Compiler/TDA2SX: SD+NFS boot
Part Number: TDA2SX
Other Parts Discussed in Thread: DRA742, DRA752, PMP
HI dear TIer;
I work on tda2sx linux mode.
Firstly I boot the system with SD only mode, it can login with root.
Then I boot with SD + NFD, when i login with root, it show incorrect.
Arago 2019.09 dra7xx-evm ttyS0
dra7xx-evm login: root
Login incorrect
Following is the boot log,  How can i solve the problem?  Thanks!
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.19.73-00040-g3d03684 (root@tfy-OptiPlex-390) (gcc version 8.3.0 (GNU Toolchain for the A-profile Architecture 8.3-2019.03 (arm-rel-8.36))) #2 SMP PREEMPT Fri Feb 28 17:22:50 CST 2020
[    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] OF: fdt: Machine model: TI DRA742
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000040300000, size 3 MiB
[    0.000000] OF: reserved mem: initialized node cmem@40300000, compatible id shared-dma-pool
[    0.000000] Reserved memory: regions without no-map are not yet supported
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 80 MiB
[    0.000000] OF: reserved mem: initialized node ipu2-memory@95800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x000000009e000000, size 32 MiB
[    0.000000] OF: reserved mem: initialized node ipu1-memory@9d000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x00000000a1000000, size 32 MiB
[    0.000000] OF: reserved mem: initialized node dsp1-memory@99000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x00000000a3000000, size 32 MiB
[    0.000000] OF: reserved mem: initialized node dsp2-memory@9f000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 32 MiB
[    0.000000] OF: reserved mem: initialized node cmem@A9000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x00000000b0000000, size 64 MiB
[    0.000000] OF: reserved mem: initialized node gpu-memory@c0000000, compatible id shared-dma-pool
[    0.000000] cma: Reserved 64 MiB at 0x00000000bbc00000
[    0.000000] OMAP4: Map 0x00000000bfd00000 to (ptrval) for dram barrier
[    0.000000] DRA752 ES1.1
[    0.000000] random: get_random_bytes called from start_kernel+0xb4/0x470 with crng_init=0
[    0.000000] percpu: Embedded 16 pages/cpu s36492 r8192 d20852 u65536
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 251456
[    0.000000] Kernel command line: console=ttyO0,115200n8 vram=16M root=/dev/nfs rw nfsroot=172.21.30.88:/home/tfy/vsdk_linux/ti_components/os_tools/linux/targetfs rootwait ip=dhcp mem=1024M cma=64M
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 280708K/1012736K available (10240K kernel code, 341K rwdata, 2804K rodata, 2048K init, 269K bss, 420732K reserved, 311296K cma-reserved, 128000K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (12256 kB)
[    0.000000]       .init : 0x(ptrval) - 0x(ptrval)   (2048 kB)
[    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 342 kB)
[    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 270 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000]  Tasks RCU enabled.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] OMAP clockevent source: timer1 at 32786 Hz
[    0.000000] arch_timer: cp15 timer(s) running at 6.14MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[    0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[    0.000019] Switching to timer-based delay loop, resolution 162ns
[    0.000296] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[    0.000305] OMAP clocksource: 32k_counter at 32768 Hz
[    0.000760] Console: colour dummy device 80x30
[    0.000780] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[    0.000789] This ensures that you still see kernel messages. Please
[    0.000796] update your kernel commandline.
[    0.000830] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[    0.000847] pid_max: default: 32768 minimum: 301
[    0.000972] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000986] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001534] CPU: Testing write buffer coherency: ok
[    0.001573] CPU0: Spectre v2: using ICIALLU workaround
[    0.001785] /cpus/cpu@0 missing clock-frequency property
[    0.001806] /cpus/cpu@1 missing clock-frequency property
[    0.001818] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.059919] Setting up static identity map for 0x80200000 - 0x80200060
[    0.079933] rcu: Hierarchical SRCU implementation.
[    0.100125] EFI services will not be available.
[    0.119993] smp: Bringing up secondary CPUs ...
[    0.200341] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.200347] CPU1: Spectre v2: using ICIALLU workaround
[    0.200470] smp: Brought up 1 node, 2 CPUs
[    0.200482] SMP: Total of 2 processors activated (24.59 BogoMIPS).
[    0.200490] CPU: All CPU(s) started in HYP mode.
[    0.200498] CPU: Virtualization extensions available.
[    0.200982] devtmpfs: initialized
[    0.219282] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[    0.219543] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.219562] futex hash table entries: 512 (order: 3, 32768 bytes)
[    0.224370] pinctrl core: initialized pinctrl subsystem
[    0.224892] DMI not present or invalid.
[    0.225170] NET: Registered protocol family 16
[    0.226343] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.227273] omap_hwmod: l3_main_2 using broken dt data from ocp
[    0.421567] cpuidle: using governor ladder
[    0.421602] cpuidle: using governor menu
[    0.431687] OMAP GPIO hardware version 0.1
[    0.457329] No ATAGs?
