rt Number: AM6548
Hardware: EVM
Software: SDK6.2
1. I connected the EVM board to the router and set a static IP 192.168.1.77 for it, meanwhile, I have a computer connected to the router and it's IP is 192.168.1.10
2. I execute the command "ping 192.168.1.10" on the evm board, then unplug the network cable from the EVM board, and then plug it in.
3. I continued to configure a static IP 192.168.1.77 for the EVM board and then executed the command "ping 192.168.1.10" again.
4. The kernel will happen a panic error and the log is
U-Boot SPL 2019.01-ga141f7abfd (Jan 05 2020 - 04:04:11 +0000) SYSFW ABI: 2.7 (firmware rev 0x0013 '19.9.0-v2019.09 (Terrific Llama') Trying to boot from MMC2 Starting ATF on ARM64 core... NOTICE: BL31: v2.2(release):ti2019.05-rc1 NOTICE: BL31: Built : 03:39:18, Jan 5 2020 I/TC: I/TC: OP-TEE version: ti2019.05-rc1-dev (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #1 Sun Jan 5 03:38:30 UTC 2020 aarch64 I/TC: Initialized U-Boot SPL 2019.01-ga141f7abfd (Jan 05 2020 - 04:02:42 +0000) Detected: AM6-IDKAPPEVM rev E3 Trying to boot from MMC2 U-Boot 2019.01-ga141f7abfd (Jan 05 2020 - 04:02:42 +0000) SoC: AM654 PG 1.0 Model: Texas Instruments AM654 Base Board Board: AM6-COMPROCEVM rev E3 DRAM: 4 GiB MMC: sdhci@4f80000: 0, sdhci@04FA0000: 1 Loading Environment from MMC... OK In: serial Out: serial Err: serial Detected: AM6-IDKAPPEVM rev E3 Net: eth3: pruss1_eth, eth2: pruss0_eth Warning: cpsw_nuss@046000000 using MAC address from ROM , eth0: cpsw_nuss@046000000, eth1: pruss2_eth Hit any key to stop autoboot: 0 switch to partitions #0, OK mmc1 is current device SD/MMC found on device 1 ** Unable to read file boot.scr ** 1490 bytes read in 2 ms (727.5 KiB/s) Loaded env from uEnv.txt Importing environment from mmc1 ... Running uenvcmd ... 1 bytes read in 3 ms (0 Bytes/s) Already setup. 13471752 bytes read in 1113 ms (11.5 MiB/s) 73168 bytes read in 9 ms (7.8 MiB/s) 11325 bytes read in 2 ms (5.4 MiB/s) ## Flattened Device Tree blob at 82000000 Booting using the fdt blob at 0x82000000 Loading Device Tree to 00000000fddb3000, end 00000000fdec7fff ... OK Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034] [ 0.000000] Machine model: Texas Instruments AM654 Base Board [ 0.000000] earlycon: ns16550a0 at MMIO32 0x0000000002800000 (options '') [ 0.000000] bootconsole [ns16550a0] enabled [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a0000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a0100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a0100000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1000000, size 1 MiB [ 0.000000] OF: reserved mem: initialized node r5f-dma-memory@a1000000, compatible id shared-dma-pool [ 0.000000] Reserved memory: created DMA memory pool at 0x00000000a1100000, size 15 MiB [ 0.000000] OF: reserved mem: initialized node r5f-memory@a1100000, compatible id shared-dma-pool [ 0.000000] cma: Reserved 512 MiB at 0x00000000c0000000 [ 0.000000] psci: probing for conduit method from DT. [ 0.000000] psci: PSCIv1.1 detected in firmware. [ 0.000000] psci: Using standard PSCI v0.2 function IDs [ 0.000000] psci: Trusted OS migration not required [ 0.000000] psci: SMC Calling Convention v1.1 [ 0.000000] random: get_random_bytes called from start_kernel+0x94/0x3e4 with crng_init=0 [ 0.000000] percpu: Embedded 2 pages/cpu s48536 r8192 d74344 u131072 [ 0.000000] Detected VIPT I-cache on CPU0 [ 0.000000] CPU features: enabling workaround for ARM erratum 845719 [ 0.000000] Speculative Store Bypass Disable mitigation not required [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 64544 [ 0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 mtdparts=47040000.spi.0:512k(ospi.tiboot3),2m(ospi.tispl),4m(ospi.u-boot),128k(ospi.env),128k(ospi.env.backup),1m(ospi.sysfw),-@8m(ospi.rootfs) root=PARTUUID=141da37b-02 rw rootfstype=ext4 rootwait [ 0.000000] Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes) [ 0.000000] Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes) [ 0.000000] software IO TLB: mapped [mem 0xf9db0000-0xfddb0000] (64MB) [ 0.000000] Memory: 3518720K/4134912K available (8574K kernel code, 804K rwdata, 3136K rodata, 576K init, 640K bss, 91904K reserved, 524288K cma-reserved) [ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1 [ 0.000000] rcu: Preemptible hierarchical RCU implementation. [ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4. [ 0.000000] Tasks RCU enabled. [ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4 [ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0 [ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode [ 0.000000] GICv3: Distributor has no Range Selector support [ 0.000000] GICv3: no VLPI support, no direct LPI support [ 0.000000] ITS [mem 0x01820000-0x0182ffff] [ 0.000000] GIC: enabling workaround for ITS: Socionext Synquacer pre-ITS [ 0.000000] ITS@0x0000000001820000: allocated 1048576 Devices @8c0800000 (flat, esz 8, psz 64K, shr 0) [ 0.000000] ITS: using cache flushing for cmd queue [ 0.000000] GIC: using LPI property table @0x00000008c00c0000 [ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000001880000 [ 0.000000] CPU0: using LPI pending table @0x00000008c00d0000 [ 0.000000] GIC: using cache flushing for LPI property table [ 0.000000] arch_timer: cp15 timer(s) running at 200.00MHz (phys). [ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns [ 0.000005] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns [ 0.008703] Console: colour dummy device 80x25 [ 0.013299] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=800000) [ 0.023989] pid_max: default: 32768 minimum: 301 [ 0.028817] Security Framework initialized [ 0.033080] Mount-cache hash table entries: 8192 (order: 0, 65536 bytes) [ 0.039963] Mountpoint-cache hash table entries: 8192 (order: 0, 65536 bytes) [ 0.071401] ASID allocator initialised with 32768 entries [ 0.084968] rcu: Hierarchical SRCU implementation. [ 0.098066] Platform MSI: gic-its@1820000 domain created [ 0.103826] PCI/MSI: /interconnect@100000/interrupt-controller@1800000/gic-its@1820000 domain created [ 0.121306] smp: Bringing up secondary CPUs ... [ 0.158423] Detected VIPT I-cache on CPU1 [ 0.158464] GICv3: CPU1: found redistributor 1 region 0:0x00000000018a0000 [ 0.158520] CPU1: using LPI pending table @0x00000008c0330000 [ 0.158566] CPU1: Booted secondary processor 0x0000000001 [0x410fd034] [ 0.220139] Detected VIPT I-cache on CPU2 [ 0.220182] GICv3: CPU2: found redistributor 100 region 0:0x00000000018c0000 [ 0.220243] CPU2: using LPI pending table @0x00000008c03c0000 [ 0.220292] CPU2: Booted secondary processor 0x0000000100 [0x410fd034] [ 0.252536] Detected VIPT I-cache on CPU3 [ 0.252563] GICv3: CPU3: found redistributor 101 region 0:0x00000000018e0000 [ 0.252619] CPU3: using LPI pending table @0x00000008c0450000 [ 0.252653] CPU3: Booted secondary processor 0x0000000101 [0x410fd034] [ 0.252799] smp: Brought up 1 node, 4 CPUs [ 0.328444] SMP: Total of 4 processors activated. [ 0.333266] CPU features: detected: GIC system register CPU interface [ 0.339877] CPU features: detected: 32-bit EL0 Support [ 0.345596] CPU: All CPU(s) started at EL2 [ 0.349828] alternatives: patching kernel code [ 0.355835] devtmpfs: initialized [ 0.371266] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns [ 0.381267] futex hash table entries: 1024 (order: 0, 65536 bytes) [ 0.388966] pinctrl core: initialized pinctrl subsystem [ 0.395263] NET: Registered protocol family 16 [ 0.401063] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____)) [ 0.408650] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers. [ 0.422123] DMA: preallocated 256 KiB pool for atomic allocations [ 0.450141] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages [ 0.457022] HugeTLB registered 512 MiB page size, pre-allocated 0 pages [ 0.465796] cryptd: max_cpu_qlen set to 1000 [ 0.472209] SCSI subsystem initialized [ 0.476712] media: Linux media interface: v0.10 [ 0.481384] videodev: Linux video capture interface: v2.00 [ 0.487041] pps_core: LinuxPPS API ver. 1 registered [ 0.492125] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it> [ 0.501488] PTP clock support registered [ 0.505526] EDAC MC: Ver: 3.0.0 [ 0.510129] Advanced Linux Sound Architecture Driver Initialized. [ 0.517340] clocksource: Switched to clocksource arch_sys_counter [ 0.523806] VFS: Disk quotas dquot_6.6.0 [ 0.527916] VFS: Dquot-cache hash table entries: 8192 (order 0, 65536 bytes) [ 0.542202] NET: Registered protocol family 2 [ 0.547370] tcp_listen_portaddr_hash hash table entries: 4096 (order: 0, 65536 bytes) [ 0.555526] TCP established hash table entries: 32768 (order: 2, 262144 bytes) [ 0.563220] TCP bind hash table entries: 32768 (order: 3, 524288 bytes) [ 0.570571] TCP: Hash tables configured (established 32768 bind 32768) [ 0.577437] UDP hash table entries: 2048 (order: 0, 65536 bytes) [ 0.583701] UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes) [ 0.590589] NET: Registered protocol family 1 [ 0.595663] RPC: Registered named UNIX socket transport module. [ 0.601745] RPC: Registered udp transport module. [ 0.606564] RPC: Registered tcp transport module. [ 0.611381] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.619153] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available [ 0.632497] Initialise system trusted keyrings [ 0.637271] workingset: timestamp_bits=46 max_order=16 bucket_order=0 [ 0.649185] squashfs: version 4.0 (2009/01/31) Phillip Lougher [ 0.655877] NFS: Registering the id_resolver key type [ 0.661077] Key type id_resolver registered [ 0.665367] Key type id_legacy registered [ 0.669485] nfs4filelayout_init: NFSv4 File Layout Driver Registering... [ 0.676576] 9p: Installing v9fs 9p2000 file system support [ 0.687196] Key type asymmetric registered [ 0.691414] Asymmetric key parser 'x509' registered [ 0.696472] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245) [ 0.704148] io scheduler noop registered [ 0.708176] io scheduler deadline registered [ 0.712720] io scheduler cfq registered (default) [ 0.717544] io scheduler mq-deadline registered [ 0.722197] io scheduler kyber registered [ 0.728380] pinctrl-single 4301c000.pinmux: 70 pins, size 280 [ 0.734967] pinctrl-single 11c000.pinmux: 185 pins, size 740 [ 0.740916] pinctrl-single 11c2e8.pinmux: 9 pins, size 36 [ 0.747646] pinctrl-single a40000.timesync_router: 512 pins, size 2048 [ 0.764556] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.787479] brd: module loaded [ 0.798030] loop: module loaded [ 0.804414] libphy: Fixed MDIO Bus: probed [ 0.809230] tun: Universal TUN/TAP device driver, 1.6 [ 0.815189] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k [ 0.823221] igbvf: Copyright (c) 2009 - 2012 Intel Corporation. [ 0.829353] sky2: driver version 1.30 [ 0.834618] VFIO - User Level meta-driver version: 0.3 [ 0.840828] i2c /dev entries driver [ 0.845781] sdhci: Secure Digital Host Controller Interface driver [ 0.852112] sdhci: Copyright(c) Pierre Ossman [ 0.857116] sdhci-pltfm: SDHCI platform and OF driver helper [ 0.864203] ledtrig-cpu: registered to indicate activity on CPUs [ 0.870459] ti-sci interconnect@100000:interconnect@28380000:interconnect@42040000:dmsc: invalid resource [ 0.882004] optee: probing for conduit method from DT. [ 0.887301] optee: revision 3.7 (5208e5c1) [ 0.887593] optee: initialized driver [ 0.897006] NET: Registered protocol family 17 [ 0.901721] 9pnet: Installing 9P2000 support [ 0.906157] Key type dns_resolver registered [ 0.911190] registered taskstats version 1 [ 0.915396] Loading compiled-in X.509 certificates [ 0.933005] ti-sci interconnect@100000:interconnect@28380000:interconnect@42040000:dmsc: invalid resource [ 0.943005] ti-sci interconnect@100000:interconnect@28380000:interconnect@42040000:dmsc: ABI: 2.7 (firmware rev 0x0013 '19.9.0-v2019.09 (Terrific Llama') [ 0.977058] random: fast init done [ 1.403657] omap_i2c 42120000.i2c: bus 0 rev0.12 at 400 kHz [ 1.410041] omap_i2c 40b00000.i2c: bus 1 rev0.12 at 100 kHz [ 1.416532] pca953x 2-0041: 2-0041 supply vcc not found, using dummy regulator [ 1.423996] pca953x 2-0041: Linked as a consumer to regulator.0 [ 1.454069] pca953x 2-0021: 2-0021 supply vcc not found, using dummy regulator [ 1.461601] pca953x 2-0021: Linked as a consumer to regulator.0 [ 1.468343] omap_i2c 2000000.i2c: bus 2 rev0.12 at 400 kHz [ 1.474631] omap_i2c 2010000.i2c: bus 3 rev0.12 at 400 kHz [ 1.480867] omap_i2c 2020000.i2c: bus 4 rev0.12 at 400 kHz [ 1.487141] omap_i2c 2030000.i2c: bus 5 rev0.12 at 100 kHz [ 1.497219] k3-ringacc 2b800000.ringacc: Ring Accelerator probed rings:286, gp-rings[96,160] sci-dev-id:195 [ 1.507234] k3-ringacc 2b800000.ringacc: dma-ring-reset-quirk: enabled [ 1.513922] k3-ringacc 2b800000.ringacc: RA Proxy rev. 66344100, num_proxies:64 [ 1.521830] k3-ringacc 3c000000.ringacc: Ring Accelerator probed rings:818, gp-rings[304,464] sci-dev-id:187 [ 1.531911] k3-ringacc 3c000000.ringacc: dma-ring-reset-quirk: enabled [ 1.538599] k3-ringacc 3c000000.ringacc: RA Proxy rev. 66344100, num_proxies:64 [ 1.546409] omap8250 40a00000.serial: PM domain pd:149 will not be powered off [ 1.554138] 40a00000.serial: ttyS1 at MMIO 0x40a00000 (irq = 8, base_baud = 6000000) is a 8250 [ 1.563791] 2800000.serial: ttyS2 at MMIO 0x2800000 (irq = 22, base_baud = 3000000) is a 8250 [ 1.572571] console [ttyS2] enabled [ 1.572571] console [ttyS2] enabled [ 1.579620] bootconsole [ns16550a0] disabled [ 1.579620] bootconsole [ns16550a0] disabled [ 1.588964] 2810000.serial: ttyS3 at MMIO 0x2810000 (irq = 23, base_baud = 3000000) is a 8250 [ 1.598176] 2820000.serial: ttyS4 at MMIO 0x2820000 (irq = 24, base_baud = 3000000) is a 8250 [ 1.610030] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes) [ 1.616233] 7 cmdlinepart partitions found on MTD device 47040000.spi.0 [ 1.622854] Creating 7 MTD partitions on "47040000.spi.0": [ 1.628348] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 1.634709] 0x000000080000-0x000000280000 : "ospi.tispl" [ 1.640682] 0x000000280000-0x000000680000 : "ospi.u-boot" [ 1.646693] 0x000000680000-0x0000006a0000 : "ospi.env" [ 1.652489] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup" [ 1.658857] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw" [ 1.664802] 0x000000800000-0x000004000000 : "ospi.rootfs" [ 1.781596] cadence-qspi 47040000.spi: Cadence QSPI NOR probe failed -517 [ 1.796136] am65-cpsw-nuss 46000000.ethernet: rx-flow-id-base is not set -22 [ 1.803260] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA07100, cpsw version 0x6BA80100 Ports: 2 [ 1.814786] UDMA has not been proped [ 1.818441] am65-cpsw-nuss 46000000.ethernet: Failed to request tx dma channel -517 [ 1.828436] am65-cpts 310d0000.cpts: CPTS ver 0x4e8a2109, freq:200000000, add_val:4 pps:0 [ 1.837149] thermal thermal_zone1: failed to read out thermal zone (-22) [ 1.843880] thermal thermal_zone2: failed to read out thermal zone (-22) [ 1.851419] keystone-wdt 40610000.rti: heartbeat 60 sec [ 1.857649] mmc0: Unknown controller version (4). You may experience problems. [ 1.896020] mmc0: SDHCI controller on 4f80000.sdhci [4f80000.sdhci] using ADMA 64-bit [ 1.904654] mmc1: Unknown controller version (4). You may experience problems. [ 1.942952] mmc1: SDHCI controller on 4fa0000.sdhci [4fa0000.sdhci] using ADMA 64-bit [ 1.959055] mmc0: new HS200 MMC card at address 0001 [ 1.965179] mmcblk0: mmc0:0001 R1J56L 14.7 GiB [ 1.970551] mmcblk0boot0: mmc0:0001 R1J56L partition 1 8.00 MiB [ 1.980492] pca953x 0-0039: 0-0039 supply vcc not found, using dummy regulator [ 1.987850] mmcblk0boot1: mmc0:0001 R1J56L partition 2 8.00 MiB [ 1.993920] pca953x 0-0039: Linked as a consumer to regulator.0 [ 1.999890] mmcblk0rpmb: mmc0:0001 R1J56L partition 3 4.00 MiB, chardev (243:0) [ 2.008949] mmcblk0: p1 [ 2.022982] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc5900 [ 2.029968] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc5900 [ 2.037516] ti-udma 285c0000.udmap: Channels: 96 (tchan: 48, echan: 0, rchan: 48, rflow: 96) [ 2.052201] ti-udma 31150000.udmap: Channels: 267 (tchan: 120, echan: 32, rchan: 150, rflow: 300) [ 2.077916] cadence-qspi 47040000.spi: mt35xu512aba (65536 Kbytes) [ 2.084115] 7 cmdlinepart partitions found on MTD device 47040000.spi.0 [ 2.090727] Creating 7 MTD partitions on "47040000.spi.0": [ 2.096219] 0x000000000000-0x000000080000 : "ospi.tiboot3" [ 2.102593] 0x000000080000-0x000000280000 : "ospi.tispl" [ 2.108571] 0x000000280000-0x000000680000 : "ospi.u-boot" [ 2.114577] 0x000000680000-0x0000006a0000 : "ospi.env" [ 2.120449] 0x0000006a0000-0x0000006c0000 : "ospi.env.backup" [ 2.126828] 0x0000006c0000-0x0000007c0000 : "ospi.sysfw" [ 2.132760] 0x000000800000-0x000004000000 : "ospi.rootfs" [ 2.146140] m25p80 spi7.0: unrecognized JEDEC id bytes: 20, ff, 1c [ 2.152363] m25p80: probe of spi7.0 failed with error -2 [ 2.158291] am65-cpsw-nuss 46000000.ethernet: rx-flow-id-base is not set -22 [ 2.165395] am65-cpsw-nuss 46000000.ethernet: initializing am65 cpsw nuss version 0x6BA07100, cpsw version 0x6BA80100 Ports: 2 [ 2.186355] am65-cpsw-nuss 46000000.ethernet: set new flow-id-base 48 [ 2.200292] pps