:csl: src/ip/qspi/V1/priv/qspi.c
# Compiling tda2px:arp32_1:release:csl: src/ip/spinlock/V0/priv/spinlock.c
# Compiling tda2px:arp32_1:release:csl: src/ip/timer/V1/priv/timer.c
# Compiling tda2px:arp32_1:release:csl: src/ip/uart/V1/priv/uart.c
# Compiling tda2px:arp32_1:release:csl: src/ip/wd_timer/V0/priv/wd_timer.c
# Compiling tda2px:arp32_1:release:csl: src/ip/pcie/V1/priv/pcie.c
# Archiving tda2px:arp32_1:release:csl into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/lib/tda2px/arp32/release/ti.csl.aearp32F ...
# Compiling tda2px:arp32_1:release:csl_utils_common: ./src/app_utils.c
# Archiving tda2px:arp32_1:release:csl_utils_common into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/common/lib/tda2px/arp32/release/csl_utils_common.aearp32F ...
# Compiling tda2px:arp32_1:release:csl_uart_console: ./src/uartConfig.c
# Archiving tda2px:arp32_1:release:csl_uart_console into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/uart_console/lib/tda2px/arp32/release/csl_uart_console.aearp32F ...
# Compiling tda2px:arp32_1:release:csl_utils_i2c: ./src/i2c.c
# Archiving tda2px:arp32_1:release:csl_utils_i2c into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/i2c/lib/tda2px/arp32/release/csl_utils_i2c.aearp32F ...
# Compiling tda2px:arp32_1:release:pm_hal: prcm/pmhal_vm.c
# Compiling tda2px:arp32_1:release:pm_hal: prcm/V5/hw_pmhal_vmdata.c
# Compiling tda2px:arp32_1:release:pm_hal: prcm/V5/hw_pmhal_data.c
# Compiling tda2px:arp32_1:release:pm_hal: prcm/V5/hw_pmhal_data_names.c
# Compiling tda2px:arp32_1:release:pm_hal: prcm/pmhal_pmic.c
# Compiling tda2px:arp32_1:release:pm_hal: prcm/pmhal_pmicComm.c
# Compiling tda2px:arp32_1:release:pm_hal: prcm/pmhal_i2cComm.c
# Compiling tda2px:arp32_1:release:pm_hal: prcm/pmhal_mm.c
# Compiling tda2px:arp32_1:release:pm_hal: prcm/pmhal_prm_int.c
# Compiling tda2px:arp32_1:release:pm_hal: prcm/pmhal_bgap.c
# Compiling tda2px:arp32_1:release:pm_hal: prcm/V5/hw_pmhal_bgap_data.c
# Compiling tda2px:arp32_1:release:pm_hal: prcm/pmhal_pdm.c
# Compiling tda2px:arp32_1:release:pm_hal: prcm/pmhal_rm.c
# Compiling tda2px:arp32_1:release:pm_hal: prcm/pmhal_sd.c
# Compiling tda2px:arp32_1:release:pm_hal: prcm/pmhal_cm.c
# Compiling tda2px:arp32_1:release:pm_hal: prcm/common/hw_pmhal_bgap_common_data.c
# Compiling tda2px:arp32_1:release:pm_hal: prcm/V5/hw_pmhal_prmdata.c
# Compiling tda2px:arp32_1:release:pm_hal: prcm/pm_utils.c
# Compiling tda2px:arp32_1:release:pm_hal: prcm/V5/hw_pmhal_clocktree_data.c
# Compiling tda2px:arp32_1:release:pm_hal: prcm/pmhal_prcm_stats.c
# Compiling tda2px:arp32_1:release:pm_hal: prcm/pmhal_clocktree.c
# Compiling tda2px:arp32_1:release:pm_hal: prcm/V5/pmhal_videopll.c
# Compiling tda2px:arp32_1:release:pm_hal: prcm/V5/hw_pmhal_videopll_data.c
# Compiling tda2px:arp32_1:release:pm_hal: prcm/V5/hw_pmhal_ina226data.c
# Compiling tda2px:arp32_1:release:pm_hal: prcm/pmhal_ina226.c
# Compiling tda2px:arp32_1:release:pm_hal: prcm/pmhal_lp87565.c
# Compiling tda2px:arp32_1:release:pm_hal: prcm/pmhal_tps65917.c
# Archiving tda2px:arp32_1:release:pm_hal into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2px/arp32/release/pm_hal.aearp32F ...
# Compiling tda2px:arp32_1:release:pm_hal_optimized: prcm/pmhal_vm.c
# Compiling tda2px:arp32_1:release:pm_hal_optimized: prcm/V5/hw_pmhal_vmdata.c
# Compiling tda2px:arp32_1:release:pm_hal_optimized: prcm/V5/hw_pmhal_data.c
# Compiling tda2px:arp32_1:release:pm_hal_optimized: prcm/V5/hw_pmhal_data_names.c
# Compiling tda2px:arp32_1:release:pm_hal_optimized: prcm/pmhal_pmic.c
# Compiling tda2px:arp32_1:release:pm_hal_optimized: prcm/pmhal_pmicComm.c
# Compiling tda2px:arp32_1:release:pm_hal_optimized: prcm/pmhal_i2cComm.c
# Compiling tda2px:arp32_1:release:pm_hal_optimized: prcm/pmhal_mm.c
# Compiling tda2px:arp32_1:release:pm_hal_optimized: prcm/pmhal_prm_int.c
# Compiling tda2px:arp32_1:release:pm_hal_optimized: prcm/pmhal_bgap.c
# Compiling tda2px:arp32_1:release:pm_hal_optimized: prcm/V5/hw_pmhal_bgap_data.c
# Compiling tda2px:arp32_1:release:pm_hal_optimized: prcm/pmhal_pdm.c
# Compiling tda2px:arp32_1:release:pm_hal_optimized: prcm/pmhal_rm.c
# Compiling tda2px:arp32_1:release:pm_hal_optimized: prcm/pmhal_sd.c
# Compiling tda2px:arp32_1:release:pm_hal_optimized: prcm/pmhal_cm.c
# Compiling tda2px:arp32_1:release:pm_hal_optimized: prcm/common/hw_pmhal_bgap_common_data.c
# Compiling tda2px:arp32_1:release:pm_hal_optimized: prcm/V5/hw_pmhal_prmdata.c
# Compiling tda2px:arp32_1:release:pm_hal_optimized: prcm/pm_utils.c
# Compiling tda2px:arp32_1:release:pm_hal_optimized: prcm/V5/hw_pmhal_clocktree_data.c
# Compiling tda2px:arp32_1:release:pm_hal_optimized: prcm/pmhal_prcm_stats.c
# Compiling tda2px:arp32_1:release:pm_hal_optimized: prcm/pmhal_clocktree.c
# Compiling tda2px:arp32_1:release:pm_hal_optimized: prcm/V5/pmhal_videopll.c
# Compiling tda2px:arp32_1:release:pm_hal_optimized: prcm/V5/hw_pmhal_videopll_data.c
# Compiling tda2px:arp32_1:release:pm_hal_optimized: prcm/V5/hw_pmhal_ina226data.c
# Compiling tda2px:arp32_1:release:pm_hal_optimized: prcm/pmhal_ina226.c
# Compiling tda2px:arp32_1:release:pm_hal_optimized: prcm/pmhal_lp87565.c
# Compiling tda2px:arp32_1:release:pm_hal_optimized: prcm/pmhal_tps65917.c
# Archiving tda2px:arp32_1:release:pm_hal_optimized into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2px/arp32/release/pm_hal_optimized.aearp32F ...
# Compiling tda2px:arp32_1:release:pm_lib: prcm/pmlib_sysconfig.c
# Compiling tda2px:arp32_1:release:pm_lib: prcm/pmlib_clkrate.c
# Compiling tda2px:arp32_1:release:pm_lib: prcm/V5/pmlib_boardconfig.c
# Compiling tda2px:arp32_1:release:pm_lib: prcm/V5/pmlib_videopll_data.c
# Compiling tda2px:arp32_1:release:pm_lib: prcm/pmlib_videopll.c
# Compiling tda2px:arp32_1:release:pm_lib: prcm/V5/pmlib_clk_rate_data_tda2px.c
# Compiling tda2px:arp32_1:release:pm_lib: prcm/pmlib_cpuidle_arp32.c
# Archiving tda2px:arp32_1:release:pm_lib into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2px/arp32/release/pm_lib.aearp32F ...
# Compiling tda2px:arp32_1:release:pm_lib_optimized: prcm/pmlib_sysconfig.c
# Compiling tda2px:arp32_1:release:pm_lib_optimized: prcm/pmlib_clkrate.c
# Compiling tda2px:arp32_1:release:pm_lib_optimized: prcm/V5/pmlib_boardconfig.c
# Compiling tda2px:arp32_1:release:pm_lib_optimized: prcm/V5/pmlib_videopll_data.c
# Compiling tda2px:arp32_1:release:pm_lib_optimized: prcm/pmlib_videopll.c
# Compiling tda2px:arp32_1:release:pm_lib_optimized: prcm/V5/pmlib_clk_rate_data_tda2px.c
# Compiling tda2px:arp32_1:release:pm_lib_optimized: prcm/pmlib_cpuidle_arp32.c
# Archiving tda2px:arp32_1:release:pm_lib_optimized into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2px/arp32/release/pm_lib_optimized.aearp32F ...
Nothing to be done for tda2px arp32_1 sbl_lib
Nothing to be done for tda2px arp32_1 sbl_utils
Nothing to be done for tda2px arp32_1 diag
# Compiling tda2px:arp32_1:release:firewall_l3l4: src/fwlibl3.c
# Compiling tda2px:arp32_1:release:firewall_l3l4: src/fwlibl4.c
# Archiving tda2px:arp32_1:release:firewall_l3l4 into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/fw_l3l4/lib/tda2px/arp32/release/firewall_l3l4.aearp32F ...
# Compiling tda2px:arp32_1:release:ipc_lib: src/tda2px/ipclib_interruptTda2px.c
# Compiling tda2px:arp32_1:release:ipc_lib: src/tda2px/ipclib_interruptTda2pxMailboxCfg.c
# Compiling tda2px:arp32_1:release:ipc_lib: src/tda2px/ipclib_interruptTda2pxProcCfg.c
# Compiling tda2px:arp32_1:release:ipc_lib: src/tda2px/ipclib_interruptTda2pxXbarCfg.c
# Compiling tda2px:arp32_1:release:ipc_lib: src/ipclib_interrupt.c
# Archiving tda2px:arp32_1:release:ipc_lib into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/ipc_lite/lib/tda2px/arp32_1/release/ipc_lib.aearp32F ...
Nothing to be done for tda2px arp32_1 norflash_lib
Nothing to be done for tda2px arp32_1 qspiflash_lib
Nothing to be done for tda2px arp32_1 i2c_lld
# Compiling tda2px:arp32_1:release:stw_platform: src/platform.c
# Compiling tda2px:arp32_1:release:stw_platform: src/stw_platform.c
# Compiling tda2px:arp32_1:release:stw_platform: src/tda2xx/irq_xbar.c
# Compiling tda2px:arp32_1:release:stw_platform: src/tda2xx/dma_xbar.c
# Compiling tda2px:arp32_1:release:stw_platform: src/tda2xx/chip_config.c
# Compiling tda2px:arp32_1:release:stw_platform: src/tda2xx/platform_tda2xx.c
# Compiling tda2px:arp32_1:release:stw_platform: src/tda2xx/platform_tda2xx_pad_config.c
# Compiling tda2px:arp32_1:release:stw_platform: src/tda2xx/stw_platformTda2xx.c
# Archiving tda2px:arp32_1:release:stw_platform into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/platform/lib/tda2px/arp32/release/stw_platform.aearp32F ...
# Compiling tda2px:arp32_1:release:stw_uartconsole: src/uartConsole.c
# Compiling tda2px:arp32_1:release:stw_uartconsole: src/uartStdio.c
# Archiving tda2px:arp32_1:release:stw_uartconsole into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/uartconsole/lib/tda2px/arp32/release/stw_uartconsole.aearp32F ...
Nothing to be done for tda2px arp32_1 stw_fatlib
Nothing to be done for tda2px arp32_1 stw_fatlib_edma
Nothing to be done for tda2px arp32_1 stw_boards
Nothing to be done for tda2px arp32_1 stw_devices
# Compiling tda2px:arp32_1:release:stw_examples_utility: src/stwutils_app.c
# Archiving tda2px:arp32_1:release:stw_examples_utility into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/examples/utility/lib/tda2px/arp32/release/stw_examples_utility.aearp32F ...
Nothing to be done for tda2px arp32_1 vps_osal_baremetal
Nothing to be done for tda2px arp32_1 vps_common
Nothing to be done for tda2px arp32_1 vpslib
Nothing to be done for tda2px arp32_1 vpsdrv_baremetal
Nothing to be done for tda2px arp32_1 fvid2
# Compiling tda2px:arp32_1:release:vps_osal_tirtos: bsp_osal.c
# Archiving tda2px:arp32_1:release:vps_osal_tirtos into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2px/arp32/release/vps_osal_tirtos.aearp32F ...
Nothing to be done for tda2px arp32_1 vps_osal_tirtos_smp
Nothing to be done for tda2px arp32_1 vps_platforms
Nothing to be done for tda2px arp32_1 vps_devices
Nothing to be done for tda2px arp32_1 vps_boards
Nothing to be done for tda2px arp32_1 vps_examples_utility
Nothing to be done for tda2px arp32_1 bsp_i2c
Nothing to be done for tda2px arp32_1 bsp_uart
Nothing to be done for tda2px arp32_1 bsp_mcspi
Nothing to be done for tda2px arp32_2 csl_init
Nothing to be done for tda2px csl_intc
Nothing to be done for tda2px arp32_2 csl_utils_common
Nothing to be done for tda2px arp32_2 csl_uart_console
Nothing to be done for tda2px arp32_2 csl_utils_i2c
Nothing to be done for tda2px arp32_2 pm_hal
Nothing to be done for tda2px arp32_2 pm_hal_optimized
Nothing to be done for tda2px arp32_2 pm_lib
Nothing to be done for tda2px arp32_2 pm_lib_optimized
Nothing to be done for tda2px pm_rtos
Nothing to be done for tda2px arp32_2 sbl_lib
Nothing to be done for tda2px arp32_2 sbl_utils
Nothing to be done for tda2px arp32_2 diag
Nothing to be done for tda2px arp32_2 firewall_l3l4
# Compiling tda2px:arp32_2:release:ipc_lib: src/tda2px/ipclib_interruptTda2px.c
# Compiling tda2px:arp32_2:release:ipc_lib: src/tda2px/ipclib_interruptTda2pxMailboxCfg.c
# Compiling tda2px:arp32_2:release:ipc_lib: src/tda2px/ipclib_interruptTda2pxProcCfg.c
# Compiling tda2px:arp32_2:release:ipc_lib: src/tda2px/ipclib_interruptTda2pxXbarCfg.c
# Compiling tda2px:arp32_2:release:ipc_lib: src/ipclib_interrupt.c
# Archiving tda2px:arp32_2:release:ipc_lib into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/ipc_lite/lib/tda2px/arp32_2/release/ipc_lib.aearp32F ...