[    0.457407] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.457422] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.457955] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[    0.457967] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[    0.458607] OMAP DMA hardware revision 0.0
[    0.470175] edma 43300000.edma: memcpy is disabled
[    0.473624] edma 43300000.edma: TI EDMA DMA engine driver
[    0.480775] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[    0.482351] evm_3v3: supplied by evm_12v0
[    0.482643] evm_5v0: supplied by evm_12v0
[    0.482944] evm_3v6: supplied by evm_5v0
[    0.486146] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[    0.486317] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[    0.486567] omap-iommu 58882000.mmu: 58882000.mmu registered
[    0.486796] omap-iommu 55082000.mmu: 55082000.mmu registered
[    0.487171] omap-iommu 41501000.mmu: 41501000.mmu registered
[    0.487351] omap-iommu 41502000.mmu: 41502000.mmu registered
[    0.487630] iommu: Adding device 58820000.ipu to group 1
[    0.487710] iommu: Adding device 55020000.ipu to group 2
[    0.487835] iommu: Adding device 40800000.dsp to group 0
[    0.488072] iommu: Adding device 41000000.dsp to group 3
[    0.489192] SCSI subsystem initialized
[    0.490425] palmas 0-0058: IRQ missing: skipping irq request
[    0.510864] palmas 0-0058: Muxing GPIO 2e, PWM 0, LED 0
[    0.512554] SMPS123: supplied by regulator-dummy
[    0.514455] SMPS45: supplied by regulator-dummy
[    0.516332] SMPS6: supplied by regulator-dummy
[    0.518087] SMPS7: supplied by regulator-dummy
[    0.519982] SMPS8: supplied by regulator-dummy
[    0.521728] SMPS9: supplied by regulator-dummy
[    0.522734] LDO1: supplied by regulator-dummy
[    0.531353] LDO2: supplied by regulator-dummy
[    0.541224] LDO3: supplied by regulator-dummy
[    0.551233] LDO4: supplied by regulator-dummy
[    0.551422] random: fast init done
[    0.551985] LDO5: supplied by regulator-dummy
[    0.552708] LDO6: supplied by regulator-dummy
[    0.553433] LDO7: supplied by regulator-dummy
[    0.554169] LDO8: supplied by regulator-dummy
[    0.554902] LDO9: supplied by regulator-dummy
[    0.561268] LDOLN: supplied by regulator-dummy
[    0.571288] LDOUSB: supplied by regulator-dummy
[    0.583907] pcf857x 0-0020: probed
[    0.584486] pcf857x 0-0021: probed
[    0.584666] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[    0.585103] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
[    0.585325] media: Linux media interface: v0.10
[    0.585364] videodev: Linux video capture interface: v2.00
[    0.585439] pps_core: LinuxPPS API ver. 1 registered
[    0.585448] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.585469] PTP clock support registered
[    0.585499] EDAC MC: Ver: 3.0.0
[    0.586270] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[    0.586517] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[    0.587022] Advanced Linux Sound Architecture Driver Initialized.
[    0.587840] clocksource: Switched to clocksource arch_sys_counter
[    0.595853] NET: Registered protocol family 2
[    0.596429] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes)
[    0.596458] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.596521] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.596648] TCP: Hash tables configured (established 8192 bind 8192)
[    0.596717] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.596751] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.596879] NET: Registered protocol family 1
[    0.617316] RPC: Registered named UNIX socket transport module.
[    0.617328] RPC: Registered udp transport module.
[    0.617336] RPC: Registered tcp transport module.
[    0.617344] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.618456] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    0.618666] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[    0.619646] Initialise system trusted keyrings
[    0.619777] workingset: timestamp_bits=14 max_order=18 bucket_order=4
[    0.624661] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.635153] NFS: Registering the id_resolver key type
[    0.635183] Key type id_resolver registered
[    0.635192] Key type id_legacy registered
[    0.635233] ntfs: driver 2.1.32 [Flags: R/O].
[    0.636804] Key type asymmetric registered
[    0.636816] Asymmetric key parser 'x509' registered
[    0.636867] bounce: pool size: 64 pages
[    0.636900] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.636911] io scheduler noop registered
[    0.636920] io scheduler deadline registered
[    0.637026] io scheduler cfq registered (default)
[    0.637036] io scheduler mq-deadline registered
[    0.637046] io scheduler kyber registered
[    0.642883] pinctrl-single 4a003400.pinmux: 282 pins, size 1128
[    0.646881] dra7-pcie 51000000.pcie: Linked as a consumer to phy-4a094000.pciephy.1
[    0.647129] dra7-pcie 51000000.pcie: WA for Errata i870 not applied
[    0.647223] dra7-pcie 51000000.pcie: host bridge /ocp/axi@0/pcie@51000000 ranges:
[    0.647264] dra7-pcie 51000000.pcie:    IO 0x20003000..0x20012fff -> 0x00000000
[    0.647292] dra7-pcie 51000000.pcie:   MEM 0x20013000..0x2fffffff -> 0x20013000