pps0: new PPS source ptp1 [ 2.204529] am65-cpsw-nuss 46000000.ethernet: CPTS ver 0x4e8a2109, freq:200000000, add_val:4 pps:1 [ 2.213498] am65-cpsw-nuss 46000000.ethernet: initialized cpsw ale version 0.4 [ 2.220718] am65-cpsw-nuss 46000000.ethernet: ALE Table size 64 [ 2.265362] am65-cpsw-nuss 46000000.ethernet: davinci mdio revision 9.7, bus freq 1000000 [ 2.273541] libphy: 46000000.ethernet: probed [ 2.281626] input: gpio-keys as /devices/platform/gpio-keys/input/input0 [ 2.288602] hctosys: unable to open rtc device (rtc0) [ 2.392216] ALSA device list: [ 2.395208] No soundcards found. [ 2.399263] Waiting for root device PARTUUID=141da37b-02... [ 3.146904] mmc1: new high speed SDXC card at address aaaa [ 3.153556] mmcblk1: mmc1:aaaa SC64G 59.5 GiB [ 3.164992] mmcblk1: p1 p2 [ 3.188649] EXT4-fs (mmcblk1p2): warning: mounting fs with errors, running e2fsck is recommended [ 3.254650] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null) [ 3.262831] VFS: Mounted root (ext4 filesystem) on device 179:98. [ 3.278836] devtmpfs: mounted [ 3.282113] Freeing unused kernel memory: 576K [ 3.286606] Run /sbin/init as init process [ 3.632333] systemd[1]: System time before build time, advancing clock. [ 3.759756] NET: Registered protocol family 10 [ 3.765365] Segment Routing with IPv6 [ 3.816359] systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid) [ 3.838084] systemd[1]: Detected architecture arm64. Welcome to Arago 2019.11! [ 3.884254] systemd[1]: Set hostname to <am65xx-evm>. [ 4.105812] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling. [ 4.122865] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.) [ 4.381047] random: systemd: uninitialized urandom read (16 bytes read) [ 4.388076] systemd[1]: Listening on Network Service Netlink Socket. [ OK ] Listening on Network Service Netlink Socket. [ 4.409484] random: systemd: uninitialized urandom read (16 bytes read) [ 4.418865] systemd[1]: Created slice system-serial\x2dgetty.slice. [ OK ] Created slice system-serial\x2dgetty.slice. [ 4.437581] random: systemd: uninitialized urandom read (16 bytes read) [ 4.444759] systemd[1]: Listening on Journal Socket. [ OK ] Listening on Journal Socket. [ 4.462754] systemd[1]: Created slice system-getty.slice. [ OK ] Created slice system-getty.slice. [ 4.485815] systemd[1]: Started Hardware RNG Entropy Gatherer Daemon. [ OK ] Started Hardware RNG Entropy Gatherer Daemon. [ OK ] Listening on Journal Socket (/dev/log). Starting Load Kernel Modules... [ OK ] Started Forward Password Requests to Wall Directory Watch. [ 4.585562] cryptodev: loading out-of-tree module taints kernel. Mounting Huge Pages File System... [ 4.596946] cryptodev: driver 1.9 loaded. [ OK ] Created slice User and Session Slice. [ OK ] Reached target Remote File Systems. Starting Remount Root and Kernel File Systems... [ OK ] Listening on udev Control Socket. [ 4.654848] EXT4-fs (mmcblk1p2): re-mounted. Opts: (null) [ OK ] Listening on udev Kernel Socket. [ OK ] Started Dispatch Password Requests to Console Directory Watch. [ OK ] Reached target Paths. Starting Journal Service... Starting Create list of required st…ce nodes for the current kernel... [ OK ] Reached target Slices. Starting udev Coldplug all Devices... Mounting Kernel Debug File System... [ OK ] Reached target Swap. Mounting Temporary Directory (/tmp)... [ OK ] Listening on initctl Compatibility Named Pipe. Mounting POSIX Message Queue File System... [ OK ] Listening on Process Core Dump Socket. [ OK ] Started Journal Service. [ OK ] Started Load Kernel Modules. [ OK ] Mounted Huge Pages File System. [ OK ] Started Remount Root and Kernel File Systems. [ OK ] Started Create list of required sta…vice nodes for the current kernel. [ OK ] Mounted Kernel Debug File System. [ OK ] Mounted Temporary Directory (/tmp). [ OK ] Mounted POSIX Message Queue File System. Starting Create Static Device Nodes in /dev... Starting Apply Kernel Variables... Mounting Kernel Configuration File System... Starting Flush Journal to Persistent Storage... [ OK ] Started Create Static Device Nodes in /dev. [ OK ] Started Apply Kernel Variables. [ OK ] Mounted Kernel Configuration File System. [ 5.150072] systemd-journald[168]: Received request to flush runtime journal from PID 1 [ OK ] Reached target Local File Systems (Pre). Mounting /media/ram... [ OK ] Reached target Containers. Mounting /var/volatile... Starting udev Kernel Device Manager... [ OK ] Started Flush Journal to Persistent Storage. [ OK ] Mounted /media/ram. [ OK ] Mounted /var/volatile. Starting Load/Save Random Seed... [ OK ] Reached target Local File Systems. Starting Create Volatile Files and Directories... [ OK ] Started Load/Save Random Seed. [ OK ] Started udev Kernel Device Manager. [ OK ] Started Create Volatile Files and Directories. Starting Update UTMP about System Boot/Shutdown... Starting Network Time Synchronization... Starting Network Service... [ OK ] Started Update UTMP about System Boot/Shutdown. [ OK ] Started udev Coldplug all Devices. [ OK ] Started Network Service. Starting Network Name Resolution... [ 5.626419] input: gpio-decoder as /devices/platform/gpio-decoder/input/input1 Starting Wait for Network to be Configured... [ OK ] Started Network Time Synchronization. [ OK ] Reached target System Initialization. [ OK ] Started Daily Cleanup of Temporary Directories. [ OK ] Listening on D-Bus System Message Bus Socket. [ OK ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket. Starting Reboot and dump vmcore via kexec... [ OK ] Listening on RPCbind Server Activation Socket. [ OK ] Listening on dropbear.socket. [ OK ] Reached target Sockets. [ 5.936237] CAN device driver interface [ OK ] Reached target Basic System. [ OK ] Started irqbalance daemon. [ 5.982147] m_can 40528000.mcan: m_can device registered (irq=17, version=32) Starting RPC Bind Service... Starting Print notice about GPLv3 packages... [ 6.027148] [drm] Initialized pvr 1.17.4948957 20110701 for 7000000.gpu on minor 0 Starting LSB: Raise network interfaces and configure them... [ OK ] Started Job spooling tools. [ 6.075765] m_can 40568000.mcan: m_can device registered (irq=19, version=32) [ OK ] Started TEE Supplicant. Starting TI IPC Daemon... Starting Login Service... [ OK ] Started D-Bus System Message Bus. [ OK ] Started Periodic Command Scheduler. [ OK ] Reached target System Time Synchronized. [ OK ] Started Daily rotation of log files. [ OK ] Reached target Timers. [ OK ] Started Network Name Resolution. [ OK ] Started Reboot and dump vmcore via kexec. [ OK ] Found device /dev/ttyS2. [ OK ] Started TI IPC Daemon. [ 6.231459] k3_r5_rproc interconnect@100000:interconnect@28380000:r5fss@41000000: creating child devices for R5F cores [ OK ] Found device /dev/ttyS1. [ OK ] Started RPC Bind Service. [ OK ] Reached target Network. Starting Lightning Fast Webserver With Light System Req[ 6.294382] platform 41000000.r5f: configured R5F for remoteproc mode uirements... Starting Simple Network Management Protocol (SNMP) Daemon.... Starting Permit User Sessions... [ OK ] Reached target Host and Network Name Lookups. [ 6.320871] platform 41000000.r5f: assigned reserved memory node r5f-dma-memory@a0000000 [ 6.334163] remoteproc remoteproc0: 41000000.r5f is available [ OK ] Started NFS status monitor for NFSv2/3 locking.. Starting Avahi mDNS/DNS-SD Stack... [ OK ] Started Permit User Sessions. [ OK ] Started Serial Getty on ttyS2. [ OK ] Started Getty on tty1. [ OK ] Started Serial Getty on ttyS1. [ OK ] Reached target Login Prompts. Starting Synchronize System and HW clocks... [ 6.485108] TI DP83867 k3-cpsw-mdio:00: attached PHY driver [TI DP83867] (mii_bus:phy_addr=k3-cpsw-mdio:00, irq=POLL) [ 6.500824] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready [ 6.756369] remoteproc remoteproc0: powering up 41000000.r5f [ 6.763286] remoteproc remoteproc0: Booting fw image am65x-mcu-r5f0_0-fw, size 4142860 [ 6.775317] platform 41000000.r5f: booting R5F core using boot addr = 0x0 [ 6.784737] virtio_rpmsg_bus virtio0: rpmsg host is online [ 6.788032] virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x3d [ 6.790613] remoteproc remoteproc0: registered virtio0 (type 7) [ 6.803719] remoteproc remoteproc0: remote processor 41000000.r5f is now up [ 7.057512] davinci_mdio b032400.mdio: davinci mdio revision 1.7, bus freq 1000000 [ OK ] Started Login Service. [ OK ] Started Lightning Fast Webserver With Light System Requirements. [FAILED] Failed to start Synchronize System and HW clocks. See 'systemctl status sync-clocks.service' for details. [ 7.104654] libphy: b032400.mdio: probed [ 7.138097] davinci_mdio b032400.mdio: phy[0]: device b032400.mdio:00, driver TI DP83867 [ 7.181448] davinci_mdio b032400.mdio: phy[3]: device b032400.mdio:03, driver TI DP83867 [ 7.354475] davinci_mdio b132400.mdio: davinci mdio revision 1.7, bus freq 1000000 [ 7.367900] libphy: b132400.mdio: probed [ 7.418363] davinci_mdio b132400.mdio: phy[0]: device b132400.mdio:00, driver TI DP83867 [ 7.466217] davinci_mdio b132400.mdio: phy[3]: device b132400.mdio:03, driver TI DP83867 [ 7.525974] am65-cpsw-nuss 46000000.ethernet eth0: Link is Down [ 7.594354] davinci_mdio b232400.mdio: davinci mdio revision 1.7, bus freq 1000000 [ 7.608225] libphy: b232400.mdio: probed [ 7.653481] davinci_mdio b232400.mdio: phy[0]: device b232400.mdio:00, driver TI DP83867 [ 7.673472] davinci_mdio b232400.mdio: phy[3]: device b232400.mdio:03, driver TI DP83867 [ 7.735926] remoteproc remoteproc1: b034000.pru is available [ OK ] Started Avahi mDNS/DNS-SD Stack. [ 7.771726] pru-rproc b034000.pru: PRU rproc node pru@b034000 probed successfully [ 7.791923] remoteproc remoteproc2: b004000.rtu is available [ 7.799880] pru-rproc b004000.rtu: PRU rproc node rtu@b004000 probed successfully [ 7.814101] remoteproc remoteproc3: b038000.pru is available [ 7.844684] pru-rproc b038000.pru: PRU rproc node pru@b038000 probed successfully [ 7.870088] remoteproc remoteproc4: b006000.rtu is available [ 7.877536] pru-rproc b006000.rtu: PRU rproc node rtu@b006000 probed successfully [ 7.889845] remoteproc remoteproc5: b134000.pru is available [ 7.898003] pru-rproc b134000.pru: PRU rproc node pru@b134000 probed successfully [ 7.909247] remoteproc remoteproc6: b104000.rtu is available [ 7.916614] pru-rproc b104000.rtu: PRU rproc node rtu@b104000 probed successfully [ 7.981807] remoteproc remoteproc7: b138000.pru is available [ 7.994506] pru-rproc b138000.pru: PRU rproc node pru@b138000 probed successfully [ 8.017189] remoteproc remoteproc8: b106000.rtu is available [ 8.052149] pru-rproc b106000.rtu: PRU rproc node rtu@b106000 probed successfully [ 8.104523] remoteproc remoteproc9: b234000.pru is available [ 8.112333] pru-rproc b234000.pru: PRU rproc node pru@b234000 probed successfully [ 8.123647] omap_rng 4e10000.trng: Random Number Generator ver. 230b34c [ 8.125086] random: crng init done [ 8.137497] random: 7 urandom warning(s) missed due to ratelimiting [ 8.147104] dwc3 4030000.usb: Failed to get clk 'ref': -2 [ 8.155362] remoteproc remoteproc10: b204000.rtu is available [ 8.169900] pru-rproc b204000.rtu: PRU rproc node rtu@b204000 probed successfully [ 8.179841] OF: graph: no port node found in /interconnect@100000/phy@4110000 [ 8.216417] remoteproc remoteproc11: b238000.pru is available [ 8.247168] pru-rproc b238000.pru: PRU rproc node pru@b238000 probed successfully [ 