i want to programming the codec in asm, i want write a code that the DAC of this codec receive data from a buffer.
i need a document that explain programming in asm of AIC23 for DSP6713.
Meriem
Meriem
Assuming you plan to handcode your C routine to asm, please see CPU and Instruction guide for C674x DSP for details (http://focus.ti.com/lit/ug/sprufe8b/sprufe8b.pdf).
Gaurav
thanks for your reply, i have already this reference guide, its not for programming the codec AIC23,
is there possibility to have mixte programmation? if its yes, what is the file extension??.asm? .c? or what ?
because when i add instructions in C about sending samples to the codec i have errors.
Regards.
Meriem