[    1.647573] dra7-pcie 51000000.pcie: Phy link never came up
[    1.647715] dra7-pcie 51000000.pcie: PCI host bridge to bus 0000:00
[    1.647729] pci_bus 0000:00: root bus resource [bus 00-ff]
[    1.647741] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    1.647752] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[    1.653872] PCI: bus0: Fast back to back transfers disabled
[    1.659488] PCI: bus1: Fast back to back transfers enabled
[    1.659531] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff 64bit]
[    1.659550] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    1.659868] pcieport 0000:00:00.0: Signaling PME with IRQ 176
[    1.659997] pcieport 0000:00:00.0: AER enabled with IRQ 176
[    1.664122] evm_1v8: supplied by smps9
[    1.664385] evm_3v3_sw: supplied by sysen1
[    1.664618] aic_dvdd: supplied by evm_3v3_sw
[    1.664705] vtt_fixed: supplied by sysen2
[    1.709502] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    1.713067] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 45, base_baud = 3000000) is a 8250
[    2.917868] console [ttyS0] enabled
[    2.922279] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 46, base_baud = 3000000) is a 8250
[    2.931908] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 47, base_baud = 3000000) is a 8250
[    2.943009] omap_rng 48090000.rng: Random Number Generator ver. 20
[    2.943349] random: crng init done
[    2.963126] brd: module loaded
[    2.972423] loop: module loaded
[    2.976237] vmemexp device MAJOR num = 244
[    2.980406] vmemexp class registered
[    2.984098] /dev/vmemexp device registered
[    2.988234] ioctl DBUFIOC_EXPORT_VIRTMEM = -1072899120
[    3.029441] m25p80 spi0.0: s25fl256s1 (32768 Kbytes)
[    3.034519] 10 fixed-partitions partitions found on MTD device spi0.0
[    3.041017] Creating 10 MTD partitions on "spi0.0":
[    3.045921] 0x000000000000-0x000000010000 : "QSPI.SPL"
[    3.051820] 0x000000010000-0x000000020000 : "QSPI.SPL.backup1"
[    3.058389] 0x000000020000-0x000000030000 : "QSPI.SPL.backup2"
[    3.064897] 0x000000030000-0x000000040000 : "QSPI.SPL.backup3"
[    3.071450] 0x000000040000-0x000000140000 : "QSPI.u-boot"
[    3.077532] 0x000000140000-0x0000001c0000 : "QSPI.u-boot-spl-os"
[    3.084247] 0x0000001c0000-0x0000001d0000 : "QSPI.u-boot-env"
[    3.090714] 0x0000001d0000-0x0000001e0000 : "QSPI.u-boot-env.backup1"
[    3.097859] 0x0000001e0000-0x0000009e0000 : "QSPI.kernel"
[    3.103934] 0x0000009e0000-0x000002000000 : "QSPI.file-system"
[    3.111050] libphy: Fixed MDIO Bus: probed
[    3.177878] davinci_mdio 48485000.mdio: davinci mdio revision 1.6, bus freq 1000000
[    3.185573] davinci_mdio 48485000.mdio: detected phy mask fffffff3
[    3.196011] libphy: 48485000.mdio: probed
[    3.200067] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, driver unknown
[    3.208127] davinci_mdio 48485000.mdio: phy[3]: device 48485000.mdio:03, driver unknown
[    3.216881] cpsw 48484000.ethernet: Detected MACID = 74:da:ea:47:25:5e
[    3.223497] cpsw 48484000.ethernet: initialized cpsw ale version 1.4
[    3.229903] cpsw 48484000.ethernet: ALE Table size 1024
[    3.235192] cpsw 48484000.ethernet: cpts: overflow check period 500 (jiffies)
[    3.243218] cpsw 48484000.ethernet: cpsw: Detected MACID = 74:da:ea:47:25:5f
[    3.251866] i2c /dev entries driver
[    3.260469] cpu cpu0: Linked as a consumer to regulator.10
[    3.266055] cpu cpu0: Linked as a consumer to regulator.32
[    3.273244] sdhci: Secure Digital Host Controller Interface driver
[    3.279554] sdhci: Copyright(c) Pierre Ossman
[    3.285295] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.291824] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22)
[    3.300832] sdhci-omap 4809c000.mmc: Got CD GPIO
[    3.305601] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.31
[    3.312654] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.16
[    3.319536] sdhci-omap 4809c000.mmc: Dropping the link to regulator.16
[    3.326316] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.16
[    3.333198] sdhci-omap 4809c000.mmc: Dropping the link to regulator.16
[    3.339818] sdhci-omap 4809c000.mmc: Dropping the link to regulator.31
[    3.346859] sdhci-omap 480b4000.mmc: Linked as a consumer to regulator.2
[    3.353637] sdhci-omap 480b4000.mmc: Dropping the link to regulator.2
[    3.360186] sdhci-omap 480b4000.mmc: Linked as a consumer to regulator.2
[    3.391710] mmc0: SDHCI controller on 480b4000.mmc [480b4000.mmc] using ADMA
[    3.399538] ti-iodelay 4844a000.padconf: Set reg 0x840 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[    3.408496] ti-iodelay 4844a000.padconf: Set reg 0x848 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[    3.417437] ti-iodelay 4844a000.padconf: Set reg 0x84c Delay(a: 307 g: 0), Elements(C=0 F=6)0x29006
[    3.426610] ti-iodelay 4844a000.padconf: Set reg 0x850 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[    3.435587] ti-iodelay 4844a000.padconf: Set reg 0x854 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[    3.444662] ti-iodelay 4844a000.padconf: Set reg 0x870 Delay(a: 785 g: 0), Elements(C=1 F=3)0x29023