Nothing to be done for tda2px arp32_2 norflash_lib
Nothing to be done for tda2px arp32_2 qspiflash_lib
Nothing to be done for tda2px arp32_2 i2c_lld
Nothing to be done for tda2px arp32_2 stw_platform
Nothing to be done for tda2px arp32_2 stw_uartconsole
Nothing to be done for tda2px arp32_2 stw_fatlib
Nothing to be done for tda2px arp32_2 stw_fatlib_edma
Nothing to be done for tda2px arp32_2 stw_boards
Nothing to be done for tda2px arp32_2 stw_devices
Nothing to be done for tda2px arp32_2 stw_examples_utility
Nothing to be done for tda2px arp32_2 vps_osal_baremetal
Nothing to be done for tda2px arp32_2 vps_common
Nothing to be done for tda2px arp32_2 vpslib
Nothing to be done for tda2px arp32_2 vpsdrv_baremetal
Nothing to be done for tda2px arp32_2 fvid2
Nothing to be done for tda2px arp32_2 vps_osal_tirtos
Nothing to be done for tda2px arp32_2 vps_osal_tirtos_smp
Nothing to be done for tda2px arp32_2 vps_platforms
Nothing to be done for tda2px arp32_2 vps_devices
Nothing to be done for tda2px arp32_2 vps_boards
Nothing to be done for tda2px arp32_2 vps_examples_utility
Nothing to be done for tda2px arp32_2 bsp_i2c
Nothing to be done for tda2px arp32_2 bsp_uart
Nothing to be done for tda2px arp32_2 bsp_mcspi
Nothing to be done for tda2px arp32_3 csl_init
Nothing to be done for tda2px arp32_3 csl_utils_common
Nothing to be done for tda2px arp32_3 csl_uart_console
Nothing to be done for tda2px arp32_3 csl_utils_i2c
Nothing to be done for tda2px arp32_3 pm_hal
Nothing to be done for tda2px arp32_3 pm_hal_optimized
Nothing to be done for tda2px arp32_3 pm_lib
Nothing to be done for tda2px arp32_3 pm_lib_optimized
Nothing to be done for tda2px arp32_3 sbl_lib
Nothing to be done for tda2px arp32_3 sbl_utils
Nothing to be done for tda2px arp32_3 diag
Nothing to be done for tda2px arp32_3 firewall_l3l4
Nothing to be done for tda2px arp32_3 ipc_lib
Nothing to be done for tda2px arp32_3 norflash_lib
Nothing to be done for tda2px arp32_3 qspiflash_lib
Nothing to be done for tda2px arp32_3 i2c_lld
Nothing to be done for tda2px arp32_3 stw_platform
Nothing to be done for tda2px arp32_3 stw_uartconsole
Nothing to be done for tda2px arp32_3 stw_fatlib
Nothing to be done for tda2px arp32_3 stw_fatlib_edma
Nothing to be done for tda2px arp32_3 stw_boards
Nothing to be done for tda2px arp32_3 stw_devices
Nothing to be done for tda2px arp32_3 stw_examples_utility
Nothing to be done for tda2px arp32_3 vps_osal_baremetal
Nothing to be done for tda2px arp32_3 vps_common
Nothing to be done for tda2px arp32_3 vpslib
Nothing to be done for tda2px arp32_3 vpsdrv_baremetal
Nothing to be done for tda2px arp32_3 fvid2
Nothing to be done for tda2px arp32_3 vps_osal_tirtos
Nothing to be done for tda2px arp32_3 vps_osal_tirtos_smp
Nothing to be done for tda2px arp32_3 vps_platforms
Nothing to be done for tda2px arp32_3 vps_devices
Nothing to be done for tda2px arp32_3 vps_boards
Nothing to be done for tda2px arp32_3 vps_examples_utility
Nothing to be done for tda2px arp32_3 bsp_i2c
Nothing to be done for tda2px arp32_3 bsp_uart
Nothing to be done for tda2px arp32_3 bsp_mcspi
Nothing to be done for tda2px arp32_4 csl_init
Nothing to be done for tda2px arp32_4 csl_utils_common
Nothing to be done for tda2px arp32_4 csl_uart_console
Nothing to be done for tda2px arp32_4 csl_utils_i2c
Nothing to be done for tda2px arp32_4 pm_hal
Nothing to be done for tda2px arp32_4 pm_hal_optimized
Nothing to be done for tda2px arp32_4 pm_lib
Nothing to be done for tda2px arp32_4 pm_lib_optimized
Nothing to be done for tda2px arp32_4 sbl_lib
Nothing to be done for tda2px arp32_4 sbl_utils
Nothing to be done for tda2px arp32_4 diag
Nothing to be done for tda2px arp32_4 firewall_l3l4
Nothing to be done for tda2px arp32_4 ipc_lib
Nothing to be done for tda2px arp32_4 norflash_lib
Nothing to be done for tda2px arp32_4 qspiflash_lib
Nothing to be done for tda2px arp32_4 i2c_lld
Nothing to be done for tda2px arp32_4 stw_platform
Nothing to be done for tda2px arp32_4 stw_uartconsole
Nothing to be done for tda2px arp32_4 stw_fatlib
Nothing to be done for tda2px arp32_4 stw_fatlib_edma
Nothing to be done for tda2px arp32_4 stw_boards
Nothing to be done for tda2px arp32_4 stw_devices
Nothing to be done for tda2px arp32_4 stw_examples_utility
Nothing to be done for tda2px arp32_4 vps_osal_baremetal
Nothing to be done for tda2px arp32_4 vps_common
Nothing to be done for tda2px arp32_4 vpslib
Nothing to be done for tda2px arp32_4 vpsdrv_baremetal
Nothing to be done for tda2px arp32_4 fvid2
Nothing to be done for tda2px arp32_4 vps_osal_tirtos
Nothing to be done for tda2px arp32_4 vps_osal_tirtos_smp
Nothing to be done for tda2px arp32_4 vps_platforms
Nothing to be done for tda2px arp32_4 vps_devices
Nothing to be done for tda2px arp32_4 vps_boards
Nothing to be done for tda2px arp32_4 vps_examples_utility
Nothing to be done for tda2px arp32_4 bsp_i2c
Nothing to be done for tda2px arp32_4 bsp_uart
Nothing to be done for tda2px arp32_4 bsp_mcspi
# Compiling tda2px:a15_0:release:csl_init: a15/src/csl_a15_init.asm
# Compiling tda2px:a15_0:release:csl_init: a15/src/exceptionhandler.asm
# Compiling tda2px:a15_0:release:csl_init: a15/src/csl_a15_startup.c
# Archiving tda2px:a15_0:release:csl_init into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/lib/tda2px/a15/release/ti.csl.init.aa15fg ...
# Compiling tda2px:a15_0:release:csl: ./arch/a15/V1/cache_a15_gcc.asm
# Compiling tda2px:a15_0:release:csl: ./arch/a15/V1/mmu_a15_gcc.asm
# Compiling tda2px:a15_0:release:csl: ./arch/a15/V1/performance_unit.asm
# Compiling tda2px:a15_0:release:csl: ./arch/a15/V1/cache_a15_rom_api_calls.asm
# Compiling tda2px:a15_0:release:csl: ./arch/a15/V0/csl_a15Asm.asm
# Compiling tda2px:a15_0:release:csl: src/ip/arm_gic/V0/csl_a15_intr.asm
# Compiling tda2px:a15_0:release:csl: ./soc/common/csl_device_xbar.c
# Compiling tda2px:a15_0:release:csl: ./soc/common/csl_device_common.c
# Compiling tda2px:a15_0:release:csl: ./arch/a15/src/mpu_wugen.c
# Compiling tda2px:a15_0:release:csl: ./arch/a15/src/interrupt.c
# Compiling tda2px:a15_0:release:csl: ./arch/a15/V1/cpu.c
# Compiling tda2px:a15_0:release:csl: ./arch/a15/V1/cp15.c
# Compiling tda2px:a15_0:release:csl: ./arch/a15/V1/cache_a15.c
# Compiling tda2px:a15_0:release:csl: ./arch/a15/V1/mmu_a15.c
# Compiling tda2px:a15_0:release:csl: ./arch/a15/V0/csl_a15.c
# Compiling tda2px:a15_0:release:csl: src/ip/dcan/V0/priv/dcan.c
# Compiling tda2px:a15_0:release:csl: src/ip/edma/V1/priv/edma.c
# Compiling tda2px:a15_0:release:csl: src/ip/elm/V0/priv/elm.c
# Compiling tda2px:a15_0:release:csl: src/ip/emif/V0/priv/emif.c
# Compiling tda2px:a15_0:release:csl: src/ip/epwm/V0/priv/csl_epwm.c
# Compiling tda2px:a15_0:release:csl: src/ip/gpio/V1/priv/gpio_v2.c
# Compiling tda2px:a15_0:release:csl: src/ip/gpmc/V1/priv/gpmc.c
# Compiling tda2px:a15_0:release:csl: src/ip/i2c/V2/priv/i2c.c
# Compiling tda2px:a15_0:release:csl: src/ip/l3fw/V0/priv/l3fw.c
# Compiling tda2px:a15_0:release:csl: src/ip/l4fw/V0/priv/l4fw.c
# Compiling tda2px:a15_0:release:csl: src/ip/mailbox/V0/priv/mailbox.c
# Compiling tda2px:a15_0:release:csl: src/ip/mcan/V0/priv/mcan.c
# Compiling tda2px:a15_0:release:csl: src/ip/mcasp/V0/priv/mcasp.c
# Compiling tda2px:a15_0:release:csl: src/ip/mcspi/V0/priv/mcspi.c
# Compiling tda2px:a15_0:release:csl: src/ip/mmc/V0/priv/mmcsd.c
# Compiling tda2px:a15_0:release:csl: src/ip/mmu/dsp/V0/priv/mmu.c
# Compiling tda2px:a15_0:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l1.c
# Compiling tda2px:a15_0:release:csl: src/ip/ocmc/V0/priv/ocmc_ecc_l2.c
# Compiling tda2px:a15_0:release:csl: src/ip/qspi/V1/priv/qspi.c
# Compiling tda2px:a15_0:release:csl: src/ip/spinlock/V0/priv/spinlock.c
# Compiling tda2px:a15_0:release:csl: src/ip/timer/V1/priv/timer.c
# Compiling tda2px:a15_0:release:csl: src/ip/uart/V1/priv/uart.c
# Compiling tda2px:a15_0:release:csl: src/ip/wd_timer/V0/priv/wd_timer.c
# Compiling tda2px:a15_0:release:csl: src/ip/pcie/V1/priv/pcie.c
# Archiving tda2px:a15_0:release:csl into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/lib/tda2px/a15/release/ti.csl.aa15fg ...
# Compiling tda2px:a15_0:release:csl_utils_common: ./src/app_utils.c
# Archiving tda2px:a15_0:release:csl_utils_common into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/common/lib/tda2px/a15/release/csl_utils_common.aa15fg ...
# Compiling tda2px:a15_0:release:csl_uart_console: ./src/uartConfig.c
# Archiving tda2px:a15_0:release:csl_uart_console into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/uart_console/lib/tda2px/a15/release/csl_uart_console.aa15fg ...
# Compiling tda2px:a15_0:release:csl_utils_i2c: ./src/i2c.c
# Archiving tda2px:a15_0:release:csl_utils_i2c into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/csl/example/utils/i2c/lib/tda2px/a15/release/csl_utils_i2c.aa15fg ...
# Compiling tda2px:a15_0:release:pm_hal: prcm/pmhal_vm.c
# Compiling tda2px:a15_0:release:pm_hal: prcm/V5/hw_pmhal_vmdata.c
# Compiling tda2px:a15_0:release:pm_hal: prcm/V5/hw_pmhal_data.c
# Compiling tda2px:a15_0:release:pm_hal: prcm/V5/hw_pmhal_data_names.c
# Compiling tda2px:a15_0:release:pm_hal: prcm/pmhal_pmic.c
# Compiling tda2px:a15_0:release:pm_hal: prcm/pmhal_pmicComm.c
# Compiling tda2px:a15_0:release:pm_hal: prcm/pmhal_i2cComm.c
# Compiling tda2px:a15_0:release:pm_hal: prcm/pmhal_mm.c
# Compiling tda2px:a15_0:release:pm_hal: prcm/pmhal_prm_int.c
# Compiling tda2px:a15_0:release:pm_hal: prcm/pmhal_bgap.c
# Compiling tda2px:a15_0:release:pm_hal: prcm/V5/hw_pmhal_bgap_data.c
# Compiling tda2px:a15_0:release:pm_hal: prcm/pmhal_pdm.c
# Compiling tda2px:a15_0:release:pm_hal: prcm/pmhal_rm.c
# Compiling tda2px:a15_0:release:pm_hal: prcm/pmhal_sd.c
# Compiling tda2px:a15_0:release:pm_hal: prcm/pmhal_cm.c
# Compiling tda2px:a15_0:release:pm_hal: prcm/common/hw_pmhal_bgap_common_data.c
# Compiling tda2px:a15_0:release:pm_hal: prcm/V5/hw_pmhal_prmdata.c
# Compiling tda2px:a15_0:release:pm_hal: prcm/pm_utils.c
# Compiling tda2px:a15_0:release:pm_hal: prcm/V5/hw_pmhal_clocktree_data.c
# Compiling tda2px:a15_0:release:pm_hal: prcm/pmhal_prcm_stats.c
# Compiling tda2px:a15_0:release:pm_hal: prcm/pmhal_clocktree.c
# Compiling tda2px:a15_0:release:pm_hal: prcm/V5/pmhal_videopll.c
# Compiling tda2px:a15_0:release:pm_hal: prcm/V5/hw_pmhal_videopll_data.c
# Compiling tda2px:a15_0:release:pm_hal: prcm/V5/hw_pmhal_ina226data.c
# Compiling tda2px:a15_0:release:pm_hal: prcm/pmhal_ina226.c
# Compiling tda2px:a15_0:release:pm_hal: prcm/pmhal_lp87565.c
# Compiling tda2px:a15_0:release:pm_hal: prcm/pmhal_tps65917.c
# Compiling tda2px:a15_0:release:pm_hal: prcm/pmhal_mpu_lprm.c
# Archiving tda2px:a15_0:release:pm_hal into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2px/a15/release/pm_hal.aa15fg ...
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/pmhal_vm.c
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/V5/hw_pmhal_vmdata.c
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/V5/hw_pmhal_data.c
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/V5/hw_pmhal_data_names.c
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/pmhal_pmic.c
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/pmhal_pmicComm.c
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/pmhal_i2cComm.c
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/pmhal_mm.c
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/pmhal_prm_int.c
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/pmhal_bgap.c
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/V5/hw_pmhal_bgap_data.c
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/pmhal_pdm.c
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/pmhal_rm.c
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/pmhal_sd.c
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/pmhal_cm.c
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/common/hw_pmhal_bgap_common_data.c
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/V5/hw_pmhal_prmdata.c
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/pm_utils.c
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/V5/hw_pmhal_clocktree_data.c
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/pmhal_prcm_stats.c
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/pmhal_clocktree.c
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/V5/pmhal_videopll.c
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/V5/hw_pmhal_videopll_data.c
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/V5/hw_pmhal_ina226data.c
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/pmhal_ina226.c
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/pmhal_lp87565.c
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/pmhal_tps65917.c
# Compiling tda2px:a15_0:release:pm_hal_optimized: prcm/pmhal_mpu_lprm.c
# Archiving tda2px:a15_0:release:pm_hal_optimized into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2px/a15/release/pm_hal_optimized.aa15fg ...
# Compiling tda2px:a15_0:release:pm_lib: prcm/pmlib_cpuidle_utils_a15host.asm
# Compiling tda2px:a15_0:release:pm_lib: prcm/pmlib_sysconfig.c
# Compiling tda2px:a15_0:release:pm_lib: prcm/pmlib_clkrate.c
# Compiling tda2px:a15_0:release:pm_lib: prcm/V5/pmlib_boardconfig.c
# Compiling tda2px:a15_0:release:pm_lib: prcm/V5/pmlib_videopll_data.c
# Compiling tda2px:a15_0:release:pm_lib: prcm/pmlib_videopll.c
# Compiling tda2px:a15_0:release:pm_lib: prcm/V5/pmlib_clk_rate_data_tda2px.c
# Compiling tda2px:a15_0:release:pm_lib: prcm/pmlib_cpuidle_a15host.c
# Archiving tda2px:a15_0:release:pm_lib into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2px/a15/release/pm_lib.aa15fg ...
# Compiling tda2px:a15_0:release:pm_lib_optimized: prcm/pmlib_cpuidle_utils_a15host.asm
# Compiling tda2px:a15_0:release:pm_lib_optimized: prcm/pmlib_sysconfig.c
# Compiling tda2px:a15_0:release:pm_lib_optimized: prcm/pmlib_clkrate.c
# Compiling tda2px:a15_0:release:pm_lib_optimized: prcm/V5/pmlib_boardconfig.c
# Compiling tda2px:a15_0:release:pm_lib_optimized: prcm/V5/pmlib_videopll_data.c
# Compiling tda2px:a15_0:release:pm_lib_optimized: prcm/pmlib_videopll.c
# Compiling tda2px:a15_0:release:pm_lib_optimized: prcm/V5/pmlib_clk_rate_data_tda2px.c
# Compiling tda2px:a15_0:release:pm_lib_optimized: prcm/pmlib_cpuidle_a15host.c
# Archiving tda2px:a15_0:release:pm_lib_optimized into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/pm/lib/tda2px/a15/release/pm_lib_optimized.aa15fg ...
