Part Number: DRA726
Other Parts Discussed in Thread: DRA722, DP83TC811, TCA6416, TCA8418, LM8323, LM8333, ADS7846, TSC2004, TSC2005, TSC2007, TPIC2810, DRA752, LP3943, TPS65010, TPS65086, TPS65090, TPS65217, TPS65218, TPS65910, TPS65912, TWL6040, LM3533, LP3971, LP3972, TPS51632, TPS62360, TPS65023, TPS65132, TLV320AIC23B, TVP5150, TVP7002, THS8200, LM3560, THS7303, OPA362, TPD12S015, TFP410, LM3630A, LM3639, PCM1681, PCM1789, PCM3168A, TAS2552, TAS5086, TAS6424, TS3A227E, TPA6130A2, LM3530, LM3642, LP3944, LP5521, LP5523, LP5562, LP8501, DAC124S085, TCA6507, CDCE706, CDCE925, ADC084S021, ADC108S102, ADC128S052, ADC161S626, ADS1015, ADS7950, ADS8688, TLC4541, DAC082S085, DAC5571, AFE4403, AFE4404, OPT3001, LMP91000, TMP006
I have some issues with the LCD with the kernel 4.19
I updated panel-simple.c as instructed by TI to another customer who seem to have a similar issue.
I don't know what could be wrong. It looks like something is on the LCD but no command line text or weston display
I put ---------------------------------- between each block to make it easier to follow
Here is the original devicetree information for the 12 inch display
lcd0: display {
compatible = "panel-dpi";
label = "lcd0";
backlight = <&lcd_bl>;
panel-timing {
clock-frequency = <93688800>;
hactive = <1920>;
vactive = <720>;
hfront-porch = <115>;
hback-porch = <20>;
hsync-len = <5>;
vback-porch = <3>;
vfront-porch = <32>;
vsync-len = <3>;
hsync-active = <0>;
vsync-active = <0>;
de-active = <1>;
pixelclk-active = <1>;
port {
lcd_in: endpoint {
remote-endpoint = <&dpi_out>;
Here is the device tree change and panel-simple.c changes
/* LVDS LCD Display*/
lcd0: display {
status = "okay";
compatible = "actiagd,gd12inch", "panel-dpi";
label = "lcd0";
port {
lcd_in: endpoint {
static const struct drm_display_mode actiagd_gd7inch_mode = {
.clock = 66800,
.hdisplay = 800,
.hsync_start = 800 + 51,
.hsync_end = 800 + 51 + 3,
.htotal = 800 + 51 + 3 + 10,
.vdisplay = 1280,
.vsync_start = 1280 + 2,
.vsync_end = 1280 + 2 + 3,
.vtotal = 1280 + 2 + 3 + 32,
.vrefresh = 60,
.flags = DRM_MODE_FLAG_NHSYNC | DRM_MODE_FLAG_NVSYNC,
static const struct panel_desc actiagd_gd7inch = {
.modes = &actiagd_gd7inch_mode,
.num_modes = 1,
.bpc = 8,
.size = {
.width = 800,
.height = 1280,
static const struct drm_display_mode actiagd_gd12inch_mode = {
.clock = 93680,
.hdisplay = 1920,
.hsync_start = 1920 + 115,
.hsync_end = 1920 + 115 + 5,
.htotal = 1920 + 115 + 5 + 20,
.vdisplay = 720,
.vsync_start = 720 + 4,
.vsync_end = 720 + 4 + 2,
.vtotal = 720 + 4 + 2 + 2,
.vrefresh = 60,
static const struct panel_desc actiagd_gd12inch = {
.modes = &actiagd_gd12inch_mode,
.num_modes = 1,
.bpc = 8,
.size = {
.width = 1920,
.height = 720,
static const struct of_device_id platform_of_match[] = {
.compatible = "actiagd,gd7inch",
.data = &actiagd_gd7inch,
.compatible = "actiagd,gd12inch",
.data = &actiagd_gd12inch,
.compatible = "ampire,am-480272h3tmqw-t01h",
.data = &ire_am_480272h3tmqw_t01h,
Here is the modetest display with kernel 4.4
root@actia-dra726-12inch:~# modetest
trying to open device 'i915'...failed
trying to open device 'radeon'...failed
trying to open device 'nouveau'...failed