[    3.453884] ti-iodelay 4844a000.padconf: Set reg 0x874 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[    3.462950] ti-iodelay 4844a000.padconf: Set reg 0x878 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[    3.471996] ti-iodelay 4844a000.padconf: Set reg 0x87c Delay(a: 613 g: 0), Elements(C=0 F=13)0x2900d
[    3.481338] ti-iodelay 4844a000.padconf: Set reg 0x880 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[    3.490386] ti-iodelay 4844a000.padconf: Set reg 0x884 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[    3.499457] ti-iodelay 4844a000.padconf: Set reg 0x888 Delay(a: 683 g: 0), Elements(C=1 F=0)0x29020
[    3.508677] ti-iodelay 4844a000.padconf: Set reg 0x88c Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[    3.517723] ti-iodelay 4844a000.padconf: Set reg 0x890 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[    3.526809] ti-iodelay 4844a000.padconf: Set reg 0x894 Delay(a: 835 g: 0), Elements(C=1 F=4)0x29024
[    3.535956] ti-iodelay 4844a000.padconf: Set reg 0x898 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[    3.544896] ti-iodelay 4844a000.padconf: Set reg 0x89c Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[    3.554040] sdhci-omap 480d1000.mmc: Linked as a consumer to regulator.8
[    3.560849] sdhci-omap 480d1000.mmc: Dropping the link to regulator.8
[    3.567386] sdhci-omap 480d1000.mmc: Linked as a consumer to regulator.7
[    3.574187] sdhci-omap 480d1000.mmc: Linked as a consumer to regulator.8
[    3.606684] ti-iodelay 4844a000.padconf: Set reg 0x190 Delay(a: 621 g: 600), Elements(C=1 F=9)0x29029
[    3.615977] ti-iodelay 4844a000.padconf: Set reg 0x194 Delay(a: 300 g: 0), Elements(C=0 F=6)0x29006
[    3.625092] ti-iodelay 4844a000.padconf: Set reg 0x1a8 Delay(a: 739 g: 600), Elements(C=1 F=12)0x2902c
[    3.634461] ti-iodelay 4844a000.padconf: Set reg 0x1ac Delay(a: 240 g: 0), Elements(C=0 F=5)0x29005
[    3.643567] ti-iodelay 4844a000.padconf: Set reg 0x1b4 Delay(a: 812 g: 600), Elements(C=1 F=13)0x2902d
[    3.652935] ti-iodelay 4844a000.padconf: Set reg 0x1b8 Delay(a: 240 g: 0), Elements(C=0 F=5)0x29005
[    3.662041] ti-iodelay 4844a000.padconf: Set reg 0x1c0 Delay(a: 954 g: 600), Elements(C=1 F=16)0x29030
[    3.671430] sdhci-omap 480d1000.mmc: no pinctrl state for sdr104 mode
[    3.677931] ti-iodelay 4844a000.padconf: Set reg 0x1c4 Delay(a: 60 g: 0), Elements(C=0 F=1)0x29001
[    3.686935] ti-iodelay 4844a000.padconf: Set reg 0x1d0 Delay(a: 1340 g: 420), Elements(C=2 F=8)0x29048
[    3.696309] ti-iodelay 4844a000.padconf: Set reg 0x1d8 Delay(a: 935 g: 600), Elements(C=1 F=16)0x29030
[    3.696320] sdhci-omap 480d1000.mmc: no pinctrl state for ddr50 mode
[    3.705677] ti-iodelay 4844a000.padconf: Set reg 0x1dc Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[    3.712067] sdhci-omap 480d1000.mmc: no pinctrl state for sdr50 mode
[    3.720989] ti-iodelay 4844a000.padconf: Set reg 0x1e4 Delay(a: 525 g: 600), Elements(C=0 F=21)0x29015
[    3.727366] sdhci-omap 480d1000.mmc: no pinctrl state for hs200_1_8v mode
[    3.736723] ti-iodelay 4844a000.padconf: Set reg 0x1e8 Delay(a: 120 g: 0), Elements(C=0 F=2)0x29002
[    3.752654] ti-iodelay 4844a000.padconf: Set reg 0x1f0 Delay(a: 767 g: 600), Elements(C=1 F=12)0x2902c
[    3.762021] ti-iodelay 4844a000.padconf: Set reg 0x1f4 Delay(a: 225 g: 0), Elements(C=0 F=4)0x29004
[    3.769230] mmc1: SDHCI controller on 480d1000.mmc [480d1000.mmc] using PIO
[    3.771206] ti-iodelay 4844a000.padconf: Set reg 0x1fc Delay(a: 565 g: 600), Elements(C=0 F=22)0x29016
[    3.787562] ti-iodelay 4844a000.padconf: Set reg 0x200 Delay(a: 60 g: 0), Elements(C=0 F=1)0x29001
[    3.796624] ti-iodelay 4844a000.padconf: Set reg 0x364 Delay(a: 969 g: 600), Elements(C=1 F=17)0x29031
[    3.806115] ti-iodelay 4844a000.padconf: Set reg 0x368 Delay(a: 180 g: 0), Elements(C=0 F=3)0x29003
[    3.816392] ledtrig-cpu: registered to indicate activity on CPUs
[    3.817004] mmc0: new HS200 MMC card at address 0001
[    3.828423] tlv320aic3x-codec 0-0019: Linked as a consumer to regulator.3
[    3.835407] tlv320aic3x-codec 0-0019: Linked as a consumer to regulator.4
[    3.842731] mmcblk0: mmc0:0001 MMC08G 7.25 GiB
[    3.843630] davinci-mcasp 48468000.mcasp: ERRATA i868 workaround is enabled
[    3.847729] mmcblk0boot0: mmc0:0001 MMC08G partition 1 8.00 MiB
[    3.854593] davinci-mcasp 4847c000.mcasp: invalid tdm slots: 0
[    3.860601] mmcblk0boot1: mmc0:0001 MMC08G partition 2 8.00 MiB
[    3.872187] mmcblk0rpmb: mmc0:0001 MMC08G partition 3 128 KiB, chardev (241:0)
[    3.872826] NET: Registered protocol family 10
[    3.890240]  mmcblk0: p1
[    3.894897] Segment Routing with IPv6
[    3.898699] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    3.905085] NET: Registered protocol family 17
[    3.909752] Key type dns_resolver registered
[    3.914156] Registering SWP/SWPB emulation handler
[    3.919004] omap_voltage_late_init: Voltage driver support not added
[    3.925400] Power Management for TI OMAP4+ devices.
[    3.930887] Loading compiled-in X.509 certificates
[    3.952778] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    3.959480] [drm] No driver support for vblank timestamp query.