# Compiling tda2px-evm:tda2px:a15_0:release:sbl_lib: src/tda2xx/sbl_lib_tda2xx_hs_support.asm
# Compiling tda2px-evm:tda2px:a15_0:release:sbl_lib: src/sbl_lib_common.c
# Compiling tda2px-evm:tda2px:a15_0:release:sbl_lib: src/sbl_lib_board.c
# Compiling tda2px-evm:tda2px:a15_0:release:sbl_lib: src/sbl_lib_weak.c
# Compiling tda2px-evm:tda2px:a15_0:release:sbl_lib: src/tda2xx/sbl_lib_tda2xx_platform.c
# Compiling tda2px-evm:tda2px:a15_0:release:sbl_lib: src/tda2xx/sbl_lib_tda2xx_prcm_dpll.c
# Compiling tda2px-evm:tda2px:a15_0:release:sbl_lib: src/tda2xx/sbl_lib_tda2xx_hs.c
# Archiving tda2px-evm:tda2px:a15_0:release:sbl_lib into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/boot/sbl_auto/lib/tda2px-evm/a15/release/sbl_lib.aa15fg ...
# Compiling tda2px-evm:tda2px:a15_0:release:sbl_utils: src/sbl_utils_common.c
# Compiling tda2px-evm:tda2px:a15_0:release:sbl_utils: src/tda2xx/sbl_utils_tda2xx.c
# Compiling tda2px-evm:tda2px:a15_0:release:sbl_utils: src/tda2xx/sbl_utils_tda2px_ddr_config.c
# Compiling tda2px-evm:tda2px:a15_0:release:sbl_utils: src/tda2xx/sbl_utils_tda2xx_iodelay.c
# Archiving tda2px-evm:tda2px:a15_0:release:sbl_utils into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/boot/sbl_auto/lib/tda2px-evm/a15/release/sbl_utils.aa15fg ...
Nothing to be done for tda2px a15_0 diag
# Compiling tda2px:a15_0:release:firewall_l3l4: src/fwlibl3.c
# Compiling tda2px:a15_0:release:firewall_l3l4: src/fwlibl4.c
# Archiving tda2px:a15_0:release:firewall_l3l4 into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/fw_l3l4/lib/tda2px/a15/release/firewall_l3l4.aa15fg ...
# Compiling tda2px:a15_0:release:ipc_lib: src/tda2px/ipclib_interruptTda2px.c
# Compiling tda2px:a15_0:release:ipc_lib: src/tda2px/ipclib_interruptTda2pxMailboxCfg.c
# Compiling tda2px:a15_0:release:ipc_lib: src/tda2px/ipclib_interruptTda2pxProcCfg.c
# Compiling tda2px:a15_0:release:ipc_lib: src/tda2px/ipclib_interruptTda2pxXbarCfg.c
# Compiling tda2px:a15_0:release:ipc_lib: src/ipclib_interrupt.c
# Archiving tda2px:a15_0:release:ipc_lib into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/ipc_lite/lib/tda2px/a15_0/release/ipc_lib.aa15fg ...
# Compiling tda2px:a15_0:release:norflash_lib: src/nor_flash.c
# Compiling tda2px:a15_0:release:norflash_lib: src/debug.c
# Archiving tda2px:a15_0:release:norflash_lib into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/boot/sbl_auto/norflash/lib/tda2px/a15/release/norflash_lib.aa15fg ...
# Compiling tda2px:a15_0:release:qspiflash_lib: src/qspi_cmd_init.c
# Compiling tda2px:a15_0:release:qspiflash_lib: src/qspi_flash.c
# Archiving tda2px:a15_0:release:qspiflash_lib into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/boot/sbl_auto/qspiflash/lib/tda2px/a15/release/qspiflash_lib.aa15fg ...
# Compiling tda2px:a15_0:release:i2c_lld: src/lld_hsi2c.c
# Compiling tda2px:a15_0:release:i2c_lld: src/lld_hsi2c_edma.c
# Archiving tda2px:a15_0:release:i2c_lld into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/i2clld/lib/tda2px/a15/release/i2c_lld.aa15fg ...
# Compiling tda2px:a15_0:release:stw_platform: src/platform.c
# Compiling tda2px:a15_0:release:stw_platform: src/stw_platform.c
# Compiling tda2px:a15_0:release:stw_platform: src/tda2xx/irq_xbar.c
# Compiling tda2px:a15_0:release:stw_platform: src/tda2xx/dma_xbar.c
# Compiling tda2px:a15_0:release:stw_platform: src/tda2xx/chip_config.c
# Compiling tda2px:a15_0:release:stw_platform: src/tda2xx/platform_tda2xx.c
# Compiling tda2px:a15_0:release:stw_platform: src/tda2xx/platform_tda2xx_pad_config.c
# Compiling tda2px:a15_0:release:stw_platform: src/tda2xx/stw_platformTda2xx.c
# Archiving tda2px:a15_0:release:stw_platform into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/platform/lib/tda2px/a15/release/stw_platform.aa15fg ...
# Compiling tda2px:a15_0:release:stw_uartconsole: src/uartConsole.c
# Compiling tda2px:a15_0:release:stw_uartconsole: src/uartStdio.c
# Archiving tda2px:a15_0:release:stw_uartconsole into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/uartconsole/lib/tda2px/a15/release/stw_uartconsole.aa15fg ...
# Compiling tda2px:a15_0:release:stw_fatlib: src/fat_mmcsd.c
# Compiling tda2px:a15_0:release:stw_fatlib: fatfs/ff.c
# Compiling tda2px:a15_0:release:stw_fatlib: src/hs_mmcsdlib.c
# Compiling tda2px:a15_0:release:stw_fatlib: src/mmcsd_proto.c
# Compiling tda2px:a15_0:release:stw_fatlib: src/hsmmcsd_API.c
# Archiving tda2px:a15_0:release:stw_fatlib into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/fatlib/lib/tda2px/a15/release/stw_fatlib.aa15fg ...
# Compiling tda2px:a15_0:release:stw_fatlib_edma: fatlib_edma/hsmmcsd_edma.c
# Archiving tda2px:a15_0:release:stw_fatlib_edma into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/fatlib/lib/tda2px/a15/release/stw_fatlib_edma.aa15fg ...
# Compiling tda2px:a15_0:release:stw_boards: src/stw_board.c
# Compiling tda2px:a15_0:release:stw_boards: src/stw_boardTda2xx.c
# Compiling tda2px:a15_0:release:stw_boards: src/stw_boardTda2xxPinmuxData.c
# Archiving tda2px:a15_0:release:stw_boards into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/boards/lib/tda2px/a15/release/stw_boards.aa15fg ...
# Compiling tda2px:a15_0:release:stw_devices: src/stw_device.c
# Compiling tda2px:a15_0:release:stw_devices: src/stw_deviceI2c.c
# Compiling tda2px:a15_0:release:stw_devices: src/ioexp/stw_deviceIoexpTca64xx.c
# Archiving tda2px:a15_0:release:stw_devices into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/devices/lib/tda2px/a15/release/stw_devices.aa15fg ...
# Compiling tda2px:a15_0:release:stw_examples_utility: src/stwutils_app.c
# Archiving tda2px:a15_0:release:stw_examples_utility into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/stw_lld/examples/utility/lib/tda2px/a15/release/stw_examples_utility.aa15fg ...
# Compiling tda2px:a15_0:release:vps_osal_baremetal: osal.c
# Compiling tda2px:a15_0:release:vps_osal_baremetal: osal_cache.c
# Archiving tda2px:a15_0:release:vps_osal_baremetal into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2px/a15_0/release/vps_osal_baremetal.aa15fg ...
Nothing to be done for tda2px a15_0 vps_common
Nothing to be done for tda2px a15_0 vpslib
Nothing to be done for tda2px a15_0 vpsdrv_baremetal
Nothing to be done for tda2px a15_0 fvid2
# Compiling tda2px:a15_0:release:vps_osal_tirtos: bsp_osal.c
# Archiving tda2px:a15_0:release:vps_osal_tirtos into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2px/a15/release/vps_osal_tirtos.aa15fg ...
# Compiling tda2px:a15_0:release:vps_osal_tirtos_smp: ../bsp_osal.c
# Archiving tda2px:a15_0:release:vps_osal_tirtos_smp into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/drivers/pdk_01_10_01_06/packages/ti/drv/vps/lib/tda2px/a15/release/vps_osal_tirtos_smp.aa15fg ...
Nothing to be done for tda2px a15_0 vps_platforms
Nothing to be done for tda2px a15_0 vps_devices
Nothing to be done for tda2px a15_0 vps_boards
Nothing to be done for tda2px a15_0 vps_examples_utility
Nothing to be done for tda2px a15_0 bsp_i2c
Nothing to be done for tda2px a15_0 bsp_uart
Nothing to be done for tda2px a15_0 bsp_mcspi
# Depend tda2px-evm:ipu1_0:release:links_common_algorithm
# Depend tda2px-evm:ipu1_1:release:links_common_algorithm
# Depend tda2px-evm:ipu2:release:links_common_algorithm
# Depend tda2px-evm:a15_0:release:links_common_algorithm
# Depend tda2px-evm:c66xdsp_1:release:links_common_algorithm
# Depend tda2px-evm:c66xdsp_2:release:links_common_algorithm
# Depend tda2px-evm:arp32_1:release:links_common_algorithm
# Depend tda2px-evm:arp32_2:release:links_common_algorithm
# Depend tda2px-evm:ipu1_0:release:links_common_dup
# Depend tda2px-evm:ipu1_1:release:links_common_dup
# Depend tda2px-evm:ipu2:release:links_common_dup
# Depend tda2px-evm:a15_0:release:links_common_dup
# Depend tda2px-evm:c66xdsp_1:release:links_common_dup
# Depend tda2px-evm:c66xdsp_2:release:links_common_dup
# Depend tda2px-evm:arp32_1:release:links_common_dup
# Depend tda2px-evm:arp32_2:release:links_common_dup
# Depend tda2px-evm:ipu1_0:release:links_common_gate
# Depend tda2px-evm:ipu1_1:release:links_common_gate
# Depend tda2px-evm:ipu2:release:links_common_gate
# Depend tda2px-evm:a15_0:release:links_common_gate
# Depend tda2px-evm:c66xdsp_1:release:links_common_gate
# Depend tda2px-evm:c66xdsp_2:release:links_common_gate
# Depend tda2px-evm:arp32_1:release:links_common_gate
# Depend tda2px-evm:arp32_2:release:links_common_gate
# Depend tda2px-evm:ipu1_0:release:links_common_ipcIn
# Depend tda2px-evm:ipu1_1:release:links_common_ipcIn
# Depend tda2px-evm:ipu2:release:links_common_ipcIn
# Depend tda2px-evm:a15_0:release:links_common_ipcIn
# Depend tda2px-evm:c66xdsp_1:release:links_common_ipcIn
# Depend tda2px-evm:c66xdsp_2:release:links_common_ipcIn
# Depend tda2px-evm:arp32_1:release:links_common_ipcIn
# Depend tda2px-evm:arp32_2:release:links_common_ipcIn
# Depend tda2px-evm:ipu1_0:release:links_common_ipcOut
# Depend tda2px-evm:ipu1_1:release:links_common_ipcOut
# Depend tda2px-evm:ipu2:release:links_common_ipcOut
# Depend tda2px-evm:a15_0:release:links_common_ipcOut
# Depend tda2px-evm:c66xdsp_1:release:links_common_ipcOut
# Depend tda2px-evm:c66xdsp_2:release:links_common_ipcOut
# Depend tda2px-evm:arp32_1:release:links_common_ipcOut
# Depend tda2px-evm:arp32_2:release:links_common_ipcOut
# Depend tda2px-evm:ipu1_0:release:links_common_merge
# Depend tda2px-evm:ipu1_1:release:links_common_merge
# Depend tda2px-evm:ipu2:release:links_common_merge
# Depend tda2px-evm:a15_0:release:links_common_merge
# Depend tda2px-evm:c66xdsp_1:release:links_common_merge
# Depend tda2px-evm:c66xdsp_2:release:links_common_merge
# Depend tda2px-evm:arp32_1:release:links_common_merge
# Depend tda2px-evm:arp32_2:release:links_common_merge
# Depend tda2px-evm:ipu1_0:release:links_common_null
# Depend tda2px-evm:ipu1_1:release:links_common_null
# Depend tda2px-evm:ipu2:release:links_common_null
# Depend tda2px-evm:a15_0:release:links_common_null
# Depend tda2px-evm:c66xdsp_1:release:links_common_null
# Depend tda2px-evm:c66xdsp_2:release:links_common_null
# Depend tda2px-evm:arp32_1:release:links_common_null
# Depend tda2px-evm:arp32_2:release:links_common_null
# Depend tda2px-evm:ipu1_0:release:links_common_nullSrc
# Depend tda2px-evm:ipu1_1:release:links_common_nullSrc
# Depend tda2px-evm:ipu2:release:links_common_nullSrc
# Depend tda2px-evm:a15_0:release:links_common_nullSrc
# Depend tda2px-evm:ipu1_0:release:links_common_select
# Depend tda2px-evm:ipu1_1:release:links_common_select
# Depend tda2px-evm:ipu2:release:links_common_select
# Depend tda2px-evm:a15_0:release:links_common_select
# Depend tda2px-evm:c66xdsp_1:release:links_common_select
# Depend tda2px-evm:c66xdsp_2:release:links_common_select
# Depend tda2px-evm:arp32_1:release:links_common_select
# Depend tda2px-evm:arp32_2:release:links_common_select
# Depend tda2px-evm:ipu1_0:release:links_common_sync
# Depend tda2px-evm:ipu1_1:release:links_common_sync
# Depend tda2px-evm:ipu2:release:links_common_sync
# Depend tda2px-evm:a15_0:release:links_common_sync
# Depend tda2px-evm:c66xdsp_1:release:links_common_sync
# Depend tda2px-evm:c66xdsp_2:release:links_common_sync
# Depend tda2px-evm:arp32_1:release:links_common_sync
# Depend tda2px-evm:arp32_2:release:links_common_sync
# Depend tda2px-evm:ipu1_0:release:links_ipu_display
# Depend tda2px-evm:ipu1_0:release:links_ipu_display_ctrl
# Depend tda2px-evm:ipu1_0:release:links_ipu_iss_capture
# Depend tda2px-evm:ipu1_0:release:links_ipu_iss_m2misp
# Depend tda2px-evm:ipu1_0:release:links_ipu_iss_m2msimcop
# Depend tda2px-evm:ipu1_0:release:links_ipu_iss_m2mresizer
# Depend tda2px-evm:ipu1_0:release:links_ipu_CANLink
# Depend tda2px-evm:ipu1_0:release:links_ipu_vip_capture
# Depend tda2px-evm:ipu1_0:release:links_ipu_vpe
# Depend tda2px-evm:ipu1_0:release:links_ipu_dssM2mWb
# Depend tda2px-evm:ipu2:release:links_ipu_ssdOverlayLink
# Depend tda2px-evm:ipu1_0:release:utils_common
# Depend tda2px-evm:ipu1_1:release:utils_common
# Depend tda2px-evm:ipu2:release:utils_common
# Depend tda2px-evm:a15_0:release:utils_common
# Depend tda2px-evm:c66xdsp_1:release:utils_common
# Depend tda2px-evm:c66xdsp_2:release:utils_common
# Depend tda2px-evm:arp32_1:release:utils_common
# Depend tda2px-evm:arp32_2:release:utils_common
# Depend tda2px-evm:ipu1_0:release:links_common_system
# Depend tda2px-evm:ipu1_1:release:links_common_system
# Depend tda2px-evm:ipu2:release:links_common_system
# Depend tda2px-evm:a15_0:release:links_common_system
# Depend tda2px-evm:c66xdsp_1:release:links_common_system
# Depend tda2px-evm:c66xdsp_2:release:links_common_system
# Depend tda2px-evm:arp32_1:release:links_common_system
# Depend tda2px-evm:arp32_2:release:links_common_system
# Depend tda2px-evm:c66xdsp_1:release:links_dsp_system
# Depend tda2px-evm:c66xdsp_2:release:links_dsp_system
# Depend tda2px-evm:arp32_1:release:links_eve_system
# Depend tda2px-evm:arp32_2:release:links_eve_system
# Depend tda2px-evm:ipu1_0:release:links_ipu_system
# Depend tda2px-evm:ipu1_1:release:links_ipu_system
# Depend tda2px-evm:ipu2:release:links_ipu_system
# Depend tda2px-evm:a15_0:release:links_a15_system
root@bhagyashree-Latitude-5490:/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/build# make -s
/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: ndk_PATH does not exist! ()
/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: nsp_PATH does not exist! ()
/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: avbtp_PATH does not exist! ()
# Compiling tda2px-evm:ipu1_0:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda2px-evm:ipu1_0:release:links_common_algorithm: algorithmLink_cfg.c
# Compiling tda2px-evm:ipu1_0:release:links_common_algorithm: algorithmLink_tsk.c
# Compiling tda2px-evm:ipu1_0:release:links_common_algorithm: algorithmLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:ipu1_0:release:links_common_algorithm
# Compiling tda2px-evm:ipu1_1:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda2px-evm:ipu1_1:release:links_common_algorithm: algorithmLink_cfg.c
# Compiling tda2px-evm:ipu1_1:release:links_common_algorithm: algorithmLink_tsk.c
# Compiling tda2px-evm:ipu1_1:release:links_common_algorithm: algorithmLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:ipu1_1:release:links_common_algorithm
# Compiling tda2px-evm:ipu2:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda2px-evm:ipu2:release:links_common_algorithm: algorithmLink_cfg.c
# Compiling tda2px-evm:ipu2:release:links_common_algorithm: algorithmLink_tsk.c
# Compiling tda2px-evm:ipu2:release:links_common_algorithm: algorithmLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:ipu2:release:links_common_algorithm
# Compiling tda2px-evm:a15_0:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda2px-evm:a15_0:release:links_common_algorithm: algorithmLink_cfg.c
# Compiling tda2px-evm:a15_0:release:links_common_algorithm: algorithmLink_tsk.c
# Compiling tda2px-evm:a15_0:release:links_common_algorithm: algorithmLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:a15_0:release:links_common_algorithm
# Compiling tda2px-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda2px-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_cfg.c
# Compiling tda2px-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_tsk.c
# Compiling tda2px-evm:c66xdsp_1:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:c66xdsp_1:release:links_common_algorithm
# Compiling tda2px-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda2px-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_cfg.c
# Compiling tda2px-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_tsk.c
# Compiling tda2px-evm:c66xdsp_2:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:c66xdsp_2:release:links_common_algorithm
# Compiling tda2px-evm:arp32_1:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda2px-evm:arp32_1:release:links_common_algorithm: algorithmLink_cfg.c
# Compiling tda2px-evm:arp32_1:release:links_common_algorithm: algorithmLink_tsk.c
# Compiling tda2px-evm:arp32_1:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:arp32_1:release:links_common_algorithm
# Compiling tda2px-evm:arp32_2:release:links_common_algorithm: algorithmLink_algPluginSupport.c
# Compiling tda2px-evm:arp32_2:release:links_common_algorithm: algorithmLink_cfg.c
# Compiling tda2px-evm:arp32_2:release:links_common_algorithm: algorithmLink_tsk.c
# Compiling tda2px-evm:arp32_2:release:links_common_algorithm: algorithmLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:arp32_2:release:links_common_algorithm
# Compiling tda2px-evm:ipu1_0:release:links_common_dup: dupLink_tsk.c
# Compiling tda2px-evm:ipu1_0:release:links_common_dup: dupLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:ipu1_0:release:links_common_dup
# Compiling tda2px-evm:ipu1_1:release:links_common_dup: dupLink_tsk.c
# Compiling tda2px-evm:ipu1_1:release:links_common_dup: dupLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:ipu1_1:release:links_common_dup
# Compiling tda2px-evm:ipu2:release:links_common_dup: dupLink_tsk.c
# Compiling tda2px-evm:ipu2:release:links_common_dup: dupLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:ipu2:release:links_common_dup
# Compiling tda2px-evm:a15_0:release:links_common_dup: dupLink_tsk.c
# Compiling tda2px-evm:a15_0:release:links_common_dup: dupLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:a15_0:release:links_common_dup
# Compiling tda2px-evm:c66xdsp_1:release:links_common_dup: dupLink_tsk.c
# Compiling tda2px-evm:c66xdsp_1:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:c66xdsp_1:release:links_common_dup
# Compiling tda2px-evm:c66xdsp_2:release:links_common_dup: dupLink_tsk.c
# Compiling tda2px-evm:c66xdsp_2:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:c66xdsp_2:release:links_common_dup
# Compiling tda2px-evm:arp32_1:release:links_common_dup: dupLink_tsk.c
# Compiling tda2px-evm:arp32_1:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:arp32_1:release:links_common_dup
# Compiling tda2px-evm:arp32_2:release:links_common_dup: dupLink_tsk.c
# Compiling tda2px-evm:arp32_2:release:links_common_dup: dupLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:arp32_2:release:links_common_dup
# Compiling tda2px-evm:ipu1_0:release:links_common_gate: gateLink_tsk.c
# Compiling tda2px-evm:ipu1_0:release:links_common_gate: gateLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:ipu1_0:release:links_common_gate
# Compiling tda2px-evm:ipu1_1:release:links_common_gate: gateLink_tsk.c
# Compiling tda2px-evm:ipu1_1:release:links_common_gate: gateLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:ipu1_1:release:links_common_gate
# Compiling tda2px-evm:ipu2:release:links_common_gate: gateLink_tsk.c
# Compiling tda2px-evm:ipu2:release:links_common_gate: gateLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:ipu2:release:links_common_gate
# Compiling tda2px-evm:a15_0:release:links_common_gate: gateLink_tsk.c
# Compiling tda2px-evm:a15_0:release:links_common_gate: gateLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:a15_0:release:links_common_gate
# Compiling tda2px-evm:c66xdsp_1:release:links_common_gate: gateLink_tsk.c
# Compiling tda2px-evm:c66xdsp_1:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:c66xdsp_1:release:links_common_gate
# Compiling tda2px-evm:c66xdsp_2:release:links_common_gate: gateLink_tsk.c
# Compiling tda2px-evm:c66xdsp_2:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:c66xdsp_2:release:links_common_gate
# Compiling tda2px-evm:arp32_1:release:links_common_gate: gateLink_tsk.c
# Compiling tda2px-evm:arp32_1:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:arp32_1:release:links_common_gate
# Compiling tda2px-evm:arp32_2:release:links_common_gate: gateLink_tsk.c
# Compiling tda2px-evm:arp32_2:release:links_common_gate: gateLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:arp32_2:release:links_common_gate
# Compiling tda2px-evm:ipu1_0:release:links_common_ipcIn: ipcInLink_tsk.c
# Compiling tda2px-evm:ipu1_0:release:links_common_ipcIn: ipcInLink_drv.c
# Compiling tda2px-evm:ipu1_0:release:links_common_ipcIn: ipcInLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:ipu1_0:release:links_common_ipcIn
# Compiling tda2px-evm:ipu1_1:release:links_common_ipcIn: ipcInLink_tsk.c
# Compiling tda2px-evm:ipu1_1:release:links_common_ipcIn: ipcInLink_drv.c
# Compiling tda2px-evm:ipu1_1:release:links_common_ipcIn: ipcInLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:ipu1_1:release:links_common_ipcIn
# Compiling tda2px-evm:ipu2:release:links_common_ipcIn: ipcInLink_tsk.c
# Compiling tda2px-evm:ipu2:release:links_common_ipcIn: ipcInLink_drv.c
# Compiling tda2px-evm:ipu2:release:links_common_ipcIn: ipcInLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:ipu2:release:links_common_ipcIn
# Compiling tda2px-evm:a15_0:release:links_common_ipcIn: ipcInLink_tsk.c
# Compiling tda2px-evm:a15_0:release:links_common_ipcIn: ipcInLink_drv.c
# Compiling tda2px-evm:a15_0:release:links_common_ipcIn: ipcInLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:a15_0:release:links_common_ipcIn
# Compiling tda2px-evm:c66xdsp_1:release:links_common_ipcIn: ipcInLink_tsk.c
# Compiling tda2px-evm:c66xdsp_1:release:links_common_ipcIn: ipcInLink_drv.c
# Compiling tda2px-evm:c66xdsp_1:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:c66xdsp_1:release:links_common_ipcIn
# Compiling tda2px-evm:c66xdsp_2:release:links_common_ipcIn: ipcInLink_tsk.c
# Compiling tda2px-evm:c66xdsp_2:release:links_common_ipcIn: ipcInLink_drv.c
# Compiling tda2px-evm:c66xdsp_2:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:c66xdsp_2:release:links_common_ipcIn
# Compiling tda2px-evm:arp32_1:release:links_common_ipcIn: ipcInLink_tsk.c
# Compiling tda2px-evm:arp32_1:release:links_common_ipcIn: ipcInLink_drv.c
# Compiling tda2px-evm:arp32_1:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:arp32_1:release:links_common_ipcIn
# Compiling tda2px-evm:arp32_2:release:links_common_ipcIn: ipcInLink_tsk.c
# Compiling tda2px-evm:arp32_2:release:links_common_ipcIn: ipcInLink_drv.c
# Compiling tda2px-evm:arp32_2:release:links_common_ipcIn: ipcInLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:arp32_2:release:links_common_ipcIn
# Compiling tda2px-evm:ipu1_0:release:links_common_ipcOut: ipcOutLink_tsk.c
# Compiling tda2px-evm:ipu1_0:release:links_common_ipcOut: ipcOutLink_drv.c
# Compiling tda2px-evm:ipu1_0:release:links_common_ipcOut: ipcOutLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:ipu1_0:release:links_common_ipcOut
# Compiling tda2px-evm:ipu1_1:release:links_common_ipcOut: ipcOutLink_tsk.c
# Compiling tda2px-evm:ipu1_1:release:links_common_ipcOut: ipcOutLink_drv.c
# Compiling tda2px-evm:ipu1_1:release:links_common_ipcOut: ipcOutLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:ipu1_1:release:links_common_ipcOut
# Compiling tda2px-evm:ipu2:release:links_common_ipcOut: ipcOutLink_tsk.c
# Compiling tda2px-evm:ipu2:release:links_common_ipcOut: ipcOutLink_drv.c
# Compiling tda2px-evm:ipu2:release:links_common_ipcOut: ipcOutLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:ipu2:release:links_common_ipcOut
# Compiling tda2px-evm:a15_0:release:links_common_ipcOut: ipcOutLink_tsk.c
# Compiling tda2px-evm:a15_0:release:links_common_ipcOut: ipcOutLink_drv.c
# Compiling tda2px-evm:a15_0:release:links_common_ipcOut: ipcOutLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:a15_0:release:links_common_ipcOut
# Compiling tda2px-evm:c66xdsp_1:release:links_common_ipcOut: ipcOutLink_tsk.c
# Compiling tda2px-evm:c66xdsp_1:release:links_common_ipcOut: ipcOutLink_drv.c
# Compiling tda2px-evm:c66xdsp_1:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:c66xdsp_1:release:links_common_ipcOut
# Compiling tda2px-evm:c66xdsp_2:release:links_common_ipcOut: ipcOutLink_tsk.c
# Compiling tda2px-evm:c66xdsp_2:release:links_common_ipcOut: ipcOutLink_drv.c
# Compiling tda2px-evm:c66xdsp_2:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:c66xdsp_2:release:links_common_ipcOut
# Compiling tda2px-evm:arp32_1:release:links_common_ipcOut: ipcOutLink_tsk.c
# Compiling tda2px-evm:arp32_1:release:links_common_ipcOut: ipcOutLink_drv.c
# Compiling tda2px-evm:arp32_1:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:arp32_1:release:links_common_ipcOut
# Compiling tda2px-evm:arp32_2:release:links_common_ipcOut: ipcOutLink_tsk.c
# Compiling tda2px-evm:arp32_2:release:links_common_ipcOut: ipcOutLink_drv.c
# Compiling tda2px-evm:arp32_2:release:links_common_ipcOut: ipcOutLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:arp32_2:release:links_common_ipcOut
# Compiling tda2px-evm:ipu1_0:release:links_common_merge: mergeLink_tsk.c
# Compiling tda2px-evm:ipu1_0:release:links_common_merge: mergeLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:ipu1_0:release:links_common_merge
# Compiling tda2px-evm:ipu1_1:release:links_common_merge: mergeLink_tsk.c
# Compiling tda2px-evm:ipu1_1:release:links_common_merge: mergeLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:ipu1_1:release:links_common_merge
# Compiling tda2px-evm:ipu2:release:links_common_merge: mergeLink_tsk.c
# Compiling tda2px-evm:ipu2:release:links_common_merge: mergeLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:ipu2:release:links_common_merge
# Compiling tda2px-evm:a15_0:release:links_common_merge: mergeLink_tsk.c
# Compiling tda2px-evm:a15_0:release:links_common_merge: mergeLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:a15_0:release:links_common_merge
# Compiling tda2px-evm:c66xdsp_1:release:links_common_merge: mergeLink_tsk.c
# Compiling tda2px-evm:c66xdsp_1:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:c66xdsp_1:release:links_common_merge
# Compiling tda2px-evm:c66xdsp_2:release:links_common_merge: mergeLink_tsk.c
# Compiling tda2px-evm:c66xdsp_2:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:c66xdsp_2:release:links_common_merge
# Compiling tda2px-evm:arp32_1:release:links_common_merge: mergeLink_tsk.c
# Compiling tda2px-evm:arp32_1:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:arp32_1:release:links_common_merge
# Compiling tda2px-evm:arp32_2:release:links_common_merge: mergeLink_tsk.c
# Compiling tda2px-evm:arp32_2:release:links_common_merge: mergeLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:arp32_2:release:links_common_merge
# Compiling tda2px-evm:ipu1_0:release:links_common_null: nullLink_tsk.c
# Archiving tda2px-evm:ipu1_0:release:links_common_null
# Compiling tda2px-evm:ipu1_1:release:links_common_null: nullLink_tsk.c
# Archiving tda2px-evm:ipu1_1:release:links_common_null
# Compiling tda2px-evm:ipu2:release:links_common_null: nullLink_tsk.c
# Archiving tda2px-evm:ipu2:release:links_common_null
# Compiling tda2px-evm:a15_0:release:links_common_null: nullLink_tsk.c
# Archiving tda2px-evm:a15_0:release:links_common_null
# Compiling tda2px-evm:c66xdsp_1:release:links_common_null: nullLink_tsk.c
# Archiving tda2px-evm:c66xdsp_1:release:links_common_null
# Compiling tda2px-evm:c66xdsp_2:release:links_common_null: nullLink_tsk.c
# Archiving tda2px-evm:c66xdsp_2:release:links_common_null
# Compiling tda2px-evm:arp32_1:release:links_common_null: nullLink_tsk.c
# Archiving tda2px-evm:arp32_1:release:links_common_null
# Compiling tda2px-evm:arp32_2:release:links_common_null: nullLink_tsk.c
# Archiving tda2px-evm:arp32_2:release:links_common_null
# Compiling tda2px-evm:ipu1_0:release:links_common_nullSrc: nullSrcLink_tsk.c
# Archiving tda2px-evm:ipu1_0:release:links_common_nullSrc
# Compiling tda2px-evm:ipu1_1:release:links_common_nullSrc: nullSrcLink_tsk.c
# Archiving tda2px-evm:ipu1_1:release:links_common_nullSrc
# Compiling tda2px-evm:ipu2:release:links_common_nullSrc: nullSrcLink_tsk.c
# Archiving tda2px-evm:ipu2:release:links_common_nullSrc
# Compiling tda2px-evm:a15_0:release:links_common_nullSrc: nullSrcLink_tsk.c
# Archiving tda2px-evm:a15_0:release:links_common_nullSrc
# Compiling tda2px-evm:ipu1_0:release:links_common_select: selectLink_tsk.c
# Compiling tda2px-evm:ipu1_0:release:links_common_select: selectLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:ipu1_0:release:links_common_select
# Compiling tda2px-evm:ipu1_1:release:links_common_select: selectLink_tsk.c
# Compiling tda2px-evm:ipu1_1:release:links_common_select: selectLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:ipu1_1:release:links_common_select
# Compiling tda2px-evm:ipu2:release:links_common_select: selectLink_tsk.c
# Compiling tda2px-evm:ipu2:release:links_common_select: selectLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:ipu2:release:links_common_select
# Compiling tda2px-evm:a15_0:release:links_common_select: selectLink_tsk.c
# Compiling tda2px-evm:a15_0:release:links_common_select: selectLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:a15_0:release:links_common_select
# Compiling tda2px-evm:c66xdsp_1:release:links_common_select: selectLink_tsk.c
# Compiling tda2px-evm:c66xdsp_1:release:links_common_select: selectLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:c66xdsp_1:release:links_common_select
# Compiling tda2px-evm:c66xdsp_2:release:links_common_select: selectLink_tsk.c
# Compiling tda2px-evm:c66xdsp_2:release:links_common_select: selectLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:c66xdsp_2:release:links_common_select
# Compiling tda2px-evm:arp32_1:release:links_common_select: selectLink_tsk.c
# Compiling tda2px-evm:arp32_1:release:links_common_select: selectLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:arp32_1:release:links_common_select
# Compiling tda2px-evm:arp32_2:release:links_common_select: selectLink_tsk.c
# Compiling tda2px-evm:arp32_2:release:links_common_select: selectLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:arp32_2:release:links_common_select
# Compiling tda2px-evm:ipu1_0:release:links_common_sync: syncLink_tsk.c
# Compiling tda2px-evm:ipu1_0:release:links_common_sync: syncLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:ipu1_0:release:links_common_sync
# Compiling tda2px-evm:ipu1_1:release:links_common_sync: syncLink_tsk.c
# Compiling tda2px-evm:ipu1_1:release:links_common_sync: syncLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:ipu1_1:release:links_common_sync
# Compiling tda2px-evm:ipu2:release:links_common_sync: syncLink_tsk.c
# Compiling tda2px-evm:ipu2:release:links_common_sync: syncLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:ipu2:release:links_common_sync
# Compiling tda2px-evm:a15_0:release:links_common_sync: syncLink_tsk.c
# Compiling tda2px-evm:a15_0:release:links_common_sync: syncLink_tsk_create_single_mbx.c
# Archiving tda2px-evm:a15_0:release:links_common_sync
# Compiling tda2px-evm:c66xdsp_1:release:links_common_sync: syncLink_tsk.c
# Compiling tda2px-evm:c66xdsp_1:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:c66xdsp_1:release:links_common_sync
# Compiling tda2px-evm:c66xdsp_2:release:links_common_sync: syncLink_tsk.c
# Compiling tda2px-evm:c66xdsp_2:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:c66xdsp_2:release:links_common_sync
# Compiling tda2px-evm:arp32_1:release:links_common_sync: syncLink_tsk.c
# Compiling tda2px-evm:arp32_1:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:arp32_1:release:links_common_sync
# Compiling tda2px-evm:arp32_2:release:links_common_sync: syncLink_tsk.c
# Compiling tda2px-evm:arp32_2:release:links_common_sync: syncLink_tsk_create_multi_mbx.c
# Archiving tda2px-evm:arp32_2:release:links_common_sync
# Compiling tda2px-evm:ipu1_0:release:links_ipu_display: displayLink_tsk.c
# Compiling tda2px-evm:ipu1_0:release:links_ipu_display: displayLink_drv.c
# Archiving tda2px-evm:ipu1_0:release:links_ipu_display
# Compiling tda2px-evm:ipu1_0:release:links_ipu_display_ctrl: displayCtrlLink_tsk.c
# Compiling tda2px-evm:ipu1_0:release:links_ipu_display_ctrl: displayCtrlLink_drv.c
# Archiving tda2px-evm:ipu1_0:release:links_ipu_display_ctrl
# Compiling tda2px-evm:ipu1_0:release:links_ipu_iss_capture: issCaptureLink_tsk.c
# Compiling tda2px-evm:ipu1_0:release:links_ipu_iss_capture: issCaptureLink_drv.c
# Archiving tda2px-evm:ipu1_0:release:links_ipu_iss_capture
# Compiling tda2px-evm:ipu1_0:release:links_ipu_iss_m2misp: issM2mIspLink_tsk.c
# Compiling tda2px-evm:ipu1_0:release:links_ipu_iss_m2misp: issM2mIspLink_drv_apply_config.c
# Compiling tda2px-evm:ipu1_0:release:links_ipu_iss_m2misp: issM2mIspLink_drv_create_delete.c
# Compiling tda2px-evm:ipu1_0:release:links_ipu_iss_m2misp: issM2mIspLink_drv_process_frame.c
# Archiving tda2px-evm:ipu1_0:release:links_ipu_iss_m2misp
# Compiling tda2px-evm:ipu1_0:release:links_ipu_iss_m2msimcop: issM2mSimcopLink_tsk.c
# Compiling tda2px-evm:ipu1_0:release:links_ipu_iss_m2msimcop: issM2mSimcopLink_drv.c
# Archiving tda2px-evm:ipu1_0:release:links_ipu_iss_m2msimcop
# Compiling tda2px-evm:ipu1_0:release:links_ipu_iss_m2mresizer: issResizer_tsk.c
# Compiling tda2px-evm:ipu1_0:release:links_ipu_iss_m2mresizer: issResizer_drv.c
# Archiving tda2px-evm:ipu1_0:release:links_ipu_iss_m2mresizer
# Compiling tda2px-evm:ipu1_0:release:links_ipu_CANLink: CANLink_drv.c
# Compiling tda2px-evm:ipu1_0:release:links_ipu_CANLink: CANLink_tsk.c
# Compiling tda2px-evm:ipu1_0:release:links_ipu_CANLink: CAN_api.c
# Compiling tda2px-evm:ipu1_0:release:links_ipu_CANLink: csl_mcan.c
# Compiling tda2px-evm:ipu1_0:release:links_ipu_CANLink: system_mcan.c
# Compiling tda2px-evm:ipu1_0:release:links_ipu_CANLink: utils_mcan.c
# Compiling tda2px-evm:ipu1_0:release:links_ipu_CANLink: configManager.c
# Archiving tda2px-evm:ipu1_0:release:links_ipu_CANLink
# Compiling tda2px-evm:ipu1_0:release:links_ipu_vip_capture: captureLink_tsk.c
# Compiling tda2px-evm:ipu1_0:release:links_ipu_vip_capture: captureLink_drv.c
# Compiling tda2px-evm:ipu1_0:release:links_ipu_vip_capture: captureLink_subframe_drv.c
# Compiling tda2px-evm:ipu1_0:release:links_ipu_vip_capture: captureLink_displaywb_drv.c
# Archiving tda2px-evm:ipu1_0:release:links_ipu_vip_capture
# Compiling tda2px-evm:ipu1_0:release:links_ipu_vpe: vpeLink_tsk.c
# Compiling tda2px-evm:ipu1_0:release:links_ipu_vpe: vpeLink_drvCommon.c
# Compiling tda2px-evm:ipu1_0:release:links_ipu_vpe: vpeLink_drv.c
# Archiving tda2px-evm:ipu1_0:release:links_ipu_vpe
# Compiling tda2px-evm:ipu1_0:release:links_ipu_dssM2mWb: dssM2mWbLink_tsk.c
# Compiling tda2px-evm:ipu1_0:release:links_ipu_dssM2mWb: dssM2mWbLink_drv.c
# Archiving tda2px-evm:ipu1_0:release:links_ipu_dssM2mWb
# Compiling tda2px-evm:ipu2:release:links_ipu_ssdOverlayLink: ssdOverlayLink_tsk.c
# Compiling tda2px-evm:ipu2:release:links_ipu_ssdOverlayLink: ssdOverlayLink_drv.c
# Compiling tda2px-evm:ipu2:release:links_ipu_ssdOverlayLink: ackermann_model.c
# Compiling tda2px-evm:ipu2:release:links_ipu_ssdOverlayLink: camera.c
# Compiling tda2px-evm:ipu2:release:links_ipu_ssdOverlayLink: car_config.c
# Compiling tda2px-evm:ipu2:release:links_ipu_ssdOverlayLink: draw_trajectory.c
# Compiling tda2px-evm:ipu2:release:links_ipu_ssdOverlayLink: ipm.c
# Compiling tda2px-evm:ipu2:release:links_ipu_ssdOverlayLink: mat.c
# Archiving tda2px-evm:ipu2:release:links_ipu_ssdOverlayLink
# Compiling tda2px-evm:ipu1_0:release:utils_common: tda2px/utils_clk.