trying to open device 'vmwgfx'...failed
trying to open device 'omapdrm'...done
Encoders:
id crtc type possible crtcs possible clones
31 34 TMDS 0x00000001 0x00000000
Connectors:
id encoder status name size (mm) modes encoders
32 31 connected unknown-1 0x0 1 31
modes:
name refresh (Hz) hdisp hss hse htot vdisp vss vse vtot)
1920x720 60 1920 2035 2040 2060 720 752 755 758 flags: nhsync, nvsync; type: preferred, driver
props:
1 EDID:
flags: immutable blob
blobs:
value:
2 DPMS:
flags: enum
enums: On=0 Standby=1 Suspend=2 Off=3
value: 0
CRTCs:
id fb pos size
34 42 (0,0) (1920x720)
props:
27 trans-key-mode:
flags: enum
enums: disable=0 gfx-dst=1 vid-src=2
value: 0
28 trans-key:
flags: range
values: 0 16777215
value: 0
29 background:
flags: range
values: 0 16777215
value: 0
30 alpha_blender:
flags: range
values: 0 1
value: 0
21 GAMMA_LUT:
flags: blob
blobs:
value:
22 GAMMA_LUT_SIZE:
flags: immutable range
values: 0 4294967295
value: 256
23 rotation:
flags: bitmask
values: rotate-0=0x1 rotate-90=0x2 rotate-180=0x4 rotate-270=0x8 reflect-x=0x10 reflect-y=0x20
value: 1
24 zorder:
flags: range
values: 0 3
value: 0
36 0 (0,0) (0x0)
0 0 0 0 0 0 0 0 0 flags: ; type:
props:
27 trans-key-mode:
flags: enum
value: 0
28 trans-key:
flags: range
values: 0 16777215
value: 0
29 background:
flags: range
values: 0 16777215
value: 0
30 alpha_blender:
flags: range
values: 0 1
value: 0
21 GAMMA_LUT:
flags: blob
blobs:
value:
22 GAMMA_LUT_SIZE:
value: 256
23 rotation:
flags: bitmask
value: 1
24 zorder:
flags: range
values: 0 3
value: 0
Planes:
id crtc fb CRTC x,y x,y gamma size possible crtcs
33 34 42 0,0 0,0 0 0x00000001
formats: RG16 RX12 XR12 RA12 AR12 XR15 AR15 RG24 RX24 XR24 RA24 AR24
props:
5 type:
flags: immutable enum
enums: Overlay=0 Primary=1 Cursor=2
value: 1
23 rotation:
flags: bitmask
value: 1
24 zorder:
flags: range
values: 0 3
value: 0
25 global_alpha:
flags: range
values: 0 255
value: 255
26 pre_mult_alpha:
flags: range
values: 0 1
value: 0
35 0 0 0,0 0,0 0 0x00000002
formats: RG16 RX12 XR12 RA12 AR12 XR15 AR15 RG24 RX24 XR24 RA24 AR24 NV12 YUYV UYVY
props:
5 type:
value: 1
23 rotation:
flags: bitmask
value: 1
24 zorder:
flags: range
values: 0 3
value: 0
25 global_alpha:
flags: range
values: 0 255
value: 255
26 pre_mult_alpha:
flags: range
values: 0 1
value: 0
Frame buffers:
id size pitch
Here is the modetest display for kernel 4.19
root@actia-gd:~# modetest
trying to open device 'amdgpu'...failed
Encoders:
53 55 TMDS 0x00000001 0x00000000
Connectors:
54 53 connected DPI-1 1920x720 1 53
modes:
1920x720 60 1920 2035 2040 2060 720 724 726 728 93680 flags: nhsync, nvsync; type: preferred, driver
props:
1 EDID:
blobs:
value:
2 DPMS:
flags: enum
value: 0
5 link-status:
flags: enum
enums: Good=0 Bad=1
value: 0
6 non-desktop:
values: 0 1
value: 0
19 CRTC_ID:
flags: object
value: 55
CRTCs:
id fb pos size
55 58 (0,0) (1920x720)
props:
20 ACTIVE:
flags: range
values: 0 1
value: 1
21 MODE_ID:
flags: blob
blobs:
value:
f06d01008007f307f8070c080000d002
d402d602d80200003c0000000a000000
48000000313932307837323000000000
00000000000000000000000000000000
00000000
18 OUT_FENCE_PTR:
flags: range
values: 0 18446744073709551615
value: 0