8.325617] remoteproc remoteproc12: b206000.rtu is available [ 8.336334] pru-rproc b206000.rtu: PRU rproc node rtu@b206000 probed successfully [ 8.347413] mmcblk1: error -110 requesting status [ 8.411515] mmcblk1: error -110 requesting status [ 8.416257] mmcblk1: recovery failed! [ 8.419967] print_req_error: I/O error, dev mmcblk1, sector 158896 [ 8.420882] mmcblk1: error -110 requesting status [ 8.430871] mmcblk1: recovery failed! [ 8.434550] print_req_error: I/O error, dev mmcblk1, sector 159920 [ 8.441916] mmcblk1: error -110 requesting status [ 8.446640] mmcblk1: recovery failed! [ 8.450327] print_req_error: I/O error, dev mmcblk1, sector 160944 [ 8.451218] mmcblk1: error -110 requesting status [ 8.559627] mmcblk1: error -110 requesting status [ 8.564375] mmcblk1: recovery failed! [ 8.568071] print_req_error: I/O error, dev mmcblk1, sector 157872 [ 8.568987] mmcblk1: error -110 requesting status [ 8.574901] Aborting journal on device mmcblk1p2-8. [ 8.610571] icssg-prueth pruss1_eth: TI PRU ethernet driver initialized: dual EMAC mode [ 8.652191] icssg-prueth pruss0_eth: TI PRU ethernet driver initialized: dual EMAC mode [ 8.655837] EXT4-fs error (device mmcblk1p2): ext4_journal_check_start:61: Detected aborted journal [ 8.669350] EXT4-fs (mmcblk1p2): Remounting filesystem read-only [ 8.669562] EXT4-fs error (device mmcblk1p2): ext4_journal_check_start:61: Detected aborted journal [ 8.682485] EXT4-fs error (device mmcblk1p2): ext4_journal_check_start:61: Detected aborted journal [ 8.699578] EXT4-fs error (device mmcblk1p2): ext4_journal_check_start:61: Detected aborted journal [ 8.702600] EXT4-fs error (device mmcblk1p2): ext4_journal_check_start:61: Detected aborted journal [ 8.711606] EXT4-fs error (device mmcblk1p2): ext4_journal_check_start:61: Detected aborted journal [ 8.714816] icssg-prueth pruss2_eth: TI PRU ethernet driver initialized: dual EMAC mode [ 8.739096] EXT4-fs error (device mmcblk1p2): ext4_journal_check_start:61: Detected aborted journal [ 8.743249] EXT4-fs error (device mmcblk1p2): ext4_journal_check_start:61: Detected aborted journal [ 8.745404] EXT4-fs error (device mmcblk1p2): ext4_journal_check_start:61: Detected aborted journal [ 8.745745] EXT4-fs error (device mmcblk1p2): ext4_journal_check_start:61: Detected aborted journal [ 8.776595] EXT4-fs error (device mmcblk1p2): ext4_journal_check_start:61: Detected aborted journal [ 8.793115] EXT4-fs error (device mmcblk1p2): ext4_journal_check_start:61: Detected aborted journal [ 8.805041] EXT4-fs error (device mmcblk1p2): ext4_journal_check_start:61: Detected aborted journal [ 8.805072] EXT4-fs error (device mmcblk1p2): ext4_journal_check_start:61: Detected aborted journal [ 8.823915] NET: Registered protocol family 45 [ OK ] Started Hardware RNG Entropy Gatherer Daemon. [ OK ] Started Simple Network Management Protocol (SNMP) Daemon.. [ 8.991834] usbcore: registered new interface driver usbfs [ 9.000211] usbcore: registered new interface driver hub [ 9.007757] usbcore: registered new device driver usb [ 9.085744] remoteproc remoteproc5: powering up b134000.pru [ 9.096823] remoteproc remoteproc5: Booting fw image ti-pruss/am65x-pru0-prueth-fw.elf, size 16460 [ 9.098435] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 9.108896] remoteproc remoteproc5: remote processor b134000.pru is now up [ 9.112446] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1 [ 9.125459] remoteproc remoteproc6: powering up b104000.rtu [ 9.135256] xhci-hcd xhci-hcd.2.auto: hcc params 0x0298fe6d hci version 0x110 quirks 0x0000000000010010 [ 9.145187] remoteproc remoteproc6: Booting fw image ti-pruss/am65x-rtu0-prueth-fw.elf, size 15540 [ 9.146211] xhci-hcd xhci-hcd.2.auto: irq 305, io mem 0x04030000 [ 9.158356] remoteproc remoteproc6: remote processor b104000.rtu is now up [ 9.161559] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19 [ 9.173779] net eth1: started [ 9.176258] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 9.186815] usb usb1: Product: xHCI Host Controller [ 9.187041] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready [ 9.192701] usb usb1: Manufacturer: Linux 4.19.79-g77dfab56c6 xhci-hcd [ 9.205128] usb usb1: SerialNumber: xhci-hcd.2.auto [ 9.212966] hub 1-0:1.0: USB hub found [ 9.217388] hub 1-0:1.0: 1 port detected [ 9.222294] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller [ 9.228658] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2 [ 9.236616] xhci-hcd xhci-hcd.2.auto: Host supports USB 3.0 SuperSpeed [ 9.243108] remoteproc remoteproc3: powering up b038000.pru [ 9.243327] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 9.257173] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19 [ 9.262618] remoteproc remoteproc3: Booting fw image ti-pruss/am65x-pru1-prueth-fw.elf, size 16460 [ 9.265541] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 9.274617] remoteproc remoteproc3: remote processor b038000.pru is now up [ 9.281742] usb usb2: Product: xHCI Host Controller [ 9.281749] usb usb2: Manufacturer: Linux 4.19.79-g77dfab56c6 xhci-hcd [ 9.281755] usb usb2: SerialNumber: xhci-hcd.2.auto [ 9.282637] hub 2-0:1.0: USB hub found [ 9.288821] remoteproc remoteproc4: powering up b006000.rtu [ 9.293664] hub 2-0:1.0: 1 port detected [ 9.305256] remoteproc remoteproc4: Booting fw image ti-pruss/am65x-rtu1-prueth-fw.elf, size 15540 [ 9.327835] remoteproc remoteproc4: remote processor b006000.rtu is now up [ 9.336184] net eth4: started [ 9.339819] IPv6: ADDRCONF(NETDEV_UP): eth4: link is not ready [ 9.369782] remoteproc remoteproc1: powering up b034000.pru [ 9.376892] remoteproc remoteproc1: Booting fw image ti-pruss/am65x-pru0-prueth-fw.elf, size 16460 [ 9.386017] remoteproc remoteproc1: remote processor b034000.pru is now up [ 9.393042] remoteproc remoteproc2: powering up b004000.rtu [ 9.398889] remoteproc remoteproc2: Booting fw image ti-pruss/am65x-rtu0-prueth-fw.elf, size 15540 [ 9.407993] remoteproc remoteproc2: remote processor b004000.rtu is now up [ 9.416063] net eth3: started [ 9.419991] IPv6: ADDRCONF(NETDEV_UP): eth3: link is not ready [ 9.449959] remoteproc remoteproc9: powering up b234000.pru [ 9.456015] remoteproc remoteproc9: Booting fw image ti-pruss/am65x-pru0-prueth-fw.elf, size 16460 [ 9.465214] remoteproc remoteproc9: remote processor b234000.pru is now up [ 9.472160] remoteproc remoteproc10: powering up b204000.rtu [ 9.477993] remoteproc remoteproc10: Booting fw image ti-pruss/am65x-rtu0-prueth-fw.elf, size 15540 [ 9.487106] remoteproc remoteproc10: remote processor b204000.rtu is now up [ 9.495301] net eth5: started [ OK ] Found device /dev/mmcblk0p1. [ 9.498852] IPv6: ADDRCONF(NETDEV_UP): eth5: link is not ready Starting File System Check on /dev/mmcblk0p1... [ 9.533103] remoteproc remoteproc7: powering up b138000.pru [ 9.539298] remoteproc remoteproc7: Booting fw image ti-pruss/am65x-pru1-prueth-fw.elf, size 16460 [ 9.548381] remoteproc remoteproc7: remote processor b138000.pru is now up [ 9.555348] remoteproc remoteproc8: powering up b106000.rtu [ 9.561078] remoteproc remoteproc8: Booting fw image ti-pruss/am65x-rtu1-prueth-fw.elf, size 15540 [ 9.570117] remoteproc remoteproc8: remote processor b106000.rtu is now up [ 9.578227] net eth2: started [ 9.581776] IPv6: ADDRCONF(NETDEV_UP): eth2: link is not ready [ 9.602096] remoteproc remoteproc11: powering up b238000.pru [ 9.608426] remoteproc remoteproc11: Booting fw image ti-pruss/am65x-pru1-prueth-fw.elf, size 16460 [ 9.617634] remoteproc remoteproc11: remote processor b238000.pru is now up [ 9.624831] remoteproc remoteproc12: powering up b206000.rtu [ 9.630741] remoteproc remoteproc12: Booting fw image ti-pruss/am65x-rtu1-prueth-fw.elf, size 15540 [ 9.639948] remoteproc remoteproc12: remote processor b206000.rtu is now up [ 9.648601] net eth6: started [ 9.652185] IPv6: ADDRCONF(NETDEV_UP): eth6: link is not ready [ OK ] Found device /dev/mmcblk1p1. Starting File System Check on /dev/mmcblk1p1... [ 9.966205] mmcblk1: error -110 requesting status [ 10.027821] mmcblk1: error -110 requesting status [ 10.032607] mmcblk1: recovery failed! [ 10.036370] print_req_error: I/O error, dev mmcblk1, sector 2048 [ 10.037365] mmcblk1: error -110 requesting status [ 10.042392] Buffer I/O error on dev mmcblk1p1, logical block 0, lost async page write [ OK ] Started File System Check on /dev/mmcblk1p1. Mounting /run/media/mmcblk1p1... [ OK ] Mounted /run/media/mmcblk1p1. *************************************************************** *************************************************************** NOTICE: This file system contains the following GPLv3 packages: autoconf bash-dev bash bc binutils cifs-utils cpio cpp-symlinks cpp dosfstools elfutils g++-symlinks g++ gawk gcc-symlinks gcc gdb gdbserver gettext glmark2 gstreamer1.0-libav gzip hidapi libbfd libcairo-perf-utils libdw1 libelf1 libgdbm-compat4 libgdbm-dev libgdbm6 libgettextlib libgettextsrc libgmp10 libidn2-0 libmpc3 libmpfr6 libreadline-dev libreadline7 libunistring2 m4-dev m4 make nettle parted pdm-anomaly-detection swig-dev swig which If you do not wish to distribute GPLv3 components please remove the above packages prior to distribution. This can be done using the opkg remove command. i.e.: opkg remove <package> Where <package> is the name printed in the list above NOTE: If the package is a dependency of another package you will be notified of the dependent packages. You should use the --force-removal-of-dependent-packages option to also remove the dependent packages as well *************************************************************** *************************************************************** _____ _____ _ _ | _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_ | | _| .'| . | . | | __| _| . | | | -_| _| _| |__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_| |___| |___| Arago Project http://arago-project.org am65xx-evm ttyS2 Arago 2019.11 am65xx-evm ttyS2 am65xx-evm login: root [ 16.524233] PVR_K: UM DDK-(4948957) and KM DDK-(4948957) match. [ OK ] [ 42.181804] icssg-prueth pruss0_eth eth3: Link is Up - 100Mbps/Full - flow control off [ 42.189833] IPv6: ADDRCONF(NETDEV_CHANGE): eth3: link becomes ready am65xx-evm login: ifconfig eth3 eth3 Link encap:Ethernet HWaddr 70:FF:76:1D:4E:56 inet addr:192.168.1.77 Bcast:192.168.1.255 Mask:255.255.255.0 inet6 addr: fe80::72ff:76ff:fe1d:4e56/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:16 errors:0 dropped:0 overruns:0 frame:0 TX packets:48 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:1516 (1.4 KiB) TX bytes:7485 (7.3 KiB) root@am65xx-evm:~# ethtool eth3 Settings for eth3: Supported ports: [ TP MII ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Supported pause frame use: No Supports auto-negotiation: Yes Supported FEC modes: Not reported Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Advertised pause frame use: No Advertised auto-negotiation: Yes Advertised FEC modes: Not reported Speed: 100Mb/s Duplex: Full Port: MII PHYAD: 0 Transceiver: internal Auto-negotiation: on Current message level: 0x00007fff (32767) drv probe link timer ifdown ifup rx_err tx_err tx_queued intr tx_done rx_status pktdata hw wol Link detected: yes root@am65xx-evm:~# ping 192.168.1.10 PING 192.168.1.10 (192.168.1.10): 56 data bytes 64 bytes from 192.168.1.10: seq=0 ttl=64 time=4.618 ms 64 bytes from 192.168.1.10: seq=1 ttl=64 time=1.856 ms 64 bytes from 192.168.1.10: seq=2 ttl=64 