[    3.965670] [drm] Initialized vdrm 1.0.0 20191105 for 44000000.ocp:vdrm@0 on minor 0
[    4.067229] Console: switching to colour frame buffer device 240x67
[    4.087944] vdrm 44000000.ocp:vdrm@0: fb0: DRM emulated frame buffer device
[    4.095509] dmm 4e000000.dmm: workaround for errata i878 in use
[    4.103006] dmm 4e000000.dmm: initialized all PAT entries
[    4.109070] [drm] Initialized omapdrm 1.0.0 20110917 for omapdrm.0 on minor 1
[    4.117292] omap_gpio 4805d000.gpio: Could not set line 27 debounce to 200000 microseconds (-22)
[    4.126143] sdhci-omap 4809c000.mmc: Got CD GPIO
[    4.130955] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.31
[    4.138023] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.16
[    4.144893] sdhci-omap 4809c000.mmc: Dropping the link to regulator.16
[    4.151534] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.36
[    4.158566] sdhci-omap 4809c000.mmc: Linked as a consumer to regulator.16
[    4.165491] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_1_8v mode
[    4.172163] sdhci-omap 4809c000.mmc: no pinctrl state for ddr_3_3v mode
[    4.178824] sdhci-omap 4809c000.mmc: no pinctrl state for hs200_1_8v mode
[    4.210810] mmc2: SDHCI controller on 4809c000.mmc [4809c000.mmc] using ADMA
[    4.219581] asoc-simple-card sound0: tlv320aic3x-hifi <-> 48468000.mcasp mapping ok
[    4.227307] asoc-simple-card sound0: ASoC: no DMI vendor name!
[    4.236544] input: gpio_keys as /devices/platform/gpio_keys/input/input0
[    4.243612] hctosys: unable to open rtc device (rtc0)
[    4.249796] net eth0: initializing cpsw version 1.15 (0)
[    4.262470] Generic PHY 48485000.mdio:02: attached PHY driver [Generic PHY] (mii_bus:phy_addr=48485000.mdio:02, irq=POLL)
[    4.277073] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    4.283309] net eth1: initializing cpsw version 1.15 (0)
[    4.295267] Generic PHY 48485000.mdio:03: attached PHY driver [Generic PHY] (mii_bus:phy_addr=48485000.mdio:03, irq=POLL)
[    4.308383] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[    4.448976] mmc2: host does not support reading read-only switch, assuming write-enable
[    4.462438] ti-iodelay 4844a000.padconf: Set reg 0x620 Delay(a: 1063 g: 17), Elements(C=1 F=9)0x29029
[    4.471733] ti-iodelay 4844a000.padconf: Set reg 0x628 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[    4.480666] ti-iodelay 4844a000.padconf: Set reg 0x62c Delay(a: 23 g: 0), Elements(C=0 F=0)0x29000
[    4.489707] ti-iodelay 4844a000.padconf: Set reg 0x634 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[    4.498638] ti-iodelay 4844a000.padconf: Set reg 0x638 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[    4.507564] ti-iodelay 4844a000.padconf: Set reg 0x640 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[    4.516495] ti-iodelay 4844a000.padconf: Set reg 0x644 Delay(a: 2 g: 0), Elements(C=0 F=0)0x29000
[    4.525447] ti-iodelay 4844a000.padconf: Set reg 0x64c Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[    4.534380] ti-iodelay 4844a000.padconf: Set reg 0x650 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[    4.543317] ti-iodelay 4844a000.padconf: Set reg 0x658 Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[    4.552263] ti-iodelay 4844a000.padconf: Set reg 0x65c Delay(a: 0 g: 0), Elements(C=0 F=0)0x29000
[    4.567167] mmc2: new ultra high speed SDR104 SDHC card at address aaaa
[    4.574541] mmcblk2: mmc2:aaaa SC32G 29.7 GiB
[    4.593574]  mmcblk2: p1 p2
[    5.367662] cpsw 48484000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[    5.387879] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[    5.417913] Sending DHCP requests ., OK
[    5.461747] IP-Config: Got DHCP answer from 172.21.100.1, my address is 172.21.100.119
[    5.469997] IP-Config: Complete:
[    5.473269]      device=eth0, hwaddr=74:da:ea:47:25:5e, ipaddr=172.21.100.119, mask=255.255.255.0, gw=172.21.100.1
[    5.483704]      host=172.21.100.119, domain=, nis-domain=(none)
[    5.489788]      bootserver=0.0.0.0, rootserver=172.21.30.88, rootpath=
[    5.489795]      nameserver0=172.21.0.20, nameserver1=172.21.0.10
[    5.506074] aic_dvdd: disabling
[    5.509416] ldousb: disabling
[    5.512673] ALSA device list:
[    5.515651]   #0: DRA7xx-EVM
[    5.536811] VFS: Mounted root (nfs filesystem) on device 0:15.
[    5.543191] devtmpfs: mounted
[    5.547299] Freeing unused kernel memory: 2048K
[    5.551995] Run /sbin/init as init process
[    5.930749] systemd[1]: System time before build time, advancing clock.
[    5.954306] systemd[1]: Configuration file /etc/systemd/system.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[    5.967871] systemd[1]: Configuration file /etc/systemd/system.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.000555] systemd[1]: systemd 239 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN2 -IDN -PCRE2 default-hierarchy=hybrid)
[    6.022401] systemd[1]: Detected architecture arm.
Welcome to Arago 2019.09!
[    6.068846] systemd[1]: Set hostname to <dra7xx-evm>.
[    6.270293] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[    6.284849] systemd[1]: Configuration file /lib/systemd/system/local-fs.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.312179] systemd[1]: Configuration file /lib/systemd/system/swap.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[    6.326363] systemd[1]: Configuration file /lib/systemd/system/swap.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.342607] systemd[1]: Configuration file /lib/systemd/system/umount.target is marked executable. Please remove executable permission bits. Proceeding anyway.
