Part Number: DRA746
For the compiler used on TI J6 M4 core what is the default include paths? The customer has several instances of the include files, such as "fcntl.h" and wanted to find out which is the actual one. None of the directories in the -I includes have these files...
/home/buildserver/VISIONSDK-BUILD/ti_components/cg_tools/linux/ti-cgt-arm_16.9.2.LTS/bin/armcl -c -qq -pdsw225 --endian=little -mv7M4 --float_support=vfplib --abi=eabi -eo.oem4 -ea.sem4 --symdebug:dwarf --embed_inline_assembly -DBIOS_BUILD -DSYSBIOS --common=off --emit_warnings_as_errors -DA15_TARGET_OS_LINUX -DDDR_MEM_1024M -DBSP_DISABLE_I2C0 -DBSP_DISABLE_I2C2 -DBSP_DISABLE_I2C5 -DDDR_MEM_1024M -DCPU_IDLE_ENABLED -g -ms -D___DSPBIOS___ -D___DUCATI_FW___ -Dxdc_target_name__=M4 -Dxdc_target_types__=ti/targets/arm/elf/std.h -Dxdc_bld__profile_release -Dxdc_bld__vers_1_0_4_6_1 -ms -oe -O3 -op0 -os --optimize_with_debug --inline_recursion_limit=20 -DTDA2XX_BUILD -DTDA2XX_FAMILY_BUILD -DSOC_TDA2XX -DPLATFORM_EVM_SI -D_DRA7xx -D_SC_VER_1_16 -D__sysbios__ -DUTILS_ASSERT_ENABLE -DFVID2_BACKWARD_COMPATIBLE -DUSE_STD_ASSERT -DTRACE_ENABLE -DASSERT_ENABLE -DENABLE_CCS_LOG -D_GNU_SOURCE -DBOARD_TYPE_TDA2XX_EVM -DRELEASE_BUILD -DBUILD_M4 -DBUILD_M4_0 -DPROC_IPU1_0_INCLUDE -DIVAHD_INCLUDE -DDSS_INCLUDE -DIPU_PRIMARY_CORE_IPU1 -DIPU_SECONDARY_CORE_IPU2 -DTDA2XX_BUILD -DTDA2XX_FAMILY_BUILD -DPLATFORM_EVM_SI -DVPS_VIP_BUILD -DVPS_DSS_BUILD -I/home/buildserver/VISIONSDK-BUILD/ti_components/cg_tools/linux/ti-cgt-arm_16.9.2.LTS/include -I. -I../include -Itda2xx -I../../ -I/home/buildserver/VISIONSDK-BUILD/ti_components/os_tools/bios_6_46_04_53/packages -I/home/buildserver/VISIONSDK-BUILD/ti_components/os_tools/linux/xdctools_3_32_01_22_core/packages -I/home/buildserver/VISIONSDK-BUILD/ti_components/os_tools/ipc_3_45_00_00/packages -I/home/buildserver/VISIONSDK-BUILD/ti_components/drivers/pdk_01_10_00_08/packages -I/home/buildserver/VISIONSDK-BUILD/ti_components/codecs/framework_components_3_40_02_07/packages -I/home/buildserver/VISIONSDK-BUILD/ti_components/codecs/xdais_7_24_00_04/packages -I/home/buildserver/VISIONSDK-BUILD/ti_components/drivers/edma3_lld_02_12_00_20/packages -I/home/buildserver/VISIONSDK-BUILD/ti_components/networking/ndk_2_24_02_31/packages -I/home/buildserver/VISIONSDK-BUILD/ti_components/networking/nsp_gmacsw_4_15_00_00/packages -I/home/buildserver/VISIONSDK-BUILD/vision_sdk/links_fw -I/home/buildserver/VISIONSDK-BUILD/vision_sdk/links_fw/src -I/home/buildserver/VISIONSDK-BUILD/ti_components/networking/ndk_2_24_02_31/packages -I/home/buildserver/VISIONSDK-BUILD/ti_components/networking/nsp_gmacsw_4_15_00_00/packages -I/packages -I/home/buildserver/VISIONSDK-BUILD/vision_sdk/links_fw/include/config/apps/tda2xx_evm_linux_all -I/home/buildserver/VISIONSDK-BUILD/ti_components/algorithms/eve_sw_01_19_00_00/common -I/home/buildserver/VISIONSDK-BUILD/ti_components/algorithms/REL.TIDL.01.01.01.00/modules/ti_dl/inc -fr=/home/buildserver/VISIONSDK-BUILD/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/utils_common/tda2xx-evm/ipu1_0/release -fs=/home/buildserver/VISIONSDK-BUILD/vision_sdk/binaries/apps/tda2xx_evm_linux_all/obj/utils_common/tda2xx-evm/ipu1_0/release -fc stat_collector_utils/cToolsHelper.c