time=2.069 ms 64 bytes from 192.168.1.10: seq=3 ttl=64 time=3.345 ms 64 bytes from 192.168.1.10: seq=4 ttl=64 time=2.924 ms 64 bytes from 192.168.1.10: seq=5 ttl=64 time=1.734 ms [ 79.045599] icssg-prueth pruss0_eth eth3: Link is Down ping: sendto: Network is unreachable [ 84.165816] icssg-prueth pruss0_eth eth3: Link is Up - 100Mbps/Full - flow control off root@am65xx-evm:~# ifconfig eth3 eth3 Link encap:Ethernet HWaddr 70:FF:76:1D:4E:56 inet6 addr: fe80::72ff:76ff:fe1d:4e56/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:72 errors:0 dropped:0 overruns:0 frame:0 TX packets:75 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:5256 (5.1 KiB) TX bytes:10787 (10.5 KiB) root@am65xx-evm:~# ifconfig eth3 192.168.1.77 root@am65xx-evm:~# ifconfig eth3 eth3 Link encap:Ethernet HWaddr 70:FF:76:1D:4E:56 inet addr:192.168.1.77 Bcast:192.168.1.255 Mask:255.255.255.0 inet6 addr: fe80::72ff:76ff:fe1d:4e56/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:108 errors:0 dropped:1 overruns:0 frame:0 TX packets:89 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:7416 (7.2 KiB) TX bytes:14085 (13.7 KiB) root@am65xx-evm:~# ethtool eth3 Settings for eth3: Supported ports: [ TP MII ] Supported link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Supported pause frame use: No Supports auto-negotiation: Yes Supported FEC modes: Not reported Advertised link modes: 10baseT/Half 10baseT/Full 100baseT/Half 100baseT/Full 1000baseT/Full Advertised pause frame use: No Advertised auto-negotiation: Yes Advertised FEC modes: Not reported Speed: 100Mb/s Duplex: Full Port: MII PHYAD: 0 Transceiver: internal Auto-negotiation: on Current message level: 0x00007fff (32767) drv probe link timer ifdown ifup rx_err tx_err tx_queued intr tx_done rx_status pktdata hw wol Link detected: yes root@am65xx-evm:~# ping 192.168.1.10 PING 192.168.1.10 (192.168.1.10): 56 data bytes [ 125.918197] NET: Registered protocol family 15 [ 126.009235] Initializing XFRM netlink socket [ 130.149351] ------------[ cut here ]------------ [ 130.153990] NETDEV WATCHDOG: eth3 (icssg-prueth): transmit queue 0 timed out [ 130.161107] WARNING: CPU: 1 PID: 0 at net/sched/sch_generic.c:466 dev_watchdog+0x29c/0x2a8 [ 130.169354] Modules linked in: xfrm_user xfrm4_tunnel tunnel4 ipcomp xfrm_ipcomp esp4 ah4 af_key xfrm_algo xhci_plat_hcd xhci_hcd usbcore rpmsg_proto icssg_prueth ti_am335x_adc dwc3 omap_rng kfifo_buf rng_core udc_core pru_rproc crc32_ce crct10dif_ce pruss irq_pruss_intc ti_k3_r5_remoteproc virtio_rpmsg_bus remoteproc pvrsrvkm(O) m_can can_dev ti_am335x_tscadc sa2ul pruss_soc_bus sha512_generic authenc phy_omap_usb2 dwc3_keystone gpio_decoder input_polldev sch_fq_codel jailhouse(O) cryptodev(O) ipv6 [ 130.213619] CPU: 1 PID: 0 Comm: swapper/1 Tainted: G O 4.19.79-g77dfab56c6 #2 [ 130.222039] Hardware name: Texas Instruments AM654 Base Board (DT) [ 130.228208] pstate: 20000005 (nzCv daif -PAN -UAO) [ 130.232990] pc : dev_watchdog+0x29c/0x2a8 [ 130.236991] lr : dev_watchdog+0x29c/0x2a8 [ 130.240988] sp : ffff00000802fd80 [ 130.244292] x29: ffff00000802fd80 x28: 0000000000000005 [ 130.249596] x27: ffff80084016af80 x26: 00000000ffffffff [ 130.254899] x25: 0000000000000140 x24: ffff800848025440 [ 130.260203] x23: ffff80084802541c x22: ffff8008444b3880 [ 130.265506] x21: ffff000008cd1000 x20: ffff800848025000 [ 130.270809] x19: 0000000000000000 x18: 0000000000000010 [ 130.276112] x17: 0000000000000000 x16: 0000000000000000 [ 130.281415] x15: ffffffffffffffff x14: ffff000008cd3648 [ 130.286718] x13: ffff000088d968a7 x12: ffff000008d968af [ 130.292021] x11: ffff000008ce9000 x10: ffff00000802fa80 [ 130.297325] x9 : 00000000ffffffd0 x8 : ffff0000084f4ff0 [ 130.302628] x7 : 6575657571207469 x6 : ffff80087fab17e8 [ 130.307931] x5 : ffff0000084230a8 x4 : 0000000000000002 [ 130.313233] x3 : 0000000000000004 x2 : 0000000000000040 [ 130.318536] x1 : 3af9cb18dd4cc700 x0 : 0000000000000000 [ 130.323840] Call trace: [ 130.326282] dev_watchdog+0x29c/0x2a8 [ 130.329940] call_timer_fn+0x20/0x78 [ 130.333507] expire_timers+0xa8/0xb8 [ 130.337074] run_timer_softirq+0xa4/0x190 [ 130.341077] __do_softirq+0x10c/0x208 [ 130.344734] irq_exit+0xb8/0xc8 [ 130.347869] __handle_domain_irq+0x64/0xb8 [ 130.351956] gic_handle_irq+0x7c/0x178 [ 130.355696] el1_irq+0xb0/0x128 [ 130.358832] arch_cpu_idle+0x10/0x18 [ 130.362401] do_idle+0x120/0x138 [ 130.365621] cpu_startup_entry+0x24/0x28 [ 130.369537] secondary_start_kernel+0x148/0x158 [ 130.374056] ---[ end trace 493d524f36cd6abb ]--- [ 130.378678] icssg-prueth pruss0_eth eth3: xmit timeout [ 136.037351] icssg-prueth pruss0_eth eth3: xmit timeout [ 141.157343] icssg-prueth pruss0_eth eth3: xmit timeout [ 146.021346] icssg-prueth pruss0_eth eth3: xmit timeout [ 151.141344] icssg-prueth pruss0_eth eth3: xmit timeout [ 156.005348] icssg-prueth pruss0_eth eth3: xmit timeout [ 161.125346] icssg-prueth pruss0_eth eth3: xmit timeout [ 165.989350] icssg-prueth pruss0_eth eth3: xmit timeout [ 171.109358] icssg-prueth pruss0_eth eth3: xmit timeout [ 175.973343] icssg-prueth pruss0_eth eth3: xmit timeout [ 181.093343] icssg-prueth pruss0_eth eth3: xmit timeout [ 185.957345] icssg-prueth pruss0_eth eth3: xmit timeout [ 191.077347] icssg-prueth pruss0_eth eth3: xmit timeout [ 195.941349] icssg-prueth pruss0_eth eth3: xmit timeout [ 201.061342] icssg-prueth pruss0_eth eth3: xmit timeout [ 206.181345] icssg-prueth pruss0_eth eth3: xmit timeout [ 211.045343] icssg-prueth pruss0_eth eth3: xmit timeout [ 216.165347] icssg-prueth pruss0_eth eth3: xmit timeout [ 221.029352] icssg-prueth pruss0_eth eth3: xmit timeout [ 226.149348] icssg-prueth pruss0_eth eth3: xmit timeout [ 231.013342] icssg-prueth pruss0_eth eth3: xmit timeout