[    6.356969] systemd[1]: Configuration file /lib/systemd/system/umount.target is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
[    6.373976] systemd[1]: Configuration file /lib/systemd/system/systemd-journald.socket is marked executable. Please remove executable permission bits. Proceeding anyway.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Listening on udev Kernel Socket.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Reached target Paths.
[  OK  ] Listening on Journal Socket.
[  OK  ] Reached target Swap.
[  OK  ] Listening on Journal Socket (/dev/log).
         Mounting Temporary Directory (/tmp)...
[  OK  ] Created slice system-getty.slice.
         Mounting Kernel Debug File System...
[  OK  ] Listening on Process Core Dump Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[  OK  ] Listening on initctl Compatibility Named Pipe.
[  OK  ] Created slice User and Session Slice.
[  OK  ] Listening on udev Control Socket.
         Starting udev Coldplug all Devices...
[  OK  ] Reached target Slices.
         Starting Load Kernel Modules...
         Starting Remount Root and Kernel File Systems...
[  OK  ] Reached target Remote File Systems.
         Starting Journal Service...
         Mounting POSIX Message Queue File System...
[    7.395888] systemd-journald[112]: Configuration file /etc/systemd/journald.conf is marked executable. Please remove executable permission bits. Proceeding anyway.
[    7.412279] systemd-journald[112]: Configuration file /etc/systemd/journald.conf is marked world-writable. Please remove world writability permission bits. Proceeding anyway.
         Starting Create list of required st…ce nodes for the current kernel...
[  OK  ] Mounted Temporary Directory (/tmp).
[  OK  ] Mounted Kernel Debug File System.
[  OK  ] Started Journal Service.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[  OK  ] Started Remount Root and Kernel File Systems.
[  OK  ] Mounted POSIX Message Queue File System.
[  OK  ] Started Create list of required sta…vice nodes for the current kernel.
         Starting Create Static Device Nodes in /dev...
         Starting Apply Kernel Variables...
         Mounting Kernel Configuration File System...
         Starting Flush Journal to Persistent Storage...
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Started Apply Kernel Variables.
[  OK  ] Mounted Kernel Configuration File System.
[    7.925981] systemd-journald[112]: Received request to flush runtime journal from PID 1
         Starting udev Kernel Device Manager...
[  OK  ] Reached target Local File Systems (Pre).
[  OK  ] Reached target Containers.
         Mounting /var/volatile...
         Mounting /media/ram...
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Mounted /var/volatile.
[  OK  ] Mounted /media/ram.
[  OK  ] Started udev Coldplug all Devices.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
[    8.369253] omap-rproc 58820000.ipu: ignoring dependency for device, assuming no driver
         Starting Create Volatile Files and Directories...
[    8.387973] omap-rproc 58820000.ipu: ignoring dependency for device, assuming no driver
[    8.403720] omap-rproc 58820000.ipu: assigned reserved memory node ipu1-memory@9d000000
[    8.427416] remoteproc remoteproc0: 58820000.ipu is available
[    8.451239] omap-rproc 55020000.ipu: ignoring dependency for device, assuming no driver
[    8.459603] omap-rproc 55020000.ipu: ignoring dependency for device, assuming no driver
[    8.468875] omap-rproc 55020000.ipu: assigned reserved memory node ipu2-memory@95800000
[    8.478413] remoteproc remoteproc1: 55020000.ipu is available
[    8.485159] omap-rproc 40800000.dsp: ignoring dependency for device, assuming no driver
[    8.495897] remoteproc remoteproc0: Direct firmware load for dra7-ipu1-fw.xem4 failed with error -2
[    8.511744] omap-rproc 40800000.dsp: ignoring dependency for device, assuming no driver
[    8.520824] remoteproc remoteproc0: powering up 58820000.ipu
[    8.526859] omap-rproc 40800000.dsp: assigned reserved memory node dsp1-memory@99000000
[    8.542554] remoteproc remoteproc0: Direct firmware load for dra7-ipu1-fw.xem4 failed with error -2
[    8.558539] remoteproc remoteproc2: 40800000.dsp is available
[    8.567929] remoteproc remoteproc0: request_firmware failed: -2
[    8.577434] omap-rproc 41000000.dsp: ignoring dependency for device, assuming no driver
[    8.590883] omap-rproc 41000000.dsp: ignoring dependency for device, assuming no driver
[  OK  ] Started Load/Save Random Seed.
[    8.600716] omap-rproc 41000000.dsp: assigned reserved memory node dsp2-memory@9f000000
[    8.616914] remoteproc remoteproc3: 41000000.dsp is available
[    8.821119] remoteproc remoteproc2: powering up 40800000.dsp
[    8.826820] remoteproc remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 604600
[    8.835869] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[    8.842251] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[    8.889158] remoteproc remoteproc3: powering up 41000000.dsp
[    8.903174] remoteproc remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size 604600
[    8.945177] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
[    8.951126] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
[    9.004466] virtio_rpmsg_bus virtio0: rpmsg host is online
[    9.014942] remoteproc remoteproc2: registered virtio0 (type 7)
[    9.022195] remoteproc remoteproc2: remote processor 40800000.dsp is now up
[    9.091388] virtio_rpmsg_bus virtio1: rpmsg host is online
[    9.107122] remoteproc remoteproc3: registered virtio1 (type 7)
[    9.114076] remoteproc remoteproc3: remote processor 41000000.dsp is now up
[  OK  ] Started Create Volatile Files and Directories.