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_remote_log_server.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_buf.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_mbx.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_mem.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_prf.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_que.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_tsk.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_tsk_multi_mbx.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_ipc_que.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_remote_log_client.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_global_time.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_buf_ext.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_timer_reconfig.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_link_stats_collector.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_pm.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_spinlock.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: safety_osal.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_cio.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: tda2px/utils_l3_emif_bw.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_execp_trace_local_m4.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_uart.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_dma.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: dma_cfg/utils_dma_edma3cc.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: dma_cfg/utils_dma_edma3cc_ipu_a15_intr.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_cbuf_ocmc.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_qspi.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_idle_m4.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_temperature.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_stat_collector.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_prcm_stats.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_emif_ecc.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_l3fw.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: stat_collector_utils/sci.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: stat_collector_utils/cToolsHelper.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_mcspi.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_mem_ipu1_0.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: dma_cfg/utils_dma_cfg_ipu1_0.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_taskTimer.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: stat_collector_utils/sci_config_dra7xx.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: utils_iss.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: file_api.c
# Compiling tda2px-evm:ipu1_0:release:utils_common: file_api_dma.c
# Archiving tda2px-evm:ipu1_0:release:utils_common
# Compiling tda2px-evm:ipu1_1:release:utils_common: tda2px/utils_clk.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: utils_remote_log_server.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: utils.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: utils_buf.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: utils_mbx.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: utils_mem.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: utils_prf.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: utils_que.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: utils_tsk.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: utils_tsk_multi_mbx.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: utils_ipc_que.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: utils_remote_log_client.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: utils_global_time.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: utils_buf_ext.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: utils_timer_reconfig.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: utils_link_stats_collector.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: utils_pm.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: utils_spinlock.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: safety_osal.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: utils_cio.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: utils_iss.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: utils_execp_trace_remote_m4.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: utils_dma.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: dma_cfg/utils_dma_edma3cc.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: dma_cfg/utils_dma_edma3cc_ipu_a15_intr.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: dma_cfg/utils_dma_cfg_ipu1_1.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: utils_idle_m4.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: utils_stat_collector.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: stat_collector_utils/sci.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: stat_collector_utils/cToolsHelper.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: utils_qspi.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: file_api.c
# Compiling tda2px-evm:ipu1_1:release:utils_common: file_api_dma.c
# Archiving tda2px-evm:ipu1_1:release:utils_common
# Compiling tda2px-evm:ipu2:release:utils_common: tda2px/utils_clk.c
# Compiling tda2px-evm:ipu2:release:utils_common: utils_remote_log_server.c
# Compiling tda2px-evm:ipu2:release:utils_common: utils.c
# Compiling tda2px-evm:ipu2:release:utils_common: utils_buf.c
# Compiling tda2px-evm:ipu2:release:utils_common: utils_mbx.c
# Compiling tda2px-evm:ipu2:release:utils_common: utils_mem.c
# Compiling tda2px-evm:ipu2:release:utils_common: utils_prf.c
# Compiling tda2px-evm:ipu2:release:utils_common: utils_que.c
# Compiling tda2px-evm:ipu2:release:utils_common: utils_tsk.c
# Compiling tda2px-evm:ipu2:release:utils_common: utils_tsk_multi_mbx.c
# Compiling tda2px-evm:ipu2:release:utils_common: utils_ipc_que.c
# Compiling tda2px-evm:ipu2:release:utils_common: utils_remote_log_client.c
# Compiling tda2px-evm:ipu2:release:utils_common: utils_global_time.c
# Compiling tda2px-evm:ipu2:release:utils_common: utils_buf_ext.c
# Compiling tda2px-evm:ipu2:release:utils_common: utils_timer_reconfig.c
# Compiling tda2px-evm:ipu2:release:utils_common: utils_link_stats_collector.c
# Compiling tda2px-evm:ipu2:release:utils_common: utils_pm.c
# Compiling tda2px-evm:ipu2:release:utils_common: utils_spinlock.c
# Compiling tda2px-evm:ipu2:release:utils_common: safety_osal.c
# Compiling tda2px-evm:ipu2:release:utils_common: utils_cio.c
# Compiling tda2px-evm:ipu2:release:utils_common: dma_cfg/utils_dma_cfg_ipu2.c
# Compiling tda2px-evm:ipu2:release:utils_common: utils_execp_trace_remote_m4.c
# Compiling tda2px-evm:ipu2:release:utils_common: utils_dma.c
# Compiling tda2px-evm:ipu2:release:utils_common: dma_cfg/utils_dma_edma3cc.c
# Compiling tda2px-evm:ipu2:release:utils_common: dma_cfg/utils_dma_edma3cc_ipu_a15_intr.c
# Compiling tda2px-evm:ipu2:release:utils_common: utils_idle_m4.c
# Compiling tda2px-evm:ipu2:release:utils_common: utils_stat_collector.c
# Compiling tda2px-evm:ipu2:release:utils_common: stat_collector_utils/sci.c
# Compiling tda2px-evm:ipu2:release:utils_common: stat_collector_utils/cToolsHelper.c
# Compiling tda2px-evm:ipu2:release:utils_common: utils_qspi.c
# Compiling tda2px-evm:ipu2:release:utils_common: file_api.c
# Compiling tda2px-evm:ipu2:release:utils_common: file_api_dma.c
# Archiving tda2px-evm:ipu2:release:utils_common
# Compiling tda2px-evm:a15_0:release:utils_common: tda2px/utils_clk.c
# Compiling tda2px-evm:a15_0:release:utils_common: utils_remote_log_server.c
# Compiling tda2px-evm:a15_0:release:utils_common: utils.c
# Compiling tda2px-evm:a15_0:release:utils_common: utils_buf.c
# Compiling tda2px-evm:a15_0:release:utils_common: utils_mbx.c
# Compiling tda2px-evm:a15_0:release:utils_common: utils_mem.c
# Compiling tda2px-evm:a15_0:release:utils_common: utils_prf.c
# Compiling tda2px-evm:a15_0:release:utils_common: utils_que.c
# Compiling tda2px-evm:a15_0:release:utils_common: utils_tsk.c
# Compiling tda2px-evm:a15_0:release:utils_common: utils_tsk_multi_mbx.c
# Compiling tda2px-evm:a15_0:release:utils_common: utils_ipc_que.c
# Compiling tda2px-evm:a15_0:release:utils_common: utils_remote_log_client.c
# Compiling tda2px-evm:a15_0:release:utils_common: utils_global_time.c
# Compiling tda2px-evm:a15_0:release:utils_common: utils_buf_ext.c
# Compiling tda2px-evm:a15_0:release:utils_common: utils_timer_reconfig.c
# Compiling tda2px-evm:a15_0:release:utils_common: utils_link_stats_collector.c
# Compiling tda2px-evm:a15_0:release:utils_common: utils_pm.c
# Compiling tda2px-evm:a15_0:release:utils_common: utils_spinlock.c
# Compiling tda2px-evm:a15_0:release:utils_common: safety_osal.c
# Compiling tda2px-evm:a15_0:release:utils_common: utils_cio.c
# Compiling tda2px-evm:a15_0:release:utils_common: utils_dma.c
# Compiling tda2px-evm:a15_0:release:utils_common: dma_cfg/utils_dma_edma3cc.c
# Compiling tda2px-evm:a15_0:release:utils_common: dma_cfg/utils_dma_edma3cc_ipu_a15_intr.c
# Compiling tda2px-evm:a15_0:release:utils_common: dma_cfg/utils_dma_cfg_a15_0.c
# Compiling tda2px-evm:a15_0:release:utils_common: utils_execp_trace_a15.c
# Compiling tda2px-evm:a15_0:release:utils_common: utils_idle_a15.c
# Compiling tda2px-evm:a15_0:release:utils_common: utils_qspi.c
# Compiling tda2px-evm:a15_0:release:utils_common: file_api.c
# Compiling tda2px-evm:a15_0:release:utils_common: file_api_dma.c
# Archiving tda2px-evm:a15_0:release:utils_common
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: tda2px/utils_clk.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: utils_remote_log_server.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: utils.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: utils_buf.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: utils_mbx.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: utils_mem.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: utils_prf.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: utils_que.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: utils_tsk.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: utils_tsk_multi_mbx.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: utils_ipc_que.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: utils_remote_log_client.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: utils_global_time.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: utils_buf_ext.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: utils_timer_reconfig.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: utils_link_stats_collector.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: utils_pm.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: utils_spinlock.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: safety_osal.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: utils_cio.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: utils_execp_trace_dsp.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: utils_dma.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: dma_cfg/utils_dma_edma3cc.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: dma_cfg/utils_dma_cfg_dsp1.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: dma_cfg/utils_dma_edma3cc_dsp_intr.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: utils_idle_c66x.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: utils_cache_c66x.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: utils_l3fw.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: utils_xmc_mpu.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: utils_ecc_c66x.c
# Compiling tda2px-evm:c66xdsp_1:release:utils_common: utils_taskTimer.c
# Archiving tda2px-evm:c66xdsp_1:release:utils_common
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: tda2px/utils_clk.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: utils_remote_log_server.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: utils.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: utils_buf.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: utils_mbx.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: utils_mem.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: utils_prf.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: utils_que.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: utils_tsk.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: utils_tsk_multi_mbx.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: utils_ipc_que.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: utils_remote_log_client.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: utils_global_time.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: utils_buf_ext.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: utils_timer_reconfig.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: utils_link_stats_collector.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: utils_pm.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: utils_spinlock.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: safety_osal.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: utils_cio.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: utils_execp_trace_dsp.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: utils_dma.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: dma_cfg/utils_dma_edma3cc.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: dma_cfg/utils_dma_cfg_dsp2.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: dma_cfg/utils_dma_edma3cc_dsp_intr.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: utils_idle_c66x.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: utils_cache_c66x.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: utils_l3fw.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: utils_xmc_mpu.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: utils_ecc_c66x.c