24 CTM:
flags: blob
blobs:
value:
25 GAMMA_LUT:
flags: blob
blobs:
value:
26 GAMMA_LUT_SIZE:
value: 256
31 background:
flags: range
values: 0 16777215
value: 0
32 trans-key-mode:
flags: enum
value: 0
33 trans-key:
flags: range
values: 0 16777215
value: 0
34 alpha_blender:
flags: range
values: 0 1
value: 0
36 rotation:
flags: bitmask
value: 1
28 zorder:
flags: range
values: 0 3
value: 0
Planes:
35 55 58 0,0 0,0 0 0x00000001
formats: RX12 AR12 RG16 XR24 RG24 AR24 RA24 RX24 AR15 XR12 RA12 XR15
props:
7 type:
value: 1
16 FB_ID:
flags: object
value: 58
17 IN_FENCE_FD:
flags: signed range
values: -1 2147483647
value: -1
19 CRTC_ID:
flags: object
value: 55
12 CRTC_X:
flags: signed range
values: -2147483648 2147483647
value: 0
13 CRTC_Y:
flags: signed range
value: 0
14 CRTC_W:
flags: range
values: 0 2147483647
value: 1920
15 CRTC_H:
flags: range
value: 720
8 SRC_X:
flags: range
value: 0
9 SRC_Y:
flags: range
value: 0
10 SRC_W:
flags: range
value: 125829120
11 SRC_H:
flags: range
value: 47185920
36 rotation:
flags: bitmask
value: 1
28 zorder:
flags: range
values: 0 3
value: 0
37 zpos:
flags: range
values: 0 3
value: 0
29 global_alpha:
flags: range
values: 0 255
value: 255
30 pre_mult_alpha:
flags: range
values: 0 1
value: 0
38 0 0 0,0 0,0 0 0x00000001
formats: RG16 RX12 YUYV AR15 RA24 NV12 RA12 XR24 RG24 UYVY AR12 XR15 AR24 XR12 RX24
props:
7 type:
value: 0
16 FB_ID:
flags: object
value: 0
17 IN_FENCE_FD:
flags: signed range
value: -1
19 CRTC_ID:
flags: object
value: 0
12 CRTC_X:
flags: signed range
value: 0
13 CRTC_Y:
flags: signed range
value: 0
14 CRTC_W:
flags: range
value: 0
15 CRTC_H:
flags: range
value: 0
8 SRC_X:
flags: range
value: 0
9 SRC_Y:
flags: range
value: 0
10 SRC_W:
flags: range
value: 0
11 SRC_H:
flags: range
value: 0
39 rotation:
flags: bitmask
value: 1
28 zorder:
flags: range
values: 0 3
value: 1
40 zpos:
flags: range
values: 0 3
value: 1
41 COLOR_ENCODING:
flags: enum
enums: ITU-R BT.601 YCbCr=0 ITU-R BT.709 YCbCr=1
value: 0
42 COLOR_RANGE:
flags: enum
enums: YCbCr limited range=0 YCbCr full range=1
value: 1
29 global_alpha:
flags: range
values: 0 255
value: 255
30 pre_mult_alpha:
flags: range
values: 0 1
value: 0
43 0 0 0,0 0,0 0 0x00000001
props:
7 type:
value: 0
16 FB_ID:
flags: object
value: 0
17 IN_FENCE_FD:
flags: signed range
value: -1
19 CRTC_ID:
flags: object
value: 0
12 CRTC_X:
flags: signed range
value: 0
13 CRTC_Y:
flags: signed range
value: 0
14 CRTC_W:
flags: range
value: 0
15 CRTC_H:
flags: range
value: 0
8 SRC_X:
flags: range
value: 0
9 SRC_Y:
flags: range
value: 0
10 SRC_W:
flags: range
value: 0
11 SRC_H:
flags: range
value: 0
44 rotation:
flags: bitmask
value: 1
28 zorder:
flags: range
values: 0 3
value: 2
45 zpos:
flags: range
values: 0 3
value: 2
46 COLOR_ENCODING:
flags: enum
value: 0
47 COLOR_RANGE:
flags: enum
value: 1
29 global_alpha:
flags: range
values: 0 255
value: 255
30 pre_mult_alpha:
flags: range
values: 0 1
value: 0
48 0 0 0,0 0,0 0 0x00000001
props:
7 type:
value: 0
16 FB_ID:
flags: object
value: 0
17 IN_FENCE_FD:
flags: signed range
value: -1
19 CRTC_ID:
flags: object
value: 0
12 CRTC_X:
flags: signed range
value: 0
13 CRTC_Y:
flags: signed range
value: 0