[    9.408645] remoteproc remoteproc1: powering up 55020000.ipu
[    9.431175] remoteproc remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 4616732
[    9.463350] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[  OK  ] Found device /dev/ttyS0.
         Starting Update UTMP about System Boot/Shutdown...
         Starting Network Time Synchronization...
[    9.580232] virtio_rpmsg_bus virtio2: rpmsg host is online
         Starting Network Service...
[    9.594866] remoteproc remoteproc1: registered virtio2 (type 7)
[    9.607006] remoteproc remoteproc1: remote processor 55020000.ipu is now up
[    9.723474] Driver for 1-wire Dallas network protocol.
[    9.783625] virtio_rpmsg_bus virtio2: creating channel rpmsg-proto addr 0x50
[    9.803419] virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x50
[    9.808016] omap_hdq 480b2000.1w: OMAP HDQ Hardware Rev 0.:. Driver in Interrupt mode
[    9.813351] virtio_rpmsg_bus virtio1: creating channel rpmsg-proto addr 0x50
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[    9.849926] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[    9.856558] omap-des 480a5000.des: will run requests pump with realtime priority
[    9.883255] omap_rtc 48838000.rtc: registered as rtc0
[   10.043850] w1_master_driver w1_bus_master1: Attaching one wire slave 01.000000000000 crc 3d
[   10.110718] w1_master_driver w1_bus_master1: Family 1 for 01.000000000000.3d is not registered.
[  OK  ] Started Network Service.
         Starting Network Name Resolution...
[  OK  ] Started Network Time Synchronization.
[   10.455556] phy phy-4a084000.phy.3: Linked as a consumer to regulator.26
[   10.465001] phy phy-4a085000.phy.4: Linked as a consumer to regulator.26
[  OK  ] Started Network Name Resolution.
[  OK  ] Reached target Host and Network Name Lookups.
[   10.847085] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[  OK  ] Reached target Network.
[  OK  ] Reached target System Initialization.
[  OK  ] Started Daily Cleanup of Temporary Directorie[   10.928719] CAN device driver interface
s.
[  OK  ] Reached target Timers.
[   10.961124] ahci 4a140000.sata: controller can't do 64bit DMA, forcing 32bit
[   10.968853] ahci 4a140000.sata: forcing port_map 0x0 -> 0x1
[   10.974875] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[   10.984607] ahci 4a140000.sata: flags: ncq sntf pm led clo only pmp pio slum part ccc apst
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[   11.008464] scsi host0: ahci
[   11.012056] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 85
[   11.023902] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[   11.035237] omap-aes 4b500000.aes: will run requests pump with realtime priority
[  OK  ] Listening on D-Bus System Message Bus Socket.
[   11.057061] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[   11.073620] omap-aes 4b700000.aes: will run requests pump with realtime priority
[   11.099133] c_can_platform 4ae3c000.can: c_can_platform device registered (regs=ac03828f, irq=98)
[  OK  ] Listening on dropbear.socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.
         Starting Login Service...
         Starting Permit User Sessions...
         Starting rc.pvr.service...
         Starting TI IPC Daemon...
[   11.347903] ata1: SATA link down (SStatus 0 SControl 300)
[  OK  ] Started D-Bus System Message Bus.
         Starting Avahi mDNS/DNS-SD Stack...
[  OK  ] Reached target System Time Synchronized.
[  OK  ] Started Permit User Sessions.
[  OK  ] Started TI IPC Daemon.
[   12.109582] pvrsrvkm: loading out-of-tree module taints kernel.
[   12.125048] pvrsrvkm 56000000.gpu: assigned reserved memory node gpu-memory@c0000000
[   12.201587] [drm] Initialized pvr 1.17.4948957 20110701 for 56000000.gpu on minor 2
[   12.373669] PVR_K: UM DDK-(4948957) and KM DDK-(4948957) match. [ OK ]
[  OK  ] Started rc.pvr.service.
[   14.231826] NET: Registered protocol family 45
[   14.441886] dwc3 48890000.usb: Failed to get clk 'ref': -2
[   14.452632] dwc3 48890000.usb: changing max_speed on rev 5533202a
[   14.459626] dwc3 488d0000.usb: Failed to get clk 'ref': -2
[   14.787464] usbcore: registered new interface driver usbfs
[   14.794611] usbcore: registered new interface driver hub
[   14.801288] usbcore: registered new device driver usb
[   14.984459] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[   14.990115] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[   14.999621] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x0000000002010010
[   15.009200] xhci-hcd xhci-hcd.0.auto: irq 184, io mem 0x488d0000
[   15.015549] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[   15.023937] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   15.031250] usb usb1: Product: xHCI Host Controller
[   15.036177] usb usb1: Manufacturer: Linux 4.19.73-00040-g3d03684 xhci-hcd
[   15.043064] usb usb1: SerialNumber: xhci-hcd.0.auto
[   15.049202] hub 1-0:1.0: USB hub found
[   15.053031] hub 1-0:1.0: 1 port detected
[   15.057952] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[   15.063512] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[   15.071254] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[   15.077930] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[   15.086180] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[   15.094533] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[   15.102809] usb usb2: Product: xHCI Host Controller
[   15.107736] usb usb2: Manufacturer: Linux 4.19.73-00040-g3d03684 xhci-hcd
[   15.114599] usb usb2: SerialNumber: xhci-hcd.0.auto
[   15.120566] hub 2-0:1.0: USB hub found
[   15.124386] hub 2-0:1.0: 1 port detected
[  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
         Starting Save/Restore Sound Card State...