# Compiling tda2px-evm:c66xdsp_2:release:utils_common: utils_taskTimer.c
# Archiving tda2px-evm:c66xdsp_2:release:utils_common
# Compiling tda2px-evm:arp32_1:release:utils_common: tda2px/utils_clk.c
# Compiling tda2px-evm:arp32_1:release:utils_common: utils_remote_log_server.c
# Compiling tda2px-evm:arp32_1:release:utils_common: utils.c
# Compiling tda2px-evm:arp32_1:release:utils_common: utils_buf.c
# Compiling tda2px-evm:arp32_1:release:utils_common: utils_mbx.c
# Compiling tda2px-evm:arp32_1:release:utils_common: utils_mem.c
# Compiling tda2px-evm:arp32_1:release:utils_common: utils_prf.c
# Compiling tda2px-evm:arp32_1:release:utils_common: utils_que.c
# Compiling tda2px-evm:arp32_1:release:utils_common: utils_tsk.c
# Compiling tda2px-evm:arp32_1:release:utils_common: utils_tsk_multi_mbx.c
# Compiling tda2px-evm:arp32_1:release:utils_common: utils_ipc_que.c
# Compiling tda2px-evm:arp32_1:release:utils_common: utils_remote_log_client.c
# Compiling tda2px-evm:arp32_1:release:utils_common: utils_global_time.c
# Compiling tda2px-evm:arp32_1:release:utils_common: utils_buf_ext.c
# Compiling tda2px-evm:arp32_1:release:utils_common: utils_timer_reconfig.c
# Compiling tda2px-evm:arp32_1:release:utils_common: utils_link_stats_collector.c
# Compiling tda2px-evm:arp32_1:release:utils_common: utils_pm.c
# Compiling tda2px-evm:arp32_1:release:utils_common: utils_spinlock.c
# Compiling tda2px-evm:arp32_1:release:utils_common: safety_osal.c
# Compiling tda2px-evm:arp32_1:release:utils_common: utils_cio.c
# Compiling tda2px-evm:arp32_1:release:utils_common: utils_dma.c
# Compiling tda2px-evm:arp32_1:release:utils_common: dma_cfg/utils_dma_edma3cc.c
# Compiling tda2px-evm:arp32_1:release:utils_common: dma_cfg/utils_dma_cfg_eve.c
# Compiling tda2px-evm:arp32_1:release:utils_common: dma_cfg/utils_dma_edma3cc_eve_intr.c
# Compiling tda2px-evm:arp32_1:release:utils_common: utils_vip_interrupt.c
# Compiling tda2px-evm:arp32_1:release:utils_common: utils_execp_trace_eve.c
# Compiling tda2px-evm:arp32_1:release:utils_common: utils_idle_arp32.c
# Compiling tda2px-evm:arp32_1:release:utils_common: utils_l3fw.c
# Archiving tda2px-evm:arp32_1:release:utils_common
# Compiling tda2px-evm:arp32_2:release:utils_common: tda2px/utils_clk.c
# Compiling tda2px-evm:arp32_2:release:utils_common: utils_remote_log_server.c
# Compiling tda2px-evm:arp32_2:release:utils_common: utils.c
# Compiling tda2px-evm:arp32_2:release:utils_common: utils_buf.c
# Compiling tda2px-evm:arp32_2:release:utils_common: utils_mbx.c
# Compiling tda2px-evm:arp32_2:release:utils_common: utils_mem.c
# Compiling tda2px-evm:arp32_2:release:utils_common: utils_prf.c
# Compiling tda2px-evm:arp32_2:release:utils_common: utils_que.c
# Compiling tda2px-evm:arp32_2:release:utils_common: utils_tsk.c
# Compiling tda2px-evm:arp32_2:release:utils_common: utils_tsk_multi_mbx.c
# Compiling tda2px-evm:arp32_2:release:utils_common: utils_ipc_que.c
# Compiling tda2px-evm:arp32_2:release:utils_common: utils_remote_log_client.c
# Compiling tda2px-evm:arp32_2:release:utils_common: utils_global_time.c
# Compiling tda2px-evm:arp32_2:release:utils_common: utils_buf_ext.c
# Compiling tda2px-evm:arp32_2:release:utils_common: utils_timer_reconfig.c
# Compiling tda2px-evm:arp32_2:release:utils_common: utils_link_stats_collector.c
# Compiling tda2px-evm:arp32_2:release:utils_common: utils_pm.c
# Compiling tda2px-evm:arp32_2:release:utils_common: utils_spinlock.c
# Compiling tda2px-evm:arp32_2:release:utils_common: safety_osal.c
# Compiling tda2px-evm:arp32_2:release:utils_common: utils_cio.c
# Compiling tda2px-evm:arp32_2:release:utils_common: utils_dma.c
# Compiling tda2px-evm:arp32_2:release:utils_common: dma_cfg/utils_dma_edma3cc.c
# Compiling tda2px-evm:arp32_2:release:utils_common: dma_cfg/utils_dma_cfg_eve.c
# Compiling tda2px-evm:arp32_2:release:utils_common: dma_cfg/utils_dma_edma3cc_eve_intr.c
# Compiling tda2px-evm:arp32_2:release:utils_common: utils_vip_interrupt.c
# Compiling tda2px-evm:arp32_2:release:utils_common: utils_execp_trace_eve.c
# Compiling tda2px-evm:arp32_2:release:utils_common: utils_idle_arp32.c
# Compiling tda2px-evm:arp32_2:release:utils_common: utils_l3fw.c
# Archiving tda2px-evm:arp32_2:release:utils_common
# Compiling tda2px-evm:ipu1_0:release:links_common_system: system_linkApi.c
# Compiling tda2px-evm:ipu1_0:release:links_common_system: system_linkApi_local.c
# Compiling tda2px-evm:ipu1_0:release:links_common_system: system_common.c
# Compiling tda2px-evm:ipu1_0:release:links_common_system: system_ipc.c
# Compiling tda2px-evm:ipu1_0:release:links_common_system: system_ipc_msgq.c
# Compiling tda2px-evm:ipu1_0:release:links_common_system: system_tsk_multi_mbx.c
# Compiling tda2px-evm:ipu1_0:release:links_common_system: system_openvxipc.c
# Compiling tda2px-evm:ipu1_0:release:links_common_system: system_work_queue_if.c
# Compiling tda2px-evm:ipu1_0:release:links_common_system: system_work_queue_tsk.c
# Compiling tda2px-evm:ipu1_0:release:links_common_system: system_work_queue_unit_test.c
# Compiling tda2px-evm:ipu1_0:release:links_common_system: system_initDeinitLinks.c
# Compiling tda2px-evm:ipu1_0:release:links_common_system: system_ipc_bios_ipc.c
# Archiving tda2px-evm:ipu1_0:release:links_common_system
# Compiling tda2px-evm:ipu1_1:release:links_common_system: system_linkApi.c
# Compiling tda2px-evm:ipu1_1:release:links_common_system: system_linkApi_local.c
# Compiling tda2px-evm:ipu1_1:release:links_common_system: system_common.c
# Compiling tda2px-evm:ipu1_1:release:links_common_system: system_ipc.c
# Compiling tda2px-evm:ipu1_1:release:links_common_system: system_ipc_msgq.c
# Compiling tda2px-evm:ipu1_1:release:links_common_system: system_tsk_multi_mbx.c
# Compiling tda2px-evm:ipu1_1:release:links_common_system: system_openvxipc.c
# Compiling tda2px-evm:ipu1_1:release:links_common_system: system_work_queue_if.c
# Compiling tda2px-evm:ipu1_1:release:links_common_system: system_work_queue_tsk.c
# Compiling tda2px-evm:ipu1_1:release:links_common_system: system_work_queue_unit_test.c
# Compiling tda2px-evm:ipu1_1:release:links_common_system: system_initDeinitLinks.c
# Compiling tda2px-evm:ipu1_1:release:links_common_system: system_ipc_bios_ipc.c
# Archiving tda2px-evm:ipu1_1:release:links_common_system
# Compiling tda2px-evm:ipu2:release:links_common_system: system_linkApi.c
# Compiling tda2px-evm:ipu2:release:links_common_system: system_linkApi_local.c
# Compiling tda2px-evm:ipu2:release:links_common_system: system_common.c
# Compiling tda2px-evm:ipu2:release:links_common_system: system_ipc.c
# Compiling tda2px-evm:ipu2:release:links_common_system: system_ipc_msgq.c
# Compiling tda2px-evm:ipu2:release:links_common_system: system_tsk_multi_mbx.c
# Compiling tda2px-evm:ipu2:release:links_common_system: system_openvxipc.c
# Compiling tda2px-evm:ipu2:release:links_common_system: system_work_queue_if.c
# Compiling tda2px-evm:ipu2:release:links_common_system: system_work_queue_tsk.c
# Compiling tda2px-evm:ipu2:release:links_common_system: system_work_queue_unit_test.c
# Compiling tda2px-evm:ipu2:release:links_common_system: system_initDeinitLinks.c
# Compiling tda2px-evm:ipu2:release:links_common_system: system_ipc_bios_ipc.c
# Archiving tda2px-evm:ipu2:release:links_common_system
# Compiling tda2px-evm:a15_0:release:links_common_system: system_linkApi.c
# Compiling tda2px-evm:a15_0:release:links_common_system: system_linkApi_local.c
# Compiling tda2px-evm:a15_0:release:links_common_system: system_common.c
# Compiling tda2px-evm:a15_0:release:links_common_system: system_ipc.c
# Compiling tda2px-evm:a15_0:release:links_common_system: system_ipc_msgq.c
# Compiling tda2px-evm:a15_0:release:links_common_system: system_tsk_multi_mbx.c
# Compiling tda2px-evm:a15_0:release:links_common_system: system_openvxipc.c
# Compiling tda2px-evm:a15_0:release:links_common_system: system_work_queue_if.c
# Compiling tda2px-evm:a15_0:release:links_common_system: system_work_queue_tsk.c
# Compiling tda2px-evm:a15_0:release:links_common_system: system_work_queue_unit_test.c
# Compiling tda2px-evm:a15_0:release:links_common_system: system_initDeinitLinks.c
# Compiling tda2px-evm:a15_0:release:links_common_system: system_ipc_bios_ipc.c
# Archiving tda2px-evm:a15_0:release:links_common_system
# Compiling tda2px-evm:c66xdsp_1:release:links_common_system: system_linkApi.c
# Compiling tda2px-evm:c66xdsp_1:release:links_common_system: system_linkApi_local.c
# Compiling tda2px-evm:c66xdsp_1:release:links_common_system: system_common.c
# Compiling tda2px-evm:c66xdsp_1:release:links_common_system: system_ipc.c
# Compiling tda2px-evm:c66xdsp_1:release:links_common_system: system_ipc_msgq.c
# Compiling tda2px-evm:c66xdsp_1:release:links_common_system: system_tsk_multi_mbx.c
# Compiling tda2px-evm:c66xdsp_1:release:links_common_system: system_openvxipc.c
# Compiling tda2px-evm:c66xdsp_1:release:links_common_system: system_work_queue_if.c
# Compiling tda2px-evm:c66xdsp_1:release:links_common_system: system_work_queue_tsk.c
# Compiling tda2px-evm:c66xdsp_1:release:links_common_system: system_work_queue_unit_test.c
# Compiling tda2px-evm:c66xdsp_1:release:links_common_system: system_initDeinitLinks.c
# Compiling tda2px-evm:c66xdsp_1:release:links_common_system: system_ipc_bios_ipc.c
# Archiving tda2px-evm:c66xdsp_1:release:links_common_system
# Compiling tda2px-evm:c66xdsp_2:release:links_common_system: system_linkApi.c
# Compiling tda2px-evm:c66xdsp_2:release:links_common_system: system_linkApi_local.c
# Compiling tda2px-evm:c66xdsp_2:release:links_common_system: system_common.c
# Compiling tda2px-evm:c66xdsp_2:release:links_common_system: system_ipc.c
# Compiling tda2px-evm:c66xdsp_2:release:links_common_system: system_ipc_msgq.c
# Compiling tda2px-evm:c66xdsp_2:release:links_common_system: system_tsk_multi_mbx.c
# Compiling tda2px-evm:c66xdsp_2:release:links_common_system: system_openvxipc.c
# Compiling tda2px-evm:c66xdsp_2:release:links_common_system: system_work_queue_if.c
# Compiling tda2px-evm:c66xdsp_2:release:links_common_system: system_work_queue_tsk.c
# Compiling tda2px-evm:c66xdsp_2:release:links_common_system: system_work_queue_unit_test.c
# Compiling tda2px-evm:c66xdsp_2:release:links_common_system: system_initDeinitLinks.c
# Compiling tda2px-evm:c66xdsp_2:release:links_common_system: system_ipc_bios_ipc.c
# Archiving tda2px-evm:c66xdsp_2:release:links_common_system
# Compiling tda2px-evm:arp32_1:release:links_common_system: system_linkApi.c
# Compiling tda2px-evm:arp32_1:release:links_common_system: system_linkApi_local.c
# Compiling tda2px-evm:arp32_1:release:links_common_system: system_common.c
# Compiling tda2px-evm:arp32_1:release:links_common_system: system_ipc.c
# Compiling tda2px-evm:arp32_1:release:links_common_system: system_ipc_msgq.c
# Compiling tda2px-evm:arp32_1:release:links_common_system: system_tsk_multi_mbx.c
# Compiling tda2px-evm:arp32_1:release:links_common_system: system_openvxipc.c
# Compiling tda2px-evm:arp32_1:release:links_common_system: system_work_queue_if.c
# Compiling tda2px-evm:arp32_1:release:links_common_system: system_work_queue_tsk.c
# Compiling tda2px-evm:arp32_1:release:links_common_system: system_work_queue_unit_test.c
# Compiling tda2px-evm:arp32_1:release:links_common_system: system_initDeinitLinks.c
# Compiling tda2px-evm:arp32_1:release:links_common_system: system_ipc_bios_ipc.c
# Archiving tda2px-evm:arp32_1:release:links_common_system
# Compiling tda2px-evm:arp32_2:release:links_common_system: system_linkApi.c
# Compiling tda2px-evm:arp32_2:release:links_common_system: system_linkApi_local.c
# Compiling tda2px-evm:arp32_2:release:links_common_system: system_common.c
# Compiling tda2px-evm:arp32_2:release:links_common_system: system_ipc.c
# Compiling tda2px-evm:arp32_2:release:links_common_system: system_ipc_msgq.c
# Compiling tda2px-evm:arp32_2:release:links_common_system: system_tsk_multi_mbx.c
# Compiling tda2px-evm:arp32_2:release:links_common_system: system_openvxipc.c
# Compiling tda2px-evm:arp32_2:release:links_common_system: system_work_queue_if.c
# Compiling tda2px-evm:arp32_2:release:links_common_system: system_work_queue_tsk.c
# Compiling tda2px-evm:arp32_2:release:links_common_system: system_work_queue_unit_test.c
# Compiling tda2px-evm:arp32_2:release:links_common_system: system_initDeinitLinks.c
# Compiling tda2px-evm:arp32_2:release:links_common_system: system_ipc_bios_ipc.c
# Archiving tda2px-evm:arp32_2:release:links_common_system
# Compiling tda2px-evm:c66xdsp_1:release:links_dsp_system: system_c6xdsp.c
# Compiling tda2px-evm:c66xdsp_1:release:links_dsp_system: systemLink_tsk_c6xdsp.c
# Archiving tda2px-evm:c66xdsp_1:release:links_dsp_system
# Compiling tda2px-evm:c66xdsp_2:release:links_dsp_system: system_c6xdsp.c
# Compiling tda2px-evm:c66xdsp_2:release:links_dsp_system: systemLink_tsk_c6xdsp.c
# Archiving tda2px-evm:c66xdsp_2:release:links_dsp_system
# Compiling tda2px-evm:arp32_1:release:links_eve_system: system_eve.c
# Compiling tda2px-evm:arp32_1:release:links_eve_system: systemLink_tsk_eve.c
# Compiling tda2px-evm:arp32_1:release:links_eve_system: systemLink_tsk_eve_multi_mbx.c
# Archiving tda2px-evm:arp32_1:release:links_eve_system
# Compiling tda2px-evm:arp32_2:release:links_eve_system: system_eve.c
# Compiling tda2px-evm:arp32_2:release:links_eve_system: systemLink_tsk_eve.c
# Compiling tda2px-evm:arp32_2:release:links_eve_system: systemLink_tsk_eve_multi_mbx.c
# Archiving tda2px-evm:arp32_2:release:links_eve_system
# Compiling tda2px-evm:ipu1_0:release:links_ipu_system: system_bsp_init.c
# Compiling tda2px-evm:ipu1_0:release:links_ipu_system: system_ipu1_0.c
# Compiling tda2px-evm:ipu1_0:release:links_ipu_system: systemLink_tsk_ipu1.c
# Archiving tda2px-evm:ipu1_0:release:links_ipu_system
# Compiling tda2px-evm:ipu1_1:release:links_ipu_system: system_ipu1_1.c
# Compiling tda2px-evm:ipu1_1:release:links_ipu_system: systemLink_tsk_ipu1.c
# Archiving tda2px-evm:ipu1_1:release:links_ipu_system
# Compiling tda2px-evm:ipu2:release:links_ipu_system: system_ipu2.c
# Compiling tda2px-evm:ipu2:release:links_ipu_system: systemLink_tsk_ipu2.c
# Archiving tda2px-evm:ipu2:release:links_ipu_system
# Compiling tda2px-evm:a15_0:release:links_a15_system: system_a15.c
# Compiling tda2px-evm:a15_0:release:links_a15_system: systemLink_tsk_a15.c
# Archiving tda2px-evm:a15_0:release:links_a15_system
# Compiling tda2px-evm:ipu1_0:release:app_alg_plugins: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/draw2d/draw2d_font_bmp.c
# Archiving tda2px-evm:ipu1_0:release:app_alg_plugins
# Compiling tda2px-evm:c66xdsp_1:release:app_alg_plugins: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/draw2d/draw2d_font_bmp.c
# Archiving tda2px-evm:c66xdsp_1:release:app_alg_plugins
# Compiling tda2px-evm:arp32_1:release:app_alg_plugins: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/draw2d/draw2d_font_bmp.c
# Archiving tda2px-evm:arp32_1:release:app_alg_plugins
# Compiling tda2px-evm:a15_0:release:app_alg_plugins: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/draw2d/draw2d_font_bmp.c
# Archiving tda2px-evm:a15_0:release:app_alg_plugins
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/common/chains_main_bios_settings.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/common/chains_main_bios.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/common/chains_main_bios_settings_vision.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/common/chains_main_bios_misc.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/common/chains_main_bios_vision.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/common/chains_main_bios_multi_cam.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/common/chains_main_bios_single_cam.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/common/chains_main_bios_iss.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/board/board_tda2xx_ti_evm.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_tsk.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_cpu_load.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_srv_calib_layout.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_sved_layout.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_sv_sof_layout.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_OF_layout.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_stereo_layout.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_stereo_multiFCalg_layout.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_pd_tsr_ld_layout.