14 CRTC_W:
flags: range
value: 0
15 CRTC_H:
flags: range
value: 0
8 SRC_X:
flags: range
value: 0
9 SRC_Y:
flags: range
value: 0
10 SRC_W:
flags: range
value: 0
11 SRC_H:
flags: range
value: 0
49 rotation:
flags: bitmask
value: 1
28 zorder:
flags: range
values: 0 3
value: 3
50 zpos:
flags: range
values: 0 3
value: 3
51 COLOR_ENCODING:
flags: enum
value: 0
52 COLOR_RANGE:
flags: enum
value: 1
29 global_alpha:
flags: range
values: 0 255
value: 255
30 pre_mult_alpha:
flags: range
values: 0 1
value: 0
Frame buffers:
id size pitch
Here is the weston log, first for the kernel 4.19 then for kernel 4.4
Date: 2020-02-19 EST
[18:15:27.986] weston 1.9.0
http://wayland.freedesktop.org
Bug reports to: bugs.freedesktop.org/enter_bug.cgi
Build: 1.8.93-2-gb05cdb8 configure.ac: bump to version 1.9.0 for the official relea
[18:15:27.986] OS: Linux, 4.4.45-actia-RevD-g89944627d5, #11 SMP PREEMPT Fri Mar 29 16:13:47 EDT 2
[18:15:27.993] Using config file '/etc//weston.ini'
[18:15:27.995] Loading module '/usr/lib/weston/drm-backend.so'
[18:15:28.039] Output repaint window is 7 ms maximum.
[18:15:28.039] initializing drm backend
[18:15:28.051] using /dev/dri/card0
[18:15:28.052] Loading module '/usr/lib/weston/gl-renderer.so'
loaded module : gbm_pvr.so
found valid GBM backend : gbm_pvr.so
[18:15:28.103] warning: either no EGL_EXT_platform_base support or specific platform support; fall
[18:15:28.112] warning: EGL_EXT_buffer_age not supported. Performance could be affected.
[18:15:28.112] Retrieving EGL client extension string failed.
[18:15:28.150] input device 'Dell Dell USB Keyboard', /dev/input/event1 is tagged by udev as: Keyb
[18:15:28.150] input device 'Dell Dell USB Keyboard', /dev/input/event1 is a keyboard
[18:15:28.205] input device 'Logitech USB Optical Mouse', /dev/input/event2 is tagged by udev as:
[18:15:28.205] input device 'Logitech USB Optical Mouse', /dev/input/event2 is a pointer caps
[18:15:28.206] input device 'eGalax_Touch_Screen', /dev/input/event0 is tagged by udev as: Touchsc
[18:15:28.206] input device 'eGalax_Touch_Screen', /dev/input/event0 is a touch device
[18:15:28.471] EGL version: 1.4 build 1.14@3699939 (MAIN)
[18:15:28.471] EGL vendor: Imagination Technologies
[18:15:28.471] EGL client APIs: OpenGL_ES
[18:15:28.471] EGL extensions: EGL_IMG_client_api_ogl EGL_KHR_image
EGL_KHR_image_base EGL_KHR_gl_texture_2D_image
EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image
EGL_KHR_vg_parent_image EGL_IMG_cl_image EGL_KHR_fence_sync
EGL_IMG_context_priority EGL_IMG_hibernate_process
EGL_IMG_image_plane_attribs EGL_KHR_surfaceless_context
EGL_KHR_wait_sync EGL_KHR_create_context
EGL_WL_bind_wayland_display EGL_EXT_image_dma_buf_import
[18:15:28.471] GL version: OpenGL ES 2.0 build 1.14@3699939 (MAIN)
[18:15:28.471] GLSL version: OpenGL ES GLSL ES 1.00 build 1.14@3699939 (MAIN)
[18:15:28.471] GL vendor: Imagination Technologies
[18:15:28.471] GL renderer: PowerVR SGX 544MP
[18:15:28.471] GL extensions: GL_OES_rgb8_rgba8 GL_OES_depth24
GL_OES_vertex_half_float GL_OES_texture_float
GL_OES_texture_half_float GL_OES_element_index_uint
GL_OES_mapbuffer GL_OES_fragment_precision_high