[  OK  ] Created slice system-systemd\x2dfsck.slice.
         Starting File System Check on /dev/mmcblk2p1...
         Starting File System Check on /dev/mmcblk2p2...
         Starting File System Check on /dev/mmcblk0p1...
         Starting weston.service...
[  OK  ] Started Serial Getty on ttyS0.
[  OK  ] Started Getty on tty1.
[  OK  ] Reached target Login Prompts.
         Starting Synchronize System and HW clocks...
[  OK  ] Started Save/Restore Sound Card State.
[  OK  ] Started File System Check on /dev/mmcblk2p1.
[  OK  ] Started Synchronize System and HW clocks.
         Mounting /run/media/mmcblk2p1...
[  OK  ] Reached target Sound Card.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Started Login Service.
[  OK  ] Started weston.service.
         Starting telnetd.service...
[   19.536249] FAT-fs (mmcblk2p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[  OK  ] Mounted /run/media/mmcblk2p1.
[  OK  ] Started File System Check on /dev/mmcblk0p1.
[  OK  ] Started File System Check on /dev/mmcblk2p2.
[  OK  ] Started telnetd.service.
[  OK  ] Reached target Multi-User System.
         Starting Update UTMP about System Runlevel Changes...
         Mounting /run/media/mmcblk2p2...
         Mounting /run/media/mmcblk0p1...
[   19.826420] EXT4-fs (mmcblk2p2): mounted filesystem with ordered data mode. Opts: (null)
[  OK  ] Started Update UTMP about System Runlevel Changes.
[   19.861114] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[  OK  ] Mounted /run/media/mmcblk2p2.
[  OK  ] Mounted /run/media/mmcblk0p1.
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org dra7xx-evm ttyS0
Login incorrect
  • Hi Robert,
    can you make sure you have full permissions on $INSTALL_DIR/ti_components/os_tools/linux/targetfs folder (or the one you use for NFS root).
    Note that only targetfs folder needs to have full permission not the files within.
    You can try:
    cd $INSTALL_DIR/ti_components/os_tools/linux/targetfs
    chmod 777 ../targetfs
    Yordan
  • HI Yordan,
    Thanks for your reply.
    I copy targetfs to a new dir under /nfs  and chmod 777.
    I can login with root,
    but if I set the dir to /vs/ti_components/os_tools/linux/targetfs,  and it had been set to 777,
    but login still failed. What would be the problem? Thanks!
    tfy@tfy-OptiPlex-390:/vs/ti_components/os_tools/linux/targetfs$ ls -al ../targetfs/
    total 76
    drwxrwxrwx 19 tfy tfy 4096 3月   3 15:29 .
    drwxrwxrwx  9 tfy tfy 4096 3月   2 18:11 ..
    drwxrwxrwx  2 tfy tfy 4096 3月   2 18:10 bin
    drwxrwxrwx  2 tfy tfy 4096 3月   2 18:10 boot
    drwxrwxrwx  2 tfy tfy 4096 3月   2 18:10 dev
    drwxrwxrwx 36 tfy tfy 4096 3月   2 18:10 etc
    drwxrwxrwx  3 tfy tfy 4096 3月   2 18:10 home
    drwxrwxrwx  2 tfy tfy 4096 3月   2 18:10 include
    drwxrwxrwx  9 tfy tfy 4096 3月   2 18:10 lib
    lrwxrwxrwx  1 tfy tfy   19 3月   2 18:10 linuxrc -> /bin/busybox.nosuid
    drwxrwxrwx  3 tfy tfy 4096 3月   2 18:10 media
    drwxrwxrwx  3 tfy tfy 4096 3月   2 18:10 mnt
    drwxrwxrwx  4 tfy tfy 4096 3月   2 18:10 opt
    drwxrwxrwx  2 tfy tfy 4096 3月   2 18:10 proc
    drwxrwxrwx  2 tfy tfy 4096 3月   2 18:10 run
    drwxrwxrwx  2 tfy tfy 4096 3月   2 18:10 sbin
    drwxrwxrwx  2 tfy tfy 4096 3月   2 18:10 sys
    drwxrwxrwx  2 tfy tfy 4096 3月   2 18:10 tmp
    drwxrwxrwx 10 tfy tfy 4096 3月   2 18:10 usr
    drwxr-xr-x  9 tfy tfy 4096 3月   2 18:10 var
    Thanks!
  • Hi Robert,
    it should not be the contents of the "targetfs" directory with full permission, but the "targetfs" directory itself.
    Can you post the output of "ls -al /vs/ti_components/os_tools/linux"
    Yordan
  • HI Yourdan,
    ls -al /vs/ti_components/os_tools/linux:
    total 36
    drwxrwxrwx  9 tfy tfy 4096 2月  24 14:37 .
    drwxrwxrwx  5 tfy tfy 4096 2月  24 14:37 ..
    drwxrwxrwx  3 tfy tfy 4096 2月  25 11:08 arm
    drwxrwxrwx  5 tfy tfy 4096 2月  25 11:28 kernel
    drwxrwxrwx  2 tfy tfy 4096 2月  24 14:37 linaro
    drwxrwxrwx  3 tfy tfy 4096 2月  25 14:38 sgx
    drwxrwxrwx 19 tfy tfy 4096 2月  28 17:48 targetfs
    drwxrwxrwx  3 tfy tfy 4096 2月  25 11:12 u-boot
    drwxrwxrwx 10 tfy tfy 4096 2月  24 14:37 xdctools_3_32_01_22_core
  • Hi Robert,
    can you try to delete files in "targetfs" directory and reextract the rootfs and see if the issue persists?
    Yordan