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_pd_tsr_ld_sof_layout.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_pd_tsr_ld_sof_stereo_layout.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_svStandalone_layout.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_svStandalone_layout2.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_fcAnalytics2_layout.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_sfm.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_Tda3x3DSv_layout.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_Tda3x2D3DSv_layout.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_Tda3xRearView3DSv_layout.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_metadata_draw.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_rvp_layout.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/grpxSrc/grpxSrcLink_tidl_od_layout.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/split/splitLink_tsk.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/split/splitLink_tsk_create_multi_mbx.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/split/splitLink_tsk_create_single_mbx.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/link_stats_monitor/link_stats_monitor.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/devices/lcd.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/devices/hdmi_tx.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/devices/eth_cam.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/display_multi_pipe/displayMultiPipe_tsk.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/display_multi_pipe/displayMultiPipe_drv.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/modules/devcontrol/devControl_handler.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/usecases/common/chains_common.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/usecases/common/chains_common_vision.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/usecases/TF_SVS/TF_SVS.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/usecases/TF_SVS/TF_SVS_priv.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/usecases/TF_SVS/debugMenu.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/usecases/tidl_OD/chains_tidlOD_priv.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/usecases/tidl_OD/chains_tidlOD.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/usecases/SD_STANDALONE/SD_STANDALONE.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/usecases/SD_STANDALONE/SD_STANDALONE_priv.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/usecases/SD_STANDALONE/debugSDMenu.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/usecases/TF_csi2_cal_display/TF_csi2_cal_display.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/usecases/TF_csi2_cal_display/TF_csi2_cal_display_priv.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/usecases/null_src_display/chains_nullSrcDisplay_priv.c
# Compiling tda2px-evm:ipu1_0:release:app_libs: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/rtos/usecases/null_src_display/chains_nullSrcDisplay.c
# Archiving tda2px-evm:ipu1_0:release:app_libs
/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: ndk_PATH does not exist! ()
/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: nsp_PATH does not exist! ()
/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: avbtp_PATH does not exist! ()
# Archiving tda2px-evm:ipu1_0:release:iss_libs
# Archiving tda2px-evm:ipu1_0:release:video_sensor_libs
# Invoking configuro...
making package.mak (because of package.bld) ...
# !!!  Current build platform is [tda2px-evm] !!!
# !!! Core is [arp32_1] !!!
generating interfaces for package vision_sdk_configuro (because package/package.xdc.inc is older than package.xdc) ...
configuring MAIN_APP_eve1.xearp32F from package/cfg/MAIN_APP_eve1_pearp32F.cfg ...
Loading Eve1.cfg for tda2px-evm
# !!! Including CPU #0 [ HOST ] in build !!!
# !!! Including CPU #1 [ IPU1-0 ] in build !!!
# !!! Including CPU #2 [ IPU1-1 ] in build !!!
# !!! Including CPU #3 [ IPU2 ] in build !!!
# !!! Including CPU #4 [ DSP1 ] in build !!!
# !!! Including CPU #5 [ DSP2 ] in build !!!
# !!! Including CPU #6 [ EVE1 ] in build !!!
# !!! Including CPU #7 [ EVE2 ] in build !!!
# !!! Using NotifyDriverMbx between [arp32_1] and [a15_0] !!!
# !!! Using NotifyDriverMbx between [arp32_1] and [ipu1_1] !!!
# !!! Using NotifyDriverMbx between [arp32_1] and [ipu1_0] !!!
# !!! Using NotifyDriverMbx between [arp32_1] and [ipu2] !!!
# !!! Using NotifyDriverMbx between [arp32_1] and [c66xdsp_1] !!!
# !!! Using NotifyDriverMbx between [arp32_1] and [c66xdsp_2] !!!
# !!! Using NotifyDriverMbx between [arp32_1] and [arp32_2] !!!
# !!! Host Proc ID is [1] !!!
generating custom ti.sysbios library makefile ...
generating custom ti.sdo.utils library makefile ...
generating custom ti.sdo.ipc library makefile ...
Starting build of library sources ...
making /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/ipc.aearp32F ...
gmake[1]: Entering directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/ipc'
clearp32F /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/utils/NameServer.c ...
arearp32F Ipc.obj ...
gmake[1]: Leaving directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/ipc'
making /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/utils.aearp32F ...
gmake[1]: Entering directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/utils'
clearp32F /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/utils/UTILS.c ...
arearp32F UTILS.obj ...
gmake[1]: Leaving directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/utils'
making /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/sysbios/sysbios.aearp32F ...
gmake[1]: Entering directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/sysbios'
clearp32F /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/BIOS.c ...
asmearp32F /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arp32/Hwi_switch_asm.sarp32 ...
asmearp32F /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arp32/Hwi_disp_always.sarp32 ...
asmearp32F /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arp32/TaskSupport_asm.sarp32 ...
arearp32F BIOS.obj arp32_Hwi_switch_asm.obj arp32_Hwi_disp_always.obj arp32_TaskSupport_asm.obj ...
gmake[1]: Leaving directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/arp32_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve1_pearp32F.src/sysbios'
Build of libraries done.
# Configuro done!
# Making tda2px-evm:arp32_1:release:vision_sdk_lib...
# Compiling tda2px-evm:arp32_1:release:vision_sdk: src/main_common_eve1.c
# Compiling tda2px-evm:arp32_1:release:vision_sdk: src/tlb_config_eve1.c
# Compiling tda2px-evm:arp32_1:release:vision_sdk: ../eve_common/tlb_config_eve_common.c
# Compiling tda2px-evm:arp32_1:release:vision_sdk: ../eve_common/main_eve_common.c
# Compiling tda2px-evm:arp32_1:release:vision_sdk: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/common/main_app/tda2px/eve1/src/main_eve1.c
# Compiling tda2px-evm:arp32_1:release:vision_sdk: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/common/app_init/app_init_eve.c
# Compiling generated MAIN_APP_eve1_pearp32F.oearp32F
# Linking into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/vision_sdk/bin/tda2px-evm/vision_sdk_arp32_1_release.xearp32F...
# /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/vision_sdk/bin/tda2px-evm/vision_sdk_arp32_1_release.xearp32F created.
# !!! Core is [arp32_2] !!!
configuring MAIN_APP_eve2.xearp32F from package/cfg/MAIN_APP_eve2_pearp32F.cfg ...
Loading Eve2.cfg for tda2px-evm
# !!! Using NotifyDriverMbx between [arp32_2] and [a15_0] !!!
# !!! Using NotifyDriverMbx between [arp32_2] and [ipu1_1] !!!
# !!! Using NotifyDriverMbx between [arp32_2] and [ipu1_0] !!!
# !!! Using NotifyDriverMbx between [arp32_2] and [ipu2] !!!
# !!! Using NotifyDriverMbx between [arp32_2] and [c66xdsp_1] !!!
# !!! Using NotifyDriverMbx between [arp32_2] and [c66xdsp_2] !!!
# !!! Using NotifyDriverMbx between [arp32_2] and [arp32_1] !!!
making /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/arp32_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve2_pearp32F.src/ipc.aearp32F ...
gmake[1]: Entering directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/arp32_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve2_pearp32F.src/ipc'
gmake[1]: Leaving directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/arp32_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve2_pearp32F.src/ipc'
making /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/arp32_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve2_pearp32F.src/utils.aearp32F ...
gmake[1]: Entering directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/arp32_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve2_pearp32F.src/utils'
gmake[1]: Leaving directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/arp32_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve2_pearp32F.src/utils'
making /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/arp32_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve2_pearp32F.src/sysbios/sysbios.aearp32F ...
gmake[1]: Entering directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/arp32_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve2_pearp32F.src/sysbios'
gmake[1]: Leaving directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/arp32_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_eve2_pearp32F.src/sysbios'
# Configuro done!
# Making tda2px-evm:arp32_2:release:vision_sdk_lib...
# Compiling tda2px-evm:arp32_2:release:vision_sdk: src/main_common_eve2.c
# Compiling tda2px-evm:arp32_2:release:vision_sdk: src/tlb_config_eve2.c
# Compiling tda2px-evm:arp32_2:release:vision_sdk: ../eve_common/tlb_config_eve_common.c
# Compiling tda2px-evm:arp32_2:release:vision_sdk: ../eve_common/main_eve_common.c
# Compiling tda2px-evm:arp32_2:release:vision_sdk: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/common/main_app/tda2px/eve2/src/main_eve2.c
# Compiling tda2px-evm:arp32_2:release:vision_sdk: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/common/app_init/app_init_eve.c
# Compiling generated MAIN_APP_eve2_pearp32F.oearp32F
# Linking into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/vision_sdk/bin/tda2px-evm/vision_sdk_arp32_2_release.xearp32F...
# /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/vision_sdk/bin/tda2px-evm/vision_sdk_arp32_2_release.xearp32F created.
# !!! Core is [c66xdsp_1] !!!
configuring MAIN_APP_c6xdsp1.xe66 from package/cfg/MAIN_APP_c6xdsp1_pe66.cfg ...
Loading Dsp1.cfg for tda2px-evm
# !!! Using NotifyDriverMbx between [c66xdsp_1] and [a15_0] !!!
# !!! Using NotifyDriverMbx between [c66xdsp_1] and [ipu1_1] !!!
# !!! Using NotifyDriverMbx between [c66xdsp_1] and [ipu1_0] !!!
# !!! Using NotifyDriverMbx between [c66xdsp_1] and [ipu2] !!!
# !!! Using NotifyDriverMbx between [c66xdsp_1] and [c66xdsp_2] !!!
# !!! Using NotifyDriverMbx between [c66xdsp_1] and [arp32_1] !!!
# !!! Using NotifyDriverMbx between [c66xdsp_1] and [arp32_2] !!!
making /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/ipc.ae66 ...
gmake[1]: Entering directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/ipc'
cle66 /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/utils/NameServer.c ...
are66 Ipc.obj ...
gmake[1]: Leaving directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/ipc'
making /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/utils.ae66 ...
gmake[1]: Entering directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/utils'
cle66 /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/utils/UTILS.c ...
are66 UTILS.obj ...
gmake[1]: Leaving directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/utils'
making /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/sysbios/sysbios.ae66 ...
gmake[1]: Entering directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/sysbios'
cle66 /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/BIOS.c ...
asme66 /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/c64p/Exception_asm.s64P ...
asme66 /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/c64p/Hwi_asm.s62 ...
asme66 /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/c64p/Hwi_asm_switch.s62 ...
asme66 /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/c64p/Hwi_disp_always.s64P ...
asme66 /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/timers/dmtimer/Timer_asm.s64P ...
asme66 /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/c62/TaskSupport_asm.s62 ...
asme66 /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/rts/ti/tls_get_tp.asm ...
are66 BIOS.obj c64p_Exception_asm.obj c64p_Hwi_asm.obj c64p_Hwi_asm_switch.obj c64p_Hwi_disp_always.obj dmtimer_Timer_asm.obj c62_TaskSupport_asm.obj ti_tls_get_tp.obj ...
gmake[1]: Leaving directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/c66xdsp_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp1_pe66.src/sysbios'
# Configuro done!
# Making tda2px-evm:c66xdsp_1:release:vision_sdk_lib...
# Compiling tda2px-evm:c66xdsp_1:release:vision_sdk: src/main_common_c6xdsp1.c
# Compiling tda2px-evm:c66xdsp_1:release:vision_sdk: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/common/main_app/tda2px/dsp1/src/main_c6xdsp1.c
# Compiling tda2px-evm:c66xdsp_1:release:vision_sdk: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/common/app_init/app_init_dsp.c
# Compiling generated MAIN_APP_c6xdsp1_pe66.oe66
# Linking into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/vision_sdk/bin/tda2px-evm/vision_sdk_c66xdsp_1_release.xe66...
# /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/vision_sdk/bin/tda2px-evm/vision_sdk_c66xdsp_1_release.xe66 created.
# !!! Core is [c66xdsp_2] !!!
configuring MAIN_APP_c6xdsp2.xe66 from package/cfg/MAIN_APP_c6xdsp2_pe66.cfg ...
Loading Dsp2.cfg for tda2px-evm
# !!! Using NotifyDriverMbx between [c66xdsp_2] and [a15_0] !!!
# !!! Using NotifyDriverMbx between [c66xdsp_2] and [ipu1_1] !!!
# !!! Using NotifyDriverMbx between [c66xdsp_2] and [ipu1_0] !!!
# !!! Using NotifyDriverMbx between [c66xdsp_2] and [ipu2] !!!
# !!! Using NotifyDriverMbx between [c66xdsp_2] and [c66xdsp_1] !!!
# !!! Using NotifyDriverMbx between [c66xdsp_2] and [arp32_1] !!!
# !!! Using NotifyDriverMbx between [c66xdsp_2] and [arp32_2] !!!
making /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/c66xdsp_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp2_pe66.src/ipc.ae66 ...
gmake[1]: Entering directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/c66xdsp_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp2_pe66.src/ipc'
are66 Ipc.obj ...
gmake[1]: Leaving directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/c66xdsp_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp2_pe66.src/ipc'
making /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/c66xdsp_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp2_pe66.src/utils.ae66 ...
gmake[1]: Entering directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/c66xdsp_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp2_pe66.src/utils'
are66 UTILS.obj ...
gmake[1]: Leaving directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/c66xdsp_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp2_pe66.src/utils'
making /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/c66xdsp_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp2_pe66.src/sysbios/sysbios.ae66 ...
gmake[1]: Entering directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/c66xdsp_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp2_pe66.src/sysbios'
gmake[1]: Leaving directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/c66xdsp_2/release/vision_sdk_configuro/package/cfg/MAIN_APP_c6xdsp2_pe66.src/sysbios'
# Configuro done!
# Making tda2px-evm:c66xdsp_2:release:vision_sdk_lib...
# Compiling tda2px-evm:c66xdsp_2:release:vision_sdk: src/main_common_c6xdsp2.c
# Compiling tda2px-evm:c66xdsp_2:release:vision_sdk: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/common/main_app/tda2px/dsp2/src/main_c6xdsp2.c
# Compiling tda2px-evm:c66xdsp_2:release:vision_sdk: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/common/app_init/app_init_dsp.c
# Compiling generated MAIN_APP_c6xdsp2_pe66.oe66
# Linking into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/vision_sdk/bin/tda2px-evm/vision_sdk_c66xdsp_2_release.xe66...