GL_OES_compressed_ETC1_RGB8_texture GL_OES_EGL_image
GL_OES_EGL_image_external GL_OES_required_internalformat
GL_OES_depth_texture GL_OES_get_program_binary
GL_OES_packed_depth_stencil GL_OES_standard_derivatives
GL_OES_vertex_array_object GL_OES_egl_sync GL_OES_texture_npot
GL_OES_surfaceless_context GL_EXT_discard_framebuffer
GL_EXT_blend_minmax GL_EXT_multi_draw_arrays
GL_EXT_multisampled_render_to_texture GL_EXT_shader_texture_lod
GL_EXT_texture_format_BGRA8888 GL_EXT_occlusion_query_boolean
GL_EXT_texture_rg GL_EXT_draw_buffers
GL_EXT_shader_framebuffer_fetch GL_IMG_shader_binary
GL_IMG_texture_compression_pvrtc
GL_IMG_texture_compression_pvrtc2 GL_IMG_texture_npot
GL_IMG_texture_format_BGRA8888 GL_IMG_read_format
GL_IMG_program_binary GL_IMG_uniform_buffer_object
GL_IMG_multisampled_render_to_texture GL_KHR_debug
[18:15:28.471] GL ES 2 renderer features:
read-back format: RGBA
wl_shm sub-image to texture: no
EGL Wayland extension: yes
[18:15:28.471] Chosen EGL config details:
RGBA bits: 8 8 8 8
swap interval range: 1 - 1
[18:15:28.471] cursor buffers unavailable, using gl cursors
[18:15:28.472] Failed to initialize backlight
[18:15:28.472] Output Unknown-1, (connector 32, crtc 34)
mode 1920x720@60.0, preferred, current
[18:15:28.472] Compositor capabilities:
arbitrary surface rotation: yes
screen capture uses y-flip: yes
presentation clock: CLOCK_MONOTONIC, id 1
[18:15:28.498] Loading module '/usr/lib/weston/desktop-shell.so'
[18:15:28.501] launching '/usr/libexec/weston-keyboard'
[18:15:28.502] launching '/usr/libexec/weston-desktop-shell'
[18:15:28.528] input device 'Logitech USB Optical Mouse', /dev/input/event2 is tagged by udev as:
[18:15:28.528] input device 'Logitech USB Optical Mouse', /dev/input/event2 is a pointer caps
[18:15:28.686] Warning: computed repaint delay is insane: -16712 msec
Date: 2020-02-19 UTC
[22:52:16.504] weston 5.0.0
Bug reports to: gitlab.freedesktop.org/.../
Build: unknown (not built from git or tarball)
[22:52:16.504] Command line: weston --idle-time=0
[22:52:16.504] OS: Linux, 4.19.73-actia-g31275c05a1, #1 SMP PREEMPT Wed Feb 19 22:25:39 UTC 2020, armv7l
[22:52:16.505] Using config file '/etc//weston.ini'
[22:52:16.513] Output repaint window is 7 ms maximum.
[22:52:16.515] Loading module '/usr/lib/libweston-5/drm-backend.so'
[22:52:16.541] initializing drm backend
[22:52:16.554] using /dev/dri/card0
[22:52:16.555] DRM: supports universal planes
[22:52:16.555] DRM: supports atomic modesetting
[22:52:16.555] DRM: supports picture aspect ratio
[22:52:16.558] Loading module '/usr/lib/libweston-5/gl-renderer.so'
[22:52:16.647] warning: either no EGL_EXT_platform_base support or specific platform support; falling back to eglGetDis
[22:52:16.657] failed to initialize display
[22:52:16.657] EGL error state: EGL_BAD_ALLOC (0x3003)
[22:52:16.657] failed to initialize egl
[22:52:16.701] fatal: failed to create compositor backend
[22:52:16.701] Internal warning: debug scope 'drm-backend' has not been destroyed.
PVR:(Error): OpenServices: PVRDRMOpenRender failed [0, ]
PVR:(Error): PVRSRVConnect: Unable to open connection. [0, ]
PVR:(Error): Couldn't connect to services [0, ]
Michel Catudal
ACTIA Corp