# /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/vision_sdk/bin/tda2px-evm/vision_sdk_c66xdsp_2_release.xe66 created.
# !!! Core is [ipu1_1] !!!
configuring MAIN_APP_ipu1_1.xem4 from package/cfg/MAIN_APP_ipu1_1_pem4.cfg ...
Loading Ipu1_1.cfg for tda2px-evm
# !!! Using NotifyDriverMbx between [ipu1_1] and [a15_0] !!!
# !!! Using NotifyDriverMbx between [ipu1_1] and [ipu1_0] !!!
# !!! Using NotifyDriverMbx between [ipu1_1] and [ipu2] !!!
# !!! Using NotifyDriverMbx between [ipu1_1] and [c66xdsp_1] !!!
# !!! Using NotifyDriverMbx between [ipu1_1] and [c66xdsp_2] !!!
# !!! Using NotifyDriverMbx between [ipu1_1] and [arp32_1] !!!
# !!! Using NotifyDriverMbx between [ipu1_1] and [arp32_2] !!!
making /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_ipu1_1_pem4.src/ipc.aem4 ...
gmake[1]: Entering directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_ipu1_1_pem4.src/ipc'
clem4 /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/utils/NameServer.c ...
arem4 Ipc.obj ...
gmake[1]: Leaving directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_ipu1_1_pem4.src/ipc'
making /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_ipu1_1_pem4.src/utils.aem4 ...
gmake[1]: Entering directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_ipu1_1_pem4.src/utils'
clem4 /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/utils/UTILS.c ...
arem4 UTILS.obj ...
gmake[1]: Leaving directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_ipu1_1_pem4.src/utils'
making /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_ipu1_1_pem4.src/sysbios/sysbios.aem4 ...
gmake[1]: Entering directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_ipu1_1_pem4.src/sysbios'
clem4 /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/BIOS.c ...
asmem4 /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/timers/dmtimer/Timer_asm.sv7M ...
asmem4 /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arm/m3/Hwi_asm.sv7M ...
asmem4 /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arm/m3/Hwi_asm_switch.sv7M ...
asmem4 /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arm/m3/IntrinsicsSupport_asm.sv7M ...
asmem4 /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arm/m3/TaskSupport_asm.sv7M ...
asmem4 /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arm/ducati/Core_asm.sv7M ...
arem4 BIOS.obj dmtimer_Timer_asm.obj m3_Hwi_asm.obj m3_Hwi_asm_switch.obj m3_IntrinsicsSupport_asm.obj m3_TaskSupport_asm.obj ducati_Core_asm.obj ...
gmake[1]: Leaving directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/ipu1_1/release/vision_sdk_configuro/package/cfg/MAIN_APP_ipu1_1_pem4.src/sysbios'
# Configuro done!
# Making tda2px-evm:ipu1_1:release:vision_sdk_lib...
# Compiling tda2px-evm:ipu1_1:release:vision_sdk: src/main_common_ipu1_1.c
# Compiling tda2px-evm:ipu1_1:release:vision_sdk: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/common/main_app/tda2px/ipu1_1/src/main_ipu1_1.c
# Compiling tda2px-evm:ipu1_1:release:vision_sdk: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/common/app_init/app_init_ipu1_1.c
# Compiling generated MAIN_APP_ipu1_1_pem4.oem4
# Linking into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/vision_sdk/bin/tda2px-evm/vision_sdk_ipu1_1_release.xem4...
# /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/vision_sdk/bin/tda2px-evm/vision_sdk_ipu1_1_release.xem4 created.
# !!! Core is [a15_0] !!!
configuring MAIN_APP_a15_0.xa15fg from package/cfg/MAIN_APP_a15_0_pa15fg.cfg ...
Loading a15_0.cfg for tda2px-evm
# !!! Using NotifyDriverMbx between [a15_0] and [ipu1_1] !!!
# !!! Using NotifyDriverMbx between [a15_0] and [ipu1_0] !!!
# !!! Using NotifyDriverMbx between [a15_0] and [ipu2] !!!
# !!! Using NotifyDriverMbx between [a15_0] and [c66xdsp_1] !!!
# !!! Using NotifyDriverMbx between [a15_0] and [c66xdsp_2] !!!
# !!! Using NotifyDriverMbx between [a15_0] and [arp32_1] !!!
# !!! Using NotifyDriverMbx between [a15_0] and [arp32_2] !!!
making /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/a15_0/release/vision_sdk_configuro/package/cfg/MAIN_APP_a15_0_pa15fg.src/sysbios/sysbios.aa15fg ...
gmake[1]: Entering directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/a15_0/release/vision_sdk_configuro/package/cfg/MAIN_APP_a15_0_pa15fg.src/sysbios'
asma15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arm/IntrinsicsSupport_asm_gnu.asm ...
asma15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arm/TaskSupport_asm_gnu.asm ...
asma15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arm/a15/Cache_asm_gnu.asm ...
asma15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arm/a15/Mmu_asm_gnu.asm ...
asma15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arm/a15/TimestampProvider_asm_gnu.asm ...
asma15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arm/exc/Exception_asm_gnu.asm ...
asma15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/timers/dmtimer/Timer_asm_gnu.sv7A ...
asma15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arm/gic/Hwi_asm_gnu.asm ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/BIOS.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arm/IntrinsicsSupport.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arm/TaskSupport.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/knl/Clock.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/knl/Idle.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/knl/Intrinsics.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/knl/Event.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/knl/Queue.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/knl/Semaphore.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/knl/Swi.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/knl/Swi_andn.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/knl/Task.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/heaps/HeapBuf.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/heaps/HeapMem.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/utils/Load.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/utils/Load_CPU.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/hal/Cache.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/hal/Core.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/hal/Hwi.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/hal/Hwi_stack.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/hal/Hwi_startup.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/hal/TimerNull.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/syncs/SyncSem.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/gates/GateHwi.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/gates/GateAll.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/gates/GateSwi.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/gates/GateTask.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/gates/GateMutexPri.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/gates/GateMutex.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arm/a15/Core.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arm/a15/Cache.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arm/a15/Mmu.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arm/a15/TimestampProvider.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/shared/vayu/IntXbar.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/shared/vayu/TimerSupport.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arm/exc/Exception.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/timers/dmtimer/Timer.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/timers/dmtimer/TimestampProvider.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/rts/gnu/ReentSupport.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/family/arm/gic/Hwi.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/bios_6_46_04_53/packages/ti/sysbios/xdcruntime/GateThreadSupport.c ...
ara15fg arm_IntrinsicsSupport_asm_gnu.o arm_TaskSupport_asm_gnu.o a15_Cache_asm_gnu.o a15_Mmu_asm_gnu.o a15_TimestampProvider_asm_gnu.o exc_Exception_asm_gnu.o dmtimer_Timer_asm_gnu.o gic_Hwi_asm_gnu.o _BIOS.o arm_IntrinsicsSupport.o arm_TaskSupport.o knl_Clock.o knl_Idle.o knl_Intrinsics.o knl_Event.o knl_Queue.o knl_Semaphore.o knl_Swi.o knl_Swi_andn.o knl_Task.o heaps_HeapBuf.o heaps_HeapMem.o utils_Load.o utils_Load_CPU.o hal_Cache.o hal_Core.o hal_Hwi.o hal_Hwi_stack.o hal_Hwi_startup.o hal_TimerNull.o syncs_SyncSem.o gates_GateHwi.o gates_GateAll.o gates_GateSwi.o gates_GateTask.o gates_GateMutexPri.o gates_GateMutex.o a15_Core.o a15_Cache.o a15_Mmu.o a15_TimestampProvider.o vayu_IntXbar.o vayu_TimerSupport.o exc_Exception.o dmtimer_Timer.o dmtimer_TimestampProvider.o gnu_ReentSupport.o gic_Hwi.o xdcruntime_GateThreadSupport.o ...
gmake[1]: Leaving directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/a15_0/release/vision_sdk_configuro/package/cfg/MAIN_APP_a15_0_pa15fg.src/sysbios'
making /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/a15_0/release/vision_sdk_configuro/package/cfg/MAIN_APP_a15_0_pa15fg.src/ipc.aa15fg ...
gmake[1]: Entering directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/a15_0/release/vision_sdk_configuro/package/cfg/MAIN_APP_a15_0_pa15fg.src/ipc'
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/utils/NameServer.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/utils/NameServerRemoteNull.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/utils/MultiProc.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/utils/List.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/ipc/GateMP.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/ipc/MessageQ.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/ipc/SharedRegion.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/ipc/ListMP.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/ipc/Ipc.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/ipc/Notify.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/ipc/family/vayu/NotifySetup.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/ipc/family/vayu/NotifyDriverMbx.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/ipc/transports/TransportShm.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/ipc/transports/TransportShmSetup.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/ipc/nsremote/NameServerRemoteNotify.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/ipc/gates/GateHWSpinlock.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/ipc/gates/GatePeterson.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/ipc/gates/GateMPSupportNull.c ...
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/ipc/heaps/HeapMemMP.c ...
ara15fg ti_sdo_utils_NameServer.o ti_sdo_utils_NameServerRemoteNull.o ti_sdo_utils_MultiProc.o ti_sdo_utils_List.o ti_sdo_ipc_GateMP.o ti_sdo_ipc_MessageQ.o ti_sdo_ipc_SharedRegion.o ti_sdo_ipc_ListMP.o ti_sdo_ipc_Ipc.o ti_sdo_ipc_Notify.o ti_sdo_ipc_family_vayu_NotifySetup.o ti_sdo_ipc_family_vayu_NotifyDriverMbx.o ti_sdo_ipc_transports_TransportShm.o ti_sdo_ipc_transports_TransportShmSetup.o ti_sdo_ipc_nsremote_NameServerRemoteNotify.o ti_sdo_ipc_gates_GateHWSpinlock.o ti_sdo_ipc_gates_GatePeterson.o ti_sdo_ipc_gates_GateMPSupportNull.o ti_sdo_ipc_heaps_HeapMemMP.o ...
gmake[1]: Leaving directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/a15_0/release/vision_sdk_configuro/package/cfg/MAIN_APP_a15_0_pa15fg.src/ipc'
making /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/a15_0/release/vision_sdk_configuro/package/cfg/MAIN_APP_a15_0_pa15fg.src/utils.aa15fg ...
gmake[1]: Entering directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/a15_0/release/vision_sdk_configuro/package/cfg/MAIN_APP_a15_0_pa15fg.src/utils'
cla15fg /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/ti_components/os_tools/ipc_3_45_00_00/packages/ti/sdo/utils/UTILS.c ...
ara15fg utils_UTILS.o utils_NameServer.o utils_NameServerRemoteNull.o utils_MultiProc.o utils_List.o ...
gmake[1]: Leaving directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/a15_0/release/vision_sdk_configuro/package/cfg/MAIN_APP_a15_0_pa15fg.src/utils'
# Configuro done!
# Making tda2px-evm:a15_0:release:vision_sdk_lib...
# Compiling tda2px-evm:a15_0:release:vision_sdk: src/main_common_a15_0.c
# Compiling tda2px-evm:a15_0:release:vision_sdk: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/common/main_app/tda2px/a15_0/src/main_a15_0.c
# Compiling tda2px-evm:a15_0:release:vision_sdk: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/common/app_init/app_init_a15.c
# Compiling generated /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/a15_0/release/vision_sdk_configuro/package/cfg/MAIN_APP_a15_0_pa15fg.c to /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/a15_0/release/MAIN_APP_a15_0_pa15fg.oa15fg ...
# Linking into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/vision_sdk/bin/tda2px-evm/vision_sdk_a15_0_release.xa15fg...
# /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/vision_sdk/bin/tda2px-evm/vision_sdk_a15_0_release.xa15fg created.
# !!! Core is [ipu1_0] !!!
configuring MAIN_APP_ipu1_0.xem4 from package/cfg/MAIN_APP_ipu1_0_pem4.cfg ...
Loading Ipu1_0.cfg for tda2px-evm
# !!! Using NotifyDriverMbx between [ipu1_0] and [a15_0] !!!
# !!! Using NotifyDriverMbx between [ipu1_0] and [ipu1_1] !!!
# !!! Using NotifyDriverMbx between [ipu1_0] and [ipu2] !!!
# !!! Using NotifyDriverMbx between [ipu1_0] and [c66xdsp_1] !!!
# !!! Using NotifyDriverMbx between [ipu1_0] and [c66xdsp_2] !!!
# !!! Using NotifyDriverMbx between [ipu1_0] and [arp32_1] !!!
# !!! Using NotifyDriverMbx between [ipu1_0] and [arp32_2] !!!
making /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/ipu1_0/release/vision_sdk_configuro/package/cfg/MAIN_APP_ipu1_0_pem4.src/ipc.aem4 ...
gmake[1]: Entering directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/ipu1_0/release/vision_sdk_configuro/package/cfg/MAIN_APP_ipu1_0_pem4.src/ipc'
arem4 Ipc.obj ...
gmake[1]: Leaving directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/ipu1_0/release/vision_sdk_configuro/package/cfg/MAIN_APP_ipu1_0_pem4.src/ipc'
making /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/ipu1_0/release/vision_sdk_configuro/package/cfg/MAIN_APP_ipu1_0_pem4.src/utils.aem4 ...
gmake[1]: Entering directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/ipu1_0/release/vision_sdk_configuro/package/cfg/MAIN_APP_ipu1_0_pem4.src/utils'
arem4 UTILS.obj ...
gmake[1]: Leaving directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/ipu1_0/release/vision_sdk_configuro/package/cfg/MAIN_APP_ipu1_0_pem4.src/utils'
making /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/ipu1_0/release/vision_sdk_configuro/package/cfg/MAIN_APP_ipu1_0_pem4.src/sysbios/sysbios.aem4 ...
gmake[1]: Entering directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/ipu1_0/release/vision_sdk_configuro/package/cfg/MAIN_APP_ipu1_0_pem4.src/sysbios'
gmake[1]: Leaving directory `/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/obj/vision_sdk/tda2px-evm/ipu1_0/release/vision_sdk_configuro/package/cfg/MAIN_APP_ipu1_0_pem4.src/sysbios'
# Configuro done!
# Making tda2px-evm:ipu1_0:release:vision_sdk_lib...
# Compiling tda2px-evm:ipu1_0:release:vision_sdk: src/main_common_ipu1_0.c
# Compiling tda2px-evm:ipu1_0:release:vision_sdk: src/ipu_primary.c
# Compiling tda2px-evm:ipu1_0:release:vision_sdk: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/common/main_app/tda2px/ipu1_0/src/main_ipu1_0.c
# Compiling tda2px-evm:ipu1_0:release:vision_sdk: /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/apps/src/common/app_init/app_init_ipu_primary.c
# Compiling generated MAIN_APP_ipu1_0_pem4.oem4
# Linking into /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/vision_sdk/bin/tda2px-evm/vision_sdk_ipu1_0_release.xem4...
 undefined first referenced
  symbol       in file
 tidl_OD   /home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/lib/tda2px-evm/ipu1_0/release/app_libs.aem4<chains_main_bios_vision.oem4>
error: unresolved symbols remain
error: errors encountered during linking;
   "/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binar
   ease.xem4" not built
/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/build/rtos/makerules/rules_m4.mk:303: recipe for target '/home/bhagyashree/BL_TF_SSD_tidl/Source_Code/ssd_framework/vision_sdk/binaries/apps/tda2px_evm_bios_all/vision_sdk/bin/tda2px-evm/vision_sdk_ipu1_0_release.xem4' failed
